path: root/arch/x86/pci/init.c
2008-05-05x86 PCI: call dmi_check_pciprobe()Yinghai Lu
this change: | commit 08f1c192c3c32797068bfe97738babb3295bbf42 | Author: Muli Ben-Yehuda <muli@il.ibm.com> | Date: Sun Jul 22 00:23:39 2007 +0300 | | x86-64: introduce struct pci_sysdata to facilitate sharing of ->sysdata | | This patch introduces struct pci_sysdata to x86 and x86-64, and | converts the existing two users (NUMA, Calgary) to use it. | | This lays the groundwork for having other users of sysdata, such as | the PCI domains work. | | The Calgary bits are tested, the NUMA bits just look ok. replaces pcibios_scan_root with pci_scan_bus_parented... but in pcibios_scan_root we have a DMI check: dmi_check_system(pciprobe_dmi_table); when when have several peer root buses this could be called multiple times (which is bad), so move that call to pci_access_init(). Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-05-05x86/pci: add pci=skip_isa_align command lines.Yinghai Lu
so we don't align the io port start address for pci cards. also move out dmi check out acpi.c, because it has nothing to do with acpi. it could spare some calling when we have several peer root buses. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-bigbox-pci * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-bigbox-pci: x86: add pci=check_enable_amd_mmconf and dmi check x86: work around io allocation overlap of HT links acpi: get boot_cpu_id as early for k8_scan_nodes x86_64: don't need set default res if only have one root bus x86: double check the multi root bus with fam10h mmconf x86: multi pci root bus with different io resource range, on 64-bit x86: use bus conf in NB conf fun1 to get bus range on, on 64-bit x86: get mp_bus_to_node early x86 pci: remove checking type for mmconfig probe x86: remove unneeded check in mmconf reject driver core: try parent numa_node at first before using default x86: seperate mmconf for fam10h out from setup_64.c x86: if acpi=off, force setting the mmconf for fam10h x86_64: check MSR to get MMCONFIG for AMD Family 10h x86_64: check and enable MMCONFIG for AMD Family 10h x86_64: set cfg_size for AMD Family 10h in case MMCONFIG x86: mmconf enable mcfg early x86: clear pci_mmcfg_virt when mmcfg get rejected x86: validate against acpi motherboard resources Fixed up fairly trivial conflicts in arch/x86/pci/{init.c,pci.h} due to OLPC support manually.
2008-04-29x86: olpc: add One Laptop Per Child architecture supportAndres Salomon
This adds support for OLPC XO hardware. Open Firmware on XOs don't contain the VSA, so it is necessary to emulate the PCI BARs in the kernel. This also adds functionality for running EC commands, and a CONFIG_OLPC. A number of OLPC drivers depend upon CONFIG_OLPC. olpc_ec_timeout is a hack to work around Embedded Controller bugs. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: geode_has_vsa build fix] [akpm@linux-foundation.org: olpc_register_battery_callback doesn't exist] Signed-off-by: Andres Salomon <dilinger@debian.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@suse.de> Cc: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-26x86 pci: remove checking type for mmconfig probeYinghai Lu
doesn't need to check if it is type1 or type2, we can use raw_pci_ops directly. also make pci_direct_conf1 static again. anyway is there system with type 2 and mmconf support? Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86: validate against acpi motherboard resourcesRobert Hancock
This path adds validation of the MMCONFIG table against the ACPI reserved motherboard resources. If the MMCONFIG table is found to be reserved in ACPI, we don't bother checking the E820 table. The PCI Express firmware spec apparently tells BIOS developers that reservation in ACPI is required and E820 reservation is optional, so checking against ACPI first makes sense. Many BIOSes don't reserve the MMCONFIG region in E820 even though it is perfectly functional, the existing check needlessly disables MMCONFIG in these cases. In order to do this, MMCONFIG setup has been split into two phases. If PCI configuration type 1 is not available then MMCONFIG is enabled early as before. Otherwise, it is enabled later after the ACPI interpreter is enabled, since we need to be able to execute control methods in order to check the ACPI reserved resources. Presently this is just triggered off the end of ACPI interpreter initialization. There are a few other behavioral changes here: - Validate all MMCONFIG configurations provided, not just the first one. - Validate the entire required length of each configuration according to the provided ending bus number is reserved, not just the minimum required allocation. - Validate that the area is reserved even if we read it from the chipset directly and not from the MCFG table. This catches the case where the BIOS didn't set the location properly in the chipset and has mapped it over other things it shouldn't have. This also cleans up the MMCONFIG initialization functions so that they simply do nothing if MMCONFIG is not compiled in. Based on an original patch by Rajesh Shah from Intel. [akpm@linux-foundation.org: many fixes and cleanups] Signed-off-by: Robert Hancock <hancockr@shaw.ca> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Andi Kleen <ak@suse.de> Cc: Rajesh Shah <rajesh.shah@intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andi Kleen <ak@suse.de> Cc: Greg KH <greg@kroah.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-11i386: move pciThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
