path: root/arch/x86/kernel/setup_64.c
2008-05-13x86: early_init_centaur(): use set_cpu_cap()Andrew Morton
arch/x86/kernel/setup_64.c:954: warning: passing argument 2 of 'set_bit' from incompatible pointer type Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-10x86: restrict keyboard io ports reservation to make ipmi driver workHelge Wagner
On some of our (single board computer) boards (x86) we are using an IPMI controller that uses I/O ports 0x62 and 0x66 for a KCS (keyboard controller style) IPMI system interface. Trying to load the openipmi driver fails, because the ports (0x62/0x66) are reserved for keyboard. keyboard reserves the full range 0x60-0x6F while it doesn't need to. Reserve only ports 0x60 and 0x64 for the legacy PS/2 i8042 keyboad controller instead of 0x60-0x6F to allow the openipmi driver to work. [ tglx: added 64bit fixup ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-08x86: cleanup PAT cpu validationThomas Gleixner
Move the scattered checks for PAT support to a single function. Its moved to addon_cpuid_features.c as this file is shared between 32 and 64 bit. Remove the manipulation of the PAT feature bit and just disable PAT in the PAT layer, based on the PAT bit provided by the CPU and the current CPU version/model white list. Change the boot CPU check so it works on Voyager somewhere in the future as well :) Also panic, when a secondary has PAT disabled but the primary one has alrady switched to PAT. We have no way to undo that. The white list is kept for now to ensure that we can rely on known to work CPU types and concentrate on the software induced problems instead of fighthing CPU erratas and subtle wreckage caused by not yet verified CPUs. Once the PAT code has stabilized enough, we can remove the white list and open the can of worms. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-bigbox-pci * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-bigbox-pci: x86: add pci=check_enable_amd_mmconf and dmi check x86: work around io allocation overlap of HT links acpi: get boot_cpu_id as early for k8_scan_nodes x86_64: don't need set default res if only have one root bus x86: double check the multi root bus with fam10h mmconf x86: multi pci root bus with different io resource range, on 64-bit x86: use bus conf in NB conf fun1 to get bus range on, on 64-bit x86: get mp_bus_to_node early x86 pci: remove checking type for mmconfig probe x86: remove unneeded check in mmconf reject driver core: try parent numa_node at first before using default x86: seperate mmconf for fam10h out from setup_64.c x86: if acpi=off, force setting the mmconf for fam10h x86_64: check MSR to get MMCONFIG for AMD Family 10h x86_64: check and enable MMCONFIG for AMD Family 10h x86_64: set cfg_size for AMD Family 10h in case MMCONFIG x86: mmconf enable mcfg early x86: clear pci_mmcfg_virt when mmcfg get rejected x86: validate against acpi motherboard resources Fixed up fairly trivial conflicts in arch/x86/pci/{init.c,pci.h} due to OLPC support manually.
2008-04-27x86: KVM guest: add basic paravirt supportMarcelo Tosatti
Add basic KVM paravirt support. Avoid vm-exits on IO delays. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27x86: KVM guest: paravirtualized clocksourceGlauber de Oliveira Costa
This is the guest part of kvm clock implementation It does not do tsc-only timing, as tsc can have deltas between cpus, and it did not seem worthy to me to keep adjusting them. We do use it, however, for fine-grained adjustment. Other than that, time comes from the host. [randy dunlap: add missing include] [randy dunlap: disallow on Voyager or Visual WS] Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-26x86: add pci=check_enable_amd_mmconf and dmi checkYinghai Lu
so will disable that feature by default, and only enable that via pci=check_enable_amd_mmconf or for system match with dmi table. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-26x86: seperate mmconf for fam10h out from setup_64.cYinghai Lu
Separate mmconf for fam10h out from setup_64.c Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86: if acpi=off, force setting the mmconf for fam10hYinghai Lu
some BIOS only let AMD fam 10h handle bus0, and nvidia mcp55/ck804 to handle other buses. at that case MCFG will cover all over them. but with acpi=off, we can not use MCFG. this patch will double check the busnbits, and if it is less handling 256 bues, and acpi=off will forcely reset the mmconf in msr, so we still use mmconf in above case. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86_64: check and enable MMCONFIG for AMD Family 10hYinghai Lu
So we can use MMCONF when MMCONF is not set by BIOS using TOP_MEM2 msr to get memory top, and try to scan fam10h mmio routing to make sure the range is not conflicted with some prefetch MMIO that is above 4G. (current only LinuxBIOS assign 64 bit mmio above 4G for some co-processor) Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86_64: fix setup_node_bootmem to support big mem excluding with memmapYinghai Lu
typical case: four sockets system, every node has 4g ram, and we are using: memmap=10g$4g to mask out memory on node1 and node2 when numa is enabled, early_node_mem is used to get node_data and node_bootmap. if it can not get memory from the same node with find_e820_area(), it will use alloc_bootmem to get buff from previous nodes. so check it and print out some info about it. need to move early_res_to_bootmem into every setup_node_bootmem. and it takes range that node has. otherwise alloc_bootmem could return addr that reserved early. depends on "mm: make reserve_bootmem can crossed the nodes". Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86, boot: export linked list of struct setup_data via debugfsHuang, Ying
Export linked list of struct setup_data via debugfs. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-26x86, boot: add linked list of struct setup_dataHuang, Ying
This patch adds a field of 64-bit physical pointer to NULL terminated single linked list of struct setup_data to real-mode kernel header. This is used as a more extensible boot parameters passing mechanism. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-26x86: array can become staticDmitri Vorobiev
In arch/x86/kernel/setup_64.c, the standard_io_resources array is needlessly defined as global. This patch makes this variable static. This patch was successfully build-tested using the defconfig for x86_64. Runtime test was performed by booting a 64-bit x86 box up to the shell prompt. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: (36 commits) SCSI: convert struct class_device to struct device DRM: remove unused dev_class IB: rename "dev" to "srp_dev" in srp_host structure IB: convert struct class_device to struct device memstick: convert struct class_device to struct device driver core: replace remaining __FUNCTION__ occurrences sysfs: refill attribute buffer when reading from offset 0 PM: Remove destroy_suspended_device() Firmware: add iSCSI iBFT Support PM: Remove legacy PM (fix) Kobject: Replace list_for_each() with list_for_each_entry(). SYSFS: Explicitly include required header file slab.h. Driver core: make device_is_registered() work for class devices PM: Convert wakeup flag accessors to inline functions PM: Make wakeup flags available whenever CONFIG_PM is set PM: Fix misuse of wakeup flag accessors in serial core Driver core: Call device_pm_add() after bus_add_device() in device_add() PM: Handle device registrations during suspend/resume block: send disk "change" event for rescan_partitions() sysdev: detect multiple driver registrations ... Fixed trivial conflict in include/linux/memory.h due to semaphore header file change (made irrelevant by the change to mutex).
2008-04-19Firmware: add iSCSI iBFT SupportKonrad Rzeszutek
Add /sysfs/firmware/ibft/[initiator|targetX|ethernetX] directories along with text properties which export the the iSCSI Boot Firmware Table (iBFT) structure. What is iSCSI Boot Firmware Table? It is a mechanism for the iSCSI tools to extract from the machine NICs the iSCSI connection information so that they can automagically mount the iSCSI share/target. Currently the iSCSI information is hard-coded in the initrd. The /sysfs entries are read-only one-name-and-value fields. The usual set of data exposed is: # for a in `find /sys/firmware/ibft/ -type f -print`; do echo -n "$a: "; cat $a; done /sys/firmware/ibft/target0/target-name: iqn.2007.com.intel-sbx44:storage-10gb /sys/firmware/ibft/target0/nic-assoc: 0 /sys/firmware/ibft/target0/chap-type: 0 /sys/firmware/ibft/target0/lun: 00000000 /sys/firmware/ibft/target0/port: 3260 /sys/firmware/ibft/target0/ip-addr: 192.168.79.116 /sys/firmware/ibft/target0/flags: 3 /sys/firmware/ibft/target0/index: 0 /sys/firmware/ibft/ethernet0/mac: 00:11:25:9d:8b:01 /sys/firmware/ibft/ethernet0/vlan: 0 /sys/firmware/ibft/ethernet0/gateway: 192.168.79.254 /sys/firmware/ibft/ethernet0/origin: 0 /sys/firmware/ibft/ethernet0/subnet-mask: 255.255.252.0 /sys/firmware/ibft/ethernet0/ip-addr: 192.168.77.41 /sys/firmware/ibft/ethernet0/flags: 7 /sys/firmware/ibft/ethernet0/index: 0 /sys/firmware/ibft/initiator/initiator-name: iqn.2007-07.com:konrad.initiator /sys/firmware/ibft/initiator/flags: 3 /sys/firmware/ibft/initiator/index: 0 For full details of the IBFT structure please take a look at: ftp://ftp.software.ibm.com/systems/support/system_x_pdf/ibm_iscsi_boot_firmware_table_v1.02.pdf [akpm@linux-foundation.org: fix build] Signed-off-by: Konrad Rzeszutek <konradr@linux.vnet.ibm.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: Peter Jones <pjones@redhat.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19x86: reserve dma32 early for gartYinghai Lu
a system with 256 GB of RAM, when NUMA is disabled crashes the following way: Your BIOS doesn't leave a aperture memory hole Please enable the IOMMU option in the BIOS setup This costs you 64 MB of RAM Cannot allocate aperture memory hole (ffff8101c0000000,65536K) Kernel panic - not syncing: Not enough memory for aperture Pid: 0, comm: swapper Not tainted 2.6.25-rc4-x86-latest.git #33 Call Trace: [<ffffffff84037c62>] panic+0xb2/0x190 [<ffffffff840381fc>] ? release_console_sem+0x7c/0x250 [<ffffffff847b1628>] ? __alloc_bootmem_nopanic+0x48/0x90 [<ffffffff847b0ac9>] ? free_bootmem+0x29/0x50 [<ffffffff847ac1f7>] gart_iommu_hole_init+0x5e7/0x680 [<ffffffff847b255b>] ? alloc_large_system_hash+0x16b/0x310 [<ffffffff84506a2f>] ? _etext+0x0/0x1 [<ffffffff847a2e8c>] pci_iommu_alloc+0x1c/0x40 [<ffffffff847ac795>] mem_init+0x45/0x1a0 [<ffffffff8479ff35>] start_kernel+0x295/0x380 [<ffffffff8479f1c2>] _sinittext+0x1c2/0x230 the root cause is : memmap PMD is too big, [ffffe200e0600000-ffffe200e07fffff] PMD ->ffff81383c000000 on node 0 almost near 4G..., and vmemmap_alloc_block will use up the ram under 4G. solution will be: 1. make memmap allocation get memory above 4G... 2. reserve some dma32 range early before we try to set up memmap for all. and release that before pci_iommu_alloc, so gart or swiotlb could get some range under 4g limit for sure. the patch is using method 2. because method1 may need more code to handle SPARSEMEM and SPASEMEM_VMEMMAP will get Your BIOS doesn't leave a aperture memory hole Please enable the IOMMU option in the BIOS setup This costs you 64 MB of RAM Mapping aperture over 65536 KB of RAM @ 4000000 Memory: 264245736k/268959744k available (8484k kernel code, 4187464k reserved, 4004k data, 724k init) Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-19x86_64: do not reserve ramdisk two timesYinghai Lu
ramdisk is reserved via reserve_early in x86_64_start_kernel, later early_res_to_bootmem() will convert to reservation in bootmem. so don't need to reserve that again. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17x86: move suspend wakeup code to CPavel Machek
Move wakeup code to .c, so that video mode setting code can be shared between boot and wakeup. Remove nasty assembly code in 64-bit case by re-using trampoline code. Stack setup was fixed to clear high 16bits of %esp, maybe that fixes some machines. .c code sharing and morse code was done H. Peter Anvin, Sam Ravnborg reviewed kbuild related stuff, and it seems okay to him. Rafael did some cleanups. [rjw: * Made the patch stop breaking compilation on x86-32 * Added arch/x86/kernel/acpi/sleep.h * Got rid of compiler warnings in arch/x86/kernel/acpi/sleep.c * Fixed 32-bit compilation on x86-64 systems * Added include/asm-x86/trampoline.h and fixed the non-SMP compilation on 64-bit x86 * Removed arch/x86/kernel/acpi/sleep_32.c which was not used * Fixed some breakage caused by the integration of smpboot.c done under us in the meantime] Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: Centaur Isaiah processor to use sysenter in 64-bit compatibility mode ↵Dave Jones
rather than syscall Upcoming 64 bit processors from Centaur can use sysenter. Signed-off-by: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Jesse Ahrens <jahrens@centtech.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: move apic declarations to mach_apic.hGlauber Costa
take them out of the x86_64-specific asm/mach_apic.h Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: split large page mapping for AMD TSEGAndi Kleen
On AMD SMM protected memory is part of the address map, but handled internally like an MTRR. That leads to large pages getting split internally which has some performance implications. Check for the AMD TSEG MSR and split the large page mapping on that area explicitely if it is part of the direct mapping. There is also SMM ASEG, but it is in the first 1MB and already covered by the earlier split first page patch. Idea for this came from an earlier patch by Andreas Herrmann On a RevF dual Socket Opteron system kernbench shows a clear improvement from this: (together with the earlier patches in this series, especially the split first 2MB patch) [lower is better] no split stddev split stddev delta Elapsed Time 87.146 (0.727516) 84.296 (1.09098) -3.2% User Time 274.537 (4.05226) 273.692 (3.34344) -0.3% System Time 34.907 (0.42492) 34.508 (0.26832) -1.1% Percent CPU 322.5 (38.3007) 326.5 (44.5128) +1.2% => About 3.2% improvement in elapsed time for kernbench. With GB pages on AMD Fam1h the impact of splitting is much higher of course, since it would split two full GB pages (together with the first 1MB split patch) instead of two 2MB pages. I could not benchmark a clear difference in kernbench on gbpages, so I kept it disabled for that case That was only limited benchmarking of course, so if someone was interested in running more tests for the gbpages case that could be revisited (contributions welcome) I didn't bother implementing this for 32bit because it is very unlikely the 32bit lowmem mapping overlaps into the TSEG near 4GB and the 2MB low split is already handled for both. [ mingo@elte.hu: do it on gbpages kernels too, there's no clear reason why it shouldnt help there. ] Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: andreas.herrmann3@amd.com Cc: mingo@elte.hu Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: account overlapped mappings in max_pfn_mappedAndi Kleen
When end_pfn is not aligned to 2MB (or 1GB) then the kernel might map more memory than end_pfn. Account this in max_pfn_mapped. Signed-off-by: Andi Kleen <ak@suse.de> Cc: andreas.herrmann3@amd.com Cc: mingo@elte.hu Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: replace the now useless max_pfn_mapped defineThomas Gleixner
2008-04-17x86: pat cpu feature bit setting for known cpusYinghai Lu
2008-04-17x86: fix build breakage when PCI is define and PARAVIRT is notRavikiran G Thirumalai
- Fix the the build breakage when PARAVIRT is defined but PCI is not This fixes problem reported at: http://marc.info/?l=linux-kernel&m=120525966600698&w=2 - Make is_vsmp_box() available even when PARAVIRT is not defined. This is needed to determine if tsc's are reliable as a time source even when PARAVIRT is not defined. - split vsmp_init to use is_vsmp_box() and set_vsmp_pv_ops() set_vsmp_pv_ops will do nothing if PCI is not enabled in the config. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: provide specialized identification routines for x86_64Glauber de Oliveira Costa
provide two specialized identify_secondary_cpu() and identify_boot_cpu() routines for x86_64. Although not strictly needed, they are functionally correct, and will ease integration with i386 Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: introduce initial apicidYinghai Lu
store initial_apicid from early identify. it is could be different from phys_proc_id later. also print it out in /proc/cpuinfo. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: fix amd_detect_cmpYinghai Lu
for system with apicid lifting, boot cpu apicid will be 4 got: CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line) CPU: L2 Cache: 512K (64 bytes/line) CPU 0/4 -> Node 0 CPU: Physical Processor ID: 1 CPU: Processor Core ID: 0 so try to offset apicid back before get phys_proc_id with bits shift. then we can get correct socket ID also remove remove cpu_data(0) reference. because cpu_data(0) only be ready after smp_prepare_cpus with the assignment from boot_cpu_data to current_cpu_data aka cpu_data(0). and check_bugs()==>identify_cpu(&boot_cpu_data) is quite before than smp_prepare_cpus. So just use boot_cpu_id instead. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: clean up cpu capabilities accesses, genericIngo Molnar
2008-04-17x86: remove wrong setting about CONSTANT_TSC for intel cpuYinghai Lu
early_init_intel() on 64-bit is introduced by commit 2b16a2353814a513cdb5c5c739b76a19d7ea39ce Author: Andi Kleen <ak@suse.de> Date: Wed Jan 30 13:32:40 2008 +0100 x86: move X86_FEATURE_CONSTANT_TSC into early cpu feature detection sets CONSTANT_TSC for intel cpus - but it is already set in init_intel(). don't need to set that two times in early_init_intel() and init_intel(). this patch removes the init_intel() one. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: clean up e820_reserve_resources on 64-bitYinghai Lu
e820_resource_resources could use insert_resource instead of request_resource also move code_resource, data_resource, bss_resource, and crashk_res out of e820_reserve_resources. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: split cpuinfo from setup_64.c into cpu/proc_64.cHiroshi Shimamoto
x86 /proc/cpuinfo code can be unified. This is the first step of unification. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: call vsmp_init explicitlyGlauber Costa
It becomes to early for ioremap, so we use early_ioremap Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ravikiran Thirumalai <kiran@scalemp.com> Acked-by: Shai Fultheim <shai@scalemp.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-03-26x86: fix memoryless node oops during bootYinghai Lu
fix oops during boot reported in this thread: http://lkml.org/lkml/2008/2/6/65 enable booting on memoryless nodes. Reported-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-22x86: revert: reserve dma32 early for gartThomas Gleixner
Revert commit f62f1fc9ef94f74fda2b456d935ba2da69fa0a40 Author: Yinghai Lu <yhlu.kernel@gmail.com> Date: Fri Mar 7 15:02:50 2008 -0800 x86: reserve dma32 early for gart The patch has a dependency on bootmem modifications which are not .25 material that late in the -rc cycle. The problem which is addressed by the patch is limited to machines with 256G and more memory booted with NUMA disabled. This is not a .25 regression and the audience which is affected by this problem is very limited, so it's safer to do the revert than pulling in intrusive bootmem changes right now. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-03-21x86: reserve dma32 early for gartYinghai Lu
2008-02-26x86: fix boot failure on 486 due to TSC breakageMikael Pettersson
> Diffing dmesg between git7 and git8 doesn't sched any light since > git8 also removed the printouts of the x86 caps as they were being > initialised and updated. I'm currently adding those printouts back > in the hope of seeing where and when the caps get broken. That turned out to be very illuminating: --- dmesg-2.6.24-git7 2008-02-24 18:01:25.295851000 +0100 +++ dmesg-2.6.24-git8 2008-02-24 18:01:25.530358000 +0100 ... CPU: After generic identify, caps: 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000 CPU: After all inits, caps: 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000 +CPU: After applying cleared_cpu_caps, caps: 00000013 00000000 00000000 00000000 00000000 00000000 00000000 00000000 Notice how the TSC cap bit goes from Off to On. (The first two lines are printout loops from -git7 forward-ported to -git8, the third line is the same printout loop added just after the xor-with-cleared_cpu_caps[] loop.) Here's how the breakage occurs: 1. arch/x86/kernel/tsc_32.c:tsc_init() sees !cpu_has_tsc, so bails and calls setup_clear_cpu_cap(X86_FEATURE_TSC). 2. include/asm-x86/cpufeature.h:setup_clear_cpu_cap(bit) clears the bit in boot_cpu_data and sets it in cleared_cpu_caps 3. arch/x86/kernel/cpu/common.c:identify_cpu() XORs all caps in with cleared_cpu_caps HOWEVER, at this point c->x86_capability correctly has TSC Off, cleared_cpu_caps has TSC On, so the XOR incorrectly sets TSC to On in c->x86_capability, with disastrous results. The real bug is that clearing bits with XOR only works if the bits are known to be 1 prior to the XOR, and that's not true here. A simple fix is to convert the XOR to AND-NOT instead. The following patch does that, and allows my 486 to boot 2.6.25-rc kernels again. [ mingo@elte.hu: fixed a similar bug in setup_64.c as well. ] The breakage was introduced via commit 7d851c8d3db0. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-19x86: fix printout ugliness in cpu info printkMarcin Slusarz
fix print_cpu_info, because it produced on boot: CPU: <6>AMD Athlon(tm) 64 Processor 3200+ stepping 00 instead of: CPU: AMD Athlon(tm) 64 Processor 3200+ stepping 00 (broken since 04e1ba852132c9ad006affcd5b8c8606295170b0 - x86: cleanup kernel/setup_64.c) Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-19x86: fix section mismatch in setup_64.c:srat_detect_nodeSam Ravnborg
srat_detect_node() is only used by __cpuinit init_intel(). So the trivial fix is to annotate srat_detect_node() with __cpuinit. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-19x86: fix section mismatch warning in setup_64.c:nearby_nodeSam Ravnborg
nearby_node() were only used by __cpuinit amd_detect_cmp() So annotating nearby_node() __cpuinit was the trivial fix. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-08aout: remove unnecessary inclusions of {asm, linux}/a.out.hDavid Howells
Remove now unnecessary inclusions of {asm,linux}/a.out.h. [akpm@linux-foundation.org: fix alpha build] Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Use BOOTMEM_EXCLUSIVE for kdumpBernhard Walle
Use the BOOTMEM_EXCLUSIVE, introduced in the previous patch, to avoid conflicts while reserving the memory for the kdump capture kernel (crashkernel=). Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: <linux-arch@vger.kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Introduce flags for reserve_bootmem()Bernhard Walle
This patchset adds a flags variable to reserve_bootmem() and uses the BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions between crashkernel area and already used memory. This patch: Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE. If that flag is set, the function returns with -EBUSY if the memory already has been reserved in the past. This is to avoid conflicts. Because that code runs before SMP initialisation, there's no race condition inside reserve_bootmem_core(). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: <linux-arch@vger.kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04x86: unify CPU feature string namesH. Peter Anvin
Move the CPU feature string names to a separate file (common to 32 and 64 bits); additionally, make <asm/cpufeature.h> includable by host code in preparation for including the CPU feature strings in the boot code. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-01x86_64: make bootmap_start page align v6Yinghai Lu
boot oopses when a system has 64 or 128 GB of RAM installed: Calling initcall 0xffffffff80bc33b6: sctp_init+0x0/0x711() BUG: unable to handle kernel NULL pointer dereference at 000000000000005f IP: [<ffffffff802bfe55>] proc_register+0xe7/0x10f PGD 0 Oops: 0000 [1] SMP CPU 0 Modules linked in: Pid: 1, comm: swapper Not tainted 2.6.24-smp-g5a514e21-dirty #6 RIP: 0010:[<ffffffff802bfe55>] [<ffffffff802bfe55>] proc_register+0xe7/0x10f RSP: 0000:ffff810824c57e60 EFLAGS: 00010246 RAX: 000000000000d7d7 RBX: ffff811024c5fa80 RCX: ffff810824c57e08 RDX: 0000000000000000 RSI: 0000000000000195 RDI: ffffffff80cc2460 RBP: ffffffffffffffff R08: 0000000000000000 R09: ffff811024c5fa80 R10: 0000000000000000 R11: 0000000000000002 R12: ffff810824c57e6c R13: 0000000000000000 R14: ffff810824c57ee0 R15: 00000006abd25bee FS: 0000000000000000(0000) GS:ffffffff80b4d000(0000) knlGS:0000000000000000 CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b CR2: 000000000000005f CR3: 0000000000201000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process swapper (pid: 1, threadinfo ffff810824c56000, task ffff812024c52000) Stack: ffffffff80a57348 0000019500000000 ffff811024c5fa80 0000000000000000 00000000ffffff97 ffffffff802bfef0 0000000000000000 ffffffffffffffff 0000000000000000 ffffffff80bc3b4b ffff810824c57ee0 ffffffff80bc34a5 Call Trace: [<ffffffff802bfef0>] ? create_proc_entry+0x73/0x8a [<ffffffff80bc3b4b>] ? sctp_snmp_proc_init+0x1c/0x34 [<ffffffff80bc34a5>] ? sctp_init+0xef/0x711 [<ffffffff80b976e3>] ? kernel_init+0x175/0x2e1 [<ffffffff8020ccf8>] ? child_rip+0xa/0x12 [<ffffffff80b9756e>] ? kernel_init+0x0/0x2e1 [<ffffffff8020ccee>] ? child_rip+0x0/0x12 Code: 1e 48 83 7b 38 00 75 08 48 c7 43 38 f0 e8 82 80 48 83 7b 30 00 75 08 48 c7 43 30 d0 e9 82 80 48 c7 c7 60 24 cc 80 e8 bd 5a 54 00 <48> 8b 45 60 48 89 6b 58 48 89 5d 60 48 89 43 50 fe 05 f5 25 a0 RIP [<ffffffff802bfe55>] proc_register+0xe7/0x10f RSP <ffff810824c57e60> CR2: 000000000000005f ---[ end trace 02c2d78def82877a ]--- Kernel panic - not syncing: Attempted to kill init! it turns out some variables near end of bss are corrupted already. in System.map we have ffffffff80d40420 b rsi_table ffffffff80d40620 B krb5_seq_lock ffffffff80d40628 b i.20437 ffffffff80d40630 b xprt_rdma_inline_write_padding ffffffff80d40638 b sunrpc_table_header ffffffff80d40640 b zero ffffffff80d40644 b min_memreg ffffffff80d40648 b rpcrdma_tk_lock_g ffffffff80d40650 B sctp_assocs_id_lock ffffffff80d40658 B proc_net_sctp ffffffff80d40660 B sctp_assocs_id ffffffff80d40680 B sysctl_sctp_mem ffffffff80d40690 B sysctl_sctp_rmem ffffffff80d406a0 B sysctl_sctp_wmem ffffffff80d406b0 b sctp_ctl_socket ffffffff80d406b8 b sctp_pf_inet6_specific ffffffff80d406c0 b sctp_pf_inet_specific ffffffff80d406c8 b sctp_af_v4_specific ffffffff80d406d0 b sctp_af_v6_specific ffffffff80d406d8 b sctp_rand.33270 ffffffff80d406dc b sctp_memory_pressure ffffffff80d406e0 b sctp_sockets_allocated ffffffff80d406e4 b sctp_memory_allocated ffffffff80d406e8 b sctp_sysctl_header ffffffff80d406f0 b zero ffffffff80d406f4 A __bss_stop ffffffff80d406f4 A _end and setup_node_bootmem() will use that page 0xd40000 for bootmap Bootmem setup node 0 0000000000000000-0000000828000000 NODE_DATA [000000000008a485 - 0000000000091484] bootmap [0000000000d406f4 - 0000000000e456f3] pages 105 Bootmem setup node 1 0000000828000000-0000001028000000 NODE_DATA [0000000828000000 - 0000000828006fff] bootmap [0000000828007000 - 0000000828106fff] pages 100 Bootmem setup node 2 0000001028000000-0000001828000000 NODE_DATA [0000001028000000 - 0000001028006fff] bootmap [0000001028007000 - 0000001028106fff] pages 100 Bootmem setup node 3 0000001828000000-0000002028000000 NODE_DATA [0000001828000000 - 0000001828006fff] bootmap [0000001828007000 - 0000001828106fff] pages 100 setup_node_bootmem() makes NODE_DATA cacheline aligned, and bootmap is page-aligned. the patch updates find_e820_area() to make sure we can meet the alignment constraints. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: early boot debugging via FireWire (ohci1394_dma=early)Bernhard Kaindl
This patch adds a new configuration option, which adds support for a new early_param which gets checked in arch/x86/kernel/setup_{32,64}.c:setup_arch() to decide wether OHCI-1394 FireWire controllers should be initialized and enabled for physical DMA access to allow remote debugging of early problems like issues ACPI or other subsystems which are executed very early. If the config option is not enabled, no code is changed, and if the boot paramenter is not given, no new code is executed, and independent of that, all new code is freed after boot, so the config option can be even enabled in standard, non-debug kernels. With specialized tools, it is then possible to get debugging information from machines which have no serial ports (notebooks) such as the printk buffer contents, or any data which can be referenced from global pointers, if it is stored below the 4GB limit and even memory dumps of of the physical RAM region below the 4GB limit can be taken without any cooperation from the CPU of the host, so the machine can be crashed early, it does not matter. In the extreme, even kernel debuggers can be accessed in this way. I wrote a small kgdb module and an accompanying gdb stub for FireWire which allows to gdb to talk to kgdb using remote remory reads and writes over FireWire. An version of the gdb stub fore FireWire is able to read all global data from a system which is running a a normal kernel without any kernel debugger, without any interruption or support of the system's CPU. That way, e.g. the task struct and so on can be read and even manipulated when the physical DMA access is granted. A HOWTO is included in this patch, in Documentation/debugging-via-ohci1394.txt and I've put a copy online at ftp://ftp.suse.de/private/bk/firewire/docs/debugging-via-ohci1394.txt It also has links to all the tools which are available to make use of it another copy of it is online at: ftp://ftp.suse.de/private/bk/firewire/kernel/ohci1394_dma_early-v2.diff Signed-Off-By: Bernhard Kaindl <bk@suse.de> Tested-By: Thomas Renninger <trenn@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: fixes some bugs about EFI memory map handlingHuang, Ying
This patch fixes some bugs of EFI memory handing code. - On x86_64, it is possible that EFI memory map can not be mapped via identity map, so efi_map_memmap is removed, just use early_ioremap. - On i386, the EFI memory map mapping take effect cross paging_init, so it is not necessary to use efi_map_memmap. - EFI memory map is unmapped in efi_enter_virtual_mode to avoid early_ioremap leak. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: not set boot cpu in cpu_present_map againYinghai Lu
in init/main.c boot_cpu_init() already does that before setup_arch Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: fix section mismatch warning in setup_64.cSam Ravnborg
Fix the following warning: WARNING: arch/x86/kernel/built-in.o(.cpuinit.text+0x7a3): Section mismatch: reference to .init.text:amd_detect_cmp in 'init_amd' The function amd_detect_cmp were annotated __init and was only used from init_amd() which are annotated __cpuinit. Annotate amd_detect_cmp() with _cpuinit to fix it. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
