commit b963a22e6d1a266a67e9eecc88134713fd54775c upstream.
Under guest controllable circumstances apic_get_tmcct will execute a
divide by zero and cause a crash. If the guest cpuid support
tsc deadline timers and performs the following sequence of requests
the host will crash.
- Set the mode to periodic
- Set the TMICT to 0
- Set the mode bits to 11 (neither periodic, nor one shot, nor tsc deadline)
- Set the TMICT to non-zero.
Then the lapic_timer.period will be 0, but the TMICT will not be. If the
guest then reads from the TMCCT then the host will perform a divide by 0.
This patch ensures that if the lapic_timer.period is 0, then the division
does not occur.
Reported-by: Andrew Honig <ahonig@google.com>
Signed-off-by: Andrew Honig <ahonig@google.com>
[bwh: Backported to 3.2: s/kvm_apic_get_reg/apic_get_reg/]
Cc: Vinson Lee <vlee@twopensource.com>
commit fda4e2e85589191b123d31cdc21fd33ee70f50fd upstream.
In kvm_lapic_sync_from_vapic and kvm_lapic_sync_to_vapic there is the
potential to corrupt kernel memory if userspace provides an address that
is at the end of a page. This patches concerts those functions to use
kvm_write_guest_cached and kvm_read_guest_cached. It also checks the
vapic_address specified by userspace during ioctl processing and returns
an error to userspace if the address is not a valid GPA.
This is generally not guest triggerable, because the required write is
done by firmware that runs before the guest. Also, it only affects AMD
processors and oldish Intel that do not have the FlexPriority feature
(unless you disable FlexPriority, of course; then newer processors are
also affected).
Fixes: b93463aa59d6 ('KVM: Accelerated apic support')
Cc: stable@vger.kernel.org
[ lizf: backported to 3.4: based on Paolo's backport hints for <3.10 ]
Signed-off-by: Li Zefan <lizefan@huawei.com>
Pull kvm updates from Avi Kivity:
"Changes include timekeeping improvements, support for assigning host
PCI devices that share interrupt lines, s390 user-controlled guests, a
large ppc update, and random fixes."
This is with the sign-off's fixed, hopefully next merge window we won't
have rebased commits.
* 'kvm-updates/3.4' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (130 commits)
KVM: Convert intx_mask_lock to spin lock
KVM: x86: fix kvm_write_tsc() TSC matching thinko
x86: kvmclock: abstract save/restore sched_clock_state
KVM: nVMX: Fix erroneous exception bitmap check
KVM: Ignore the writes to MSR_K7_HWCR(3)
KVM: MMU: make use of ->root_level in reset_rsvds_bits_mask
KVM: PMU: add proper support for fixed counter 2
KVM: PMU: Fix raw event check
KVM: PMU: warn when pin control is set in eventsel msr
KVM: VMX: Fix delayed load of shared MSRs
KVM: use correct tlbs dirty type in cmpxchg
KVM: Allow host IRQ sharing for assigned PCI 2.3 devices
KVM: Ensure all vcpus are consistent with in-kernel irqchip settings
KVM: x86 emulator: Allow PM/VM86 switch during task switch
KVM: SVM: Fix CPL updates
KVM: x86 emulator: VM86 segments must have DPL 3
KVM: x86 emulator: Fix task switch privilege checks
arch/powerpc/kvm/book3s_hv.c: included linux/sched.h twice
KVM: x86 emulator: correctly mask pmc index bits in RDPMC instruction emulation
KVM: mmu_notifier: Flush TLBs before releasing mmu_lock
Acked-by: Avi Kivity <avi@redhat.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Cong Wang <amwang@redhat.com>
This requires some restructuring; rather than use 'virtual_tsc_khz'
to indicate whether hardware rate scaling is in effect, we consider
each VCPU to always have a virtual TSC rate. Instead, there is new
logic above the vendor-specific hardware scaling that decides whether
it is even necessary to use and updates all rate variables used by
common code. This means we can simply query the virtual rate at
any point, which is needed for software rate scaling.
There is also now a threshold added to the TSC rate scaling; minor
differences and variations of measured TSC rate can accidentally
provoke rate scaling to be used when it is not needed. Instead,
we have a tolerance variable called tsc_tolerance_ppm, which is
the maximum variation from user requested rate at which scaling
will be used. The default is 250ppm, which is the half the
threshold for NTP adjustment, allowing for some hardware variation.
In the event that hardware rate scaling is not available, we can
kludge a bit by forcing TSC catchup to turn on when a faster than
hardware speed has been requested, but there is nothing available
yet for the reverse case; this requires a trap and emulate software
implementation for RDTSC, which is still forthcoming.
[avi: fix 64-bit division on i386]
Signed-off-by: Zachary Amsden <zamsden@gmail.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
If the guest programs an IPI with level=0 (de-assert) and trig_mode=0 (edge),
it is erroneously treated as INIT de-assert and ignored, but to quote the
spec: "For this delivery mode [INIT de-assert], the level flag must be set to
0 and trigger mode flag to 1."
Signed-off-by: Julian Stecklina <js@alien8.de>
Needed to deliver performance monitoring interrupts.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
The cpuid code has grown; put it into a separate file.
This patch emulate lapic tsc deadline timer for guest:
Enumerate tsc deadline timer capability by CPUID;
Enable tsc deadline timer mode by lapic MMIO;
Start tsc deadline timer by WRMSR;
[jan: use do_div()]
[avi: fix for !irqchip_in_kernel()]
[marcelo: another fix for !irqchip_in_kernel()]
Signed-off-by: Liu, Jinsong <jinsong.liu@intel.com>
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Certain guests, specifically RTOSes, request faster periodic timers than
what we allow by default. Add a module parameter to adjust the limit for
non-standard setups. Also add a rate-limited warning in case the guest
requested more.
Convert remaining printks that the guest can trigger to apic_printk.
Instruction emulation for EOI writes can be skipped, since sane
guest simply uses MOV instead of string operations. This is a nice
improvement when guest doesn't support x2apic or hyper-V EOI
support.
a single VM bandwidth is observed with ~8% bandwidth improvement
(7.4Gbps->8Gbps), by saving ~5% cycles from EOI emulation.
Signed-off-by: Kevin Tian <kevin.tian@intel.com>
<Based on earlier work from>:
Signed-off-by: Eddie Dong <eddie.dong@intel.com>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Access to this page is mostly done through the regs member which holds
the address to this page. The exceptions are in vmx_vcpu_reset() and
kvm_free_lapic() and these both can easily be converted to using regs.
Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp>
This warning was once used for debugging QEMU user space. Though
uncommon, it is actually possible to send an INIT request to a running
VCPU. So better drop this warning before someone misuses it to flood
kernel logs this way.
After an interrupt injection, the PPR changes, and we have to reflect that
into the vapic. This causes a KVM_REQ_EVENT to be set, which causes the
whole interrupt injection routine to be run again (harmlessly).
Optimize by only setting KVM_REQ_EVENT if the ppr was lowered; otherwise
there is no chance that a new injection is needed.
* 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (321 commits)
KVM: Drop CONFIG_DMAR dependency around kvm_iommu_map_pages
KVM: Fix signature of kvm_iommu_map_pages stub
KVM: MCE: Send SRAR SIGBUS directly
KVM: MCE: Add MCG_SER_P into KVM_MCE_CAP_SUPPORTED
KVM: fix typo in copyright notice
KVM: Disable interrupts around get_kernel_ns()
KVM: MMU: Avoid sign extension in mmu_alloc_direct_roots() pae root address
KVM: MMU: move access code parsing to FNAME(walk_addr) function
KVM: MMU: audit: check whether have unsync sps after root sync
KVM: MMU: audit: introduce audit_printk to cleanup audit code
KVM: MMU: audit: unregister audit tracepoints before module unloaded
KVM: MMU: audit: fix vcpu's spte walking
KVM: MMU: set access bit for direct mapping
KVM: MMU: cleanup for error mask set while walk guest page table
KVM: MMU: update 'root_hpa' out of loop in PAE shadow path
KVM: x86 emulator: Eliminate compilation warning in x86_decode_insn()
KVM: x86: Fix constant type in kvm_get_time_scale
KVM: VMX: Add AX to list of registers clobbered by guest switch
KVM guest: Move a printk that's using the clock before it's ready
KVM: x86: TSC catchup mode
Fix typo in copyright notice.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Instead of blindly attempting to inject an event before each guest entry,
check for a possible event first in vcpu->requests. Sites that can trigger
event injection are modified to set KVM_REQ_EVENT:
- interrupt, nmi window opening
- ppr updates
- i8259 output changes
- local apic irr changes
- rflags updates
- gif flag set
- event set on exit
This improves non-injecting entry performance, and sets the stage for
non-atomic injection.
When operating on whole pages, use clear_page() and copy_page() in
favor of memset() and memcpy(); after all that's what they are
intended for.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
LKML-Reference: <4C7FB8CA0200007800013F51@vpn.id2.novell.com>
Makes it a little more readable and hackable.
If the guest wants to accept timer interrupts on a CPU other
than the BSP, we need to remove this gate.
Signed-off-by: Chris Lalancette <clalance@redhat.com>
Fix a slight error with assertion in local APIC code.
Signed-off-by: Zachary Amsden <zamsden@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Implement HYPER-V apic MSRs. Spec defines three MSRs that speed-up
access to EOI/TPR/ICR apic registers for PV guests.
Signed-off-by: Vadim Rozenfeld <vrozenfe@redhat.com>
When we queue an interrupt to the local apic, we set the IRR before the TMR.
The vcpu can pick up the IRR and inject the interrupt before setting the TMR,
and perhaps even EOI it, causing incorrect behaviour.
The race is really insignificant since it can only occur on the first
interrupt (usually following interrupts will not change TMR), but it's better
closed than open.
Fixed by reordering setting the TMR vs IRR.
Cc: stable@kernel.org
The vcpus are initialized with irr_pending set to false, but
loading the LAPIC registers with pending IRR fails to reset
the irr_pending variable.
Remove duplicated #include('s) in
arch/x86/kvm/lapic.c
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
The only thing it protects now is interrupt injection into lapic and
this can work lockless. Even now with kvm->irq_lock in place access
to lapic is not entirely serialized since vcpu access doesn't take
kvm->irq_lock.
The allows removal of irq_lock from the injection path.
hrtimer->base can be temporarily NULL due to racing hrtimer_start.
See switch_hrtimer_base/lock_hrtimer_base.
Use hrtimer_get_remaining which is robust against it.
CC: stable@kernel.org
Don't overflow when computing the 64-bit period from 32-bit registers.
Fixes sourceforge bug #2826486.
Signed-off-by: Aurelien Jarno <aurelien@aurel32.net>
Otherwise its possible to starve the host by programming lapic timer
with a very high frequency.
Some Linux versions (f8) try to read EOI register that is write only.
Add tracepoint in msi/ioapic/pic set_irq() functions,
in IPI sending and in the point where IRQ is placed into
apic's IRR.
Some in-famous OS do unaligned writing for APIC MMIO, and the return value
has been missed in recent change, then the OS hangs.
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
This patch implements MSR interface to local apic as defines by x2apic
Intel specification.
Directed EOI is specified by x2APIC, but is available even when lapic is
in xAPIC mode.
This changes bus accesses to use high-level kvm_io_bus_read/kvm_io_bus_write
functions. in_range now becomes unused so it is removed from device ops in
favor of read/write callbacks performing range checks internally.
This allows aliasing (mostly for in-kernel virtio), as well as better error
handling by making it possible to pass errors up to userspace.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
This allows use of the powerful ftrace infrastructure.
See Documentation/trace/ for usage information.
[avi, stephen: various build fixes]
[sheng: fix control register breakage]
Most of the time IRR is empty, so instead of scanning the whole IRR on
each VM entry keep a variable that tells us if IRR is not empty. IRR
will have to be scanned twice on each IRQ delivery, but this is much
more rare than VM entry.
Use it instead of open code "vcpu_id zero is BSP" assumption.
Protect irq injection/acking data structures with a separate irq_lock
mutex. This fixes the following deadlock:
CPU A CPU B
kvm_vm_ioctl_deassign_dev_irq()
mutex_lock(&kvm->lock); worker_thread()
-> kvm_deassign_irq() -> kvm_assigned_dev_interrupt_work_handler()
-> deassign_host_irq() mutex_lock(&kvm->lock);
-> cancel_work_sync() [blocked]
[gleb: fix ia64 path]
Reported-by: Alex Williamson <alex.williamson@hp.com>
None of the interface services the LAPIC emulation provides need to be
exported to modules, and kvm_lapic_get_base is even totally unused
today.
We modernize the io_device code so that we use container_of() instead of
dev->private, and move the vtable to a separate ops structure
(theoretically allows better caching for multiple instances of the same
ops structure)
Signed-off-by: Gregory Haskins <ghaskins@novell.com>
Acked-by: Chris Wright <chrisw@sous-sol.org>
Apparently nobody turned this on in a while...
setting apic_debug to something compilable, generates
some errors. This patch fixes it.
Signed-off-by: Glauber Costa <glommer@redhat.com>
Fix this sparse warnings:
arch/x86/kvm/lapic.c:916:22: warning: symbol 'lapic_timer_ops' was not declared. Should it be static?
arch/x86/kvm/i8254.c:268:22: warning: symbol 'kpit_ops' was not declared. Should it be static?
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
