path: root/arch/x86/math-emu/fpu_entry.c
2010-05-10x86, fpu: Unbreak FPU emulationH. Peter Anvin
Unbreak FPU emulation, broken by checkin 86603283326c9e95e5ad4e9fdddeec93cac5d9ad: x86: Introduce 'struct fpu' and related API Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Avi Kivity <avi@redhat.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1273135546-29690-3-git-send-email-avi@redhat.com>
2009-02-10x86: fix math_emu register frame accessTejun Heo
do_device_not_available() is the handler for #NM and it declares that it takes a unsigned long and calls math_emu(), which takes a long argument and surprisingly expects the stack frame starting at the zero argument would match struct math_emu_info, which isn't true regardless of configuration in the current code. This patch makes do_device_not_available() take struct pt_regs like other exception handlers and initialize struct math_emu_info with pointer to it and pass pointer to the math_emu_info to math_emulate() like normal C functions do. This way, unless gcc makes a copy of struct pt_regs in do_device_not_available(), the register frame is correctly accessed regardless of kernel configuration or compiler used. This doesn't fix all math_emu problems but it at least gets it somewhat working. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-09x86: math_emu info cleanupTejun Heo
Impact: cleanup * Come on, struct info? s/struct info/struct math_emu_info/ * Use struct pt_regs and kernel_vm86_regs instead of defining its own register frame structure. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-04x86: fix broken math-emu with lazy allocation of fpu areaSuresh Siddha
Fix the math emulation that got broken with the recent lazy allocation of FPU area. init_fpu() need to be added for the math-emulation path aswell for the FPU area allocation. math emulation enabled kernel booted fine with this, in the presence of "no387 nofxsr" boot param. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: hpa@zytor.com Cc: mingo@elte.hu Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-19x86, fpu: split FPU state from task struct - v5Suresh Siddha
Split the FPU save area from the task struct. This allows easy migration of FPU context, and it's generally cleaner. It also allows the following two optimizations: 1) only allocate when the application actually uses FPU, so in the first lazy FPU trap. This could save memory for non-fpu using apps. Next patch does this lazy allocation. 2) allocate the right size for the actual cpu rather than 512 bytes always. Patches enabling xsave/xrstor support (coming shortly) will take advantage of this. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17i386: arch/x86/math-emu/fpu_entry.c warning fixAndrew Morton
arch/x86/math-emu/fpu_entry.c:555: warning: 'entry_sel_off.empty' is used uninitialized in this function Presumably it's harmless, but I'll sleep better at night knowing that we initialised it. Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: x86 user_regset cleanupRoland McGrath
This removes a bunch of dead code that is no longer needed now that the user_regset interfaces are being used for all these jobs. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: x86 user_regset math_emuRoland McGrath
This converts the ptrace/signal accessors for i387 math_emu state to the user_regset interface style, and calls these from the old interfaces. It also cleans up math_emulate's ptrace check to be a single-step check, which is what it really wants. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: lindent arch/i386/math-emu, cleanupIngo Molnar
manually clean up some of the damage that lindent caused. (this is a separate commit so that in the unlikely case of a typo we can bisect it down to the manual edits.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: lindent arch/i386/math-emuIngo Molnar
lindent these files: errors lines of code errors/KLOC arch/x86/math-emu/ 2236 9424 237.2 arch/x86/math-emu/ 128 8706 14.7 no other changes. No code changed: text data bss dec hex filename 5589802 612739 3833856 10036397 9924ad vmlinux.before 5589802 612739 3833856 10036397 9924ad vmlinux.after the intent of this patch is to ease the automated tracking of kernel code quality - it's just much easier for us to maintain it if every file in arch/x86 is supposed to be clean. NOTE: it is a known problem of lindent that it causes some style damage of its own, but it's a safe tool (well, except for the gcc array range initializers extension), so we did the bulk of the changes via lindent, and did the manual fixups in a followup patch. the resulting math-emu code has been tested by Thomas Gleixner on a real 386 DX CPU as well, and it works fine. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-11i386: move math-emuThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
