There's a race condition in the PIT emulation code in KVM. In
__kvm_migrate_pit_timer the pit_timer object is accessed without
synchronization. If the race condition occurs at the wrong time this
can crash the host kernel.
This fixes CVE-2014-3611.
Cc: stable@vger.kernel.org
Signed-off-by: Andrew Honig <ahonig@google.com>
Limit PIT timer frequency similarly to the limit applied by
LAPIC timer.
Cc: stable@kernel.org
Reviewed-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Userspace may deliver RTC interrupt without query the status. So we
want to track RTC EOI for this case.
Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com>
Reviewed-by: Gleb Natapov <gleb@redhat.com>
The kvm i8254 emulation for counter 0 (but not for counters 1 and 2)
has at least two bugs in mode 0:
1. The OUT bit, computed by pit_get_out(), is never set high.
2. The counter value, computed by pit_get_count(), wraps back around to
the initial counter value, rather than wrapping back to 0xFFFF
(which is the behavior described in the comment in __kpit_elapsed,
the behavior implemented by qemu, and the behavior observed on AMD
hardware).
The bug stems from __kpit_elapsed computing the elapsed time mod the
initial counter value (stored as nanoseconds in ps->period). This is both
unnecessary (none of the callers of kpit_elapsed expect the value to be
at most the initial counter value) and incorrect (it causes pit_get_count
to appear to wrap around to the initial counter value rather than 0xFFFF).
Removing this mod from __kpit_elapsed fixes both of the above bugs.
Signed-off-by: Nickolai Zeldovich <nickolai@csail.mit.edu>
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
One structure nests inside the other, providing no value at all.
Signed-off-by: Avi Kivity <avi@redhat.com>
'timer_mode_mask' is unused
'tscdeadline' is unused
't_ops' only adds needless indirection
'vcpu' is unused
Remove.
kvm_timer_fn(), the sole inhabitant of timer.c, is only used by lapic.c. Move
it there to make it easier to hack on it.
struct kvm_timer is a thin wrapper around hrtimer, and only adds obfuscation.
Move near its two users (with different names) to prepare for simplification.
We can't run PIT IRQ injection work in the interrupt context of the host
timer. This would allow the user to influence the handler complexity by
asking for a broadcast to a large number of VCPUs. Therefore, this work
was pushed into workqueue context in 9d244caf2e. However, this prevents
prioritizing the PIT injection over other task as workqueues share
kernel threads.
This replaces the workqueue with a kthread worker and gives that thread
a name in the format "kvm-pit/<owner-process-pid>". That allows to
identify and adjust the kthread priority according to the VM process
parameters.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Move the test for KVM_PIT_FLAGS_HPET_LEGACY into create_pit_timer
instead of replicating it on the caller site.
User space may create the PIT and forgets about setting up the irqchips.
In that case, firing PIT IRQs will crash the host:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000128
IP: [<ffffffffa10f6280>] kvm_set_irq+0x30/0x170 [kvm]
Call Trace:
[<ffffffffa11228c1>] pit_do_work+0x51/0xd0 [kvm]
[<ffffffff81071431>] process_one_work+0x111/0x4d0
[<ffffffff81071bb2>] worker_thread+0x152/0x340
[<ffffffff81075c8e>] kthread+0x7e/0x90
[<ffffffff815a4474>] kernel_thread_helper+0x4/0x10
Prevent this by checking the irqchip mode before starting a timer. We
can't deny creating the PIT if the irqchips aren't set up yet as
current user land expects this order to work.
Currently the method of dealing with an IO operation on a bus (PIO/MMIO)
is to call the read or write callback for each device registered
on the bus until we find a device which handles it.
Since the number of devices on a bus can be significant due to ioeventfds
and coalesced MMIO zones, this leads to a lot of overhead on each IO
operation.
Instead of registering devices, we now register ranges which points to
a device. Lookup is done using an efficient bsearch instead of a linear
search.
Performance test was conducted by comparing exit count per second with
200 ioeventfds created on one byte and the guest is trying to access a
different byte continuously (triggering usermode exits).
Before the patch the guest has achieved 259k exits per second, after the
patch the guest does 274k exits per second.
Cc: Avi Kivity <avi@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Fix typo in copyright notice.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Pit interrupt injection was done by workqueue, so no need to check
pending pit timer in vcpu thread which could lead unnecessary
unblocking of vcpu.
Signed-off-by: Jason Wang <jasowang@redhat.com>
Free irq source id if create pit workqueue fail
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
kernel needs to destroy workqueue if kvm_create_pit() fails, otherwise
after pit is freed, the workqueue is leaked.
Signed-off-by: Xiaotian Feng <dfeng@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Gregory Haskins <ghaskins@novell.com>
Fix:
general protection fault: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Call Trace:
[<ffffffffa0159bd1>] ? kvm_set_irq+0xdd/0x24b [kvm]
[<ffffffff8106ea8b>] ? trace_hardirqs_off_caller+0x1f/0x10e
[<ffffffff813ad17f>] ? sub_preempt_count+0xe/0xb6
[<ffffffff8106d273>] ? put_lock_stats+0xe/0x27
RIP [<ffffffffa0159c72>] kvm_set_irq+0x17e/0x24b [kvm]
This bug is triggered when guest is shutdown, is because we freed
irq_routing before pit thread stopped
Stanse found that there is an omitted unlock in kvm_create_pit in one fail
path. Add proper unlock there.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: x86@kernel.org
Cc: kvm@vger.kernel.org
We really want to "kvm_set_irq" during the hrtimer callback,
but that is risky because that is during interrupt context.
Instead, offload the work to a workqueue, which is a bit safer
and should provide most of the same functionality.
Signed-off-by: Chris Lalancette <clalance@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The i8254/i8259 locks need to be real spinlocks on preempt-rt. Convert
them to raw_spinlock. No change for !RT kernels.
If fail to create pit, we should unregister kvm irq notifier
which register in kvm_create_pit().
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Acked-by: Marcelo Tosatti <mtosatti@redhat.com>
PIT control word (address 0x43) is write-only, reads are undefined.
- Add pr_fmt(fmt) "pit: " fmt
- Strip pit: prefixes from pr_debug
LKML-Reference: <bbd4de532f18bb7c11f64ba20d224c08291cb126.1260383912.git.joe@perches.com>
The only thing it protects now is interrupt injection into lapic and
this can work lockless. Even now with kvm->irq_lock in place access
to lapic is not entirely serialized since vcpu access doesn't take
kvm->irq_lock.
hrtimer->base can be temporarily NULL due to racing hrtimer_start.
See switch_hrtimer_base/lock_hrtimer_base.
Use hrtimer_get_remaining which is robust against it.
CC: stable@kernel.org
This takes care of the following entries from Dan's list:
arch/x86/kvm/i8254.c +714 kvm_inject_pit_timer_irqs(6) warning: variable derefenced in initializer 'vcpu'
arch/x86/kvm/i8254.c +714 kvm_inject_pit_timer_irqs(6) warning: variable derefenced before check 'vcpu'
Reported-by: Dan Carpenter <error27@gmail.com>
Cc: corbet@lwn.net
Cc: eteo@redhat.com
Cc: Julia Lawall <julia@diku.dk>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Acked-by: Sheng Yang <sheng@linux.intel.com>
Today kvm_io_bus_regsiter_dev() returns void and will internally BUG_ON
if it fails. We want to create dynamic MMIO/PIO entries driven from
userspace later in the series, so we need to enhance the code to be more
robust with the following changes:
1) Add a return value to the registration function
2) Fix up all the callsites to check the return code, handle any
failures, and percolate the error up to the caller.
3) Add an unregister function that collapses holes in the array
Signed-off-by: Gregory Haskins <ghaskins@novell.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
When kvm is in hpet_legacy_mode, the hpet is providing the timer
interrupt and the pit should not be. So in legacy mode, the pit timer
is destroyed, but the *state* of the pit is maintained. So if kvm or
the guest tries to modify the state of the pit, this modification is
accepted, *except* that the timer isn't actually started. When we exit
hpet_legacy_mode, the current state of the pit (which is up to date
since we've been accepting modifications) is used to restart the pit
timer.
The saved_mode code in kvm_pit_load_count temporarily changes mode to
0xff in order to destroy the timer, but then restores the actual
value, again maintaining "current" state of the pit for possible later
reenablement.
[avi: add some reserved storage in the ioctl; make SET_PIT2 IOW]
[marcelo: fix memory corruption due to reserved storage]
Signed-off-by: Beth Kon <eak@us.ibm.com>
This changes bus accesses to use high-level kvm_io_bus_read/kvm_io_bus_write
functions. in_range now becomes unused so it is removed from device ops in
favor of read/write callbacks performing range checks internally.
This allows aliasing (mostly for in-kernel virtio), as well as better error
handling by making it possible to pass errors up to userspace.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Use slots_lock to protect device list on the bus. slots_lock is already
taken for read everywhere, so we only need to take it for write when
registering devices. This is in preparation to removing in_range and
kvm->lock around it.
Correct missing locking in a few places in x86's vm_ioctl handling path.
[christian: remove unused variables on s390]
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Use it instead of open code "vcpu_id zero is BSP" assumption.
Protect irq injection/acking data structures with a separate irq_lock
mutex. This fixes the following deadlock:
CPU A CPU B
kvm_vm_ioctl_deassign_dev_irq()
mutex_lock(&kvm->lock); worker_thread()
-> kvm_deassign_irq() -> kvm_assigned_dev_interrupt_work_handler()
-> deassign_host_irq() mutex_lock(&kvm->lock);
-> cancel_work_sync() [blocked]
[gleb: fix ia64 path]
Reported-by: Alex Williamson <alex.williamson@hp.com>
We currently publish the i8254 resources to the pio_bus before the devices
are fully initialized. Since we hold the pit_lock, its probably not
a real issue. But lets clean this up anyway.
Reported-by: Avi Kivity <avi@redhat.com>
Acked-by: Chris Wright <chrisw@sous-sol.org>
We modernize the io_device code so that we use container_of() instead of
dev->private, and move the vtable to a separate ops structure
(theoretically allows better caching for multiple instances of the same
ops structure)
The in-kernel speaker emulation is only a dummy and also unneeded from
the performance point of view. Rather, it takes user space support to
generate sound output on the host, e.g. console beeps.
To allow this, introduce KVM_CREATE_PIT2 which controls in-kernel
speaker port emulation via a flag passed along the new IOCTL. It also
leaves room for future extensions of the PIT configuration interface.
Fix division by zero triggered by latch count command on uninitialized
counter.
Commit 46ee278652f4cbd51013471b64c7897ba9bcd1b1 causes Solaris 10
to hang on boot.
Assuming that PIT counter reads should return 0 for an expired timer
is wrong: when it is active, the counter never stops (see comment on
__kpit_elapsed).
Also arm a one shot timer for mode 0.
Fix this sparse warnings:
arch/x86/kvm/lapic.c:916:22: warning: symbol 'lapic_timer_ops' was not declared. Should it be static?
arch/x86/kvm/i8254.c:268:22: warning: symbol 'kpit_ops' was not declared. Should it be static?
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
Hide the internals of vcpu awakening / injection from the in-kernel
emulated timers. This makes future changes in this logic easier and
decreases the distance to more generic timer handling.
We can infer elapsed time from hrtimer_expires_remaining.
Unused.
While the PIT is masked the guest cannot ack the irq, so the reinject logic
will never allow the interrupt to be injected.
Fix by resetting the reinjection counters on unmask.
Unbreaks Xen.
Otherwise, two threads can create a PIT in parallel and cause a memory leak.
