path: root/arch/x86/lguest
2011-07-22lguest: Fix translation count about wikipedia's cpuid pageAdrian Knoth
The comment is outdated, wikipedia now has six translations of the cpuid page. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-22lguest: Fix three simple typos in commentsAdrian Knoth
This patch fixes three typos I've accidentally spotted. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (one was already fixed)
2011-07-22lguest: update commentsRusty Russell
Also removes a long-unused #define and an extraneous semicolon. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-22lguest: remove remaining vmcallRusty Russell
We switch back from using vmcall in 091ebf07a2408f9a56634caa0f86d9360e9af23b because it was unreliable under kvm, but I missed one (rarely-used) place. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-22lguest: use a special 1:1 linear pagetable mode until first switch.Rusty Russell
The Host used to create some page tables for the Guest to use at the top of Guest memory; it would then tell the Guest where this was. In particular, it created linear mappings for 0 and 0xC0000000 addresses because lguest used to switch to its real page tables quite late in boot. However, since d50d8fe19 Linux initialized boot page tables in head_32.S even before the "are we lguest?" boot jump. So, now we can simplify things: the Host pagetable code assumes 1:1 linear mapping until it first calls the LHCALL_NEW_PGTABLE hypercall, which we now do before we reach C code. This also means that the Host doesn't need to know anything about the Guest's PAGE_OFFSET. (Non-Linux guests might not even have such a thing). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-30lguest: fix timer interrupt setupRusty Russell
Without an IRQ chip set, we now get a WARN_ON and no timer interrupt. This prevents booting. Fortunately, the fix is a one-liner: set up the timer IRQ like everything else. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org # .39.x
2011-05-19Merge branch 'timers-clocksource-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-clocksource-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clocksource: convert mips to generic i8253 clocksource clocksource: convert x86 to generic i8253 clocksource clocksource: convert footbridge to generic i8253 clocksource clocksource: add common i8253 PIT clocksource blackfin: convert to clocksource_register_hz mips: convert to clocksource_register_hz/khz sparc: convert to clocksource_register_hz/khz alpha: convert to clocksource_register_hz microblaze: convert to clocksource_register_hz/khz ia64: convert to clocksource_register_hz/khz x86: Convert remaining x86 clocksources to clocksource_register_hz/khz Make clocksource name const
2011-05-14Merge branch 'consolidate-clksrc-i8253' of ↵Thomas Gleixner
master.kernel.org:~rmk/linux-2.6-arm into timers/clocksource Conflicts: arch/ia64/kernel/cyclone.c arch/mips/kernel/i8253.c arch/x86/kernel/i8253.c Reason: Resolve conflicts so further cleanups do not conflict further Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-06Correct occurrences ofRob Landley
- Documentation/kvm/ to Documentation/virtual/kvm - Documentation/uml/ to Documentation/virtual/uml - Documentation/lguest/ to Documentation/virtual/lguest throughout the kernel source tree. Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com>
2011-03-18x86: Fix common misspellingsLucas De Marchi
They were generated by 'codespell' and then manually reviewed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: trivial@kernel.org LKML-Reference: <1300389856-1099-3-git-send-email-lucas.demarchi@profusion.mobi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-12x86: Cleanup the genirq name spaceThomas Gleixner
genirq is switching to a consistent name space for the irq related functions. Convert x86. Conversion was done with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-21x86: Convert remaining x86 clocksources to clocksource_register_hz/khzJohn Stultz
This converts the remaining x86 clocksources to use clocksource_register_hz/khz. CC: jacob.jun.pan@intel.com CC: Glauber Costa <glommer@redhat.com> CC: Dimitri Sivanich <sivanich@sgi.com> CC: Rusty Russell <rusty@rustcorp.com.au> CC: Jeremy Fitzhardinge <jeremy@xensource.com> CC: Chris McDermott <lcm@us.ibm.com> CC: Thomas Gleixner <tglx@linutronix.de> Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen] Signed-off-by: John Stultz <johnstul@us.ibm.com>
2011-01-20LGUEST_GUEST: fix unmet direct dependencies (VIRTUALIZATION && VIRTIO)Randy Dunlap
Honor the kconfig menu hierarchy to remove kconfig dependency warnings: VIRTIO and VIRTIO_RING are subordinate to VIRTUALIZATION. warning: (LGUEST_GUEST) selects VIRTIO which has unmet direct dependencies (VIRTUALIZATION) warning: (LGUEST_GUEST && VIRTIO_PCI && VIRTIO_BALLOON) selects VIRTIO_RING which has unmet direct dependencies (VIRTUALIZATION && VIRTIO) Reported-by: Toralf F_rster <toralf.foerster@gmx.de> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-01-20lguest: compile fixesRusty Russell
arch/x86/lguest/boot.c: In function ‘lguest_init_IRQ’: arch/x86/lguest/boot.c:824: error: macro "__this_cpu_write" requires 2 arguments, but only 1 given arch/x86/lguest/boot.c:824: error: ‘__this_cpu_write’ undeclared (first use in this function) arch/x86/lguest/boot.c:824: error: (Each undeclared identifier is reported only once arch/x86/lguest/boot.c:824: error: for each function it appears in.) drivers/lguest/x86/core.c: In function ‘copy_in_guest_info’: drivers/lguest/x86/core.c:94: error: lvalue required as left operand of assignment Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-01-20lguest: Use this_cpu_opsChristoph Lameter
Use this_cpu_ops in a couple of places in lguest. Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-01-04x86, mm: Initialize initial_page_table before paravirt jumpsRusty Russell
v2.6.36-rc8-54-gb40827f (x86-32, mm: Add an initial page table for core bootstrapping) made x86 boot using initial_page_table and broke lguest. For 2.6.37 we simply cut & paste the initialization code into lguest (da32dac10126 "lguest: populate initial_page_table"), now we fix it properly by doing that initialization before the paravirt jump. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: lguest <lguest@ozlabs.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <201101041720.54535.rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-16lguest: populate initial_page_tableRusty Russell
Two x86 patches broke lguest: 1) v2.6.35-492-g72d7c3b, which changed x86 to use the memblock allocator. In lguest, the host places linear page tables at the top of mem, which used to be enough to get us up to the swapper_pg_dir page tables. With the first patch, the direct mapping tables used that memory: Before: kernel direct mapping tables up to 4000000 @ 7000-1a000 After: kernel direct mapping tables up to 4000000 @ 3fed000-4000000 I initially fixed this by lying about the amount of memory we had, so the kernel wouldn't blatt the lguest boot pagetables (yuk!), but then... 2) v2.6.36-rc8-54-gb40827f, which made x86 boot use initial_page_table. This was initialized in a part of head_32.S which isn't executed by lguest; it is then copied into swapper_pg_dir. So we have to initialize it; and anyway we switch to it before we blatt the old tables, so that fixes the previous damage as well. For the moment, I cut & pasted the code into lguest's boot code, but next merge window I will merge them. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> To: x86@kernel.org
2010-12-16lguest: restore boot speedRusty Russell
lguest is dumb and drops *all* the pagetables for set_pte (which is only used for kernel mapping manipulation, so it's OK without highmem). But it's used a lot in boot, too. As a guest optimization, we suppressed this flushing until the first page switch. Now we have initial_page_table, that happens much earlier, so extend the heuristic to wait until we switch to something other than the swapper_pg_dir or initial_page_table. As measured on my laptop under kvm, this dropped the time-to-mount-root from 48 seconds to 4.3 seconds. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-12-16lguest: fix crash lguest_time_initRusty Russell
fe25c7fc2e "x86: lguest: Convert to new irq chip functions" converted enable_lguest_irq() to take a struct irq_data *, but didn't fix the one internal caller. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> To: x86@kernel.org
2010-10-12x86: lguest: Use new irq allocatorThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au>
2010-10-12x86: lguest: Convert to new irq chip functionsThomas Gleixner
2010-09-21lguest: update comments to reflect LHCALL_LOAD_GDT_ENTRY.Rusty Russell
We used to have a hypercall which reloaded the entire GDT, then we switched to one which loaded a single entry (to match the IDT code). Some comments were not updated, so fix them. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reported by: Eviatar Khen <eviatarkhen@gmail.com>
2010-05-28Merge branch 'ht-delete-2.6.35' into releaseLen Brown
2010-04-14lguest: stop using KVM hypercall mechanismRusty Russell
This is a partial revert of 4cd8b5e2a159 "lguest: use KVM hypercalls"; we revert to using (just as questionable but more reliable) int $15 for hypercalls. I didn't revert the register mapping, so we still use the same calling convention as kvm. KVM in more recent incarnations stopped injecting a fault when a guest tried to use the VMCALL instruction from ring 1, so lguest under kvm fails to make hypercalls. It was nice to share code with our KVM cousins, but this was overreach. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Matias Zabaljauregui <zabaljauregui@gmail.com> Cc: Avi Kivity <avi@redhat.com>
2010-03-14ACPI: delete the "acpi=ht" boot optionLen Brown
acpi=ht was important in 2003 -- before ACPI was universally deployed and enabled by default in the major Linux distributions. At that time, there were a fair number of people who or chose to, or needed to, run with acpi=off, yet also wanted access to Hyper-threading. Today we find that many invocations of "acpi=ht" are accidental, and thus is it possible that it is doing more harm than good. In 2.6.34, we warn on invocation of acpi=ht. In 2.6.35, we delete the boot option. Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-23lguest: move panic notifier registration to its expected place.Rusty Russell
We used to defer it, so lockdep was happy. We now init lockdep early anyway, so just do it after that. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-16x86: Move get/set_wallclock to x86_platform_opsFeng Tang
get/set_wallclock() have already a set of platform dependent implementations (default, EFI, paravirt). MRST will add another variant. Moving them to platform ops simplifies the existing code and minimizes the effort to integrate new variants. Signed-off-by: Feng Tang <feng.tang@intel.com> LKML-Reference: <new-submission> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-31x86: Move tsc_calibration to x86_init_opsThomas Gleixner
TSC calibration is modified by the vmware hypervisor and paravirt by separate means. Moorestown wants to add its own calibration routine as well. So make calibrate_tsc a proper x86_init_ops function and override it by paravirt or by the early setup of the vmware hypervisor. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-31x86: Add timer_init to x86_init_opsThomas Gleixner
The timer init code is convoluted with several quirks and the paravirt timer chooser. Figuring out which code path is actually taken is not for the faint hearted. Move the numaq TSC quirk to tsc_pre_init x86_init_ops function and replace the paravirt time chooser and the remaining x86 quirk with a simple x86_init_ops function. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-31x86: Move irq_init to x86_init_opsThomas Gleixner
irq_init is overridden by x86_quirks and by paravirts. Unify the whole mess and make it an unconditional x86_init_ops function which defaults to the standard function and can be overridden by the early platform code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-27x86: Move memory_setup to x86_init_opsThomas Gleixner
memory_setup is overridden by x86_quirks and by paravirts with weak functions and quirks. Unify the whole mess and make it an unconditional x86_init_ops function which defaults to the standard function and can be overridden by the early platform code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-07-30lguest: update commentryRusty Russell
Every so often, after code shuffles, I need to go through and unbitrot the Lguest Journey (see drivers/lguest/README). Since we now use RCU in a simple form in one place I took the opportunity to expand that explanation. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
2009-07-30lguest: fix comment styleRusty Russell
I don't really notice it (except to begrudge the extra vertical space), but Ingo does. And he pointed out that one excuse of lguest is as a teaching tool, it should set a good example. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@redhat.com>
2009-07-17lguest: restrict CPUID to avoid perf counter wrmsrRusty Russell
Avoid the following: [ 0.012093] WARNING: at arch/x86/kernel/apic/apic.c:249 native_apic_write_dummy+0x2f/0x40() Rather than chase each new cpuid-detected feature, just lie about the highest valid CPUID so this code is never run. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-07-17lguest: fix journeyMatias Zabaljauregui
fix: "make Guest" was complaining about duplicated G:032 Signed-off-by: Matias Zabaljauregui <zabaljauregui@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12lguest: PAE supportMatias Zabaljauregui
This version requires that host and guest have the same PAE status. NX cap is not offered to the guest, yet. Signed-off-by: Matias Zabaljauregui <zabaljauregui@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12lguest: Add support for kvm_hypercall4()Matias Zabaljauregui
Add support for kvm_hypercall4(); PAE wants it. Signed-off-by: Matias Zabaljauregui <zabaljauregui at gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12lguest: replace hypercall name LHCALL_SET_PMD with LHCALL_SET_PGDMatias Zabaljauregui
replace LHCALL_SET_PMD with LHCALL_SET_PGD hypercall name (That's really what it is, and the confusion gets worse with PAE support) Signed-off-by: Matias Zabaljauregui <zabaljauregui@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reported-by: Jeremy Fitzhardinge <jeremy@goop.org>
2009-06-12lguest: use native_set_* macros, which properly handle 64-bit entries when ↵Matias Zabaljauregui
PAE is activated Some cleanups and replace direct assignment with native_set_* macros which properly handle 64-bit entries when PAE is activated Signed-off-by: Matias Zabaljauregui <zabaljauregui@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12lguest: optimize by coding restore_flags and irq_enable in assembler.Rusty Russell
The downside of the last patch which made restore_flags and irq_enable check interrupts is that they are now too big to be patched directly into the callsites, so the C versions are always used. But the C versions go via PV_CALLEE_SAVE_REGS_THUNK which saves all the registers. In fact, we don't need any registers in the fast path, so we can do better than this if we actually code them in assembler. The results are in the noise, but since it's about the same amount of code, it's worth applying. 1GB Guest->Host: input(suppressed),output(suppressed) Before: Seconds: 0:16.53 Packets: 377268,753673 Interrupts: 22461,24297 Notifications: 1(5245),21303(732370) Net IRQs triggered: 377023(245),42578(711095) After: Seconds: 0:16.48 Packets: 377289,753673 Interrupts: 22281,24465 Notifications: 1(5245),21296(732377) Net IRQs triggered: 377060(229),42564(711109) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12lguest: improve interrupt handling, speed up stream networkingRusty Russell
lguest never checked for pending interrupts when enabling interrupts, and things still worked. However, it makes a significant difference to TCP performance, so it's time we fixed it by introducing a pending_irq flag and checking it on irq_restore and irq_enable. These two routines are now too big to patch into the 8/10 bytes patch space, so we drop that code. Note: The high latency on interrupt delivery had a very curious effect: once everything else was optimized, networking without GSO was faster than networking with GSO, since more interrupts were sent and hence a greater chance of one getting through to the Guest! Note2: (Almost) Closing the same loophole for iret doesn't have any measurable effect, so I'm leaving that patch for the moment. Before: 1GB tcpblast Guest->Host: 30.7 seconds 1GB tcpblast Guest->Host (no GSO): 76.0 seconds After: 1GB tcpblast Guest->Host: 6.8 seconds 1GB tcpblast Guest->Host (no GSO): 27.8 seconds Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12lguest: clean up lguest_init_IRQRusty Russell
Copy from arch/x86/kernel/irqinit_32.c: we don't use the vectors beyond LGUEST_IRQS (if any), but we might as well set them all. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-10Merge branch 'x86-xen-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-xen-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (42 commits) xen: cache cr0 value to avoid trap'n'emulate for read_cr0 xen/x86-64: clean up warnings about IST-using traps xen/x86-64: fix breakpoints and hardware watchpoints xen: reserve Xen start_info rather than e820 reserving xen: add FIX_TEXT_POKE to fixmap lguest: update lazy mmu changes to match lguest's use of kvm hypercalls xen: honour VCPU availability on boot xen: add "capabilities" file xen: drop kexec bits from /sys/hypervisor since kexec isn't implemented yet xen/sys/hypervisor: change writable_pt to features xen: add /sys/hypervisor support xen/xenbus: export xenbus_dev_changed xen: use device model for suspending xenbus devices xen: remove suspend_cancel hook xen/dev-evtchn: clean up locking in evtchn xen: export ioctl headers to userspace xen: add /dev/xen/evtchn driver xen: add irq_from_evtchn xen: clean up gate trap/interrupt constants xen: set _PAGE_NX in __supported_pte_mask before pagetable construction ...
2009-06-10Merge branch 'irq-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (76 commits) x86, apic: Fix dummy apic read operation together with broken MP handling x86, apic: Restore irqs on fail paths x86: Print real IOAPIC version for x86-64 x86: enable_update_mptable should be a macro sparseirq: Allow early irq_desc allocation x86, io-apic: Don't mark pin_programmed early x86, irq: don't call mp_config_acpi_gsi() if update_mptable is not enabled x86, irq: update_mptable needs pci_routeirq x86: don't call read_apic_id if !cpu_has_apic x86, apic: introduce io_apic_irq_attr x86/pci: add 4 more return parameters to IO_APIC_get_PCI_irq_vector(), fix x86: read apic ID in the !acpi_lapic case x86: apic: Fixmap apic address even if apic disabled x86: display extended apic registers with print_local_APIC and cpu_debug code x86: read apic ID in the !acpi_lapic case x86: clean up and fix setup_clear/force_cpu_cap handling x86: apic: Check rev 3 fadt correctly for physical_apic bit x86/pci: update pirq_enable_irq() to setup io apic routing x86/acpi: move setup io apic routing out of CONFIG_ACPI scope x86/pci: add 4 more return parameters to IO_APIC_get_PCI_irq_vector() ...
2009-06-04lguest: fix 'unhandled trap 13' with CONFIG_CC_STACKPROTECTORRusty Russell
We don't set up the canary; let's disable stack protector on boot.c so we can get into lguest_init, then set it up. As a side effect, switch_to_new_gdt() sets up %fs for us properly too. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-08Merge branch 'x86/urgent' into x86/xenIngo Molnar
Conflicts: arch/frv/include/asm/pgtable.h arch/x86/include/asm/required-features.h arch/x86/xen/mmu.c Merge reason: x86/xen was on a .29 base still, move it to a fresher branch and pick up Xen fixes as well, plus resolve conflicts Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-28x86/irq: change irq_desc_alloc() to take node instead of cpuYinghai Lu
This simplifies the node awareness of the code. All our allocators only deal with a NUMA node ID locality not with CPU ids anyway - so there's no need to maintain (and transform) a CPU id all across the IRq layer. v2: keep move_irq_desc related [ Impact: cleanup, prepare IRQ code to be NUMA-aware ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@goop.org> LKML-Reference: <49F65536.2020300@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-19lguest: fix guest crash on non-linear addresses in gdt pvopsRusty Russell
Fixes guest crash 'lguest: bad read address 0x4800000 len 256' The new per-cpu allocator ends up handing a non-linear address to write_gdt_entry. We do __pa() on it, and hand it to the host, which kills us. I've long wanted to make the hypercall "LOAD_GDT_ENTRY" to match the IDT code, but had no pressing reason until now. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: lguest@ozlabs.org
2009-04-07lguest: update lazy mmu changes to match lguest's use of kvm hypercallsJeremy Fitzhardinge
Duplicate hcall -> kvm_hypercall0 convertion from "lguest: use KVM hypercalls". Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Matias Zabaljauregui <zabaljauregui at gmail.com> Cc: Rusty Russell <rusty@rustcorp.com.au>
