Ingo suggested SIGKILL check should be moved into slowpath
function. This will reduce the page fault fastpath impact
of this recent commit:
37b23e0525d3: x86,mm: make pagefault killable
Suggested-by: Ingo Molnar <mingo@elte.hu>
Cc: kamezawa.hiroyu@jp.fujitsu.com
Cc: minchan.kim@gmail.com
Cc: willy@linux.intel.com
Link: http://lkml.kernel.org/r/4DDE0B5C.9050907@jp.fujitsu.com
When an oom killing occurs, almost all processes are getting stuck at the
following two points.
1) __alloc_pages_nodemask
2) __lock_page_or_retry
1) is not very problematic because TIF_MEMDIE leads to an allocation
failure and getting out from page allocator.
2) is more problematic. In an OOM situation, zones typically don't have
page cache at all and memory starvation might lead to greatly reduced IO
performance. When a fork bomb occurs, TIF_MEMDIE tasks don't die quickly,
meaning that a fork bomb may create new process quickly rather than the
oom-killer killing it. Then, the system may become livelocked.
This patch makes the pagefault interruptible by SIGKILL.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Matthew Wilcox <willy@linux.intel.com>
Commit e66eed651fd1 ("list: remove prefetching from regular list
iterators") removed the include of prefetch.h from list.h, which
uncovered several cases that had apparently relied on that rather
obscure header file dependency.
So this fixes things up a bit, using
grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]')
grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]')
to guide us in finding files that either need <linux/prefetch.h>
inclusion, or have it despite not needing it.
There are more of them around (mostly network drivers), but this gets
many core ones.
It's forbidden to take the page_table_lock with the irq disabled
or if there's contention the IPIs (for tlb flushes) sent with
the page_table_lock held will never run leading to a deadlock.
Nobody takes the pgd_lock from irq context so the _irqsave can be
removed.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: <stable@kernel.org>
LKML-Reference: <201102162345.p1GNjMjm021738@imap1.linux-foundation.org>
mm_fault_error() should not execute oom-killer, if page fault
occurs in kernel space. E.g. in copy_from_user()/copy_to_user().
This would happen if we find ourselves in OOM on a
copy_to_user(), or a copy_from_user() which faults.
Without this patch, the kernels hangs up in copy_from_user(),
because OOM killer sends SIG_KILL to current process, but it
can't handle a signal while in syscall, then the kernel returns
to copy_from_user(), reexcute current command and provokes
page_fault again.
With this patch the kernel return -EFAULT from copy_from_user().
The code, which checks that page fault occurred in kernel space,
has been copied from do_sigbus().
This situation is handled by the same way on powerpc, xtensa,
tile, ...
Signed-off-by: Andrey Vagin <avagin@openvz.org>
LKML-Reference: <201103092322.p29NMNPH001682@imap1.linux-foundation.org>
access_error() already takes error_code as an argument, so there is
no need for an additional write flag.
Signed-off-by: Michel Lespinasse <walken@google.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Ying Han <yinghan@google.com>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
This change reduces mmap_sem hold times that are caused by waiting for
disk transfers when accessing file mapped VMAs.
It introduces the VM_FAULT_ALLOW_RETRY flag, which indicates that the call
site wants mmap_sem to be released if blocking on a pending disk transfer.
In that case, filemap_fault() returns the VM_FAULT_RETRY status bit and
do_page_fault() will then re-acquire mmap_sem and retry the page fault.
It is expected that the retry will hit the same page which will now be
cached, and thus it will complete with a low mmap_sem hold time.
Tests:
- microbenchmark: thread A mmaps a large file and does random read accesses
to the mmaped area - achieves about 55 iterations/s. Thread B does
mmap/munmap in a loop at a separate location - achieves 55 iterations/s
before, 15000 iterations/s after.
- We are seeing related effects in some applications in house, which show
significant performance regressions when running without this change.
[akpm@linux-foundation.org: fix warning & crash]
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: <linux-arch@vger.kernel.org>
mm/memory-failure.c
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86-32, percpu: Correct the ordering of the percpu readmostly section
x86, mm: Enable ARCH_DMA_ADDR_T_64BIT with X86_64 || HIGHMEM64G
x86: Spread tlb flush vector between nodes
percpu: Introduce a read-mostly percpu API
x86, mm: Fix incorrect data type in vmalloc_sync_all()
x86, mm: Hold mm->page_table_lock while doing vmalloc_sync
x86, mm: Fix bogus whitespace in sync_global_pgds()
x86-32: Fix sparse warning for the __PHYSICAL_MASK calculation
x86, mm: Add RESERVE_BRK_ARRAY() helper
mm, x86: Saving vmcore with non-lazy freeing of vmas
x86, kdump: Change copy_oldmem_page() to use cached addressing
x86, mm: fix uninitialized addr in kernel_physical_mapping_init()
x86, kmemcheck: Remove double test
x86, mm: Make spurious_fault check explicitly check the PRESENT bit
x86-64, mem: Update all PGDs for direct mapping and vmemmap mapping changes
x86, mm: Separate x86_64 vmalloc_sync_all() into separate functions
x86, mm: Avoid unnecessary TLB flush
arch/x86/mm/fault.c: In function 'vmalloc_sync_all':
arch/x86/mm/fault.c:238: warning: assignment makes integer from pointer without a cast
introduced by 617d34d9e5d8326ec8f188c616aa06ac59d083fe.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
LKML-Reference: <20101020103642.GA3135@kryptos.osrc.amd.com>
Take mm->page_table_lock while syncing the vmalloc region. This prevents
a race with the Xen pagetable pin/unpin code, which expects that the
page_table_lock is already held. If this race occurs, then Xen can see
an inconsistent page type (a page can either be read/write or a pagetable
page, and pin/unpin converts it between them), which will cause either
the pin or the set_p[gm]d to fail; either will crash the kernel.
vmalloc_sync_all() should be called rarely, so this extra use of
page_table_lock should not interfere with its normal users.
The mm pointer is stashed in the pgd page's index field, as that won't
be otherwise used for pgds.
Reported-by: Ian Campbell <ian.cambell@eu.citrix.com>
Originally-by: Jan Beulich <jbeulich@novell.com>
LKML-Reference: <4CB88A4C.1080305@goop.org>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
In x86, faults exit by executing the iret instruction, which then
reenables NMIs if we faulted in NMI context. Then if a fault
happens in NMI, another NMI can nest after the fault exits.
But we don't yet support nested NMIs because we have only one NMI
stack. To prevent from that, check that vmalloc and kmemcheck
faults don't happen in this context. Most of the other kernel faults
in NMIs can be more easily spotted by finding explicit
copy_from,to_user() calls on review.
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
An earlier patch fixed the hwpoison fault handling to encode the
huge page size in the fault code of the page fault handler.
This is needed to report this information in SIGBUS to user space.
This is a straight forward patch to pass this information
through to the signal handling in the x86 specific fault.c
Cc: x86@kernel.org
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: fengguang.wu@intel.com
pte_present() returns true even present bit isn't set but _PAGE_PROTNONE
(global bit) bit is set. While with CONFIG_DEBUG_PAGEALLOC, free pages have
global bit set but present bit clear. This patch makes we could catch
free pages access with CONFIG_DEBUG_PAGEALLOC enabled.
[ hpa: added a comment in the code as a warning to janitors ]
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
LKML-Reference: <1280217988.32400.75.camel@sli10-desk.sh.intel.com>
No behavior change.
Move some of vmalloc_sync_all() code into a new function
sync_global_pgds() that will be useful for memory hotplug.
Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com>
LKML-Reference: <4C6E4ECD.1090607@linux.intel.com>
Reviewed-by: Andi Kleen <ak@linux.intel.com>
It's wrong for several reasons, but the most direct one is that the
fault may be for the stack accesses to set up a previous SIGBUS. When
we have a kernel exception, the kernel exception handler does all the
fixups, not some user-level signal handler.
Even apart from the nested SIGBUS issue, it's also wrong to give out
kernel fault addresses in the signal handler info block, or to send a
SIGBUS when a system call already returns EFAULT.
* 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Limit number of per cpu TSC sync messages
x86: dumpstack, 64-bit: Disable preemption when walking the IRQ/exception stacks
x86: dumpstack: Clean up the x86_stack_ids[][] initalization and other details
x86, cpu: mv display_cacheinfo -> cpu_detect_cache_sizes
x86: Suppress stack overrun message for init_task
x86: Fix cpu_devs[] initialization in early_cpu_init()
x86: Remove CPU cache size output for non-Intel too
x86: Minimise printk spew from per-vendor init code
x86: Remove the CPU cache size printk's
cpumask: Avoid cpumask_t in arch/x86/kernel/apic/nmi.c
x86: Make sure we also print a Code: line for show_regs()
init_task doesn't get its stack end location set to
STACK_END_MAGIC, and hence the message is confusing
rather than helpful in this case.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
LKML-Reference: <4B06AEFE02000078000211F4@vpn.id2.novell.com>
kernel/trace/trace_event_profile.c
Merge reason: update to -rc5 and resolve conflict.
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits)
HWPOISON: Enable error_remove_page on btrfs
HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs
HWPOISON: Add madvise() based injector for hardware poisoned pages v4
HWPOISON: Enable error_remove_page for NFS
HWPOISON: Enable .remove_error_page for migration aware file systems
HWPOISON: The high level memory error handler in the VM v7
HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process
HWPOISON: shmem: call set_page_dirty() with locked page
HWPOISON: Define a new error_remove_page address space op for async truncation
HWPOISON: Add invalidate_inode_page
HWPOISON: Refactor truncate to allow direct truncating of page v2
HWPOISON: check and isolate corrupted free pages v2
HWPOISON: Handle hardware poisoned pages in try_to_unmap
HWPOISON: Use bitmask/action code for try_to_unmap behaviour
HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2
HWPOISON: Add poison check to page fault handling
HWPOISON: Add basic support for poisoned pages in fault handler v3
HWPOISON: Add new SIGBUS error codes for hardware poison signals
HWPOISON: Add support for poison swap entries v2
HWPOISON: Export some rmap vma locking to outside world
kernel/trace/Makefile
kernel/trace/trace.h
kernel/trace/trace_event_types.h
kernel/trace/trace_export.c
Merge reason:
Sync with latest significant tracing core changes.
Bye-bye Performance Counters, welcome Performance Events!
In the past few months the perfcounters subsystem has grown out its
initial role of counting hardware events, and has become (and is
becoming) a much broader generic event enumeration, reporting, logging,
monitoring, analysis facility.
Naming its core object 'perf_counter' and naming the subsystem
'perfcounters' has become more and more of a misnomer. With pending
code like hw-breakpoints support the 'counter' name is less and
less appropriate.
All in one, we've decided to rename the subsystem to 'performance
events' and to propagate this rename through all fields, variables
and API names. (in an ABI compatible fashion)
The word 'event' is also a bit shorter than 'counter' - which makes
it slightly more convenient to write/handle as well.
Thanks goes to Stephane Eranian who first observed this misnomer and
suggested a rename.
User-space tooling and ABI compatibility is not affected - this patch
should be function-invariant. (Also, defconfigs were not touched to
keep the size down.)
This patch has been generated via the following script:
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/PERF_EVENT_/PERF_RECORD_/g' \
-e 's/PERF_COUNTER/PERF_EVENT/g' \
-e 's/perf_counter/perf_event/g' \
-e 's/nb_counters/nb_events/g' \
-e 's/swcounter/swevent/g' \
-e 's/tpcounter_event/tp_event/g' \
$FILES
for N in $(find . -name perf_counter.[ch]); do
M=$(echo $N | sed 's/perf_counter/perf_event/g')
mv $N $M
done
FILES=$(find . -name perf_event.*)
sed -i \
-e 's/COUNTER_MASK/REG_MASK/g' \
-e 's/COUNTER/EVENT/g' \
-e 's/\<event\>/event_id/g' \
-e 's/counter/event/g' \
-e 's/Counter/Event/g' \
$FILES
... to keep it as correct as possible. This script can also be
used by anyone who has pending perfcounters patches - it converts
a Linux kernel tree over to the new naming. We tried to time this
change to the point in time where the amount of pending patches
is the smallest: the end of the merge window.
Namespace clashes were fixed up in a preparatory patch - and some
stylistic fallout will be fixed up in a subsequent patch.
( NOTE: 'counters' are still the proper terminology when we deal
with hardware registers - and these sed scripts are a bit
over-eager in renaming them. I've undone some of that, but
in case there's something left where 'counter' would be
better than 'event' we can undo that on an individual basis
instead of touching an otherwise nicely automated patch. )
Suggested-by: Stephane Eranian <eranian@google.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Acked-by: Paul Mackerras <paulus@samba.org>
Reviewed-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
LKML-Reference: <new-submission>
Add VM_FAULT_HWPOISON handling to the x86 page fault handler. This is
very similar to VM_FAULT_OOM, the only difference is that a different
si_code is passed to user space and the new addr_lsb field is initialized.
v2: Make the printk more verbose/unique
Cc: x86@kernel.org
x86, highmem_32.c: Clean up comment
x86, pgtable.h: Clean up types
x86: Clean up dump_pagetable()
Add __kprobes to the functions which handle in-kernel fixable page
faults. Since kprobes can cause those in-kernel page faults by accessing
kprobe data structures, probing those fault functions will cause
fault-int3-loop (do_page_fault has already been marked as __kprobes).
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
LKML-Reference: <20090827172311.8246.92725.stgit@localhost.localdomain>
Since commit 5fd29d6c ("printk: clean up handling of log-levels
and newlines"), the kernel logs segfaults like:
<6>gnome-power-man[24509]: segfault at 20 ip 00007f9d4950465a sp 00007fffbb50fc70 error 4 in libgobject-2.0.so.0.2103.0[7f9d494f7000+45000]
with the extra "<6>" being KERN_INFO. This happens because the
printk in show_signal_msg() started with KERN_CONT and then
used "%s" to pass in the real level; and KERN_CONT is no longer
an empty string, and printk only pays attention to the level at
the very beginning of the format string.
Therefore, remove the KERN_CONT from this printk, since it is
now actively causing problems (and never really made any
sense).
Signed-off-by: Roland Dreier <roland@digitalvampire.org>
LKML-Reference: <874otjitkj.fsf@shaolin.home.digitalvampire.org>
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up
handling of log-levels and newlines") changed printk semantics. printk
lines with multiple KERN_<level> prefixes are no longer emitted as
before the patch.
<level> is now included in the output on each additional use.
Remove all uses of multiple KERN_<level>s in formats.
Use pgtable access helpers for 32-bit version dump_pagetable()
and get rid of __typeof__() operators. This needs to make
pmd_pfn() available for 2-level pgtable.
Also, remove some casts for 64-bit version dump_pagetable().
LKML-Reference: <20090627063514.GA2834@localhost.localdomain>
This allows the callers to now pass down the full set of FAULT_FLAG_xyz
flags to handle_mm_fault(). All callers have been (mechanically)
converted to the new calling convention, there's almost certainly room
for architectures to clean up their code and then add FAULT_FLAG_RETRY
when that support is added.
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (45 commits)
x86, mce: fix error path in mce_create_device()
x86: use zalloc_cpumask_var for mce_dev_initialized
x86: fix duplicated sysfs attribute
x86: de-assembler-ize asm/desc.h
i386: fix/simplify espfix stack switching, move it into assembly
i386: fix return to 16-bit stack from NMI handler
x86, ioapic: Don't call disconnect_bsp_APIC if no APIC present
x86: Remove duplicated #include's
x86: msr.h linux/types.h is only required for __KERNEL__
x86: nmi: Add Intel processor 0x6f4 to NMI perfctr1 workaround
x86, mce: mce_intel.c needs <asm/apic.h>
x86: apic/io_apic.c: dmar_msi_type should be static
x86, io_apic.c: Work around compiler warning
x86: mce: Don't touch THERMAL_APIC_VECTOR if no active APIC present
x86: mce: Handle banks == 0 case in K7 quirk
x86, boot: use .code16gcc instead of .code16
x86: correct the conversion of EFI memory types
x86: cap iomem_resource to addressable physical memory
x86, mce: rename _64.c files which are no longer 64-bit-specific
x86, mce: mce.h cleanup
Manually fix up trivial conflict in arch/x86/mm/fault.c
Prefetch instructions can generate spurious faults on certain
models of older CPUs. The faults themselves cannot be stopped
and they can occur pretty much anywhere - so the way we solve
them is that we detect certain patterns and ignore the fault.
There is one small path of code where we must not take faults
though: the #PF handler execution leading up to the reading
of the CR2 (the faulting address). If we take a fault there
then we destroy the CR2 value (with that of the prefetching
instruction's) and possibly mishandle user-space or
kernel-space pagefaults.
It turns out that in current upstream we do exactly that:
prefetchw(&mm->mmap_sem);
/* Get the faulting address: */
address = read_cr2();
This is not good.
So turn around the order: first read the cr2 then prefetch
the lock address. Reading cr2 is plenty fast (2 cycles) so
delaying the prefetch by this amount shouldnt be a big issue
performance-wise.
[ And this might explain a mystery fault.c warning that sometimes
occurs on one an old AMD/Semptron based test-system i have -
which does have such prefetch problems. ]
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Vegard Nossum <vegard.nossum@gmail.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
LKML-Reference: <20090616030522.GA22162@Krystal>
The hooks that we modify are:
- Page fault handler (to handle kmemcheck faults)
- Debug exception handler (to hide pages after single-stepping
the instruction that caused the page fault)
Also redefine memset() to use the optimized version if kmemcheck is
enabled.
(Thanks to Pekka Enberg for minimizing the impact on the page fault
handler.)
As kmemcheck doesn't handle MMX/SSE instructions (yet), we also disable
the optimized xor code, and rely instead on the generic C implementation
in order to avoid false-positive warnings.
Signed-off-by: Vegard Nossum <vegardno@ifi.uio.no>
[whitespace fixlet]
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
[rebased for mainline inclusion]
arch/x86/kernel/irqinit.c
arch/x86/kernel/irqinit_64.c
arch/x86/kernel/traps.c
arch/x86/mm/fault.c
include/linux/sched.h
kernel/exit.c
Pure renames only, to PERF_COUNT_HW_* and PERF_COUNT_SW_*.
* 'x86-xen-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (42 commits)
xen: cache cr0 value to avoid trap'n'emulate for read_cr0
xen/x86-64: clean up warnings about IST-using traps
xen/x86-64: fix breakpoints and hardware watchpoints
xen: reserve Xen start_info rather than e820 reserving
xen: add FIX_TEXT_POKE to fixmap
lguest: update lazy mmu changes to match lguest's use of kvm hypercalls
xen: honour VCPU availability on boot
xen: add "capabilities" file
xen: drop kexec bits from /sys/hypervisor since kexec isn't implemented yet
xen/sys/hypervisor: change writable_pt to features
xen: add /sys/hypervisor support
xen/xenbus: export xenbus_dev_changed
xen: use device model for suspending xenbus devices
xen: remove suspend_cancel hook
xen/dev-evtchn: clean up locking in evtchn
xen: export ioctl headers to userspace
xen: add /dev/xen/evtchn driver
xen: add irq_from_evtchn
xen: clean up gate trap/interrupt constants
xen: set _PAGE_NX in __supported_pte_mask before pagetable construction
Andrew pointed out that the 'once' variable has a needlessly
function-global scope. We can in fact eliminate it completely,
via the use of printk_once().
[ Impact: cleanup ]
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Paul suggested we allow for data addresses to be recorded along with
the traditional IPs as power can provide these.
For now, only the software pagefault events provide data addresses,
but in the future power might as well for some events.
x86 doesn't seem capable of providing this atm.
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
LKML-Reference: <20090408130409.394816925@chello.nl>
Provide separate sw counters for major and minor page faults.
We use the generic software counter infrastructure to provide
page fault events.
Impact: cleanup
Eliminate more than 20 unnecessary #include lines in fault.c
Also fix include file dependency bug in asm/traps.h. (this was
masked before, by implicit inclusion)
LKML-Reference: <tip-56aea8468746e673a4bf50b6a13d97b2d1cbe1e8@git.kernel.org>
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
Impact: simplification, robustness
Make paravirt_lazy_mode() always return PARAVIRT_LAZY_NONE
when in an interrupt. This prevents interrupt code from
accidentally inheriting an outer lazy state, and instead
does everything synchronously. Outer batched operations
are left deferred.
Clarify the kmmio_fault() comment.
Acked-by: Pekka Paalanen <pq@iki.fi>
Impact: extend prefetch handling on 64-bit
Currently there's an extra is_prefetch() check done in do_sigbus(),
which we only do on 32 bits.
This is a last-ditch check before we terminate a task, so it's worth
giving prefetch instructions another chance - should none of our
existing quirks have caught a prefetch instruction related spurious
fault.
The only risk is if a prefetch causes a real sigbus, in that case
we'll not OOM but try another fault. But this code has been on
32-bit for a long time, so it should be fine in practice.
So do this on 64-bit too - and thus remove one more #ifdef.
Impact: cleanup
Removal of an #ifdef in fault_in_kernel_space(), by making
use of the new TASK_SIZE_MAX symbol which is now available
on 32-bit too.
Impact: cleanup
Rename TASK_SIZE64 to TASK_SIZE_MAX, and provide the
define on 32-bit too. (mapped to TASK_SIZE)
This allows 32-bit code to make use of the (former-) TASK_SIZE64
symbol as well, in a clean way.
Impact: cleanup
do_page_fault() has this ugly #ifdef in its prototype:
#ifdef CONFIG_X86_64
asmlinkage
#endif
void __kprobes do_page_fault(struct pt_regs *regs, unsigned long error_code)
Replace it with 'dotraplinkage' which maps to exactly the above
construct: nothing on 32-bit and asmlinkage on 64-bit.
Impact: add oops-recursion check to 32-bit
Unify the oops state-machine, to the 64-bit version. It is
slightly more careful in that it does a recursion check
in oops_begin(), and is thus more likely to show the relevant
oops.
It also means that 32-bit will print one more line at the
end of pagefault triggered oopses:
printk(KERN_EMERG "CR2: %016lx\n", address);
Which is generally good information to be seen in partial-dump
digital-camera jpegs ;-)
The downside is the somewhat more complex critical path. Both
variants have been tested well meanwhile by kernel developers
crashing their boxes so i dont think this is a practical worry.
This removes 3 ugly #ifdefs from no_context() and makes the
function a lot nicer read.
Impact: refine/extend page fault related oops printing on 64-bit
- honor the pause_on_oops logic on 64-bit too
- print out NX fault warnings on 64-bit as well
- factor out the NX fault message to make it git-greppable and readable
Note that this means that we do the PF_INSTR check on 32-bit non-PAE
as well where it should not occur ... normally. Cannot hurt.
Impact: cleanup
Avoid a couple more #ifdefs by moving fundamentally non-unifiable
functions into a single #ifdef 32-bit / #else / #endif block in
fault.c: vmalloc*(), dump_pagetable(), check_vm8086_mode().
No code changed:
4618 32 24 4674 1242 fault.o.before
4618 32 24 4674 1242 fault.o.after
