path: root/arch/x86/kernel/sys_x86_64.c
2015-03-31x86/mm: Improve AMD Bulldozer ASLR workaroundHector Marco-Gisbert
The ASLR implementation needs to special-case AMD F15h processors by clearing out bits [14:12] of the virtual address in order to avoid I$ cross invalidations and thus performance penalty for certain workloads. For details, see: dfb09f9b7ab0 ("x86, amd: Avoid cache aliasing penalties on AMD family 15h") This special case reduces the mmapped file's entropy by 3 bits. The following output is the run on an AMD Opteron 62xx class CPU processor under x86_64 Linux 4.0.0: $ for i in `seq 1 10`; do cat /proc/self/maps | grep "r-xp.*libc" ; done b7588000-b7736000 r-xp 00000000 00:01 4924 /lib/i386-linux-gnu/libc.so.6 b7570000-b771e000 r-xp 00000000 00:01 4924 /lib/i386-linux-gnu/libc.so.6 b75d0000-b777e000 r-xp 00000000 00:01 4924 /lib/i386-linux-gnu/libc.so.6 b75b0000-b775e000 r-xp 00000000 00:01 4924 /lib/i386-linux-gnu/libc.so.6 b7578000-b7726000 r-xp 00000000 00:01 4924 /lib/i386-linux-gnu/libc.so.6 ... Bits [12:14] are always 0, i.e. the address always ends in 0x8000 or 0x0000. 32-bit systems, as in the example above, are especially sensitive to this issue because 32-bit randomness for VA space is 8 bits (see mmap_rnd()). With the Bulldozer special case, this diminishes to only 32 different slots of mmap virtual addresses. This patch randomizes per boot the three affected bits rather than setting them to zero. Since all the shared pages have the same value at bits [12..14], there is no cache aliasing problems. This value gets generated during system boot and it is thus not known to a potential remote attacker. Therefore, the impact from the Bulldozer workaround gets diminished and ASLR randomness increased. More details at: http://hmarco.org/bugs/AMD-Bulldozer-linux-ASLR-weakness-reducing-mmaped-files-by-eight.html Original white paper by AMD dealing with the issue: http://developer.amd.com/wordpress/media/2012/10/SharedL1InstructionCacheonAMD15hCPU.pdf Mentored-by: Ismael Ripoll <iripoll@disca.upv.es> Signed-off-by: Hector Marco-Gisbert <hecmargi@upv.es> Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Kees Cook <keescook@chromium.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jan-Simon <dl9pf@gmx.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-fsdevel@vger.kernel.org Link: http://lkml.kernel.org/r/1427456301-3764-1-git-send-email-hecmargi@upv.es Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-08-22x86 get_unmapped_area: Access mmap_legacy_base through mm_struct memberRadu Caragea
This is the updated version of df54d6fa5427 ("x86 get_unmapped_area(): use proper mmap base for bottom-up direction") that only randomizes the mmap base address once. Signed-off-by: Radu Caragea <sinaelgl@gmail.com> Reported-and-tested-by: Jeff Shorey <shoreyjeff@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Michel Lespinasse <walken@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Adrian Sendroiu <molecula2788@gmail.com> Cc: Greg KH <greg@kroah.com> Cc: Kamal Mostafa <kamal@canonical.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-22Revert "x86 get_unmapped_area(): use proper mmap base for bottom-up direction"Linus Torvalds
This reverts commit df54d6fa54275ce59660453e29d1228c2b45a826. The commit isn't necessarily wrong, but because it recalculates the random mmap_base every time, it seems to confuse user memory allocators that expect contiguous mmap allocations even when the mmap address isn't specified. In particular, the MATLAB Java runtime seems to be unhappy. See https://bugzilla.kernel.org/show_bug.cgi?id=60774 So we'll want to apply the random offset only once, and Radu has a patch for that. Revert this older commit in order to apply the other one. Reported-by: Jeff Shorey <shoreyjeff@gmail.com> Cc: Radu Caragea <sinaelgl@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13x86 get_unmapped_area(): use proper mmap base for bottom-up directionRadu Caragea
When the stack is set to unlimited, the bottomup direction is used for mmap-ings but the mmap_base is not used and thus effectively renders ASLR for mmapings along with PIE useless. Cc: Michel Lespinasse <walken@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Adrian Sendroiu <molecula2788@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-24x86: Fix a typoYuanhan Liu
legact -> legacy Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-12-11mm: fix cache coloring on x86_64 architectureMichel Lespinasse
Fix the x86-64 cache alignment code to take pgoff into account. Use the x86 and MIPS cache alignment code as the basis for a generic cache alignment function. The old x86 code will always align the mmap to aliasing boundaries, even if the program mmaps the file with a non-zero pgoff. If program A mmaps the file with pgoff 0, and program B mmaps the file with pgoff 1. The old code would align the mmaps, resulting in misaligned pages: A: 0123 B: 123 After this patch, they are aligned so the pages line up: A: 0123 B: 123 Proposed by Rik van Riel. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm: use vm_unmapped_area() on x86_64 architectureMichel Lespinasse
Update the x86_64 arch_get_unmapped_area[_topdown] functions to make use of vm_unmapped_area() instead of implementing a brute force search. Signed-off-by: Michel Lespinasse <walken@google.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 support for x86-64 from Ingo Molnar: "This tree introduces the X32 binary format and execution mode for x86: 32-bit data space binaries using 64-bit instructions and 64-bit kernel syscalls. This allows applications whose working set fits into a 32 bits address space to make use of 64-bit instructions while using a 32-bit address space with shorter pointers, more compressed data structures, etc." Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c} * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits) x32: Fix alignment fail in struct compat_siginfo x32: Fix stupid ia32/x32 inversion in the siginfo format x32: Add ptrace for x32 x32: Switch to a 64-bit clock_t x32: Provide separate is_ia32_task() and is_x32_task() predicates x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls x86/x32: Fix the binutils auto-detect x32: Warn and disable rather than error if binutils too old x32: Only clear TIF_X32 flag once x32: Make sure TS_COMPAT is cleared for x32 tasks fs: Remove missed ->fds_bits from cessation use of fd_set structs internally fs: Fix close_on_exec pointer in alloc_fdtable x32: Drop non-__vdso weak symbols from the x32 VDSO x32: Fix coding style violations in the x32 VDSO code x32: Add x32 VDSO support x32: Allow x32 to be configured x32: If configured, add x32 system calls to system call tables x32: Handle process creation x32: Signal-related system calls x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h> ...
2012-03-21mm: search from free_area_cache for the bigger sizeXiao Guangrong
If the required size is bigger than cached_hole_size it is better to search from free_area_cache - it is easier to get a free region, specifically for the 64 bit process whose address space is large enough Do it just as hugetlb_get_unmapped_area_topdown() in arch/x86/mm/hugetlbpage.c Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hillf Danton <dhillf@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-20x86: Factor out TIF_IA32 from 32-bit address spaceH. Peter Anvin
Factor out IA32 (compatibility instruction set) from 32-bit address space in the thread_info flags; this is a precondition patch for x32 support. Originally-by: H. J. Lu <hjl.tools@gmail.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Link: http://lkml.kernel.org/n/tip-4pr1xnnksprt7t0h3w5fw4rv@git.kernel.org
2011-09-28x86, amd: Include linux/elf.h since we use stuff from asm/elf.hStephen Rothwell
After merging the moduleh tree, today's linux-next build (x86_64 allmodconfig) failed like this: arch/x86/kernel/sys_x86_64.c:28:10: warning: 'enum align_flags' declared inside parameter list arch/x86/kernel/sys_x86_64.c:28:10: warning: its scope is only this definition or declaration, which is probably not what you want arch/x86/kernel/sys_x86_64.c:28:22: error: parameter 3 ('flags') has incomplete type [...] Presumably caused by the module.h split interacting with a new commit dfb09f9b7ab0 ("x86, amd: Avoid cache aliasing penalties on AMD family 15h") from the x8 tree. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Link: http://lkml.kernel.org/r/20110928174214.17a58be15d84d67c185930e1@canb.auug.org.au Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-06x86-32, amd: Move va_align definition to unbreak 32-bit buildBorislav Petkov
hpa reported that dfb09f9b7ab03fd367740e541a5caf830ed56726 breaks 32-bit builds with the following error message: /home/hpa/kernel/linux-tip.cpu/arch/x86/kernel/cpu/amd.c:437: undefined reference to `va_align' /home/hpa/kernel/linux-tip.cpu/arch/x86/kernel/cpu/amd.c:436: undefined reference to `va_align' This is due to the fact that va_align is a global in a 64-bit only compilation unit. Move it to mmap.c where it is visible to both subarches. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Link: http://lkml.kernel.org/r/1312633899-1131-1-git-send-email-bp@amd64.org Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2011-08-05x86, amd: Avoid cache aliasing penalties on AMD family 15hBorislav Petkov
This patch provides performance tuning for the "Bulldozer" CPU. With its shared instruction cache there is a chance of generating an excessive number of cache cross-invalidates when running specific workloads on the cores of a compute module. This excessive amount of cross-invalidations can be observed if cache lines backed by shared physical memory alias in bits [14:12] of their virtual addresses, as those bits are used for the index generation. This patch addresses the issue by clearing all the bits in the [14:12] slice of the file mapping's virtual address at generation time, thus forcing those bits the same for all mappings of a single shared library across processes and, in doing so, avoids instruction cache aliases. It also adds the command line option "align_va_addr=(32|64|on|off)" with which virtual address alignment can be enabled for 32-bit or 64-bit x86 individually, or both, or be completely disabled. This change leaves virtual region address allocation on other families and/or vendors unaffected. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Link: http://lkml.kernel.org/r/1312550110-24160-2-git-send-email-bp@amd64.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-03-12improve sys_newuname() for compat architecturesChristoph Hellwig
On an architecture that supports 32-bit compat we need to override the reported machine in uname with the 32-bit value. Instead of doing this separately in every architecture introduce a COMPAT_UTS_MACHINE define in <asm/compat.h> and apply it directly in sys_newuname(). Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-08-11tracing: Convert x86_64 mmap and uname to use DEFINE_SYSCALLJason Baron
A number of syscalls are not using 'DEFINE_SYSCALL'. I'm not sure why. Convert x86_64 uname and mmap to use DEFINE_SYSCALL. Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Jiaying Zhang <jiayingz@google.com> Cc: Martin Bligh <mbligh@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2008-10-06Merge branches 'x86/alternatives', 'x86/cleanups', 'x86/commandline', ↵Ingo Molnar
'x86/crashdump', 'x86/debug', 'x86/defconfig', 'x86/doc', 'x86/exports', 'x86/fpu', 'x86/gart', 'x86/idle', 'x86/mm', 'x86/mtrr', 'x86/nmi-watchdog', 'x86/oprofile', 'x86/paravirt', 'x86/reboot', 'x86/sparse-fixes', 'x86/tsc', 'x86/urgent' and 'x86/vmalloc' into x86-v28-for-linus-phase1
2008-07-31x86: coding style fixes to arch/x86/kernel/sys_x86_64.cGustavo F. Padovan
Fix all errors and many warnings reported by checkpatch.pl without change sys_x86_64.o arch/x86/kernel/sys_x86_64.o: text data bss dec hex filename 1567 0 0 1567 61f sys_x86_64.o.after 1567 0 0 1567 61f sys_x86_64.o.before md5: de28ffedcb5851dfd7ec87a03afec1fd sys_x86_64.o.after de28ffedcb5851dfd7ec87a03afec1fd sys_x86_64.o.before Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-22x86: Introducing asm/syscalls.hJaswinder Singh
Declaring arch-dependent syscalls for x86 architecture Signed-off-by: Jaswinder Singh <jaswinder@infradead.org>
2008-05-03unified (weak) sys_pipe implementationUlrich Drepper
This replaces the duplicated arch-specific versions of "sys_pipe()" with one unified implementation. This removes almost 250 lines of duplicated code. It's marked __weak, so that *if* an architecture wants to override the default implementation it can do so by simply having its own replacement version, since many architectures use alternate calling conventions for the 'pipe()' system call for legacy reasons (ie traditional UNIX implementations often return the two file descriptors in registers) I still haven't changed the cris version even though Linus says the BKL isn't needed. The arch maintainer can easily do it if there are really no obstacles. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30x86: PIE executable randomization, checkpatch fixesAndrew Morton
#39: FILE: arch/ia64/ia32/binfmt_elf32.c:229: +elf32_map (struct file *filep, unsigned long addr, struct elf_phdr *eppnt, int prot, int type, unsigned long unused) WARNING: no space between function name and open parenthesis '(' #39: FILE: arch/ia64/ia32/binfmt_elf32.c:229: +elf32_map (struct file *filep, unsigned long addr, struct elf_phdr *eppnt, int prot, int type, unsigned long unused) WARNING: line over 80 characters #67: FILE: arch/x86/kernel/sys_x86_64.c:80: + new_begin = randomize_range(*begin, *begin + 0x02000000, 0); ERROR: use tabs not spaces #110: FILE: arch/x86/kernel/sys_x86_64.c:185: + ^I mm->cached_hole_size = 0;$ ERROR: use tabs not spaces #111: FILE: arch/x86/kernel/sys_x86_64.c:186: + ^I^Imm->free_area_cache = mm->mmap_base;$ ERROR: use tabs not spaces #112: FILE: arch/x86/kernel/sys_x86_64.c:187: + ^I}$ ERROR: use tabs not spaces #141: FILE: arch/x86/kernel/sys_x86_64.c:216: + ^I^I/* remember the largest hole we saw so far */$ ERROR: use tabs not spaces #142: FILE: arch/x86/kernel/sys_x86_64.c:217: + ^I^Iif (addr + mm->cached_hole_size < vma->vm_start)$ ERROR: use tabs not spaces #143: FILE: arch/x86/kernel/sys_x86_64.c:218: + ^I^I mm->cached_hole_size = vma->vm_start - addr;$ ERROR: use tabs not spaces #157: FILE: arch/x86/kernel/sys_x86_64.c:232: + ^Imm->free_area_cache = TASK_UNMAPPED_BASE;$ ERROR: need a space before the open parenthesis '(' #291: FILE: arch/x86/mm/mmap_64.c:101: + } else if(mmap_is_legacy()) { WARNING: braces {} are not necessary for single statement blocks #302: FILE: arch/x86/mm/mmap_64.c:112: + if (current->flags & PF_RANDOMIZE) { + mm->mmap_base += ((long)rnd) << PAGE_SHIFT; + } WARNING: line over 80 characters #314: FILE: fs/binfmt_elf.c:48: +static unsigned long elf_map (struct file *, unsigned long, struct elf_phdr *, int, int, unsigned long); WARNING: no space between function name and open parenthesis '(' #314: FILE: fs/binfmt_elf.c:48: +static unsigned long elf_map (struct file *, unsigned long, struct elf_phdr *, int, int, unsigned long); WARNING: line over 80 characters #429: FILE: fs/binfmt_elf.c:438: + eppnt, elf_prot, elf_type, total_size); ERROR: need space after that ',' (ctx:VxV) #480: FILE: fs/binfmt_elf.c:939: + elf_prot, elf_flags,0); ^ total: 9 errors, 7 warnings, 461 lines checked Your patch has style problems, please review. If any of these errors are false positives report them to the maintainer, see CHECKPATCH in MAINTAINERS. Please run checkpatch prior to sending patches Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Jakub Jelinek <jakub@redhat.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: PIE executable randomizationJiri Kosina
main executable of (specially compiled/linked -pie/-fpie) ET_DYN binaries onto a random address (in cases in which mmap() is allowed to perform a randomization). The code has been extraced from Ingo's exec-shield patch http://people.redhat.com/mingo/exec-shield/ [akpm@linux-foundation.org: fix used-uninitialsied warning] [kamezawa.hiroyu@jp.fujitsu.com: fixed ia32 ELF on x86_64 handling] Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Roland McGrath <roland@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-13Delete filenames in comments.Dave Jones
Since the x86 merge, lots of files that referenced their own filenames are no longer correct. Rather than keep them up to date, just delete them, as they add no real value. Additionally: - fix up comment formatting in scx200_32.c - Remove a credit from myself in setup_64.c from a time when we had no SCM - remove longwinded history from tsc_32.c which can be figured out from git. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11x86_64: move kernelThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
