path: root/arch/x86/xen/Kconfig
2008-04-24xen: allow compilation with non-flat memoryJeremy Fitzhardinge
There's no real reason we can't support sparsemem/discontigmem, so do so. This is mostly useful to support hotplug memory. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: remove depends on X86_32 from PARAVIRT & PARAVIRT_GUESTEduardo Pereira Habkost
With this, the paravirt_ops code can be enabled on x86_64 also. Each guest implementation (Xen, VMI, lguest) now depends on X86_32. The dependencies can be dropped for each one when they start to support x86_64. Signed-off-by: Eduardo Habkost <ehabkost@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-23Normalize config options for guest supportRusty Russell
1) Group all the "guest OS" support options together, under a PARAVIRT_GUEST menu. 2) Make those options select CONFIG_PARAVIRT, as suggested by Andi. 3) Make kconfig help titles consistent. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <ak@suse.de> Cc: Zach Amsden <zach@vmware.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Chris Wright <chrisw@sous-sol.org>
2007-10-11i386: move xenThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
