path: root/arch/x86/kernel/setup_32.c
2008-07-08x86: rename setup_32.c to setup.cYinghai Lu
and let 64 bit use that instead of setup_64.c [ mingo@elte.hu ] x86: build fix fix: arch/x86/kernel/setup.c: In function ‘setup_arch': arch/x86/kernel/setup.c:561: error: implicit declaration of function ‘efi_reserve_early' and: arch/x86/kernel/setup.c:766: error: implicit declaration of function 'init_cpu_to_node' and: arch/x86/kernel/setup.c:676: warning: operation on 'max_pfn_mapped' may be undefined Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: space to tab in setup_archYinghai Lu
2008-07-08x86: merge 64bit setup_arch into setup_32Yinghai Lu
2008-07-08x86: add extra includes for 64bit supportYinghai Lu
2008-07-08x86: put global variable for 32bit all togetherYinghai Lu
those variables are not needed by 64 bit. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: update reserve_initrd to support 64bitYinghai Lu
2008-07-08x86: we can use full bootmem after have init_memory_mappingYinghai Lu
So remove outdated comments Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: fix memory setup bugYinghai Lu
interesting... [ 0.000000] mapped low ram: 0 - 20000000 [ 0.000000] low ram: 00000000 - 1fff0000 [ 0.000000] bootmap 00002000 - 00006000 max_pfn_mapped > max_low_pfn? it seems init_memory_mapping reveals an old bug. please check attached test patch. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: introduce init_memory_mapping for 32bit #2Yinghai Lu
moving relocate_initrd early Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: introduce init_memory_mapping for 32bit #1Yinghai Lu
... so can we use mem below max_low_pfn earlier. this allows us to move several functions more early instead of waiting to after paging_init. That includes moving relocate_initrd() earlier in the bootup, and kva related early setup done in initmem_init. (in followup patches) Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: setup_arch 32bit move kvm_guest_init laterYinghai Lu
2008-07-08x86: setup_arch 32bit move command line copying earlyYinghai Lu
2008-07-08x86: setup_arch 32bit move efi check laterYinghai Lu
2008-07-08x86: move some func calling from setup_arch to paging_initYinghai Lu
those function depend on paging setup pgtable, so they could access the ram in bootmem region but just get mapped. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: build fixIngo Molnar
fix: arch/x86/kernel/setup_32.c:409: error: 'enable_local_apic' undeclared (first use in this function) arch/x86/kernel/setup_32.c:409: error: (Each undeclared identifier is reported only once arch/x86/kernel/setup_32.c:409: error: for each function it appears in.) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: clean up using max_low_pfn on 32-bitYinghai Lu
so that max_low_pfn is not changed after it is set. so we can move that early and out of initmem_init. could call find_low_pfn_range just after max_pfn is set. also could move reserve_initrd out of setup_bootmem_allocator so 32bit is more like 64bit. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: move reservetop and vmalloc parsing to pgtable_32.cYinghai Lu
also change reserve_top_address to __init attibute Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: move find_max_low_pfn to init_32.cYinghai Lu
2008-07-08x86: move boot_params declaring to setup.cYinghai Lu
2008-07-08x86: introduce reserve_initrdYinghai Lu
2008-07-08x86: introduce initmem_init for 32 bitYinghai Lu
2008-07-08x86: move elfcorehdr parsing to setup.cYinghai Lu
2008-07-08x86: move reserve_standard_io_resource to setup.cYinghai Lu
2008-07-08x86: remove two duplicated funcs in setup_32.cYinghai Lu
early_cpu_init is declared in processor.h memory_setup is defined in e820.c Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: seperate probe_roms into another fileYinghai Lu
it is only needed for 32bit Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: remove some acpi ifdefs in setup_32/64Yinghai Lu
2008-07-08x86: check command line when CONFIG_X86_MPPARSE is not set, v2Yinghai Lu
if acpi=off, acpi=noirq and pci=noacpi, we need to disable apic. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: unify crashkernel reservation for 32 and 64 bitBernhard Walle
This patch moves the reserve_crashkernel() to setup.c and removes the architecture-specific version. Both versions were more or less the same. I tested it on both x86-64 and i386, with CONFIG_KEXEC on and off (so that it compiles). Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: yhlu.kernel@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08Merge branch 'x86/numa' into x86/develIngo Molnar
Conflicts: arch/x86/Kconfig arch/x86/kernel/e820.c arch/x86/kernel/efi_64.c arch/x86/kernel/mpparse.c arch/x86/kernel/setup.c arch/x86/kernel/setup_32.c arch/x86/mm/init_64.c include/asm-x86/proto.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: cleanup early per cpu variables/accesses v4Mike Travis
* Introduce a new PER_CPU macro called "EARLY_PER_CPU". This is used by some per_cpu variables that are initialized and accessed before there are per_cpu areas allocated. ["Early" in respect to per_cpu variables is "earlier than the per_cpu areas have been setup".] This patchset adds these new macros: DEFINE_EARLY_PER_CPU(_type, _name, _initvalue) EXPORT_EARLY_PER_CPU_SYMBOL(_name) DECLARE_EARLY_PER_CPU(_type, _name) early_per_cpu_ptr(_name) early_per_cpu_map(_name, _idx) early_per_cpu(_name, _cpu) The DEFINE macro defines the per_cpu variable as well as the early map and pointer. It also initializes the per_cpu variable and map elements to "_initvalue". The early_* macros provide access to the initial map (usually setup during system init) and the early pointer. This pointer is initialized to point to the early map but is then NULL'ed when the actual per_cpu areas are setup. After that the per_cpu variable is the correct access to the variable. The early_per_cpu() macro is not very efficient but does show how to access the variable if you have a function that can be called both "early" and "late". It tests the early ptr to be NULL, and if not then it's still valid. Otherwise, the per_cpu variable is used instead: #define early_per_cpu(_name, _cpu) \ (early_per_cpu_ptr(_name) ? \ early_per_cpu_ptr(_name)[_cpu] : \ per_cpu(_name, _cpu)) A better method is to actually check the pointer manually. In the case below, numa_set_node can be called both "early" and "late": void __cpuinit numa_set_node(int cpu, int node) { int *cpu_to_node_map = early_per_cpu_ptr(x86_cpu_to_node_map); if (cpu_to_node_map) cpu_to_node_map[cpu] = node; else per_cpu(x86_cpu_to_node_map, cpu) = node; } * Add a flag "arch_provides_topology_pointers" that indicates pointers to topology cpumask_t maps are available. Otherwise, use the function returning the cpumask_t value. This is useful if cpumask_t set size is very large to avoid copying data on to/off of the stack. * The coverage of CONFIG_DEBUG_PER_CPU_MAPS has been increased while the non-debug case has been optimized a bit. * Remove an unreferenced compiler warning in drivers/base/topology.c * Clean up #ifdef in setup.c For inclusion into sched-devel/latest tree. Based on: git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git + sched-devel/latest .../mingo/linux-2.6-sched-devel.git Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-08x86: use acpi_numa_init to parse on 32-bit numaYinghai Lu
seperate SRAT finding and parsing from get_memcfg_from_srat, and let getmemcfg_from_srat only handle array from previous step. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: move some function out of setup_bootmem_allocYinghai Lu
... to make it more like 64-bit. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: kill bad_pproYinghai Lu
so don't punish all other cpus without that problem when init highmem Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: move e820_resource_resources to e820.cYinghai Lu
and make 32-bit resource registration more like 64 bit. also move probe_roms back to setup_32.c Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: clean up relocate_initrdYinghai Lu
1. move that before zone_sizes_init ... 2. add free_early for one old one, otherwise it will be be reserved again when we init highmem. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08Merge branch 'linus' into tmp.x86.mpparse.newIngo Molnar
2008-06-19x86: use BOOTMEM_EXCLUSIVE on 32-bitBernhard Walle
This patch uses the BOOTMEM_EXCLUSIVE for crashkernel reservation also for i386 and prints a error message on failure. The patch is still for 2.6.26 since it is only bug fixing. The unification of reserve_crashkernel() between i386 and x86_64 should be done for 2.6.27. Signed-off-by: Bernhard Walle <bwalle@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org>
2008-06-10x86: update mptable, fixYinghai Lu
need to call early_reserve_e820() to preallocate mptable for 32bit Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-10x86: introduce max_physical_apicid for bigsmp switchingYinghai Lu
a multi-socket test-system with 3 or 4 ioapics, when 4 dualcore cpus or 2 quadcore cpus installed, needs to switch to bigsmp or physflat. CPU apic id is [4,11] instead of [0,7], and we need to check max apic id instead of cpu numbers. also add check for 32 bit when acpi is not compiled in or acpi=off. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-05x86: linked list of setup_data for i386Huang, Ying
This patch adds linked list of struct setup_data supported for i386. Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: andi@firstfloor.org Cc: mingo@redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-06-05x86: reserve EFI memory map with reserve_earlyHuang, Ying
This patch reserves the EFI memory map with reserve_early(). Because EFI memory map is allocated by bootloader, if it is not reserved by reserved_early(), it may be overwritten through address returned by find_e820_area(). Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: andi@firstfloor.org Cc: mingo@redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-06-04x86: make 32-bit use e820_register_active_regions()Yinghai Lu
this way 32-bit is more similar to 64-bit, and smarter e820 and numa. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-04x86: change propagate_e820_map() back to find_max_pfn(), 32-bit, fixYinghai Lu
add memory_present() calls for sparse and non-numa. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-03x86: clean up max_pfn_mapped usage - 32-bitYinghai Lu
on 32-bit in head_32.S after initial page table is done, we get initial max_pfn_mapped, and then kernel_physical_mapping_init will give us a final one. We need to use that to make sure find_e820_area will get valid addresses for boot_map and for NODE_DATA(0) on numa32. XEN PV and lguest may need to assign max_pfn_mapped too. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-03x86, 32-bit: change propagate_e820_map() back to find_max_pfn()Yinghai Lu
we don't need to call memory_present that early. numa and sparse will call memory_present later and might even fail, it will call memory_present for the full range. also for sparse it will call alloc_bootmem ... before we set up bootmem. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-31x86: extend e820 early_res support 32bit -fix #5Yinghai Lu
reserve early numa kva, so it will not clash with new RAMDISK Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-31x86: extend e820 early_res support 32bit -fix #3Yinghai Lu
introduce init_pg_table_start, so xen PV could specify the value. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-27x86: extend e820 ealy_res support 32bit - fix #2Yinghai Lu
remove extra -1 in reseve_early calling panic if can not find space for new RAMDISK Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-25x86: allow MPPARSE to be deselected in SMP configsAlexey Starikovskiy
2008-05-25x86: move e820_mark_nosave_regions to e820.cYinghai Lu
and make e820_mark_nosave_regions to take limit_pfn to use max_low_pfn for 32bit and end_pfn for 64bit Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
