path: root/arch/x86/lib/delay_32.c
2007-11-14x86: disable preemption in delay_tsc()Andrew Morton
Marin Mitov points out that delay_tsc() can misbehave if it is preempted and rescheduled on a different CPU which has a skewed TSC. Fix it by disabling preemption. (I assume that the worst-case behaviour here is a stall of 2^32 cycles) Cc: Andi Kleen <ak@suse.de> Cc: Marin Mitov <mitov@issp.bas.bg> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19x86: convert cpuinfo_x86 array to a per_cpu arrayMike Travis
cpu_data is currently an array defined using NR_CPUS. This means that we overallocate since we will rarely really use maximum configured cpus. When NR_CPU count is raised to 4096 the size of cpu_data becomes 3,145,728 bytes. These changes were adopted from the sparc64 (and ia64) code. An additional field was added to cpuinfo_x86 to be a non-ambiguous cpu index. This corresponds to the index into a cpumask_t as well as the per_cpu index. It's used in various places like show_cpuinfo(). cpu_data is defined to be the boot_cpu_data structure for the NON-SMP case. Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-11i386: move libThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
