Historically a lot of these existed because we did not have
a distinction between what was modular code and what was providing
support to modules via EXPORT_SYMBOL and friends. That changed
when we forked out support for the latter into the export.h file.
This means we should be able to reduce the usage of module.h
in code that is obj-y Makefile or bool Kconfig. The advantage
in doing so is that module.h itself sources about 15 other headers;
adding significantly to what we feed cpp, and it can obscure what
headers we are effectively using.
Since module.h was the source for init.h (for __init) and for
export.h (for EXPORT_SYMBOL) we consider each obj-y/bool instance
for the presence of either and replace as needed.
One module.h was converted to moduleparam.h since the file had
multiple module_param() in it, and another file had an instance of
MODULE_DEVICE_TABLE deleted, since that is a no-op when builtin.
Finally, the 32 bit build coverage of olpc_ofw revealed a couple
implicit includes, which were pretty self evident to fix based on
what gcc was complaining about.
Link: http://lkml.kernel.org/r/20160714001901.31603-6-paul.gortmaker@windriver.com
SFI specification v0.8.2 defines type of devices which are connected to
SD bus. In particularly WiFi dongle is a such.
Add a callback to enumerate the devices connected to SD bus.
Cc: Bjorn Helgaas <bhelgaas@google.com>
Link: http://lkml.kernel.org/r/1468322192-62080-1-git-send-email-andriy.shevchenko@linux.intel.com
The patch was generated using fixed coccinelle semantic patch
scripts/coccinelle/api/memdup.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2014320
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Link: http://lkml.kernel.org/r/1438934377-4922-9-git-send-email-a.hajda@samsung.com
Convert IOAPIC driver to support and use hierarchical irqdomain
interfaces. It's a little big, but would break bisecting if we split
it into multiple patches.
Fold in a patch from Andy Shevchenko <andriy.shevchenko@linux.intel.com>
to make it bisectable.
http://lkml.org/lkml/2014/12/10/622
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Tested-by: Joerg Roedel <jroedel@suse.de>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Sander Eikelenboom <linux@eikelenboom.it>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: sfi-devel@simplefirmware.org
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Dimitri Sivanich <sivanich@sgi.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Rob Herring <robh@kernel.org>
Cc: David Cohen <david.a.cohen@linux.intel.com>
Link: http://lkml.kernel.org/r/1428905519-23704-38-git-send-email-jiang.liu@linux.intel.com
Introduce helper functions to manipulate struct irq_alloc_info for
IOAPIC. Also add an extra parameter to IOAPIC interfaces to prepare
for hierarchical irqdomain. Function mp_set_gsi_attr() will be removed
once we have switched to hierarchical irqdomains.
Cc: Jan Beulich <JBeulich@suse.com>
Link: http://lkml.kernel.org/r/1428905519-23704-33-git-send-email-jiang.liu@linux.intel.com
Correctly indent code in function sfi_parse_mtmr().
Tested-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: H. Peter Anvin <hpa@linux.intel.com>
Cc: Jiri Kosina <trivial@kernel.org>
Link: http://lkml.kernel.org/r/1428905519-23704-31-git-send-email-jiang.liu@linux.intel.com
MID has no PIC, but depending on the platform it requires the
abt_timer, which is connected to irq0. The timer is set up at
late_time_init().
But, looking at the MID code it seems, that there is no reason to do
so. The only code which might need the timer working is the TSC
calibration code, but thats a non issue on MID as that is using its
own empty calibration function. And check_timer() is not invoked
either because MID has no PIC and therefor no legacy irqs.
So if you look at intel_mid_time_init() then you'll see that in the
ARAT case the timer setup is skipped already. So until the point where
x86_init.timers.setup_percpu_clockev() is called for the boot cpu
nothing really needs a timer on MID.
According to the MID code the apbt horror is only used for moorestown.
Medfield and later use the local apic timer without the apbt nonsense.
The best thing we can do is to drop moorestown support and get rid of
that apbt nonsense alltogether.
I don't think anyone deeply cares about it not being supported from
3.18 on. The number of devices which sport a moorestown should be
pretty limited and the only relevant use case of those is to act as a
pocket heater with short battery life time. Its pretty pointless to
update kernels on pocket heaters except for bragging reasons.
If someone at Intel really thinks that we need to keep moorestown
alive for other than documentary and sentimental reasons, then we can
move the apbt setup to x86_init.timers.setup_percpu_clockev(). At that
point the IOAPIC is setup already, so it should just work.
Cc: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com>
Cc: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
Link: http://lkml.kernel.org/r/1428905519-23704-30-git-send-email-jiang.liu@linux.intel.com
Intel MID platforms has no legacy interrupts, so no IRQ descriptors
preallocated. We need to call mp_map_gsi_to_irq() to create IRQ
descriptors for APB timers and RTC timers, otherwise it may cause
invalid memory access as:
[ 0.116839] BUG: unable to handle kernel NULL pointer dereference at
0000003a
[ 0.123803] IP: [<c1071c0e>] setup_irq+0xf/0x4d
Cc: <stable@vger.kernel.org> # 3.17
Link: http://lkml.kernel.org/r/1414387308-27148-3-git-send-email-jiang.liu@linux.intel.com
Refine SFI to use common irqdomain map interface to program IOAPIC pins,
so we can unify the callsite to progam IOAPIC pins.
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Len Brown <lenb@kernel.org>
Link: http://lkml.kernel.org/r/1402302011-23642-33-git-send-email-jiang.liu@linux.intel.com
Enhance SFI to provide basic support of irqdomain with identity mapping
between GSIs and IRQs.
Some Intel MID platforms assumes identity mapping between GSI and IRQ,
so we can't dynamically allocate IRQ number on demand.
Link: http://lkml.kernel.org/r/1402302011-23642-28-git-send-email-jiang.liu@linux.intel.com
This is a cleanup proposed by coccinelle. It replaces memcpy with struct
assignment on intel-mid's sfi layer.
Generated by: coccinelle/misc/memcpy-assign.cocci
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Link: http://lkml.kernel.org/r/1389917588-9785-1-git-send-email-david.a.cohen@linux.intel.com
Signed-off-by: David Cohen <david.a.cohen@linux.intel.com>
This patch cleans up get_gpio_by_name() to return an error code
instead of hardcoded -1.
Link: http://lkml.kernel.org/r/1389913624-9149-4-git-send-email-david.a.cohen@linux.intel.com
When Intel MID finds a match between SFI table from FW and registered
SFI devices, it will always register a device regardless the platform
code was successful or not.
This patch adds an extra option for platform code to return error code
and abort device registration on SFI table parsing.
This patch does not contain any functional changes for current intel
mid platform code.
Link: http://lkml.kernel.org/r/1389913624-9149-2-git-send-email-david.a.cohen@linux.intel.com
This code was partially based on Mark Brown's previous work.
Link: http://lkml.kernel.org/r/1387224459-25746-4-git-send-email-david.a.cohen@linux.intel.com
Signed-off-by: Fei Yang <fei.yang@intel.com>
Cc: Mark F. Brown <mark.f.brown@intel.com>
As Intel rolling out more SoC's after Moorestown, we need to
re-structure the code in a way that is backward compatible and easy to
expand. This patch implements a flexible way to support multiple boards
and devices.
This patch does not add any new functional support. It just refactors
the existing code to increase the modularity and decrease the code
duplication for supporting multiple soc's and boards.
Currently intel-mid.c has both board and soc related code in one file.
This patch moves the board related code to new files and let linker
script to create SFI devite table following this:
1. Move the SFI device specific code to
arch/x86/platform/intel-mid/device-libs/platform_<device>.*
A new device file is added for every supported device. This code will
get conditionally compiled by using corresponding device driver
CONFIG option.
2. Move the device_ids location to .x86_intel_mid_dev.init section by
using new sfi_device() macro.
This patch was based on previous code from Sathyanarayanan Kuppuswamy.
Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com>
Link: http://lkml.kernel.org/r/1382049336-21316-13-git-send-email-david.a.cohen@linux.intel.com
Intel mid sfi code doesn't need struct devs_id.get_platform_data != NULL.
If the callback is not set, just assume there is no platform_data.
Link: http://lkml.kernel.org/r/1382049336-21316-11-git-send-email-david.a.cohen@linux.intel.com
Moved SFI specific parsing/handling code to sfi.c. This will enable us
to reuse our intel-mid code for platforms that supports firmware
interfaces other than SFI (like ACPI).
Link: http://lkml.kernel.org/r/1382049336-21316-10-git-send-email-david.a.cohen@linux.intel.com
