The DMI tables are only used in __init code, thereby can be marked as
initialization data, too. The same is true for the callback functions
referenced from the DMI tables.
This moves ~9.6 kB of code and r/o data to the init sections, marking the
memory for release after initialization.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Pull x86 old platform removal from Peter Anvin:
"This patchset removes support for several completely obsolete
platforms, where the maintainers either have completely vanished or
acked the removal. For some of them it is questionable if there even
exists functional specimens of the hardware"
Geert Uytterhoeven apparently thought this was a April Fool's pull request ;)
* 'x86-nuke-platforms-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, platforms: Remove NUMAQ
x86, platforms: Remove SGI Visual Workstation
x86, apic: Remove support for IBM Summit/EXA chipset
x86, apic: Remove support for ia32-based Unisys ES7000
The SGI Visual Workstation seems to be dead; remove support so we
don't have to continue maintaining it.
Cc: Andrey Panin <pazke@donpac.ru>
Cc: Michael Reed <mdr@sgi.com>
Link: http://lkml.kernel.org/r/530CFD6C.7040705@zytor.com
There are no callers of get_mp_bus_to_node(), so we no longer need
mp_bus_to_node[], get_mp_bus_to_node(), or set_mp_bus_to_node().
This removes them.
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
This replaces all uses of get_mp_bus_to_node() with x86_pci_root_bus_node().
I think these uses are all on root buses, except possibly for blind
probing, where NUMA node information is unimportant.
Nobody really uses the return value of pcibios_scan_root() (one place uses
it to control a printk, but the printk is not very useful). This converts
pcibios_scan_root() to a void function.
pci_scan_bus_on_node() is only called by pcibios_scan_root().
This merges pci_scan_bus_on_node() into pcibios_scan_root() and removes
pci_scan_bus_on_node().
pci_scan_bus_with_sysdata() and pcibios_scan_root() are quite similar:
pci_scan_bus_on_node(..., &pci_root_ops, -1)
pcibios_scan_root
pci_scan_bus_on_node(..., &pci_root_ops, get_mp_bus_to_node(busnum))
get_mp_bus_to_node() returns -1 if it couldn't find the node number, so
this removes pci_scan_bus_with_sysdata() and uses pcibios_scan_root()
instead.
The PCI core checks to see whether we've already scanned a bus, so we don't
need to do it in pcibios_scan_root(). Here's where it happens in the core:
pcibios_scan_root
pci_scan_root_bus
pci_create_root_bus
b2 = pci_find_bus(pci_domain_nr(b), bus)
if (b2)
goto err_out; # already scanned this bus
This removes the check from pcibios_scan_root().
f9a37be0f0 ("x86: Use PCI setup data") added support for using PCI ROM
images from setup_data. This used phys_to_virt(), which is not valid for
highmem addresses, and can cause a crash when booting a 32-bit kernel via
the EFI boot stub.
pcibios_add_device() assumes that the physical addresses stored in
setup_data are accessible via the direct kernel mapping, and that calling
phys_to_virt() is valid. This isn't guaranteed to be true on x86 where the
direct mapping range is much smaller than on x86-64.
Calling phys_to_virt() on a highmem address results in the following:
BUG: unable to handle kernel paging request at 39a3c198
IP: [<c262be0f>] pcibios_add_device+0x2f/0x90
Call Trace:
[<c2370c73>] pci_device_add+0xe3/0x130
[<c274640b>] pci_scan_single_device+0x8b/0xb0
[<c2370d08>] pci_scan_slot+0x48/0x100
[<c2371904>] pci_scan_child_bus+0x24/0xc0
[<c262a7b0>] pci_acpi_scan_root+0x2c0/0x490
[<c23b7203>] acpi_pci_root_add+0x312/0x42f
The solution is to use ioremap() instead of phys_to_virt() to map the
setup data into the kernel address space.
[bhelgaas: changelog]
Tested-by: Jani Nikula <jani.nikula@intel.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Seth Forshee <seth.forshee@canonical.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: stable@vger.kernel.org # v3.8+
Implement pcibios_{add|remove}_bus() hooks for x86 platforms.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Reviewed-by: Yinghai Lu <yinghai@kernel.org>
Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Myron Stowe <myron.stowe@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI changes from Bjorn Helgaas:
"Host bridge hotplug
- Major overhaul of ACPI host bridge add/start (Rafael Wysocki, Yinghai Lu)
- Major overhaul of PCI/ACPI binding (Rafael Wysocki, Yinghai Lu)
- Split out ACPI host bridge and ACPI PCI device hotplug (Yinghai Lu)
- Stop caching _PRT and make independent of bus numbers (Yinghai Lu)
PCI device hotplug
- Clean up cpqphp dead code (Sasha Levin)
- Disable ARI unless device and upstream bridge support it (Yijing Wang)
- Initialize all hot-added devices (not functions 0-7) (Yijing Wang)
Power management
- Don't touch ASPM if disabled (Joe Lawrence)
- Fix ASPM link state management (Myron Stowe)
Miscellaneous
- Fix PCI_EXP_FLAGS accessor (Alex Williamson)
- Disable Bus Master in pci_device_shutdown (Konstantin Khlebnikov)
- Document hotplug resource and MPS parameters (Yijing Wang)
- Add accessor for PCIe capabilities (Myron Stowe)
- Drop pciehp suspend/resume messages (Paul Bolle)
- Make pci_slot built-in only (not a module) (Jiang Liu)
- Remove unused PCI/ACPI bind ops (Jiang Liu)
- Removed used pci_root_bus (Bjorn Helgaas)"
* tag 'pci-v3.9-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (51 commits)
PCI/ACPI: Don't cache _PRT, and don't associate them with bus numbers
PCI: Fix PCI Express Capability accessors for PCI_EXP_FLAGS
ACPI / PCI: Make pci_slot built-in only, not a module
PCI/PM: Clear state_saved during suspend
PCI: Use atomic_inc_return() rather than atomic_add_return()
PCI: Catch attempts to disable already-disabled devices
PCI: Disable Bus Master unconditionally in pci_device_shutdown()
PCI: acpiphp: Remove dead code for PCI host bridge hotplug
PCI: acpiphp: Create companion ACPI devices before creating PCI devices
PCI: Remove unused "rc" in virtfn_add_bus()
PCI: pciehp: Drop suspend/resume ENTRY messages
PCI/ASPM: Don't touch ASPM if forcibly disabled
PCI/ASPM: Deallocate upstream link state even if device is not PCIe
PCI: Document MPS parameters pci=pcie_bus_safe, pci=pcie_bus_perf, etc
PCI: Document hpiosize= and hpmemsize= resource reservation parameters
PCI: Use PCI Express Capability accessor
PCI: Introduce accessor to retrieve PCIe Capabilities Register
PCI: Put pci_dev in device tree as early as possible
PCI: Skip attaching driver in device_add()
PCI: acpiphp: Keep driver loaded even if no slots found
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitconst,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Daniel Drake <dsd@laptop.org>
pci_root_bus is unused, so remove all references to it.
Commit 284f5f9 was intended to disable the "only_one_child()" optimization
on Stratus ftServer systems, but its DMI check is wrong. It looks for
DMI_SYS_VENDOR that contains "ftServer", when it should look for
DMI_SYS_VENDOR containing "Stratus" and DMI_PRODUCT_NAME containing
"ftServer".
Tested on Stratus ftServer 6400.
Reported-by: Fadeeva Marina <astarta@rat.ru>
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=51331
Signed-off-by: Myron Stowe <myron.stowe@redhat.com>
CC: stable@vger.kernel.org # v3.5+
* pci/mjg-pci-roms-from-efi:
PCI: Use phys_addr_t for physical ROM address
Use phys_addr_t rather than "void *" for physical memory address.
This removes casts and fixes a "cast from pointer to integer of different
size" warning on ppc44x_defconfig.
PCI: Add support for non-BAR ROMs
PCI: Add pcibios_add_device
EFI: Stash ROMs if they're not in the PCI BAR
EFI can provide PCI ROMs out of band via boot services, which may not be
available after boot. Add support for using the data handed off to us by
the boot stub or bootloader.
[bhelgaas: added Seth's boot_params section mismatch fix]
[bhelgaas: drop "boot_params.hdr.version < 0x0209" test]
Tested-by: Seth Forshee <seth.forshee@canonical.com>
pci_ext_cfg_avail() doesn't use the "struct pci_dev *" passed to
it, and there's no requirement that a host bridge even be represented
by a pci_dev. This drops the pci_ext_cfg_avail() parameter.
Signed-off-by: Taku Izumi <izumi.taku@jp.fujitsu.com>
Make pcibios_setup() consistently use the "__init" section annotation.
A PCIe downstream port is a P2P bridge. Its secondary interface is
a link that should lead only to device 0 (unless ARI is enabled)[1], so
we don't probe for non-zero device numbers.
Some Stratus ftServer systems have a PCIe downstream port (02:00.0) that
leads to both an upstream port (03:00.0) and a downstream port (03:01.0),
and 03:01.0 has important devices below it:
[0000:02]-+-00.0-[03-3c]--+-00.0-[04-09]--...
\-01.0-[0a-0d]--+-[USB]
+-[NIC]
Previously, we didn't enumerate device 03:01.0, so USB and the network
didn't work. This patch adds a DMI quirk to scan all device numbers,
not just 0, below a downstream port.
Based on a patch by Prarit Bhargava.
[1] PCIe spec r3.0, sec 7.3.1
CC: Myron Stowe <mstowe@redhat.com>
CC: Don Dutile <ddutile@redhat.com>
CC: James Paradis <james.paradis@stratus.com>
CC: Matthew Wilcox <matthew.r.wilcox@intel.com>
CC: Jesse Barnes <jbarnes@virtuousgeek.org>
CC: Prarit Bhargava <prarit@redhat.com>
pcibios_scan_root() and pci_scan_bus_on_node() were almost identical,
so this patch merges them.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
x86 has two kinds of PCI root bus scanning:
(1) ACPI-based, using _CRS resources. This used pci_create_bus(), not
pci_scan_bus(), because ACPI hotplug needed to split the
pci_bus_add_devices() into a separate host bridge .start() method.
This patch parses the _CRS resources earlier, so we can build a list of
resources and pass it to pci_create_root_bus().
Note that as before, we parse the _CRS even if we aren't going to use
it so we can print it for debugging purposes.
(2) All other, which used either default resources (ioport_resource and
iomem_resource) or information read from the hardware via amd_bus.c or
similar. This used pci_scan_bus().
This patch converts x86_pci_root_bus_res_quirks() (previously called
from pcibios_fixup_bus()) to x86_pci_root_bus_resources(), which builds
a list of resources before we call pci_scan_root_bus().
We also use x86_pci_root_bus_resources() if we have ACPI but are
ignoring _CRS.
CC: Yinghai Lu <yinghai.lu@oracle.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
This doesn't change any functionality, but it makes a subsequent patch
slightly simpler.
pci_scan_bus(NULL, ...) and pci_scan_bus_parented() are identical except
that pci_scan_bus() also calls pci_bus_add_devices():
pci_create_bus
pci_scan_child_bus
pci_scan_bus
pci_create_bus
pci_scan_child_bus
pci_bus_add_devices
All callers of pcibios_scan_root() call pci_bus_add_devices() explicitly,
and we don't pass a parent device, so we might as well use pci_scan_bus().
As with any other such change, the goal is to prevent inadvertent
writes to these structures (assuming DEBUG_RODATA is enabled), and to
separate data (possibly frequently) written to from such never getting
modified.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Commit 6e8af08dfa40b747002207d3ce8e8b43a050d99f enables pci=bfsort on
future Dell systems. But the identification string 'Dell System' matches
on already existing whitelist, which do not have SMBIOS type 0xB1,
causing pci=bfsort not being set on existing whitelist.
This patch fixes the regression by moving the type 0xB1 check beyond the
existing whitelist so that existing whitelist is walked before.
Signed-off-by: Shyam Iyer <shyam_iyer@dell.com>
Signed-off-by: Narendra K <narendra_k@dell.com>
This patch enables pci=bfsort by default on future Dell systems.
It reads SMBIOS type 0xB1 vendor specific record and sets pci=bfsort
accordingly.
Offset Name Length Value Description
04 Flags0 Word Varies Bits 9-10
- 10:9 = 00 Unknown
- 10:9 = 01 Breadth First
- 10:9 = 10 Depth First
- 10:9 = 11 Reserved
1. Any time pci=bfsort has to be enabled on a system, we need to add the
model number of the system to the white list. With this patch, that
is not required.
2. Typically, model number has to be added to the white list when the
system is under development. With this change, that is not required.
Signed-off-by: Jordan Hargrave <jordan_hargrave@dell.com>
Separate out x86 cache_line_size initialisation code into its own
function (so it can be shared by Xen later in this patch series)
[ Impact: cleanup ]
Signed-off-by: Alex Nixon <alex.nixon@citrix.com>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: "H. Peter Anvin" <hpa@zytor.com>
Reviewed-by: Matthew Wilcox <willy@linux.intel.com>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: x86@kernel.org
The Linux kernel assigns BARs that a BIOS did not assign, most likely
to handle broken BIOSes that didn't enumerate the devices correctly.
On UV the BIOS purposely doesn't assign I/O BARs for certain devices/
drivers we know don't use them (examples, LSI SAS, Qlogic FC, ...).
We purposely don't assign these I/O BARs because I/O Space is a very
limited resource. There is only 64k of I/O Space, and in a PCIe
topology that space gets divided up into 4k chucks (this is due to
the fact that a pci-to-pci bridge's I/O decoder is aligned at 4k)...
Thus a system can have at most 16 cards with I/O BARs: (64k / 4k = 16)
SGI needs to scale to >16 devices with I/O BARs. So by not assigning
I/O BARs on devices we know don't use them, we can do that (iff the
kernel doesn't go and assign these BARs that the BIOS purposely didn't
assign).
This patch will not assign a resource to a device BAR if that BAR was
not assigned by the BIOS, and the kernel cmdline option 'pci=nobar'
was specified. This patch is closely modeled after the 'pci=norom'
option that currently exists in the tree.
Signed-off-by: Mike Habeck <habeck@sgi.com>
Signed-off-by: Mike Travis <travis@sgi.com>
pci_config_lock must be a real spinlock in preempt-rt. Convert it to
raw_spinlock. No change for !RT kernels.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* 'x86-mrst-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits)
x86, mrst: Fix whitespace breakage in apb_timer.c
x86, mrst: Fix APB timer per cpu clockevent
x86, mrst: Remove X86_MRST dependency on PCI_IOAPIC
x86, olpc: Use pci subarch init for OLPC
x86, pci: Add arch_init to x86_init abstraction
x86, mrst: Add Kconfig dependencies for Moorestown
x86, pci: Exclude Moorestown PCI code if CONFIG_X86_MRST=n
x86, numaq: Make CONFIG_X86_NUMAQ depend on CONFIG_PCI
x86, pci: Add sanity check for PCI fixed bar probing
x86, legacy_irq: Remove duplicate vector assigment
x86, legacy_irq: Remove left over nr_legacy_irqs
x86, mrst: Platform clock setup code
x86, apbt: Moorestown APB system timer driver
x86, mrst: Add vrtc platform data setup code
x86, mrst: Add platform timer info parsing code
x86, mrst: Fill in PCI functions in x86_init layer
x86, mrst: Add dummy legacy pic to platform setup
x86/PCI: Moorestown PCI support
x86, ioapic: Add dummy ioapic functions
x86, ioapic: Early enable ioapic for timer irq
Fixed up semantic conflict of new clocksources due to commit
17622339af25 ("clocksource: add argument to resume callback").
The main benefit of using ACPI host bridge window information is that
we can do better resource allocation in systems with multiple host bridges,
e.g., http://bugzilla.kernel.org/show_bug.cgi?id=14183
Sometimes we need _CRS information even if we only have one host bridge,
e.g., https://bugs.launchpad.net/ubuntu/+source/linux/+bug/341681
Most of these systems are relatively new, so this patch turns on
"pci=use_crs" only on machines with a BIOS date of 2008 or newer.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
The PCI initialization in pci_subsys_init() is a mess. pci_numaq_init,
pci_acpi_init, pci_visws_init and pci_legacy_init are called and each
implementation checks and eventually modifies the global variable
pcibios_scanned.
x86_init functions allow us to do this more elegant. The pci.init
function pointer is preset to pci_legacy_init. numaq, acpi and visws
can modify the pointer in their early setup functions. The functions
return 0 when they did the full initialization including bus scan. A
non zero return value indicates that pci_legacy_init needs to be
called either because the selected function failed or wants the
generic bus scan in pci_legacy_init to happen (e.g. visws).
LKML-Reference: <43F901BD926A4E43B106BF17856F07559FB80CFE@orsmsx508.amr.corp.intel.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Jacob Pan <jacob.jun.pan@intel.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Instead of the PCI code needing to have code to determine the
cacheline size of each processor, use the data the cpu identification
code should have already determined during early boot.
(The vendor checks are also incomplete, and don't take into account
modern CPUs)
I've been carrying a variant of this code in Fedora for a while,
that prints debug information. There are a number of cases where we
are currently setting the PCI cacheline size to 32 bytes, when the CPU
cacheline size is 64 bytes. With this patch, we set them both the same.
Signed-off-by: Dave Jones <davej@redhat.com>
Till now, CLS has been determined either by arch code or as
L1_CACHE_BYTES. Only x86 and ia64 set CLS explicitly and x86 doesn't
always get it right. On most configurations, the chance is that
firmware configures the correct value during boot.
This patch makes pci_init() determine CLS by looking at what firmware
has configured. It scans all devices and if all non-zero values
agree, the value is used. If none is configured or there is a
disagreement, pci_dfl_cache_line_size is used. arch can set the dfl
value (via PCI_CACHE_LINE_BYTES or pci_dfl_cache_line_size) or
override the actual one.
ia64, x86 and sparc64 updated to set the default cls instead of the
actual one.
While at it, declare pci_cache_line_size and pci_dfl_cache_line_size
in pci.h and drop private declarations from arch code.
Acked-by: David Miller <davem@davemloft.net>
Acked-by: Greg KH <gregkh@suse.de>
We use -1 to indicate no node affinity, so we need a signed type here or
all sorts of bad things happen, like crashes in dev_attr_show as
reported by Ingo:
[ 158.058140] warning: `dbus-daemon' uses 32-bit capabilities (legacy support in use)
[ 159.370562] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 159.372694] IP: [<ffffffff8143b722>] bitmap_scnprintf+0x72/0xd0
[ 159.372694] PGD 71d3e067 PUD 7052e067 PMD 0
[ 159.372694] Oops: 0000 [#1] SMP DEBUG_PAGEALLOC
[ 159.372694] last sysfs file: /sys/devices/pci0000:00/0000:00:01.0/local_cpus
[ 159.372694] CPU 0
[ 159.372694] Pid: 7364, comm: irqbalance Not tainted 2.6.31-tip #8043 System Product Name
[ 159.372694] RIP: 0010:[<ffffffff8143b722>] [<ffffffff8143b722>] bitmap_scnprintf+0x72/0xd0
[ 159.372694] RSP: 0018:ffff8800712a1e38 EFLAGS: 00010246
[ 159.372694] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
[ 159.372694] RDX: 0000000000000000 RSI: 0000000000000004 RDI: ffff880077dc5000
[ 159.372694] RBP: ffff8800712a1e68 R08: 0000000000000001 R09: 0000000000000001
[ 159.372694] R10: ffffffff8215c47c R11: 0000000000000000 R12: 0000000000000000
[ 159.372694] R13: 0000000000000000 R14: 0000000000000ffe R15: ffff880077dc5000
[ 159.372694] FS: 00007f5f578f76f0(0000) GS:ffff880007000000(0000) knlGS:0000000000000000
[ 159.372694] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 159.372694] CR2: 0000000000000000 CR3: 0000000071a77000 CR4: 00000000000006f0
[ 159.372694] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 159.372694] DR3: ffffffff835109dc DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 159.372694] Process irqbalance (pid: 7364, threadinfo ffff8800712a0000, task ffff880070773000)
[ 159.372694] Stack:
[ 159.372694] 2222222222222222 ffff880077dc5000 fffffffffffffffb ffff88007d366b40
[ 159.372694] <0> ffff8800712a1f48 ffff88007d3840a0 ffff8800712a1e88 ffffffff8146332b
[ 159.372694] <0> fffffffffffffff4 ffffffff82450718 ffff8800712a1ea8 ffffffff815a9a1f
[ 159.372694] Call Trace:
[ 159.372694] [<ffffffff8146332b>] local_cpus_show+0x3b/0x60
[ 159.372694] [<ffffffff815a9a1f>] dev_attr_show+0x2f/0x60
[ 159.372694] [<ffffffff8118ee6f>] sysfs_read_file+0xbf/0x1d0
[ 159.372694] [<ffffffff8112afe9>] vfs_read+0xc9/0x180
[ 159.372694] [<ffffffff8112c365>] sys_read+0x55/0x90
[ 159.372694] [<ffffffff810114f2>] system_call_fastpath+0x16/0x1b
[ 159.372694] Code: 41 b9 01 00 00 00 44 8d 46 03 49 63 fc 0f 49 d3 c1 f8 1f 4c 01 ff c1 e8 1a c1 fa 06 41 c1 e8 02 8d 0c 03 48 63 d2 83 e1 3f 29 c1 <49> 8b 44 d5 00 48 c7 c2 8c 37 16 82 48 d3 e8 89 f1 44 89 f6 49
[ 159.372694] RIP [<ffffffff8143b722>] bitmap_scnprintf+0x72/0xd0
[ 159.372694] RSP <ffff8800712a1e38>
[ 159.600828] ---[ end trace 35550c356e84e60c ]---
Reported-by: Ingo Molnar <mingo@elte.hu>
Tested-by: Ingo Molnar <mingo@elte.hu>
The current mp_bus_to_node array is initialized only by AMD specific
code, since AMD platforms have registers that can be used for
determining mode numbers. On new Intel platforms it's necessary to
initialize this array as well though, otherwise all PCI node numbers
will be 0, when in fact they should be -1 (indicating that I/O isn't
tied to any particular node).
So move the mp_bus_to_node code into the common PCI code, and
initialize it early with a default value of -1. This may be overridden
later by arch code (e.g. the AMD code).
With this change, PCI consistent memory and other node specific
allocations (e.g. skbuff allocs) should occur on the "current" node.
If, for performance reasons, applications want to be bound to specific
nodes, they should open their devices only after being pinned to the
CPU where they'll run, for maximum locality.
Acked-by: Yinghai Lu <yinghai@kernel.org>
Tested-by: Jesse Brandeburg <jesse.brandeburg@gmail.com>
This reverts commit 9e9f46c44e487af0a82eb61b624553e2f7118f5b.
Quoting from the commit message:
"At this point, it seems to solve more problems than it causes, so let's
try using it by default. It's an easy revert if it ends up causing
trouble."
And guess what? The _CRS code causes trouble.
At this point, it seems to solve more problems than it causes, so let's try using it by default. It's an easy revert if it ends up causing trouble.
Reviewed-by: Yinghai Lu <yhlu.kernel@gmail.com>
Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Rename set_pci_bus_resources_arch_default to x86_pci_root_bus_res_quirks, move
the weak version from common.c to i386.c, and before calling, make sure it's a
root bus.
Commit 30a18d6c3f1e774de656ebd8ff219d53e2ba4029 introduced a new
function to set the PCI bus resources. Unfortunately, neither the
author, nor the committers seemed to know that we already have somewhere
to do that -- pcibios_fixup_bus(). This patch moves the hook (used only
by the K8 code) into x86-specific code where it should have been in the
first place.
Cc: Yinghai Lu <yinghai.lu@sun.com>
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Impact: debuggability and micro-optimization
Putting whatever is possible into the (final) .rodata section increases
the likelihood of catching memory corruption bugs early, and reduces
false cache line sharing.
LKML-Reference: <49B909A5.76E4.0078.0@novell.com>
pcibios_enable_device() and pcibios_disable_device() don't handle
IRQs for devices that have MSI enabled and it should treat the
devices with MSI-X enabled in the same way.
The _OSC capability OSC_EXT_PCI_CONFIG_SUPPORT is set when the root
bridge is added with pci_acpi_osc_support() if we can access PCI
extended config space.
This adds the function pci_ext_cfg_avail which returns true if we can
access PCI extended config space (offset greater than 0xff). It
currently only returns false if arch=x86 and raw_pci_ext_ops is not set
(which might happen if pci=nommcfg is set on the kernel command-line).
Signed-off-by: Andrew Patterson <andrew.patterson@hp.com>
Impact: cleanup
Now that arch/x86/pci/pci.h is used in a number of other places as well,
move the lowlevel x86 pci definitions into the architecture include files.
(not to be confused with the existing arch/x86/include/asm/pci.h file,
which provides public details about x86 PCI)
Tested on: X86_32_UP, X86_32_SMP and X86_64_SMP
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Boot IRQ quirks for Broadcom and AMD/ATI)
This is against linux-2.6-tip, branch pci-ioapic-boot-irq-quirks.
Subject: Introduce config option for pci reroute quirks
The config option X86_REROUTE_FOR_BROKEN_BOOT_IRQS is introduced to
enable (or disable) the redirection of the interrupt handler to the boot
interrupt line by default. Depending on the existence of interrupt
masking / threaded interrupt handling in the kernel (vanilla, rt, ...)
and the maturity of the rerouting patch, users can enable or disable the
redirection by default.
This means that the reroute quirk can be applied to any kernel without
changing it.
Interrupt sharing could be increased if this option is enabled. However this
option is vital for threaded interrupt handling, as done by the RT kernel.
It should simplify the consolidation with the RT kernel.
The option can be overridden by either pci=ioapicreroute or
pci=noioapicreroute.
Signed-off-by: Stefan Assmann <sassmann@suse.de>
Signed-off-by: Olaf Dabrunz <od@suse.de>
Cc: Jon Masters <jonathan@jonmasters.org>
Cc: Ihno Krumreich <ihno@suse.de>
Cc: Sven Dietrich <sdietrich@suse.de>
Cc: Daniel Gollub <dgollub@suse.de>
Cc: Felix Foerster <ffoerster@suse.de>
drivers/pci/quirks.c
