path: root/arch/x86/tools
2010-02-07x86: Remove trailing spaces in messagesFrans Pop
Signed-off-by: Frans Pop <elendil@planet.nl> Cc: Avi Kivity <avi@redhat.com> Cc: x86@kernel.org LKML-Reference: <1265478443-31072-10-git-send-email-elendil@planet.nl> [ Left out the KVM bits. ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-28Merge branch 'iommu/fixes' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/joro/linux-2.6-iommu into x86/urgent
2009-12-18x86: Fix objdump version check in chkobjdump.awk for different formats.Masami Hiramatsu
Different version of objdump says its version in different way; GNU objdump 2.16.1 or GNU objdump version 2.19.51.0.14-1.fc11 20090722 This patch uses the first argument which starts with a number as version string. Changes in v2: - Remove unneeded increment. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> LKML-Reference: <20091218154012.16960.5113.stgit@dhcp-100-2-132.bos.redhat.com> Suggested-by: H. Peter Anvin <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-17x86: Fix objdump version check in arch/x86/tools/chkobjdump.awkakpm@linux-foundation.org
It says Warning: objdump version is older than 2.19 Warning: Skipping posttest. because it used the wrong field from `objdump -v': akpm:/usr/src/25> /opt/crosstool/gcc-4.0.2-glibc-2.3.6/x86_64-unknown-linux-gnu/bin/x86_64-unknown-linux-gnu-objdump -v GNU objdump 2.16.1 Copyright 2005 Free Software Foundation, Inc. This program is free software; you may redistribute it under the terms of the GNU General Public License. This program has absolutely no warranty. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <200912172326.nBHNQaQl024796@imap1.linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Masami Hiramatsu <mhiramat@redhat.com>
2009-12-17x86: Don't use POSIX character classes in gen-insn-attr-x86.awkRoland Dreier
Not all awk implementations (including the default awk in Ubuntu 9.10) support POSIX character classes. Since x86-opcode-map.txt is plain ASCII, we can just use explicit ranges for lower case, alphabetic, and alphanumeric characters instead. Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> LKML-Reference: <adabphy750b.fsf@roland-alpha.cisco.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-16Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Fix kprobes build with non-gawk awk x86: Split swiotlb initialization into two stages x86: Regex support and known-movable symbols for relocs, fix _end x86, msr: Remove incorrect, duplicated code in the MSR driver x86: Merge kernel_thread() x86: Sync 32/64-bit kernel_thread x86, 32-bit: Use same regs as 64-bit for kernel_thread_helper x86, 64-bit: Use user_mode() to determine new stack pointer in copy_thread() x86, 64-bit: Move kernel_thread to C x86-64, paravirt: Call set_iopl_mask() on 64 bits x86-32: Avoid pipeline serialization in PTREGSCALL1 and 2 x86: Merge sys_clone x86, 32-bit: Convert sys_vm86 & sys_vm86old x86: Merge sys_sigaltstack x86: Merge sys_execve x86: Merge sys_iopl x86-32: Add new pt_regs stubs cpumask: Use modern cpumask style in arch/x86/kernel/cpu/mcheck/mce-inject.c
2009-12-15x86: Fix kprobes build with non-gawk awkJonathan Nieder
The instruction attribute table generator fails when run by mawk or original-awk: $ mawk -f arch/x86/tools/gen-insn-attr-x86.awk \ arch/x86/lib/x86-opcode-map.txt > /dev/null Semantic error at 240: Second IMM error $ echo $? 1 Line 240 contains "c8: ENTER Iw,Ib", which indicates that this instruction has two immediate operands, the second of which is one byte. The script loops through the immediate operands using a for loop. Unfortunately, there is no guarantee in awk that a for (variable in array) loop will return the indices in increasing order. Internally, both original-awk and mawk iterate over a hash table for this purpose, and both implementations happen to produce the index 2 before 1. The supposed second immediate operand is more than one byte wide, producing the error. So loop over the indices in increasing order instead. As a side-effect, with mawk this means the silly two-entry hash table never has to be built. Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Acked-by Masami Hiramatsu <mhiramat@redhat.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091213220437.GA27718@progeny.tock> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-06x86, perf probe: Fix warning in test_get_len()Jean Delvare
Fix the following warning: arch/x86/tools/test_get_len.c: In function "main": arch/x86/tools/test_get_len.c:116: warning: unused variable "c" Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-03Merge branch 'perf/probes' into perf/coreIngo Molnar
Merge reason: add these fixes to 'perf probe'. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-20x86: insn decoder test checks objdump versionMasami Hiramatsu
Check objdump version before using it for insn decoder build test, because some older objdump can't decode AVX code correctly. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Jim Keniston <jkenisto@us.ibm.com> LKML-Reference: <20091120171314.6715.30390.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-11-20x86: Fix insn decoder test typosMasami Hiramatsu
Fix postest_verbose to posttest_verbose, and add posttest_64bit option for CONFIG_64BIT != y, since old command just passed '-' instead of '-n' when CONFIG_64BIT is not set. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Jim Keniston <jkenisto@us.ibm.com> LKML-Reference: <20091120171307.6715.66099.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-11-19x86: Instruction decoder test should generate build warningMasami Hiramatsu
Since some instructions are not decoded correctly by older versions of objdump, it may cause false positive error in insn decoder posttest. This changes build error of insn decoder test to build warning. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> LKML-Reference: <20091116230631.5250.41579.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-17x86: Show symbol name if insn decoder test failedMasami Hiramatsu
Show symbol name if insn decoder test find a difference. This will help us to find out where the issue is. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> LKML-Reference: <20091116230624.5250.49813.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-17x86: Add verbose option to insn decoder testMasami Hiramatsu
Add verbose option to insn decoder test. This dumps decoded instruction when building kernel with V=1. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> LKML-Reference: <20091116230618.5250.18762.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-29x86: AVX instruction set decoder supportMasami Hiramatsu
Add Intel AVX(Advanced Vector Extensions) instruction set support to x86 instruction decoder. This adds insn.vex_prefix field for storing VEX prefixes, and introduces some original tags for expressing opcodes attributes. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> LKML-Reference: <20091027204226.30545.23451.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-29x86: Merge INAT_REXPFX into INAT_PFX_*Masami Hiramatsu
Merge INAT_REXPFX into INAT_PFX_* macro and rename it to INAT_PFX_REX. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> LKML-Reference: <20091027204211.30545.58090.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-21x86, instruction decoder: Fix test_get_len build rulesIngo Molnar
Add the kernel source include file as well to the include files search path, to fix this build bug: In file included from arch/x86/tools/test_get_len.c:28: arch/x86/lib/insn.c:21:26: error: linux/string.h: No such file or directory Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap<systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091020165531.4145.21872.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-04x86: Remove unused config macros from instruction decoder selftestMasami Hiramatsu
Remove dummy definitions of CONFIG_X86_64 and CONFIG_X86_32 because those macros are not used in the instruction decoder anymore. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <20090828221326.8778.70723.stgit@localhost.localdomain> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-09-04x86: Allow x86-32 instruction decoder selftest on x86-64Masami Hiramatsu
Pass $(CONFIG_64BIT) to the x86 insn decoder selftest in case we are decoding 32bit code on x86-64, which will happen when building kernel with ARCH=i386 on x86-64. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <20090828221319.8778.88508.stgit@localhost.localdomain> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-08-27x86: Check awk features before generating inat-tables.cMasami Hiramatsu
Check some awk mandatory features to generate inat-tables.c that old mawk doesn't support. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Avi Kivity <avi@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Przemysław Pawełczyk <przemyslaw@pawelczyk.it> Cc: Roland McGrath <roland@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> LKML-Reference: <20090821194316.12478.57394.stgit@localhost.localdomain> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-08-27x86: Fix x86 instruction decoder selftest to check only .textMasami Hiramatsu
Fix x86 instruction decoder selftest to check only .text because other sections (e.g. .notes) will have random bytes which don't need to be checked. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Avi Kivity <avi@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Przemysław Pawełczyk <przemyslaw@pawelczyk.it> Cc: Roland McGrath <roland@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> LKML-Reference: <20090821194307.12478.76938.stgit@localhost.localdomain> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-08-27x86: X86 instruction decoder build-time selftestMasami Hiramatsu
Add a user-space selftest of x86 instruction decoder at kernel build time. When CONFIG_X86_DECODER_SELFTEST=y, Kbuild builds a test harness of x86 instruction decoder and performs it after building vmlinux. The test compares the results of objdump and x86 instruction decoder code and check there are no differences. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Avi Kivity <avi@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Przemysław Pawełczyk <przemyslaw@pawelczyk.it> Cc: Roland McGrath <roland@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> LKML-Reference: <20090813203421.31965.29006.stgit@localhost.localdomain> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-08-27x86: Instruction decoder APIMasami Hiramatsu
Add x86 instruction decoder to arch-specific libraries. This decoder can decode x86 instructions used in kernel into prefix, opcode, modrm, sib, displacement and immediates. This can also show the length of instructions. This version introduces instruction attributes for decoding instructions. The instruction attribute tables are generated from the opcode map file (x86-opcode-map.txt) by the generator script(gen-insn-attr-x86.awk). Currently, the opcode maps are based on opcode maps in Intel(R) 64 and IA-32 Architectures Software Developers Manual Vol.2: Appendix.A, and consist of below two types of opcode tables. 1-byte/2-bytes/3-bytes opcodes, which has 256 elements, are written as below; Table: table-name Referrer: escaped-name opcode: mnemonic|GrpXXX [operand1[,operand2...]] [(extra1)[,(extra2)...] [| 2nd-mnemonic ...] (or) opcode: escape # escaped-name EndTable Group opcodes, which has 8 elements, are written as below; GrpTable: GrpXXX reg: mnemonic [operand1[,operand2...]] [(extra1)[,(extra2)...] [| 2nd-mnemonic ...] EndTable These opcode maps include a few SSE and FP opcodes (for setup), because those opcodes are used in the kernel. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Avi Kivity <avi@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Przemysław Pawełczyk <przemyslaw@pawelczyk.it> Cc: Roland McGrath <roland@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> LKML-Reference: <20090813203413.31965.49709.stgit@localhost.localdomain> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
