path: root/arch/x86/pci/acpi.c
2009-06-30x86/PCI: get root CRS before scanning childrenYinghai Lu
This allows us to remove adjust_transparent_bridge_resources and give x86_pci_root_bus_res_quirks a chance when _CRS is not used or not there. Acked-by: Gary Hade <garyhade@us.ibm.com> Tested-by: Gary Hade <garyhade@us.ibm.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-30x86/PCI: fix boundary checking when using root CRSYinghai Lu
Don't touch info->res_num if we are out of space. Acked-by: Gary Hade <garyhade@us.ibm.com> Tested-by: Gary Hade <garyhade@us.ibm.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-24Revert "PCI: use ACPI _CRS data by default"Linus Torvalds
This reverts commit 9e9f46c44e487af0a82eb61b624553e2f7118f5b. Quoting from the commit message: "At this point, it seems to solve more problems than it causes, so let's try using it by default. It's an easy revert if it ends up causing trouble." And guess what? The _CRS code causes trouble. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16x86/ACPI: Correct maximum allowed _CRS returned resources and warn if exceededGary Hade
Issue a warning if _CRS returns too many resource descriptors to be accommodated by the fixed size resource array instances. If there is no transparent bridge on the root bus "too many" is the PCI_BUS_NUM_RESOURCES size of the resource array. Otherwise, the last 3 slots of the resource array must be excluded making the maximum (PCI_BUS_NUM_RESOURCES - 3). The current code: - is silent when _CRS returns too many resource descriptors and - incorrectly allows use of the last 3 slots of the resource array for a root bus with a transparent bridge Signed-off-by: Gary Hade <garyhade@us.ibm.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-11PCI: use ACPI _CRS data by defaultJesse Barnes
At this point, it seems to solve more problems than it causes, so let's try using it by default. It's an easy revert if it ends up causing trouble. Reviewed-by: Yinghai Lu <yhlu.kernel@gmail.com> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07x86/PCI: use dev_printk for PCI bus locality messagesBjorn Helgaas
Since pci_bus has a struct device, use dev_printk directly instead of faking it by hand. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07x86/PCI: make PCI bus locality messages more meaningfulBjorn Helgaas
Change PCI bus locality messages so they have a bit more context and look like the rest of PCI, e.g., - bus 01 -> node 0 - bus 04 -> node 0 + pci 0000:01: bus on NUMA node 0 + pci 0000:04: bus on NUMA node 0 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-12-29x86, pci: move arch/x86/pci/pci.h to arch/x86/include/asm/pci_x86.hJaswinder Singh Rajput
Impact: cleanup Now that arch/x86/pci/pci.h is used in a number of other places as well, move the lowlevel x86 pci definitions into the architecture include files. (not to be confused with the existing arch/x86/include/asm/pci.h file, which provides public details about x86 PCI) Tested on: X86_32_UP, X86_32_SMP and X86_64_SMP Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-24x86: PIC, L-APIC and I/O APIC debug informationMaciej W. Rozycki
Dump all the PIC, local APIC and I/O APIC information at the fs_initcall() level, which is after ACPI (if used) has initialised PCI information, making the point of invocation consistent across MP-table and ACPI platforms. Remove explicit calls to print_IO_APIC() from elsewhere. Make the interface of all the functions involved consistent between 32-bit and 64-bit versions and make them all static by default by the means of a New-and-Improved(TM) __apicdebuginit() macro. Note that like print_IO_APIC() all these only output anything if "apic=debug" has been passed to the kernel through the command line. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-09x86/pci: removing subsys_initcall ordering dependenciesRobert Richter
So far subsys_initcalls has been executed in this order depending on the object order in the Makefile: arch/x86/pci/visws.c:subsys_initcall(pcibios_init); arch/x86/pci/numa.c:subsys_initcall(pci_numa_init); arch/x86/pci/acpi.c:subsys_initcall(pci_acpi_init); arch/x86/pci/legacy.c:subsys_initcall(pci_legacy_init); arch/x86/pci/irq.c:subsys_initcall(pcibios_irq_init); arch/x86/pci/common.c:subsys_initcall(pcibios_init); This patch removes the ordering dependency. There is now only one subsys_initcall function that contains subsystem initialization code with a defined order. Signed-off-by: Robert Richter <robert.richter@amd.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08Merge branch 'x86/numa' into x86/develIngo Molnar
Conflicts: arch/x86/Kconfig arch/x86/kernel/e820.c arch/x86/kernel/efi_64.c arch/x86/kernel/mpparse.c arch/x86/kernel/setup.c arch/x86/kernel/setup_32.c arch/x86/mm/init_64.c include/asm-x86/proto.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: don't call pxm_to_node againYinghai Lu
also make bus_numa work even if ACPI_NUMA is not defined. don't call pxm_to_node again, and use node directly. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: make dev_to_node return online nodeYinghai Lu
a numa system (with multi HT chains) may return node without ram. Aka it is not online. Try to get an online node, otherwise return -1. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-08x86: move pci_routirq declaration to pci.hThomas Gleixner
2008-05-05x86/pci: add pci=skip_isa_align command lines.Yinghai Lu
so we don't align the io port start address for pci cards. also move out dmi check out acpi.c, because it has nothing to do with acpi. it could spare some calling when we have several peer root buses. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-26x86: get mp_bus_to_node earlyYinghai Lu
Currently, on an amd k8 system with multi ht chains, the numa_node of pci devices under /sys/devices/pci0000:80/* is always 0, even if that chain is on node 1 or 2 or 3. Workaround: pcibus_to_node(bus) is used when we want to get the node that pci_device is on. In struct device, we already have numa_node member, and we could use dev_to_node()/set_dev_node() to get and set numa_node in the device. set_dev_node is called in pci_device_add() with pcibus_to_node(bus), and pcibus_to_node uses bus->sysdata for nodeid. The problem is when pci_add_device is called, bus->sysdata is not assigned correct nodeid yet. The result is that numa_node will always be 0. pcibios_scan_root and pci_scan_root could take sysdata. So we need to get mp_bus_to_node mapping before these two are called, and thus get_mp_bus_to_node could get correct node for sysdata in root bus. In scanning of the root bus, all child busses will take parent bus sysdata. So all pci_device->dev.numa_node will be assigned correctly and automatically. Later we could use dev_to_node(&pci_dev->dev) to get numa_node, and we could also could make other bus specific device get the correct numa_node too. This is an updated version of pci_sysdata and Jeff's pci_domain patch. [ mingo@elte.hu: build fix ] Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-20PCI: remove "pci=routeirq" noise from dmesgBjorn Helgaas
The "pci=routeirq" option was added in 2004, and I don't get any valid reports anymore. The option is still mentioned in kernel-parameters.txt. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-20PCI: Include PCI domain in PCI bus names on x86/x86_64Gary Hade
The PCI bus names included in /proc/iomem and /proc/ioports are of the form 'PCI Bus #XX' where XX is the bus number. This patch changes the naming to 'PCI Bus XXXX:YY' where XXXX is the domain number and YY is the bus number. For example, PCI bus 14 in domain 0 will show as 'PCI Bus 0000:14' instead of 'PCI Bus #14'. This change makes the naming consistent with other architectures such as ia64 where multiple PCI domain support has been around longer. Signed-off-by: Gary Hade <garyhade@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-15acpi: unneccessary to scan the PCI bus already scannedyakui.zhao@intel.com
http://bugzilla.kernel.org/show_bug.cgi?id=10124 this change: commit 08f1c192c3c32797068bfe97738babb3295bbf42 Author: Muli Ben-Yehuda <muli@il.ibm.com> Date: Sun Jul 22 00:23:39 2007 +0300 x86-64: introduce struct pci_sysdata to facilitate sharing of ->sysdata This patch introduces struct pci_sysdata to x86 and x86-64, and converts the existing two users (NUMA, Calgary) to use it. This lays the groundwork for having other users of sysdata, such as the PCI domains work. The Calgary bits are tested, the NUMA bits just look ok. replaces pcibios_scan_root by pci_scan_bus_parented... but in pcibios_scan_root we have a check about scanned busses. Cc: <yakui.zhao@intel.com> Cc: Stian Jordet <stian@jordet.net> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Yinghai Lu" <yhlu.kernel@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-20Pull fluff into release branchLen Brown
Conflicts: drivers/acpi/ec.c Signed-off-by: Len Brown <len.brown@intel.com>
2007-11-17x86: check boundary in count setup resourceYinghai Lu
need to check info->res_num less than PCI_BUS_NUM_RESOURCES, so info->bus->resource[info->res_num] = res will not beyond of bus resource array when acpi returns too many resource entries. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Gary Hade <gary.hade@us.ibm.com> Cc: Len Brown <lenb@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-16x86: acpi_pciprobe_dmi_table[] must be __devinitdataAdrian Bunk
This patch fixes the following section mismatches with CONFIG_HOTPLUG=n: <-- snip --> ... WARNING: vmlinux.o(.data+0x23640): Section mismatch: reference to .init.text.20:can_skip_ioresource_align (between 'acpi_pciprobe_dmi_table' and 'pcibios_irq_mask') WARNING: vmlinux.o(.data+0x2366c): Section mismatch: reference to .init.text.20:can_skip_ioresource_align (between 'acpi_pciprobe_dmi_table' and 'pcibios_irq_mask') WARNING: vmlinux.o(.data+0x23698): Section mismatch: reference to .init.text.20:can_skip_ioresource_align (between 'acpi_pciprobe_dmi_table' and 'pcibios_irq_mask') ... <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-12x86/pci/acpi: fix DMI const-ification falloutJeff Garzik
Fix DMI const-ification fallout that appeared when merging subsystem trees. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12PCI: X86: Introduce and enable PCI domain supportJeff Garzik
* fix bug in pci_read() and pci_write() which prevented PCI domain support from working (hardcoded domain 0). * unconditionally enable CONFIG_PCI_DOMAINS * implement pci_domain_nr() and pci_proc_domain(), as required of all arches when CONFIG_PCI_DOMAINS is enabled. * store domain in struct pci_sysdata, as assigned by ACPI * support "pci=nodomains" Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12PCI: use _CRS for PCI resource allocationGary Hade
Use _CRS for PCI resource allocation This patch resolves an issue where incorrect PCI memory and i/o ranges are being assigned to hotplugged PCI devices on some IBM systems. The resource mis-allocation not only makes the PCI device unuseable but often makes the entire system unuseable due to resulting machine checks. The hotplug capable PCI slots on the affected systems are not located under a standard P2P bridge but are instead located under PCI root bridges or subtractive decode P2P bridges. For example, the IBM x3850 contains 2 hotplug capable PCI-X slots and 4 hotplug capable PCIe slots with the PCI-X slots each located under a PCI root bridge and the PCIe slots each located under a subtractive decode P2P bridge. The current i386/x86_64 PCI resource allocation code does not use _CRS returned resource information. No other resource information source is available for slots that are not below a standard P2P bridge so incorrect ranges are being allocated from e820 hole causing the bad result. This patch causes the kernel to use _CRS returned resource info. It is roughly based on a change provided by Matthew Wilcox for the ia64 kernel in 2005. Due to possible buggy BIOS factor and possible yet to be discovered kernel issues the function is disabled by default and can be enabled with pci=use_crs. Signed-off-by: Gary Hade <gary.hade@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12PCI: skip ISA ioresource alignment on some systemsGary Hade
Skip ISA ioresource alignment on some systems To conserve limited PCI i/o resource on some IBM multi-node systems, the BIOS allocates (via _CRS) and expects the kernel to use addresses in ranges currently excluded by pcibios_align_resource() [i386/pci/i386.c]. This change allows the kernel to use the currently excluded address ranges on the IBM x3800, x3850, and x3950. Signed-off-by: Gary Hade <gary.hade@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-11i386: move pciThomas Gleixner
