commit 7e8ce0e2b036dbc6617184317983aea4f2c52099 upstream.
The AMD FCH USB XHCI Controller advertises support for generating PME#
while in D0. When in D0, it does signal PME# for USB 3.0 connect events,
but not for USB 2.0 or USB 1.1 connect events, which means the controller
doesn't wake correctly for those events.
00:10.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller [1022:7914] (rev 20) (prog-if 30 [XHCI])
Subsystem: Dell FCH USB XHCI Controller [1028:087e]
Capabilities: [50] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Clear PCI_PM_CAP_PME_D0 in dev->pme_support to indicate the device will not
assert PME# from D0 so we don't rely on it.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=203673
Link: https://lore.kernel.org/r/20190902145252.32111-1-kai.heng.feng@canonical.com
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: stable@vger.kernel.org
[ Upstream commit ea094d53580f40c2124cef3d072b73b2425e7bfd ]
In pcibios_irq_init(), the PCI IRQ routing table 'pirq_table' is first
found through pirq_find_routing_table(). If the table is not found and
CONFIG_PCI_BIOS is defined, the table is then allocated in
pcibios_get_irq_routing_table() using kmalloc(). Later, if the I/O APIC is
used, this table is actually not used. In that case, the allocated table
is not freed, which is a memory leak.
Free the allocated table if it is not used.
Signed-off-by: Wenwen Wang <wang6495@umn.edu>
[bhelgaas: added Ingo's reviewed-by, since the only change since v1 was to
use the irq_routing_table local variable name he suggested]
Reviewed-by: Ingo Molnar <mingo@kernel.org>
[ Upstream commit 53bb565fc5439f2c8c57a786feea5946804aa3e9 ]
In the expression "word1 << 16", word1 starts as u16, but is promoted to a
signed int, then sign-extended to resource_size_t, which is probably not
what was intended. Cast to resource_size_t to avoid the sign extension.
This fixes an identical issue as fixed by commit 0b2d70764bb3 ("x86/PCI:
Fix Broadcom CNB20LE unintended sign extension") back in 2014.
Detected by CoverityScan, CID#138749, 138750 ("Unintended sign extension")
Fixes: 3f6ea84a3035 ("PCI: read memory ranges out of Broadcom CNB20LE host bridge")
Signed-off-by: Bjorn Helgaas <helgaas@kernel.org>
commit ddec3bdee05b06f1dda20ded003c3e10e4184cab upstream.
acpi_os_get_root_pointer() may return a valid address even if acpi_disabled
is set, but the host bridge information from the ACPI tables is not going
to be used in that case and the Broadcom host bridge initialization should
not be skipped then, So make broadcom_postcore_init() check acpi_disabled
too to avoid this issue.
Fixes: 6361d72b04d1 (x86/PCI: read Broadcom CNB20LE host bridge info before PCI scan)
Reported-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Linux PCI <linux-pci@vger.kernel.org>
Link: https://lkml.kernel.org/r/3186627.pxZj1QbYNg@aspire.rjw.lan
commit 13cfc732160f7bc7e596128ce34cda361c556966 upstream.
Neither soft poweroff (transition to ACPI power state S5) nor
suspend-to-RAM (transition to state S3) works on the Macbook Pro 11,4 and
11,5.
The problem is related to the [mem 0x7fa00000-0x7fbfffff] space. When we
use that space, e.g., by assigning it to the 00:1c.0 Root Port, the ACPI
Power Management 1 Control Register (PM1_CNT) at [io 0x1804] doesn't work
anymore.
Linux does a soft poweroff (transition to S5) by writing to PM1_CNT. The
theory about why this doesn't work is:
- The write to PM1_CNT causes an SMI
- The BIOS SMI handler depends on something in
- When Linux assigns [mem 0x7fa00000-0x7fbfffff] to the 00:1c.0 Port, it
covers up whatever the SMI handler uses, so the SMI handler no longer
works correctly
Reserve the [mem 0x7fa00000-0x7fbfffff] space so we don't assign it to
anything.
This is voodoo programming, since we don't know what the real conflict is,
but we've failed to find the root cause.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=103211
Tested-by: thejoe@gmail.com
Cc: Rafael J. Wysocki <rafael@kernel.org>
Cc: Lukas Wunner <lukas@wunner.de>
Cc: Chen Yu <yu.c.chen@intel.com>
commit 84d582d236dc1f9085e741affc72e9ba061a67c2 upstream.
Recent discussion (http://marc.info/?l=xen-devel&m=149192184523741)
established that commit 72a9b186292d ("xen: Remove event channel
notification through Xen PCI platform device") (and thus commit
da72ff5bfcb0 ("partially revert "xen: Remove event channel
notification through Xen PCI platform device"")) are unnecessary and,
in fact, prevent HVM guests from booting on Xen releases prior to 4.0
Therefore we revert both of those commits.
The summary of that discussion is below:
Here is the brief summary of the current situation:
Before the offending commit (72a9b186292):
1) INTx does not work because of the reset_watches path.
2) The reset_watches path is only taken if you have Xen > 4.0
3) The Linux Kernel by default will use vector inject if the hypervisor
support. So even INTx does not work no body running the kernel with
Xen > 4.0 would notice. Unless he explicitly disabled this feature
either in the kernel or in Xen (and this can only be disabled by
modifying the code, not user-supported way to do it).
After the offending commit (+ partial revert):
1) INTx is no longer support for HVM (only for PV guests).
2) Any HVM guest The kernel will not boot on Xen < 4.0 which does
not have vector injection support. Since the only other mode
supported is INTx which.
So based on this summary, I think before commit (72a9b186292) we were
in much better position from a user point of view.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: x86@kernel.org
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Stefano Stabellini <sstabellini@kernel.org>
Cc: Julien Grall <julien.grall@arm.com>
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Ross Lagerwall <ross.lagerwall@citrix.com>
Cc: xen-devel@lists.xenproject.org
Cc: linux-pci@vger.kernel.org
Cc: Anthony Liguori <aliguori@amazon.com>
Cc: KarimAllah Ahmed <karahmed@amazon.de>
Signed-off-by: Juergen Gross <jgross@suse.com>
[ Upstream commit c74fd80f2f41d05f350bb478151021f88551afe8 ]
Revert the main part of commit:
af42b8d12f8a ("xen: fix MSI setup and teardown for PV on HVM guests")
That commit introduced reading the pci device's msi message data to see
if a pirq was previously configured for the device's msi/msix, and re-use
that pirq. At the time, that was the correct behavior. However, a
later change to Qemu caused it to call into the Xen hypervisor to unmap
all pirqs for a pci device, when the pci device disables its MSI/MSIX
vectors; specifically the Qemu commit:
c976437c7dba9c7444fb41df45468968aaa326ad
("qemu-xen: free all the pirqs for msi/msix when driver unload")
Once Qemu added this pirq unmapping, it was no longer correct for the
kernel to re-use the pirq number cached in the pci device msi message
data. All Qemu releases since 2.1.0 contain the patch that unmaps the
pirqs when the pci device disables its MSI/MSIX vectors.
This bug is causing failures to initialize multiple NVMe controllers
under Xen, because the NVMe driver sets up a single MSIX vector for
each controller (concurrently), and then after using that to talk to
the controller for some configuration data, it disables the single MSIX
vector and re-configures all the MSIX vectors it needs. So the MSIX
setup code tries to re-use the cached pirq from the first vector
for each controller, but the hypervisor has already given away that
pirq to another controller, and its initialization fails.
This is discussed in more detail at:
https://lists.xen.org/archives/html/xen-devel/2017-01/msg00447.html
Fixes: af42b8d12f8a ("xen: fix MSI setup and teardown for PV on HVM guests")
Signed-off-by: Dan Streetman <dan.streetman@canonical.com>
Reviewed-by: Stefano Stabellini <sstabellini@kernel.org>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 89e9f7bcd8744ea25fcf0ac671b8d72c10d7d790 upstream.
Martin reported that the Supermicro X8DTH-i/6/iF/6F advertises incorrect
host bridge windows via _CRS:
pci_root PNP0A08:00: host bridge window [io 0xf000-0xffff]
pci_root PNP0A08:01: host bridge window [io 0xf000-0xffff]
Both bridges advertise the 0xf000-0xffff window, which cannot be correct.
Work around this by ignoring _CRS on this system. The downside is that we
may not assign resources correctly to hot-added PCI devices (if they are
possible on this system).
Link: https://bugzilla.kernel.org/show_bug.cgi?id=42606
Reported-by: Martin Burnicki <martin.burnicki@meinberg.de>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Summary of PCI changes for the v4.9 merge window:
Enumeration:
- microblaze: Add multidomain support for procfs (Bharat Kumar Gogada)
Resource management:
- Ignore requested alignment for PROBE_ONLY and fixed resources (Yongji Xie)
- Ignore requested alignment for VF BARs (Yongji Xie)
PCI device hotplug:
- Make core explicitly non-modular (Paul Gortmaker)
PCIe native device hotplug:
- Rename pcie_isr() locals for clarity (Bjorn Helgaas)
- Return IRQ_NONE when we can't read interrupt status (Bjorn Helgaas)
- Remove unnecessary guard (Bjorn Helgaas)
- Clean up dmesg "Slot(%s)" messages (Bjorn Helgaas)
- Remove useless pciehp_get_latch_status() calls (Bjorn Helgaas)
- Clear attention LED on device add (Keith Busch)
- Allow exclusive userspace control of indicators (Keith Busch)
- Process all hotplug events before looking for new ones (Mayurkumar Patel)
- Don't re-read Slot Status when queuing hotplug event (Mayurkumar Patel)
- Don't re-read Slot Status when handling surprise event (Mayurkumar Patel)
- Make explicitly non-modular (Paul Gortmaker)
Power management:
- Afford direct-complete to devices with non-standard PM (Lukas Wunner)
- Query platform firmware for device power state (Lukas Wunner)
- Recognize D3cold in pci_update_current_state() (Lukas Wunner)
- Avoid unnecessary resume after direct-complete (Lukas Wunner)
Virtualization:
- Mark Atheros AR9580 to avoid bus reset (Maik Broemme)
- Check for pci_setup_device() failure in pci_iov_add_virtfn() (Po Liu)
MSI:
- Enable PCI_MSI_IRQ_DOMAIN support for ARC (Joao Pinto)
AER:
- Remove aerdriver.nosourceid kernel parameter (Bjorn Helgaas)
- Remove aerdriver.forceload kernel parameter (Bjorn Helgaas)
- Fix aer_probe() kernel-doc comment (Cao jin)
- Add bus flag to skip source ID matching (Jon Derrick)
- Avoid memory allocation in interrupt handling path (Jon Derrick)
- Cache capability position (Keith Busch)
- Remove duplicate AER severity translation (Tyler Baicar)
- Send correct severity to calculate AER severity (Tyler Baicar)
Precision Time Measurement:
- Add Precision Time Measurement (PTM) support (Jonathan Yong)
- Add PTM clock granularity information (Bjorn Helgaas)
- Add pci_enable_ptm() for drivers to enable PTM on endpoints (Bjorn Helgaas)
Generic host bridge driver:
- Fix pci_remap_iospace() failure path (Lorenzo Pieralisi)
Altera host bridge driver:
- Remove redundant platform_get_resource() return value check (Bjorn Helgaas)
- Poll for link training status after retraining the link (Ley Foon Tan)
- Rework config accessors for use without a struct pci_bus (Ley Foon Tan)
- Move retrain from fixup to altera_pcie_host_init() (Ley Foon Tan)
- Make MSI explicitly non-modular (Paul Gortmaker)
- Relax device number checking to allow SR-IOV (Po Liu)
ARM Versatile host bridge driver:
Axis ARTPEC-6 host bridge driver:
- Drop __init from artpec6_add_pcie_port() (Niklas Cassel)
Freescale i.MX6 host bridge driver:
Intel VMD host bridge driver:
- Add quirk for AER to ignore source ID (Jon Derrick)
- Allocate IRQ lists with correct MSI-X count (Jon Derrick)
- Convert to use pci_alloc_irq_vectors() API (Jon Derrick)
- Eliminate vmd_vector member from list type (Jon Derrick)
- Eliminate index member from IRQ list (Jon Derrick)
- Synchronize with RCU freeing MSI IRQ descs (Keith Busch)
- Request userspace control of PCIe hotplug indicators (Keith Busch)
- Move VMD driver to drivers/pci/host (Keith Busch)
Marvell Aardvark host bridge driver:
- Remove redundant dev_err call in advk_pcie_probe() (Wei Yongjun)
Microsoft Hyper-V host bridge driver:
- Use zero-length array in struct pci_packet (Dexuan Cui)
- Use pci_function_description[0] in struct definitions (Dexuan Cui)
- Remove the unused 'wrk' in struct hv_pcibus_device (Dexuan Cui)
- Handle vmbus_sendpacket() failure in hv_compose_msi_msg() (Dexuan Cui)
- Handle hv_pci_generic_compl() error case (Dexuan Cui)
- Use list_move_tail() instead of list_del() + list_add_tail() (Wei Yongjun)
NVIDIA Tegra host bridge driver:
- Remove redundant _data suffix (Thierry Reding)
- Use of_device_get_match_data() (Thierry Reding)
Qualcomm host bridge driver:
Renesas R-Car host bridge driver:
- Consolidate register space lookup and ioremap (Bjorn Helgaas)
- Don't disable/unprepare clocks on prepare/enable failure (Geert Uytterhoeven)
- Add multi-MSI support (Grigory Kletsko)
- Fix some checkpatch warnings (Sergei Shtylyov)
- Try increasing PCIe link speed to 5 GT/s at boot (Sergei Shtylyov)
Rockchip host bridge driver:
- Add DT bindings for Rockchip PCIe controller (Shawn Lin)
- Add Rockchip PCIe controller support (Shawn Lin)
- Improve the deassert sequence of four reset pins (Shawn Lin)
- Fix wrong transmitted FTS count (Shawn Lin)
- Increase the Max Credit update interval (Rajat Jain)
Samsung Exynos host bridge driver:
ST Microelectronics SPEAr13xx host bridge driver:
Synopsys DesignWare host bridge driver:
- Return data directly from dw_pcie_readl_rc() (Bjorn Helgaas)
- Exchange viewport of `MEMORYs' and `CFGs/IOs' (Dong Bo)
- Check LTSSM training bit before deciding link is up (Jisheng Zhang)
- Move link wait definitions to .c file (Joao Pinto)
- Wait for iATU enable (Joao Pinto)
- Add iATU Unroll feature (Joao Pinto)
- Keep viewport fixed for IO transaction if num_viewport > 2 (Pratyush Anand)
- Remove redundant platform_get_resource() return value check (Wei Yongjun)
TI DRA7xx host bridge driver:
TI Keystone host bridge driver:
- Propagate request_irq() failure (Wei Yongjun)
Xilinx AXI host bridge driver:
- Keep both legacy and MSI interrupt domain references (Bharat Kumar Gogada)
- Clear interrupt register for invalid interrupt (Bharat Kumar Gogada)
- Clear correct MSI set bit (Bharat Kumar Gogada)
- Dispose of MSI virtual IRQ (Bharat Kumar Gogada)
Xilinx NWL host bridge driver:
- Expand error logging (Bharat Kumar Gogada)
- Enable all MSI interrupts using MSI mask (Bharat Kumar Gogada)
Miscellaneous:
- Drop CONFIG_KEXEC_CORE ifdeffery (Lukas Wunner)
- portdrv: Make explicitly non-modular (Paul Gortmaker)
- Make DPC explicitly non-modular (Paul Gortmaker)"
* tag 'pci-v4.9-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (105 commits)
x86/PCI: VMD: Move VMD driver to drivers/pci/host
PCI: rockchip: Fix wrong transmitted FTS count
PCI: rockchip: Improve the deassert sequence of four reset pins
PCI: rockchip: Increase the Max Credit update interval
PCI: rcar: Try increasing PCIe link speed to 5 GT/s at boot
PCI/AER: Fix aer_probe() kernel-doc comment
PCI: Ignore requested alignment for VF BARs
PCI: Ignore requested alignment for PROBE_ONLY and fixed resources
PCI: Avoid unnecessary resume after direct-complete
PCI: Recognize D3cold in pci_update_current_state()
PCI: Query platform firmware for device power state
PCI: Afford direct-complete to devices with non-standard PM
PCI/AER: Cache capability position
PCI/AER: Avoid memory allocation in interrupt handling path
x86/PCI: VMD: Request userspace control of PCIe hotplug indicators
PCI: pciehp: Allow exclusive userspace control of indicators
ACPI / APEI: Send correct severity to calculate AER severity
PCI/AER: Remove duplicate AER severity translation
x86/PCI: VMD: Synchronize with RCU freeing MSI IRQ descs
x86/PCI: VMD: Eliminate index member from IRQ list
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen updates from David Vrabel:
"xen features and fixes for 4.9:
- switch to new CPU hotplug mechanism
- support driver_override in pciback
- require vector callback for HVM guests (the alternate mechanism via
the platform device has been broken for ages)"
* tag 'for-linus-4.9-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/x86: Update topology map for PV VCPUs
xen/x86: Initialize per_cpu(xen_vcpu, 0) a little earlier
xen/pciback: support driver_override
xen/pciback: avoid multiple entries in slot list
xen/pciback: simplify pcistub device handling
xen: Remove event channel notification through Xen PCI platform device
xen/events: Convert to hotplug state machine
xen/x86: Convert to hotplug state machine
x86/xen: add missing \n at end of printk warning message
xen/grant-table: Use kmalloc_array() in arch_gnttab_valloc()
xen: Make VPMU init message look less scary
xen: rename xen_pmu_init() in sys-hypervisor.c
hotplug: Prevent alloc/free of irq descriptors during cpu up/down (again)
xen/x86: Move irq allocation from Xen smp_op.cpu_up()
* pci/host-vmd:
x86/PCI: VMD: Eliminate vmd_vector member from list type
x86/PCI: VMD: Convert to use pci_alloc_irq_vectors() API
x86/PCI: VMD: Allocate IRQ lists with correct MSI-X count
PCI: Use positive flags in pci_alloc_irq_vectors()
PCI: Update "pci=resource_alignment" documentation
drivers/pci/host/Kconfig
drivers/pci/host/Makefile
Move the driver source and Kconfig to the PCI host bridge drivers directory
and move the config option to a more appropriate sub-menu instead of
occupying the top-level location.
Update the Kconfig option with the X86_64 dependency that was implicitly
included from the previous location, and add information about the module
name when built as a loadable module.
Signed-off-by: Keith Busch <keith.busch@intel.com>
CC: Jon Derrick <jonathan.derrick@intel.com>
Ever since commit 254d1a3f02eb ("xen/pv-on-hvm kexec: shutdown watches
from old kernel") using the INTx interrupt from Xen PCI platform
device for event channel notification would just lockup the guest
during bootup. postcore_initcall now calls xs_reset_watches which
will eventually try to read a value from XenStore and will get stuck
on read_reply at XenBus forever since the platform driver is not
probed yet and its INTx interrupt handler is not registered yet. That
means that the guest can not be notified at this moment of any pending
event channels and none of the per-event handlers will ever be invoked
(including the XenStore one) and the reply will never be picked up by
the kernel.
The exact stack where things get stuck during xenbus_init:
-xenbus_init
-xs_init
-xs_reset_watches
-xenbus_scanf
-xenbus_read
-xs_single
-xs_single
-xs_talkv
Vector callbacks have always been the favourite event notification
mechanism since their introduction in commit 38e20b07efd5 ("x86/xen:
event channels delivery on HVM.") and the vector callback feature has
always been advertised for quite some time by Xen that's why INTx was
broken for several years now without impacting anyone.
Luckily this also means that event channel notification through INTx
is basically dead-code which can be safely removed without impacting
anybody since it has been effectively disabled for more than 4 years
with nobody complaining about it (at least as far as I'm aware of).
This commit removes event channel notification through Xen PCI
platform device.
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: x86@kernel.org
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Julien Grall <julien.grall@citrix.com>
Signed-off-by: KarimAllah Ahmed <karahmed@amazon.de>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Add set_dev_domain_options() to set PCI domain-specific options as devices
are added. The first usage is to request exclusive userspace control of
PCIe hotplug indicators in VMD domains.
Devices in a VMD domain use PCIe hotplug Attention and Power Indicators in
a non-standard way; tell pciehp to ignore the indicators so userspace can
control them via the sysfs "attention" file.
To determine whether a bus is within a VMD domain, add a bool to the
pci_sysdata structure that the VMD driver sets during initialization.
[bhelgaas: changelog]
Requested-by: Kapil Karkra <kapil.karkra@intel.com>
Tested-by: Artur Paszkiewicz <artur.paszkiewicz@intel.com>
Fix a potential race when disabling MSI/MSI-X on a VMD domain device. If
the VMD interrupt service is running, it may see a disabled IRQ. We can
synchronize RCU just before freeing the MSI descriptor. This is safe since
the irq_desc lock isn't held, and the descriptor is valid even though it is
disabled. After vmd_msi_free(), though, the handler is reinitialized to
handle_bad_irq(), so we can't let the VMD ISR's list iteration see the
disabled IRQ after this.
Acked-by Jon Derrick: <jonathan.derrick@intel.com>
Use math to discover the IRQ list index number relative to the IRQ list
head.
Signed-off-by: Jon Derrick <jonathan.derrick@intel.com>
Acked-by: Keith Busch <keith.busch@intel.com>
Eliminate unused vmd and vector members from vmd_irq_list and discover the
vector using pci_irq_vector().
Convert to use the pci_alloc_irq_vectors() API.
Reviewed-by: Keith Busch <keith.busch@intel.com>
To reduce the amount of memory required for IRQ lists, only allocate their
space after calling pci_msix_enable_range() which may reduce the number of
MSI-X vectors allocated.
The Haswell Power Control Unit has a non-PCI register (CONFIG_TDP_NOMINAL)
where BAR 0 is supposed to be. This is erratum HSE43 in the spec update
referenced below:
The PCIe* Base Specification indicates that Configuration Space Headers
have a base address register at offset 0x10. Due to this erratum, the
Power Control Unit's CONFIG_TDP_NOMINAL CSR (Bus 1; Device 30; Function
3; Offset 0x10) is located where a base register is expected.
Mark the PCU as having non-compliant BARs so we don't try to probe any of
them. There are no other BARs on this device.
Rename the quirk so it's not Broadwell-specific.
Link: http://www.intel.com/content/www/us/en/processors/xeon/xeon-e5-v3-spec-update.html
Link: http://www.intel.com/content/www/us/en/processors/xeon/xeon-e5-v3-datasheet-vol-2.html (section 5.4, Device 30 Function 3)
Link: https://bugzilla.kernel.org/show_bug.cgi?id=153881
Reported-by: Paul Menzel <pmenzel@molgen.mpg.de>
Tested-by: Prarit Bhargava <prarit@redhat.com>
Acked-by: Myron Stowe <myron.stowe@redhat.com>
We can't initialize the list head on deletion as this causes the node to
point to itself, which causes an infinite loop if vmd_irq() happens to be
servicing that node.
The list initialization was trying to fix a bug from multiple calls to
disable the same IRQ. Fix this instead by having the VMD driver track if
the interrupt is enabled.
[bhelgaas: changelog, add "Fixes"]
Fixes: 97e923063575 ("x86/PCI: VMD: Initialize list item in IRQ disable")
Reported-by: Grzegorz Koczot <grzegorz.koczot@intel.com>
Tested-by: Miroslaw Drost <miroslaw.drost@intel.com>
Guided by grsecurity's analogous __read_only markings in arch/x86,
this applies several uses of __ro_after_init to structures that are
only updated during __init, and const for some structures that are
never updated. Additionally extends __init markings to some functions
that are only used during __init, and cleans up some missing C99 style
static initializers.
Cc: Brad Spengler <spender@grsecurity.net>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: David Brown <david.brown@linaro.org>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Emese Revfy <re.emese@gmail.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Mathias Krause <minipli@googlemail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: PaX Team <pageexec@freemail.hu>
Cc: kernel-hardening@lists.openwall.com
Link: http://lkml.kernel.org/r/20160808232906.GA29731@www.outflux.net
The dma-mapping core and the implementations do not change the DMA
attributes passed by pointer. Thus the pointer can point to const data.
However the attributes do not have to be a bitfield. Instead unsigned
long will do fine:
1. This is just simpler. Both in terms of reading the code and setting
attributes. Instead of initializing local attributes on the stack
and passing pointer to it to dma_set_attr(), just set the bits.
2. It brings safeness and checking for const correctness because the
attributes are passed by value.
Semantic patches for this change (at least most of them):
virtual patch
virtual context
@r@
identifier f, attrs;
f(...,
- struct dma_attrs *attrs
+ unsigned long attrs
identifier r.f;
f(...,
- NULL
+ 0
and
// Options: --all-includes
virtual patch
virtual context
@r@
type t;
t f(..., struct dma_attrs *attrs);
identifier r.f;
f(...,
- NULL
+ 0
Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Mark Salter <msalter@redhat.com> [c6x]
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris]
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm]
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Joerg Roedel <jroedel@suse.de> [iommu]
Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp]
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core]
Acked-by: David Vrabel <david.vrabel@citrix.com> [xen]
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390]
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32]
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu]
"Highlights:
- ARM64 support for ACPI host bridges
- new drivers for Axis ARTPEC-6 and Marvell Aardvark
- new pci_alloc_irq_vectors() interface for MSI-X, MSI, legacy INTx
- pci_resource_to_user() cleanup (more to come)
Detailed summary:
Enumeration:
- Move ecam.h to linux/include/pci-ecam.h (Jayachandran C)
- Add parent device field to ECAM struct pci_config_window (Jayachandran C)
- Add generic MCFG table handling (Tomasz Nowicki)
- Refactor pci_bus_assign_domain_nr() for CONFIG_PCI_DOMAINS_GENERIC (Tomasz Nowicki)
- Factor DT-specific pci_bus_find_domain_nr() code out (Tomasz Nowicki)
- Add devm_request_pci_bus_resources() (Bjorn Helgaas)
- Unify pci_resource_to_user() declarations (Bjorn Helgaas)
- Implement pci_resource_to_user() with pcibios_resource_to_bus() (microblaze, powerpc, sparc) (Bjorn Helgaas)
- Request host bridge window resources (designware, iproc, rcar, xgene, xilinx, xilinx-nwl) (Bjorn Helgaas)
- Make PCI I/O space optional on ARM32 (Bjorn Helgaas)
- Ignore write combining when mapping I/O port space (Bjorn Helgaas)
- Claim bus resources on MIPS PCI_PROBE_ONLY set-ups (Bjorn Helgaas)
- Remove unicore32 pci=firmware command line parameter handling (Bjorn Helgaas)
- Support I/O resources when parsing host bridge resources (Jayachandran C)
- Add helpers to request/release memory and I/O regions (Johannes Thumshirn)
- Use pci_(request|release)_mem_regions (NVMe, lpfc, GenWQE, ethernet/intel, alx) (Johannes Thumshirn)
- Extend pci=resource_alignment to specify device/vendor IDs (Koehrer Mathias (ETAS/ESW5))
- Add generic pci_bus_claim_resources() (Lorenzo Pieralisi)
- Claim bus resources on ARM32 PCI_PROBE_ONLY set-ups (Lorenzo Pieralisi)
- Remove ARM32 and ARM64 arch-specific pcibios_enable_device() (Lorenzo Pieralisi)
- Add pci_unmap_iospace() to unmap I/O resources (Sinan Kaya)
- Remove powerpc __pci_mmap_set_pgprot() (Yinghai Lu)
PCI device hotplug:
- Allow additional bus numbers for hotplug bridges (Keith Busch)
- Ignore interrupts during D3cold (Lukas Wunner)
Power management:
- Enforce type casting for pci_power_t (Andy Shevchenko)
- Don't clear d3cold_allowed for PCIe ports (Mika Westerberg)
- Put PCIe ports into D3 during suspend (Mika Westerberg)
- Power on bridges before scanning new devices (Mika Westerberg)
- Runtime resume bridge before rescan (Mika Westerberg)
- Add runtime PM support for PCIe ports (Mika Westerberg)
- Remove redundant check of pcie_set_clkpm (Shawn Lin)
Virtualization:
- Add function 1 DMA alias quirk for Marvell 88SE9182 (Aaron Sierra)
- Add DMA alias quirk for Adaptec 3805 (Alex Williamson)
- Mark Atheros AR9485 and QCA9882 to avoid bus reset (Chris Blake)
- Add ACS quirk for Solarflare SFC9220 (Edward Cree)
MSI:
- Fix PCI_MSI dependencies (Arnd Bergmann)
- Add pci_msix_desc_addr() helper (Christoph Hellwig)
- Switch msix_program_entries() to use pci_msix_desc_addr() (Christoph Hellwig)
- Make the "entries" argument to pci_enable_msix() optional (Christoph Hellwig)
- Provide sensible IRQ vector alloc/free routines (Christoph Hellwig)
- Spread interrupt vectors in pci_alloc_irq_vectors() (Christoph Hellwig)
Error Handling:
- Bind DPC to Root Ports as well as Downstream Ports (Keith Busch)
- Remove DPC tristate module option (Keith Busch)
- Convert Downstream Port Containment driver to use devm_* functions (Mika Westerberg)
- Select IRQ_DOMAIN (Arnd Bergmann)
- Claim bus resources on PCI_PROBE_ONLY set-ups (Lorenzo Pieralisi)
ACPI host bridge driver:
- Add ARM64 acpi_pci_bus_find_domain_nr() (Tomasz Nowicki)
- Add ARM64 ACPI support for legacy IRQs parsing and consolidation with DT code (Tomasz Nowicki)
- Implement ARM64 AML accessors for PCI_Config region (Tomasz Nowicki)
- Support ARM64 ACPI-based PCI host controller (Tomasz Nowicki)
- Check link status before retrain link (Ley Foon Tan)
- Poll for link up status after retraining the link (Ley Foon Tan)
- Add PCI_MSI_IRQ_DOMAIN dependency (Arnd Bergmann)
- Add DT binding for Axis ARTPEC-6 PCIe controller (Niklas Cassel)
- Add Axis ARTPEC-6 PCIe controller driver (Niklas Cassel)
- Use lock save/restore in interrupt enable path (Jon Derrick)
- Select device dma ops to override (Keith Busch)
- Initialize list item in IRQ disable (Keith Busch)
- Use x86_vector_domain as parent domain (Keith Busch)
- Separate MSI and MSI-X vector sharing (Keith Busch)
- Add DT binding for the Aardvark PCIe controller (Thomas Petazzoni)
- Add Aardvark PCI host controller driver (Thomas Petazzoni)
- Add Aardvark PCIe support for Armada 3700 (Thomas Petazzoni)
- Fix interrupt cleanup path (Cathy Avery)
- Don't leak buffer in hv_pci_onchannelcallback() (Vitaly Kuznetsov)
- Handle all pending messages in hv_pci_onchannelcallback() (Vitaly Kuznetsov)
- Program PADS_REFCLK_CFG* always, not just on legacy SoCs (Stephen Warren)
- Program PADS_REFCLK_CFG* registers with per-SoC values (Stephen Warren)
- Use lower-case hex consistently for register definitions (Thierry Reding)
- Use generic pci_remap_iospace() rather than ARM32-specific one (Thierry Reding)
- Stop setting pcibios_min_mem (Thierry Reding)
- Drop gen2 dummy I/O port region (Bjorn Helgaas)
- Fix return value in case of error (Christophe JAILLET)
Miscellaneous:
- Make bus_attr_resource_alignment static (Ben Dooks)
- Include <asm/dma.h> for isa_dma_bridge_buggy (Ben Dooks)
- MAINTAINERS: Add file patterns for PCI device tree bindings (Geert Uytterhoeven)
- Make host bridge drivers explicitly non-modular (Paul Gortmaker)"
* tag 'pci-v4.8-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (125 commits)
PCI: xgene: Make explicitly non-modular
PCI: thunder-pem: Make explicitly non-modular
PCI: thunder-ecam: Make explicitly non-modular
PCI: tegra: Make explicitly non-modular
PCI: rcar-gen2: Make explicitly non-modular
PCI: rcar: Make explicitly non-modular
PCI: mvebu: Make explicitly non-modular
PCI: layerscape: Make explicitly non-modular
PCI: keystone: Make explicitly non-modular
PCI: hisi: Make explicitly non-modular
PCI: generic: Make explicitly non-modular
PCI: designware-plat: Make it explicitly non-modular
PCI: artpec6: Make explicitly non-modular
PCI: armada8k: Make explicitly non-modular
PCI: artpec: Add PCI_MSI_IRQ_DOMAIN dependency
PCI: Add ACS quirk for Solarflare SFC9220
arm64: dts: marvell: Add Aardvark PCIe support for Armada 3700
PCI: aardvark: Add Aardvark PCI host controller driver
dt-bindings: add DT binding for the Aardvark PCIe controller
PCI: tegra: Program PADS_REFCLK_CFG* registers with per-SoC values
Pull x86 header cleanups from Ingo Molnar:
"This tree is a cleanup of the x86 tree reducing spurious uses of
module.h - which should improve build performance a bit"
* 'x86-headers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, crypto: Restore MODULE_LICENSE() to glue_helper.c so it loads
x86/apic: Remove duplicated include from probe_64.c
x86/ce4100: Remove duplicated include from ce4100.c
x86/headers: Include spinlock_types.h in x8664_ksyms_64.c for missing spinlock_t
x86/platform: Delete extraneous MODULE_* tags fromm ts5500
x86: Audit and remove any remaining unnecessary uses of module.h
x86/kvm: Audit and remove any unnecessary uses of module.h
x86/xen: Audit and remove any unnecessary uses of module.h
x86/platform: Audit and remove any unnecessary uses of module.h
x86/lib: Audit and remove any unnecessary uses of module.h
x86/kernel: Audit and remove any unnecessary uses of module.h
x86/mm: Audit and remove any unnecessary uses of module.h
x86: Don't use module.h just for AUTHOR / LICENSE tags
'pci/host-hv', 'pci/host-vmd' and 'pci/host-xilinx' into next
* pci/host-aardvark:
* pci/host-altera:
PCI: altera: Poll for link up status after retraining the link
PCI: altera: Check link status before retrain link
PCI: altera: Reorder read/write functions
* pci/host-dra7xx:
PCI: dra7xx: Fix return value in case of error
* pci/host-hv:
PCI: hv: Fix interrupt cleanup path
PCI: hv: Handle all pending messages in hv_pci_onchannelcallback()
PCI: hv: Don't leak buffer in hv_pci_onchannelcallback()
* pci/host-vmd:
x86/PCI: VMD: Separate MSI and MSI-X vector sharing
x86/PCI: VMD: Use x86_vector_domain as parent domain
x86/PCI: VMD: Use lock save/restore in interrupt enable path
x86/PCI: VMD: Select device dma ops to override
* pci/host-xilinx:
PCI: xilinx: Fix return value in case of error
Manually apply changes from pci/demodularize-hosts and
pci/host-request-windows to drivers/pci/host/pci-aardvark.c
Pull irq updates from Thomas Gleixner:
"The irq department delivers:
- new core infrastructure to allow better management of multi-queue
devices (interrupt spreading, node aware descriptor allocation ...)
- a new interrupt flow handler to support the new fangled Intel VMD
devices.
- yet another new interrupt controller driver.
- a series of fixes which addresses sparse warnings, missing
includes, missing static declarations etc from Ben Dooks.
- a fix for the error handling in the hierarchical domain allocation
code.
- the usual pile of small updates to core and driver code"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits)
genirq: Fix missing irq allocation affinity hint
irqdomain: Fix irq_domain_alloc_irqs_recursive() error handling
irq/Documentation: Correct result of echnoing 5 to smp_affinity
MAINTAINERS: Remove Jiang Liu from irq domains
genirq/msi: Fix broken debug output
genirq: Add a helper to spread an affinity mask for MSI/MSI-X vectors
genirq/msi: Make use of affinity aware allocations
genirq: Use affinity hint in irqdesc allocation
genirq: Add affinity hint to irq allocation
genirq: Introduce IRQD_AFFINITY_MANAGED flag
genirq/msi: Remove unused MSI_FLAG_IDENTITY_MAP
irqchip/s3c24xx: Fixup IO accessors for big endian
irqchip/exynos-combiner: Fix usage of __raw IO
irqdomain: Fix disposal of mappings for interrupt hierarchies
irqchip/aspeed-vic: Add irq controller for Aspeed
doc/devicetree: Add Aspeed VIC bindings
x86/PCI/VMD: Use untracked irq handler
genirq: Add untracked irq handler
irqchip/mips-gic: Populate irq_domain names
irqchip/gicv3-its: Implement two-level(indirect) device table support
Pull x86 platform updates from Ingo Molnar:
"The main changes in this cycle were:
- Intel-SoC enhancements (Andy Shevchenko)
- Intel CPU symbolic model definition rework (Dave Hansen)
- ... other misc changes"
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (25 commits)
x86/sfi: Enable enumeration of SD devices
x86/pci: Use MRFLD abbreviation for Merrifield
x86/platform/intel-mid: Make vertical indentation consistent
x86/platform/intel-mid: Mark regulators explicitly defined
x86/platform/intel-mid: Rename mrfl.c to mrfld.c
x86/platform/intel-mid: Enable spidev on Intel Edison boards
x86/platform/intel-mid: Extend PWRMU to support Penwell
x86/pci, x86/platform/intel_mid_pci: Remove duplicate power off code
x86/platform/intel-mid: Add pinctrl for Intel Merrifield
x86/platform/intel-mid: Enable GPIO expanders on Edison
x86/platform/intel-mid: Add Power Management Unit driver
x86/platform/atom/punit: Enable support for Merrifield
x86/platform/intel_mid_pci: Rework IRQ0 workaround
x86, thermal: Clean up and fix CPU model detection for intel_soc_dts_thermal
x86, mmc: Use Intel family name macros for mmc driver
x86/intel_telemetry: Use Intel family name macros for telemetry driver
x86/acpi/lss: Use Intel family name macros for the acpi_lpss driver
x86/cpufreq: Use Intel family name macros for the intel_pstate cpufreq driver
x86/platform: Use new Intel model number macros
x86/intel_idle: Use Intel family macros for intel_idle
Historically a lot of these existed because we did not have
a distinction between what was modular code and what was providing
support to modules via EXPORT_SYMBOL and friends. That changed
when we forked out support for the latter into the export.h file.
This means we should be able to reduce the usage of module.h
in code that is obj-y Makefile or bool Kconfig. In the case of
some of these which are modular, we can extend that to also include
files that are building basic support functionality but not related
to loading or registering the final module; such files also have
no need whatsoever for module.h
The advantage in removing such instances is that module.h itself
sources about 15 other headers; adding significantly to what we feed
cpp, and it can obscure what headers we are effectively using.
Since module.h was the source for init.h (for __init) and for
export.h (for EXPORT_SYMBOL) we consider each instance for the
presence of either and replace as needed.
In the case of crypto/glue_helper.c we delete a redundant instance
of MODULE_LICENSE in order to delete module.h -- the license info
is already present at the top of the file.
The uncore change warrants a mention too; it is uncore.c that uses
module.h and not uncore.h; hence the relocation done there.
Link: http://lkml.kernel.org/r/20160714001901.31603-9-paul.gortmaker@windriver.com
Everywhere in the kernel the MRFLD is used as abbreviation of Intel Merrifield.
Do the same in intel_mid_pci.c module.
Link: http://lkml.kernel.org/r/1468321462-136016-1-git-send-email-andriy.shevchenko@linux.intel.com
Intel MID platforms (Moorestown, Medfield, Clovertrail, Merrifield) are
sharing the code in the intel_mid_pci.c module. There is no need to
power off specific Moorestown devices after the following commit:
5823d0893ec2 ("x86/platform/intel-mid: Add Power Management Unit driver")
... because the condition in mrfld_power_off_dev() is true for any platform
from the above list.
Remove duplicate power off certain devices on Intel Moorestown and rename
the affected functions to show that they are applied to any of Intel MID
platforms.
Link: http://lkml.kernel.org/r/1467749348-100518-1-git-send-email-andriy.shevchenko@linux.intel.com
Trying to make the ISA and PCI init functionality common turned out
to be a bad idea, because the ISA path depends on external
functionality.
Restore the previous behavior and limit the refactoring to PCI
interrupts only.
Fixes: 1fcb6a813c4f "ACPI,PCI,IRQ: remove redundant code in acpi_irq_penalty_init()"
Signed-off-by: Sinan Kaya <okaya@codeaurora.org>
Tested-by: Wim Osterholt <wim@djo.tudelft.nl>
Child devices in a VMD domain that want to use MSI are slowing down MSI-X
using devices sharing the same vectors. Move all MSI usage to a single VMD
vector, and MSI-X devices can share the rest.
Acked-by: Jon Derrick <jonathan.derrick@intel.com>
Otherwise APIC code assumes VMD's IRQ domain can be managed by the APIC,
resulting in an invalid cast of irq_data during irq_force_complete_move().
Enabling interrupts may result in an interrupt raised and serviced while
VMD holds a lock, resulting in contention with the spin lock held while
enabling interrupts.
The solution is to disable preemption and save/restore the state during
interrupt enable and disable.
Fixes lockdep:
[ INFO: HARDIRQ-safe -> HARDIRQ-unsafe lock order detected ]
4.6.0-2016-06-16-lockdep+ #47 Tainted: G E
kworker/0:1/447 [HC0[0]:SC0[0]:HE0:SE1] is trying to acquire:
(list_lock){+.+...}, at: [<ffffffffa04eb8fc>] vmd_irq_enable+0x3c/0x70 [vmd]
and this task is already holding:
(&irq_desc_lock_class){-.-...}, at: [<ffffffff810e1ff6>] __setup_irq+0xa6/0x610
which would create a new lock dependency:
(&irq_desc_lock_class){-.-...} -> (list_lock){+.+...}
but this new dependency connects a HARDIRQ-irq-safe lock:
... which became HARDIRQ-irq-safe at:
[<ffffffff810c9f21>] __lock_acquire+0x981/0xe00
[<ffffffff810cb039>] lock_acquire+0x119/0x220
[<ffffffff8167294d>] _raw_spin_lock+0x3d/0x80
[<ffffffff810e36d4>] handle_level_irq+0x24/0x110
[<ffffffff8101f20a>] handle_irq+0x1a/0x30
[<ffffffff81675fc1>] do_IRQ+0x61/0x120
[<ffffffff8167404c>] ret_from_intr+0x0/0x20
[<ffffffff81672e30>] _raw_spin_unlock_irqrestore+0x40/0x60
[<ffffffff810e21ee>] __setup_irq+0x29e/0x610
[<ffffffff810e25a1>] setup_irq+0x41/0x90
[<ffffffff81f5777f>] setup_default_timer_irq+0x1e/0x20
[<ffffffff81f57798>] hpet_time_init+0x17/0x19
[<ffffffff81f5775a>] x86_late_time_init+0xa/0x11
[<ffffffff81f51e9b>] start_kernel+0x382/0x436
[<ffffffff81f51308>] x86_64_start_reservations+0x2a/0x2c
[<ffffffff81f51445>] x86_64_start_kernel+0x13b/0x14a
to a HARDIRQ-irq-unsafe lock:
(list_lock){+.+...}
... which became HARDIRQ-irq-unsafe at:
... [<ffffffff810c9d8e>] __lock_acquire+0x7ee/0xe00
[<ffffffffa04eba42>] vmd_msi_init+0x72/0x150 [vmd]
[<ffffffff810e8597>] msi_domain_alloc+0xb7/0x140
[<ffffffff810e6b10>] irq_domain_alloc_irqs_recursive+0x40/0xa0
[<ffffffff810e6cea>] __irq_domain_alloc_irqs+0x14a/0x330
[<ffffffff810e8a8c>] msi_domain_alloc_irqs+0x8c/0x1d0
[<ffffffff813ca4e3>] pci_msi_setup_msi_irqs+0x43/0x70
[<ffffffff813cada1>] pci_enable_msi_range+0x131/0x280
[<ffffffff813bf5e0>] pcie_port_device_register+0x320/0x4e0
[<ffffffff813bf9a4>] pcie_portdrv_probe+0x34/0x60
[<ffffffff813b0e85>] local_pci_probe+0x45/0xa0
[<ffffffff813b226b>] pci_device_probe+0xdb/0x130
[<ffffffff8149e3cc>] driver_probe_device+0x22c/0x440
[<ffffffff8149e774>] __device_attach_driver+0x94/0x110
[<ffffffff8149bfad>] bus_for_each_drv+0x5d/0x90
[<ffffffff8149e030>] __device_attach+0xc0/0x140
[<ffffffff8149e0c0>] device_attach+0x10/0x20
[<ffffffff813a77f7>] pci_bus_add_device+0x47/0x90
[<ffffffff813a7879>] pci_bus_add_devices+0x39/0x70
[<ffffffff813aaba7>] pci_rescan_bus+0x27/0x30
[<ffffffffa04ec1af>] vmd_probe+0x68f/0x76c [vmd]
[<ffffffff81088064>] work_for_cpu_fn+0x14/0x20
[<ffffffff8108c244>] process_one_work+0x1f4/0x740
[<ffffffff8108c9c6>] worker_thread+0x236/0x4f0
[<ffffffff810935c2>] kthread+0xf2/0x110
[<ffffffff816738f2>] ret_from_fork+0x22/0x50
Possible interrupt unsafe locking scenario:
CPU0 CPU1
lock(list_lock);
local_irq_disable();
lock(&irq_desc_lock_class);
lock(list_lock);
<Interrupt>
*** DEADLOCK ***
There is no way to know which device in a VMD triggered an interrupt
without invoking every registered driver's actions. This uses the
untracked irq handler so that a less used device does not trigger
spurious interrupt.
We have been previously recommending users to enable "noirqdebug", but do
not want to force a system setting just to keep this domain functional.
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Jon Derrick <jonathan.derrick@intel.com>
Link: http://lkml.kernel.org/r/1466200821-29159-2-git-send-email-keith.busch@intel.com
Add Power Management Unit driver to handle power states of South Complex
devices on Intel Tangier. In the future it might be expanded to cover North
Complex devices as well.
With this driver the power state of the host controllers such as SPI, I2C,
UART, eMMC, and DMA would be managed.
Cc: David Cohen <david.a.cohen@linux.intel.com>
Cc: Mika Westerberg <mika.westerberg@linux.intel.com>
Link: http://lkml.kernel.org/r/1465928985-12113-1-git-send-email-andriy.shevchenko@linux.intel.com
[ Minor readability edits. ]
On Intel Merrifield platform several PCI devices have a bogus configuration,
i.e. the IRQ0 had been assigned to few of them. These are PCI root bridge,
eMMC0, HS UART common registers, PWM, and HDMI. The actual interrupt line can
be allocated to one device exclusively, in our case to eMMC0, the rest should
cope without it and basically known drivers for them are not using interrupt
line at all.
Rework IRQ0 workaround, which was previously done to avoid conflict between
eMMC0 and HS UART common registers, to behave differently based on the device
in question, i.e. allocate interrupt line to eMMC0, but silently skip interrupt
allocation for the rest except HS UART common registers which are not used
anyway. With this rework IOSF MBI driver in particular would be used.
Fixes: 39d9b77b8deb ("x86/pci/intel_mid_pci: Work around for IRQ0 assignment")
Link: http://lkml.kernel.org/r/1465842481-136852-1-git-send-email-andriy.shevchenko@linux.intel.com
Multiple calls to disable an IRQ would have caused the driver to
dereference a poisoned list item. This re-initializes the list to allow
multiple requests to disable the IRQ.
VMD device doesn't usually have device archdata specific dma_ops, so we
need to override the default ops for VMD devices.
Fix typo.
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
Pull xen bug fixes from David Vrabel.
* tag 'for-linus-4.7-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen: use same main loop for counting and remapping pages
xen/events: Don't move disabled irqs
xen/x86: actually allocate legacy interrupts on PV guests
Xen: don't warn about 2-byte wchar_t in efi
xen/gntdev: reduce copy batch size to 16
xen/x86: don't lose event interrupts
b4ff8389ed14 is incomplete: relies on nr_legacy_irqs() to get the number
of legacy interrupts when actually nr_legacy_irqs() returns 0 after
probe_8259A(). Use NR_IRQS_LEGACY instead.
Signed-off-by: Stefano Stabellini <sstabellini@kernel.org>
CC: stable@vger.kernel.org
"Enumeration:
- Refine PCI support check in pcibios_init() (Adrian-Ken Rueegsegger)
- Provide common functions for ECAM mapping (Jayachandran C)
- Allow all PCIe services on non-ACPI host bridges (Jon Derrick)
- Remove return values from pcie_port_platform_notify() and relatives (Jon Derrick)
- Widen portdrv service type from 4 bits to 8 bits (Keith Busch)
- Add Downstream Port Containment portdrv service type (Keith Busch)
- Add Downstream Port Containment driver (Keith Busch)
- Identify Enhanced Allocation (EA) BAR Equivalent resources in sysfs (Alex Williamson)
- Supply CPU physical address (not bus address) to iomem_is_exclusive() (Bjorn Helgaas)
- alpha: Call iomem_is_exclusive() for IORESOURCE_MEM, but not IORESOURCE_IO (Bjorn Helgaas)
- Mark Broadwell-EP Home Agent 1 as having non-compliant BARs (Prarit Bhargava)
- Disable all BAR sizing for devices with non-compliant BARs (Prarit Bhargava)
- Move PCI I/O space management from OF to PCI core code (Tomasz Nowicki)
PCI device hotplug:
- acpiphp_ibm: Avoid uninitialized variable reference (Dan Carpenter)
- Use cached copy of PCI_EXP_SLTCAP_HPC bit (Lukas Wunner)
Virtualization:
- Mark Intel i40e NIC INTx masking as broken (Alex Williamson)
- Reverse standard ACS vs device-specific ACS enabling (Alex Williamson)
- Work around Intel Sunrise Point PCH incorrect ACS capability (Alex Williamson)
IOMMU:
- Add pci_add_dma_alias() to abstract implementation (Bjorn Helgaas)
- Move informational printk to pci_add_dma_alias() (Bjorn Helgaas)
- Add support for multiple DMA aliases (Jacek Lawrynowicz)
- Add DMA alias quirk for mic_x200_dma (Jacek Lawrynowicz)
Thunderbolt:
- Fix double free of drom buffer (Andreas Noever)
- Add Intel Thunderbolt device IDs (Lukas Wunner)
- Fix typos and magic number (Lukas Wunner)
- Support 1st gen Light Ridge controller (Lukas Wunner)
- Use generic ECAM API (Jayachandran C)
Cavium ThunderX host bridge driver:
- Don't clobber read-only bits in bridge config registers (David Daney)
- Use enum instead of bool for variant indicator (Andrey Smirnov)
- Implement reset sequence for i.MX6+ (Andrey Smirnov)
- Factor out ref clock enable (Bjorn Helgaas)
- Add initial imx6sx support (Christoph Fritz)
- Add reset-gpio-active-high boolean property to DT (Petr Štetiar)
- Add DT property for link gen, default to Gen1 (Tim Harvey)
- dts: Specify imx6qp version of PCIe core (Andrey Smirnov)
- dts: Fix PCIe reset GPIO polarity on Toradex Apalis Ixora (Petr Štetiar)
Marvell Armada host bridge driver:
- add DT binding for Marvell Armada 7K/8K PCIe controller (Thomas Petazzoni)
- Add driver for Marvell Armada 7K/8K PCIe controller (Thomas Petazzoni)
Marvell MVEBU host bridge driver:
- Constify mvebu_pcie_pm_ops structure (Jisheng Zhang)
- Use SET_NOIRQ_SYSTEM_SLEEP_PM_OPS for mvebu_pcie_pm_ops (Jisheng Zhang)
- Report resources release after stopping the bus (Vitaly Kuznetsov)
- Add explicit barriers to config space access (Vitaly Kuznetsov)
- Select PCI_MSI_IRQ_DOMAIN (Arnd Bergmann)
- Remove incorrect RC memory base/limit configuration (Gabriele Paoloni)
- Move Root Complex setup code to dw_pcie_setup_rc() (Jisheng Zhang)
- Add error IRQ handler (Murali Karicheri)
- Remove unnecessary goto statement (Murali Karicheri)
Miscellaneous:
- Fix spelling errors (Colin Ian King)"
* tag 'pci-v4.7-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (48 commits)
PCI: Disable all BAR sizing for devices with non-compliant BARs
x86/PCI: Mark Broadwell-EP Home Agent 1 as having non-compliant BARs
PCI: Identify Enhanced Allocation (EA) BAR Equivalent resources in sysfs
PCI, of: Move PCI I/O space management to PCI core code
PCI: generic, thunder: Use generic ECAM API
PCI: Provide common functions for ECAM mapping
PCI: hv: Add explicit barriers to config space access
PCI: Use cached copy of PCI_EXP_SLTCAP_HPC bit
PCI: Add Downstream Port Containment driver
PCI: Add Downstream Port Containment portdrv service type
PCI: Widen portdrv service type from 4 bits to 8 bits
PCI: designware: Remove incorrect RC memory base/limit configuration
PCI: hv: Report resources release after stopping the bus
ARM: dts: imx6qp: Specify imx6qp version of PCIe core
PCI: imx6: Implement reset sequence for i.MX6+
PCI: imx6: Use enum instead of bool for variant indicator
PCI: thunder: Don't clobber read-only bits in bridge config registers
thunderbolt: Fix double free of drom buffer
PCI: rcar: Select PCI_MSI_IRQ_DOMAIN
PCI: armada: Add driver for Marvell Armada 7K/8K PCIe controller
* pci/hotplug:
* pci/resource:
Pull ACPI updates from Rafael Wysocki:
"The new features here are ACPI 6.1 support (and some previously
missing bits of ACPI 6.0 support) in ACPICA and two new drivers, a
driver for the ACPI Generic Event Device (GED) feature introduced by
ACPI 6.1 and the INT3406 thermal driver for display thermal
management. Also the value returned by the _HRV (hardware revision)
ACPI object will be exported to user space via sysfs now.
In addition to that, ACPI on ARM64 will not depend on EXPERT any more.
The rest is mostly fixes and cleanups and some code reorganization.
Specifics:
- In-kernel ACPICA code update to the upstream release 20160422
adding support for ACPI 6.1 along with some previously missing bits
of ACPI 6.0 support, making a fair amount of fixes and cleanups and
reducing divergences between the upstream ACPICA and the in-kernel
code (Bob Moore, Lv Zheng, Al Stone, Aleksey Makarov, Will Miles)
- ACPI Generic Event Device (GED) support and a fix for it (Sinan
Kaya, Paul Gortmaker)
- INT3406 thermal driver for display thermal management and ACPI
backlight support code reorganization related to it (Aaron Lu, Arnd
Bergmann)
- Support for exporting the value returned by the _HRV (hardware
revision) ACPI object via sysfs (Betty Dall)
- Removal of the EXPERT dependency for ACPI on ARM64 (Mark Brown)
- Rework of the handling of ACPI _OSI mechanism allowing the
_OSI("Darwin") support to be overridden from the kernel command
line among other things (Lv Zheng, Chen Yu)
- Rework of the ACPI tables override mechanism to prepare it for the
introduction of overlays support going forward (Lv Zheng, Rafael
Wysocki)
- Fixes related to the ECDT support and module-level execution of AML
(Lv Zheng)
- ACPI PCI interrupts management update to make it work better on
ARM64 mostly (Sinan Kaya)
- ACPI SRAT handling update to make the code process all entires in
the table order regardless of the entry type (Lukasz Anaczkowski)
- EFI power off support for full-hardware ACPI platforms that don't
support ACPI S5 (Chen Yu)
- Fixes and cleanups related to the ACPI core's sysfs interface (Dan
Carpenter, Betty Dall)
- acpi_dev_present() API rework to reduce possible confusion related
to it (Lukas Wunner)
- Removal of CLK_IS_ROOT from two ACPI drivers (Stephen Boyd)"
* tag 'acpi-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (82 commits)
ACPI / video: mark acpi_video_get_levels() inline
Thermal / ACPI / video: add INT3406 thermal driver
ACPI / GED: make evged.c explicitly non-modular
ACPI / tables: Fix DSDT override mechanism
ACPI / sysfs: fix error code in get_status()
ACPICA: Update version to 20160422
ACPICA: Move all ASCII utilities to a common file
ACPICA: ACPI 2.0, Hardware: Add access_width/bit_offset support for acpi_hw_write()
ACPICA: ACPI 2.0, Hardware: Add access_width/bit_offset support in acpi_hw_read()
ACPICA: Executer: Introduce a set of macros to handle bit width mask generation
ACPICA: Hardware: Add optimized access bit width support
ACPICA: Utilities: Add ACPI_IS_ALIGNED() macro
ACPICA: Renamed some #defined flag constants for clarity
ACPICA: ACPI 6.0, tools/iasl: Add support for new resource descriptors
ACPICA: ACPI 6.0: Update _BIX support for new package element
ACPICA: ACPI 6.1: Support for new PCCT subtable
ACPICA: Refactor evaluate_object to reduce nesting
ACPICA: Divergence: remove unwanted spaces for typedef
ACPI,PCI,IRQ: remove SCI penalize function
Commit b894157145e4 ("x86/PCI: Mark Broadwell-EP Home Agent & PCU as having
non-compliant BARs") marked Home Agent 0 & PCU has having non-compliant
BARs. Home Agent 1 also has non-compliant BARs.
Mark Home Agent 1 as having non-compliant BARs so the PCI core doesn't
touch them.
The problem with these devices is documented in the Xeon v4 specification
update:
BDF2 PCI BARs in the Home Agent Will Return Non-Zero Values
During Enumeration
Problem: During system initialization the Operating System may access
the standard PCI BARs (Base Address Registers). Due to
this erratum, accesses to the Home Agent BAR registers (Bus
1; Device 18; Function 0,4; Offsets (0x14-0x24) will return
non-zero values.
Implication: The operating system may issue a warning. Intel has not
observed any functional failures due to this erratum.
Link: http://www.intel.com/content/www/us/en/processors/xeon/xeon-e5-v4-spec-update.html
Fixes: b894157145e4 ("x86/PCI: Mark Broadwell-EP Home Agent & PCU as having non-compliant BARs")
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Ingo Molnar <mingo@redhat.com>
CC: "H. Peter Anvin" <hpa@zytor.com>
CC: Andi Kleen <ak@linux.intel.com>
acpi_irq_get_penalty is now calculating the penalty on the fly now.
No need to maintain global list of penalties or calculate them
at the init time. Removing duplicate code in acpi_irq_penalty_init.
