git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull x86 cdso updates from Peter Anvin:
"Vdso cleanups and improvements largely from Andy Lutomirski. This
makes the vdso a lot less ''special''"
* 'x86/vdso' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/vdso, build: Make LE access macros clearer, host-safe
x86/vdso, build: Fix cross-compilation from big-endian architectures
x86/vdso, build: When vdso2c fails, unlink the output
x86, vdso: Fix an OOPS accessing the HPET mapping w/o an HPET
x86, mm: Replace arch_vma_name with vm_ops->name for vsyscalls
x86, mm: Improve _install_special_mapping and fix x86 vdso naming
mm, fs: Add vm_ops->name as an alternative to arch_vma_name
x86, vdso: Remove vestiges of VDSO_PRELINK and some outdated comments
x86, vdso: Move the vvar and hpet mappings next to the 64-bit vDSO
x86, vdso: Move the 32-bit vdso special pages after the text
x86, vdso: Reimplement vdso.so preparation in build-time C
x86, vdso: Move syscall and sysenter setup into kernel/cpu/common.c
x86, vdso: Clean up 32-bit vs 64-bit vdso params
x86, mm: Ensure correct alignment of the fixmap
The early_ioremap code requires that its buffers not span a PMD
boundary. The logic for ensuring that only works if the fixmap is
aligned, so assert that it's aligned correctly.
To make this work reliably, reserve_top_address needs to be
adjusted.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/e59a5f4362661f75dd4841fa74e1f2448045e245.1399317206.git.luto@amacapital.net
In __ioremap_caller() (the guts of ioremap), we loop over the range of
pfns being remapped and checks each one individually with page_is_ram().
For large ioremaps, this can be very slow. For example, we have a
device with a 256 GiB PCI BAR, and ioremapping this BAR can take 20+
seconds -- sometimes long enough to trigger the soft lockup detector!
Internally, page_is_ram() calls walk_system_ram_range() on a single
page. Instead, we can make a single call to walk_system_ram_range()
from __ioremap_caller(), and do our further checks only for any RAM
pages that we find. For the common case of MMIO, this saves an enormous
amount of work, since the range being ioremapped doesn't intersect
system RAM at all.
With this change, ioremap on our 256 GiB BAR takes less than 1 second.
Signed-off-by: Roland Dreier <roland@purestorage.com>
Link: http://lkml.kernel.org/r/1399054721-1331-1-git-send-email-roland@kernel.org
Move x86 over to the generic early ioremap implementation.
Signed-off-by: Mark Salter <msalter@redhat.com>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Cc: Borislav Petkov <borislav.petkov@amd.com>
Cc: Dave Young <dyoung@redhat.com>
This patch series takes the common bits from the x86 early ioremap
implementation and creates a generic implementation which may be used by
other architectures. The early ioremap interfaces are intended for
situations where boot code needs to make temporary virtual mappings
before the normal ioremap interfaces are available. Typically, this
means before paging_init() has run.
This patch (of 6):
There's a lot of sparse warnings for code like below: void *a =
early_memremap(phys_addr, size);
early_memremap intend to map kernel memory with ioremap facility, the
return pointer should be a kernel ram pointer instead of iomem one.
For making the function clearer and supressing sparse warnings this patch
do below two things:
1. cast to (__force void *) for the return value of early_memremap
2. add early_memunmap function and pass (__force void __iomem *) to iounmap
From Boris:
"Ingo told me yesterday, it makes sense too. I'd guess we can try it.
FWIW, all callers of early_memremap use the memory they get remapped
as normal memory so we should be safe"
Signed-off-by: Dave Young <dyoung@redhat.com>
After commit:
8827247ffcc ("x86: don't define __this_fixmap_does_not_exist()")
variable idx0 is no longer needed, so just remove it.
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: <linux-mm@kvack.org>
Cc: <wangchen@cn.fujitsu.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Link: http://lkml.kernel.org/r/5209A173.3090600@huawei.com
Infact, let the compiler enter the function name so that there
are no discrepancies.
Link: http://lkml.kernel.org/r/1372369996-20556-1-git-send-email-bp@alien8.de
This patchset removes vm_struct list management after initializing
vmalloc. Adding and removing an entry to vmlist is linear time
complexity, so it is inefficient. If we maintain this list, overall
time complexity of adding and removing area to vmalloc space is O(N),
although we use rbtree for finding vacant place and it's time complexity
is just O(logN).
And vmlist and vmlist_lock is used many places of outside of vmalloc.c.
It is preferable that we hide this raw data structure and provide
well-defined function for supporting them, because it makes that they
cannot mistake when manipulating theses structure and it makes us easily
maintain vmalloc layer.
For kexec and makedumpfile, I export vmap_area_list, instead of vmlist.
This comes from Atsushi's recommendation. For more information, please
refer below link. https://lkml.org/lkml/2012/12/6/184
This patch:
The purpose of iterating a vmlist is finding vm area with specific virtual
address. find_vm_area() is provided for this purpose and more efficient,
because it uses a rbtree. So change it.
Signed-off-by: Joonsoo Kim <js1304@gmail.com>
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
Acked-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp>
Cc: Dave Anderson <anderson@redhat.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
This reverts commit 53b87cf088e2ea68d7c59619d0214cc15bb76133.
It causes odd bootup problems on x86-64. Markus Trippelsdorf gets a
repeatable oops, and I see a non-repeatable oops (or constant stream of
messages that scroll off too quickly to read) that seems to go away with
this commit reverted.
So we don't know exactly what is wrong with the commit, but it's
definitely problematic, and worth reverting sooner rather than later.
Bisected-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Cc: H Peter Anvin <hpa@zytor.com>
Cc: Jan Beulich <jbeulich@suse.com>
Cc: Matt Fleming <matt.fleming@intel.com>
There are various pieces of code in arch/x86 that require a page table
with an identity mapping. Make trampoline_pgd a proper kernel page
table, it currently only includes the kernel text and module space
mapping.
One new feature of trampoline_pgd is that it now has mappings for the
physical I/O device addresses, which are inserted at ioremap()
time. Some broken implementations of EFI firmware require these
mappings to always be around.
Acked-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Fix kernel-doc warnings in arch/x86/mm/ioremap.c and
arch/x86/mm/pageattr.c, just like this one:
Warning(arch/x86/mm/ioremap.c:204):
No description found for parameter 'phys_addr'
Excess function parameter 'offset' description in 'ioremap_nocache'
Signed-off-by: Wanpeng Li <liwp@linux.vnet.ibm.com>
Cc: Gavin Shan <shangw@linux.vnet.ibm.com>
Cc: Wanpeng Li <liwp.linux@gmail.com>
Link: http://lkml.kernel.org/r/1339296652-2935-1-git-send-email-liwp.linux@gmail.com
While tracking down the reason for an ioremap() failure I was
distracted by the WARN_ONCE() in __ioremap_caller().
Performing a WARN_ONCE() sanity check before the mapping
is successful seems pointless if the caller sends bad values.
A case in point is when the BIOS provides erroneous screen_info
values causing vesafb_probe() to request an outrageuous size.
The WARN_ONCE is then wasted on bogosity. Move the warning to a
point where the mapping has been successfully allocated.
Addresses:
http://bugs.launchpad.net/bugs/772042
Reviewed-by: Suresh Siddha <suresh.b.siddha@intel.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Link: http://lkml.kernel.org/r/4DB99D2E.9080106@canonical.com
Xen requires that all pages containing pagetable entries to be mapped
read-only. If pages used for the initial pagetable are already mapped
then we can change the mapping to RO. However, if they are initially
unmapped, we need to make sure that when they are later mapped, they
are also mapped RO.
We do this by knowing that the kernel pagetable memory is pre-allocated
in the range e820_table_start - e820_table_end, so any pfn within this
range should be mapped read-only. However, the pagetable setup code
early_ioremaps the pages to write their entries, so we must make sure
that mappings created in the early_ioremap fixmap area are mapped RW.
(Those mappings are removed before the pages are presented to Xen
as pagetable pages.)
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
LKML-Reference: <4CB63A80.8060702@goop.org>
Cc: Yinghai Lu <yinghai@kernel.org>
x86 early_iounmap(): fix off-by-one error in page alignment of allocation
size for sizes where size%PAGE_SIZE==1.
Signed-off-by: Florian Zumbiehl <florz@florz.de>
LKML-Reference: <201007202219.o6KMJlES021058@imap1.linux-foundation.org>
Check for normal RAM in x86 ioremap() code seems to not work for the
last page frame in the specified physical address range.
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
LKML-Reference: <4C1AE6CD.1080704@jp.fujitsu.com>
Current x86 ioremap() doesn't handle physical address higher than
32-bit properly in X86_32 PAE mode. When physical address higher than
32-bit is passed to ioremap(), higher 32-bits in physical address is
cleared wrongly. Due to this bug, ioremap() can map wrong address to
linear address space.
In my case, 64-bit MMIO region was assigned to a PCI device (ioat
device) on my system. Because of the ioremap()'s bug, wrong physical
address (instead of MMIO region) was mapped to linear address space.
Because of this, loading ioatdma driver caused unexpected behavior
(kernel panic, kernel hangup, ...).
LKML-Reference: <4C1AE680.7090408@jp.fujitsu.com>
When specifying the 'reservetop=0xbadc0de' kernel parameter,
the kernel will stop booting due to a early_ioremap bug that
relates to commit 8827247ff.
The root cause of boot failure problem is the value of
'slot_virt[i]' was initialized in setup_arch->early_ioremap_init().
But later in setup_arch, the function 'parse_early_param' will
modify 'FIXADDR_TOP' when 'reservetop=0xbadc0de' being specified.
The simplest fix might be use __fix_to_virt(idx0) to get updated
value of 'FIXADDR_TOP' in '__early_ioremap' instead of reference
old value from slot_virt[slot] directly.
Changelog since v0:
-v1: When reservetop being handled then FIXADDR_TOP get
adjusted, Hence check prev_map then re-initialize slot_virt and
PMD based on new FIXADDR_TOP.
-v2: place fixup_early_ioremap hence call early_ioremap_init in
reserve_top_address to re-initialize slot_virt and
corresponding PMD when parse_reservertop
-v3: move fixup_early_ioremap out of reserve_top_address to make
sure other clients of reserve_top_address like xen/lguest won't
broken
Signed-off-by: Liang Li <liang.li@windriver.com>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Cc: Wang Chen <wangchen@cn.fujitsu.com>
LKML-Reference: <1272621711-8683-1-git-send-email-liang.li@windriver.com>
[ fixed three small cleanliness details in fixup_early_ioremap() ]
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, mm: Unify kernel_physical_mapping_init() API
x86, mm: Allow highmem user page tables to be disabled at boot time
x86: Do not reserve brk for DMI if it's not going to be used
x86: Convert tlbstate_lock to raw_spinlock
x86: Use the generic page_is_ram()
x86: Remove BIOS data range from e820
Move page_is_ram() declaration to mm.h
Generic page_is_ram: use __weak
resources: introduce generic page_is_ram()
x86/mm is on 32-rc4 and missing the spinlock namespace changes which
are needed for further commits into this topic.
The generic resource based page_is_ram() works better with memory
hotplug/hotremove. So switch the x86 e820map based code to it.
CC: Andi Kleen <andi@firstfloor.org>
CC: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
CC: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
LKML-Reference: <20100122033004.470767217@intel.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
In preparation for moving to the generic page_is_ram(), make explicit
what we expect to be reserved and not reserved.
Tested-by: Wu Fengguang <fengguang.wu@intel.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <20100122033004.335813103@intel.com>
The early ioremap fixmap entries cover half (or for 32-bit
non-PAE, a quarter) of a page table, yet they got
uncondtitionally aligned so far to a 256-entry boundary. This is
not necessary if the range of page table entries anyway falls
into a single page table.
This buys back, for (theoretically) 50% of all configurations
(25% of all non-PAE ones), at least some of the lowmem
necessarily lost with commit e621bd18958ef5dbace3129ebe17a0a475e127d9.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
LKML-Reference: <4B2BB66F0200007800026AD6@vpn.id2.novell.com>
* 'x86-pat-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: pat: Remove ioremap_default()
x86: pat: Clean up req_type special case for reserve_memtype()
x86: Relegate CONFIG_PAT and CONFIG_MTRR configurability to EMBEDDED
Commit:
b6ff32d: x86, PAT: Consolidate code in pat_x_mtrr_type() and reserve_memtype()
consolidated reserve_memtype() and pat_x_mtrr_type,
this made ioremap_default() same as ioremap_cache().
Remove the redundant function and change the only caller to use
ioremap_cache.
Signed-off-by: Xiaotian Feng <dfeng@redhat.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
LKML-Reference: <1257845005-7938-1-git-send-email-dfeng@redhat.com>
kernel missed to free memtype if get_vm_area_caller failed in
__ioremap_caller.
This patch introduces error path to fix this and cleans up the
repetitive error return sequences that contributed to the
creation of the bug.
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <1257389031-20429-1-git-send-email-dfeng@redhat.com>
x86, pat: Fix cacheflush address in change_page_attr_set_clr()
mm: remove !NUMA condition from PAGEFLAGS_EXTENDED condition set
x86: Fix earlyprintk=dbgp for machines without NX
x86, pat: Sanity check remap_pfn_range for RAM region
x86, pat: Lookup the protection from memtype list on vm_insert_pfn()
x86, pat: Add lookup_memtype to get the current memtype of a paddr
x86, pat: Use page flags to track memtypes of RAM pages
x86, pat: Generalize the use of page flag PG_uncached
x86, pat: Add rbtree to do quick lookup in memtype tracking
x86, pat: Add PAT reserve free to io_mapping* APIs
x86, pat: New i/f for driver to request memtype for IO regions
x86, pat: ioremap to follow same PAT restrictions as other PAT users
x86, pat: Keep identity maps consistent with mmaps even when pat_disabled
x86, mtrr: make mtrr_aps_delayed_init static bool
x86, pat/mtrr: Rendezvous all the cpus for MTRR/PAT init
generic-ipi: Allow cpus not yet online to call smp_call_function with irqs disabled
x86: Fix an incorrect argument of reserve_bootmem()
x86: Fix system crash when loading with "reservetop" parameter
Split __phys_addr out into its own file so we can disable
-fstack-protector in a fine-grained fashion. Also it doesn't
have terribly much to do with the rest of ioremap.c.
Reason: Change to is_new_memtype_allowed() in x86/urgent
Resolved semantic conflicts in:
arch/x86/mm/pat.c
ioremap has this hard-coded check for new type and requested type. That
check differs from other PAT users like /dev/mem mmap, remap_pfn_range
in only one condition where requested type is UC_MINUS and new type
is WC. Under that condition, ioremap fails. But other PAT interfaces succeed
with a WC mapping.
Change to make ioremap be in sync with other PAT APIs and use the same
macro as others. Also changes the error print to KERN_ERR instead of
pr_debug.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: fix microcode driver newly spewing warnings
x86, PAT: Remove page granularity tracking for vm_insert_pfn maps
x86: disable X86_PTRACE_BTS for now
x86, documentation: kernel-parameters replace X86-32,X86-64 with X86
x86: pci-swiotlb.c swiotlb_dma_ops should be static
x86, PAT: Remove duplicate memtype reserve in devmem mmap
x86, PAT: Changing memtype to WC ensuring no WB alias
x86, PAT: Handle faults cleanly in set_memory_ APIs
x86, PAT: Change order of cpa and free in set_memory_wb
x86, CPA: Change idmap attribute before ioremap attribute setup
Impact: fix kprobes crash on 32-bit with RAM above 4G
Use phys_addr_t for receiving a physical address argument
instead of unsigned long. This allows fixmap to handle
pages higher than 4GB on x86-32.
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: systemtap-ml <systemtap@sources.redhat.com>
Cc: Gary Hade <garyhade@us.ibm.com>
LKML-Reference: <49DE3695.6040800@redhat.com>
Fix pat_x_mtrr_type() to use UC_MINUS when the mtrr type return UC. This
is to be consistent with ioremap() and ioremap_nocache() which uses
UC_MINUS.
Consolidate the code such that reserve_memtype() also uses
pat_x_mtrr_type() when the caller doesn't specify any special attribute
(non WB attribute).
LKML-Reference: <20090409212708.939936000@intel.com>
Change the identity mapping with the requested attribute first, before
we setup the virtual memory mapping with the new requested attribute.
This makes sure that there is no window when identity map'ed attribute
may disagree with ioremap range on the attribute type.
This also avoids doing cpa on the ioremap'ed address twice (first in
ioremap_page_range and then in ioremap_change_attr using vaddr), and
should improve ioremap performance a bit.
LKML-Reference: <20090409212708.373330000@intel.com>
Tetsuo Handa reported this link bug:
| arch/x86/mm/built-in.o(.init.text+0x1831): In function `early_ioremap_init':
| : undefined reference to `__this_fixmap_does_not_exist'
| make: *** [.tmp_vmlinux1] Error 1
Commit:8827247ffcc9e880cbe4705655065cf011265157 used a variable (which
would be optimized to constant) as fix_to_virt()'s parameter.
It's depended on gcc's optimization and fails on old gcc. (Tetsuo used gcc 3.3)
We can use __fix_to_vir() instead, because we know it's safe and
don't need link time error reporting.
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
Cc: sfr@canb.auug.org.au
LKML-Reference: <49C9FFEA.7060908@cn.fujitsu.com>
This reverts commit 698609bdcd35d0641f4c6622c83680ab1a6d67cb.
69860 breaks Xen booting, as it relies on head*.S to set up the fixmap
pagetables (as a side-effect of initializing the USB debug port).
Xen, however, does not boot via head*.S, and so the fixmap area is
not initialized.
The specific symptom of the crash is a fault in dmi_scan(), because
the pointer that early_ioremap returns is not actually present.
Cc: Jan Beulich <jbeulich@novell.com>
LKML-Reference: <49C43A8E.5090203@goop.org>
Impact: kernel image size reduction
Since in most configurations the pmd page needed maps the same range of
virtual addresses which is also mapped by the earlier inserted one for
covering FIX_DBGP_BASE, that page (and its insertion in the page
tables) can be avoided altogether by detecting the condition at compile
time.
LKML-Reference: <49B91826.76E4.0078.0@novell.com>
Impact: 32/64-bit consolidation
In a first step, this allows fixing phys_addr_valid() for PAE (which
until now reported all addresses to be valid). Subsequently, this will
also allow simplifying some MTRR handling code.
LKML-Reference: <49B9101E.76E4.0078.0@novell.com>
'x86/urgent', 'linus' and 'core/percpu' into x86/core
I found that virt_addr_valid() was returning true for fixmap addresses.
I'm not sure whether pfn_valid() is supposed to include this test,
but there's no harm in being explicit.
Cc: Jiri Slaby <jirislaby@gmail.com>
LKML-Reference: <49B166D6.2080505@goop.org>
Impact: improve out-of-range fixmap index debugging
Commit "1b42f51630c7eebce6fb780b480731eb81afd325"
defined the __this_fixmap_does_not_exist() function
with a WARN_ON(1) in it.
This causes the linker to not report an error when
__this_fixmap_does_not_exist() is called with a
non-constant parameter.
Ingo defined __this_fixmap_does_not_exist() because he
wanted to get virt addresses of fix memory of nest level
by non-constant index.
But we can fix this and still keep the link-time check:
We can get the four slot virt addresses on link time and
store them to array slot_virt[].
Then we can then refer the slot_virt with non-constant index,
in the ioremap-leak detection code.
LKML-Reference: <49B2075B.4070509@cn.fujitsu.com>
Impact: cleanup, micro-optimization
Pre-initialize boot_cpu_data.x86_phys_bits to a reasonable default
to remove the use of system_state tests in __virt_addr_valid()
and __phys_addr().
Rather than relying on the ever-unreliable system_state,
add a specific __vmalloc_start_set flag to indicate whether
the vmalloc area has meaningful boundaries yet, and use that
in x86-32's __phys_addr and __virt_addr_valid.
'x86/uaccess' and 'x86/urgent' into x86/core
Jeff Mahoney reported:
> With Suse's hwinfo tool, on -tip:
> WARNING: at arch/x86/mm/pat.c:637 reserve_pfn_range+0x5b/0x26d()
reserve_pfn_range() is not tracking the memory range below 1MB
as non-RAM and as such is inconsistent with similar checks in
reserve_memtype() and free_memtype()
Rename the pagerange_is_ram() to pat_pagerange_is_ram() and add the
"track legacy 1MB region as non RAM" condition.
And also, fix reserve_pfn_range() to return -EINVAL, when the pfn
range is RAM. This is to be consistent with this API design.
Reported-and-tested-by: Jeff Mahoney <jeffm@suse.com>
'x86/doc', 'x86/header-fixes', 'x86/mm', 'x86/paravirt', 'x86/pat', 'x86/setup-v2', 'x86/subarch', 'x86/uaccess' and 'x86/urgent' into x86/core
Impact: fix/extend ioremap_wc() beyond 4GB aperture on 32-bit
ioremap_wc() was taking in unsigned long parameter, where as it should take
64-bit resource_size_t parameter like other ioremap variants.
(take 2)
Debugging and original patch from Nick Piggin <npiggin@suse.de>
The early fixmap pmd entry inserted at the very top of the KVA is causing the
subsequent fixmap mapping code to not provide physically linear pte pages over
the kmap atomic portion of the fixmap (which relies on said property to
calculate pte addresses).
This has caused weird boot failures in kmap_atomic much later in the boot
process (initial userspace faults) on a 32-bit PAE system with a larger number
of CPUs (smaller CPU counts tend not to run over into the next page so don't
show up the problem).
Solve this by attempting to clear out the page table, and copy any of its
entries to the new one. Also, add a bug if a nonlinear condition is encountered
and can't be resolved, which might save some hours of debugging if this fragile
scheme ever breaks again...
Once we have such logic, we can also use it to eliminate the early ioremap
trickery around the page table setup for the fixmap area. This also fixes
potential issues with FIX_* entries sharing the leaf page table with the early
ioremap ones getting discarded by early_ioremap_clear() and not restored by
early_ioremap_reset(). It at once eliminates the temporary (and configuration,
namely NR_CPUS, dependent) unavailability of early fixed mappings during the
time the fixmap area page tables get constructed.
Finally, also replace the hard coded calculation of the initial table space
needed for the fixmap area with a proper one, allowing kernels configured for
large CPU counts to actually boot.
Based-on: Nick Piggin <npiggin@suse.de>
Impact: make debug warning less scary
The ioremap() time multi-BAR map warning has been causing false
positives:
http://lkml.org/lkml/2008/12/10/432
http://lkml.org/lkml/2008/12/11/136
So make it less scary by making it once-per-boot, by making it KERN_INFO
and by adding this text:
"Info: mapping multiple BARs. Your kernel is fine."
Impact: some new sparse warnings in e820.c etc, but no functional change.
As with regular ioremap, iounmap etc, annotate with __iomem.
Fixes the following sparse warnings, will produce some new ones
elsewhere in arch/x86 that will get worked out over time.
arch/x86/mm/ioremap.c:402:9: warning: cast removes address space of expression
arch/x86/mm/ioremap.c:406:10: warning: cast adds address space to expression (<asn:2>)
arch/x86/mm/ioremap.c:782:19: warning: Using plain integer as NULL pointer
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
'core/printk' and 'core/misc' into core-v28-for-linus
