path: root/arch/x86/pci/bus_numa.c
2010-03-03Merge branch 'x86-bootmem-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-bootmem-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits) early_res: Need to save the allocation name in drop_range_partial() sparsemem: Fix compilation on PowerPC early_res: Add free_early_partial() x86: Fix non-bootmem compilation on PowerPC core: Move early_res from arch/x86 to kernel/ x86: Add find_fw_memmap_area Move round_up/down to kernel.h x86: Make 32bit support NO_BOOTMEM early_res: Enhance check_and_double_early_res x86: Move back find_e820_area to e820.c x86: Add find_early_area_size x86: Separate early_res related code from e820.c x86: Move bios page reserve early to head32/64.c sparsemem: Put mem map for one node together. sparsemem: Put usemap for one node together x86: Make 64 bit use early_res instead of bootmem before slab x86: Only call dma32_reserve_bootmem 64bit !CONFIG_NUMA x86: Make early_node_mem get mem > 4 GB if possible x86: Dynamically increase early_res array size x86: Introduce max_early_res and early_res_count ...
2010-02-23PCI: augment bus resource table with a listBjorn Helgaas
Previously we used a table of size PCI_BUS_NUM_RESOURCES (16) for resources forwarded to a bus by its upstream bridge. We've increased this size several times when the table overflowed. But there's no good limit on the number of resources because host bridges and subtractive decode bridges can forward any number of ranges to their secondary buses. This patch reduces the table to only PCI_BRIDGE_RESOURCE_NUM (4) entries, which corresponds to the number of windows a PCI-to-PCI (3) or CardBus (4) bridge can positively decode. Any additional resources, e.g., PCI host bridge windows or subtractively-decoded regions, are kept in a list. I'd prefer a single list rather than this split table/list approach, but that requires simultaneous changes to every architecture. This approach only requires immediate changes where we set up (a) host bridges with more than four windows and (b) subtractive-decode P2P bridges, and we can incrementally change other architectures to use the list. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-10x86/pci: Add cap_resource()Yinghai Lu
Prepare for 32bit pci root bus -v2: hpa said we should compare with (resource_size_t)~0 -v3: according to Linus to use MAX_RESOURCE instead. also need need to put related patches together -v4: according to Andrew, use min in cap_resource() Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <1265793639-15071-8-git-send-email-yinghai@kernel.org> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-02-10x86/pci: AMD one chain system to use pci read out resYinghai Lu
Found MSI amd k8 based laptops is hiding [0x70000000, 0x80000000) RAM from e820. enable amd one chain even for all. -v2: use bool for found, according to Andrew Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <1265793639-15071-6-git-send-email-yinghai@kernel.org> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-02-10x86/pci: Use resource_size_t in update_resYinghai Lu
Prepare to enable 32bit intel and amd bus. Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <1265793639-15071-5-git-send-email-yinghai@kernel.org> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-16PCI: fix section mismatch on update_res()Jiri Slaby
Remark update_res from __init to __devinit as it is called also from __devinit functions. This patch removes the following warning message: WARNING: vmlinux.o(.devinit.text+0x774a): Section mismatch in reference from the function pci_root_bus_res() to the function .init.text:update_res() The function __devinit pci_root_bus_res() references a function __init update_res(). If update_res is only used by pci_root_bus_res then annotate update_res with a matching annotation. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Aristeu Sergio <arozansk@redhat.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: linux-pci@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-24x86/pci: seperate x86_pci_rootbus_res_quirks from amd_bus.cYinghai Lu
Those functions are used by intel_bus.c so seperate them to another file. and make amd_bus a bit smaller. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
