commit 5fd5387c89ec99ff6cb82d2477ffeb7211b781c2 upstream.
In no-direct mapping, we mark sp is 'direct' when we mapping the
guest's larger page, but its access is encoded form upper page-struct
entire not include the last mapping, it will cause access conflict.
For example, have this mapping:
[W]
/ PDE1 -> |---|
P[W] | | LPA
\ PDE2 -> |---|
[R]
P have two children, PDE1 and PDE2, both PDE1 and PDE2 mapping the
same lage page(LPA). The P's access is WR, PDE1's access is WR,
PDE2's access is RO(just consider read-write permissions here)
When guest access PDE1, we will create a direct sp for LPA, the sp's
access is from P, is W, then we will mark the ptes is W in this sp.
Then, guest access PDE2, we will find LPA's shadow page, is the same as
PDE's, and mark the ptes is RO.
So, if guest access PDE1, the incorrect #PF is occured.
Fixed by encode the last mapping access into direct shadow page
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
commit 9e7b0e7fba45ca3c6357aeb7091ebc281f1de365 upstream.
If the mapping is writable but the dirty flag is not set, we will find
the read-only direct sp and setup the mapping, then if the write #PF
occur, we will mark this mapping writable in the read-only direct sp,
now, other real read-only mapping will happily write it without #PF.
It may hurt guest's COW
Fixed by re-install the mapping when write #PF occur.
commit 1871c6020d7308afb99127bba51f04548e7ca84e upstream
Currently when x86 emulator needs to access memory, page walk is done with
broadest permission possible, so if emulated instruction was executed
by userspace process it can still access kernel memory. Fix that by
providing correct memory access to page walker during emulation.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
commit a6085fbaf65ab09bfb5ec8d902d6d21680fe1895 upstream.
Exit the guest pagetable walk loop if reading gpte failed. Otherwise its
possible to enter an endless loop processing the previous present pte.
commit fb341f572d26e0786167cd96b90cc4febed830cf upstream.
The invlpg prefault optimization breaks Windows 2008 R2 occasionally.
The visible effect is that the invlpg handler instantiates a pte which
is, microseconds later, written with a different gfn by another vcpu.
The OS could have other mechanisms to prevent a present translation from
being used, which the hypervisor is unaware of.
While the documentation states that the cpu is at liberty to prefetch tlb
entries, it looks like this is not heeded, so remove tlb prefetch from
invlpg.
this flag notify that the host physical page we are pointing to from
the spte is write protected, and therefore we cant change its access
to be write unless we run get_user_pages(write = 1).
(this is needed for change_pte support in kvm)
Signed-off-by: Izik Eidus <ieidus@redhat.com>
This patch adds support for shadow paging to the 1gb page table code in KVM.
With this code the guest can use 1gb pages even if the host does not support
them.
[ Marcelo: fix shadow page collision on pmd level if a guest 1gb page is mapped
with 4kb ptes on host level ]
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
The page walker may be used with nested paging too when accessing mmio
areas. Make it support the additional page-level too.
[ Marcelo: fix reserved bit check for 1gb pte ]
With the new name and the corresponding backend changes this function
can now support multiple hugepage sizes.
[avi: fix build on non-x86]
We use shadow_pte and spte inconsistently, switch to the shorter spelling.
Rename set_shadow_pte() to __set_spte() to avoid a conflict with the
existing set_spte(), and to indicate its lowlevelness.
Since the guest and host ptes can have wildly different format, adjust
the pte accessor names to indicate on which type of pte they operate on.
No functional changes.
Instead of reloading the pdptrs on every entry and exit (vmcs writes on vmx,
guest memory access on svm) extract them on demand.
Dixes compilation warning:
CC arch/x86/kernel/io_delay.o
arch/x86/kvm/paging_tmpl.h: In function ‘paging64_fetch’:
arch/x86/kvm/paging_tmpl.h:279: warning: ‘sptep’ may be used uninitialized in this function
arch/x86/kvm/paging_tmpl.h: In function ‘paging32_fetch’:
warning is bogus (always have a least one level), but need to shut the compiler
up.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Complexity to fix it not worthwhile the gains, as discussed
in http://article.gmane.org/gmane.comp.emulators.kvm.devel/28649.
Detect, indicate, and propagate page faults where reserved bits are set.
Take care to handle the different paging modes, each of which has different
sets of reserved bits.
[avi: fix pte reserved bits for efer.nxe=0]
Signed-off-by: Eddie Dong <eddie.dong@intel.com>
The original one is for the code before refactoring.
Signed-off-by: Yaozu (Eddie) Dong <eddie.dong@intel.com>
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
There is no reason to update the shadow pte here because the guest pte
is only changed to dirty state.
When kvm emulates an invlpg instruction, it can drop a shadow pte, but
leaves the guest tlbs intact. This can cause memory corruption when
swapping out.
Without this the other cpu can still write to a freed host physical page.
tlb smp flush must happen if rmap_remove is called always before mmu_lock
is released because the VM will take the mmu_lock before it can finally add
the page to the freelist after swapout. mmu notifier makes it safe to flush
the tlb after freeing the page (otherwise it would never be safe) so we can do
a single flush for multiple sptes invalidated.
Cc: stable@kernel.org
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: Marcelo Tosatti <mtosatti@redhat.com>
In the paging_fetch function rmap_remove is called after setting a large
pte to non-present. This causes rmap_remove to not drop the reference to
the large page. The result is a memory leak of that page.
This actually describes what is going on, rather than alerting the reader
that something strange is going on.
Effectively reverting to the pre walk_shadow() version -- but now
with the reusable for_each().
The invlpg and sync walkers lack knowledge of large host sptes,
descending to non-existant pagetable level.
Stop at directory level in such case.
Fixes SMP Windows XP with hugepages.
If the guest executes invlpg, peek into the pagetable and attempt to
prepopulate the shadow entry.
Also stop dirty fault updates from interfering with the fork detector.
2% improvement on RHEL3/AIM7.
Skip syncing global pages on cr3 switch (but not on cr4/cr0). This is
important for Linux 32-bit guests with PAE, where the kmap page is
marked as global.
It is possible for a shadow page to have a parent link
pointing to a freed page. When zapping a high level table,
kvm_mmu_page_unlink_children fails to remove the parent_pte link.
For that to happen, the child must be unreachable via the shadow
tree, which can happen in shadow_walk_entry if the guest pte was
modified in between walk() and fetch(). Remove the parent pte
reference in such case.
Possible cause for oops in bug #2217430.
Allow guest pagetables to go out of sync. Instead of emulating write
accesses to guest pagetables, or unshadowing them, we un-write-protect
the page table and allow the guest to modify it at will. We rely on
invlpg executions to synchronize individual ptes, and will synchronize
the entire pagetable on tlb flushes.
With pages out of sync invlpg needs to be trapped. For now simply nuke
the entry.
Untested on AMD.
Examine guest pagetable and bring the shadow back in sync. Caller is responsible
for local TLB flush before re-entering guest mode.
It is necessary to flush all TLB's when a large spte entry is
overwritten with a normal page directory pointer.
Convert gfn_to_pfn to use get_user_pages_fast, which can do lockless
pagetable lookups on x86. Kernel compilation on 4-way guest is 3.7%
faster on VMX.
EPT is 4 level by default in 32pae(48 bits), but the addr parameter
of kvm_shadow_walk->entry() only accept unsigned long as virtual
address, which is 32bit in 32pae. This result in SHADOW_PT_INDEX()
overflow when try to fetch level 4 index.
Fix it by extend kvm_shadow_walk->entry() to accept 64bit addr in
parameter.
Signed-off-by: Sheng Yang <sheng.yang@intel.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
It is not specific to the paging mode, so can be made global (and reusable).
The shadow code assigns a pte directly in one place, which is nonatomic on
i386 can can cause random memory references. Fix by using an atomic setter.
Synchronize changes to host virtual addresses which are part of
a KVM memory slot to the KVM shadow mmu. This allows pte operations
like swapping, page migration, and madvise() to transparently work
with KVM.
Signed-off-by: Andrea Arcangeli <andrea@qumranet.com>
Instead of reading each pte individually, read 256 bytes worth of ptes and
batch process them.
This patch introduces a gfn_to_pfn() function and corresponding functions like
kvm_release_pfn_dirty(). Using these new functions, we can modify the x86
MMU to no longer assume that it can always get a struct page for any given gfn.
We don't want to eliminate gfn_to_page() entirely because a number of places
assume they can do gfn_to_page() and then kmap() the results. When we support
IO memory, gfn_to_page() will fail for IO pages although gfn_to_pfn() will
succeed.
This does not implement support for avoiding reference counting for reserved
RAM or for IO memory. However, it should make those things pretty straight
forward.
Since we're only introducing new common symbols, I don't think it will break
the non-x86 architectures but I haven't tested those. I've tested Intel,
AMD, NPT, and hugetlbfs with Windows and Linux guests.
[avi: fix overflow when shifting left pfns by adding casts]
Signed-off-by: Anthony Liguori <aliguori@us.ibm.com>
Unify slots_lock acquision around vcpu_run(). This is simpler and less
error-prone.
Also fix some callsites that were not grabbing the lock properly.
[avi: drop slots_lock while in guest mode to avoid holding the lock
for indefinite periods]
If we populate a shadow pte due to a fault (and not speculatively due to a
pte write) then we can set the accessed bit on it, as we know it will be
set immediately on the next guest instruction. This saves a read-modify-write
operation.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Create large pages mappings if the guest PTE's are marked as such and
the underlying memory is hugetlbfs backed. If the largepage contains
write-protected pages, a large pte is not used.
Gives a consistent 2% improvement for data copies on ram mounted
filesystem, without NPT/EPT.
Anthony measures a 4% improvement on 4-way kernbench, with NPT.
Currently an mmio guest pte is encoded in the shadow pagetable as a
not-present trapping pte, with the SHADOW_IO_MARK bit set. However
nothing is ever done with this information, so maintaining it is a
useless complication.
This patch moves the check for mmio to before shadow ptes are instantiated,
so the shadow code is never invoked for ptes that reference mmio. The code
is simpler, and with future work, can be made to handle mmio concurrently.
A guest partial guest pte write will leave shadow_trap_nonpresent_pte
in spte, which generates a vmexit at the next guest access through that pte.
This patch improves this by reading the full guest pte in advance and thus
being able to update the spte and eliminate the vmexit.
This helps pae guests which use two 32-bit writes to set a single 64-bit pte.
[truncation fix by Eric]
Signed-off-by: Feng (Eric) Liu <eric.e.liu@intel.com>
For improved concurrency, the guest walk is performed concurrently with other
vcpus. This means that we need to revalidate the guest ptes once we have
write-protected the guest page tables, at which point they can no longer be
modified.
The current code attempts to avoid this check if the shadow page table is not
new, on the assumption that if it has existed before, the guest could not have
modified the pte without the shadow lock. However the assumption is incorrect,
as the racing vcpu could have modified the pte, then instantiated the shadow
page, before our vcpu regains control:
vcpu0 vcpu1
fault
walk pte
modify pte
fault in same pagetable
instantiate shadow page
lookup shadow page
conclude it is old
instantiate spte based on stale guest pte
We could do something clever with generation counters, but a test run by
Marcelo suggests this is unnecessary and we can just do the revalidation
unconditionally. The pte will be in the processor cache and the check can
be quite fast.
the cr3 variable is now inside the vcpu->arch structure.
