path: root/arch/x86/mm
2014-04-08arch/x86/mm/kmemcheck/kmemcheck.c: use kstrtoint() instead of sscanf()David Rientjes
Kmemcheck should use the preferred interface for parsing command line arguments, kstrto*(), rather than sscanf() itself. Use it appropriately. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Vegard Nossum <vegardno@ifi.uio.no> Acked-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07x86: use generic early_ioremapMark Salter
Move x86 over to the generic early ioremap implementation. Signed-off-by: Mark Salter <msalter@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Borislav Petkov <borislav.petkov@amd.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Dave Young <dyoung@redhat.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07x86/mm: sparse warning fix for early_memremapDave Young
This patch series takes the common bits from the x86 early ioremap implementation and creates a generic implementation which may be used by other architectures. The early ioremap interfaces are intended for situations where boot code needs to make temporary virtual mappings before the normal ioremap interfaces are available. Typically, this means before paging_init() has run. This patch (of 6): There's a lot of sparse warnings for code like below: void *a = early_memremap(phys_addr, size); early_memremap intend to map kernel memory with ioremap facility, the return pointer should be a kernel ram pointer instead of iomem one. For making the function clearer and supressing sparse warnings this patch do below two things: 1. cast to (__force void *) for the return value of early_memremap 2. add early_memunmap function and pass (__force void __iomem *) to iounmap From Boris: "Ingo told me yesterday, it makes sense too. I'd guess we can try it. FWIW, all callers of early_memremap use the memory they get remapped as normal memory so we should be safe" Signed-off-by: Dave Young <dyoung@redhat.com> Signed-off-by: Mark Salter <msalter@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Borislav Petkov <borislav.petkov@amd.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-02Merge branch 'x86-nuke-platforms-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 old platform removal from Peter Anvin: "This patchset removes support for several completely obsolete platforms, where the maintainers either have completely vanished or acked the removal. For some of them it is questionable if there even exists functional specimens of the hardware" Geert Uytterhoeven apparently thought this was a April Fool's pull request ;) * 'x86-nuke-platforms-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, platforms: Remove NUMAQ x86, platforms: Remove SGI Visual Workstation x86, apic: Remove support for IBM Summit/EXA chipset x86, apic: Remove support for ia32-based Unisys ES7000
2014-04-01Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm change from Ingo Molnar: "A micro-optimization for acpi_numa_slit_init()" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mm: Avoid duplicated pxm_to_node() calls
2014-03-31Merge branch 'x86-efi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 EFI changes from Ingo Molnar: "The main changes: - Add debug code to the dump EFI pagetable - Borislav Petkov - Make 1:1 runtime mapping robust when booting on machines with lots of memory - Borislav Petkov - Move the EFI facilities bits out of 'x86_efi_facility' and into efi.flags which is the standard architecture independent place to keep EFI state, by Matt Fleming. - Add 'EFI mixed mode' support: this allows 64-bit kernels to be booted from 32-bit firmware. This needs a bootloader that supports the 'EFI handover protocol'. By Matt Fleming" * 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits) x86, efi: Abstract x86 efi_early calls x86/efi: Restore 'attr' argument to query_variable_info() x86/efi: Rip out phys_efi_get_time() x86/efi: Preserve segment registers in mixed mode x86/boot: Fix non-EFI build x86, tools: Fix up compiler warnings x86/efi: Re-disable interrupts after calling firmware services x86/boot: Don't overwrite cr4 when enabling PAE x86/efi: Wire up CONFIG_EFI_MIXED x86/efi: Add mixed runtime services support x86/efi: Firmware agnostic handover entry points x86/efi: Split the boot stub into 32/64 code paths x86/efi: Add early thunk code to go from 64-bit to 32-bit x86/efi: Build our own EFI services pointer table efi: Add separate 32-bit/64-bit definitions x86/efi: Delete dead code when checking for non-native x86/mm/pageattr: Always dump the right page table in an oops x86, tools: Consolidate #ifdef code x86/boot: Cleanup header.S by removing some #ifdefs efi: Use NULL instead of 0 for pointer ...
2014-03-31Merge branch 'x86-cpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cpu handling changes from Ingo Molnar: "Bigger changes: - Intel CPU hardware-enablement: new vector instructions support (AVX-512), by Fenghua Yu. - Support the clflushopt instruction and use it in appropriate places. clflushopt is similar to clflush but with more relaxed ordering, by Ross Zwisler. - MSR accessor cleanups, by Borislav Petkov. - 'forcepae' boot flag for those who have way too much time to spend on way too old Pentium-M systems and want to live way too dangerously, by Chris Bainbridge" * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, cpu: Add forcepae parameter for booting PAE kernels on PAE-disabled Pentium M Rename TAINT_UNSAFE_SMP to TAINT_CPU_OUT_OF_SPEC x86, intel: Make MSR_IA32_MISC_ENABLE bit constants systematic x86, Intel: Convert to the new bit access MSR accessors x86, AMD: Convert to the new bit access MSR accessors x86: Add another set of MSR accessor functions x86: Use clflushopt in drm_clflush_virt_range x86: Use clflushopt in drm_clflush_page x86: Use clflushopt in clflush_cache_range x86: Add support for the clflushopt instruction x86, AVX-512: Enable AVX-512 States Context Switch x86, AVX-512: AVX-512 Feature Detection
2014-03-13x86, pageattr: Correct WBINVD spelling in commentBorislav Petkov
It is WBINVD, for INValiDate and not "wbindv". Use caps for instruction names, while at it. Signed-off-by: Borislav Petkov <bp@suse.de> Link: http://lkml.kernel.org/r/1394633584-5509-4-git-send-email-bp@alien8.de Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-03-06x86, trace: Further robustify CR2 handling vs tracingPeter Zijlstra
Building on commit 0ac09f9f8cd1 ("x86, trace: Fix CR2 corruption when tracing page faults") this patch addresses another few issues: - Now that read_cr2() is lifted into trace_do_page_fault(), we should pass the address to trace_page_fault_entries() to avoid it re-reading a potentially changed cr2. - Put both trace_do_page_fault() and trace_page_fault_entries() under CONFIG_TRACING. - Mark both fault entry functions {,trace_}do_page_fault() as notrace to avoid getting __mcount or other function entry trace callbacks before we've observed CR2. - Mark __do_page_fault() as noinline to guarantee the function tracer does get to see the fault. Cc: <jolsa@redhat.com> Cc: <vincent.weaver@maine.edu> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20140306145300.GO9987@twins.programming.kicks-ass.net Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-03-05Merge remote-tracking branch 'tip/x86/efi-mixed' into efi-for-mingoMatt Fleming
Conflicts: arch/x86/kernel/setup.c arch/x86/platform/efi/efi.c arch/x86/platform/efi/efi_64.c
2014-03-05Merge remote-tracking branch 'tip/x86/urgent' into efi-for-mingoMatt Fleming
Conflicts: arch/x86/include/asm/efi.h
2014-03-04x86, trace: Fix CR2 corruption when tracing page faultsJiri Olsa
The trace_do_page_fault function trigger tracepoint and then handles the actual page fault. This could lead to error if the tracepoint caused page fault. The original cr2 value gets lost and the original page fault handler kills current process with SIGSEGV. This happens if you record page faults with callchain data, the user part of it will cause tracepoint handler to page fault: # perf record -g -e exceptions:page_fault_user ls Fixing this by saving the original cr2 value and using it after tracepoint handler is done. v2: Moving the cr2 read before exception_enter, because it could trigger tracepoint as well. Reported-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Reported-by: Vince Weaver <vincent.weaver@maine.edu> Tested-by: Vince Weaver <vincent.weaver@maine.edu> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1402211701380.6395@vincent-weaver-1.um.maine.edu Link: http://lkml.kernel.org/r/20140228160526.GD1133@krava.brq.redhat.com
2014-03-04x86/mm/pageattr: Always dump the right page table in an oopsMatt Fleming
Now that we have EFI-specific page tables we need to lookup the pgd when dumping those page tables, rather than assuming that swapper_pgdir is the current pgdir. Remove the double underscore prefix, which is usually reserved for static functions. Acked-by: Borislav Petkov <bp@suse.de> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-03-04x86, pageattr: Export page unmapping interfaceBorislav Petkov
We will use it in efi so expose it. Signed-off-by: Borislav Petkov <bp@suse.de> Tested-by: Toshi Kani <toshi.kani@hp.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-03-04x86, ptdump: Add the functionality to dump an arbitrary pagetableBorislav Petkov
With reusing the ->trampoline_pgd page table for mapping EFI regions in order to use them after having switched to EFI virtual mode, it is very useful to be able to dump aforementioned page table in dmesg. This adds that functionality through the walk_pgd_level() interface which can be called from somewhere else. The original functionality of dumping to debugfs remains untouched. Cc: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Borislav Petkov <bp@suse.de> Tested-by: Toshi Kani <toshi.kani@hp.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-02-27x86: Use clflushopt in clflush_cache_rangeRoss Zwisler
If clflushopt is available on the system, use it instead of clflush in clflush_cache_range. Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com> Link: http://lkml.kernel.org/r/1393441612-19729-3-git-send-email-ross.zwisler@linux.intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-02-27x86, platforms: Remove NUMAQH. Peter Anvin
The NUMAQ support seems to be unmaintained, remove it. Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: David Rientjes <rientjes@google.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/n/530CFD6C.7040705@zytor.com
2014-02-13x86, smap: smap_violation() is bogus if CONFIG_X86_SMAP is offH. Peter Anvin
If CONFIG_X86_SMAP is disabled, smap_violation() tests for conditions which are incorrect (as the AC flag doesn't matter), causing spurious faults. The dynamic disabling of SMAP (nosmap on the command line) is fine because it disables X86_FEATURE_SMAP, therefore causing the static_cpu_has() to return false. Found by Fengguang Wu's test system. [ v3: move all predicates into smap_violation() ] [ v2: use IS_ENABLED() instead of #ifdef ] Reported-by: Fengguang Wu <fengguang.wu@intel.com> Link: http://lkml.kernel.org/r/20140213124550.GA30497@localhost Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: <stable@vger.kernel.org> # v3.7+
2014-02-09x86/mm: Avoid duplicated pxm_to_node() callsYinghai Lu
In slit init code, too many pxm_to_node() function calls are done. We can store from_node/to_node instead of keep calling pxm_to_node(). - Before this patch: pxm_to_node() is called n*(1+n*3) times. - After this patch: pxm_to_node() is called n*(1+n) times. for 8 sockets, it will be 72 instead of 200. for 32 sockets, it will be 1056 instead of 3104. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Toshi Kani <toshi.kani@hp.com> Cc: David Rientjes <rientjes@google.com> Link: http://lkml.kernel.org/r/1390770102-4007-1-git-send-email-yinghai@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-02-08Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "Quite a varied little collection of fixes. Most of them are relatively small or isolated; the biggest one is Mel Gorman's fixes for TLB range flushing. A couple of AMD-related fixes (including not crashing when given an invalid microcode image) and fix a crash when compiled with gcov" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, microcode, AMD: Unify valid container checks x86, hweight: Fix BUG when booting with CONFIG_GCOV_PROFILE_ALL=y x86/efi: Allow mapping BGRT on x86-32 x86: Fix the initialization of physnode_map x86, cpu hotplug: Fix stack frame warning in check_irq_vectors_for_cpu_disable() x86/intel/mid: Fix X86_INTEL_MID dependencies arch/x86/mm/srat: Skip NUMA_NO_NODE while parsing SLIT mm, x86: Revisit tlb_flushall_shift tuning for page flushes except on IvyBridge x86: mm: change tlb_flushall_shift for IvyBridge x86/mm: Eliminate redundant page table walk during TLB range flushing x86/mm: Clean up inconsistencies when flushing TLB ranges mm, x86: Account for TLB flushes only when debugging x86/AMD/NB: Fix amd_set_subcaches() parameter type x86/quirks: Add workaround for AMD F16h Erratum792 x86, doc, kconfig: Fix dud URL for Microcode data
2014-02-07Merge tag 'efi-urgent' into x86/urgentH. Peter Anvin
* Avoid WARN_ON() when mapping BGRT on Baytrail (EFI 32-bit). Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-02-06arch/x86/mm/numa.c: fix array index overflow when synchronizing nid to ↵Tang Chen
memblock.reserved. The following path will cause array out of bound. memblock_add_region() will always set nid in memblock.reserved to MAX_NUMNODES. In numa_register_memblks(), after we set all nid to correct valus in memblock.reserved, we called setup_node_data(), and used memblock_alloc_nid() to allocate memory, with nid set to MAX_NUMNODES. The nodemask_t type can be seen as a bit array. And the index is 0 ~ MAX_NUMNODES-1. After that, when we call node_set() in numa_clear_kernel_node_hotplug(), the nodemask_t got an index of value MAX_NUMNODES, which is out of [0 ~ MAX_NUMNODES-1]. See below: numa_init() |---> numa_register_memblks() | |---> memblock_set_node(memory) set correct nid in memblock.memory | |---> memblock_set_node(reserved) set correct nid in memblock.reserved | |...... | |---> setup_node_data() | |---> memblock_alloc_nid() here, nid is set to MAX_NUMNODES (1024) |...... |---> numa_clear_kernel_node_hotplug() |---> node_set() here, we have an index 1024, and overflowed This patch moves nid setting to numa_clear_kernel_node_hotplug() to fix this problem. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Tested-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Reported-by: Dave Jones <davej@redhat.com> Cc: David Rientjes <rientjes@google.com> Tested-by: Dave Jones <davej@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-06arch/x86/mm/numa.c: initialize numa_kernel_nodes in ↵Tang Chen
numa_clear_kernel_node_hotplug() On-stack variable numa_kernel_nodes in numa_clear_kernel_node_hotplug() was not initialized. So we need to initialize it. [akpm@linux-foundation.org: use NODE_MASK_NONE, per David] Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Tested-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Reported-by: Dave Jones <davej@redhat.com> Reported-by: David Rientjes <rientjes@google.com> Tested-by: Dave Jones <davej@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-01x86: Fix the initialization of physnode_mapPetr Tesarik
With DISCONTIGMEM, the mapping between a pfn and its owning node is initialized using data provided by the BIOS. However, the initialization may fail if the extents are not aligned to section boundary (64M). The symptom of this bug is an early boot failure in pfn_to_page(), as it tries to access NODE_DATA(__nid) using index from an unitialized element of the physnode_map[] array. While the bug is always present, it is more likely to be hit in kdump kernels on large machines, because: 1. The memory map for a kdump kernel is specified as exactmap, and exactmap is more likely to be unaligned. 2. Large reservations are more likely to span across a 64M boundary. [ hpa: fixed incorrect use of "pfn" instead of "start" ] Signed-off-by: Petr Tesarik <ptesarik@suse.cz> Link: http://lkml.kernel.org/r/20140201133019.32e56f86@hananiah.suse.cz Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-01-25Merge branch 'linus' into x86/urgentIngo Molnar
Merge in the x86 changes to apply a fix. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-25arch/x86/mm/srat: Skip NUMA_NO_NODE while parsing SLITToshi Kani
When ACPI SLIT table has an I/O locality (i.e. a locality unique to an I/O device), numa_set_distance() emits this warning message: NUMA: Warning: node ids are out of bound, from=-1 to=-1 distance=10 acpi_numa_slit_init() calls numa_set_distance() with pxm_to_node(), which assumes that all localities have been parsed with SRAT previously. SRAT does not list I/O localities, where as SLIT lists all localities including I/Os. Hence, pxm_to_node() returns NUMA_NO_NODE (-1) for an I/O locality. I/O localities are not supported and are ignored today, but emitting such warning message leads to unnecessary confusion. Change acpi_numa_slit_init() to avoid calling numa_set_distance() with NUMA_NO_NODE. Signed-off-by: Toshi Kani <toshi.kani@hp.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/n/tip-dSvpjjvp8aMzs1ybkftxohlh@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-25x86/mm: Eliminate redundant page table walk during TLB range flushingMel Gorman
When choosing between doing an address space or ranged flush, the x86 implementation of flush_tlb_mm_range takes into account whether there are any large pages in the range. A per-page flush typically requires fewer entries than would covered by a single large page and the check is redundant. There is one potential exception. THP migration flushes single THP entries and it conceivably would benefit from flushing a single entry instead of the mm. However, this flush is after a THP allocation, copy and page table update potentially with any other threads serialised behind it. In comparison to that, the flush is noise. It makes more sense to optimise balancing to require fewer flushes than to optimise the flush itself. This patch deletes the redundant huge page check. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Davidlohr Bueso <davidlohr@hp.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Alex Shi <alex.shi@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-sgei1drpOcburujPsfh6ovmo@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-25x86/mm: Clean up inconsistencies when flushing TLB rangesMel Gorman
NR_TLB_LOCAL_FLUSH_ALL is not always accounted for correctly and the comparison with total_vm is done before taking tlb_flushall_shift into account. Clean it up. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Davidlohr Bueso <davidlohr@hp.com> Reviewed-by: Alex Shi <alex.shi@linaro.org> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Hugh Dickins <hughd@google.com> Link: http://lkml.kernel.org/n/tip-Iz5gcahrgskIldvukulzi0hh@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-25mm, x86: Account for TLB flushes only when debuggingMel Gorman
Bisection between 3.11 and 3.12 fingered commit 9824cf97 ("mm: vmstats: tlb flush counters") to cause overhead problems. The counters are undeniably useful but how often do we really need to debug TLB flush related issues? It does not justify taking the penalty everywhere so make it a debugging option. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Davidlohr Bueso <davidlohr@hp.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com> Cc: Alex Shi <alex.shi@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-XzxjntugxuwpxXhcrxqqh53b@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-23mm: dump page when hitting a VM_BUG_ON using VM_BUG_ON_PAGESasha Levin
Most of the VM_BUG_ON assertions are performed on a page. Usually, when one of these assertions fails we'll get a BUG_ON with a call stack and the registers. I've recently noticed based on the requests to add a small piece of code that dumps the page to various VM_BUG_ON sites that the page dump is quite useful to people debugging issues in mm. This patch adds a VM_BUG_ON_PAGE(cond, page) which beyond doing what VM_BUG_ON() does, also dumps the page before executing the actual BUG_ON. [akpm@linux-foundation.org: fix up includes] Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21x86/mm: memblock: switch to use NUMA_NO_NODEGrygorii Strashko
Update X86 code to use NUMA_NO_NODE instead of MAX_NUMNODES while calling memblock APIs, because memblock API will be changed to use NUMA_NO_NODE and will produce warning during boot otherwise. See: https://lkml.org/lkml/2013/12/9/898 Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Acked-by: David Rientjes <rientjes@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21acpi, numa, mem_hotplug: mark all nodes the kernel resides un-hotpluggableTang Chen
At very early time, the kernel have to use some memory such as loading the kernel image. We cannot prevent this anyway. So any node the kernel resides in should be un-hotpluggable. Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Rafael J . Wysocki" <rjw@sisk.pl> Cc: Chen Tang <imtangchen@gmail.com> Cc: Gong Chen <gong.chen@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Len Brown <lenb@kernel.org> Cc: Liu Jiang <jiang.liu@huawei.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Taku Izumi <izumi.taku@jp.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Thomas Renninger <trenn@suse.de> Cc: Toshi Kani <toshi.kani@hp.com> Cc: Vasilis Liaskovitis <vasilis.liaskovitis@profitbricks.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21acpi, numa, mem_hotplug: mark hotpluggable memory in memblockTang Chen
When parsing SRAT, we know that which memory area is hotpluggable. So we invoke function memblock_mark_hotplug() introduced by previous patch to mark hotpluggable memory in memblock. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Rafael J . Wysocki" <rjw@sisk.pl> Cc: Chen Tang <imtangchen@gmail.com> Cc: Gong Chen <gong.chen@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Len Brown <lenb@kernel.org> Cc: Liu Jiang <jiang.liu@huawei.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Taku Izumi <izumi.taku@jp.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Thomas Renninger <trenn@suse.de> Cc: Toshi Kani <toshi.kani@hp.com> Cc: Vasilis Liaskovitis <vasilis.liaskovitis@profitbricks.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21memblock: make memblock_set_node() support different memblock_typeTang Chen
[sfr@canb.auug.org.au: fix powerpc build] Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Rafael J . Wysocki" <rjw@sisk.pl> Cc: Chen Tang <imtangchen@gmail.com> Cc: Gong Chen <gong.chen@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Len Brown <lenb@kernel.org> Cc: Liu Jiang <jiang.liu@huawei.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Taku Izumi <izumi.taku@jp.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Thomas Renninger <trenn@suse.de> Cc: Toshi Kani <toshi.kani@hp.com> Cc: Vasilis Liaskovitis <vasilis.liaskovitis@profitbricks.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-20Merge branch 'x86-kaslr-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 kernel address space randomization support from Peter Anvin: "This enables kernel address space randomization for x86" * 'x86-kaslr-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, kaslr: Clarify RANDOMIZE_BASE_MAX_OFFSET x86, kaslr: Remove unused including <linux/version.h> x86, kaslr: Use char array to gain sizeof sanity x86, kaslr: Add a circular multiply for better bit diffusion x86, kaslr: Mix entropy sources together as needed x86/relocs: Add percpu fixup for GNU ld 2.23 x86, boot: Rename get_flags() and check_flags() to *_cpuflags() x86, kaslr: Raise the maximum virtual address to -1 GiB on x86_64 x86, kaslr: Report kernel offset on panic x86, kaslr: Select random position from e820 maps x86, kaslr: Provide randomness functions x86, kaslr: Return location from decompress_kernel x86, boot: Move CPU flags out of cpucheck x86, relocs: Add more per-cpu gold special cases
2014-01-20Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm changes from Ingo Molnar: "A cleanup, a fix and ASLR support for hugetlb mappings" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mm/numa: Fix 32-bit kernel NUMA boot x86/mm: Implement ASLR for hugetlb mappings x86/mm: Unify pte_to_pgoff() and pgoff_to_pte() helpers
2014-01-20Merge branch 'x86-efi-kexec-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 EFI changes from Ingo Molnar: "This consists of two main parts: - New static EFI runtime services virtual mapping layout which is groundwork for kexec support on EFI (Borislav Petkov) - EFI kexec support itself (Dave Young)" * 'x86-efi-kexec-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) x86/efi: parse_efi_setup() build fix x86: ksysfs.c build fix x86/efi: Delete superfluous global variables x86: Reserve setup_data ranges late after parsing memmap cmdline x86: Export x86 boot_params to sysfs x86: Add xloadflags bit for EFI runtime support on kexec x86/efi: Pass necessary EFI data for kexec via setup_data efi: Export EFI runtime memory mapping to sysfs efi: Export more EFI table variables to sysfs x86/efi: Cleanup efi_enter_virtual_mode() function x86/efi: Fix off-by-one bug in EFI Boot Services reservation x86/efi: Add a wrapper function efi_map_region_fixed() x86/efi: Remove unused variables in __map_region() x86/efi: Check krealloc return value x86/efi: Runtime services virtual mapping x86/mm/cpa: Map in an arbitrary pgd x86/mm/pageattr: Add last levels of error path x86/mm/pageattr: Add a PUD error unwinding path x86/mm/pageattr: Add a PTE pagetable populating function x86/mm/pageattr: Add a PMD pagetable populating function ...
2014-01-20Merge branch 'x86-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cleanups from Ingo Molnar: "Misc cleanups" * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, cpu, amd: Fix a shadowed variable situation um, x86: Fix vDSO build x86: Delete non-required instances of include <linux/init.h> x86, realmode: Pointer walk cleanups, pull out invariant use of __pa() x86/traps: Clean up error exception handler definitions
2014-01-16x86, mm, perf: Allow recursive faults from interruptsPeter Zijlstra
Waiman managed to trigger a PMI while in a emulate_vsyscall() fault, the PMI in turn managed to trigger a fault while obtaining a stack trace. This triggered the sig_on_uaccess_error recursive fault logic and killed the process dead. Fix this by explicitly excluding interrupts from the recursive fault logic. Reported-and-Tested-by: Waiman Long <waiman.long@hp.com> Fixes: e00b12e64be9 ("perf/x86: Further optimize copy_from_user_nmi()") Cc: Aswin Chandramouleeswaran <aswin@hp.com> Cc: Scott J Norton <scott.norton@hp.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20140110200603.GJ7572@laptop.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-06x86: Delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. [ hpa: undid incorrect removal from arch/x86/kernel/head_32.S ] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Link: http://lkml.kernel.org/r/1389054026-12947-1-git-send-email-paul.gortmaker@windriver.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-01-05Merge tag 'v3.13-rc7' into x86/efi-kexec to resolve conflictsIngo Molnar
Conflicts: arch/x86/platform/efi/efi.c drivers/firmware/efi/Kconfig Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-12-19x86/mm/numa: Fix 32-bit kernel NUMA bootLans Zhang
When booting a 32-bit x86 kernel on a NUMA machine, node data cannot be allocated from local node if the account of memory for node 0 covers the low memory space entirely: [ 0.000000] Initmem setup node 0 [mem 0x00000000-0x83fffffff] [ 0.000000] NODE_DATA [mem 0x367ed000-0x367edfff] [ 0.000000] Initmem setup node 1 [mem 0x840000000-0xfffffffff] [ 0.000000] Cannot find 4096 bytes in node 1 [ 0.000000] 64664MB HIGHMEM available. [ 0.000000] 871MB LOWMEM available. To fix this issue, node data is allowed to be allocated from other nodes if the memory of local node is still not mapped. The expected result looks like this: [ 0.000000] Initmem setup node 0 [mem 0x00000000-0x83fffffff] [ 0.000000] NODE_DATA [mem 0x367ed000-0x367edfff] [ 0.000000] Initmem setup node 1 [mem 0x840000000-0xfffffffff] [ 0.000000] NODE_DATA [mem 0x367ec000-0x367ecfff] [ 0.000000] NODE_DATA(1) on node 0 [ 0.000000] 64664MB HIGHMEM available. [ 0.000000] 871MB LOWMEM available. Signed-off-by: Lans Zhang <jia.zhang@windriver.com> Cc: <andi@firstfloor.org> Cc: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1386303510-18574-1-git-send-email-jia.zhang@windriver.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-12-19Merge tag 'v3.13-rc4' into x86/mmIngo Molnar
Pick up the latest fixes before applying new patches. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-12-18mm: numa: serialise parallel get_user_page against THP migrationMel Gorman
Base pages are unmapped and flushed from cache and TLB during normal page migration and replaced with a migration entry that causes any parallel NUMA hinting fault or gup to block until migration completes. THP does not unmap pages due to a lack of support for migration entries at a PMD level. This allows races with get_user_pages and get_user_pages_fast which commit 3f926ab945b6 ("mm: Close races between THP migration and PMD numa clearing") made worse by introducing a pmd_clear_flush(). This patch forces get_user_page (fast and normal) on a pmd_numa page to go through the slow get_user_page path where it will serialise against THP migration and properly account for the NUMA hinting fault. On the migration side the page table lock is taken for each PTE update. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-26Merge tag 'efi-next' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/mfleming/efi into x86/efi Pull EFI virtual mapping changes from Matt Fleming: * New static EFI runtime services virtual mapping layout which is groundwork for kexec support on EFI. (Borislav Petkov) Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-21x86, mm: do not leak page->ptl for pmd page tablesKirill A. Shutemov
There are two code paths how page with pmd page table can be freed: pmd_free() and pmd_free_tlb(). I've missed the second one and didn't add page table destructor call there. It leads to leak of page->ptl for pmd page tables, if dynamically allocated page->ptl is in use. The patch adds the missed destructor and modifies documentation accordingly. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Andrey Vagin <avagin@openvz.org> Tested-by: Andrey Vagin <avagin@openvz.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-20Wrong page freed on preallocate_pmds() failure exitAl Viro
Note that pmds[i] is simply uninitialized at that point... Granted, it's very hard to hit (you need split page locks *and* kmalloc(sizeof(spinlock_t), GFP_KERNEL) failing), but the code is obviously bogus. Introduced by commit 09ef4939850a ("x86: add missed pgtable_pmd_page_ctor/dtor calls for preallocated pmds") Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-19x86/mm: Implement ASLR for hugetlb mappingsKirill A. Shutemov
Matthew noticed that hugetlb mappings don't participate in ASLR on x86-64: % for i in `seq 3`; do > tools/testing/selftests/vm/map_hugetlb | grep address > done Returned address is 0x2aaaaac00000 Returned address is 0x2aaaaac00000 Returned address is 0x2aaaaac00000 /proc/PID/maps entries for the mapping are always the same (except inode number): 2aaaaac00000-2aaabac00000 rw-p 00000000 00:0c 8200 /anon_hugepage (deleted) 2aaaaac00000-2aaabac00000 rw-p 00000000 00:0c 256 /anon_hugepage (deleted) 2aaaaac00000-2aaabac00000 rw-p 00000000 00:0c 7180 /anon_hugepage (deleted) The reason is the generic hugetlb_get_unmapped_area() function which is used on x86-64. It doesn't support randomization and use bottom-up unmapped area lookup, instead of usual top-down on x86-64. x86 has arch-specific hugetlb_get_unmapped_area(), but it's used only on x86-32. Let's use arch-specific hugetlb_get_unmapped_area() on x86-64 too. That adds ASLR and switches hugetlb mappings to use top-down unmapped area lookup: % for i in `seq 3`; do > tools/testing/selftests/vm/map_hugetlb | grep address > done Returned address is 0x7f4f08a00000 Returned address is 0x7fdda4200000 Returned address is 0x7febe0000000 /proc/PID/maps entries: 7f4f08a00000-7f4f18a00000 rw-p 00000000 00:0c 1168 /anon_hugepage (deleted) 7fdda4200000-7fddb4200000 rw-p 00000000 00:0c 7092 /anon_hugepage (deleted) 7febe0000000-7febf0000000 rw-p 00000000 00:0c 7183 /anon_hugepage (deleted) Unmapped area lookup policy for hugetlb mappings is consistent with normal mappings now -- the only difference is alignment requirements for huge pages. libhugetlbfs test-suite didn't detect any regressions with the patch applied (although it shows few failures on my machine regardless the patch). Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mel Gorman <mgorman@suse.de> Link: http://lkml.kernel.org/r/20131119131750.EA45CE0090@blue.fi.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-15x86: handle pgtable_page_ctor() failKirill A. Shutemov
Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15x86: add missed pgtable_pmd_page_ctor/dtor calls for preallocated pmdsKirill A. Shutemov
In split page table lock case, we embed spinlock_t into struct page. For obvious reason, we don't want to increase size of struct page if spinlock_t is too big, like with DEBUG_SPINLOCK or DEBUG_LOCK_ALLOC or on -rt kernel. So we disable split page table lock, if spinlock_t is too big. This patchset allows to allocate the lock dynamically if spinlock_t is big. In this page->ptl is used to store pointer to spinlock instead of spinlock itself. It costs additional cache line for indirect access, but fix page fault scalability for multi-threaded applications. LOCK_STAT depends on DEBUG_SPINLOCK, so on current kernel enabling LOCK_STAT to analyse scalability issues breaks scalability. ;) The patchset mostly fixes this. Results for ./thp_memscale -c 80 -b 512M on 4-socket machine: baseline, no CONFIG_LOCK_STAT: 9.115460703 seconds time elapsed baseline, CONFIG_LOCK_STAT=y: 53.890567123 seconds time elapsed patched, no CONFIG_LOCK_STAT: 8.852250368 seconds time elapsed patched, CONFIG_LOCK_STAT=y: 11.069770759 seconds time elapsed Patch count is scary, but most of them trivial. Overview: Patches 1-4 Few bug fixes. No dependencies to other patches. Probably should applied as soon as possible. Patch 5 Changes signature of pgtable_page_ctor(). We will use it for dynamic lock allocation, so it can fail. Patches 6-8 Add missing constructor/destructor calls on few archs. It's fixes NR_PAGETABLE accounting and prepare to use split ptl. Patches 9-33 Add pgtable_page_ctor() fail handling to all archs. Patches 34 Finally adds support of dynamically-allocated page->pte. Also contains documentation for split page table lock. This patch (of 34): I've missed that we preallocate few pmds on pgd_alloc() if X86_PAE enabled. Let's add missed constructor/destructor calls. I haven't noticed it during testing since prep_new_page() clears page->mapping and therefore page->ptl. It's effectively equal to spin_lock_init(&page->ptl). Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Chris Zankel <chris@zankel.net> Cc: Christoph Lameter <cl@linux.com> Cc: David Howells <dhowells@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Grant Likely <grant.likely@linaro.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Mikael Starvik <starvik@axis.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
