Migrate the PIT timer to the physical CPU which vcpu0 is scheduled on,
similarly to what is done for the LAPIC timers, otherwise PIT interrupts
will be delayed until an unrelated event causes an exit.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
Otherwise hlt emulation fails if PIT is not injecting IRQ's.
The in-kernel PIT emulation ignores pending timers if operating under
mode 4, which for example DragonFlyBSD uses (and Plan9 too, apparently).
Mode 4 seems to be similar to one-shot mode, other than the fact that it
starts counting after the next CLK pulse once programmed, while mode 1
starts counting immediately, so add a FIXME to enhance precision.
Fixes sourceforge bug 1952988.
Acked-by: Sheng Yang <sheng.yang@intel.com>
Rename div64_64 to div64_u64 to make it consistent with the other divide
functions, so it clearly includes the type of the divide. Move its definition
to math64.h as currently no architecture overrides the generic implementation.
They can still override it of course, but the duplicated declarations are
avoided.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Cc: Avi Kivity <avi@qumranet.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Patrick McHardy <kaber@trash.net>
We wish to export it to userspace, so move it into the kvm namespace.
Timers that fire between guest hlt and vcpu_block's add_wait_queue() are
ignored, possibly resulting in hangs.
Also make sure that atomic_inc and waitqueue_active tests happen in the
specified order, otherwise the following race is open:
CPU0 CPU1
if (waitqueue_active(wq))
add_wait_queue()
if (!atomic_read(pit_timer->pending))
schedule()
atomic_inc(pit_timer->pending)
Separate the reset part and prepare for reset support.
Signed-off-by: Sheng Yang <sheng.yang@intel.com>
The patch moves the PIT model from userspace to kernel, and increases
the timer accuracy greatly.
[marcelo: make last_injected_time per-guest]
Tested-and-Acked-by: Alex Davis <alex14641@yahoo.com>
