git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"Some virtio internal cleanups, a new virtio device "virtio input", and
a change to allow the legacy virtio balloon.
Most excitingly, some lguest work! No seriously, I got some cleanup
patches"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
virtio: drop virtio_device_is_legacy_only
virtio_pci: support non-legacy balloon devices
virtio_mmio: support non-legacy balloon devices
virtio_ccw: support non-legacy balloon devices
virtio: balloon might not be a legacy device
virtio_balloon: transitional interface
virtio_ring: Update weak barriers to use dma_wmb/rmb
virtio_pci_modern: switch to type-safe io accessors
virtio_pci_modern: type-safe io accessors
lguest: handle traps on the "interrupt suppressed" iret instruction.
virtio: drop a useless config read
virtio_config: reorder functions
Add virtio-input driver.
lguest: suppress interrupts for single insn, not range.
lguest: simplify lguest_iret
lguest: rename i386_head.S in the comments
lguest: explicitly set miscdevice's private_data NULL
lguest: fix pending interrupt test.
Interrupt entry points are handled with the following code,
each 32-byte code block contains seven entry points:
[push][jump 22] // 4 bytes
[push][jump 18] // 4 bytes
[push][jump 14] // 4 bytes
[push][jump 10] // 4 bytes
[push][jump 6] // 4 bytes
[push][jump 2] // 4 bytes
[push][jump common_interrupt][padding] // 8 bytes
[push][jump]
[push][jump]
[push][jump]
[push][jump]
[push][jump]
[push][jump]
[padding_2]
common_interrupt:
And there is a table which holds pointers to every entry point,
IOW: to every push.
In cold cache, two jumps are still costlier than one, even
though we get the benefit of them residing in the same
cacheline.
This change replaces short jumps with near ones to
'common_interrupt', and pads every push+jump pair to 8 bytes. This
way, each interrupt takes only one jump.
This change replaces ".p2align CONFIG_X86_L1_CACHE_SHIFT" before
dispatch table with ".align 8" - we do not need anything
stronger than that.
The table of entry addresses (the interrupt[] array) is no
longer necessary, the address of entries can be easily
calculated as (irq_entries_start + i*8).
12546 0 0 12546 3102 entry_64.o.before
11626 0 0 11626 2d6a entry_64.o
The size decrease is because 1656 bytes of .init.rodata are
gone. That's initdata, though. The resident size does go up a
bit.
Run-tested (32 and 64 bits).
Acked-and-Tested-by: Borislav Petkov <bp@suse.de>
Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Alexei Starovoitov <ast@plumgrid.com>
Cc: Will Drewry <wad@chromium.org>
Link: http://lkml.kernel.org/r/1428090553-7283-1-git-send-email-dvlasenk@redhat.com
The last patch reduced our interrupt-suppression region to one address,
so simplify the code somewhat.
Also, remove the obsolete undefined instruction ranges and the comment
which refers to lguest_guest.S instead of head_32.S.
CC: lguest@lists.ozlabs.org
CC: x86@kernel.org
CC: linux-kernel@vger.kernel.org
i386_head.S renamed to the head_32.S, let's update it in
the comments too.
Signed-off-by: Alexander Kuleshov <kuleshovmail@gmail.com>
Denys says:
TEST with zero will always set ZF. Thus, "jnz send_interrupts" never jumps.
We get interrupts regularly enough that this didn't cause immediate problems.
Reported-by: Denys Vlasenko <vda.linux@googlemail.com>
We currently store references to the top of the kernel stack in
multiple places: kernel_stack (with an offset) and
init_tss.x86_tss.sp0 (no offset). The latter is defined by
hardware and is a clean canonical way to find the top of the
stack. Add an accessor so we can start using it.
This needs minor paravirt tweaks. On native, sp0 defines the
top of the kernel stack and is therefore always correct. On Xen
and lguest, the hypervisor tracks the top of the stack, but we
want to start reading sp0 in the kernel. Fixing this is simple:
just update our local copy of sp0 as well as the hypervisor's
copy on task switches.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/8d675581859712bee09a055ed8f785d80dac1eca.1425611534.git.luto@amacapital.net
We now add about 10k, not 6k, when lguest support is compiled in.
Reported-by: Randy Dunlap <rdunlap@infradead.org>
The 1.0 spec clearly states that you must set the ACKNOWLEDGE and
DRIVER status bits before accessing the feature bits. This is a
problem for the early console code, which doesn't really want to
acknowledge the device (the spec specifically excepts writing to the
console's emerg_wr from the usual ordering constrains).
Instead, we check that the *size* of the device configuration is
sufficient to hold emerg_wr: at worst (if the device doesn't support
the VIRTIO_CONSOLE_F_EMERG_WRITE feature), it will ignore the
writes.
This involves manually checking the console device (which is always in
slot 1 of bus 0) and using the window in VIRTIO_PCI_CAP_PCI_CFG to
program it (as we can't map the BAR yet).
We could in fact do this much earlier, but we wait for the first
write from the virtio_cons_early_init() facility.
This lets us deliver interrupts for our emulated PCI devices using our
dumb PIC, and not emulate an 8259 and PCI irq mapping tables or whatever.
Once we add PCI, it starts trying to manage our interrupts.
This no longer speeds up boot (IDE got better, I guess), but it does stop
us probing for a PCI bus.
When X86_LOCAL_APIC (i.e. unconditionally on x86-64),
first_system_vector will never end up being higher than
LOCAL_TIMER_VECTOR (0xef), and hence building stubs for vectors
0xef...0xff is pointlessly reducing code density. Deal with this at
build time already.
Taking into consideration that X86_64 implies X86_LOCAL_APIC, also
simplify (and hence make easier to read and more consistent with the
change done here) some #if-s in arch/x86/kernel/irqinit.c.
While we could further improve the packing of the IRQ entry stubs (the
four ones now left in the last set could be fit into the four padding
bytes each of the final four sets have) this doesn't seem to provide
any real benefit: Both irq_entries_start and common_interrupt getting
cache line aligned, eliminating the 30th set would just produce 32
bytes of padding between the 29th and common_interrupt.
[ tglx: Folded lguest fix from Dan Carpenter ]
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: lguest@lists.ozlabs.org
Link: http://lkml.kernel.org/r/54574D5F0200007800044389@mail.emea.novell.com
Link: http://lkml.kernel.org/r/20141115185718.GB6530@mwanda
As requested by Linus add explicit __visible to the asmlinkage users.
This marks all functions visible to assembler.
Tree sweep for arch/x86/*
Link: http://lkml.kernel.org/r/1398984278-29319-3-git-send-email-andi@firstfloor.org
- Make the C code used by the paravirt stubs visible
- Since they have to be global now, give them a more unique
name.
Link: http://lkml.kernel.org/r/1382458079-24450-3-git-send-email-andi@firstfloor.org
Since the Guest is in ring 1, it can't read the debug registers: doing
so gives a number of nasty messages:
(gdb) run
Starting program: /bin/sleep
[ 31.170230] general protection fault: 0000 [#1] SMP
[ 31.170230] Modules linked in:
[ 31.170230] CPU: 0 PID: 2678 Comm: sleep Not tainted 3.11.0+ #64
[ 31.170230] task: cc5c09b0 ti: cc79c000 task.ti: cc79c000
[ 31.170230] EIP: 0061:[<c01333d8>] EFLAGS: 00000097 CPU: 0
[ 31.170230] EIP is at native_get_debugreg+0x58/0x70
[ 31.170230] EAX: 00000006 EBX: cc79dfb4 ECX: b7fff918 EDX: 00000000
[ 31.170230] ESI: cc5c09b0 EDI: 00000000 EBP: cc79df84 ESP: cc79df84
[ 31.170230] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0069
[ 31.170230] CR0: 00000008 CR2: 081ba69a CR3: 0e2f2000 CR4: 00000000
The code was moved in 07fe9977b6234ede1bd29e10e0323e478860c871 but
the comment was not updated. The reference in drivers/vhost/vhost.c
is left alone as it is historic.
Signed-off-by: Holger Hans Peter Freyther <holger@moiji-mobile.com>
Pull timer core updates from Thomas Gleixner:
"The timer changes contain:
- posix timer code consolidation and fixes for odd corner cases
- sched_clock implementation moved from ARM to core code to avoid
duplication by other architectures
- alarm timer updates
- clocksource and clockevents unregistration facilities
- clocksource/events support for new hardware
- precise nanoseconds RTC readout (Xen feature)
- generic support for Xen suspend/resume oddities
- the usual lot of fixes and cleanups all over the place
The parts which touch other areas (ARM/XEN) have been coordinated with
the relevant maintainers. Though this results in an handful of
trivial to solve merge conflicts, which we preferred over nasty cross
tree merge dependencies.
The patches which have been committed in the last few days are bug
fixes plus the posix timer lot. The latter was in akpms queue and
next for quite some time; they just got forgotten and Frederic
collected them last minute."
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (59 commits)
hrtimer: Remove unused variable
hrtimers: Move SMP function call to thread context
clocksource: Reselect clocksource when watchdog validated high-res capability
posix-cpu-timers: don't account cpu timer after stopped thread runtime accounting
posix_timers: fix racy timer delta caching on task exit
posix-timers: correctly get dying task time sample in posix_cpu_timer_schedule()
selftests: add basic posix timers selftests
posix_cpu_timers: consolidate expired timers check
posix_cpu_timers: consolidate timer list cleanups
posix_cpu_timer: consolidate expiry time type
tick: Sanitize broadcast control logic
tick: Prevent uncontrolled switch to oneshot mode
tick: Make oneshot broadcast robust vs. CPU offlining
x86: xen: Sync the CMOS RTC as well as the Xen wallclock
x86: xen: Sync the wallclock when the system time is set
timekeeping: Indicate that clock was set in the pvclock gtod notifier
timekeeping: Pass flags instead of multiple bools to timekeeping_update()
xen: Remove clock_was_set() call in the resume path
hrtimers: Support resuming with two or more CPUs online (but stopped)
timer: Fix jiffies wrap behavior of round_jiffies_common()
Pull trivial module and virtio fixes from Rusty Russell.
Apparently these were meant for 3.10, but came in after the release.
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
modpost.c: Add .text.unlikely to TEXT_SECTIONS
virtio: remove virtqueue_add_buf().
virtio_blk: Add missing 'static' qualifiers
virtio: console: Add emergency writeonly register to config space
virtio_pci: better macro exported in uapi
Reimplement FPU detection code in C and drop old, not-so-recommended
detection method in asm. Move all the relevant stuff into i387.c where
it conceptually belongs. Finally drop cpuinfo_x86.hard_math.
[ hpa: huge thanks to Borislav for taking my original concept patch
and productizing it ]
[ Boris, note to self: do not use static_cpu_has before alternatives! ]
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Link: http://lkml.kernel.org/r/1367244262-29511-2-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1365436666-9837-2-git-send-email-bp@alien8.de
All the virtualized platforms (KVM, lguest and Xen) have persistent
wallclocks that have more than one second of precision.
read_persistent_wallclock() and update_persistent_wallclock() allow
for nanosecond precision but their implementation on x86 with
x86_platform.get/set_wallclock() only allows for one second precision.
This means guests may see a wallclock time that is off by up to 1
second.
Make set_wallclock() and get_wallclock() take a struct timespec
parameter (which allows for nanosecond precision) so KVM and Xen
guests may start with a more accurate wallclock time and a Xen dom0
can maintain a more accurate wallclock for guests.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Since commit 9a163ed8e0 (i386: move kernel) kernel/i386_head.S
was renamed to kernel/head_32.S. We do the same for lguest/i386_head.S.
Signed-off-by: Daniel Baluta <dbaluta@ixiacom.com>
Pull x86 paravirt update from Ingo Molnar:
"Various paravirtualization related changes - the biggest one makes
guest support optional via CONFIG_HYPERVISOR_GUEST"
* 'x86-paravirt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, wakeup, sleep: Use pvops functions for changing GDT entries
x86, xen, gdt: Remove the pvops variant of store_gdt.
x86-32, gdt: Store/load GDT for ACPI S3 or hibernation/resume path is not needed
x86-64, gdt: Store/load GDT for ACPI S3 or hibernate/resume path is not needed.
x86: Make Linux guest support optional
x86, Kconfig: Move PARAVIRT_DEBUG into the paravirt menu
Invoking arch_flush_lazy_mmu_mode() results in calls to
preempt_enable()/disable() which may have performance impact.
Since lazy MMU is not used on bare metal we can patch away
arch_flush_lazy_mmu_mode() so that it is never called in such
environment.
[ hpa: the previous patch "Fix vmalloc_fault oops during lazy MMU
updates" may cause a minor performance regression on
bare metal. This patch resolves that performance regression. It is
somewhat unclear to me if this is a good -stable candidate. ]
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Link: http://lkml.kernel.org/r/1364045796-10720-2-git-send-email-konrad.wilk@oracle.com
Tested-by: Josh Boyer <jwboyer@redhat.com>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Borislav Petkov <bp@suse.de>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: <stable@vger.kernel.org> SEE NOTE ABOVE
Put all config options needed to run Linux as a guest behind a
CONFIG_HYPERVISOR_GUEST menu so that they don't get built-in by default
but be selectable by the user. Also, make all units which depend on
x86_hyper, depend on this new symbol so that compilation doesn't fail
when CONFIG_HYPERVISOR_GUEST is disabled but those units assume its
presence.
Sort options in the new HYPERVISOR_GUEST menu, adapt config text and
drop redundant select.
Link: http://lkml.kernel.org/r/1362428421-9244-3-git-send-email-bp@alien8.de
Cc: Dmitry Torokhov <dtor@vmware.com>
Cc: K. Y. Srinivasan <kys@microsoft.com>
Cc: Haiyang Zhang <haiyangz@microsoft.com>
Pull x86 mm changes from Peter Anvin:
"This is a huge set of several partly interrelated (and concurrently
developed) changes, which is why the branch history is messier than
one would like.
The *really* big items are two humonguous patchsets mostly developed
by Yinghai Lu at my request, which completely revamps the way we
create initial page tables. In particular, rather than estimating how
much memory we will need for page tables and then build them into that
memory -- a calculation that has shown to be incredibly fragile -- we
now build them (on 64 bits) with the aid of a "pseudo-linear mode" --
a #PF handler which creates temporary page tables on demand.
This has several advantages:
1. It makes it much easier to support things that need access to data
very early (a followon patchset uses this to load microcode way
early in the kernel startup).
2. It allows the kernel and all the kernel data objects to be invoked
from above the 4 GB limit. This allows kdump to work on very large
systems.
3. It greatly reduces the difference between Xen and native (Xen's
equivalent of the #PF handler are the temporary page tables created
by the domain builder), eliminating a bunch of fragile hooks.
The patch series also gets us a bit closer to W^X.
Additional work in this pull is the 64-bit get_user() work which you
were also involved with, and a bunch of cleanups/speedups to
__phys_addr()/__pa()."
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (105 commits)
x86, mm: Move reserving low memory later in initialization
x86, doc: Clarify the use of asm("%edx") in uaccess.h
x86, mm: Redesign get_user with a __builtin_choose_expr hack
x86: Be consistent with data size in getuser.S
x86, mm: Use a bitfield to mask nuisance get_user() warnings
x86/kvm: Fix compile warning in kvm_register_steal_time()
x86-32: Add support for 64bit get_user()
x86-32, mm: Remove reference to alloc_remap()
x86-32, mm: Remove reference to resume_map_numa_kva()
x86-32, mm: Rip out x86_32 NUMA remapping code
x86/numa: Use __pa_nodebug() instead
x86: Don't panic if can not alloc buffer for swiotlb
mm: Add alloc_bootmem_low_pages_nopanic()
x86, 64bit, mm: hibernate use generic mapping_init
x86, 64bit, mm: Mark data/bss/brk to nx
x86: Merge early kernel reserve for 32bit and 64bit
x86: Add Crash kernel low reservation
x86, kdump: Remove crashkernel range find limit for 64bit
memblock: Add memblock_mem_size()
x86, boot: Not need to check setup_header version for setup_data
Fix kconfig warning for LGUEST_GUEST config by selecting TTY:
warning: (KVMTOOL_TEST_ENABLE && LGUEST_GUEST) selects VIRTIO_CONSOLE which has unmet direct dependencies (VIRTIO && TTY)
Cc: Joe Millenbach <jmillenbach@gmail.com>
The __pa() fixup series that follows touches KVM code that is not
present in the existing branch based on v3.7-rc5, so merge in the
current upstream from Linus.
The function lguest_write_cr3 is using __pa to convert swapper_pg_dir and
initial_page_table from virtual addresses to physical. The correct function
to use for these values is __pa_symbol since they are C visible symbols.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Link: http://lkml.kernel.org/r/20121116215748.8521.83556.stgit@ahduyck-cp1.jf.intel.com
mce_ser, mce_bios_cmci_threshold and mce_disabled are the last three
bools which need conversion. Move them to the mca_config struct and
adjust usage sites accordingly.
Signed-off-by: Borislav Petkov <bp@alien8.de>
Acked-by: Tony Luck <tony.luck@intel.com>
Everyone who selects VIRTIO is also made to select VIRTIO_RING; just make
them synonymous, since we removed the indirection layer some time ago.
Make sure the interrupt is allocated correctly by lguest_setup_irq (check the
return value of irq_alloc_desc_at for -ENOMEM)
Signed-off-by: Stratos Psomadakis <psomas@cslab.ece.ntua.gr>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (cleanups and commentry)
We need this in advance of the module.h cleanup, or we'll
get compile errors like this:
CC drivers/lguest/lguest_device.o
drivers/lguest/lguest_device.c: In function ‘lguest_devices_init’:
drivers/lguest/lguest_device.c:490: error: ‘THIS_MODULE’ undeclared (first use in this function)
Host might be running under KVM, but we shouldn't allow Guest to think it
can use KVM hypercalls (it can't, and it will embarrass itself if it tries).
The comment is outdated, wikipedia now has six translations of the cpuid
page.
Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de>
This patch fixes three typos I've accidentally spotted.
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (one was already fixed)
Also removes a long-unused #define and an extraneous semicolon.
We switch back from using vmcall in 091ebf07a2408f9a56634caa0f86d9360e9af23b
because it was unreliable under kvm, but I missed one (rarely-used) place.
The Host used to create some page tables for the Guest to use at the
top of Guest memory; it would then tell the Guest where this was. In
particular, it created linear mappings for 0 and 0xC0000000 addresses
because lguest used to switch to its real page tables quite late in
boot.
However, since d50d8fe19 Linux initialized boot page tables in
head_32.S even before the "are we lguest?" boot jump. So, now we can
simplify things: the Host pagetable code assumes 1:1 linear mapping
until it first calls the LHCALL_NEW_PGTABLE hypercall, which we now do
before we reach C code.
This also means that the Host doesn't need to know anything about the
Guest's PAGE_OFFSET. (Non-Linux guests might not even have such a
thing).
Without an IRQ chip set, we now get a WARN_ON and no timer interrupt. This
prevents booting.
Fortunately, the fix is a one-liner: set up the timer IRQ like everything
else.
Cc: stable@kernel.org # .39.x
* 'timers-clocksource-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
clocksource: convert mips to generic i8253 clocksource
clocksource: convert x86 to generic i8253 clocksource
clocksource: convert footbridge to generic i8253 clocksource
clocksource: add common i8253 PIT clocksource
blackfin: convert to clocksource_register_hz
mips: convert to clocksource_register_hz/khz
sparc: convert to clocksource_register_hz/khz
alpha: convert to clocksource_register_hz
microblaze: convert to clocksource_register_hz/khz
ia64: convert to clocksource_register_hz/khz
x86: Convert remaining x86 clocksources to clocksource_register_hz/khz
Make clocksource name const
master.kernel.org:~rmk/linux-2.6-arm into timers/clocksource
arch/ia64/kernel/cyclone.c
arch/mips/kernel/i8253.c
arch/x86/kernel/i8253.c
Reason: Resolve conflicts so further cleanups do not conflict further
- Documentation/kvm/ to Documentation/virtual/kvm
- Documentation/uml/ to Documentation/virtual/uml
- Documentation/lguest/ to Documentation/virtual/lguest
throughout the kernel source tree.
Signed-off-by: Rob Landley <rob@landley.net>
They were generated by 'codespell' and then manually reviewed.
Cc: trivial@kernel.org
LKML-Reference: <1300389856-1099-3-git-send-email-lucas.demarchi@profusion.mobi>
genirq is switching to a consistent name space for the irq related
functions. Convert x86. Conversion was done with coccinelle.
This converts the remaining x86 clocksources to use
clocksource_register_hz/khz.
CC: jacob.jun.pan@intel.com
CC: Glauber Costa <glommer@redhat.com>
CC: Dimitri Sivanich <sivanich@sgi.com>
CC: Rusty Russell <rusty@rustcorp.com.au>
CC: Jeremy Fitzhardinge <jeremy@xensource.com>
CC: Chris McDermott <lcm@us.ibm.com>
CC: Thomas Gleixner <tglx@linutronix.de>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen]
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Honor the kconfig menu hierarchy to remove kconfig dependency warnings:
VIRTIO and VIRTIO_RING are subordinate to VIRTUALIZATION.
warning: (LGUEST_GUEST) selects VIRTIO which has unmet direct dependencies (VIRTUALIZATION)
warning: (LGUEST_GUEST && VIRTIO_PCI && VIRTIO_BALLOON) selects VIRTIO_RING which has unmet direct dependencies (VIRTUALIZATION && VIRTIO)
Reported-by: Toralf F_rster <toralf.foerster@gmx.de>
arch/x86/lguest/boot.c: In function ‘lguest_init_IRQ’:
arch/x86/lguest/boot.c:824: error: macro "__this_cpu_write" requires 2 arguments, but only 1 given
arch/x86/lguest/boot.c:824: error: ‘__this_cpu_write’ undeclared (first use in this function)
arch/x86/lguest/boot.c:824: error: (Each undeclared identifier is reported only once
arch/x86/lguest/boot.c:824: error: for each function it appears in.)
drivers/lguest/x86/core.c: In function ‘copy_in_guest_info’:
drivers/lguest/x86/core.c:94: error: lvalue required as left operand of assignment
