path: root/arch/x86/kernel/time_64.c
2008-02-08time: fix typo in commentsLi Zefan
Fix typo in comments. BTW: I have to fix coding style in arch/ia64/kernel/time.c also, otherwise checkpatch.pl will be complaining. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30x86: fix cpu MHz reporting for AMD family 0x11Andreas Herrmann3
Fix cpu MHz reporting for AMD family 0x11 when powernow-k8 is disabled. Just adhere to the CONSTANT_TSC feature bit for AMD CPUs when deciding whether cpu_khz needs calibration. The additional check for CPU family is not needed and prevents calibration for future CPUs. Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: remove get_cycles_syncAndi Kleen
rdtsc is now speculation-safe, so no need for the sync variants of the APIs. [ mingo@elte.hu: removed the nsec_barrier() complication. ] Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: prepare time related functions for paravirtGlauber de Oliveira Costa
This patch add provisions for time related functions so they can be later replaced by paravirt versions. it basically encloses {g,s}et_wallclock inside the already existent functions update_persistent_clock and read_persistent_clock, and defines {s,g}et_wallclock to the core of such functions. it also allow for a later-on-game time initialization, as done by i386. Paravirt guests can set a function to do their own initialization this way. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: rename the struct pt_regs members for 32/64-bit consistencyH. Peter Anvin
We have a lot of code which differs only by the naming of specific members of structures that contain registers. In order to enable additional unifications, this patch drops the e- or r- size prefix from the register names in struct pt_regs, and drops the x- prefixes for segment registers on the 32-bit side. This patch also performs the equivalent renames in some additional places that might be candidates for unification in the future. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: clean up arch/x86/kernel/time_64.c includesThomas Gleixner
Reduce the lets include all to the minimum. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: share rtc codeThomas Gleixner
Remove the rtc code from time_64.c and add the extra bits to the i386 path. The ACPI century check is probably valid for i386 as well, but this is material for a separate patch. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: unify mc146818rtc.h - prepare for sharing rtc codeThomas Gleixner
Unify mc146818rtc.h by adding the rtc_cmos_read/write functions to time_64.c. This is a preparatory patch to finaly share the rtc code, which is unsurprisingly similar. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-11-17x86: on x86_64, correct reading of PC RTC when update in progress in time_64.cDavid P. Reed
Correct potentially unstable PC RTC time register reading in time_64.c Stop the use of an incorrect technique for reading the standard PC RTC timer, which is documented to "disconnect" time registers from the bus while updates are in progress. The use of UIP flag while interrupts are disabled to protect a 244 microsecond window is one of the Motorola spec sheet's documented ways to read the RTC time registers reliably. tglx: removed locking changes from original patch, as they gain nothing (read_persistent_clock is only called during boot, suspend, resume - so no hot path affected) and conflict with the paravirt locking scheme (see 32bit code), which we do not want to complicate for no benefit. Signed-off-by: David P. Reed <dpreed@reed.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-17x86: fix freeze in x86_64 RTC update code in time_64.cDavid P. Reed
Fix hard freeze on x86_64 when the ntpd service calls update_persistent_clock() A repeatable but randomly timed freeze has been happening in Fedora 6 and 7 for the last year, whenever I run the ntpd service on my AMD64x2 HP Pavilion dv9000z laptop. This freeze is due to the use of spin_lock(&rtc_lock) under the assumption (per a bad comment) that set_rtc_mmss is called only with interrupts disabled. The call from ntp.c to update_persistent_clock is made with interrupts enabled. Signed-off-by: David P. Reed <dpreed@reed.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-13Delete filenames in comments.Dave Jones
Since the x86 merge, lots of files that referenced their own filenames are no longer correct. Rather than keep them up to date, just delete them, as they add no real value. Additionally: - fix up comment formatting in scx200_32.c - Remove a credit from myself in setup_64.c from a time when we had no SCM - remove longwinded history from tsc_32.c which can be figured out from git. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12x86_64: remove now unused codeThomas Gleixner
Remove the unused code after the switch to clock events. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2007-10-12x86: unify timex.h variantsThomas Gleixner
Combine the timex.h variants and move the TSC related code into tsc.h. Move the set_cyc2ns_scale() call into the tsc calibraction code, where it belongs. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2007-10-12x86: Fix irq0 / local apic timer accountingThomas Gleixner
The clock events merge introduced a change to the nmi watchdog code to handle the not longer increasing local apic timer count in the broadcast mode. This is fine for UP, but on SMP it pampers over a stuck CPU which is not handling the broadcast interrupt due to the unconditional sum up of local apic timer count and irq0 count. To cover all cases we need to keep track on which CPU irq0 is handled. In theory this is CPU#0 due to the explicit disabling of irq balancing for irq0, but there are systems which ignore this on the hardware level. The per cpu irq0 accounting allows us to remove the irq0 to CPU0 binding as well. Add a per cpu counter for irq0 and evaluate this instead of the global irq0 count in the nmi watchdog code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2007-10-12x86_64: convert to clock eventsThomas Gleixner
Finally switch to the clockevents code. Share code with i386 for hpet and PIT. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2007-10-12i386: prepare sharing the PIT codeThomas Gleixner
PIT clock events work already and the PIT handling is the same for i386 and x86_64. x86_64 does not support PIT as a clock source, so disable the PIT clocksource for x86_64. Use the i386 i8253.h include file for x86_64 as well to share the exports and the PIT constants. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2007-10-12x86_64: Consolidate tsc calibrationThomas Gleixner
Move the TSC calibration code to tsc.c. Reimplement it so the pm timer can be used as a reference as well. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2007-10-12x86: block irq balancing for timerVenki Pallipadi
Disable irq balancing on IRQ0. Several SIS chipsets lock up when you try to change affinity of IRQ #0. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2007-10-11x86_64: move kernelThomas Gleixner
