commit 10a70416e1f067f6c4efda6ffd8ea96002ac4223 upstream
The L1TF workaround doesn't make any attempt to mitigate speculate accesses
to the first physical page for zeroed PTEs. Normally it only contains some
data from the early real mode BIOS.
It's not entirely clear that the first page is reserved in all
configurations, so add an extra reservation call to make sure it is really
reserved. In most configurations (e.g. with the standard reservations)
it's likely a nop.
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Dave Hansen <dave.hansen@intel.com>
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
... before the first use of kaiser_enabled as otherwise funky
things happen:
about to get started...
(XEN) d0v0 Unhandled page fault fault/trap [#14, ec=0000]
(XEN) Pagetable walk from ffff88022a449090:
(XEN) L4[0x110] = 0000000229e0e067 0000000000001e0e
(XEN) L3[0x008] = 0000000000000000 ffffffffffffffff
(XEN) domain_crash_sync called from entry.S: fault at ffff82d08033fd08
entry.o#create_bounce_frame+0x135/0x14d
(XEN) Domain 0 (vcpu#0) crashed on cpu#0:
(XEN) ----[ Xen-4.9.1_02-3.21 x86_64 debug=n Not tainted ]----
(XEN) CPU: 0
(XEN) RIP: e033:[<ffffffff81007460>]
(XEN) RFLAGS: 0000000000000286 EM: 1 CONTEXT: pv guest (d0v0)
commit 99c13b8c8896d7bcb92753bf0c63a8de4326e78d upstream.
The pat_enabled() logic is broken on CPUs which do not support PAT and
where the initialization code fails to call pat_init(). Due to that the
enabled flag stays true and pat_enabled() returns true wrongfully.
As a consequence the mappings, e.g. for Xorg, are set up with the wrong
caching mode and the required MTRR setups are omitted.
To cure this the following changes are required:
1) Make pat_enabled() return true only if PAT initialization was
invoked and successful.
2) Invoke init_cache_modes() unconditionally in setup_arch() and
remove the extra callsites in pat_disable() and the pat disabled
code path in pat_init().
Also rename __pat_enabled to pat_disabled to reflect the real purpose of
this variable.
Fixes: 9cd25aac1f44 ("x86/mm/pat: Emulate PAT when it is disabled")
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Bernhard Held <berny156@gmx.de>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: "Luis R. Rodriguez" <mcgrof@suse.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/alpine.LRH.2.02.1707041749300.3456@file01.intranet.prod.int.rdu2.redhat.com
Running microcode_init() from setup_arch() is a bad idea because
not even kmalloc() is ready at that point and the loader does
all kinds of allocations and init/registration with various
subsystems.
Make it a late initcall when required facilities are initialized
so that the microcode driver initialization can succeed too.
Reported-and-tested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20151120112400.GC4028@pd.tnic
The commit f5f3497cad8c extended the low identity mapping. However, if
the kernel uses more than 2 GB (VMSPLIT_2G_OPT or VMSPLIT_1G memory
split), the normal memory mapping is overwritten by the low identity
mapping causing a crash. To avoid overwritting, limit the low identity
map to cover only memory before kernel range (PAGE_OFFSET).
Fixes: f5f3497cad8c "x86/setup: Extend low identity map to cover whole kernel range
Signed-off-by: Krzysztof Mazur <krzysiek@podlesie.net>
Cc: Laszlo Ersek <lersek@redhat.com>
Cc: Matt Fleming <matt.fleming@intel.com>
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/1446815916-22105-1-git-send-email-krzysiek@podlesie.net
Pull RAS changes from Ingo Molnar:
"The main system reliability related changes were from x86, but also
some generic RAS changes:
- AMD MCE error injection subsystem enhancements. (Aravind
Gopalakrishnan)
- Fix MCE and CPU hotplug interaction bug. (Ashok Raj)
- kcrash bootup robustness fix. (Baoquan He)
- kcrash cleanups. (Borislav Petkov)
- x86 microcode driver rework: simplify it by unmodularizing it and
other cleanups. (Borislav Petkov)"
* 'ras-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
x86/mce: Add a default case to the switch in __mcheck_cpu_ancient_init()
x86/mce: Add a Scalable MCA vendor flags bit
MAINTAINERS: Unify the microcode driver section
x86/microcode/intel: Move #ifdef DEBUG inside the function
x86/microcode/amd: Remove maintainers from comments
x86/microcode: Remove modularization leftovers
x86/microcode: Merge the early microcode loader
x86/microcode: Unmodularize the microcode driver
x86/mce: Fix thermal throttling reporting after kexec
kexec/crash: Say which char is the unrecognized
x86/setup/crash: Check memblock_reserve() retval
x86/setup/crash: Cleanup some more
x86/setup/crash: Remove alignment variable
x86/setup: Cleanup crashkernel reservation functions
x86/amd_nb, EDAC: Rename amd_get_node_id()
x86/setup: Do not reserve crashkernel high memory if low reservation failed
x86/microcode/amd: Do not overwrite final patch levels
x86/microcode/amd: Extract current patch level read to a function
x86/ras/mce_amd_inj: Inject bank 4 errors on the NBC
x86/ras/mce_amd_inj: Trigger deferred and thresholding errors interrupts
Pull EFI changes from Ingo Molnar:
"The main changes in this cycle were:
- further EFI code generalization to make it more workable for ARM64
- various extensions, such as 64-bit framebuffer address support,
UEFI v2.5 EFI_PROPERTIES_TABLE support
- code modularization simplifications and cleanups
- new debugging parameters
- various fixes and smaller additions"
* 'core-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
efi: Fix warning of int-to-pointer-cast on x86 32-bit builds
efi: Use correct type for struct efi_memory_map::phys_map
x86/efi: Fix kernel panic when CONFIG_DEBUG_VIRTUAL is enabled
efi: Add "efi_fake_mem" boot option
x86/efi: Rename print_efi_memmap() to efi_print_memmap()
efi: Auto-load the efi-pstore module
efi: Introduce EFI_NX_PE_DATA bit and set it from properties table
efi: Add support for UEFIv2.5 Properties table
efi: Add EFI_MEMORY_MORE_RELIABLE support to efi_md_typeattr_format()
efifb: Add support for 64-bit frame buffer addresses
efi/arm64: Clean up efi_get_fdt_params() interface
arm64: Use core efi=debug instead of uefi_debug command line parameter
efi/x86: Move efi=debug option parsing to core
drivers/firmware: Make efi/esrt.c driver explicitly non-modular
efi: Use the generic efi.memmap instead of 'memmap'
acpi/apei: Use appropriate pgprot_t to map GHES memory
arm64, acpi/apei: Implement arch_apei_get_mem_attributes()
arm64/mm: Add PROT_DEVICE_nGnRnE and PROT_NORMAL_WT
acpi, x86: Implement arch_apei_get_mem_attributes()
efi, x86: Rearrange efi_mem_attributes()
Make CONFIG_MICROCODE a bool. It was practically a bool already anyway,
since early loader was forcing it to =y.
Regardless, there's no real reason to have something be a module which
gets built-in on the majority of installations out there. And its not
like there's noticeable change in functionality - we still can load late
microcode - just the module glue disappears.
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Len Brown <len.brown@intel.com>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Link: http://lkml.kernel.org/r/1445334889-300-2-git-send-email-bp@alien8.de
memblock_reserve() can fail but the crashkernel reservation code
doesn't check that and this can lead the user into believing
that the crashkernel region was actually reserved. Make sure we
check that return value and we exit early with a failure message
in the error case.
Reviewed-by: Dave Young <dyoung@redhat.com>
Reviewed-by: Joerg Roedel <jroedel@suse.de>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Juergen Gross <jgross@suse.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: WANG Chao <chaowang@redhat.com>
Cc: jerry_hoemann@hp.com
Link: http://lkml.kernel.org/r/1445246268-26285-7-git-send-email-bp@alien8.de
* Remove unused auto_set variable
* Cleanup local function variable declarations
* Reformat printk string and use pr_info()
No functionality change.
Link: http://lkml.kernel.org/r/1445246268-26285-6-git-send-email-bp@alien8.de
Use a macro instead. No functionality change.
Link: http://lkml.kernel.org/r/1445246268-26285-5-git-send-email-bp@alien8.de
* Shorten variable names
* Realign code, space out for better readability
No code changed:
# arch/x86/kernel/setup.o:
4543 3096 69904 77543 12ee7 setup.o.before
4543 3096 69904 77543 12ee7 setup.o.after
md5:
8a1b7c6738a553ca207b56bd84a8f359 setup.o.before.asm
8a1b7c6738a553ca207b56bd84a8f359 setup.o.after.asm
Link: http://lkml.kernel.org/r/1445246268-26285-4-git-send-email-bp@alien8.de
People reported that when allocating crashkernel memory using
the ",high" and ",low" syntax, there were cases where the
reservation of the high portion succeeds but the reservation of
the low portion fails.
Then kexec can load the kdump kernel successfully, but booting
the kdump kernel fails as there's no low memory.
The low memory allocation for the kdump kernel can fail on large
systems for a couple of reasons. For example, the manually
specified crashkernel low memory can be too large and thus no
adequate memblock region would be found.
Therefore, we try to reserve low memory for the crash kernel
*after* the high memory portion has been allocated. If that
fails, we free crashkernel high memory too and return. The user
can then take measures accordingly.
Tested-by: Joerg Roedel <jroedel@suse.de>
Signed-off-by: Baoquan He <bhe@redhat.com>
[ Massage text. ]
Cc: Dave Young <dyoung@redhat.com>
Cc: yinghai@kernel.org
Link: http://lkml.kernel.org/r/1445246268-26285-2-git-send-email-bp@alien8.de
On 32-bit systems, the initial_page_table is reused by
efi_call_phys_prolog as an identity map to call
SetVirtualAddressMap. efi_call_phys_prolog takes care of
converting the current CPU's GDT to a physical address too.
For PAE kernels the identity mapping is achieved by aliasing the
first PDPE for the kernel memory mapping into the first PDPE
of initial_page_table. This makes the EFI stub's trick "just work".
However, for non-PAE kernels there is no guarantee that the identity
mapping in the initial_page_table extends as far as the GDT; in this
case, accesses to the GDT will cause a page fault (which quickly becomes
a triple fault). Fix this by copying the kernel mappings from
swapper_pg_dir to initial_page_table twice, both at PAGE_OFFSET and at
identity mapping.
For some reason, this is only reproducible with QEMU's dynamic translation
mode, and not for example with KVM. However, even under KVM one can clearly
see that the page table is bogus:
$ qemu-system-i386 -pflash OVMF.fd -M q35 vmlinuz0 -s -S -daemonize
$ gdb
(gdb) target remote localhost:1234
(gdb) hb *0x02858f6f
Hardware assisted breakpoint 1 at 0x2858f6f
(gdb) c
Continuing.
Breakpoint 1, 0x02858f6f in ?? ()
(gdb) monitor info registers
GDT= 0724e000 000000ff
IDT= fffbb000 000007ff
CR0=0005003b CR2=ff896000 CR3=032b7000 CR4=00000690
The page directory is sane:
(gdb) x/4wx 0x32b7000
0x32b7000: 0x03398063 0x03399063 0x0339a063 0x0339b063
(gdb) x/4wx 0x3398000
0x3398000: 0x00000163 0x00001163 0x00002163 0x00003163
(gdb) x/4wx 0x3399000
0x3399000: 0x00400003 0x00401003 0x00402003 0x00403003
but our particular page directory entry is empty:
(gdb) x/1wx 0x32b7000 + (0x724e000 >> 22) * 4
0x32b7070: 0x00000000
[ It appears that you can skate past this issue if you don't receive
any interrupts while the bogus GDT pointer is loaded, or if you avoid
reloading the segment registers in general.
Andy Lutomirski provides some additional insight:
"AFAICT it's entirely permissible for the GDTR and/or LDT
descriptor to point to unmapped memory. Any attempt to use them
(segment loads, interrupts, IRET, etc) will try to access that memory
as if the access came from CPL 0 and, if the access fails, will
generate a valid page fault with CR2 pointing into the GDT or
LDT."
Up until commit 23a0d4e8fa6d ("efi: Disable interrupts around EFI
calls, not in the epilog/prolog calls") interrupts were disabled
around the prolog and epilog calls, and the functional GDT was
re-installed before interrupts were re-enabled.
Which explains why no one has hit this issue until now. ]
Reported-by: Laszlo Ersek <lersek@redhat.com>
Cc: <stable@vger.kernel.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
[ Updated changelog. ]
git://git.kernel.org/pub/scm/linux/kernel/git/mfleming/efi into core/efi
Pull v4.4 EFI updates from Matt Fleming:
- Make the EFI System Resource Table (ESRT) driver explicitly
non-modular by ripping out the module_* code since Kconfig doesn't
allow it to be built as a module anyway. (Paul Gortmaker)
- Make the x86 efi=debug kernel parameter, which enables EFI debug
code and output, generic and usable by arm64. (Leif Lindholm)
- Add support to the x86 EFI boot stub for 64-bit Graphics Output
Protocol frame buffer addresses. (Matt Fleming)
- Detect when the UEFI v2.5 EFI_PROPERTIES_TABLE feature is enabled
in the firmware and set an efi.flags bit so the kernel knows when
it can apply more strict runtime mapping attributes - Ard Biesheuvel
- Auto-load the efi-pstore module on EFI systems, just like we
currently do for the efivars module. (Ben Hutchings)
- Add "efi_fake_mem" kernel parameter which allows the system's EFI
memory map to be updated with additional attributes for specific
memory ranges. This is useful for testing the kernel code that handles
the EFI_MEMORY_MORE_RELIABLE memmap bit even if your firmware
doesn't include support. (Taku Izumi)
Note: there is a semantic conflict between the following two commits:
8a53554e12e9 ("x86/efi: Fix multiple GOP device support")
ae2ee627dc87 ("efifb: Add support for 64-bit frame buffer addresses")
I fixed up the interaction in the merge commit, changing the type of
current_fb_base from u32 to u64.
This patch introduces new boot option named "efi_fake_mem".
By specifying this parameter, you can add arbitrary attribute
to specific memory range.
This is useful for debugging of Address Range Mirroring feature.
For example, if "efi_fake_mem=2G@4G:0x10000,2G@0x10a0000000:0x10000"
is specified, the original (firmware provided) EFI memmap will be
updated so that the specified memory regions have
EFI_MEMORY_MORE_RELIABLE attribute (0x10000):
<original>
efi: mem36: [Conventional Memory| | | | | | |WB|WT|WC|UC] range=[0x0000000100000000-0x00000020a0000000) (129536MB)
<updated>
efi: mem36: [Conventional Memory| |MR| | | | |WB|WT|WC|UC] range=[0x0000000100000000-0x0000000180000000) (2048MB)
efi: mem37: [Conventional Memory| | | | | | |WB|WT|WC|UC] range=[0x0000000180000000-0x00000010a0000000) (61952MB)
efi: mem38: [Conventional Memory| |MR| | | | |WB|WT|WC|UC] range=[0x00000010a0000000-0x0000001120000000) (2048MB)
efi: mem39: [Conventional Memory| | | | | | |WB|WT|WC|UC] range=[0x0000001120000000-0x00000020a0000000) (63488MB)
And you will find that the following message is output:
efi: Memory: 4096M/131455M mirrored memory
Signed-off-by: Taku Izumi <izumi.taku@jp.fujitsu.com>
Cc: Xishi Qiu <qiuxishi@huawei.com>
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
There are two kexec load syscalls, kexec_load another and kexec_file_load.
kexec_file_load has been splited as kernel/kexec_file.c. In this patch I
split kexec_load syscall code to kernel/kexec.c.
And add a new kconfig option KEXEC_CORE, so we can disable kexec_load and
use kexec_file_load only, or vice verse.
The original requirement is from Ted Ts'o, he want kexec kernel signature
being checked with CONFIG_KEXEC_VERIFY_SIG enabled. But kexec-tools use
kexec_load syscall can bypass the checking.
Vivek Goyal proposed to create a common kconfig option so user can compile
in only one syscall for loading kexec kernel. KEXEC/KEXEC_FILE selects
KEXEC_CORE so that old config files still work.
Because there's general code need CONFIG_KEXEC_CORE, so I updated all the
architecture Kconfig with a new option KEXEC_CORE, and let KEXEC selects
KEXEC_CORE in arch Kconfig. Also updated general kernel code with to
kexec_load syscall.
Signed-off-by: Dave Young <dyoung@redhat.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Petr Tesarik <ptesarik@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
The early_ioremap library now has a generic copy_from_early_mem()
function. Use the generic copy function for x86 relocate_initrd().
[akpm@linux-foundation.org: remove MAX_MAP_CHUNK define, per Yinghai Lu]
Signed-off-by: Mark Salter <msalter@redhat.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Yinghai Lu <yinghai@kernel.org>
The kernel does not support the MCA bus anymroe, so mark sys_desc_table
as obsolete: remove any reference from the code together with the remaining
of MCA logic.
bloat-o-meter output:
add/remove: 0/0 grow/shrink: 0/2 up/down: 0/-55 (-55)
function old new delta
i386_start_kernel 128 119 -9
setup_arch 1421 1375 -46
Signed-off-by: Paolo Pisati <p.pisati@gmail.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Link: http://lkml.kernel.org/r/1437409430-8491-1-git-send-email-p.pisati@gmail.com
Pull x86 fixes from Ingo Molnar:
"Two FPU rewrite related fixes. This addresses all known x86
regressions at this stage. Also some other misc fixes"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/fpu: Fix boot crash in the early FPU code
x86/asm/entry/64: Update path names
x86/fpu: Fix FPU related boot regression when CPUID masking BIOS feature is enabled
x86/boot/setup: Clean up the e820_reserve_setup_data() code
x86/kaslr: Fix typo in the KASLR_FLAG documentation
Merge branch that got ready.
UEFI GetMemoryMap() uses a new attribute bit to mark mirrored memory
address ranges. See UEFI 2.5 spec pages 157-158:
http://www.uefi.org/sites/default/files/resources/UEFI%202_5.pdf
On EFI enabled systems scan the memory map and tell memblock about any
mirrored ranges.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Cc: Xiexiuqi <xiexiuqi@huawei.com>
Cc: Naoya Horiguchi <nao.horiguchi@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching
Pull livepatching fixes from Jiri Kosina:
- symbol lookup locking fix, from Miroslav Benes
- error handling improvements in case of failure of the module coming
notifier, from Minfei Huang
- we were too pessimistic when kASLR has been enabled on x86 and were
dropping address hints on the floor unnecessarily in such case. Fix
from Jiri Kosina
- a few other small fixes and cleanups
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching:
livepatch: add module locking around kallsyms calls
livepatch: annotate klp_init() with __init
livepatch: introduce patch/func-walking helpers
livepatch: make kobject in klp_object statically allocated
livepatch: Prevent patch inconsistencies if the coming module notifier fails
livepatch: match return value to function signature
x86: kaslr: fix build due to missing ALIGN definition
livepatch: x86: make kASLR logic more accurate
x86: introduce kaslr_offset()
Pull x86 core updates from Ingo Molnar:
"There were so many changes in the x86/asm, x86/apic and x86/mm topics
in this cycle that the topical separation of -tip broke down somewhat -
so the result is a more traditional architecture pull request,
collected into the 'x86/core' topic.
The topics were still maintained separately as far as possible, so
bisectability and conceptual separation should still be pretty good -
but there were a handful of merge points to avoid excessive
dependencies (and conflicts) that would have been poorly tested in the
end.
The next cycle will hopefully be much more quiet (or at least will
have fewer dependencies).
* x86/apic changes, with related IRQ core changes: (Jiang Liu, Thomas
Gleixner)
- This is the second and most intrusive part of changes to the x86
interrupt handling - full conversion to hierarchical interrupt
domains:
[IOAPIC domain] -----
[MSI domain] --------[Remapping domain] ----- [ Vector domain ]
| (optional) |
[HPET MSI domain] ----- |
[DMAR domain] -----------------------------
[Legacy domain] -----------------------------
This now reflects the actual hardware and allowed us to distangle
the domain specific code from the underlying parent domain, which
can be optional in the case of interrupt remapping. It's a clear
separation of functionality and removes quite some duct tape
constructs which plugged the remap code between ioapic/msi/hpet
and the vector management.
- Intel IOMMU IRQ remapping enhancements, to allow direct interrupt
injection into guests (Feng Wu)
* x86/asm changes:
- Tons of cleanups and small speedups, micro-optimizations. This
is in preparation to move a good chunk of the low level entry
code from assembly to C code (Denys Vlasenko, Andy Lutomirski,
Brian Gerst)
- Moved all system entry related code to a new home under
arch/x86/entry/ (Ingo Molnar)
- Removal of the fragile and ugly CFI dwarf debuginfo annotations.
Conversion to C will reintroduce many of them - but meanwhile
they are only getting in the way, and the upstream kernel does
not rely on them (Ingo Molnar)
- NOP handling refinements. (Borislav Petkov)
* x86/mm changes:
- Big PAT and MTRR rework: making the code more robust and
preparing to phase out exposing direct MTRR interfaces to drivers -
in favor of using PAT driven interfaces (Toshi Kani, Luis R
Rodriguez, Borislav Petkov)
- New ioremap_wt()/set_memory_wt() interfaces to support
Write-Through cached memory mappings. This is especially
important for good performance on NVDIMM hardware (Toshi Kani)
* x86/ras changes:
- Add support for deferred errors on AMD (Aravind Gopalakrishnan)
This is an important RAS feature which adds hardware support for
poisoned data. That means roughly that the hardware marks data
which it has detected as corrupted but wasn't able to correct, as
poisoned data and raises an APIC interrupt to signal that in the
form of a deferred error. It is the OS's responsibility then to
take proper recovery action and thus prolonge system lifetime as
far as possible.
- Add support for Intel "Local MCE"s: upcoming CPUs will support
CPU-local MCE interrupts, as opposed to the traditional system-
wide broadcasted MCE interrupts (Ashok Raj)
- Misc cleanups (Borislav Petkov)
* x86/platform changes:
- Intel Atom SoC updates
... and lots of other cleanups, fixlets and other changes - see the
shortlog and the Git log for details"
* 'x86-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (222 commits)
x86/hpet: Use proper hpet device number for MSI allocation
x86/hpet: Check for irq==0 when allocating hpet MSI interrupts
x86/mm/pat, drivers/infiniband/ipath: Use arch_phys_wc_add() and require PAT disabled
x86/mm/pat, drivers/media/ivtv: Use arch_phys_wc_add() and require PAT disabled
x86/platform/intel/baytrail: Add comments about why we disabled HPET on Baytrail
genirq: Prevent crash in irq_move_irq()
genirq: Enhance irq_data_to_desc() to support hierarchy irqdomain
iommu, x86: Properly handle posted interrupts for IOMMU hotplug
iommu, x86: Provide irq_remapping_cap() interface
iommu, x86: Setup Posted-Interrupts capability for Intel iommu
iommu, x86: Add cap_pi_support() to detect VT-d PI capability
iommu, x86: Avoid migrating VT-d posted interrupts
iommu, x86: Save the mode (posted or remapped) of an IRTE
iommu, x86: Implement irq_set_vcpu_affinity for intel_ir_chip
iommu: dmar: Provide helper to copy shared irte fields
iommu: dmar: Extend struct irte for VT-d Posted-Interrupts
iommu: Add new member capability to struct irq_remap_ops
x86/asm/entry/64: Disentangle error_entry/exit gsbase/ebx/usermode code
x86/asm/entry/32: Shorten __audit_syscall_entry() args preparation
x86/asm/entry/32: Explain reloading of registers after __audit_syscall_entry()
When the crash kernel is loaded above 4GiB in memory, the
first kernel allocates only 72MiB of low-memory for the DMA
requirements of the second kernel. On systems with many
devices this is not enough and causes device driver
initialization errors and failed crash dumps. Testing by
SUSE and Redhat has shown that 256MiB is a good default
value for now and the discussion has lead to this value as
well. So set this default value to 256MiB to make sure there
is enough memory available for DMA.
Signed-off-by: Joerg Roedel <jroedel@suse.de>
[ Reflow comment. ]
Acked-by: Baoquan He <bhe@redhat.com>
Cc: Jörg Rödel <joro@8bytes.org>
Cc: kexec@lists.infradead.org
Link: http://lkml.kernel.org/r/1433500202-25531-4-git-send-email-joro@8bytes.org
Deobfuscate the 'found' logic, it can be replaced with a simple:
if (!pa_data)
return;
and 'found' can be eliminated.
Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1433398729-8314-1-git-send-email-weiyang@linux.vnet.ibm.com
Offset that has been chosen for kaslr during kernel decompression can be
easily computed as a difference between _text and __START_KERNEL. We are
already making use of this in dump_kernel_offset() notifier and in
arch_crash_save_vmcoreinfo().
Introduce kaslr_offset() that makes this computation instead of hard-coding
it, so that other kernel code (such as live patching) can make use of it.
Also convert existing users to make use of it.
This patch is equivalent transofrmation without any effects on the resulting
code:
$ diff -u vmlinux.old.asm vmlinux.new.asm
--- vmlinux.old.asm 2015-04-28 17:55:19.520983368 +0200
+++ vmlinux.new.asm 2015-04-28 17:55:24.141206072 +0200
@@ -1,5 +1,5 @@
-vmlinux.old: file format elf64-x86-64
+vmlinux.new: file format elf64-x86-64
Disassembly of section .text:
Acked-by: Borislav Petkov <bp@suse.de>
io_apic_ops.init() is either NULL, if IO-APIC support is disabled at
compile time or native_io_apic_init_mappings(). No point to have that
as we can achieve the same thing with an empty inline.
Pull x86 mm changes from Ingo Molnar:
- reduce the x86/32 PAE per task PGD allocation overhead from 4K to
0.032k (Fenghua Yu)
- early_ioremap/memunmap() usage cleanups (Juergen Gross)
- gbpages support cleanups (Luis R Rodriguez)
- improve AMD Bulldozer (family 0x15) ASLR I$ aliasing workaround to
increase randomization by 3 bits (per bootup) (Hector
Marco-Gisbert)
- misc fixlets"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mm: Improve AMD Bulldozer ASLR workaround
x86/mm/pat: Initialize __cachemode2pte_tbl[] and __pte2cachemode_tbl[] in a bit more readable fashion
init.h: Clean up the __setup()/early_param() macros
x86/mm: Simplify probe_page_size_mask()
x86/mm: Further simplify 1 GB kernel linear mappings handling
x86/mm: Use early_param_on_off() for direct_gbpages
init.h: Add early_param_on_off()
x86/mm: Simplify enabling direct_gbpages
x86/mm: Use IS_ENABLED() for direct_gbpages
x86/mm: Unexport set_memory_ro() and set_memory_rw()
x86/mm, efi: Use early_ioremap() in arch/x86/platform/efi/efi-bgrt.c
x86/mm: Use early_memunmap() instead of early_iounmap()
x86/mm/pat: Ensure different messages in STRICT_DEVMEM and PAT cases
x86/mm: Reduce PAE-mode per task pgd allocation overhead from 4K to 32 bytes
Commit:
e2b32e678513 ("x86, kaslr: randomize module base load address")
made module base address randomization unconditional and didn't regard
disabled KKASLR due to CONFIG_HIBERNATION and command line option
"nokaslr". For more info see (now reverted) commit:
f47233c2d34f ("x86/mm/ASLR: Propagate base load address calculation")
In order to propagate KASLR status to kernel proper, we need a single bit
in boot_params.hdr.loadflags and we've chosen bit 1 thus leaving the
top-down allocated bits for bits supposed to be used by the bootloader.
Originally-From: Jiri Kosina <jkosina@suse.cz>
Suggested-by: H. Peter Anvin <hpa@zytor.com>
This reverts commit:
The main reason for the revert is that the new boot flag does not work
at all currently, and in order to make this work, we need non-trivial
changes to the x86 boot code which we didn't manage to get done in
time for merging.
And even if we did, they would've been too risky so instead of
rushing things and break booting 4.1 on boxes left and right, we
will be very strict and conservative and will take our time with
this to fix and test it properly.
Reported-by: Yinghai Lu <yinghai@kernel.org>
Cc: Baoquan He <bhe@redhat.com>
Cc: H. Peter Anvin <hpa@linux.intel.com
Cc: Junjie Mao <eternal.n08@gmail.com>
Link: http://lkml.kernel.org/r/20150316100628.GD22995@pd.tnic
Memory mapped via early_memremap() should be unmapped with
early_memunmap() instead of early_iounmap().
Signed-off-by: Juergen Gross <jgross@suse.com>
Cc: matt.fleming@intel.com
Link: http://lkml.kernel.org/r/1424769211-11378-2-git-send-email-jgross@suse.com
Pull misc x86 fixes from Ingo Molnar:
"This contains:
- EFI fixes
- a boot printout fix
- ASLR/kASLR fixes
- intel microcode driver fixes
- other misc fixes
Most of the linecount comes from an EFI revert"
x86/mm/ASLR: Avoid PAGE_SIZE redefinition for UML subarch
x86/microcode/intel: Handle truncated microcode images more robustly
x86/microcode/intel: Guard against stack overflow in the loader
x86, mm/ASLR: Fix stack randomization on 64-bit systems
x86/mm/init: Fix incorrect page size in init_memory_mapping() printks
Documentation/x86: Fix path in zero-page.txt
x86/apic: Fix the devicetree build in certain configs
Revert "efi/libstub: Call get_memory_map() to obtain map and desc sizes"
x86/efi: Avoid triple faults during EFI mixed mode calls
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp into x86/urgent
Pull ASLR and kASLR fixes from Borislav Petkov:
- Add a global flag announcing KASLR state so that relevant code can do
informed decisions based on its setting. (Jiri Kosina)
- Fix a stack randomization entropy decrease bug. (Hector Marco-Gisbert)
Commit:
makes the base address for module to be unconditionally randomized in
case when CONFIG_RANDOMIZE_BASE is defined and "nokaslr" option isn't
present on the commandline.
This is not consistent with how choose_kernel_location() decides whether
it will randomize kernel load base.
Namely, CONFIG_HIBERNATION disables kASLR (unless "kaslr" option is
explicitly specified on kernel commandline), which makes the state space
larger than what module loader is looking at. IOW CONFIG_HIBERNATION &&
CONFIG_RANDOMIZE_BASE is a valid config option, kASLR wouldn't be applied
by default in that case, but module loader is not aware of that.
Instead of fixing the logic in module.c, this patch takes more generic
aproach. It introduces a new bootparam setup data_type SETUP_KASLR and
uses that to pass the information whether kaslr has been applied during
kernel decompression, and sets a global 'kaslr_enabled' variable
accordingly, so that any kernel code (module loading, livepatching, ...)
can make decisions based on its value.
x86 module loader is converted to make use of this flag.
Cc: "H. Peter Anvin" <hpa@linux.intel.com>
Link: https://lkml.kernel.org/r/alpine.LNX.2.00.1502101411280.10719@pobox.suse.cz
[ Always dump correct kaslr status when panicking ]
Pull x86 perf updates from Ingo Molnar:
"This series tightens up RDPMC permissions: currently even highly
sandboxed x86 execution environments (such as seccomp) have permission
to execute RDPMC, which may leak various perf events / PMU state such
as timing information and other CPU execution details.
This 'all is allowed' RDPMC mode is still preserved as the
(non-default) /sys/devices/cpu/rdpmc=2 setting. The new default is
that RDPMC access is only allowed if a perf event is mmap-ed (which is
needed to correctly interpret RDPMC counter values in any case).
As a side effect of these changes CR4 handling is cleaned up in the
x86 code and a shadow copy of the CR4 value is added.
The extra CR4 manipulation adds ~ <50ns to the context switch cost
between rdpmc-capable and rdpmc-non-capable mms"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86: Add /sys/devices/cpu/rdpmc=2 to allow rdpmc for all tasks
perf/x86: Only allow rdpmc if a perf_event is mapped
perf: Pass the event to arch_perf_update_userpage()
perf: Add pmu callbacks to track event mapping and unmapping
x86: Add a comment clarifying LDT context switching
x86: Store a per-cpu shadow copy of CR4
x86: Clean up cr4 manipulation
This patch adds arch specific code for kernel address sanitizer.
16TB of virtual addressed used for shadow memory. It's located in range
[ffffec0000000000 - fffffc0000000000] between vmemmap and %esp fixup
stacks.
At early stage we map whole shadow region with zero page. Latter, after
pages mapped to direct mapping address range we unmap zero pages from
corresponding shadow (see kasan_map_shadow()) and allocate and map a real
shadow memory reusing vmemmap_populate() function.
Also replace __pa with __pa_nodebug before shadow initialized. __pa with
CONFIG_DEBUG_VIRTUAL=y make external function call (__phys_addr)
__phys_addr is instrumented, so __asan_load could be called before shadow
area initialized.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Konstantin Serebryany <kcc@google.com>
Cc: Dmitry Chernenkov <dmitryc@google.com>
Signed-off-by: Andrey Konovalov <adech.fo@gmail.com>
Cc: Yuri Gribov <tetra2005@gmail.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Jim Davis <jim.epost@gmail.com>
Context switches and TLB flushes can change individual bits of CR4.
CR4 reads take several cycles, so store a shadow copy of CR4 in a
per-cpu variable.
To avoid wasting a cache line, I added the CR4 shadow to
cpu_tlbstate, which is already touched in switch_mm. The heaviest
users of the cr4 shadow will be switch_mm and __switch_to_xtra, and
__switch_to_xtra is called shortly after switch_mm during context
switch, so the cacheline is likely to be hot.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Cc: Vince Weaver <vince@deater.net>
Cc: "hillf.zj" <hillf.zj@alibaba-inc.com>
Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/3a54dd3353fffbf84804398e00dfdc5b7c1afd7d.1414190806.git.luto@amacapital.net
early_memremap() takes care of page alignment and map size, so we can
just remap the required data size and get rid of the adjustments in
the setup code.
[tglx: Massaged changelog ]
Signed-off-by: WANG Chao <chaowang@redhat.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Bryan O'Donoghue <pure.logic@nexus-software.ie>
Link: http://lkml.kernel.org/r/1420628150-16872-1-git-send-email-chaowang@redhat.com
Pull x86 vdso updates from Ingo Molnar:
"Various vDSO updates from Andy Lutomirski, mostly cleanups and
reorganization to improve maintainability, but also some
micro-optimizations and robustization changes"
* 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86_64/vsyscall: Restore orig_ax after vsyscall seccomp
x86_64: Add a comment explaining the TASK_SIZE_MAX guard page
x86_64,vsyscall: Make vsyscall emulation configurable
x86_64, vsyscall: Rewrite comment and clean up headers in vsyscall code
x86_64, vsyscall: Turn vsyscalls all the way off when vsyscall==none
x86,vdso: Use LSL unconditionally for vgetcpu
x86: vdso: Fix build with older gcc
x86_64/vdso: Clean up vgetcpu init and merge the vdso initcalls
x86_64/vdso: Remove jiffies from the vvar page
x86/vdso: Make the PER_CPU segment 32 bits
x86/vdso: Make the PER_CPU segment start out accessed
x86/vdso: Change the PER_CPU segment to use struct desc_struct
x86_64/vdso: Move getcpu code from vsyscall_64.c to vdso/vma.c
x86_64/vsyscall: Move all of the gate_area code to vsyscall_64.c
This is really the meat of the MPX patch set. If there is one patch to
review in the entire series, this is the one. There is a new ABI here
and this kernel code also interacts with userspace memory in a
relatively unusual manner. (small FAQ below).
Long Description:
This patch adds two prctl() commands to provide enable or disable the
management of bounds tables in kernel, including on-demand kernel
allocation (See the patch "on-demand kernel allocation of bounds tables")
and cleanup (See the patch "cleanup unused bound tables"). Applications
do not strictly need the kernel to manage bounds tables and we expect
some applications to use MPX without taking advantage of this kernel
support. This means the kernel can not simply infer whether an application
needs bounds table management from the MPX registers. The prctl() is an
explicit signal from userspace.
PR_MPX_ENABLE_MANAGEMENT is meant to be a signal from userspace to
require kernel's help in managing bounds tables.
PR_MPX_DISABLE_MANAGEMENT is the opposite, meaning that userspace don't
want kernel's help any more. With PR_MPX_DISABLE_MANAGEMENT, the kernel
won't allocate and free bounds tables even if the CPU supports MPX.
PR_MPX_ENABLE_MANAGEMENT will fetch the base address of the bounds
directory out of a userspace register (bndcfgu) and then cache it into
a new field (->bd_addr) in the 'mm_struct'. PR_MPX_DISABLE_MANAGEMENT
will set "bd_addr" to an invalid address. Using this scheme, we can
use "bd_addr" to determine whether the management of bounds tables in
kernel is enabled.
Also, the only way to access that bndcfgu register is via an xsaves,
which can be expensive. Caching "bd_addr" like this also helps reduce
the cost of those xsaves when doing table cleanup at munmap() time.
Unfortunately, we can not apply this optimization to #BR fault time
because we need an xsave to get the value of BNDSTATUS.
==== Why does the hardware even have these Bounds Tables? ====
MPX only has 4 hardware registers for storing bounds information.
If MPX-enabled code needs more than these 4 registers, it needs to
spill them somewhere. It has two special instructions for this
which allow the bounds to be moved between the bounds registers
and some new "bounds tables".
They are similar conceptually to a page fault and will be raised by
the MPX hardware during both bounds violations or when the tables
are not present. This patch handles those #BR exceptions for
not-present tables by carving the space out of the normal processes
address space (essentially calling the new mmap() interface indroduced
earlier in this patch set.) and then pointing the bounds-directory
over to it.
The tables *need* to be accessed and controlled by userspace because
the instructions for moving bounds in and out of them are extremely
frequent. They potentially happen every time a register pointing to
memory is dereferenced. Any direct kernel involvement (like a syscall)
to access the tables would obviously destroy performance.
==== Why not do this in userspace? ====
This patch is obviously doing this allocation in the kernel.
However, MPX does not strictly *require* anything in the kernel.
It can theoretically be done completely from userspace. Here are
a few ways this *could* be done. I don't think any of them are
practical in the real-world, but here they are.
Q: Can virtual space simply be reserved for the bounds tables so
that we never have to allocate them?
A: As noted earlier, these tables are *HUGE*. An X-GB virtual
area needs 4*X GB of virtual space, plus 2GB for the bounds
directory. If we were to preallocate them for the 128TB of
user virtual address space, we would need to reserve 512TB+2GB,
which is larger than the entire virtual address space today.
This means they can not be reserved ahead of time. Also, a
single process's pre-popualated bounds directory consumes 2GB
of virtual *AND* physical memory. IOW, it's completely
infeasible to prepopulate bounds directories.
Q: Can we preallocate bounds table space at the same time memory
is allocated which might contain pointers that might eventually
need bounds tables?
A: This would work if we could hook the site of each and every
memory allocation syscall. This can be done for small,
constrained applications. But, it isn't practical at a larger
scale since a given app has no way of controlling how all the
parts of the app might allocate memory (think libraries). The
kernel is really the only place to intercept these calls.
Q: Could a bounds fault be handed to userspace and the tables
allocated there in a signal handler instead of in the kernel?
A: (thanks to tglx) mmap() is not on the list of safe async
handler functions and even if mmap() would work it still
requires locking or nasty tricks to keep track of the
allocation state there.
Having ruled out all of the userspace-only approaches for managing
bounds tables that we could think of, we create them on demand in
the kernel.
Based-on-patch-by: Qiaowei Ren <qiaowei.ren@intel.com>
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: linux-mm@kvack.org
Cc: linux-mips@linux-mips.org
Cc: Dave Hansen <dave@sr71.net>
Link: http://lkml.kernel.org/r/20141114151829.AD4310DE@viggo.jf.intel.com
This adds CONFIG_X86_VSYSCALL_EMULATION, guarded by CONFIG_EXPERT.
Turning it off completely disables vsyscall emulation, saving ~3.5k
for vsyscall_64.c, 4k for vsyscall_emu_64.S (the fake vsyscall
page), some tiny amount of core mm code that supports a gate area,
and possibly 4k for a wasted pagetable. The latter is because the
vsyscall addresses are misaligned and fit poorly in the fixmap.
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/406db88b8dd5f0cbbf38216d11be34bbb43c7eae.1414618407.git.luto@amacapital.net
Fengguang Wu reported a boot crash on the x86 platform
via the 0-day Linux Kernel Performance Test:
cma: dma_contiguous_reserve: reserving 31 MiB for global area
BUG: Int 6: CR2 (null)
[<41850786>] dump_stack+0x16/0x18
[<41d2b1db>] early_idt_handler+0x6b/0x6b
[<41072227>] ? __phys_addr+0x2e/0xca
[<41d4ee4d>] cma_declare_contiguous+0x3c/0x2d7
[<41d6d359>] dma_contiguous_reserve_area+0x27/0x47
[<41d6d4d1>] dma_contiguous_reserve+0x158/0x163
[<41d33e0f>] setup_arch+0x79b/0xc68
[<41d2b7cf>] start_kernel+0x9c/0x456
[<41d2b2ca>] i386_start_kernel+0x79/0x7d
(See details at: https://lkml.org/lkml/2014/10/8/708)
It is because dma_contiguous_reserve() is called before
initmem_init() in x86, the variable high_memory is not
initialized but accessed by __pa(high_memory) in
dma_contiguous_reserve().
This patch moves dma_contiguous_reserve() after initmem_init()
so that high_memory is initialized before accessed.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Weijie Yang <weijie.yang@samsung.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Cc: iamjoonsoo.kim@lge.com
Cc: 'Linux-MM' <linux-mm@kvack.org>
Cc: 'Weijie Yang' <weijie.yang.kh@gmail.com>
Link: http://lkml.kernel.org/r/000101cfef69%2431e528a0%2495af79e0%24%25yang@samsung.com
Quark SoC X1000 advertises Page Global Enable for it's
Translation Lookaside Buffer via cpuid. The silicon does not
in fact support PGE and hence will not flush the TLB when CR4.PGE
is rewritten. The Quark documentation makes clear the necessity to
instead rewrite CR3 in order to flush any TLB entries, irrespective
of the state of CR4.PGE or an individual PTE.PGE
See Intel Quark Core DevMan_001.pdf section 6.4.11
In setup.c setup_arch() the code will load_cr3() and then do a
__flush_tlb_all().
On Quark the entire TLB will be flushed at the load_cr3().
The __flush_tlb_all() have no effect and can be safely ignored.
Later on in the boot process we switch off the flag for cpu_has_pge()
which means that subsequent calls to __flush_tlb_all() will
call __flush_tlb() not __flush_tlb_global() flushing the TLB in the
correct way via load_cr3() not CR4.PGE rewrite
This patch documents the behaviour of flushing the TLB for Quark in
setup_arch()
Comment text suggested by Thomas Gleixner
Signed-off-by: Bryan O'Donoghue <pure.logic@nexus-software.ie>
Cc: davej@redhat.com
Cc: hmh@hmh.eng.br
Link: http://lkml.kernel.org/r/1412641189-12415-2-git-send-email-pure.logic@nexus-software.ie
We've got constants, so let's use them instead of hard-coded values.
Signed-off-by: Daniel Kiper <daniel.kiper@oracle.com>
Currently, "cma=" kernel parameter is used to specify the size of CMA,
but we can't specify where it is located. We want to locate CMA below
4GB for devices only supporting 32-bit addressing on 64-bit systems
without iommu.
This enables to specify the placement of CMA by extending "cma=" kernel
parameter.
Examples:
1. locate 64MB CMA below 4GB by "cma=64M@0-4G"
2. locate 64MB CMA exact at 512MB by "cma=64M@512M"
Note that the DMA contiguous memory allocator on x86 assumes that
page_address() works for the pages to allocate. So this change requires
to limit end address of contiguous memory area upto max_pfn_mapped to
prevent from locating it on highmem area by the argument of
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Don Dutile <ddutile@redhat.com>
Pull x86 old platform removal from Peter Anvin:
"This patchset removes support for several completely obsolete
platforms, where the maintainers either have completely vanished or
acked the removal. For some of them it is questionable if there even
exists functional specimens of the hardware"
Geert Uytterhoeven apparently thought this was a April Fool's pull request ;)
* 'x86-nuke-platforms-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, platforms: Remove NUMAQ
x86, platforms: Remove SGI Visual Workstation
x86, apic: Remove support for IBM Summit/EXA chipset
x86, apic: Remove support for ia32-based Unisys ES7000
arch/x86/include/asm/efi.h
Alex reported hitting the following BUG after the EFI 1:1 virtual
mapping work was merged,
kernel BUG at arch/x86/mm/init_64.c:351!
invalid opcode: 0000 [#1] SMP
Call Trace:
[<ffffffff818aa71d>] init_extra_mapping_uc+0x13/0x15
[<ffffffff818a5e20>] uv_system_init+0x22b/0x124b
[<ffffffff8108b886>] ? clockevents_register_device+0x138/0x13d
[<ffffffff81028dbb>] ? setup_APIC_timer+0xc5/0xc7
[<ffffffff8108b620>] ? clockevent_delta2ns+0xb/0xd
[<ffffffff818a3a92>] ? setup_boot_APIC_clock+0x4a8/0x4b7
[<ffffffff8153d955>] ? printk+0x72/0x74
[<ffffffff818a1757>] native_smp_prepare_cpus+0x389/0x3d6
[<ffffffff818957bc>] kernel_init_freeable+0xb7/0x1fb
[<ffffffff81535530>] ? rest_init+0x74/0x74
[<ffffffff81535539>] kernel_init+0x9/0xff
[<ffffffff81541dfc>] ret_from_fork+0x7c/0xb0
Getting this thing to work with the new mapping scheme would need more
work, so automatically switch to the old memmap layout for SGI UV.
Acked-by: Russ Anderson <rja@sgi.com>
Cc: Alex Thorlton <athorlton@sgi.com
As we grow support for more EFI architectures they're going to want the
ability to query which EFI features are available on the running system.
Instead of storing this information in an architecture-specific place,
stick it in the global 'struct efi', which is already the central
location for EFI state.
While we're at it, let's change the return value of efi_enabled() to be
bool and replace all references to 'facility' with 'feature', which is
the usual word used to describe the attributes of the running system.
