path: root/arch/x86/kernel
2012-02-15mm, rt: kmap_atomic schedulingPeter Zijlstra
In fact, with migrate_disable() existing one could play games with kmap_atomic. You could save/restore the kmap_atomic slots on context switch (if there are any in use of course), this should be esp easy now that we have a kmap_atomic stack. Something like the below.. it wants replacing all the preempt_disable() stuff with pagefault_disable() && migrate_disable() of course, but then you can flip kmaps around like below. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> [dvhart@linux.intel.com: build fix] Link: http://lkml.kernel.org/r/1311842631.5890.208.camel@twins
2012-02-15x86-no-perf-irq-work-rt.patchThomas Gleixner
2012-02-15x86: Disable IST stacks for debug/int 3/stack fault for PREEMPT_RTAndi Kleen
Normally the x86-64 trap handlers for debug/int 3/stack fault run on a special interrupt stack to make them more robust when dealing with kernel code. The PREEMPT_RT kernel can sleep in locks even while allocating GFP_ATOMIC memory. When one of these trap handlers needs to send real time signals for ptrace it allocates memory and could then try to to schedule. But it is not allowed to schedule on a IST stack. This can cause warnings and hangs. This patch disables the IST stacks for these handlers for PREEMPT_RT kernel. Instead let them run on the normal process stack. The kernel only really needs the ISTs here to make kernel debuggers more robust in case someone sets a break point somewhere where the stack is invalid. But there are no kernel debuggers in the standard kernel that do this. It also means kprobes cannot be set in situations with invalid stack; but that sounds like a reasonable restriction. The stack fault change could minimally impact oops quality, but not very much because stack faults are fairly rare. A better solution would be to use similar logic as the NMI "paranoid" path: check if signal is for user space, if yes go back to entry.S, switch stack, call sync_regs, then do the signal sending etc. But this patch is much simpler and should work too with minimal impact. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-02-15x86: Convert mce timer to hrtimerThomas Gleixner
mce_timer is started in atomic contexts of cpu bringup. This results in might_sleep() warnings on RT. Convert mce_timer to a hrtimer to avoid this. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-02-15softirq-disable-softirq-stacks-for-rt.patchThomas Gleixner
2012-02-15early-printk-consolidate.patchThomas Gleixner
2012-02-15timekeeping: Convert xtime_lock to raw_seqlockThomas Gleixner
Convert xtime_lock to raw_seqlock and fix up all users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-02-15x86: Do not disable preemption in int3 on 32bitSteven Rostedt
Preemption must be disabled before enabling interrupts in do_trap on x86_64 because the stack in use for int3 and debug is a per CPU stack set by th IST. But 32bit does not have an IST and the stack still belongs to the current task and there is no problem in scheduling out the task. Keep preemption enabled on X86_32 when enabling interrupts for do_trap(). The name of the function is changed from preempt_conditional_sti/cli() to conditional_sti/cli_ist(), to annotate that this function is used when the stack is on the IST. Cc: stable-rt@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-02-15x86-32-fix-signal-crap.patchThomas Gleixner
2012-02-15x86: Do not unmask io_apic when interrupt is in progressIngo Molnar
With threaded interrupts we might see an interrupt in progress on migration. Do not unmask it when this is the case. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-02-15signal/x86: Delay calling signals in atomicOleg Nesterov
On x86_64 we must disable preemption before we enable interrupts for stack faults, int3 and debugging, because the current task is using a per CPU debug stack defined by the IST. If we schedule out, another task can come in and use the same stack and cause the stack to be corrupted and crash the kernel on return. When CONFIG_PREEMPT_RT_FULL is enabled, spin_locks become mutexes, and one of these is the spin lock used in signal handling. Some of the debug code (int3) causes do_trap() to send a signal. This function calls a spin lock that has been converted to a mutex and has the possibility to sleep. If this happens, the above issues with the corrupted stack is possible. Instead of calling the signal right away, for PREEMPT_RT and x86_64, the signal information is stored on the stacks task_struct and TIF_NOTIFY_RESUME is set. Then on exit of the trap, the signal resume code will send the signal when preemption is enabled. [ rostedt: Switched from #ifdef CONFIG_PREEMPT_RT_FULL to ARCH_RT_DELAYS_SIGNAL_SEND and added comments to the code. ] Cc: stable-rt@vger.kernel.org Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-02-15sched: Use schedule_preempt_disabled()Thomas Gleixner
Coccinelle based conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-02-15x86: hpet: Disable MSI on Lenovo W510Thomas Gleixner
MSI based per cpu timers lose interrupts when intel_idle() is enabled - independent of the c-state. With idle=poll the problem cannot be observed. We have no idea yet, whether this is a W510 specific issue or a general chipset oddity. Blacklist the known problem machine. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-02-15x86: kprobes: Remove remove bogus preempt_enableThomas Gleixner
The CONFIG_PREEMPT=n section of setup_singlestep() contains: preempt_enable_no_resched(); That's bogus as it is asymetric - no preempt_disable() - and it just never blew up because preempt_enable_no_resched() is a NOP when CONFIG_PREEMPT=n. Remove it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-02-15x86: Call idle notifier after irq_enter()Frederic Weisbecker
Interrupts notify the idle exit state before calling irq_enter(). But the notifier code calls rcu_read_lock() and this is not allowed while rcu is in an extended quiescent state. We need to wait for rcu_irq_enter() to be called before doing so otherwise this results in a grumpy RCU: [ 0.099991] WARNING: at include/linux/rcupdate.h:194 __atomic_notifier_call_chain+0xd2/0x110() [ 0.099991] Hardware name: AMD690VM-FMH [ 0.099991] Modules linked in: [ 0.099991] Pid: 0, comm: swapper Not tainted 3.0.0-rc6+ #255 [ 0.099991] Call Trace: [ 0.099991] <IRQ> [<ffffffff81051c8a>] warn_slowpath_common+0x7a/0xb0 [ 0.099991] [<ffffffff81051cd5>] warn_slowpath_null+0x15/0x20 [ 0.099991] [<ffffffff817d6fa2>] __atomic_notifier_call_chain+0xd2/0x110 [ 0.099991] [<ffffffff817d6ff1>] atomic_notifier_call_chain+0x11/0x20 [ 0.099991] [<ffffffff81001873>] exit_idle+0x43/0x50 [ 0.099991] [<ffffffff81020439>] smp_apic_timer_interrupt+0x39/0xa0 [ 0.099991] [<ffffffff817da253>] apic_timer_interrupt+0x13/0x20 [ 0.099991] <EOI> [<ffffffff8100ae67>] ? default_idle+0xa7/0x350 [ 0.099991] [<ffffffff8100ae65>] ? default_idle+0xa5/0x350 [ 0.099991] [<ffffffff8100b19b>] amd_e400_idle+0x8b/0x110 [ 0.099991] [<ffffffff810cb01f>] ? rcu_enter_nohz+0x8f/0x160 [ 0.099991] [<ffffffff810019a0>] cpu_idle+0xb0/0x110 [ 0.099991] [<ffffffff817a7505>] rest_init+0xe5/0x140 [ 0.099991] [<ffffffff817a7468>] ? rest_init+0x48/0x140 [ 0.099991] [<ffffffff81cc5ca3>] start_kernel+0x3d1/0x3dc [ 0.099991] [<ffffffff81cc5321>] x86_64_start_reservations+0x131/0x135 [ 0.099991] [<ffffffff81cc5412>] x86_64_start_kernel+0xed/0xf4 Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20110929194047.GA10247@linux.vnet.ibm.com Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Andy Henroid <andrew.d.henroid@intel.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-02-03x86/microcode_amd: Add support for CPU family specific container filesAndreas Herrmann
commit 5b68edc91cdc972c46f76f85eded7ffddc3ff5c2 upstream. We've decided to provide CPU family specific container files (starting with CPU family 15h). E.g. for family 15h we have to load microcode_amd_fam15h.bin instead of microcode_amd.bin Rationale is that starting with family 15h patch size is larger than 2KB which was hard coded as maximum patch size in various microcode loaders (not just Linux). Container files which include patches larger than 2KB cause different kinds of trouble with such old patch loaders. Thus we have to ensure that the default container file provides only patches with size less than 2KB. Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Borislav Petkov <borislav.petkov@amd.com> Cc: <stable@kernel.org> Link: http://lkml.kernel.org/r/20120120164412.GD24508@alberich.amd.com [ documented the naming convention and tidied the code a bit. ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-25x86, UV: Update Boot messages for SGI UV2 platformJack Steiner
commit da517a08ac5913cd80ce3507cddd00f2a091b13c upstream. SGI UV systems print a message during boot: UV: Found <num> blades Due to packaging changes, the blade count is not accurate for on the next generation of the platform. This patch corrects the count. Signed-off-by: Jack Steiner <steiner@sgi.com> Link: http://lkml.kernel.org/r/20120106191900.GA19772@sgi.com Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25x86/PCI: amd: factor out MMCONFIG discoveryBjorn Helgaas
commit 24d25dbfa63c376323096660bfa9ad45a08870ce upstream. This factors out the AMD native MMCONFIG discovery so we can use it outside amd_bus.c. amd_bus.c reads AMD MSRs so it can remove the MMCONFIG area from the PCI resources. We may also need the MMCONFIG information to work around BIOS defects in the ACPI MCFG table. Cc: Borislav Petkov <borislav.petkov@amd.com> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-23perf/x86: Fix raw_spin_unlock_irqrestore() usageRobert Richter
Use raw_spin_unlock_irqrestore() as equivalent to raw_spin_lock_irqsave(). Signed-off-by: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1324646665-13334-1-git-send-email-robert.richter@amd.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-19x86, dumpstack: Fix code bytes breakage due to missing KERN_CONTClemens Ladisch
When printing the code bytes in show_registers(), the markers around the byte at the fault address could make the printk() format string look like a valid log level and facility code. This would prevent this byte from being printed and result in a spurious newline: [ 7555.765589] Code: 8b 32 e9 94 00 00 00 81 7d 00 ff 00 00 00 0f 87 96 00 00 00 48 8b 83 c0 00 00 00 44 89 e2 44 89 e6 48 89 df 48 8b 80 d8 02 00 00 [ 7555.765683] 8b 48 28 48 89 d0 81 e2 ff 0f 00 00 48 c1 e8 0c 48 c1 e0 04 Add KERN_CONT where needed, and elsewhere in show_registers() for consistency. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Link: http://lkml.kernel.org/r/4EEFA7AE.9020407@ladisch.de Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-12-12Revert "x86, efi: Calling __pa() with an ioremap()ed address is invalid"Keith Packard
This hangs my MacBook Air at boot time; I get no console messages at all. I reverted this on top of -rc5 and my machine boots again. This reverts commit e8c7106280a305e1ff2a3a8a4dfce141469fb039. Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Matthew Garrett <mjg@redhat.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Huang Ying <huang.ying.caritas@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1321621751-3650-1-git-send-email-matt@console Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-09x86, efi: Calling __pa() with an ioremap()ed address is invalidMatt Fleming
If we encounter an efi_memory_desc_t without EFI_MEMORY_WB set in ->attribute we currently call set_memory_uc(), which in turn calls __pa() on a potentially ioremap'd address. On CONFIG_X86_32 this is invalid, resulting in the following oops on some machines: BUG: unable to handle kernel paging request at f7f22280 IP: [<c10257b9>] reserve_ram_pages_type+0x89/0x210 [...] Call Trace: [<c104f8ca>] ? page_is_ram+0x1a/0x40 [<c1025aff>] reserve_memtype+0xdf/0x2f0 [<c1024dc9>] set_memory_uc+0x49/0xa0 [<c19334d0>] efi_enter_virtual_mode+0x1c2/0x3aa [<c19216d4>] start_kernel+0x291/0x2f2 [<c19211c7>] ? loglevel+0x1b/0x1b [<c19210bf>] i386_start_kernel+0xbf/0xc8 A better approach to this problem is to map the memory region with the correct attributes from the start, instead of modifying it after the fact. The uncached case can be handled by ioremap_nocache() and the cached by ioremap_cache(). Despite first impressions, it's not possible to use ioremap_cache() to map all cached memory regions on CONFIG_X86_64 because EFI_RUNTIME_SERVICES_DATA regions really don't like being mapped into the vmalloc space, as detailed in the following bug report, https://bugzilla.redhat.com/show_bug.cgi?id=748516 Therefore, we need to ensure that any EFI_RUNTIME_SERVICES_DATA regions are covered by the direct kernel mapping table on CONFIG_X86_64. To accomplish this we now map E820_RESERVED_EFI regions via the direct kernel mapping with the initial call to init_memory_mapping() in setup_arch(), whereas previously these regions wouldn't be mapped if they were after the last E820_RAM region until efi_ioremap() was called. Doing it this way allows us to delete efi_ioremap() completely. Signed-off-by: Matt Fleming <matt.fleming@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Matthew Garrett <mjg@redhat.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Huang Ying <huang.ying.caritas@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1321621751-3650-1-git-send-email-matt@console-pimps.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-08x86, hpet: Immediately disable HPET timer 1 if rtc irq is maskedMark Langsdorf
When HPET is operating in RTC mode, the TN_ENABLE bit on timer1 controls whether the HPET or the RTC delivers interrupts to irq8. When the system goes into suspend, the RTC driver sends a signal to the HPET driver so that the HPET releases control of irq8, allowing the RTC to wake the system from suspend. The switchover is accomplished by a write to the HPET configuration registers which currently only occurs while servicing the HPET interrupt. On some systems, I have seen the system suspend before an HPET interrupt occurs, preventing the write to the HPET configuration register and leaving the HPET in control of the irq8. As the HPET is not active during suspend, it does not generate a wake signal and RTC alarms do not work. This patch forces the HPET driver to immediately transfer control of the irq8 channel to the RTC instead of waiting until the next interrupt event. Signed-off-by: Mark Langsdorf <mark.langsdorf@amd.com> Link: http://lkml.kernel.org/r/20111118153306.GB16319@alberich.amd.com Tested-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org
2011-12-05Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: intr_remapping: Fix section mismatch in ir_dev_scope_init() intel-iommu: Fix section mismatch in dmar_parse_rmrr_atsr_dev() x86, amd: Fix up numa_node information for AMD CPU family 15h model 0-0fh northbridge functions x86, AMD: Correct align_va_addr documentation x86/rtc, mrst: Don't register a platform RTC device for for Intel MID platforms x86/mrst: Battery fixes x86/paravirt: PTE updates in k(un)map_atomic need to be synchronous, regardless of lazy_mmu mode x86: Fix "Acer Aspire 1" reboot hang x86/mtrr: Resolve inconsistency with Intel processor manual x86: Document rdmsr_safe restrictions x86, microcode: Fix the failure path of microcode update driver init code Add TAINT_FIRMWARE_WORKAROUND on MTRR fixup x86/mpparse: Account for bus types other than ISA and PCI x86, mrst: Change the pmic_gpio device type to IPC mrst: Added some platform data for the SFI translations x86,mrst: Power control commands update x86/reboot: Blacklist Dell OptiPlex 990 known to require PCI reboot x86, UV: Fix UV2 hub part number x86: Add user_mode_vm check in stack_overflow_check
2011-12-05Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf: Fix loss of notification with multi-event perf, x86: Force IBS LVT offset assignment for family 10h perf, x86: Disable PEBS on SandyBridge chips trace_events_filter: Use rcu_assign_pointer() when setting ftrace_event_call->filter perf session: Fix crash with invalid CPU list perf python: Fix undefined symbol problem perf/x86: Enable raw event access to Intel offcore events perf: Don't use -ENOSPC for out of PMU resources perf: Do not set task_ctx pointer in cpuctx if there are no events in the context perf/x86: Fix PEBS instruction unwind oprofile, x86: Fix crash when unloading module (nmi timer mode) oprofile: Fix crash when unloading module (hr timer mode)
2011-12-05x86, amd: Fix up numa_node information for AMD CPU family 15h model 0-0fh ↵Andreas Herrmann
northbridge functions I've received complaints that the numa_node attribute for family 15h model 00-0fh (e.g. Interlagos) northbridge functions shows -1 instead of the proper node ID. Correct this with attached quirks (similar to quirks for other AMD CPU families used in multi-socket systems). Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Frank Arnold <frank.arnold@amd.com> Cc: Borislav Petkov <borislav.petkov@amd.com> Link: http://lkml.kernel.org/r/20111202072143.GA31916@alberich.amd.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05x86/rtc, mrst: Don't register a platform RTC device for for Intel MID platformsMathias Nyman
Intel MID x86 platforms have a memory mapped virtual RTC instead. No MID platform have the default ports (and accessing them may do weird stuff). Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: feng.tang@intel.com Cc: Feng Tang <feng.tang@intel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05Merge branch 'ucode' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp ↵Ingo Molnar
into x86/urgent
2011-12-05x86: Fix "Acer Aspire 1" reboot hangPeter Chubb
Looks like on some Acer Aspire 1s with older bioses, reboot via bios fails. It works on my machine, (with BIOS version 0.3310) but not on some others (BIOS version 0.3309). There's a log of problems at: https://bbs.archlinux.org/viewtopic.php?id=124136 This patch adds a different callback to the reboot quirk table, to allow rebooting via keybaord controller. Reported-by: Uroš Vampl <mobile.leecher@gmail.com> Tested-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Peter Chubb <peter.chubb@nicta.com.au> Cc: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stable@kernel.org Link: http://lkml.kernel.org/r/1323093233-9481-1-git-send-email-anarsoul@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05x86/mtrr: Resolve inconsistency with Intel processor manualAjaykumar Hotchandani
Following is from Notes of section 11.5.3 of Intel processor manual available at: http://www.intel.com/Assets/PDF/manual/325384.pdf For the Pentium 4 and Intel Xeon processors, after the sequence of steps given above has been executed, the cache lines containing the code between the end of the WBINVD instruction and before the MTRRS have actually been disabled may be retained in the cache hierarchy. Here, to remove code from the cache completely, a second WBINVD instruction must be executed after the MTRRs have been disabled. This patch provides resolution for that. Ideally, I will like to make changes only for Pentium 4 and Xeon processors. But, I am not finding easier way to do it. And, extra wbinvd() instruction does not hurt much for other processors. Signed-off-by: Ajaykumar Hotchandani <ajaykumar.hotchandani@oracle.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Link: http://lkml.kernel.org/r/4EBD1CC5.3030008@oracle.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05x86, microcode: Fix the failure path of microcode update driver init codeSrivatsa S. Bhat
The microcode update driver's initialization code does not handle failures correctly. This patch fixes this issue. Signed-off-by: Jan Beulich <JBeulich@suse.com> Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20111107123530.12164.31227.stgit@srivatsabhat.in.ibm.com Link: http://lkml.kernel.org/r/4ED8E2270200007800065120@nat28.tlf.novell.com Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-12-05Add TAINT_FIRMWARE_WORKAROUND on MTRR fixupPrarit Bhargava
TAINT_FIRMWARE_WORKAROUND should be set when an MTRR fixup is done. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Link: http://lkml.kernel.org/r/1318958650-12447-1-git-send-email-prarit@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05x86/mpparse: Account for bus types other than ISA and PCIBjorn Helgaas
In commit f8924e770e04 ("x86: unify mp_bus_info"), the 32-bit and 64-bit versions of MP_bus_info were rearranged to match each other better. Unfortunately it introduced a regression: prior to that change we used to always set the mp_bus_not_pci bit, then clear it if we found a PCI bus. After it, we set mp_bus_not_pci for ISA buses, clear it for PCI buses, and leave it alone otherwise. In the cases of ISA and PCI, there's not much difference. But ISA is not the only non-PCI bus, so it's better to always set mp_bus_not_pci and clear it only for PCI. Without this change, Dan's Dell PowerEdge 4200 panics on boot with a log indicating interrupt routing trouble unless the "noapic" option is supplied. With this change, the machine boots reliably without "noapic". Fixes http://bugs.debian.org/586494 Reported-bisected-and-tested-by: Dan McGrath <troubledaemon@gmail.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Cc: stable@vger.kernel.org # 2.6.26+ Cc: Dan McGrath <troubledaemon@gmail.com> Cc: Alexey Starikovskiy <aystarik@gmail.com> [jrnieder@gmail.com: clarified commit message] Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Link: http://lkml.kernel.org/r/20111122215000.GA9151@elie.hsd1.il.comcast.net Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05x86/reboot: Blacklist Dell OptiPlex 990 known to require PCI rebootRafael J. Wysocki
Dell OptiPlex 990 is known to require PCI reboot, so add it to the reboot blacklist in pci_reboot_dmi_table[]. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Link: http://lkml.kernel.org/r/201111160019.51303.rjw@sisk.pl Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05x86, UV: Fix UV2 hub part numberJack Steiner
There was a mixup when the SGI UV2 hub chip was sent to be fabricated, and it ended up with the wrong part number in the HRP_NODE_ID mmr. Future versions of the chip will (may) have the correct part number. Change the UV infrastructure to recognize both part numbers as valid IDs of a UV2 hub chip. Signed-off-by: Jack Steiner <steiner@sgi.com> Link: http://lkml.kernel.org/r/20111129210058.GA20452@sgi.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05x86: Add user_mode_vm check in stack_overflow_checkMitsuo Hayasaka
The kernel stack overflow is checked in stack_overflow_check(), which may wrongly detect the overflow if the stack pointer in user space points to the kernel stack intentionally or accidentally. So, the actual overflow is never detected after this misdetection because WARN_ONCE() is used on the detection of it. This patch adds user-mode-vm checking before it to avoid this problem and bails out early if the user stack is used. Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com> Cc: yrl.pp-manager.tt@hitachi.com Cc: Randy Dunlap <rdunlap@xenotime.net> Link: http://lkml.kernel.org/r/20111129060821.11076.55315.stgit@ltc219.sdl.hitachi.co.jp Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com>
2011-12-05perf, x86: Force IBS LVT offset assignment for family 10hRobert Richter
On AMD family 10h we see firmware bug messages like the following: [Firmware Bug]: cpu 6, try to use APIC500 (LVT offset 0) for vector 0x10400, but the register is already in use for vector 0xf9 on another cpu [Firmware Bug]: cpu 6, IBS interrupt offset 0 not available (MSRC001103A=0x0000000000000100) [Firmware Bug]: using offset 1 for IBS interrupts [Firmware Bug]: workaround enabled for IBS LVT offset perf: AMD IBS detected (0x00000007) We always see this, since the offsets are not assigned by the BIOS for this family. Force LVT offset assignment in this case. If the OS assignment fails, fallback to BIOS settings and try to setup this. The fallback to BIOS settings weakens the family check since force_ibs_eilvt_setup() may fail e.g. in case of virtual machines. But setup may still succeed if BIOS offsets are correct. Other families don't have a workaround implemented that assigns LVT offsets. It's ok, to drop calling force_ibs_eilvt_setup() for that families. With the patch the [Firmware Bug] messages vanish. We see now: IBS: LVT offset 1 assigned perf: AMD IBS detected (0x00000007) Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20111109162225.GO12451@erda.amd.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05perf, x86: Disable PEBS on SandyBridge chipsPeter Zijlstra
Cc: Stephane Eranian <eranian@google.com> Cc: stable@kernel.org Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-04x86: Fix boot failures on older AMD CPU'sLinus Torvalds
People with old AMD chips are getting hung boots, because commit bcb80e53877c ("x86, microcode, AMD: Add microcode revision to /proc/cpuinfo") moved the microcode detection too early into "early_init_amd()". At that point we are *so* early in the booth that the exception tables haven't even been set up yet, so the whole rdmsr_safe(MSR_AMD64_PATCH_LEVEL, &c->microcode, &dummy); doesn't actually work: if the rdmsr does a GP fault (due to non-existant MSR register on older CPU's), we can't fix it up yet, and the boot fails. Fix it by simply moving the code to a slightly later point in the boot (init_amd() instead of early_init_amd()), since the kernel itself doesn't even really care about the microcode patchlevel at this point (or really ever: it's made available to user space in /proc/cpuinfo, and updated if you do a microcode load). Reported-tested-and-bisected-by: Larry Finger <Larry.Finger@lwfinger.net> Tested-by: Bob Tracy <rct@gherkin.frus.com> Acked-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-03xen/pm_idle: Make pm_idle be default_idle under Xen.Konrad Rzeszutek Wilk
The idea behind commit d91ee5863b71 ("cpuidle: replace xen access to x86 pm_idle and default_idle") was to have one call - disable_cpuidle() which would make pm_idle not be molested by other code. It disallows cpuidle_idle_call to be set to pm_idle (which is excellent). But in the select_idle_routine() and idle_setup(), the pm_idle can still be set to either: amd_e400_idle, mwait_idle or default_idle. This depends on some CPU flags (MWAIT) and in AMD case on the type of CPU. In case of mwait_idle we can hit some instances where the hypervisor (Amazon EC2 specifically) sets the MWAIT and we get: Brought up 2 CPUs invalid opcode: 0000 [#1] SMP Pid: 0, comm: swapper Not tainted 3.1.0-0.rc6.git0.3.fc16.x86_64 #1 RIP: e030:[<ffffffff81015d1d>] [<ffffffff81015d1d>] mwait_idle+0x6f/0xb4 ... Call Trace: [<ffffffff8100e2ed>] cpu_idle+0xae/0xe8 [<ffffffff8149ee78>] cpu_bringup_and_idle+0xe/0x10 RIP [<ffffffff81015d1d>] mwait_idle+0x6f/0xb4 RSP <ffff8801d28ddf10> In the case of amd_e400_idle we don't get so spectacular crashes, but we do end up making an MSR which is trapped in the hypervisor, and then follow it up with a yield hypercall. Meaning we end up going to hypervisor twice instead of just once. The previous behavior before v3.0 was that pm_idle was set to default_idle regardless of select_idle_routine/idle_setup. We want to do that, but only for one specific case: Xen. This patch does that. Fixes RH BZ #739499 and Ubuntu #881076 Reported-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-20Merge branch 'kvm-updates/3.2' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/3.2' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM guest: prevent tracing recursion with kvmclock Revert "KVM: PPC: Add support for explicit HIOR setting" KVM: VMX: Check for automatic switch msr table overflow KVM: VMX: Add support for guest/host-only profiling KVM: VMX: add support for switching of PERF_GLOBAL_CTRL KVM: s390: announce SYNC_MMU KVM: s390: Fix tprot locking KVM: s390: handle SIGP sense running intercepts KVM: s390: Fix RUNNING flag misinterpretation
2011-11-20KVM guest: prevent tracing recursion with kvmclockAvi Kivity
Prevent tracing of preempt_disable() in get_cpu_var() in kvm_clock_read(). When CONFIG_DEBUG_PREEMPT is enabled, preempt_disable/enable() are traced and this causes the function_graph tracer to go into an infinite recursion. By open coding the preempt_disable() around the get_cpu_var(), we can use the notrace version which prevents preempt_disable/enable() from being traced and prevents the recursion. Based on a similar patch for Xen from Jeremy Fitzhardinge. Tested-by: Gleb Natapov <gleb@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-11-14x86: Call stop_machine_text_poke() on all CPUsRabin Vincent
It appears that stop_machine_text_poke() wants to be called on all CPUs, like it's done from text_poke_smp(). Fix text_poke_smp_batch() to do this. Signed-off-by: Rabin Vincent <rabin@rab.in> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Jason Baron <jbaron@redhat.com> Link: http://lkml.kernel.org/r/1319702072-32676-1-git-send-email-rabin@rab.in Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-14perf/x86: Enable raw event access to Intel offcore eventsPeter Zijlstra
Now that the core offcore support is fixed up (thanks Stephane) and we have sane generic events utilizing them, re-enable the raw access to the feature as well. Note that it doesn't matter if you use event 0x1b7 or 0x1bb to specify an offcore event, either one works and neither guarantees you'll end up on a particular offcore MSR. Based on original patch from: Vince Weaver <vweaver1@eecs.utk.edu>. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Vince Weaver <vweaver1@eecs.utk.edu>. Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.00.1108031200390.703@cl320.eecs.utk.edu Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-14perf: Don't use -ENOSPC for out of PMU resourcesPeter Zijlstra
People (Linus) objected to using -ENOSPC to signal not having enough resources on the PMU to satisfy the request. Use -EINVAL. Requested-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Stephane Eranian <eranian@google.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: David Daney <david.daney@cavium.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-xv8geaz2zpbjhlx0svmpp28n@git.kernel.org [ merged to newer kernel, fixed up MIPS impact ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-14perf/x86: Fix PEBS instruction unwindPeter Zijlstra
Masami spotted that we always try to decode the instruction stream as 64bit instructions when running a 64bit kernel, this doesn't work for ia32-compat proglets. Use TIF_IA32 to detect if we need to use the 32bit instruction decoder. Reported-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: stable@kernel.org Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-10x86, ioapic: Only print ioapic debug information for IRQs belonging to an ↵Mathias Nyman
ioapic chip with "apic=verbose" the print_IO_APIC() function tries to print IRQ to pin mappings for every active irq. It assumes chip_data is of type irq_cfg and may cause an oops if not. As the print_IO_APIC() is called from a late_initcall other chained irq chips may already be registered with custom chip_data information, causing an oops. This is the case with intel MID SoC devices with gpio demuxers registered as irq_chips. Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> [ -v2: fixed build failure ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-10x86/mrst: Avoid reporting wrong nmi statusJacob Pan
Moorestown/Medfield platform does not have port 0x61 to report NMI status, nor does it have external NMI sources. The only NMI sources are from lapic, as results of perf counter overflow or IPI, e.g. NMI watchdog or spin lock debug. Reading port 0x61 on Moorestown will return 0xff which misled NMI handlers to false critical errors such memory parity error. The subsequent ioport access for NMI handling can also cause undefined behavior on Moorestown. This patch allows kernel process NMI due to watchdog or backrace dump without unnecessary hangs. Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> [hand applied] Signed-off-by: Alan Cox <alan@linux.intel.com>
2011-11-10x86/apic: Allow use of lapic timer early calibration resultJacob Pan
lapic timer calibration can be combined with tsc in platform specific calibration functions. if such calibration result is obtained early, we can skip the redundant calibration loops. Signed-off-by: Jacob Pan <jacob.jun.pan@intel.com> Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-10x86/apic: Do not clear nr_irqs_gsi if no legacy irqsJacob Pan
nr_legacy_irqs is set in probe_nr_irqs_gsi, we should not clear it after that. Otherwise, the result is that MSI irqs will be allocated from the wrong range for the systems without legacy PIC. Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
