commit 51ac3d2f0c505ca36ffc9715ffd518d756589ef8 upstream.
NEC OEMs the same platforms as Stratus does, which have multiple devices on
some PCIe buses under downstream ports.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=51331
Fixes: 1278998f8ff6 ("PCI: Work around Stratus ftServer broken PCIe hierarchy (fix DMI check)")
Signed-off-by: Charlotte Richardson <charlotte.richardson@stratus.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: Myron Stowe <myron.stowe@redhat.com>
commit cbace46a9710a480cae51e4611697df5de41713e upstream.
Commit 30919b0bf356 ("x86: avoid low BIOS area when allocating address
space") moved the test for resource allocations that fall within the first
1MB of address space from the PCI-specific path to a generic path, such
that all resource allocations will avoid this area. However, this breaks
ISA cards which need to allocate a memory region within the first 1MB. An
example is the i82365 PCMCIA controller and derivatives like the Ricoh
RF5C296/396 which map part of the PCMCIA socket memory address space into
the first 1MB of system memory address space. They do not work anymore as
no usable memory region exists due to this change:
Intel ISA PCIC probe: Ricoh RF5C296/396 ISA-to-PCMCIA at port 0x3e0 ofs 0x00, 2 sockets
host opts [0]: none
host opts [1]: none
ISA irqs (scanned) = 3,4,5,9,10 status change on irq 10
pcmcia_socket pcmcia_socket1: pccard: PCMCIA card inserted into slot 1
pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcff: excluding 0xcf8-0xcff
pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3ff: excluding 0x170-0x177 0x1f0-0x1f7 0x2f8-0x2ff 0x370-0x37f 0x3c0-0x3e7 0x3f0-0x3ff
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0a0000-0x0affff: excluding 0xa0000-0xaffff
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0b0000-0x0bffff: excluding 0xb0000-0xbffff
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0cffff: excluding 0xc0000-0xcbfff
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0d0000-0x0dffff: clean.
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0e0000-0x0effff: clean.
pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff: clean.
pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff: clean.
pcmcia_socket pcmcia_socket1: cs: IO port probe 0xc00-0xcff: excluding 0xcf8-0xcff
pcmcia_socket pcmcia_socket1: cs: IO port probe 0xa00-0xaff: clean.
pcmcia_socket pcmcia_socket1: cs: IO port probe 0x100-0x3ff: excluding 0x170-0x177 0x1f0-0x1f7 0x2f8-0x2ff 0x370-0x37f 0x3c0-0x3e7 0x3f0-0x3ff
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0a0000-0x0affff: excluding 0xa0000-0xaffff
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0b0000-0x0bffff: excluding 0xb0000-0xbffff
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0c0000-0x0cffff: excluding 0xc0000-0xcbfff
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0d0000-0x0dffff: clean.
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0e0000-0x0effff: clean.
pcmcia_socket pcmcia_socket1: cs: memory probe 0x60000000-0x60ffffff: clean.
pcmcia_socket pcmcia_socket1: cs: memory probe 0xa0000000-0xa0ffffff: clean.
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0cc000-0x0effff: excluding 0xe0000-0xeffff
pcmcia_socket pcmcia_socket1: cs: unable to map card memory!
If filtering out the first 1MB is reverted, everything works as expected.
Tested-by: Robert Resch <fli4l@robert.reschpara.de>
Signed-off-by: Christoph Schulz <develop@kristov.de>
Pull ACPI and power management updates from Rafael Wysocki:
"As far as the number of commits goes, the top spot belongs to ACPI
this time with cpufreq in the second position and a handful of PM
core, PNP and cpuidle updates. They are fixes and cleanups mostly, as
usual, with a couple of new features in the mix.
The most visible change is probably that we will create struct
acpi_device objects (visible in sysfs) for all devices represented in
the ACPI tables regardless of their status and there will be a new
sysfs attribute under those objects allowing user space to check that
status via _STA.
Consequently, ACPI device eject or generally hot-removal will not
delete those objects, unless the table containing the corresponding
namespace nodes is unloaded, which is extremely rare. Also ACPI
container hotplug will be handled quite a bit differently and cpufreq
will support CPU boost ("turbo") generically and not only in the
acpi-cpufreq driver.
Specifics:
- ACPI core changes to make it create a struct acpi_device object for
every device represented in the ACPI tables during all namespace
scans regardless of the current status of that device. In
accordance with this, ACPI hotplug operations will not delete those
objects, unless the underlying ACPI tables go away.
- On top of the above, new sysfs attribute for ACPI device objects
allowing user space to check device status by triggering the
execution of _STA for its ACPI object. From Srinivas Pandruvada.
- ACPI core hotplug changes reducing code duplication, integrating
the PCI root hotplug with the core and reworking container hotplug.
- ACPI core simplifications making it use ACPI_COMPANION() in the
code "glueing" ACPI device objects to "physical" devices.
- ACPICA update to upstream version 20131218. This adds support for
the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves
debug facilities. From Bob Moore, Lv Zheng and Betty Dall.
- Init code change to carry out the early ACPI initialization
earlier. That should allow us to use ACPI during the timekeeping
initialization and possibly to simplify the EFI initialization too.
From Chun-Yi Lee.
- Clenups of the inclusions of ACPI headers in many places all over
from Lv Zheng and Rashika Kheria (work in progress).
- New helper for ACPI _DSM execution and rework of the code in
drivers that uses _DSM to execute it via the new helper. From
Jiang Liu.
- New Win8 OSI blacklist entries from Takashi Iwai.
- Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun
Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava,
Rashika Kheria, Tang Chen, Zhang Rui.
- intel_pstate driver updates, including proper Baytrail support,
from Dirk Brandewie and intel_pstate documentation from Ramkumar
Ramachandra.
- Generic CPU boost ("turbo") support for cpufreq from Lukasz
Majewski.
- powernow-k6 cpufreq driver fixes from Mikulas Patocka.
- cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark
Brown.
- Assorted cpufreq drivers fixes and cleanups from Anson Huang, John
Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh
Kumar.
- cpuidle cleanups from Bartlomiej Zolnierkiewicz.
- Support for hibernation APM events from Bin Shi.
- Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC
disabled during thaw transitions from Bjørn Mork.
- PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf
Hansson.
- PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente
Kurusa, Rashika Kheria.
- New tool for profiling system suspend from Todd E Brandt and a
cpupower tool cleanup from One Thousand Gnomes"
* tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits)
thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412)
cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ
Documentation: cpufreq / boost: Update BOOST documentation
cpufreq: exynos: Extend Exynos cpufreq driver to support boost
cpufreq / boost: Kconfig: Support for software-managed BOOST
acpi-cpufreq: Adjust the code to use the common boost attribute
cpufreq: Add boost frequency support in core
intel_pstate: Add trace point to report internal state.
cpufreq: introduce cpufreq_generic_get() routine
ARM: SA1100: Create dummy clk_get_rate() to avoid build failures
cpufreq: stats: create sysfs entries when cpufreq_stats is a module
cpufreq: stats: free table and remove sysfs entry in a single routine
cpufreq: stats: remove hotplug notifiers
cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly
cpufreq: speedstep: remove unused speedstep_get_state
platform: introduce OF style 'modalias' support for platform bus
PM / tools: new tool for suspend/resume performance optimization
ACPI: fix module autoloading for ACPI enumerated devices
ACPI: add module autoloading support for ACPI enumerated devices
ACPI: fix create_modalias() return value handling
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI changes for the v3.14 merge window:
Resource management
- Change pci_bus_region addresses to dma_addr_t (Bjorn Helgaas)
- Support 64-bit AGP BARs (Bjorn Helgaas, Yinghai Lu)
- Add pci_bus_address() to get bus address of a BAR (Bjorn Helgaas)
- Use pci_resource_start() for CPU address of AGP BARs (Bjorn Helgaas)
- Enforce bus address limits in resource allocation (Yinghai Lu)
- Allocate 64-bit BARs above 4G when possible (Yinghai Lu)
- Convert pcibios_resource_to_bus() to take pci_bus, not pci_dev (Yinghai Lu)
PCI device hotplug
- Major rescan/remove locking update (Rafael J. Wysocki)
- Make ioapic builtin only (not modular) (Yinghai Lu)
- Fix release/free issues (Yinghai Lu)
- Clean up pciehp (Bjorn Helgaas)
- Announce pciehp slot info during enumeration (Bjorn Helgaas)
MSI
- Add pci_msi_vec_count(), pci_msix_vec_count() (Alexander Gordeev)
- Add pci_enable_msi_range(), pci_enable_msix_range() (Alexander Gordeev)
- Deprecate "tri-state" interfaces: fail/success/fail+info (Alexander Gordeev)
- Export MSI mode using attributes, not kobjects (Greg Kroah-Hartman)
- Drop "irq" param from *_restore_msi_irqs() (DuanZhenzhong)
SR-IOV
- Clear NumVFs when disabling SR-IOV in sriov_init() (ethan.zhao)
Virtualization
- Add support for save/restore of extended capabilities (Alex Williamson)
- Add Virtual Channel to save/restore support (Alex Williamson)
- Never treat a VF as a multifunction device (Alex Williamson)
- Add pci_try_reset_function(), et al (Alex Williamson)
AER
- Ignore non-PCIe error sources (Betty Dall)
- Support ACPI HEST error sources for domains other than 0 (Betty Dall)
- Consolidate HEST error source parsers (Bjorn Helgaas)
- Add a TLP header print helper (Borislav Petkov)
Freescale i.MX6
- Remove unnecessary code (Fabio Estevam)
- Make reset-gpio optional (Marek Vasut)
- Report "link up" only after link training completes (Marek Vasut)
- Start link in Gen1 before negotiating for Gen2 mode (Marek Vasut)
- Fix PCIe startup code (Richard Zhu)
Marvell MVEBU
- Remove duplicate of_clk_get_by_name() call (Andrew Lunn)
- Drop writes to bridge Secondary Status register (Jason Gunthorpe)
- Obey bridge PCI_COMMAND_MEM and PCI_COMMAND_IO bits (Jason Gunthorpe)
- Support a bridge with no IO port window (Jason Gunthorpe)
- Use max_t() instead of max(resource_size_t,) (Jingoo Han)
- Remove redundant of_match_ptr (Sachin Kamat)
- Call pci_ioremap_io() at startup instead of dynamically (Thomas Petazzoni)
NVIDIA Tegra
- Disable Gen2 for Tegra20 and Tegra30 (Eric Brower)
Renesas R-Car
- Add runtime PM support (Valentine Barshak)
- Fix rcar_pci_probe() return value check (Wei Yongjun)
Synopsys DesignWare
- Fix crash in dw_msi_teardown_irq() (Bjørn Erik Nilsen)
- Remove redundant call to pci_write_config_word() (Bjørn Erik Nilsen)
- Fix missing MSI IRQs (Harro Haan)
- Add dw_pcie prefix before cfg_read/write (Pratyush Anand)
- Fix I/O transfers by using CPU (not realio) address (Pratyush Anand)
- Whitespace cleanup (Jingoo Han)
EISA
- Call put_device() if device_register() fails (Levente Kurusa)
- Revert EISA initialization breakage ((Bjorn Helgaas)
Miscellaneous
- Remove unused code, including PCIe 3.0 interfaces (Stephen Hemminger)
- Prevent bus conflicts while checking for bridge apertures (Bjorn Helgaas)
- Stop clearing bridge Secondary Status when setting up I/O aperture (Bjorn Helgaas)
- Use dev_is_pci() to identify PCI devices (Yijing Wang)
- Deprecate DEFINE_PCI_DEVICE_TABLE (Joe Perches)
- Update documentation 00-INDEX (Erik Ekman)"
* tag 'pci-v3.14-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (119 commits)
Revert "EISA: Initialize device before its resources"
Revert "EISA: Log device resources in dmesg"
vfio-pci: Use pci "try" reset interface
PCI: Check parent kobject in pci_destroy_dev()
xen/pcifront: Use global PCI rescan-remove locking
powerpc/eeh: Use global PCI rescan-remove locking
PCI: Fix pci_check_and_unmask_intx() comment typos
PCI: Add pci_try_reset_function(), pci_try_reset_slot(), pci_try_reset_bus()
MPT / PCI: Use pci_stop_and_remove_bus_device_locked()
platform / x86: Use global PCI rescan-remove locking
PCI: hotplug: Use global PCI rescan-remove locking
pcmcia: Use global PCI rescan-remove locking
ACPI / hotplug / PCI: Use global PCI rescan-remove locking
ACPI / PCI: Use global PCI rescan-remove locking in PCI root hotplug
PCI: Add global pci_lock_rescan_remove()
PCI: Cleanup pci.h whitespace
PCI: Reorder so actual code comes before stubs
PCI/AER: Support ACPI HEST AER error sources for PCI domains other than 0
ACPICA: Add helper macros to extract bus/segment numbers from HEST table.
PCI: Make local functions static
Pull Intel MID updates from Ingo Molnar:
"This tree improves Intel MID (Mobile Internet Device) platform
support:
- Merrifield platform support (David Cohen)
- Clovertrail platform support (Kuppuswamy Sathyanarayanan)
- Various cleanups and fixes (David Cohen)"
* 'x86-intel-mid-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, intel_mid: Replace memcpy with struct assignment
x86, intel-mid: Return proper error code from get_gpio_by_name()
x86, intel-mid: Check get_gpio_by_name() error code on platform code
x86, intel-mid: sfi_handle_*_dev() should check for pdata error code
x86, intel-mid: Remove deprecated X86_MDFLD and X86_WANT_INTEL_MID configs
x86, intel-mid: Add Merrifield platform support
x86, intel-mid: Add Clovertrail platform support
x86, intel-mid: Move Medfield code out of intel-mid.c core file
This code was partially based on Mark Brown's previous work.
Signed-off-by: David Cohen <david.a.cohen@linux.intel.com>
Link: http://lkml.kernel.org/r/1387224459-25746-4-git-send-email-david.a.cohen@linux.intel.com
Signed-off-by: Fei Yang <fei.yang@intel.com>
Cc: Mark F. Brown <mark.f.brown@intel.com>
Cc: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
[ hpa: undid incorrect removal from arch/x86/kernel/head_32.S ]
Link: http://lkml.kernel.org/r/1389054026-12947-1-git-send-email-paul.gortmaker@windriver.com
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Change x86_msi.restore_msi_irqs(struct pci_dev *dev, int irq) to
x86_msi.restore_msi_irqs(struct pci_dev *dev).
restore_msi_irqs() restores multiple MSI-X IRQs, so param 'int irq' is
unneeded. This makes code more consistent between vm and bare metal.
Dom0 MSI-X restore code can also be optimized as XEN only has a hypercall
to restore all MSI-X vectors at one time.
Tested-by: Sucheta Chakraborty <sucheta.chakraborty@qlogic.com>
Signed-off-by: Zhenzhong Duan <zhenzhong.duan@oracle.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
The following warnings can be seen in W=1 builds, because the original
sfi_acpi.[ch] header inclusions are incorrect:
include/linux/sfi_acpi.h:72:2: error: implicit declaration of function 'acpi_table_parse' [-Werror=implicit-function-declaration]
drivers/sfi/sfi_acpi.c:154:5: warning: no previous prototype for 'sfi_acpi_table_parse' [-Wmissing-prototypes]
Fix linux/sfi_acpi.h and modify drivers/sfi/sfi_acpi.c accordingly.
Reported-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
[rjw: Subject and changelog]
Replace direct inclusions of <acpi/acpi.h>, <acpi/acpi_bus.h> and
<acpi/acpi_drivers.h>, which are incorrect, with <linux/acpi.h>
inclusions and remove some inclusions of those files that aren't
necessary.
First of all, <acpi/acpi.h>, <acpi/acpi_bus.h> and <acpi/acpi_drivers.h>
should not be included directly from any files that are built for
CONFIG_ACPI unset, because that generally leads to build warnings about
undefined symbols in !CONFIG_ACPI builds. For CONFIG_ACPI set,
<linux/acpi.h> includes those files and for CONFIG_ACPI unset it
provides stub ACPI symbols to be used in that case.
Second, there are ordering dependencies between those files that always
have to be met. Namely, it is required that <acpi/acpi_bus.h> be included
prior to <acpi/acpi_drivers.h> so that the acpi_pci_root declarations the
latter depends on are always there. And <acpi/acpi.h> which provides
basic ACPICA type declarations should always be included prior to any other
ACPI headers in CONFIG_ACPI builds. That also is taken care of including
<linux/acpi.h> as appropriate.
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Acked-by: Bjorn Helgaas <bhelgaas@google.com> (drivers/pci stuff)
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> (Xen stuff)
Modify struct acpi_dev_node to contain a pointer to struct acpi_device
associated with the given device object (that is, its ACPI companion
device) instead of an ACPI handle corresponding to it. Introduce two
new macros for manipulating that pointer in a CONFIG_ACPI-safe way,
ACPI_COMPANION() and ACPI_COMPANION_SET(), and rework the
ACPI_HANDLE() macro to take the above changes into account.
Drop the ACPI_HANDLE_SET() macro entirely and rework its users to
use ACPI_COMPANION_SET() instead. For some of them who used to
pass the result of acpi_get_child() directly to ACPI_HANDLE_SET()
introduce a helper routine acpi_preset_companion() doing an
equivalent thing.
The main motivation for doing this is that there are things
represented by struct acpi_device objects that don't have valid
ACPI handles (so called fixed ACPI hardware features, such as
power and sleep buttons) and we would like to create platform
device objects for them and "glue" them to their ACPI companions
in the usual way (which currently is impossible due to the
lack of valid ACPI handles). However, there are more reasons
why it may be useful.
First, struct acpi_device pointers allow of much better type checking
than void pointers which are ACPI handles, so it should be more
difficult to write buggy code using modified struct acpi_dev_node
and the new macros. Second, the change should help to reduce (over
time) the number of places in which the result of ACPI_HANDLE() is
passed to acpi_bus_get_device() in order to obtain a pointer to the
struct acpi_device associated with the given "physical" device,
because now that pointer is returned by ACPI_COMPANION() directly.
Finally, the change should make it easier to write generic code that
will build both for CONFIG_ACPI set and unset without adding explicit
compiler directives to it.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> # on Haswell
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reviewed-by: Aaron Lu <aaron.lu@intel.com> # for ATA and SDIO part
Pull PCI changes from Bjorn Helgaas:
"Resource management
- Fix host bridge window coalescing (Alexey Neyman)
- Pass type, width, and prefetchability for window alignment (Wei Yang)
PCI device hotplug
- Convert acpiphp, acpiphp_ibm to dynamic debug (Lan Tianyu)
Power management
- Remove pci_pm_complete() (Liu Chuansheng)
MSI
- Fail initialization if device is not in PCI_D0 (Yijing Wang)
MPS (Max Payload Size)
- Use pcie_get_mps() and pcie_set_mps() to simplify code (Yijing Wang)
- Use pcie_set_readrq() to simplify code (Yijing Wang)
- Use cached pci_dev->pcie_mpss to simplify code (Yijing Wang)
SR-IOV
- Enable upstream bridges even for VFs on virtual buses (Bjorn Helgaas)
- Use pci_is_root_bus() to avoid catching virtual buses (Wei Yang)
Virtualization
- Add x86 MSI masking ops (Konrad Rzeszutek Wilk)
Freescale i.MX6
- Support i.MX6 PCIe controller (Sean Cross)
- Increase link startup timeout (Marek Vasut)
- Probe PCIe in fs_initcall() (Marek Vasut)
- Fix imprecise abort handler (Tim Harvey)
Renesas R-Car
- Support Gen2 internal PCIe controller (Valentine Barshak)
Samsung Exynos
- Add MSI support (Jingoo Han)
- Turn off power when link fails (Jingoo Han)
- Add Jingoo Han as maintainer (Jingoo Han)
- Add clk_disable_unprepare() on error path (Wei Yongjun)
Synopsys DesignWare
- Add irq_create_mapping() (Pratyush Anand)
- Add header guards (Seungwon Jeon)
Miscellaneous
- Enable native PCIe services by default on non-ACPI (Andrew Murray)
- Cleanup _OSC usage and messages (Bjorn Helgaas)
- Remove pcibios_last_bus boot option on non-x86 (Bjorn Helgaas)
- Convert bus code to use bus_, drv_, and dev_groups (Greg Kroah-Hartman)
- Remove unused pci_mem_start (Myron Stowe)
- Make sysfs functions static (Sachin Kamat)
- Warn on invalid return from driver probe (Stephen M. Cameron)
- Remove Intel Haswell D3 delays (Todd E Brandt)
- Call pci_set_master() in core if driver doesn't do it (Yinghai Lu)
- Use pci_is_pcie() to simplify code (Yijing Wang)
- Use PCIe capability accessors to simplify code (Yijing Wang)
- Use cached pci_dev->pcie_cap to simplify code (Yijing Wang)
- Removed unused "is_pcie" from struct pci_dev (Yijing Wang)
- Simplify sysfs CPU affinity implementation (Yijing Wang)"
* tag 'pci-v3.13-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (79 commits)
PCI: Enable upstream bridges even for VFs on virtual buses
PCI: Add pci_upstream_bridge()
PCI: Add x86_msi.msi_mask_irq() and msix_mask_irq()
PCI: Warn on driver probe return value greater than zero
PCI: Drop warning about drivers that don't use pci_set_master()
PCI: Workaround missing pci_set_master in pci drivers
powerpc/pci: Use pci_is_pcie() to simplify code [fix]
PCI: Update pcie_ports 'auto' behavior for non-ACPI platforms
PCI: imx6: Probe the PCIe in fs_initcall()
PCI: Add R-Car Gen2 internal PCI support
PCI: imx6: Remove redundant of_match_ptr
PCI: Report pci_pme_active() kmalloc failure
mn10300/PCI: Remove useless pcibios_last_bus
frv/PCI: Remove pcibios_last_bus
PCI: imx6: Increase link startup timeout
PCI: exynos: Remove redundant of_match_ptr
PCI: imx6: Fix imprecise abort handler
PCI: Fail MSI/MSI-X initialization if device is not in PCI_D0
PCI: imx6: Remove redundant dev_err() in imx6_pcie_probe()
x86/PCI: Coalesce multiple overlapping host bridge windows
* pci/misc:
Certain platforms do not allow writes in the MSI-X BARs to setup or tear
down vector values. To combat against the generic code trying to write to
that and either silently being ignored or crashing due to the pagetables
being marked R/O this patch introduces a platform override.
Note that we keep two separate, non-weak, functions default_mask_msi_irqs()
and default_mask_msix_irqs() for the behavior of the arch_mask_msi_irqs()
and arch_mask_msix_irqs(), as the default behavior is needed by x86 PCI
code.
For Xen, which does not allow the guest to write to MSI-X tables - as the
hypervisor is solely responsible for setting the vector values - we
implement two nops.
This fixes a Xen guest crash when passing a PCI device with MSI-X to the
guest. See the bugzilla for more details.
[bhelgaas: add bugzilla info]
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=64581
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
CC: Sucheta Chakraborty <sucheta.chakraborty@qlogic.com>
CC: Zhenzhong Duan <zhenzhong.duan@oracle.com>
* pci/misc:
MAINTAINERS: Add arch/x86/pci to PCI file patterns
PCI/PM: Remove pci_pm_complete()
PCI: Add pci_dev_show_local_cpu() to simplify code
mn10300/PCI: Remove unused pci_mem_start
cris/PCI: Remove unused pci_mem_start
PCI: Make pci_dev_pm_ops static
drivers/pci/pci-sysfs.c
mrst is used as common name to represent all intel_mid type
soc's. But moorsetwon is just one of the intel_mid soc. So
renamed them to use intel_mid.
This patch mainly renames the variables and related
functions that uses *mrst* prefix with *intel_mid*.
To ensure that there are no functional changes, I have compared
the objdump of related files before and after rename and found
the only difference is symbol and name changes.
Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com>
Link: http://lkml.kernel.org/r/1382049336-21316-6-git-send-email-david.a.cohen@linux.intel.com
Function 'type1_access_ok' should return bool value, not 0/1.
This patch changes 'return 0/1' to 'return false/true'.
Cc: H. Peter Anvin <hpa@linux.intel.com>
Cc: David Cohen <david.a.cohen@linux.intel.com>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Link: http://lkml.kernel.org/r/1382049336-21316-5-git-send-email-david.a.cohen@linux.intel.com
Following files contains code that is common to all intel mid
soc's. So renamed them as below.
mrst/mrst.c -> intel-mid/intel-mid.c
mrst/vrtc.c -> intel-mid/intel_mid_vrtc.c
mrst/early_printk_mrst.c -> intel-mid/intel_mid_vrtc.c
pci/mrst.c -> pci/intel_mid_pci.c
Also, renamed the corresponding header files and made changes
to the driver files that included these header files.
the objdump of renamed files before and after rename and found
that the only difference is file name change.
Link: http://lkml.kernel.org/r/1382049336-21316-4-git-send-email-david.a.cohen@linux.intel.com
Previously we coalesced windows by expanding the first overlapping one and
making the second invalid. But we never look at the expanded first window
again, so we fail to notice other windows that overlap it. For example, we
coalesced these:
[io 0x0000-0x03af] // #0
[io 0x03e0-0x0cf7] // #1
[io 0x0000-0xdfff] // #2
into these, which still overlap:
[io 0x0000-0xdfff] // #0
The fix is to expand the *second* overlapping resource and ignore the
first, so we get this instead with no overlaps:
[bhelgaas: changelog]
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=62511
Signed-off-by: Alexey Neyman <stilor@att.net>
This reverts commit 07f9b61c3915e8eb156cb4461b3946736356ad02.
07f9b61c was intended to be a cleanup that didn't change anything, but in
fact, for systems without _CBA (which is almost everything), it broke
extended config space for domain 0 and all config space for other domains.
Reference: http://lkml.kernel.org/r/20131004011806.GE20450@dangermouse.emea.sgi.com
Reported-by: Hedi Berriche <hedi@sgi.com>
The PCI core caches the PCIe Capability offset in pci_dev->pcie_cap, so
use that instead of pci_find_capability(). Use pci_bus_set_ops() when
replacing the device pci_ops. And use #defines instead of numeric
constants.
[bhelgaas: changelog, also use PCI_EXP_LNKCTL_ASPMC]
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
PCI device hotplug:
- Use PCIe native hotplug, not ACPI hotplug, when possible (Neil Horman)
- Assign resources on per-host bridge basis (Yinghai Lu)
MPS (Max Payload Size):
- Allow larger MPS settings below hotplug-capable Root Port (Yijing Wang)
- Add warnings about unsafe MPS settings (Yijing Wang)
- Simplify interface and messages (Bjorn Helgaas)
SR-IOV:
- Return -ENOSYS on non-SR-IOV devices (Stefan Assmann)
- Update NumVFs register when disabling SR-IOV (Yijing Wang)
Virtualization:
- Add bus and slot reset support (Alex Williamson)
- Fix ACS (Access Control Services) issues (Alex Williamson)
Miscellaneous:
- Simplify PCIe Capability accessors (Bjorn Helgaas)
- Add pcibios_pm_ops for arch-specific hibernate stuff (Sebastian Ott)
- Disable decoding during BAR sizing only when necessary (Zoltan Kiss)
- Delay enabling bridges until they're needed (Yinghai Lu)
- Split Designware support into Synopsys and Exynos parts (Jingoo Han)
- Convert class code to use dev_groups (Greg Kroah-Hartman)
- Cleanup Designware and Exynos I/O access wrappers (Seungwon Jeon)
- Fix bridge I/O window alignment (Bjorn Helgaas)
- Add pci_wait_for_pending_transaction() (Casey Leedom)
- Use devm_ioremap_resource() in Marvell driver (Tushar Behera)
* tag 'pci-v3.12-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (63 commits)
PCI/ACPI: Fix _OSC ordering to allow PCIe hotplug use when available
PCI: exynos: Add I/O access wrappers
PCI: designware: Drop "addr" arg from dw_pcie_readl_rc()/dw_pcie_writel_rc()
PCI: Remove pcie_cap_has_devctl()
PCI: Support PCIe Capability Slot registers only for ports with slots
PCI: Remove PCIe Capability version checks
PCI: Allow PCIe Capability link-related register access for switches
PCI: Add offsets of PCIe capability registers
PCI: Tidy bitmasks and spacing of PCIe capability definitions
PCI: Remove obsolete comment reference to pci_pcie_cap2()
PCI: Clarify PCI_EXP_TYPE_PCI_BRIDGE comment
PCI: Rename PCIe capability definitions to follow convention
PCI: Warn if unsafe MPS settings detected
PCI: Fix MPS peer-to-peer DMA comment syntax
PCI: Disable decoding for BAR sizing only when it was actually enabled
PCI: Add comment about needing pci_msi_off() even when CONFIG_PCI_MSI=n
PCI: Add pcibios_pm_ops for optional arch-specific hibernate functionality
PCI: Don't restrict MPS for slots below Root Ports
PCI: Simplify MPS test for Downstream Port
PCI: Remove unnecessary check for pcie_get_mps() failure
* pci/yijing-mps-v8:
PCI: Simplify pcie_bus_configure_settings() interface
PCI: Drop "PCI-E" prefix from Max Payload Size message
Based on a patch by Jon Mason (see URL below).
All users of pcie_bus_configure_settings() pass arguments of the form
"bus, bus->self->pcie_mpss". The "mpss" argument is redundant since we
can easily look it up internally. In addition, all callers check
"bus->self" for NULL, which we can also do internally.
This patch simplifies the interface and the callers. No functional change.
Reference: http://lkml.kernel.org/r/1317048850-30728-2-git-send-email-mason@myri.com
We can check for addr being zero earlier and thus avoid the mutex_unlock()
cleanup path.
[bhelgaas: drop warning printk]
Signed-off-by: ethan.zhao <ethan.zhao@oracle.com>
Acked-by: Yinghai Lu <yinghai@kernel.org>
This patch fixes warning and errors found by checkpatch.pl:
* replace asm/acpi.h, asm/io.h and asm/smp.h with linux/acpi.h,
linux/io.h and linux/smp.h respectively
* remove explicit initialization to 0 of a static global variable
* replace printk(KERN_INFO ...) with pr_info
* use tabs instead of spaces for indentation
* arrange comments so that they adhere to Documentation/CodingStyle
[bhelgaas: capitalize "PCI", "Langwell", "Lincroft" consistently]
Signed-off-by: Valentina Manea <valentina.manea.m@gmail.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
In hotplug case (especially with Thunderbolt enabled systems) we might need
to call pcibios_resource_survey_bus() several times for a bus. The function
ends up calling pci_claim_resource() for each bridge resource that then
fails claiming that the resource exists already (which it does). Once this
happens the resource is invalidated thus preventing devices behind the
bridge to allocate their resources.
To fix this we do what has been done in pcibios_allocate_dev_resources()
and check 'parent' of the given resource. If it is non-NULL it means that
the resource has been allocated already and we can skip it. We do the same
for ROM resources as well.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
Note that some harmless section mismatch warnings may result, since
notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c)
are flagged as __cpuinit -- so if we remove the __cpuinit from
arch specific callers, we will also get section mismatch warnings.
As an intermediate step, we intend to turn the linux/init.h cpuinit
content into no-ops as early as possible, since that will get rid
of these warnings. In any case, they are temporary and harmless.
This removes all the arch/x86 uses of the __cpuinit macros from
all C files. x86 only had the one __CPUINIT used in assembly files,
and it wasn't paired off with a .previous or a __FINIT, so we can
delete it directly w/o any corresponding additional change there.
[1] https://lkml.org/lkml/2013/5/20/589
Cc: x86@kernel.org
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
"PCI device hotplug
- Add pci_alloc_dev() interface (Gu Zheng)
- Add pci_bus_get()/put() for reference counting (Jiang Liu)
- Fix SR-IOV reference count issues (Jiang Liu)
- Remove unused acpi_pci_roots list (Jiang Liu)
MSI
- Conserve interrupt resources on x86 (Alexander Gordeev)
AER
- Force fatal severity when component has been reset (Betty Dall)
- Reset link below Root Port as well as Downstream Port (Betty Dall)
- Fix "Firmware first" flag setting (Bjorn Helgaas)
- Don't parse HEST for non-PCIe devices (Bjorn Helgaas)
ASPM
- Warn when we can't disable ASPM as driver requests (Bjorn Helgaas)
Miscellaneous
- Add CircuitCo PCI IDs (Darren Hart)
- Add AMD CZ SATA and SMBus PCI IDs (Shane Huang)
- Work around Ivytown NTB BAR size issue (Jon Mason)
- Detect invalid initial BAR values (Kevin Hao)
- Add pcibios_release_device() (Sebastian Ott)
- Fix powerpc & sparc PCI_UNKNOWN power state usage (Bjorn Helgaas)"
* tag 'pci-v3.11-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (51 commits)
MAINTAINERS: Add ACPI folks for ACPI-related things under drivers/pci
PCI: Add CircuitCo vendor ID and subsystem ID
PCI: Use pdev->pm_cap instead of pci_find_capability(..,PCI_CAP_ID_PM)
PCI: Return early on allocation failures to unindent mainline code
PCI: Simplify IOV implementation and fix reference count races
PCI: Drop redundant setting of bus->is_added in virtfn_add_bus()
unicore32/PCI: Remove redundant call of pci_bus_add_devices()
m68k/PCI: Remove redundant call of pci_bus_add_devices()
PCI / ACPI / PM: Use correct power state strings in messages
PCI: Fix comment typo for pcie_pme_remove()
PCI: Rename pci_release_bus_bridge_dev() to pci_release_host_bridge_dev()
PCI: Fix refcount issue in pci_create_root_bus() error recovery path
ia64/PCI: Clean up pci_scan_root_bus() usage
PCI/AER: Reset link for devices below Root Port or Downstream Port
ACPI / APEI: Force fatal AER severity when component has been reset
PCI/AER: Remove "extern" from function declarations
PCI/AER: Move AER severity defines to aer.h
PCI/AER: Set dev->__aer_firmware_first only for matching devices
PCI/AER: Factor out HEST device type matching
PCI/AER: Don't parse HEST table for non-PCIe devices
f9a37be0f0 ("x86: Use PCI setup data") added support for using PCI ROM
images from setup_data. This used phys_to_virt(), which is not valid for
highmem addresses, and can cause a crash when booting a 32-bit kernel via
the EFI boot stub.
pcibios_add_device() assumes that the physical addresses stored in
setup_data are accessible via the direct kernel mapping, and that calling
phys_to_virt() is valid. This isn't guaranteed to be true on x86 where the
direct mapping range is much smaller than on x86-64.
Calling phys_to_virt() on a highmem address results in the following:
BUG: unable to handle kernel paging request at 39a3c198
IP: [<c262be0f>] pcibios_add_device+0x2f/0x90
Call Trace:
[<c2370c73>] pci_device_add+0xe3/0x130
[<c274640b>] pci_scan_single_device+0x8b/0xb0
[<c2370d08>] pci_scan_slot+0x48/0x100
[<c2371904>] pci_scan_child_bus+0x24/0xc0
[<c262a7b0>] pci_acpi_scan_root+0x2c0/0x490
[<c23b7203>] acpi_pci_root_add+0x312/0x42f
The solution is to use ioremap() instead of phys_to_virt() to map the
setup data into the kernel address space.
Tested-by: Jani Nikula <jani.nikula@intel.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Cc: Seth Forshee <seth.forshee@canonical.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: stable@vger.kernel.org # v3.8+
We should increase info->res_num before we checking pci_use_crs return
when pci=nocrs set.
No functional change, since we don't use res_num and res_offset[]
in the "!pci_use_crs" case anyway, but this makes the code read better.
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Jiang Liu <liuj97@gmail.com>
Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com>
Cc: Feng Tang <feng.tang@intel.com>
00:03.0"
This reverts commit dd72be99d11dbf738d910a38479ce414a51eb21e.
Andy Shevchenko <andy.shevchenko@gmail.com> reported that this commit
broke Intel Medfield devices.
Reference: https://lkml.kernel.org/r/CAHp75Vdf6gFZChS47=grUygHBDWcoOWDYPzw+Zj5bdVCWj85Jw@mail.gmail.com
Reported-by: Andy Shevchenko <andy.shevchenko@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
Pull Xen bug-fixes from Konrad Rzeszutek Wilk:
- More fixes in the vCPU PVHVM hotplug path.
- Add more documentation.
- Fix various ARM related issues in the Xen generic drivers.
- Updates in the xen-pciback driver per Bjorn's updates.
- Mask the x2APIC feature for PV guests.
* tag 'stable/for-linus-3.10-rc0-tag-two' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/pci: Used cached MSI-X capability offset
xen/pci: Use PCI_MSIX_TABLE_BIR, not PCI_MSIX_FLAGS_BIRMASK
xen: clear IRQ_NOAUTOEN and IRQ_NOREQUEST
xen: mask x2APIC feature in PV
xen: SWIOTLB is only used on x86
xen/spinlock: Fix check from greater than to be also be greater or equal to.
xen/smp/pvhvm: Don't point per_cpu(xen_vpcu, 33 and larger) to shared_info
xen/vcpu: Document the xen_vcpu_info and xen_vcpu
xen/vcpu/pvhvm: Fix vcpu hotplugging hanging.
We now cache the MSI-X capability offset in the struct pci_dev, so no
need to find the capability again.
Acked-by: Jan Beulich <jbeulich@suse.com>
CC: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
PCI_MSIX_FLAGS_BIRMASK is mis-named because the BIR mask is in the
Table Offset register, not the flags ("Message Control" per spec)
register.
For real PCI devices 00:00.0, 00:02.0 and 00:03.0, there is either no
PCI shim, or no guarantee of data correctness of offset 256-4k. So for
whatever reason, Linux kernel should not do MMCFG PCI config access to
those devices. Instead, always use configuration mechanism 1 for those
devices.
The 00:00.0, 00:02.0 and 00:03.0 devices are built-in single-function
devices and are not PCI-PCI bridges, so this set of devices should be
complete.
Signed-off-by: Bin Gao <bin.gao@linux.intel.com>
"PCI changes for the v3.10 merge window:
PCI device hotplug
- Remove ACPI PCI subdrivers (Jiang Liu, Myron Stowe)
- Make acpiphp builtin only, not modular (Jiang Liu)
- Add acpiphp mutual exclusion (Jiang Liu)
Power management
- Skip "PME enabled/disabled" messages when not supported (Rafael
Wysocki)
- Fix fallback to PCI_D0 (Rafael Wysocki)
Miscellaneous
- Factor quirk_io_region (Yinghai Lu)
- Cache MSI capability offsets & cleanup (Gavin Shan, Bjorn Helgaas)
- Clean up EISA resource initialization and logging (Bjorn Helgaas)
- Fix prototype warnings (Andy Shevchenko, Bjorn Helgaas)
- MIPS: Initialize of_node before scanning bus (Gabor Juhos)
- Fix pcibios_get_phb_of_node() declaration "weak" annotation (Gabor
Juhos)
- Add MSI INTX_DISABLE quirks for AR8161/AR8162/etc (Xiong Huang)
- Fix aer_inject return values (Prarit Bhargava)
- Remove PME/ACPI dependency (Andrew Murray)
- Use shared PCI_BUS_NUM() and PCI_DEVID() (Shuah Khan)"
* tag 'pci-v3.10-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (63 commits)
vfio-pci: Use cached MSI/MSI-X capabilities
vfio-pci: Use PCI_MSIX_TABLE_BIR, not PCI_MSIX_FLAGS_BIRMASK
PCI: Remove "extern" from function declarations
PCI: Use PCI_MSIX_TABLE_BIR, not PCI_MSIX_FLAGS_BIRMASK
PCI: Drop msi_mask_reg() and remove drivers/pci/msi.h
PCI: Use msix_table_size() directly, drop multi_msix_capable()
PCI: Drop msix_table_offset_reg() and msix_pba_offset_reg() macros
PCI: Drop is_64bit_address() and is_mask_bit_support() macros
PCI: Drop msi_data_reg() macro
PCI: Drop msi_lower_address_reg() and msi_upper_address_reg() macros
PCI: Drop msi_control_reg() macro and use PCI_MSI_FLAGS directly
PCI: Use cached MSI/MSI-X offsets from dev, not from msi_desc
PCI: Clean up MSI/MSI-X capability #defines
PCI: Use cached MSI-X cap while enabling MSI-X
PCI: Use cached MSI cap while enabling MSI interrupts
PCI: Remove MSI/MSI-X cap check in pci_msi_check_device()
PCI: Cache MSI/MSI-X capability offsets in struct pci_dev
PCI: Use u8, not int, for PM capability offset
[SCSI] megaraid_sas: Use correct #define for MSI-X capability
For quite a few Xen versions, this wasn't the IRQ vector anymore
anyway, and it is not being used by the kernel for anything. Hence
drop the field from struct irq_info, and respective function
parameters.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Implement pcibios_{add|remove}_bus() hooks for x86 platforms.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Reviewed-by: Yinghai Lu <yinghai@kernel.org>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Myron Stowe <myron.stowe@redhat.com>
- Update the Xen ACPI memory and CPU hotplug locking mechanism.
- Fix PAT issues wherein various applications would not start
- Fix handling of multiple MSI as AHCI now does it.
- Fix ARM compile failures.
* tag 'stable/for-linus-3.9-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xenbus: fix compile failure on ARM with Xen enabled
xen/pci: We don't do multiple MSI's.
xen/pat: Disable PAT using pat_enabled value.
xen/acpi: xen cpu hotplug minor updates
xen/acpi: xen memory hotplug minor updates
There is no hypercall to setup multiple MSI per PCI device.
As such with these two new commits:
- 08261d87f7d1b6253ab3223756625a5c74532293
PCI/MSI: Enable multiple MSIs with pci_enable_msi_block_auto()
- 5ca72c4f7c412c2002363218901eba5516c476b1
AHCI: Support multiple MSIs
we would call the PHYSDEVOP_map_pirq 'nvec' times with the same
contents of the PCI device. Sander discovered that we would get
the same PIRQ value 'nvec' times and return said values to the
caller. That of course meant that the device was configured only
with one MSI and AHCI would fail with:
ahci 0000:00:11.0: version 3.0
xen: registering gsi 19 triggering 0 polarity 1
xen: --> pirq=19 -> irq=19 (gsi=19)
(XEN) [2013-02-27 19:43:07] IOAPIC[0]: Set PCI routing entry (6-19 -> 0x99 -> IRQ 19 Mode:1 Active:1)
ahci 0000:00:11.0: AHCI 0001.0200 32 slots 4 ports 6 Gbps 0xf impl SATA mode
ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part
ahci: probe of 0000:00:11.0 failed with error -22
That is b/c in ahci_host_activate the second call to
devm_request_threaded_irq would return -EINVAL as we passed in
(on the second run) an IRQ that was never initialized.
CC: stable@vger.kernel.org
Reported-and-Tested-by: Sander Eikelenboom <linux@eikelenboom.it>
"Host bridge hotplug
- Major overhaul of ACPI host bridge add/start (Rafael Wysocki, Yinghai Lu)
- Major overhaul of PCI/ACPI binding (Rafael Wysocki, Yinghai Lu)
- Split out ACPI host bridge and ACPI PCI device hotplug (Yinghai Lu)
- Stop caching _PRT and make independent of bus numbers (Yinghai Lu)
PCI device hotplug
- Clean up cpqphp dead code (Sasha Levin)
- Disable ARI unless device and upstream bridge support it (Yijing Wang)
- Initialize all hot-added devices (not functions 0-7) (Yijing Wang)
Power management
- Don't touch ASPM if disabled (Joe Lawrence)
- Fix ASPM link state management (Myron Stowe)
Miscellaneous
- Fix PCI_EXP_FLAGS accessor (Alex Williamson)
- Disable Bus Master in pci_device_shutdown (Konstantin Khlebnikov)
- Document hotplug resource and MPS parameters (Yijing Wang)
- Add accessor for PCIe capabilities (Myron Stowe)
- Drop pciehp suspend/resume messages (Paul Bolle)
- Make pci_slot built-in only (not a module) (Jiang Liu)
- Remove unused PCI/ACPI bind ops (Jiang Liu)
- Removed used pci_root_bus (Bjorn Helgaas)"
* tag 'pci-v3.9-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (51 commits)
PCI/ACPI: Don't cache _PRT, and don't associate them with bus numbers
PCI: Fix PCI Express Capability accessors for PCI_EXP_FLAGS
ACPI / PCI: Make pci_slot built-in only, not a module
PCI/PM: Clear state_saved during suspend
PCI: Use atomic_inc_return() rather than atomic_add_return()
PCI: Catch attempts to disable already-disabled devices
PCI: Disable Bus Master unconditionally in pci_device_shutdown()
PCI: acpiphp: Remove dead code for PCI host bridge hotplug
PCI: acpiphp: Create companion ACPI devices before creating PCI devices
PCI: Remove unused "rc" in virtfn_add_bus()
PCI: pciehp: Drop suspend/resume ENTRY messages
PCI/ASPM: Don't touch ASPM if forcibly disabled
PCI/ASPM: Deallocate upstream link state even if device is not PCIe
PCI: Document MPS parameters pci=pcie_bus_safe, pci=pcie_bus_perf, etc
PCI: Document hpiosize= and hpmemsize= resource reservation parameters
PCI: Use PCI Express Capability accessor
PCI: Introduce accessor to retrieve PCIe Capabilities Register
PCI: Put pci_dev in device tree as early as possible
PCI: Skip attaching driver in device_add()
PCI: acpiphp: Keep driver loaded even if no slots found
Add UV3 to exclusion list. Instead of adding every new series of
SGI UV systems, just check oem_id to have a prefix of "SGI".
Signed-off-by: Mike Travis <travis@sgi.com>
Link: http://lkml.kernel.org/r/20130211194508.457937455@gulag1.americas.sgi.com
Acked-by: Russ Anderson <rja@sgi.com>
Reviewed-by: Dimitri Sivanich <sivanich@sgi.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
* pci/rafael-set-root-bridge-handle:
ACPI / PCI: Set root bridge ACPI handle in advance
The ACPI handles of PCI root bridges need to be known to
acpi_bind_one(), so that it can create the appropriate
"firmware_node" and "physical_node" files for them, but currently
the way it gets to know those handles is not exactly straightforward
(to put it lightly).
This is how it works, roughly:
1. acpi_bus_scan() finds the handle of a PCI root bridge,
creates a struct acpi_device object for it and passes that
object to acpi_pci_root_add().
2. acpi_pci_root_add() creates a struct acpi_pci_root object,
populates its "device" field with its argument's address
(device->handle is the ACPI handle found in step 1).
3. The struct acpi_pci_root object created in step 2 is passed
to pci_acpi_scan_root() and used to get resources that are
passed to pci_create_root_bus().
4. pci_create_root_bus() creates a struct pci_host_bridge object
and passes its "dev" member to device_register().
5. platform_notify(), which for systems with ACPI is set to
acpi_platform_notify(), is called.
So far, so good. Now it starts to be "interesting".
6. acpi_find_bridge_device() is used to find the ACPI handle of
the given device (which is the PCI root bridge) and executes
acpi_pci_find_root_bridge(), among other things, for the
given device object.
7. acpi_pci_find_root_bridge() uses the name (sic!) of the given
device object to extract the segment and bus numbers of the PCI
root bridge and passes them to acpi_get_pci_rootbridge_handle().
8. acpi_get_pci_rootbridge_handle() browses the list of ACPI PCI
root bridges and finds the one that matches the given segment
and bus numbers. Its handle is then used to initialize the
ACPI handle of the PCI root bridge's device object by
acpi_bind_one(). However, this is *exactly* the ACPI handle we
started with in step 1.
Needless to say, this is quite embarassing, but it may be avoided
thanks to commit f3fd0c8 (ACPI: Allow ACPI handles of devices to be
initialized in advance), which makes it possible to initialize the
ACPI handle of a device before passing it to device_register().
Accordingly, add a new __weak routine, pcibios_root_bridge_prepare(),
defaulting to an empty implementation that can be replaced by the
interested architecutres (x86 and ia64 at the moment) with functions
that will set the root bridge's ACPI handle before its dev member is
passed to device_register(). Make both x86 and ia64 provide such
implementations of pcibios_root_bridge_prepare() and remove
acpi_pci_find_root_bridge() and acpi_get_pci_rootbridge_handle() that
aren't necessary any more.
Included is a fix for breakage on systems with non-ACPI PCI host
bridges from Bjorn Helgaas.
* pci/yinghai-survey-resources:
x86/PCI: Implement pcibios_resource_survey_bus()
PCI/ACPI: Reserve firmware-allocated resources for hot-added root buses
x86/PCI: Keep resource allocation functions after boot
x86/PCI: Don't track firmware-assigned BAR values for hot-added devices
x86/PCI: Factor out pcibios_allocate_dev_rom_resource()
x86/PCI: Allocate resources on a per-bus basis for hot-adding root buses
x86/PCI: Factor out pcibios_allocate_dev_resources()
x86/PCI: Factor out pcibios_allocate_bridge_resources()
During testing remove/rescan root bus 00, found
[ 338.142574] bus: 'pci': really_probe: probing driver ata_piix with device 0000:00:01.1
[ 338.146788] ata_piix 0000:00:01.1: device not available (can't reserve [io 0x01f0-0x01f7])
[ 338.150565] ata_piix: probe of 0000:00:01.1 failed with error -22
because that fixed resource is not claimed.
For bootint path it is claimed in from
arch/x86/pci/i386.c::pcibios_allocate_resources()
Claim those resources, so on the remove/rescan will still use old
resources.
It is some kind honoring FW setting in the registers during hot add.
esp root-bus hot add is through acpi, BIOS has chance to set some registers
before handing over.
[bhelgaas: move weak definition to patch that uses it]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
The PCI resource allocation functions will be used for hot-added
devices, so keep them around.
The BIOS doesn't assign BAR values for hot-added devices, so don't
bother saving the original values when we enumerate these devices.
[bhelgaas: changelog, return constant 0 in pcibios_retrieve_fw_addr]
Factor pcibios_allocate_rom_resources() and
pcibios_allocate_dev_rom_resource() out of pcibios_assign_resources().
This will allow us to allocate ROM resources for hot-added root buses.
