Migrate the PIT timer to the physical CPU which vcpu0 is scheduled on,
similarly to what is done for the LAPIC timers, otherwise PIT interrupts
will be delayed until an unrelated event causes an exit.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
This make sure not to schedule in atomic during fx_init. I also
changed the name of fpu_init to fx_finit to avoid duplicating the name
with fpu_init that is already used in the kernel, this makes grep
simpler if nothing else.
Signed-off-by: Andrea Arcangeli <andrea@qumranet.com>
Clear pending exceptions when setting new register values. This avoids
spurious exceptions after restoring a vcpu state or after
reset-on-triple-fault.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
The busy bit is bit 1 of the type field, not bit 8.
Signed-off-by: Izik Eidus <izike@qumranet.com>
[aliguory: plug leak]
Signed-off-by: Sheng Yang <sheng.yang@intel.com>
Signed-off-by: Anthony Liguori <aliguori@us.ibm.com>
Enable kvm_set_spte() to generate EPT entries.
There is a window open between testing of pending IRQ's
and assignment of guest_mode in __vcpu_run.
Injection of IRQ's can race with __vcpu_run as follows:
CPU0 CPU1
kvm_x86_ops->run()
vcpu->guest_mode = 0 SET_IRQ_LINE ioctl
kvm_x86_ops->inject_pending_irq
kvm_cpu_has_interrupt()
apic_test_and_set_irr()
kvm_vcpu_kick
if (vcpu->guest_mode)
send_ipi()
vcpu->guest_mode = 1
So move guest_mode=1 assignment before ->inject_pending_irq, and make
sure that it won't reorder after it.
So userspace can save/restore the mpstate during migration.
[avi: export the #define constants describing the value]
[christian: add s390 stubs]
[avi: ditto for ia64]
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
We wish to export it to userspace, so move it into the kvm namespace.
Trace markers allow userspace to trace execution of a virtual machine
in order to monitor its performance.
Signed-off-by: Feng (Eric) Liu <eric.e.liu@intel.com>
Noticed by Marcelo Tosatti.
Unify slots_lock acquision around vcpu_run(). This is simpler and less
error-prone.
Also fix some callsites that were not grabbing the lock properly.
[avi: drop slots_lock while in guest mode to avoid holding the lock
for indefinite periods]
This emulates the x86 hardware task switch mechanism in software, as it is
unsupported by either vmx or svm. It allows operating systems which use it,
like freedos, to run as kvm guests.
Hypercall based pte updates are faster than faults, and also allow use
of the lazy MMU mode to batch operations.
Don't report the feature if two dimensional paging is enabled.
[avi:
- one mmu_op hypercall instead of one per op
- allow 64-bit gpa on hypercall
- don't pass host errors (-ENOMEM) to guest]
[akpm: warning fix on i386]
Add basic KVM paravirt support. Avoid vm-exits on IO delays.
The patch moves the PIT model from userspace to kernel, and increases
the timer accuracy greatly.
[marcelo: make last_injected_time per-guest]
Tested-and-Acked-by: Alex Davis <alex14641@yahoo.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
In the current inject_page_fault path KVM only checks if there is another PF
pending and injects a DF then. But it has to check for a pending DF too to
detect a shutdown condition in the VCPU. If this is not detected the VCPU goes
to a PF -> DF -> PF loop when it should triple fault. This patch detects this
condition and handles it with an KVM_SHUTDOWN exit to userspace.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Names like 'set_cr3()' look dangerously close to affecting the host.
Create large pages mappings if the guest PTE's are marked as such and
the underlying memory is hugetlbfs backed. If the largepage contains
write-protected pages, a large pte is not used.
Gives a consistent 2% improvement for data copies on ram mounted
filesystem, without NPT/EPT.
Anthony measures a 4% improvement on 4-way kernbench, with NPT.
Mark zapped root pagetables as invalid and ignore such pages during lookup.
This is a problem with the cr3-target feature, where a zapped root table fools
the faulting code into creating a read-only mapping. The result is a lockup
if the instruction can't be emulated.
Cc: Anthony Liguori <aliguori@us.ibm.com>
Darwin relies on this and ceases to work without.
Signed-off-by: Alexander Graf <alex@csgraf.de>
In two case statements, use the ever popular 'i' instead of index:
arch/x86/kvm/x86.c:1063:7: warning: symbol 'index' shadows an earlier one
arch/x86/kvm/x86.c:1000:9: originally declared here
arch/x86/kvm/x86.c:1079:7: warning: symbol 'index' shadows an earlier one
Make it static.
arch/x86/kvm/x86.c:1945:24: warning: symbol 'emulate_ops' was not declared. Should it be static?
Drop the return statements.
arch/x86/kvm/x86.c:2878:2: warning: returning void-valued expression
arch/x86/kvm/x86.c:2944:2: warning: returning void-valued expression
Signed-off-by: Amit Shah <amit.shah@qumranet.com>
The x86 desc_struct unification allows us to remove segment_descriptor.h.
This is the host part of kvm clocksource implementation. As it does
not include clockevents, it is a fairly simple implementation. We
only have to register a per-vcpu area, and start writing to it periodically.
The area is binary compatible with xen, as we use the same shadow_info
structure.
[marcelo: fix bad_page on MSR_KVM_SYSTEM_TIME]
[avi: save full value of the msr, even if enable bit is clear]
[avi: clear previous value of time_page]
Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com>
The load_pdptrs() function is required in the SVM module for NPT support.
This patch makes the EFER register accessible on a 32bit KVM host. This is
necessary to boot 32 bit PAE guests under SVM.
This patch aligns the bits the guest can set in the EFER register with the
features in the host processor. Currently it lets EFER.NX disabled if the
processor does not support it and enables EFER.LME and EFER.LMA only for KVM on
64 bit hosts.
This patch give the SVM and VMX implementations the ability to add some bits
the guest can set in its EFER register.
This patch replaces the mmap_sem lock for the memory slots with a new
kvm private lock, it is needed beacuse untill now there were cases where
kvm accesses user memory while holding the mmap semaphore.
Injecting an GP when accessing this MSR lets Windows crash when running some
stress test tools in KVM. So this patch emulates access to this MSR.
Signed-off-by: Markus Rechberger <markus.rechberger@amd.com>
One of the use cases for the supported cpuid list is to create a "greatest
common denominator" of cpu capabilities in a server farm. As such, it is
useful to be able to get the list without creating a virtual machine first.
Since the code does not depend on the vm in any way, all that is needed is
to move it to the device ioctl handler. The capability identifier is also
changed so that binaries made against -rc1 will fail gracefully.
Whilst working on getting a VM to initialize in to IA32e mode I found
this issue. set_cr0 relies on comparing the old cr0 to the new one to
work correctly. Move the assignment below so the compare can work.
Signed-off-by: Paul Knowles <paul@transitive.com>
arch/x86/kvm/x86.c: In function 'emulator_cmpxchg_emulated':
arch/x86/kvm/x86.c:1746: warning: passing argument 2 of 'vcpu->arch.mmu.gva_to_gpa' makes integer from pointer without a cast
arch/x86/kvm/x86.c:1746: warning: 'addr' is used uninitialized in this function
Is true. Local variable `addr' shadows incoming arg `addr'. Avi is on
vacation for a while, so...
Cc: Avi Kivity <avi@qumranet.com>
Migrating the apic timer in the critical section is not very nice, and is
absolutely horrible with the real-time port. Move migration to the regular
vcpu execution path, triggered by a new bitflag.
When preparing to enter the guest, if an interrupt comes in while
preemption is disabled but interrupts are still enabled, we miss a
preemption point. Fix by explicitly checking whether we need to
reschedule.
Otherwise we re-initialize the mmu caches, which will fail since the
caches are already registered, which will cause us to deinitialize said caches.
When executing a test program called "crashme", we found the KVM guest cannot
survive more than ten seconds, then encounterd kernel panic. The basic concept
of "crashme" is generating random assembly code and trying to execute it.
After some fixes on emulator insn validity judgment, we found it's hard to
get the current emulator handle the invalid instructions correctly, for the
#UD trap for hypercall patching caused troubles. The problem is, if the opcode
itself was OK, but combination of opcode and modrm_reg was invalid, and one
operand of the opcode was memory (SrcMem or DstMem), the emulator will fetch
the memory operand first rather than checking the validity, and may encounter
an error there. For example, ".byte 0xfe, 0x34, 0xcd" has this problem.
In the patch, we simply check that if the invalid opcode wasn't vmcall/vmmcall,
then return from emulate_instruction() and inject a #UD to guest. With the
patch, the guest had been running for more than 12 hours.
Do not hold kvm->lock mutex across the entire pagefault code,
only acquire it in places where it is necessary, such as mmu
hash list, active list, rmap and parent pte handling.
Allow concurrent guest walkers by switching walk_addr() to use
mmap_sem in read-mode.
And get rid of the lockless __gfn_to_page.
[avi: move kvm_mmu_pte_write() locking inside the function]
[avi: add locking for real mode]
[avi: fix cmpxchg locking]
FlexPriority accelerates the tpr without any patching.
This adds a mechanism for exposing the virtual apic tpr to the guest, and a
protocol for letting the guest update the tpr without causing a vmexit if
conditions allow (e.g. there is no interrupt pending with a higher priority
than the new tpr).
Add a facility to report on accesses to the local apic tpr even if the
local apic is emulated in the kernel. This is basically a hack that
allows userspace to patch Windows which tends to bang on the tpr a lot.
This can help diagnosing what the guest is trying to do. In many cases
we can get away with partial emulation of msrs.
Moving kvm_vcpu_kick() to x86.c. Since it should be
common for all archs, put its declarations in <linux/kvm_host.h>
Signed-off-by: Zhang Xiantao <xiantao.zhang@intel.com>
