[ Upstream commit 8678654e3c7ad7b0f4beb03fa89691279cba71f9 ]
gcc 7 warns:
arch/x86/kvm/ioapic.c: In function 'kvm_ioapic_reset':
arch/x86/kvm/ioapic.c:597:2: warning: 'memset' used with length equal to number of elements without multiplication by element size [-Wmemset-elt-size]
And it is right. Memset whole array using sizeof operator.
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: x86@kernel.org
Cc: kvm@vger.kernel.org
Cc: stable@vger.kernel.org
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
[Added x86 subject tag]
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Pull KVM updates from Paolo Bonzini:
"First batch of KVM changes for 4.1
The most interesting bit here is irqfd/ioeventfd support for ARM and
ARM64.
Summary:
ARM/ARM64:
fixes for live migration, irqfd and ioeventfd support (enabling
vhost, too), page aging
s390:
interrupt handling rework, allowing to inject all local interrupts
via new ioctl and to get/set the full local irq state for migration
and introspection. New ioctls to access memory by virtual address,
and to get/set the guest storage keys. SIMD support.
MIPS:
FPU and MIPS SIMD Architecture (MSA) support. Includes some
patches from Ralf Baechle's MIPS tree.
x86:
bugfixes (notably for pvclock, the others are small) and cleanups.
Another small latency improvement for the TSC deadline timer"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (146 commits)
KVM: use slowpath for cross page cached accesses
kvm: mmu: lazy collapse small sptes into large sptes
KVM: x86: Clear CR2 on VCPU reset
KVM: x86: DR0-DR3 are not clear on reset
KVM: x86: BSP in MSR_IA32_APICBASE is writable
KVM: x86: simplify kvm_apic_map
KVM: x86: avoid logical_map when it is invalid
KVM: x86: fix mixed APIC mode broadcast
KVM: x86: use MDA for interrupt matching
kvm/ppc/mpic: drop unused IRQ_testbit
KVM: nVMX: remove unnecessary double caching of MAXPHYADDR
KVM: nVMX: checks for address bits beyond MAXPHYADDR on VM-entry
KVM: x86: cache maxphyaddr CPUID leaf in struct kvm_vcpu
KVM: vmx: pass error code with internal error #2
x86: vdso: fix pvclock races with task migration
KVM: remove kvm_read_hva and kvm_read_hva_atomic
KVM: x86: optimize delivery of TSC deadline timer interrupt
KVM: x86: extract blocking logic from __vcpu_run
kvm: x86: fix x86 eflags fixed bit
KVM: s390: migrate vcpu interrupt state
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into 'kvm-next'
KVM/ARM changes for v4.1:
- fixes for live migration
- irqfd support
- kvm-io-bus & vgic rework to enable ioeventfd
- page ageing for stage-2 translation
- various cleanups
This is needed in e.g. ARM vGIC emulation, where the MMIO handling
depends on the VCPU that does the access.
Signed-off-by: Nikolay Nikolaev <n.nikolaev@virtualopensystems.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Acked-by: Christoffer Dall <christoffer.dall@linaro.org>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
An overhead from function call is not appropriate for its size and
frequency of execution.
Suggested-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
kvm_ioapic_update_eoi() wasn't called if directed EOI was enabled.
We need to do that for irq notifiers. (Like with edge interrupts.)
Fix it by skipping EOI broadcast only.
Bug: https://bugzilla.kernel.org/show_bug.cgi?id=82211
Tested-by: Bandan Das <bsd@redhat.com>
This patch fixes the bug discussed in
https://www.mail-archive.com/kvm@vger.kernel.org/msg109813.html
This patch uses a new field named irr_delivered to record the
delivery status of edge-triggered interrupts, and clears the
delivered interrupts in kvm_get_ioapic. So it has the same effect
of commit 0bc830b05c667218d703f2026ec866c49df974fc
("KVM: ioapic: clear IRR for edge-triggered interrupts at delivery")
while avoids the bug of Windows guests.
Signed-off-by: Wincy Van <fanwenyi0529@gmail.com>
Signed-off-by: Radim Krcmar <rkrcmar@redhat.com>
ia64 does not need them anymore. Ack notifiers become x86-specific
too.
Suggested-by: Gleb Natapov <gleb@kernel.org>
Reviewed-by: Radim Krcmar <rkrcmar@redhat.com>
