path: root/arch/x86/kernel/traps_32.c
2008-10-13traps: x86: finalize unification of traps.cAlexander van Heukelum
traps_32.c and traps_64.c are now equal. Move one to traps.c, delete the other one and change the Makefile Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13traps: x86: make traps_32.c and traps_64.c equalAlexander van Heukelum
Use CONFIG_X86_64/CONFIG_X86_32 to condtionally compile the parts needed for x86_64 or i386 only. Runs a small userspace for a number of minimal configurations and boots the defconfigs. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13traps: x86: various noop-changes preparing for unification of traps_xx.cAlexander van Heukelum
- reordering include files - whitespace changes - comment changes - removed unused bad_intr() - make default_do_nmi static Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13traps: i386: expand clear_mem_error and remove from mach_traps.hAlexander van Heukelum
This is the last user of clear_mem_error, which is defined only on i386. Expand the inline function and remove it from include/asm-x86/mach-default/mach_traps.h Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13traps: i386: use preempt_conditional_sti/cli in do_int3Alexander van Heukelum
Use preempt_conditional_sti/cli in do_int3, like on x86_64. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13traps: x86: converge trap_init functionsAlexander van Heukelum
- set_system_gate on i386 is really set_system_trap_gate - set_system_gate on x86_64 is really set_system_intr_gate - ist=0 means no special stack switch is done: - introduce STACKFAULT_STACK, DOUBLEFAULT_STACK, NMI_STACK, DEBUG_STACK and MCE_STACK as on x86_64. - use the _ist variants with XXX_STACK set to zero - remove set_system_gate Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu> traps: x86: correct copy/paste bug: a trap is a GATE_TRAP Fix copy/paste/forgot-to-edit bug in desc.h. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13x86, traps: converge do_debug handlersAlexander van Heukelum
Make the x86_64-version and the i386-version of do_debug more similar. - introduce preempt_conditional_sti/cli to i386. The preempt-count is now elevated during the trap handler, like on x86_64. It does not run on a separate stack, however. - replace an open-coded "send_sigtrap" - copy some comments Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13x86, traps: introduce dotraplinkageAlexander van Heukelum
Mark the exception handlers with "dotraplinkage" to hide the calling convention differences between i386 and x86_64. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13x86, traps, i386: factor out lazy io-bitmap copyAlexander van Heukelum
x86_64 does not do the lazy io-bitmap dance. Putting it in its own function makes i386's do_general_protection look much more like x86_64's. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: split out dumpstack code from traps_32.cAlexander van Heukelum
The dumpstack code is logically quite independent from the hardware traps. Split it out into its own file. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13x86: __show_registers() and __show_regs() API unificationPekka Enberg
Currently the low-level function to dump user-passed registers on i386 is called __show_registers() whereas on x86-64 it's called __show_regs(). Unify the API to simplify porting of kmemcheck to x86-64. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13traps: i386: make do_trap more like x86_64Alexander van Heukelum
This patch hardcodes which traps should be forwarded to handle_vm86_trap in do_trap. This allows to remove the vm86 parameter from the i386-version of do_trap, which makes the DO_VM86_ERROR and DO_VM86_ERROR_INFO macros unnecessary. x86_64 part is whitespace only. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: trace_hardirqs_fixup should now not be necessary: irqs are off.Alexander van Heukelum
The exception handlers in entry_32.S should now all call TRACE_IRQS_OFF before calling the C code. The calls to trace_hardirqs_fixup should now be unnecessary. Remove them. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: remove temporary DO_TRAP macros, expanding the last one usedAlexander van Heukelum
Only one use of the DO_TRAP macros remains. Expand that one and remove the macros now. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 19 to an interrupt gateAlexander van Heukelum
Handle SIMD coprocessor exception with interrupt initially off. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 18 to an interrupt gateAlexander van Heukelum
Handle machine check exception with interrupt initially off. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 17 to an interrupt gateAlexander van Heukelum
Handle alignment check exception with interrupt initially off. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 16 to an interrupt gateAlexander van Heukelum
Handle coprocessor error exception with interrupt initially off. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 15 to an interrupt gateAlexander van Heukelum
Handle exception 15 with interrupt initially off. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 13 to an interrupt gateAlexander van Heukelum
Handle general protection exception with interrupt initially off. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 12 to an interrupt gateAlexander van Heukelum
Handle stack segment exception with interrupt initially off. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 11 to an interrupt gateAlexander van Heukelum
Handle segment not present exception with interrupt initially off. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 10 to an interrupt gateAlexander van Heukelum
Handle invalid TSS exception with interrupt initially off. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 9 to an interrupt gateAlexander van Heukelum
Handle coprocessor segment overrun exception with interrupt initially off. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 7 to an interrupt gateAlexander van Heukelum
Handle no coprocessor exception with interrupt initially off. device_not_available in entry_32.S calls either math_state_restore or math_emulate. This patch adds an extra indirection to be able to re-enable interrupts explicitly in traps_32.c Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 6 to an interrupt gateAlexander van Heukelum
Handle invalid opcode exception with interrupt initially off. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 5 to an interrupt gateAlexander van Heukelum
Handle bounds exception with interrupt initially off. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 4 to an interrupt gateAlexander van Heukelum
Handle overflow exception with interrupt initially off. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: expand exception 3 DO_TRAP macroAlexander van Heukelum
The int3 exception was already takes as an interrupt and do_int3 does not fit in the new DO_ERROR macro. This patch just expands the DO_TRAP macro and rearranges the code a bit. No functional changes intended. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: convert hardware exception 0 to an interrupt gateAlexander van Heukelum
Handle divide error exception with interrupt initially off. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: prepare to convert exceptions to interruptsAlexander van Heukelum
There is some macro magic in traps_32.c to construct standard exception dispatch functions. This patch renames the DO_ERROR- like macros to DO_TRAP, and introduces new DO_ERROR ones that conditionally reenable interrupts explicitly, like x86_64. No code changes. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13i386: remove kprobes' restore_interrupts in favour of conditional_stiAlexander van Heukelum
x86_64 uses a helper function conditional_sti in traps_64.c which is equal to restore_interrupts in kprobes.h. The only user of restore_interrupts is in traps_32.c. Introduce conditional_sti for i386 and remove restore_interrupts. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-23signals: demultiplexing SIGTRAP signalSrinivasa Ds
Currently a SIGTRAP can denote any one of below reasons. - Breakpoint hit - H/W debug register hit - Single step - Signal sent through kill() or rasie() Architectures like powerpc/parisc provides infrastructure to demultiplex SIGTRAP signal by passing down the information for receiving SIGTRAP through si_code of siginfot_t structure. Here is an attempt is generalise this infrastructure by extending it to x86 and x86_64 archs. Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Cc: Roland McGrath <roland@redhat.com> Cc: akpm@linux-foundation.org Cc: paulus@samba.org Cc: linuxppc-dev@ozlabs.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-30x86, xsave: enable xsave/xrstor on cpus with xsave supportSuresh Siddha
Enables xsave/xrstor by turning on cr4.osxsave on cpu's which have the xsave support. For now, features that OS supports/enabled are FP and SSE. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-18x86: introducing asm-x86/traps.hJaswinder Singh
Declaring x86 traps under one hood. Declaring x86 do_traps before defining them. Signed-off-by: Jaswinder Singh <jaswinder@infradead.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-18x86: traps_xx: modify x86_64 to use _log_lvl variantsAlexander van Heukelum
i386 has show_trace_log_lvl and show_stack_log_lvl, allowing traces to be emitted with log-level annotations. This patch introduces them to x86_64, but log_lvl is only ever set to an empty string. Output of traces is unchanged. i386-chunk is whitespace-only. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-18x86: traps_xx: refactor die() like in x86_64Alexander van Heukelum
Make the diff between the traps_32.c and traps_64.c a bit smaller. Change traps_32.c to look more like traps_64.c: - move lock information to file scope - split out oops_begin() and oops_end() from die() - increment nest counter in oops_begin Only whitespace change in traps_64.c No functional changes intended. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Acked-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-09x86: traps_xx: various small changesAlexander van Heukelum
- order of local variable declarations - minor code changes Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Acked-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-09x86: traps_xx: modify default_do_nmiAlexander van Heukelum
- local caching of smp_processor_id() in default_do_nmi() - v2: do not split default_do_nmi over two lines On Wed, Jul 02, 2008 at 08:12:20PM +0400, Cyrill Gorcunov wrote: > | -static notrace __kprobes void default_do_nmi(struct pt_regs *regs) > | +static notrace __kprobes void > | +default_do_nmi(struct pt_regs *regs) > | [ ... ] > | -asmlinkage notrace __kprobes void default_do_nmi(struct pt_regs *regs) > | +asmlinkage notrace __kprobes void > | +default_do_nmi(struct pt_regs *regs) > > Hi Alexander, good done, thanks! But why did you split default_do_nmi > definition by two lines? I think it would be better to keep them as it > was before, ie by a single line > > static notrace __kprobes void default_do_nmi(struct pt_regs *regs) Thanks! Here is the replacement patch with default_do_nmi left on a single line. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Acked-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-09x86: traps_xx: restructure do_general_protection()Alexander van Heukelum
- if (cond) block -> if (!cond) goto end_of_block - local caching of current Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Acked-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-09x86: traps_xx: modify __dieAlexander van Heukelum
if (cond) block -> if (!cond) goto end_of_block Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Acked-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-09x86: traps_xx: shuffle headers and globalsAlexander van Heukelum
Reorder headers and collect globals in traps_32.c and traps_64.c Code size and data size are unaffected by the changes. Code itself is changed due to different ordering of data and bss. The bss segment changed size due to a change in the packing of the variables. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Acked-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-09x86: initial changes to unify traps_32.c and traps_64.cAlexander van Heukelum
This patch does not change the generated object files. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: fix "x86: let setup_arch call init_apic_mappings for 32bit"Ingo Molnar
add back this line lost from trap_init(): set_trap_gate(0, &divide_error); Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: let setup_arch call init_apic_mappings for 32bitYinghai Lu
instead of calling it from trap_init() also move init ioapic mapping out of apic_32.c so 32 bit do same as 64 bit Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: don't use gdt_page openly.Glauber Costa
There's a macro available for that. Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-16Merge branch 'linus' into x86/nmitip-x86-nmi-2008-06-16_09.20_MonIngo Molnar
Conflicts: arch/x86/kernel/nmi_32.c
2008-06-12x86, lockdep: fix "WARNING: at kernel/lockdep.c:2658 check_flags+0x4c/0x128()"Vegard Nossum
Alessandro Suardi reported: > Recently upgraded my FC6 desktop to Fedora 9; with the > latest nautilus RPM updates my VNC session went nuts > with nautilus pegging the CPU for everything that breathed. > > I now reverted to an earlier nautilus package, but during > the peak CPU period my kernel spat this: > > [314185.623294] ------------[ cut here ]------------ > [314185.623414] WARNING: at kernel/lockdep.c:2658 check_flags+0x4c/0x128() > [314185.623514] Modules linked in: iptable_filter ip_tables x_tables > sunrpc ipv6 fuse snd_via82xx snd_ac97_codec ac97_bus snd_mpu401_uart > snd_rawmidi via686a hwmon parport_pc sg parport uhci_hcd ehci_hcd > [314185.623924] Pid: 12314, comm: nautilus Not tainted 2.6.26-rc5-git2 #4 > [314185.624021] [<c0115b95>] warn_on_slowpath+0x41/0x7b > [314185.624021] [<c010de70>] ? do_page_fault+0x2c1/0x5fd > [314185.624021] [<c0128396>] ? up_read+0x16/0x28 > [314185.624021] [<c010de70>] ? do_page_fault+0x2c1/0x5fd > [314185.624021] [<c012fa33>] ? __lock_acquire+0xbb4/0xbc3 > [314185.624021] [<c012d0a0>] check_flags+0x4c/0x128 > [314185.624021] [<c012fa73>] lock_acquire+0x31/0x7d > [314185.624021] [<c0128cf6>] __atomic_notifier_call_chain+0x30/0x80 > [314185.624021] [<c0128cc6>] ? __atomic_notifier_call_chain+0x0/0x80 > [314185.624021] [<c0128d52>] atomic_notifier_call_chain+0xc/0xe > [314185.624021] [<c0128d81>] notify_die+0x2d/0x2f > [314185.624021] [<c01043b0>] do_int3+0x1f/0x4d > [314185.624021] [<c02f2d3b>] int3+0x27/0x2c > [314185.624021] ======================= > [314185.624021] ---[ end trace 1923f65a2d7bb246 ]--- > [314185.624021] possible reason: unannotated irqs-off. > [314185.624021] irq event stamp: 488879 > [314185.624021] hardirqs last enabled at (488879): [<c0102d67>] > restore_nocheck+0x12/0x15 > [314185.624021] hardirqs last disabled at (488878): [<c0102dca>] > work_resched+0x19/0x30 > [314185.624021] softirqs last enabled at (488876): [<c011a1ba>] > __do_softirq+0xa6/0xac > [314185.624021] softirqs last disabled at (488865): [<c010476e>] > do_softirq+0x57/0xa6 > > I didn't seem to find it with some googling, so here it is. > > I was incidentally ltracing that process to try and find out > what was gulping down that much CPU (sorry, no idea > whether ltrace and the WARNING happened at the same > time or which came first) and: Yeah, this is extremely likely to be the source of the warning. The warning should be harmless, however. > Box is my trusty noname K7-800, 512MB RAM; if there's > anything else useful I might be able to provide, just ask. It would be interesting to see where the int3 comes from. Too bad, lockdep doesn't provide the register dump. The stacktrace also doesn't go further than the int3(), I wonder if this int3 came from userspace? The ltrace readme says "software breakpoints, like gdb", so I guess this is the case. Yep, seems like it. This looks relevant: | commit fb1dac909d94ff807cd833d340c6827c3a957159 | Author: Peter Zijlstra <a.p.zijlstra@chello.nl> | Date: Wed Jan 16 09:51:59 2008 +0100 | | lockdep: more hardirq annotations for notify_die() I'm attaching a similarly-looking patch for this case (DO_VM86_ERROR), though I suspect it might be missing for the other cases (DO_ERROR/DO_ERROR_INFO) as well. Reported-by: Alessandro Suardi <alessandro.suardi@gmail.com> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-25x86: nmi - unify die_nmi() interfaceCyrill Gorcunov
By slightly changing 32bit mode die_nmi() we may unify the interface and make it common for both (32/64bit) modes Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: hpa@zytor.com Cc: mingo@redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-26i386: fix signal type for iret exceptionJan Beulich
.. since it uses ILL_BADSTK (which is meaningless in the context of SIGSEGV). Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
