path: root/arch/x86/math-emu
2010-05-10x86, fpu: Unbreak FPU emulationH. Peter Anvin
Unbreak FPU emulation, broken by checkin 86603283326c9e95e5ad4e9fdddeec93cac5d9ad: x86: Introduce 'struct fpu' and related API Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Avi Kivity <avi@redhat.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1273135546-29690-3-git-send-email-avi@redhat.com>
2010-05-10x86: Introduce 'struct fpu' and related APIAvi Kivity
Currently all fpu state access is through tsk->thread.xstate. Since we wish to generalize fpu access to non-task contexts, wrap the state in a new 'struct fpu' and convert existing access to use an fpu API. Signal frame handlers are not converted to the API since they will remain task context only things. Signed-off-by: Avi Kivity <avi@redhat.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1273135546-29690-3-git-send-email-avi@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-04x86, math-emu: fix init_fpu for task != currentDaniel Glöckner
Impact: fix math-emu related crash while using GDB/ptrace init_fpu() calls finit to initialize a task's xstate, while finit always works on the current task. If we use PTRACE_GETFPREGS on another process and both processes did not already use floating point, we get a null pointer exception in finit. This patch creates a new function finit_task that takes a task_struct parameter. finit becomes a wrapper that simply calls finit_task with current. On the plus side this avoids many calls to get_current which would each resolve to an inline assembler mov instruction. An empty finit_task has been added to i387.h to avoid linker errors in case the compiler still emits the call in init_fpu when CONFIG_MATH_EMULATION is not defined. The declaration of finit in i387.h has been removed as the remaining code using this function gets its prototype from fpu_proto.h. Signed-off-by: Daniel Glöckner <dg@emlix.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Pallipadi Venkatesh" <venkatesh.pallipadi@intel.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Bill Metzenthen <billm@melbpc.org.au> LKML-Reference: <E1Lew31-0004il-Fg@mailer.emlix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-10x86: add %gs accessors for x86_32Tejun Heo
Impact: cleanup On x86_32, %gs is handled lazily. It's not saved and restored on kernel entry/exit but only when necessary which usually is during task switch but there are few other places. Currently, it's done by calling savesegment() and loadsegment() explicitly. Define get_user_gs(), set_user_gs() and task_user_gs() and use them instead. While at it, clean up register access macros in signal.c. This cleans up code a bit and will help future changes. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-10x86: fix math_emu register frame accessTejun Heo
do_device_not_available() is the handler for #NM and it declares that it takes a unsigned long and calls math_emu(), which takes a long argument and surprisingly expects the stack frame starting at the zero argument would match struct math_emu_info, which isn't true regardless of configuration in the current code. This patch makes do_device_not_available() take struct pt_regs like other exception handlers and initialize struct math_emu_info with pointer to it and pass pointer to the math_emu_info to math_emulate() like normal C functions do. This way, unless gcc makes a copy of struct pt_regs in do_device_not_available(), the register frame is correctly accessed regardless of kernel configuration or compiler used. This doesn't fix all math_emu problems but it at least gets it somewhat working. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-09x86: math_emu info cleanupTejun Heo
Impact: cleanup * Come on, struct info? s/struct info/struct math_emu_info/ * Use struct pt_regs and kernel_vm86_regs instead of defining its own register frame structure. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-18x86: coding style fixes to arch/x86/math-emu/reg_constantPaolo Ciarrocchi
Before: total: 6 errors, 1 warnings, 117 lines checked After: total: 0 errors, 1 warnings, 117 lines checked paolo@paolo-desktop:~/linux.trees.git$ md5sum /tmp/reg_constant.o.* 780388a3056d58fb759efaf190d5d3d1 /tmp/reg_constant.o.after 780388a3056d58fb759efaf190d5d3d1 /tmp/reg_constant.o.before paolo@paolo-desktop:~/linux.trees.git$ size /tmp/reg_constant.o.* text data bss dec hex filename 457 0 0 457 1c9 /tmp/reg_constant.o.after 457 0 0 457 1c9 /tmp/reg_constant.o.before Signed-off-by: Paolo Ciarrocchi <paolo.ciarrocchi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-04x86: fix broken math-emu with lazy allocation of fpu areaSuresh Siddha
Fix the math emulation that got broken with the recent lazy allocation of FPU area. init_fpu() need to be added for the math-emulation path aswell for the FPU area allocation. math emulation enabled kernel booted fine with this, in the presence of "no387 nofxsr" boot param. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: hpa@zytor.com Cc: mingo@elte.hu Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-19x86, fpu: split FPU state from task struct - v5Suresh Siddha
Split the FPU save area from the task struct. This allows easy migration of FPU context, and it's generally cleaner. It also allows the following two optimizations: 1) only allocate when the application actually uses FPU, so in the first lazy FPU trap. This could save memory for non-fpu using apps. Next patch does this lazy allocation. 2) allocate the right size for the actual cpu rather than 512 bytes always. Patches enabling xsave/xrstor support (coming shortly) will take advantage of this. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17i386: arch/x86/math-emu/reg_ld_str.c: fix warningAndrew Morton
arch/x86/math-emu/reg_ld_str.c:380: warning: 'l[0]' may be used uninitialized in this function arch/x86/math-emu/reg_ld_str.c:380: warning: 'l[1]' may be used uninitialized in this function I can't actually spot the bug here. There's one obvious place, but fixing that didn't shut the warning up. Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17i386: arch/x86/math-emu/fpu_entry.c warning fixAndrew Morton
arch/x86/math-emu/fpu_entry.c:555: warning: 'entry_sel_off.empty' is used uninitialized in this function Presumably it's harmless, but I'll sleep better at night knowing that we initialised it. Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: arch/x86/math-emu/errors.c: fix printk warningsAndrew Morton
arch/x86/math-emu/errors.c:163: warning: format '%ld' expects type 'long int', but argument 3 has type 'u32' arch/x86/math-emu/errors.c:175: warning: format '%ld' expects type 'long int', but argument 3 has type 'u32' arch/x86/math-emu/errors.c:175: warning: format '%ld' expects type 'long int', but argument 4 has type 'u32' arch/x86/math-emu/errors.c:175: warning: format '%ld' expects type 'long int', but argument 5 has type 'u32' arch/x86/math-emu/errors.c:175: warning: format '%ld' expects type 'long int', but argument 6 has type 'u32' Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: x86 user_regset cleanupRoland McGrath
This removes a bunch of dead code that is no longer needed now that the user_regset interfaces are being used for all these jobs. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: x86 user_regset math_emuRoland McGrath
This converts the ptrace/signal accessors for i387 math_emu state to the user_regset interface style, and calls these from the old interfaces. It also cleans up math_emulate's ptrace check to be a single-step check, which is what it really wants. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: lindent arch/i386/math-emu, cleanupIngo Molnar
manually clean up some of the damage that lindent caused. (this is a separate commit so that in the unlikely case of a typo we can bisect it down to the manual edits.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: lindent arch/i386/math-emuIngo Molnar
lindent these files: errors lines of code errors/KLOC arch/x86/math-emu/ 2236 9424 237.2 arch/x86/math-emu/ 128 8706 14.7 no other changes. No code changed: text data bss dec hex filename 5589802 612739 3833856 10036397 9924ad vmlinux.before 5589802 612739 3833856 10036397 9924ad vmlinux.after the intent of this patch is to ease the automated tracking of kernel code quality - it's just much easier for us to maintain it if every file in arch/x86 is supposed to be clean. NOTE: it is a known problem of lindent that it causes some style damage of its own, but it's a safe tool (well, except for the gcc array range initializers extension), so we did the bulk of the changes via lindent, and did the manual fixups in a followup patch. the resulting math-emu code has been tested by Thomas Gleixner on a real 386 DX CPU as well, and it works fine. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-14kbuild: fix up CFLAGS usageSam Ravnborg
Only in very rare cases is it needed to change CFLAGS outside of arch/*/Makefile. Fix up all wrong cases - in most cases the use of EXTRA_CFLAGS is the only thing needed. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-11i386: move math-emuThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
