path: root/arch/x86/kvm/lapic.c
2008-05-18KVM: LAPIC: ignore pending timers if LVTT is disabledMarcelo Tosatti
Only use the APIC pending timers count to break out of HLT emulation if the timer vector is enabled. Certain configurations of Windows simply mask out the vector without disabling the timer. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-01rename div64_64 to div64_u64Roman Zippel
Rename div64_64 to div64_u64 to make it consistent with the other divide functions, so it clearly includes the type of the divide. Move its definition to math64.h as currently no architecture overrides the generic implementation. They can still override it of course, but the duplicated declarations are avoided. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Avi Kivity <avi@qumranet.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-27KVM: export kvm_lapic_set_tpr() to modulesJoerg Roedel
This patch exports the kvm_lapic_set_tpr() function from the lapic code to modules. It is required in the kvm-amd module to optimize CR8 intercepts. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: Rename VCPU_MP_STATE_* to KVM_MP_STATE_*Avi Kivity
We wish to export it to userspace, so move it into the kvm namespace. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: hlt emulation should take in-kernel APIC/PIT timers into accountMarcelo Tosatti
Timers that fire between guest hlt and vcpu_block's add_wait_queue() are ignored, possibly resulting in hangs. Also make sure that atomic_inc and waitqueue_active tests happen in the specified order, otherwise the following race is open: CPU0 CPU1 if (waitqueue_active(wq)) add_wait_queue() if (!atomic_read(pit_timer->pending)) schedule() atomic_inc(pit_timer->pending) Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: replace remaining __FUNCTION__ occurancesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-03-04KVM: Avoid infinite-frequency local apic timerAvi Kivity
If the local apic initial count is zero, don't start a an hrtimer with infinite frequency, locking up the host. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Move apic timer migration away from critical sectionAvi Kivity
Migrating the apic timer in the critical section is not very nice, and is absolutely horrible with the real-time port. Move migration to the regular vcpu execution path, triggered by a new bitflag. Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Accelerated apic supportAvi Kivity
This adds a mechanism for exposing the virtual apic tpr to the guest, and a protocol for letting the guest update the tpr without causing a vmexit if conditions allow (e.g. there is no interrupt pending with a higher priority than the new tpr). Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: local APIC TPR access reporting facilityAvi Kivity
Add a facility to report on accesses to the local apic tpr even if the local apic is emulated in the kernel. This is basically a hack that allows userspace to patch Windows which tends to bang on the tpr a lot. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Move arch dependent files to new directory arch/x86/kvm/Avi Kivity
This paves the way for multiple architecture support. Note that while ioapic.c could potentially be shared with ia64, it is also moved. Signed-off-by: Avi Kivity <avi@qumranet.com>
