Just reuse rsvd_bits() inside kvm_set_mmio_spte_mask()
for slightly better code.
Signed-off-by: Tiejun Chen <tiejun.chen@intel.com>
Now we can flush all the TLBs out of the mmu lock without TLB corruption when
write-proect the sptes, it is because:
- we have marked large sptes readonly instead of dropping them that means we
just change the spte from writable to readonly so that we only need to care
the case of changing spte from present to present (changing the spte from
present to nonpresent will flush all the TLBs immediately), in other words,
the only case we need to care is mmu_spte_update()
- in mmu_spte_update(), we haved checked
SPTE_HOST_WRITEABLE | PTE_MMU_WRITEABLE instead of PT_WRITABLE_MASK, that
means it does not depend on PT_WRITABLE_MASK anymore
Acked-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
This patch adds SMAP handling logic when setting CR4 for guests
Thanks a lot to Paolo Bonzini for his suggestion to use the branchless
way to detect SMAP violation.
Signed-off-by: Feng Wu <feng.wu@intel.com>
kvm_mmu initialization is mostly filling in function pointers, there is
no way for it to fail. Clean up unused return values.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
KVM's existing shadow MMU code already supports nested TDP. To use it, we
need to set up a new "MMU context" for nested EPT, and create a few callbacks
for it (nested_ept_*()). This context should also use the EPT versions of
the page table access functions (defined in the previous patch).
Then, we need to switch back and forth between this nested context and the
regular MMU context when switching between L1 and L2 (when L1 runs this L2
with EPT).
Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Signed-off-by: Nadav Har'El <nyh@il.ibm.com>
Signed-off-by: Jun Nakajima <jun.nakajima@intel.com>
Signed-off-by: Xinhao Xu <xinhao.xu@intel.com>
Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com>
This patch tries to introduce a very simple and scale way to invalidate
all mmio sptes - it need not walk any shadow pages and hold mmu-lock
KVM maintains a global mmio valid generation-number which is stored in
kvm->memslots.generation and every mmio spte stores the current global
generation-number into his available bits when it is created
When KVM need zap all mmio sptes, it just simply increase the global
generation-number. When guests do mmio access, KVM intercepts a MMIO #PF
then it walks the shadow page table and get the mmio spte. If the
generation-number on the spte does not equal the global generation-number,
it will go to the normal #PF handler to update the mmio spte
Since 19 bits are used to store generation-number on mmio spte, we zap all
mmio sptes when the number is round
Reviewed-by: Gleb Natapov <gleb@redhat.com>
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
Define some meaningful names instead of raw code
The current kvm_mmu_zap_all is really slow - it is holding mmu-lock to
walk and zap all shadow pages one by one, also it need to zap all guest
page's rmap and all shadow page's parent spte list. Particularly, things
become worse if guest uses more memory or vcpus. It is not good for
scalability
In this patch, we introduce a faster way to invalidate all shadow pages.
KVM maintains a global mmu invalid generation-number which is stored in
kvm->arch.mmu_valid_gen and every shadow page stores the current global
generation-number into sp->mmu_valid_gen when it is created
When KVM need zap all shadow pages sptes, it just simply increase the
global generation-number then reload root shadow pages on all vcpus.
Vcpu will create a new shadow page table according to current kvm's
generation-number. It ensures the old pages are not used any more.
Then the obsolete pages (sp->mmu_valid_gen != kvm->arch.mmu_valid_gen)
are zapped by using lock-break technique
The current name "kvm_mmu_free_some_pages" should be used for something
that actually frees some shadow pages, as we expect from the name, but
what the function is doing is to make some, KVM_MIN_FREE_MMU_PAGES,
shadow pages available: it does nothing when there are enough.
This patch changes the name to reflect this meaning better; while doing
this renaming, the code in the wrapper function is inlined into the main
body since the whole function will be inlined into the only caller now.
Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp>
n_max_mmu_pages
As noticed by Ulrich Obergfell <uobergfe@redhat.com>, the mmu
counters are for beancounting purposes only - so n_used_mmu_pages and
n_max_mmu_pages could be relaxed (example: before f0f5933a1626c8df7b),
resulting in n_used_mmu_pages > n_max_mmu_pages.
Make code robust against n_used_mmu_pages > n_max_mmu_pages.
Instead of branchy code depending on level, gpte.ps, and mmu configuration,
prepare everything in a bitmap during mode changes and look it up during
runtime.
Signed-off-by: Avi Kivity <avi@redhat.com>
walk_addr_generic() permission checks are a maze of branchy code, which is
performed four times per lookup. It depends on the type of access, efer.nxe,
cr0.wp, cr4.smep, and in the near future, cr4.smap.
Optimize this away by precalculating all variants and storing them in a
bitmap. The bitmap is recalculated when rarely-changing variables change
(cr0, cr4) and is indexed by the often-changing variables (page fault error
code, pte access permissions).
The permission check is moved to the end of the loop, otherwise an SMEP
fault could be reported as a false positive, when PDE.U=1 but PTE.U=0.
Noted by Xiao Guangrong.
The result is short, branch-free code.
gpte_access() computes the access permissions of a guest pte and also
write-protects clean gptes. This is wrong when we are servicing a
write fault (since we'll be setting the dirty bit momentarily) but
correct when instantiating a speculative spte, or when servicing a
read fault (since we'll want to trap a following write in order to
set the dirty bit).
It doesn't seem to hurt in practice, but in order to make the code
readable, push the write protection out of gpte_access() and into
a new protect_clean_gpte() which is called explicitly when needed.
The idea is from Avi:
| We could cache the result of a miss in an spte by using a reserved bit, and
| checking the page fault error code (or seeing if we get an ept violation or
| ept misconfiguration), so if we get repeated mmio on a page, we don't need to
| search the slot list/tree.
| (https://lkml.org/lkml/2011/2/22/221)
When the page fault is caused by mmio, we cache the info in the shadow page
table, and also set the reserved bits in the shadow page table, so if the mmio
is caused again, we can quickly identify it and emulate it directly
Searching mmio gfn in memslots is heavy since we need to walk all memeslots, it
can be reduced by this feature, and also avoid walking guest page table for
soft mmu.
[jan: fix operator precedence issue]
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
If the page fault is caused by mmio, we can cache the mmio info, later, we do
not need to walk guest page table and quickly know it is a mmio fault while we
emulate the mmio instruction
This patch moves the detection whether a page-fault was
nested or not out of the error code and moves it into a
separate variable in the fault struct.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
This patch introduces the init_kvm_nested_mmu() function
which is used to re-initialize the nested mmu when the l2
guest changes its paging mode.
Some logic of the init_kvm_softmmu function is required to
build the Nested Nested Paging context. So factor the
required logic into a seperate function and export it.
Also make the whole init path suitable for more than one mmu
context.
Doing this makes the code much more readable. That's
borne out by the fact that this patch removes code. "used"
also happens to be the number that we need to return back to
the slab code when our shrinker gets called. Keeping this
value as opposed to free makes the next patch simpler.
So, 'struct kvm' is kzalloc()'d. 'struct kvm_arch' is a
structure member (and not a pointer) of 'struct kvm'. That
means they start out zeroed. I _think_ they get initialized
properly by kvm_mmu_change_mmu_pages(). But, that only happens
via kvm ioctls.
Another benefit of storing 'used' intead of 'free' is
that the values are consistent from the moment the structure is
allocated: no negative "used" value.
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
Signed-off-by: Tim Pepper <lnxninja@linux.vnet.ibm.com>
"free" is a poor name for this value. In this context, it means,
"the number of mmu pages which this kvm instance should be able to
allocate." But "free" implies much more that the objects are there
and ready for use. "available" is a much better description, especially
when you see how it is calculated.
In this patch, we abstract its use into a function. We'll soon
replace the function's contents by calculating the value in a
different way.
All of the reads of n_free_mmu_pages are taken care of in this
patch. The modification sites will be handled in a patch
later in the series.
Currently when x86 emulator needs to access memory, page walk is done with
broadest permission possible, so if emulated instruction was executed
by userspace process it can still access kernel memory. Fix that by
providing correct memory access to page walker during emulation.
Cc: stable@kernel.org
They have more general scope than the mmu.
Since we'd like to allow the guest to own a few bits of cr0 at times, we need
to know when we access those bits.
We can use them in x86.c and vmx.c now...
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
Some bits of cr4 can be owned by the guest on vmx, so when we read them,
we copy them to the vcpu structure. In preparation for making the set of
guest-owned bits dynamic, use helpers to access these bits so we don't need
to know where the bit resides.
No changes to svm since all bits are host-owned there.
Required by EPT misconfiguration handler.
Since the guest and host ptes can have wildly different format, adjust
the pte accessor names to indicate on which type of pte they operate on.
No functional changes.
Also remove bit 5-6 from rsvd_bits_mask per latest SDM.
Signed-off-by: Eddie Dong <Eddie.Dong@intel.com>
is_long_mode currently checks the LongModeEnable bit in
EFER instead of the LongModeActive bit. This is wrong, but
we survived this till now since it wasn't triggered. This
breaks guests that go from long mode to compatibility mode.
This is noticed on a solaris guest and fixes bug #1842160
Signed-off-by: Amit Shah <amit.shah@qumranet.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
The KVM MMU tries to detect when a speculative pte update is not actually
used by demand fault, by checking the accessed bit of the shadow pte. If
the shadow pte has not been accessed, we deem that page table flooded and
remove the shadow page table, allowing further pte updates to proceed
without emulation.
However, if the pte itself points at a page table and only used for write
operations, the accessed bit will never be set since all access will happen
through the emulator.
This is exactly what happens with kscand on old (2.4.x) HIGHMEM kernels.
The kernel points a kmap_atomic() pte at a page table, and then
proceeds with read-modify-write operations to look at the dirty and accessed
bits. We get a false flood trigger on the kmap ptes, which results in the
mmu spending all its time setting up and tearing down shadows.
Fix by setting the shadow accessed bit on emulated accesses.
The function get_tdp_level() provided the number of tdp level for EPT and
NPT rather than the NPT specific macro.
Signed-off-by: Sheng Yang <sheng.yang@intel.com>
Move some definitions to mmu.h in order to allow building common table
entries between EPT and non-EPT.
This patch contains the changes to the KVM MMU necessary for support of the
Nested Paging feature in AMD Barcelona and Phenom Processors.
This paves the way for multiple architecture support. Note that while
ioapic.c could potentially be shared with ia64, it is also moved.
