path: root/arch/x86/pci/mmconfig-shared.c
2008-04-26x86: add pci=check_enable_amd_mmconf and dmi checkYinghai Lu
so will disable that feature by default, and only enable that via pci=check_enable_amd_mmconf or for system match with dmi table. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-26x86 pci: remove checking type for mmconfig probeYinghai Lu
doesn't need to check if it is type1 or type2, we can use raw_pci_ops directly. also make pci_direct_conf1 static again. anyway is there system with type 2 and mmconf support? Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86: remove unneeded check in mmconf rejectYinghai Lu
mmconfig is only used to access extended configuration space. so don't need to reject MFG that only have one entry and only handle bus0. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86_64: check MSR to get MMCONFIG for AMD Family 10hYinghai Lu
so even booting kernel with acpi=off or even MCFG is not there, we still can use MMCONFIG. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Cc: Andi Kleen <ak@suse.de> Cc: Greg KH <greg@kroah.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86: mmconf enable mcfg earlyYinghai Lu
Patch "x86: validate against ACPI motherboard resources" changed the mmconf init sequence, and init MMCONF late in acpi_init. here change it back to old sequence: 1. check hostbridge in early 2. check MCFG with e820 in early 3. if all fail, will check MCFg with acpi _CRS in acpi_init So we can make MCONF working again when acpi=off is set if hostbridge support that. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Greg KH <greg@kroah.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-26x86: clear pci_mmcfg_virt when mmcfg get rejectedYinghai Lu
For x86_64, need to free pci_mmcfg_virt, and iounmap some pointers when MMCONF is not reserved in E820 or acpi _CRS and get rejected. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Greg KH <greg@kroah.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-26x86: validate against acpi motherboard resourcesRobert Hancock
This path adds validation of the MMCONFIG table against the ACPI reserved motherboard resources. If the MMCONFIG table is found to be reserved in ACPI, we don't bother checking the E820 table. The PCI Express firmware spec apparently tells BIOS developers that reservation in ACPI is required and E820 reservation is optional, so checking against ACPI first makes sense. Many BIOSes don't reserve the MMCONFIG region in E820 even though it is perfectly functional, the existing check needlessly disables MMCONFIG in these cases. In order to do this, MMCONFIG setup has been split into two phases. If PCI configuration type 1 is not available then MMCONFIG is enabled early as before. Otherwise, it is enabled later after the ACPI interpreter is enabled, since we need to be able to execute control methods in order to check the ACPI reserved resources. Presently this is just triggered off the end of ACPI interpreter initialization. There are a few other behavioral changes here: - Validate all MMCONFIG configurations provided, not just the first one. - Validate the entire required length of each configuration according to the provided ending bus number is reserved, not just the minimum required allocation. - Validate that the area is reserved even if we read it from the chipset directly and not from the MCFG table. This catches the case where the BIOS didn't set the location properly in the chipset and has mapped it over other things it shouldn't have. This also cleans up the MMCONFIG initialization functions so that they simply do nothing if MMCONFIG is not compiled in. Based on an original patch by Rajesh Shah from Intel. [akpm@linux-foundation.org: many fixes and cleanups] Signed-off-by: Robert Hancock <hancockr@shaw.ca> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Andi Kleen <ak@suse.de> Cc: Rajesh Shah <rajesh.shah@intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andi Kleen <ak@suse.de> Cc: Greg KH <greg@kroah.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-10Change pci_raw_ops to pci_raw_read/writeMatthew Wilcox
We want to allow different implementations of pci_raw_ops for standard and extended config space on x86. Rather than clutter generic code with knowledge of this, we make pci_raw_ops private to x86 and use it to implement the new raw interface -- raw_pci_read() and raw_pci_write(). Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-10PCI x86: always use conf1 to access config space below 256 bytesIvan Kokshaysky
Thanks to Loic Prylli <loic@myri.com>, who originally proposed this idea. Always using legacy configuration mechanism for the legacy config space and extended mechanism (mmconf) for the extended config space is a simple and very logical approach. It's supposed to resolve all known mmconf problems. It still allows per-device quirks (tweaking dev->cfg_size). It also allows to get rid of mmconf fallback code. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11i386: move pciThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
