the handler
Introduce faulthandler_disabled() and use it to check for irq context and
disabled pagefaults (via pagefault_disable()) in the pagefault handlers.
Please note that we keep the in_atomic() checks in place - to detect
whether in irq context (in which case preemption is always properly
disabled).
In contrast, preempt_disable() should never be used to disable pagefaults.
With !CONFIG_PREEMPT_COUNT, preempt_disable() doesn't modify the preempt
counter, and therefore the result of in_atomic() differs.
We validate that condition by using might_fault() checks when calling
might_sleep().
Therefore, add a comment to faulthandler_disabled(), describing why this
is needed.
faulthandler_disabled() and pagefault_disable() are defined in
linux/uaccess.h, so let's properly add that include to all relevant files.
This patch is based on a patch from Thomas Gleixner.
Reviewed-and-tested-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Cc: David.Laight@ACULAB.COM
Cc: airlied@linux.ie
Cc: akpm@linux-foundation.org
Cc: benh@kernel.crashing.org
Cc: bigeasy@linutronix.de
Cc: borntraeger@de.ibm.com
Cc: daniel.vetter@intel.com
Cc: heiko.carstens@de.ibm.com
Cc: herbert@gondor.apana.org.au
Cc: hocko@suse.cz
Cc: hughd@google.com
Cc: mst@redhat.com
Cc: paulus@samba.org
Cc: ralf@linux-mips.org
Cc: schwidefsky@de.ibm.com
Cc: yang.shi@windriver.com
Link: http://lkml.kernel.org/r/1431359540-32227-7-git-send-email-dahi@linux.vnet.ibm.com
user_mode_vm() and user_mode() are now the same. Change all callers
of user_mode_vm() to user_mode().
The next patch will remove the definition of user_mode_vm.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brad Spengler <spender@grsecurity.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/43b1f57f3df70df5a08b0925897c660725015554.1426728647.git.luto@kernel.org
[ Merged to a more recent kernel. ]
This is slightly shorter and slightly faster. It's also more
correct: the split between user and kernel addresses is
TASK_SIZE_MAX, regardless of ti->flags.
Link: http://lkml.kernel.org/r/09156b63bad90a327827003c9e53faa82ef4c56e.1426728647.git.luto@kernel.org
Context switches and TLB flushes can change individual bits of CR4.
CR4 reads take several cycles, so store a shadow copy of CR4 in a
per-cpu variable.
To avoid wasting a cache line, I added the CR4 shadow to
cpu_tlbstate, which is already touched in switch_mm. The heaviest
users of the cr4 shadow will be switch_mm and __switch_to_xtra, and
__switch_to_xtra is called shortly after switch_mm during context
switch, so the cacheline is likely to be hot.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Cc: Vince Weaver <vince@deater.net>
Cc: "hillf.zj" <hillf.zj@alibaba-inc.com>
Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/3a54dd3353fffbf84804398e00dfdc5b7c1afd7d.1414190806.git.luto@amacapital.net
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
Cc: stable@vger.kernel.org
My commit 26178ec11ef3 ("x86: mm: consolidate VM_FAULT_RETRY handling")
had a really stupid typo: the FAULT_FLAG_USER bit is in the 'flags'
variable, not the 'fault' variable. Duh,
The one silver lining in this is that Dave finding this at least
confirms that trinity actually triggers this special path easily, in a
way normal use does not.
Reported-by: Dave Jones <davej@redhat.com>
The VM_FAULT_RETRY handling was confusing and incorrect for the case of
returning to kernel mode. We need to handle the exception table fixup
if we return to kernel mode due to a fatal signal - it will basically
look to the kernel user mode access like the access failed due to the VM
going away from udner it. Which is correct - the process is dying - and
avoids the whole "repeat endless kernel page faults" case.
Handling the VM_FAULT_RETRY early and in just one place also simplifies
the mmap_sem handling, since once we've taken care of VM_FAULT_RETRY we
know that we can just drop the lock. The remaining accounting and
possible error handling is thread-local and does not need the mmap_sem.
This replaces four copies in various stages of mm_fault_error() handling
with just a single one. It will also allow for more natural placement
of the unlocking after some further cleanup.
Pull x86 mm updates from Ingo Molnar:
"This tree includes the following changes:
- fix memory hotplug
- fix hibernation bootup memory layout assumptions
- fix hyperv numa guest kernel messages
- remove dead code
- update documentation"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mm: Update memory map description to list hypervisor-reserved area
x86/mm, hibernate: Do not assume the first e820 area to be RAM
x86/mm/numa: Drop dead code and rename setup_node_data() to setup_alloc_data()
x86/mm/hotplug: Modify PGD entry when removing memory
x86/mm/hotplug: Pass sync_global_pgds() a correct argument in remove_pagetable()
x86: Remove set_pmd_pfn
Pull scheduler updates from Ingo Molnar:
"The main changes in this cycle were:
- Optimized support for Intel "Cluster-on-Die" (CoD) topologies (Dave
Hansen)
- Various sched/idle refinements for better idle handling (Nicolas
Pitre, Daniel Lezcano, Chuansheng Liu, Vincent Guittot)
- sched/numa updates and optimizations (Rik van Riel)
- sysbench speedup (Vincent Guittot)
- capacity calculation cleanups/refactoring (Vincent Guittot)
- Various cleanups to thread group iteration (Oleg Nesterov)
- Double-rq-lock removal optimization and various refactorings
(Kirill Tkhai)
- various sched/deadline fixes
... and lots of other changes"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (72 commits)
sched/dl: Use dl_bw_of() under rcu_read_lock_sched()
sched/fair: Delete resched_cpu() from idle_balance()
sched, time: Fix build error with 64 bit cputime_t on 32 bit systems
sched: Improve sysbench performance by fixing spurious active migration
sched/x86: Fix up typo in topology detection
x86, sched: Add new topology for multi-NUMA-node CPUs
sched/rt: Use resched_curr() in task_tick_rt()
sched: Use rq->rd in sched_setaffinity() under RCU read lock
sched: cleanup: Rename 'out_unlock' to 'out_free_new_mask'
sched: Use dl_bw_of() under RCU read lock
sched/fair: Remove duplicate code from can_migrate_task()
sched, mips, ia64: Remove __ARCH_WANT_UNLOCKED_CTXSW
sched: print_rq(): Don't use tasklist_lock
sched: normalize_rt_tasks(): Don't use _irqsave for tasklist_lock, use task_rq_lock()
sched: Fix the task-group check in tg_has_rt_tasks()
sched/fair: Leverage the idle state info when choosing the "idlest" cpu
sched: Let the scheduler see CPU idle states
sched/deadline: Fix inter- exclusive cpusets migrations
sched/deadline: Clear dl_entity params when setscheduling to different class
sched/numa: Kill the wrong/dead TASK_DEAD check in task_numa_fault()
If a fault on a kernel address is due to a non-present page, then it
cannot be the result of stale TLB entry from a protection change (RO
to RW or NX to X). Thus the pagetable walk in spurious_fault() can be
skipped.
See the initial if in spurious_fault() and the tests in
spurious_fault_check()) for the set of possible error codes checked
for spurious faults. These are:
IRUWP
Before x00xx && ( 1xxxx || xxx1x )
After ( 10001 || 00011 ) && ( 1xxxx || xxx1x )
Thus the new condition is a subset of the previous one, excluding only
non-present faults (I == 1 and W == 1 are mutually exclusive).
This avoids spurious_fault() oopsing in some cases if the pagetables
it attempts to walk are not accessible. This obscures the location of
the original fault.
This also fixes a crash with Xen PV guests when they access entries in
the M2P corresponding to device MMIO regions. The M2P is mapped
(read-only) by Xen into the kernel address space of the guest and this
mapping may contains holes for non-RAM regions. Read faults will
result in calls to spurious_fault(), but because the page tables for
the M2P mappings are not accessible by the guest the pagetable walk
would fault.
This was not normally a problem as MMIO mappings would not normally
result in a M2P lookup because of the use of the _PAGE_IOMAP bit the
PTE. However, removing the _PAGE_IOMAP bit requires M2P lookups for
MMIO mappings as well.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Dave Hansen <dave.hansen@intel.com>
This facility is used in a few places so let's introduce
a helper function to improve code readability.
Signed-off-by: Aaron Tomlin <atomlin@redhat.com>
Cc: aneesh.kumar@linux.vnet.ibm.com
Cc: dzickus@redhat.com
Cc: bmr@redhat.com
Cc: jcastillo@redhat.com
Cc: oleg@redhat.com
Cc: riel@redhat.com
Cc: prarit@redhat.com
Cc: jgh@redhat.com
Cc: minchan@kernel.org
Cc: mpe@ellerman.id.au
Cc: tglx@linutronix.de
Cc: hannes@cmpxchg.org
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Seiji Aguchi <seiji.aguchi@hds.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: linuxppc-dev@lists.ozlabs.org
Link: http://lkml.kernel.org/r/1410527779-8133-3-git-send-email-atomlin@redhat.com
Tasks get their end of stack set to STACK_END_MAGIC with the
aim to catch stack overruns. Currently this feature does not
apply to init_task. This patch removes this restriction.
Note that a similar patch was posted by Prarit Bhargava
some time ago but was never merged:
http://marc.info/?l=linux-kernel&m=127144305403241&w=2
Acked-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
Cc: bmr@redhat.com
Cc: jgh@redhat.com
Cc: Alex Thorlton <athorlton@sgi.com>
Cc: Daeseok Youn <daeseok.youn@gmail.com>
Cc: Fabian Frederick <fabf@skynet.be>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Vladimir Davydov <vdavydov@parallels.com>
Link: http://lkml.kernel.org/r/1410527779-8133-2-git-send-email-atomlin@redhat.com
When hot-adding/removing memory, sync_global_pgds() is called
for synchronizing PGD to PGD entries of all processes MM. But
when hot-removing memory, sync_global_pgds() does not work
correctly.
At first, sync_global_pgds() checks whether target PGD is none
or not. And if PGD is none, the PGD is skipped. But when
hot-removing memory, PGD may be none since PGD may be cleared by
free_pud_table(). So when sync_global_pgds() is called after
hot-removing memory, sync_global_pgds() should not skip PGD even
if the PGD is none. And sync_global_pgds() must clear PGD
Currently sync_global_pgds() does not clear PGD entries of all
processes MM when hot-removing memory. So when hot adding
memory which is same memory range as removed memory after
hot-removing memory, following call traces are shown:
kernel BUG at arch/x86/mm/init_64.c:206!
[<ffffffff815e0c80>] kernel_physical_mapping_init+0x1b2/0x1d2
[<ffffffff815ced94>] init_memory_mapping+0x1d4/0x380
[<ffffffff8104aebd>] arch_add_memory+0x3d/0xd0
[<ffffffff815d03d9>] add_memory+0xb9/0x1b0
[<ffffffff81352415>] acpi_memory_device_add+0x1af/0x28e
[<ffffffff81325dc4>] acpi_bus_device_attach+0x8c/0xf0
[<ffffffff813413b9>] acpi_ns_walk_namespace+0xc8/0x17f
[<ffffffff81325d38>] ? acpi_bus_type_and_status+0xb7/0xb7
[<ffffffff813418ed>] acpi_walk_namespace+0x95/0xc5
[<ffffffff81326b4c>] acpi_bus_scan+0x9a/0xc2
[<ffffffff81326bff>] acpi_scan_bus_device_check+0x8b/0x12e
[<ffffffff81326cb5>] acpi_scan_device_check+0x13/0x15
[<ffffffff81320122>] acpi_os_execute_deferred+0x25/0x32
[<ffffffff8107e02b>] process_one_work+0x17b/0x460
[<ffffffff8107edfb>] worker_thread+0x11b/0x400
[<ffffffff8107ece0>] ? rescuer_thread+0x400/0x400
[<ffffffff81085aef>] kthread+0xcf/0xe0
[<ffffffff81085a20>] ? kthread_create_on_node+0x140/0x140
[<ffffffff815fc76c>] ret_from_fork+0x7c/0xb0
This patch clears PGD entries of all processes MM when
sync_global_pgds() is called after hot-removing memory
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Acked-by: Toshi Kani <toshi.kani@hp.com>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Gu Zheng <guz.fnst@cn.fujitsu.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Add a comment describing the circumstances in which
__lock_page_or_retry() will or will not release the mmap_sem when
returning 0.
Add comments to lock_page_or_retry()'s callers (filemap_fault(),
do_swap_page()) noting the impact on VM_FAULT_RETRY returns.
Add comments on up the call tree, particularly replacing the false "We
return with mmap_sem still held" comments.
Signed-off-by: Paul Cassella <cassella@cray.com>
Pull x86 mm changes from Ingo Molnar:
"The main change in this cycle is the rework of the TLB range flushing
code, to simplify, fix and consolidate the code. By Dave Hansen"
x86/mm: Set TLB flush tunable to sane value (33)
x86/mm: New tunable for single vs full TLB flush
x86/mm: Add tracepoints for TLB flushes
x86/mm: Unify remote INVLPG code
x86/mm: Fix missed global TLB flush stat
x86/mm: Rip out complicated, out-of-date, buggy TLB flushing
x86/mm: Clean up the TLB flushing code
x86/smep: Be more informative when signalling an SMEP fault
Pull more perf updates from Ingo Molnar:
"A second round of perf updates:
- wide reaching kprobes sanitization and robustization, with the hope
of fixing all 'probe this function crashes the kernel' bugs, by
Masami Hiramatsu.
- uprobes updates from Oleg Nesterov: tmpfs support, corner case
fixes and robustization work.
- perf tooling updates and fixes from Jiri Olsa, Namhyung Ki, Arnaldo
et al:
* Add support to accumulate hist periods (Namhyung Kim)
* various fixes, refactorings and enhancements"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (101 commits)
perf: Differentiate exec() and non-exec() comm events
perf: Fix perf_event_comm() vs. exec() assumption
uprobes/x86: Rename arch_uprobe->def to ->defparam, minor comment updates
perf/documentation: Add description for conditional branch filter
perf/x86: Add conditional branch filtering support
perf/tool: Add conditional branch filter 'cond' to perf record
perf: Add new conditional branch filter 'PERF_SAMPLE_BRANCH_COND'
uprobes: Teach copy_insn() to support tmpfs
uprobes: Shift ->readpage check from __copy_insn() to uprobe_register()
perf/x86: Use common PMU interrupt disabled code
perf/ARM: Use common PMU interrupt disabled code
perf: Disable sampled events if no PMU interrupt
perf: Fix use after free in perf_remove_from_context()
perf tools: Fix 'make help' message error
perf record: Fix poll return value propagation
perf tools: Move elide bool into perf_hpp_fmt struct
perf tools: Remove elide setup for SORT_MODE__MEMORY mode
perf tools: Fix "==" into "=" in ui_browser__warning assignment
perf tools: Allow overriding sysfs and proc finding with env var
perf tools: Consider header files outside perf directory in tags target
If pagefault triggers due to SMEP triggering, it can't be really easily
distinguished from any other oops-causing pagefault, which might lead to quite
some confusion when trying to understand the reason for the oops.
Print an explanatory message in case the fault happened during instruction
fetch for _PAGE_USER page which is present and executable on SMEP-enabled CPUs.
This is consistent with what we are doing for NX already; in addition to
immediately seeing from the oops what might be happening, it can even easily
give a good indication to sysadmins who are carefully monitoring their kernel
logs that someone might be trying to pwn them.
Link: http://lkml.kernel.org/r/alpine.LNX.2.00.1406102248490.1321@pobox.suse.cz
This makes the 64-bit and x32 vdsos use the same mechanism as the
32-bit vdso. Most of the churn is deleting all the old fixmap code.
Link: http://lkml.kernel.org/r/8af87023f57f6bb96ec8d17fce3f88018195b49b.1399317206.git.luto@amacapital.net
Use NOKPROBE_SYMBOL macro for protecting functions
from kprobes instead of __kprobes annotation under
arch/x86.
This applies nokprobe_inline annotation for some cases,
because NOKPROBE_SYMBOL() will inhibit inlining by
referring the symbol address.
This just folds a bunch of previous NOKPROBE_SYMBOL()
cleanup patches for x86 to one patch.
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/20140417081814.26341.51656.stgit@ltc230.yrl.intra.hitachi.co.jp
Cc: Borislav Petkov <bp@suse.de>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Fernando Luis Vázquez Cao <fernando_b1@lab.ntt.co.jp>
Cc: Gleb Natapov <gleb@redhat.com>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Jonathan Lebon <jlebon@redhat.com>
Cc: Matt Fleming <matt.fleming@intel.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com>
Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Vineet Gupta <vgupta@synopsys.com>
Pull x86 EFI changes from Ingo Molnar:
"The main changes:
- Add debug code to the dump EFI pagetable - Borislav Petkov
- Make 1:1 runtime mapping robust when booting on machines with lots
of memory - Borislav Petkov
- Move the EFI facilities bits out of 'x86_efi_facility' and into
efi.flags which is the standard architecture independent place to
keep EFI state, by Matt Fleming.
- Add 'EFI mixed mode' support: this allows 64-bit kernels to be
booted from 32-bit firmware. This needs a bootloader that supports
the 'EFI handover protocol'. By Matt Fleming"
* 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits)
x86, efi: Abstract x86 efi_early calls
x86/efi: Restore 'attr' argument to query_variable_info()
x86/efi: Rip out phys_efi_get_time()
x86/efi: Preserve segment registers in mixed mode
x86/boot: Fix non-EFI build
x86, tools: Fix up compiler warnings
x86/efi: Re-disable interrupts after calling firmware services
x86/boot: Don't overwrite cr4 when enabling PAE
x86/efi: Wire up CONFIG_EFI_MIXED
x86/efi: Add mixed runtime services support
x86/efi: Firmware agnostic handover entry points
x86/efi: Split the boot stub into 32/64 code paths
x86/efi: Add early thunk code to go from 64-bit to 32-bit
x86/efi: Build our own EFI services pointer table
efi: Add separate 32-bit/64-bit definitions
x86/efi: Delete dead code when checking for non-native
x86/mm/pageattr: Always dump the right page table in an oops
x86, tools: Consolidate #ifdef code
x86/boot: Cleanup header.S by removing some #ifdefs
efi: Use NULL instead of 0 for pointer
Building on commit 0ac09f9f8cd1 ("x86, trace: Fix CR2 corruption when
tracing page faults") this patch addresses another few issues:
- Now that read_cr2() is lifted into trace_do_page_fault(), we should
pass the address to trace_page_fault_entries() to avoid it
re-reading a potentially changed cr2.
- Put both trace_do_page_fault() and trace_page_fault_entries() under
CONFIG_TRACING.
- Mark both fault entry functions {,trace_}do_page_fault() as notrace
to avoid getting __mcount or other function entry trace callbacks
before we've observed CR2.
- Mark __do_page_fault() as noinline to guarantee the function tracer
does get to see the fault.
Cc: <jolsa@redhat.com>
Cc: <vincent.weaver@maine.edu>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20140306145300.GO9987@twins.programming.kicks-ass.net
arch/x86/kernel/setup.c
arch/x86/platform/efi/efi.c
arch/x86/platform/efi/efi_64.c
The trace_do_page_fault function trigger tracepoint
and then handles the actual page fault.
This could lead to error if the tracepoint caused page
fault. The original cr2 value gets lost and the original
page fault handler kills current process with SIGSEGV.
This happens if you record page faults with callchain
data, the user part of it will cause tracepoint handler
to page fault:
# perf record -g -e exceptions:page_fault_user ls
Fixing this by saving the original cr2 value
and using it after tracepoint handler is done.
v2: Moving the cr2 read before exception_enter, because
it could trigger tracepoint as well.
Reported-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Tested-by: Vince Weaver <vincent.weaver@maine.edu>
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1402211701380.6395@vincent-weaver-1.um.maine.edu
Link: http://lkml.kernel.org/r/20140228160526.GD1133@krava.brq.redhat.com
Now that we have EFI-specific page tables we need to lookup the pgd when
dumping those page tables, rather than assuming that swapper_pgdir is
the current pgdir.
Remove the double underscore prefix, which is usually reserved for
static functions.
Acked-by: Borislav Petkov <bp@suse.de>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
If CONFIG_X86_SMAP is disabled, smap_violation() tests for conditions
which are incorrect (as the AC flag doesn't matter), causing spurious
faults.
The dynamic disabling of SMAP (nosmap on the command line) is fine
because it disables X86_FEATURE_SMAP, therefore causing the
static_cpu_has() to return false.
Found by Fengguang Wu's test system.
[ v3: move all predicates into smap_violation() ]
[ v2: use IS_ENABLED() instead of #ifdef ]
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Link: http://lkml.kernel.org/r/20140213124550.GA30497@localhost
Cc: <stable@vger.kernel.org> # v3.7+
Waiman managed to trigger a PMI while in a emulate_vsyscall() fault,
the PMI in turn managed to trigger a fault while obtaining a stack
trace. This triggered the sig_on_uaccess_error recursive fault logic
and killed the process dead.
Fix this by explicitly excluding interrupts from the recursive fault
logic.
Reported-and-Tested-by: Waiman Long <waiman.long@hp.com>
Fixes: e00b12e64be9 ("perf/x86: Further optimize copy_from_user_nmi()")
Cc: Aswin Chandramouleeswaran <aswin@hp.com>
Cc: Scott J Norton <scott.norton@hp.com>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/20140110200603.GJ7572@laptop.programming.kicks-ass.net
Pull two x86 fixes from Ingo Molnar.
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/microcode/amd: Tone down printk(), don't treat a missing firmware file as an error
x86/dumpstack: Fix printk_address for direct addresses
Pull x86/trace changes from Ingo Molnar:
"This adds page fault tracepoints which have zero runtime cost in the
disabled case via IDT trickery (no NOPs in the page fault hotpath)"
* 'x86-trace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, trace: Change user|kernel_page_fault to page_fault_user|kernel
x86, trace: Add page fault tracepoints
x86, trace: Delete __trace_alloc_intr_gate()
x86, trace: Register exception handler to trace IDT
x86, trace: Remove __alloc_intr_gate()
Consider a kernel crash in a module, simulated the following way:
static int my_init(void)
char *map = (void *)0x5;
*map = 3;
return 0;
module_init(my_init);
When we turn off FRAME_POINTERs, the very first instruction in
that function causes a BUG. The problem is that we print IP in
the BUG report using %pB (from printk_address). And %pB
decrements the pointer by one to fix printing addresses of
functions with tail calls.
This was added in commit 71f9e59800e5ad4 ("x86, dumpstack: Use
%pB format specifier for stack trace") to fix the call stack
printouts.
So instead of correct output:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000005
IP: [<ffffffffa01ac000>] my_init+0x0/0x10 [pb173]
We get:
IP: [<ffffffffa0152000>] 0xffffffffa0151fff
To fix that, we use %pS only for stack addresses printouts (via
newly added printk_stack_address) and %pB for regs->ip (via
printk_address). I.e. we revert to the old behaviour for all
except call stacks. And since from all those reliable is 1, we
remove that parameter from printk_address.
Cc: Namhyung Kim <namhyung@gmail.com>
Cc: joe@perches.com
Cc: jirislaby@gmail.com
Link: http://lkml.kernel.org/r/1382706418-8435-1-git-send-email-jslaby@suse.cz
Tracepoints are named hierachially, and it makes more sense to keep a
general flow of information level from general to specific from left
to right, i.e.
x86_exceptions.page_fault_user|kernel
rather than
x86_exceptions.user|kernel_page_fault
Suggested-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Seiji Aguchi <seiji.aguchi@hds.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Link: http://lkml.kernel.org/r/20131111082955.GB12405@gmail.com
This patch introduces page fault tracepoints to x86 architecture
by switching IDT.
Two events, for user and kernel spaces, are introduced at the beginning
of page fault handler for tracing.
- User space event
There is a request of page fault event for user space as below.
https://lkml.kernel.org/r/1368079520-11015-2-git-send-email-fdeslaur+()+gmail+!+com
https://lkml.kernel.org/r/1368079520-11015-1-git-send-email-fdeslaur+()+gmail+!+com
- Kernel space event:
When we measure an overhead in kernel space for investigating performance
issues, we can check if it comes from the page fault events.
Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com>
Link: http://lkml.kernel.org/r/52716E67.6090705@hds.com
This patch registers exception handlers for tracing to a trace IDT.
To implemented it in set_intr_gate(), this patch does followings.
- Register the exception handlers to
the trace IDT by prepending "trace_" to the handler's names.
- Also, newly introduce trace_page_fault() to add tracepoints
in a subsequent patch.
Link: http://lkml.kernel.org/r/52716DEC.5050204@hds.com
Now that we can deal with nested NMI due to IRET re-enabling NMIs and
can deal with faults from NMI by making sure we preserve CR2 over NMIs
we can in fact simply access user-space memory from NMI context.
So rewrite copy_from_user_nmi() to use __copy_from_user_inatomic() and
rework the fault path to do the minimal required work before taking
the in_atomic() fault handler.
In particular avoid perf_sw_event() which would make perf recurse on
itself (it should be harmless as our recursion protections should be
able to deal with this -- but why tempt fate).
Also rename notify_page_fault() to kprobes_fault() as that is a much
better name; there is no notifier in it and its specific to kprobes.
Don measured that his worst case NMI path shrunk from ~300K cycles to
~150K cycles.
Cc: Stephane Eranian <eranian@google.com>
Cc: jmario@redhat.com
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: dave.hansen@linux.intel.com
Tested-by: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/r/20131024105206.GM2490@laptop.programming.kicks-ass.net
The x86 fault handler bails in the middle of error handling when the
task has a fatal signal pending. For a subsequent patch this is a
problem in OOM situations because it relies on pagefault_out_of_memory()
being called even when the task has been killed, to perform proper
per-task OOM state unwinding.
Shortcutting the fault like this is a rather minor optimization that
saves a few instructions in rare cases. Just remove it for
user-triggered faults.
Use the opportunity to split the fault retry handling from actual fault
errors and add locking documentation that reads suprisingly similar to
ARM's.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: azurIt <azurit@pobox.sk>
Unlike global OOM handling, memory cgroup code will invoke the OOM killer
in any OOM situation because it has no way of telling faults occuring in
kernel context - which could be handled more gracefully - from
Pass a flag that identifies faults originating in user space from the
architecture-specific fault handlers to generic code so that memcg OOM
handling can be improved.
Pull x86 cpuid changes from Ingo Molnar:
"The biggest change is x86 CPU bug handling refactoring and cleanups,
by Borislav Petkov"
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, CPU, AMD: Drop useless label
x86, AMD: Correct {rd,wr}msr_amd_safe warnings
x86: Fold-in trivial check_config function
x86, cpu: Convert AMD Erratum 400
x86, cpu: Convert AMD Erratum 383
x86, cpu: Convert Cyrix coma bug detection
x86, cpu: Convert FDIV bug detection
x86, cpu: Convert F00F bug detection
x86, cpu: Expand cpufeature facility to include cpu bugs
Pull scheduler changes from Ingo Molnar:
"The main changes in this development cycle were:
- full dynticks preparatory work by Frederic Weisbecker
- factor out the cpu time accounting code better, by Li Zefan
- multi-CPU load balancer cleanups and improvements by Joonsoo Kim
- various smaller fixes and cleanups"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (45 commits)
sched: Fix init NOHZ_IDLE flag
sched: Prevent to re-select dst-cpu in load_balance()
sched: Rename load_balance_tmpmask to load_balance_mask
sched: Move up affinity check to mitigate useless redoing overhead
sched: Don't consider other cpus in our group in case of NEWLY_IDLE
sched: Explicitly cpu_idle_type checking in rebalance_domains()
sched: Change position of resched_cpu() in load_balance()
sched: Fix wrong rq's runnable_avg update with rt tasks
sched: Document task_struct::personality field
sched/cpuacct/UML: Fix header file dependency bug on the UML build
cgroup: Kill subsys.active flag
sched/cpuacct: No need to check subsys active state
sched/cpuacct: Initialize cpuacct subsystem earlier
sched/cpuacct: Initialize root cpuacct earlier
sched/cpuacct: Allocate per_cpu cpuusage for root cpuacct statically
sched/cpuacct: Clean up cpuacct.h
sched/cpuacct: Remove redundant NULL checks in cpuacct_acount_field()
sched/cpuacct: Remove redundant NULL checks in cpuacct_charge()
sched/cpuacct: Add cpuacct_acount_field()
sched/cpuacct: Add cpuacct_init()
In paravirtualized x86_64 kernels, vmalloc_fault may cause an oops
when lazy MMU updates are enabled, because set_pgd effects are being
deferred.
One instance of this problem is during process mm cleanup with memory
cgroups enabled. The chain of events is as follows:
- zap_pte_range enables lazy MMU updates
- zap_pte_range eventually calls mem_cgroup_charge_statistics,
which accesses the vmalloc'd mem_cgroup per-cpu stat area
- vmalloc_fault is triggered which tries to sync the corresponding
PGD entry with set_pgd, but the update is deferred
- vmalloc_fault oopses due to a mismatch in the PUD entries
The OOPs usually looks as so:
kernel BUG at arch/x86/mm/fault.c:396!
invalid opcode: 0000 [#1] SMP
.. snip ..
CPU 1
Pid: 10866, comm: httpd Not tainted 3.6.10-4.fc18.x86_64 #1
RIP: e030:[<ffffffff816271bf>] [<ffffffff816271bf>] vmalloc_fault+0x11f/0x208
.. snip ..
Call Trace:
[<ffffffff81627759>] do_page_fault+0x399/0x4b0
[<ffffffff81004f4c>] ? xen_mc_extend_args+0xec/0x110
[<ffffffff81624065>] page_fault+0x25/0x30
[<ffffffff81184d03>] ? mem_cgroup_charge_statistics.isra.13+0x13/0x50
[<ffffffff81186f78>] __mem_cgroup_uncharge_common+0xd8/0x350
[<ffffffff8118aac7>] mem_cgroup_uncharge_page+0x57/0x60
[<ffffffff8115fbc0>] page_remove_rmap+0xe0/0x150
[<ffffffff8115311a>] ? vm_normal_page+0x1a/0x80
[<ffffffff81153e61>] unmap_single_vma+0x531/0x870
[<ffffffff81154962>] unmap_vmas+0x52/0xa0
[<ffffffff81007442>] ? pte_mfn_to_pfn+0x72/0x100
[<ffffffff8115c8f8>] exit_mmap+0x98/0x170
[<ffffffff810050d9>] ? __raw_callee_save_xen_pmd_val+0x11/0x1e
[<ffffffff81059ce3>] mmput+0x83/0xf0
[<ffffffff810624c4>] exit_mm+0x104/0x130
[<ffffffff8106264a>] do_exit+0x15a/0x8c0
[<ffffffff810630ff>] do_group_exit+0x3f/0xa0
[<ffffffff81063177>] sys_exit_group+0x17/0x20
[<ffffffff8162bae9>] system_call_fastpath+0x16/0x1b
Calling arch_flush_lazy_mmu_mode immediately after set_pgd makes the
changes visible to the consistency checks.
RedHat-Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=914737
Tested-by: Josh Boyer <jwboyer@redhat.com>
Reported-and-Tested-by: Krishna Raman <kraman@redhat.com>
Signed-off-by: Samu Kallio <samu.kallio@aberdeencloud.com>
Link: http://lkml.kernel.org/r/1364045796-10720-1-git-send-email-konrad.wilk@oracle.com
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
... to using the new facility and drop the cpuinfo_x86 member.
Link: http://lkml.kernel.org/r/1363788448-31325-3-git-send-email-bp@alien8.de
On exception exit, we restore the previous context tracking state based on
the regs of the interrupted frame. Iff that frame is in user mode as
stated by user_mode() helper, we restore the context tracking user mode.
However there is a tiny chunck of low level arch code after we pass through
user_enter() and until the CPU eventually resumes userspace.
If an exception happens in this tiny area, exception_enter() correctly
exits the context tracking user mode but exception_exit() won't restore
it because of the value returned by user_mode(regs).
As a result we may return to userspace with the wrong context tracking
state.
To fix this, change exception_enter() to return the context tracking state
prior to its call and pass this saved state to exception_exit(). This restores
the real context tracking state of the interrupted frame.
(May be this patch was suggested to me, I don't recall exactly. If so,
sorry for the missing credit).
Cc: Li Zhong <zhong@linux.vnet.ibm.com>
Cc: Kevin Hilman <khilman@linaro.org>
Cc: Mats Liljegren <mats.liljegren@enea.com>
Cc: Namhyung Kim <namhyung.kim@lge.com>
Exceptions handling on context tracking should share common
treatment: on entry we exit user mode if the exception triggered
in that context. Then on exception exit we return to that previous
context.
Generalize this to avoid duplication across archs.
the PRESENT bit"
I got a report for a minor regression introduced by commit
027ef6c87853b ("mm: thp: fix pmd_present for split_huge_page and
PROT_NONE with THP").
So the problem is, pageattr creates kernel pagetables (pte and
pmds) that breaks pte_present/pmd_present and the patch above
exposed this invariant breakage for pmd_present.
The same problem already existed for the pte and pte_present and
it was fixed by commit 660a293ea9be709 ("x86, mm: Make
spurious_fault check explicitly check the PRESENT bit") (if it
wasn't for that commit, it wouldn't even be a regression). That
fix avoids the pagefault to use pte_present. I could follow
through by stopping using pmd_present/pmd_huge too.
However I think it's more robust to fix pageattr and to clear
the PSE/GLOBAL bitflags too in addition to the present bitflag.
So the kernel page fault can keep using the regular
pte_present/pmd_present/pmd_huge.
The confusion arises because _PAGE_GLOBAL and _PAGE_PROTNONE are
sharing the same bit, and in the pmd case we pretend _PAGE_PSE
to be set only in present pmds (to facilitate split_huge_page
final tlb flush).
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Shaohua Li <shaohua.li@intel.com>
Cc: "H. Peter Anvin" <hpa@linux.intel.com>
Without this patch, it is trivial to determine kernel page
mappings by examining the error code reported to dmesg[1].
Instead, declare the entire kernel memory space as a violation
of a present page.
Additionally, since show_unhandled_signals is enabled by
default, switch branch hinting to the more realistic
expectation, and unobfuscate the setting of the PF_PROT bit to
improve readability.
[1] http://vulnfactory.org/blog/2013/02/06/a-linux-memory-trick/
Reported-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Suggested-by: Brad Spengler <spender@grsecurity.net>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Link: http://lkml.kernel.org/r/20130207174413.GA12485@www.outflux.net
out_of_memory() is a globally defined function to call the oom killer.
x86, sh, and powerpc all use a function of the same name within file scope
in their respective fault.c unnecessarily. Inline the functions into the
pagefault handlers to clean the code up.
Signed-off-by: David Rientjes <rientjes@google.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Create a new subsystem that probes on kernel boundaries
to keep track of the transitions between level contexts
with two basic initial contexts: user or kernel.
This is an abstraction of some RCU code that use such tracking
to implement its userspace extended quiescent state.
We need to pull this up from RCU into this new level of indirection
because this tracking is also going to be used to implement an "on
demand" generic virtual cputime accounting. A necessary step to
shutdown the tick while still accounting the cputime.
Cc: Gilad Ben-Yossef <gilad@benyossef.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
[ paulmck: fix whitespace error and email address. ]
.fault now can retry. The retry can break state machine of .fault. In
filemap_fault, if page is miss, ra->mmap_miss is increased. In the second
try, since the page is in page cache now, ra->mmap_miss is decreased. And
these are done in one fault, so we can't detect random mmap file access.
Add a new flag to indicate .fault is tried once. In the second try, skip
ra->mmap_miss decreasing. The filemap_fault state machine is ok with it.
I only tested x86, didn't test other archs, but looks the change for other
archs is obvious, but who knows :)
Signed-off-by: Shaohua Li <shaohua.li@fusionio.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Pull x86/smap support from Ingo Molnar:
"This adds support for the SMAP (Supervisor Mode Access Prevention) CPU
feature on Intel CPUs: a hardware feature that prevents unintended
user-space data access from kernel privileged code.
It's turned on automatically when possible.
This, in combination with SMEP, makes it even harder to exploit kernel
bugs such as NULL pointer dereferences."
Fix up trivial conflict in arch/x86/kernel/entry_64.S due to newly added
includes right next to each other.
* 'x86-smap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, smep, smap: Make the switching functions one-way
x86, suspend: On wakeup always initialize cr4 and EFER
x86-32: Start out eflags and cr4 clean
x86, smap: Do not abuse the [f][x]rstor_checking() functions for user space
x86-32, smap: Add STAC/CLAC instructions to 32-bit kernel entry
x86, smap: Reduce the SMAP overhead for signal handling
x86, smap: A page fault due to SMAP is an oops
x86, smap: Turn on Supervisor Mode Access Prevention
x86, smap: Add STAC and CLAC instructions to control user space access
x86, uaccess: Merge prototypes for clear_user/__clear_user
x86, smap: Add a header file with macros for STAC/CLAC
x86, alternative: Add header guards to <asm/alternative-asm.h>
x86, alternative: Use .pushsection/.popsection
x86, smap: Add CR4 bit for SMAP
x86-32, mm: The WP test should be done on a kernel page
Add necessary hooks to x86 exception for userspace
RCU extended quiescent state support.
This includes traps, page fault, debug exceptions, etc...
Cc: Alessio Igor Bogani <abogani@kernel.org>
Cc: Avi Kivity <avi@redhat.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Geoff Levand <geoff@infradead.org>
Cc: Gilad Ben Yossef <gilad@benyossef.com>
Cc: Hakan Akkan <hakanakkan@gmail.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Kevin Hilman <khilman@ti.com>
Cc: Max Krasnyansky <maxk@qualcomm.com>
Cc: Stephen Hemminger <shemminger@vyatta.com>
Cc: Sven-Thorsten Dietrich <thebigcorporation@gmail.com>
If we get a page fault due to SMAP, trigger an oops rather than
spinning forever.
Link: http://lkml.kernel.org/r/1348256595-29119-11-git-send-email-hpa@linux.intel.com
