Commit 3195ef59cb42 ("x86: Do full rtc synchronization with ntp") had
the side-effect of unconditionally enabling the RTC_LIB symbol on x86,
which in turn disables the selection of the CONFIG_RTC and
CONFIG_GEN_RTC drivers that contain a two older implementations of
the CONFIG_RTC_DRV_CMOS driver.
This removes x86 from the list for genrtc, and changes all references
to the asm/rtc.h header to instead point to the interfaces
from linux/mc146818rtc.h.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
As per hpa CE4100 platforms can also disable pnpbios:
http://lkml.kernel.org/r/5702B5C2.7070101@zytor.com
Then Sebastian also recently noted that CE4100 also disables
RTC probe, to do that Sebastian had long ago added the RTC
of_have_populated_dt() check, he noted that it was meant to
skip the RTC probe on all OF platforms but as of now, CE4100
was the only x86 DT using this.
We can just fold this requirement into the platform quirk
then. This now means that all of these match platform quirks
for pnpbios and RTC preferences:
* X86_SUBARCH_XEN
* X86_SUBARCH_LGUEST
* X86_SUBARCH_INTEL_MID
* X86_SUBARCH_CE4100
Also see:
http://lkml.kernel.org/r/570B52EA.60300@linutronix.de
Suggested-by: H. Peter Anvin <hpa@zytor.com>
Suggested-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: andrew.cooper3@citrix.com
Cc: andriy.shevchenko@linux.intel.com
Cc: boris.ostrovsky@oracle.com
Cc: david.vrabel@citrix.com
Cc: ffainelli@freebox.fr
Cc: george.dunlap@citrix.com
Cc: glin@suse.com
Cc: jgross@suse.com
Cc: jlee@suse.com
Cc: josh@joshtriplett.org
Cc: julien.grall@linaro.org
Cc: konrad.wilk@oracle.com
Cc: kozerkov@parallels.com
Cc: lenb@kernel.org
Cc: lguest@lists.ozlabs.org
Cc: linux-acpi@vger.kernel.org
Cc: lv.zheng@intel.com
Cc: matt@codeblueprint.co.uk
Cc: mbizon@freebox.fr
Cc: rjw@rjwysocki.net
Cc: robert.moore@intel.com
Cc: rusty@rustcorp.com.au
Cc: tiwai@suse.de
Cc: toshi.kani@hp.com
Cc: xen-devel@lists.xensource.com
Link: http://lkml.kernel.org/r/1460592286-300-17-git-send-email-mcgrof@kernel.org
This moves the ACPI specific check into the ACPI boot code,
it also takes advantage of the x86_platform.legacy.rtc which
is checked for already on the RTC initialization code. This
lets us remove the nasty #ifdefery and consolidate the checks
to use only one toggle to disable the RTC init code.
The works as RTC is initialized by device_initcall(add_rtc_cmos),
this will run late in boot on start_kernel() during rest_init(),
acpi_parse_fadt() gets called earlier during setup_arch().
Cc: bigeasy@linutronix.de
Cc: glin@suse.com
Cc: jgross@suse.com
Cc: jlee@suse.com
Cc: lenb@kernel.org
Cc: tiwai@suse.de
Link: http://lkml.kernel.org/r/1460592286-300-6-git-send-email-mcgrof@kernel.org
We have 4 types of x86 platforms that disable RTC:
* Intel MID
* Lguest - uses paravirt
* Xen dom-U - uses paravirt
* x86 on legacy systems annotated with an ACPI legacy flag
We can consolidate all of these into a platform specific legacy
quirk set early in boot through i386_start_kernel() and through
x86_64_start_reservations(). This deals with the RTC quirks which
we can rely on through the hardware subarch, the ACPI check can
be dealt with separately.
For Xen things are bit more complex given that the @X86_SUBARCH_XEN
x86_hardware_subarch is shared on for Xen which uses the PV path for
both domU and dom0. Since the semantics for differentiating between
the two are Xen specific we provide a platform helper to help override
default legacy features -- x86_platform.set_legacy_features(). Use
of this helper is highly discouraged, its only purpose should be
to account for the lack of semantics available within your given
x86_hardware_subarch.
As per 0-day, this bumps the vmlinux size using i386-tinyconfig as
follows:
TOTAL TEXT init.text x86_early_init_platform_quirks()
+70 +62 +62 +43
Only 8 bytes overhead total, as the main increase in size is
all removed via __init.
Suggested-by: Ingo Molnar <mingo@kernel.org>
Reviewed-by: Juergen Gross <jgross@suse.com>
Cc: glin@suse.com
Cc: jlee@suse.com
Cc: lenb@kernel.org
Cc: tiwai@suse.de
Link: http://lkml.kernel.org/r/1460592286-300-5-git-send-email-mcgrof@kernel.org
Adding the rtc platform device in non-privileged Xen PV guests causes
an IRQ conflict because these guests do not have legacy PIC and may
allocate irqs in the legacy range.
In a single VCPU Xen PV guest we should have:
/proc/interrupts:
CPU0
0: 4934 xen-percpu-virq timer0
1: 0 xen-percpu-ipi spinlock0
2: 0 xen-percpu-ipi resched0
3: 0 xen-percpu-ipi callfunc0
4: 0 xen-percpu-virq debug0
5: 0 xen-percpu-ipi callfuncsingle0
6: 0 xen-percpu-ipi irqwork0
7: 321 xen-dyn-event xenbus
8: 90 xen-dyn-event hvc_console
But hvc_console cannot get its interrupt because it is already in use
by rtc0 and the console does not work.
genirq: Flags mismatch irq 8. 00000000 (hvc_console) vs. 00000000 (rtc0)
We can avoid this problem by realizing that unprivileged PV guests (both
Xen and lguests) are not supposed to have rtc_cmos device and so
adding it is not necessary.
Privileged guests (i.e. Xen's dom0) do use it but they should not have
irq conflicts since they allocate irqs above legacy range (above
gsi_top, in fact).
Instead of explicitly testing whether the guest is privileged we can
extend pv_info structure to include information about guest's RTC
support.
Reported-and-tested-by: Sander Eikelenboom <linux@eikelenboom.it>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: vkuznets@redhat.com
Cc: xen-devel@lists.xenproject.org
Cc: stable@vger.kernel.org # 4.2+
Link: http://lkml.kernel.org/r/1449842873-2613-1-git-send-email-boris.ostrovsky@oracle.com
__FUNCTION__ hasn't been treated as a string literal since gcc 3.4, so
this only helps people who only test-compile using 3.3 (compiler-gcc3.h
barks at anything older than that). Besides, there are almost no
occurrences of __FUNCTION__ left in the tree.
[akpm@linux-foundation.org: convert remaining __FUNCTION__ references]
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Joe Perches <joe@perches.com>
Building with clang:
CC arch/x86/kernel/rtc.o
arch/x86/kernel/rtc.c:173:29: warning: duplicate 'const' declaration
specifier [-Wduplicate-decl-specifier]
static const char * const const ids[] __initconst =
Remove the duplicate const, it is not needed and causes a warning.
Link: http://lkml.kernel.org/r/1421244475-313-1-git-send-email-colin.king@canonical.com
Pull x86/intel-mid changes from Ingo Molnar:
"Update the 'intel mid' (mobile internet device) platform code as Intel
is rolling out more SoC designs.
This gets rid of most of the 'MRST' platform code in the process,
mostly by renaming and shuffling code around into their respective
'intel-mid' platform drivers"
* 'x86-intel-mid-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, intel-mid: Do not re-introduce usage of obsolete __cpuinit
intel_mid: Move platform device setups to their own platform_<device>.* files
x86: intel-mid: Add section for sfi device table
intel-mid: sfi: Allow struct devs_id.get_platform_data to be NULL
intel_mid: Moved SFI related code to sfi.c
intel_mid: Added custom handler for ipc devices
intel_mid: Added custom device_handler support
intel_mid: Refactored sfi_parse_devs() function
intel_mid: Renamed *mrst* to *intel_mid*
pci: intel_mid: Return true/false in function returning bool
mrst: Fixed indentation issues
mrst: Fixed printk/pr_* related issues
Even though the omission was found only during code review
(originally in the Xen hypervisor, looking through ACPI v5 flags
and their meanings and uses), we shouldn't be creating a
corresponding platform device in that case.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Cc: John Stultz <john.stultz@linaro.org>
Link: http://lkml.kernel.org/r/5265029D02000078000FC4D2@nat28.tlf.novell.com
mrst is used as common name to represent all intel_mid type
soc's. But moorsetwon is just one of the intel_mid soc. So
renamed them to use intel_mid.
This patch mainly renames the variables and related
functions that uses *mrst* prefix with *intel_mid*.
To ensure that there are no functional changes, I have compared
the objdump of related files before and after rename and found
the only difference is symbol and name changes.
Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com>
Link: http://lkml.kernel.org/r/1382049336-21316-6-git-send-email-david.a.cohen@linux.intel.com
Signed-off-by: David Cohen <david.a.cohen@linux.intel.com>
Following files contains code that is common to all intel mid
soc's. So renamed them as below.
mrst/mrst.c -> intel-mid/intel-mid.c
mrst/vrtc.c -> intel-mid/intel_mid_vrtc.c
mrst/early_printk_mrst.c -> intel-mid/intel_mid_vrtc.c
pci/mrst.c -> pci/intel_mid_pci.c
Also, renamed the corresponding header files and made changes
to the driver files that included these header files.
the objdump of renamed files before and after rename and found
that the only difference is file name change.
Link: http://lkml.kernel.org/r/1382049336-21316-4-git-send-email-david.a.cohen@linux.intel.com
All the virtualized platforms (KVM, lguest and Xen) have persistent
wallclocks that have more than one second of precision.
read_persistent_wallclock() and update_persistent_wallclock() allow
for nanosecond precision but their implementation on x86 with
x86_platform.get/set_wallclock() only allows for one second precision.
This means guests may see a wallclock time that is off by up to 1
second.
Make set_wallclock() and get_wallclock() take a struct timespec
parameter (which allows for nanosecond precision) so KVM and Xen
guests may start with a more accurate wallclock time and a Xen dom0
can maintain a more accurate wallclock for guests.
Signed-off-by: John Stultz <john.stultz@linaro.org>
Every 11 minutes ntp attempts to update the x86 rtc with the current
system time. Currently, the x86 code only updates the rtc if the system
time is within +/-15 minutes of the current value of the rtc. This
was done originally to avoid setting the RTC if the RTC was in localtime
mode (common with Windows dualbooting). Other architectures do a full
synchronization and now that we have better infrastructure to detect
when the RTC is in localtime, there is no reason that x86 should be
software limited to a 30 minute window.
This patch changes the behavior of the kernel to do a full synchronization
(year, month, day, hour, minute, and second) of the rtc when ntp requests
a synchronization between the system time and the rtc.
I've used the RTC library functions in this patchset as they do all the
required bounds checking.
Cc: x86@kernel.org
Cc: Matt Fleming <matt.fleming@intel.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: linux-efi@vger.kernel.org
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
[jstultz: Tweak commit message, fold in build fix found by fengguang
Also add select RTC_LIB to X86, per new dependency, as found by prarit]
We shouldn't print the current century every time we read the
RTC.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Link: http://lkml.kernel.org/r/20130104224146.15189.14874.stgit@bhelgaas.mtv.corp.google.com
Move native_read_tsc() to tsc.c to allow profiling to be
re-enabled for rtc.c.
Link: http://lkml.kernel.org/r/1349698050-6560-1-git-send-email-david.vrabel@citrix.com
Intel MID x86 platforms have a memory mapped virtual RTC
instead. No MID platform have the default ports (and
accessing them may do weird stuff).
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Cc: feng.tang@intel.com
Cc: Feng Tang <feng.tang@intel.com>
These files were implicitly getting EXPORT_SYMBOL via device.h
which was including module.h, but that will be fixed up shortly.
By fixing these now, we can avoid seeing things like:
arch/x86/kernel/rtc.c:29: warning: type defaults to ‘int’ in declaration of ‘EXPORT_SYMBOL’
arch/x86/kernel/pci-dma.c:20: warning: type defaults to ‘int’ in declaration of ‘EXPORT_SYMBOL’
arch/x86/kernel/e820.c:69: warning: type defaults to ‘int’ in declaration of ‘EXPORT_SYMBOL_GPL’
[ with input from Randy Dunlap <rdunlap@xenotime.net> and also
from Stephen Rothwell <sfr@canb.auug.org.au> ]
A deadlock was introduced on x86 in commit ef68c8f87ed1 ("x86:
Serialize EFI time accesses on rtc_lock") because efi_get_time()
and friends can be called with rtc_lock already held by
read_persistent_time(), e.g.:
timekeeping_init()
read_persistent_clock() <-- acquire rtc_lock
efi_get_time()
phys_efi_get_time() <-- acquire rtc_lock <DEADLOCK>
To fix this let's push the locking down into the get_wallclock()
and set_wallclock() implementations. Only the clock
implementations that access the x86 RTC directly need to acquire
rtc_lock, so it makes sense to push the locking down into the
rtc, vrtc and efi code.
The virtualization implementations don't require rtc_lock to be
held because they provide their own serialization.
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Acked-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Avi Kivity <avi@redhat.com> [for the virtualization aspect]
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Josh Boyer <jwboyer@gmail.com>
This allows to load the OF driver based informations from the device
tree. Systems without BIOS may need to perform some initialization.
PowerPC creates a PNP device from the OF information and performs this
kind of initialization in their private PCI quirk. This looks more
generic.
This patch also avoids registering the platform RTC driver on X86 if
we have a device tree blob. Otherwise we would setup the device based
on the hardcoded information in arch/x86 rather than the device tree
based one.
[ tglx: Changed "int of_have_populated_dt()" to bool as recommended by
Grant ]
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
Cc: sodaville@linutronix.de
Cc: devicetree-discuss@lists.ozlabs.org
Cc: rtc-linux@googlegroups.com
Cc: Alessandro Zummo <a.zummo@towertech.it>
LKML-Reference: <1298405266-1624-12-git-send-email-bigeasy@linutronix.de>
Occasionally the system gets into a state where the CMOS clock has gotten
slightly ahead of current time and the periodic update of RTC fails. The
message is a nuisance and repeats spamming the log.
See: http://www.ntp.org/ntpfaq/NTP-s-trbl-spec.htm#Q-LINUX-SET-RTC-MMSS
Rather than just removing the message, make it show only once and reduce
severity since it indicates a normal and non urgent condition.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (38 commits)
x86: Move get/set_wallclock to x86_platform_ops
x86: platform: Fix section annotations
x86: apic namespace cleanup
x86: Distangle ioapic and i8259
x86: Add Moorestown early detection
x86: Add hardware_subarch ID for Moorestown
x86: Add early platform detection
x86: Move tsc_init to late_time_init
x86: Move tsc_calibration to x86_init_ops
x86: Replace the now identical time_32/64.c by time.c
x86: time_32/64.c unify profile_pc
x86: Move calibrate_cpu to tsc.c
x86: Make timer setup and global variables the same in time_32/64.c
x86: Remove mca bus ifdef from timer interrupt
x86: Simplify timer_ack magic in time_32.c
x86: Prepare unification of time_32/64.c
x86: Remove do_timer hook
x86: Add timer_init to x86_init_ops
x86: Move percpu clockevents setup to x86_init_ops
x86: Move xen_post_allocator_init into xen_pagetable_setup_done
Fix up conflicts in arch/x86/include/asm/io_apic.h
get/set_wallclock() have already a set of platform dependent
implementations (default, EFI, paravirt). MRST will add another
variant.
Moving them to platform ops simplifies the existing code and minimizes
the effort to integrate new variants.
Signed-off-by: Feng Tang <feng.tang@intel.com>
LKML-Reference: <new-submission>
The persistent clock of some architectures (e.g. s390) have a
better granularity than seconds. To reduce the delta between the
host clock and the guest clock in a virtualized system change the
read_persistent_clock function to return a struct timespec.
Acked-by: John Stultz <johnstul@us.ibm.com>
Cc: Daniel Walker <dwalker@fifo99.com>
LKML-Reference: <20090814134811.013873340@de.ibm.com>
Impact: cleanup
- fix various style problems
- fix header file issues
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Change various rtc related code to use the new bcd2bin/bin2bcd functions
instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
Cc: David Brownell <david-b@pacbell.net>
Most if not all x86 platforms have an RTC device, but sometimes the RTC
is not exposed as a PNP0b00/PNP0b01/PNP0b02 device in PNPBIOS or ACPI:
http://bugzilla.kernel.org/show_bug.cgi?id=11580
https://bugzilla.redhat.com/show_bug.cgi?id=451188
It's best if we can discover the RTC via PNP because then we know
which flavor of device it is, where it lives, and which IRQ it uses.
But if we can't, we should register a platform device using the
compiled-in RTC_PORT/RTC_IRQ resource assumptions.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Reported-by: Rik Theys <rik.theys@esat.kuleuven.be>
Reported-by: shr_msn@yahoo.com.tw
Recently (around 2.6.25) I've noticed that RTC no longer works for me. It
turned out this is because I use pnpacpi=off kernel option to work around
the parport_pc bugs. I always did so, but RTC used to work fine in the
past, and now it have regressed.
The patch fixes the problem by creating the platform device for the RTC
when PNP is disabled. This may also help running the PNP-enabled kernel
on an older PCs.
Signed-off-by: Stas Sergeev <stsp@aknet.ru>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Adam Belay <ambx1@neo.rr.com>
fix code to access CMOS rtc registers so that it does not use inb_p and
outb_p routines, which are deprecated. Extensive research on all known
CMOS RTC chipset timing shows that there is no need for a delay in
accessing the registers of these chips even on old machines. These chipa
are never on an expansion bus, but have always been "motherboard"
resources, either in the processor chipset or explicitly on the
motherboard, and they are not part of the ISA/LPC or PCI buses, so
delays should not be based on bus timing. The reason to fix it:
1) port 80 writes often hang some laptops that use ENE EC chipsets,
esp. those designed and manufactured by Quanta for HP;
2) RTC accesses are timing sensitive, and extra microseconds may matter;
3) the new "io_delay" function is calibrated by expansion bus timing needs,
thus is not appropriate for access to CMOS rtc registers.
Signed-off-by: David P. Reed <dpreed@reed.com>
Acked-by: Alan Cox <alan@redhat.com>
The extended century readout does not solve the year 2038 problem on
32bit!
v2: Fix compilation on !ACPI, pointed out by tglx
Signed-off-by: Andi Kleen <ak@suse.de>
We assume that the RTC clock is BCD, so print a warning if it claims
to be binary.
[ tglx@linutronix.de: changed to WARN_ON - we want to know that!
If no one reports it we can remove the complete if (RTC_ALWAYS_BCD)
magic, which has RTC_ALWAYS_BCD defined to 1 since Linux 1.0 ... ]
We know it is already after 2000. Use the year 2000 offset for both 32
and 64 bit, which removes ifdefs and the 1970 magic.
[ tglx@linutronix.de: remove 1970 magic, replace bogus commit message ]
[ andi@firstfloor.org: build fix ]
make native_read_tsc() always non-speculative.
move native_read_tsc() offline.
Remove the rtc code from time_64.c and add the extra bits to the
i386 path. The ACPI century check is probably valid for i386 as
well, but this is material for a separate patch.
The mach-default/mach_time.h code inline is moved to arch/x86/kernel/rtc.c
and the header files are adjusted.
Shrink the 3 dozen includes to the ones we really need.
