path: root/arch/x86/kvm/irq.h
2008-04-27KVM: hlt emulation should take in-kernel APIC/PIT timers into accountMarcelo Tosatti
Timers that fire between guest hlt and vcpu_block's add_wait_queue() are ignored, possibly resulting in hangs. Also make sure that atomic_inc and waitqueue_active tests happen in the specified order, otherwise the following race is open: CPU0 CPU1 if (waitqueue_active(wq)) add_wait_queue() if (!atomic_read(pit_timer->pending)) schedule() atomic_inc(pit_timer->pending) Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Move apic timer migration away from critical sectionAvi Kivity
Migrating the apic timer in the critical section is not very nice, and is absolutely horrible with the real-time port. Move migration to the regular vcpu execution path, triggered by a new bitflag. Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Move kvm_vcpu_kick() to x86.cZhang Xiantao
Moving kvm_vcpu_kick() to x86.c. Since it should be common for all archs, put its declarations in <linux/kvm_host.h> Signed-off-by: Zhang Xiantao <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Move irqchip declarations into new ioapic.h and lapic.hZhang Xiantao
This allows reuse of ioapic in ia64. Signed-off-by: Zhang Xiantao <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Move arch dependent files to new directory arch/x86/kvm/Avi Kivity
This paves the way for multiple architecture support. Note that while ioapic.c could potentially be shared with ia64, it is also moved. Signed-off-by: Avi Kivity <avi@qumranet.com>
