commit 0594c58161b6e0f3da8efa9c6e3d4ba52b652717 upstream.
The initial observation was that in PV mode under Xen 32-bit user space
didn't work anymore. Attempts of system calls ended in #GP(0x402). All
of the sudden the vector 0x80 handler was not in place anymore. As it
turns out up to 5.13 redundant initialization did occur: Once from
cpu_initialize_context() (through its VCPUOP_initialise hypercall) and a
2nd time while each CPU was brought fully up. This 2nd initialization is
now gone, uncovering that the 1st one was flawed: Unlike for the
set_trap_table hypercall, a full virtual IDT needs to be specified here;
the "vector" fields of the individual entries are of no interest. With
many (kernel) IDT entries still(?) (i.e. at that point at least) empty,
the syscall vector 0x80 ended up in slot 0x20 of the virtual IDT, thus
becoming the domain's handler for vector 0x20.
Make xen_convert_trap_info() fit for either purpose, leveraging the fact
that on the xen_copy_trap_info() path the table starts out zero-filled.
This includes moving out the writing of the sentinel, which would also
have lead to a buffer overrun in the xen_copy_trap_info() case if all
(kernel) IDT entries were populated. Convert the writing of the sentinel
to clearing of the entire table entry rather than just the address
field.
(I didn't bother trying to identify the commit which uncovered the issue
in 5.14; the commit named below is the one which actually introduced the
bad code.)
Fixes: f87e4cac4f4e ("xen: SMP guest support")
Cc: stable@vger.kernel.org
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Link: https://lore.kernel.org/r/7a266932-092e-b68f-f2bb-1473b61adc6e@suse.com
Signed-off-by: Juergen Gross <jgross@suse.com>
commit 88c15ec90ff16880efab92b519436ee17b198477 upstream.
As result of commit "x86/xen: Avoid fast syscall path for Xen PV
guests", the irq_enable_sysexit pv op is not called by Xen PV guests
anymore and since they were the only ones who used it we can
safely remove it.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Acked-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: david.vrabel@citrix.com
Cc: konrad.wilk@oracle.com
Cc: virtualization@lists.linux-foundation.org
Cc: xen-devel@lists.xenproject.org
Link: http://lkml.kernel.org/r/1447970147-1733-3-git-send-email-boris.ostrovsky@oracle.com
commit def9331a12977770cc6132d79f8e6565871e8e38 upstream
When running as Xen pv guest X86_BUG_SYSRET_SS_ATTRS must not be set
on AMD cpus.
This bug/feature bit is kind of special as it will be used very early
when switching threads. Setting the bit and clearing it a little bit
later leaves a critical window where things can go wrong. This time
window has enlarged a little bit by using setup_clear_cpu_cap() instead
of the hypervisor's set_cpu_features callback. It seems this larger
window now makes it rather easy to hit the problem.
The proper solution is to never set the bit in case of Xen.
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
Signed-off-by: Srivatsa S. Bhat <srivatsa@csail.mit.edu>
Reviewed-by: Matt Helsley (VMware) <matt.helsley@gmail.com>
Reviewed-by: Alexey Makhalov <amakhalov@vmware.com>
Reviewed-by: Bo Gan <ganb@vmware.com>
Upstream commit: 0808e80cb760de2733c0527d2090ed2205a1eef8 ("xen: set
cpu capabilities from xen_start_kernel()")
There is no need to set the same capabilities for each cpu
individually. This can easily be done for all cpus when starting the
kernel.
commit 660da7c9228f685b2ebe664f9fd69aaddcc420b5 upstream.
We can use PCID if the CPU has PCID and PGE and we're not on Xen.
By itself, this has no effect. A followup patch will start using PCID.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Nadav Amit <nadav.amit@gmail.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/6327ecd907b32f79d5aa0d466f04503bbec5df88.1498751203.git.luto@kernel.org
commit 88ba281108ed0c25c9d292b48bd3f272fcb90dd0 upstream.
Xen supports PAT without MTRRs for its guests. In order to
enable WC attribute, it was necessary for xen_start_kernel()
to call pat_init_cache_modes() to update PAT table before
starting guest kernel.
Now that the kernel initializes PAT table to the BIOS handoff
state when MTRR is disabled, this Xen-specific PAT init code
is no longer necessary. Delete it from xen_start_kernel().
Also change __init_cache_modes() to a static function since
PAT table should not be tweaked by other modules.
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Acked-by: Juergen Gross <jgross@suse.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: elliott@hpe.com
Cc: paul.gortmaker@windriver.com
Link: http://lkml.kernel.org/r/1458769323-24491-7-git-send-email-toshi.kani@hpe.com
commit 02f037d641dc6672be5cfe7875a48ab99b95b154 upstream.
In preparation for fixing a regression caused by:
9cd25aac1f44 ("x86/mm/pat: Emulate PAT when it is disabled")'
... PAT needs to support a case that PAT MSR is initialized with a
non-default value.
When pat_init() is called and PAT is disabled, it initializes the
PAT table with the BIOS default value. Xen, however, sets PAT MSR
with a non-default value to enable WC. This causes inconsistency
between the PAT table and PAT MSR when PAT is set to disable on Xen.
Change pat_init() to handle the PAT disable cases properly. Add
init_cache_modes() to handle two cases when PAT is set to disable.
1. CPU supports PAT: Set PAT table to be consistent with PAT MSR.
2. CPU does not support PAT: Set PAT table to be consistent with
PWT and PCD bits in a PTE.
Note, __init_cache_modes(), renamed from pat_init_cache_modes(),
will be changed to a static function in a later patch.
Cc: elliott@hpe.com
Link: http://lkml.kernel.org/r/1458769323-24491-2-git-send-email-toshi.kani@hpe.com
commit b7a584598aea7ca73140cb87b40319944dd3393f upstream.
On Xen PV, regs->flags doesn't reliably reflect IOPL and the
exit-to-userspace code doesn't change IOPL. We need to context
switch it manually.
I'm doing this without going through paravirt because this is
specific to Xen PV. After the dust settles, we can merge this with
the 32-bit code, tidy up the iopl syscall implementation, and remove
the set_iopl pvop entirely.
Fixes XSA-171.
Reviewewd-by: Jan Beulich <JBeulich@suse.com>
Cc: Andrew Cooper <andrew.cooper3@citrix.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Jan Beulich <JBeulich@suse.com>
Link: http://lkml.kernel.org/r/693c3bd7aeb4d3c27c92c622b7d0f554a458173c.1458162709.git.luto@kernel.org
Adding the rtc platform device in non-privileged Xen PV guests causes
an IRQ conflict because these guests do not have legacy PIC and may
allocate irqs in the legacy range.
In a single VCPU Xen PV guest we should have:
/proc/interrupts:
CPU0
0: 4934 xen-percpu-virq timer0
1: 0 xen-percpu-ipi spinlock0
2: 0 xen-percpu-ipi resched0
3: 0 xen-percpu-ipi callfunc0
4: 0 xen-percpu-virq debug0
5: 0 xen-percpu-ipi callfuncsingle0
6: 0 xen-percpu-ipi irqwork0
7: 321 xen-dyn-event xenbus
8: 90 xen-dyn-event hvc_console
But hvc_console cannot get its interrupt because it is already in use
by rtc0 and the console does not work.
genirq: Flags mismatch irq 8. 00000000 (hvc_console) vs. 00000000 (rtc0)
We can avoid this problem by realizing that unprivileged PV guests (both
Xen and lguests) are not supposed to have rtc_cmos device and so
adding it is not necessary.
Privileged guests (i.e. Xen's dom0) do use it but they should not have
irq conflicts since they allocate irqs above legacy range (above
gsi_top, in fact).
Instead of explicitly testing whether the guest is privileged we can
extend pv_info structure to include information about guest's RTC
support.
Reported-and-tested-by: Sander Eikelenboom <linux@eikelenboom.it>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Cc: vkuznets@redhat.com
Cc: stable@vger.kernel.org # 4.2+
Link: http://lkml.kernel.org/r/1449842873-2613-1-git-send-email-boris.ostrovsky@oracle.com
After 32-bit syscall rewrite, and specifically after commit:
5f310f739b4c ("x86/entry/32: Re-implement SYSENTER using the new C path")
... the stack frame that is passed to xen_sysexit is no longer a
"standard" one (i.e. it's not pt_regs).
Since we end up calling xen_iret from xen_sysexit we don't need
to fix up the stack and instead follow entry_SYSENTER_32's IRET
path directly to xen_iret.
We can do the same thing for compat mode even though stack does
not need to be fixed. This will allow us to drop usergs_sysret32
paravirt op (in the subsequent patch)
Suggested-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/1447970147-1733-2-git-send-email-boris.ostrovsky@oracle.com
Build cpu_hotplug for ARM and ARM64 guests.
Rename arch_(un)register_cpu to xen_(un)register_cpu and provide an
empty implementation on ARM and ARM64. On x86 just call
arch_(un)register_cpu as we are already doing.
Initialize cpu_hotplug on ARM.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Reviewed-by: Julien Grall <julien.grall@citrix.com>
Currently there is a number of issues preventing PVHVM Xen guests from
doing successful kexec/kdump:
- Bound event channels.
- Registered vcpu_info.
- PIRQ/emuirq mappings.
- shared_info frame after XENMAPSPACE_shared_info operation.
- Active grant mappings.
Basically, newly booted kernel stumbles upon already set up Xen
interfaces and there is no way to reestablish them. In Xen-4.7 a new
feature called 'soft reset' is coming. A guest performing kexec/kdump
operation is supposed to call SCHEDOP_shutdown hypercall with
SHUTDOWN_soft_reset reason before jumping to new kernel. Hypervisor
(with some help from toolstack) will do full domain cleanup (but
keeping its memory and vCPU contexts intact) returning the guest to
the state it had when it was first booted and thus allowing it to
start over.
Doing SHUTDOWN_soft_reset on Xen hypervisors which don't support it is
probably OK as by default all unknown shutdown reasons cause domain
destroy with a message in toolstack log: 'Unknown shutdown reason code
5. Destroying domain.' which gives a clue to what the problem is and
eliminates false expectations.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: <stable@vger.kernel.org>
For PV guests these registers are set up by hypervisor and thus
should not be written by the guest. The comment in xen_write_msr_safe()
says so but we still write the MSRs, causing the hypervisor to
print a warning.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen updates from David Vrabel:
"Xen features and fixes for 4.3:
- Convert xen-blkfront to the multiqueue API
- [arm] Support binding event channels to different VCPUs.
- [x86] Support > 512 GiB in a PV guests (off by default as such a
guest cannot be migrated with the current toolstack).
- [x86] PMU support for PV dom0 (limited support for using perf with
Xen and other guests)"
* tag 'for-linus-4.3-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (33 commits)
xen: switch extra memory accounting to use pfns
xen: limit memory to architectural maximum
xen: avoid another early crash of memory limited dom0
xen: avoid early crash of memory limited dom0
arm/xen: Remove helpers which are PV specific
xen/x86: Don't try to set PCE bit in CR4
xen/PMU: PMU emulation code
xen/PMU: Intercept PMU-related MSR and APIC accesses
xen/PMU: Describe vendor-specific PMU registers
xen/PMU: Initialization code for Xen PMU
xen/PMU: Sysfs interface for setting Xen PMU mode
xen: xensyms support
xen: remove no longer needed p2m.h
xen: allow more than 512 GB of RAM for 64 bit pv-domains
xen: move p2m list if conflicting with e820 map
xen: add explicit memblock_reserve() calls for special pages
mm: provide early_memremap_ro to establish read-only mapping
xen: check for initrd conflicting with e820 map
xen: check pre-allocated page tables for conflict with memory map
xen: check for kernel memory conflicting with memory layout
Since VPMU code emulates RDPMC instruction with RDMSR and because hypervisor
does not emulate it there is no reason to try setting CR4's PCE bit (and the
hypervisor will warn on seeing it set).
Provide interfaces for recognizing accesses to PMU-related MSRs and
LVTPC APIC and process these accesses in Xen PMU code.
(The interrupt handler performs XENPMU_flush right away in the beginning
since no PMU emulation is available. It will be added with a later patch).
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Map shared data structure that will hold CPU registers, VPMU context,
V/PCPU IDs of the CPU interrupted by PMU interrupt. Hypervisor fills
this information in its handler and passes it to the guest for further
processing.
Set up PMU VIRQ.
Now that perf infrastructure will assume that PMU is available on a PV
guest we need to be careful and make sure that accesses via RDPMC
instruction don't cause fatal traps by the hypervisor. Provide a nop
RDPMC handler.
For the same reason avoid issuing a warning on a write to APIC's LVTPC.
Both of these will be made functional in later patches.
Some special pages containing interfaces to xen are being reserved
implicitly only today. The memblock_reserve() call to reserve them is
meant to reserve the p2m list supplied by xen. It is just reserving
not only the p2m list itself, but some more pages up to the start of
the xen built page tables.
To be able to move the p2m list to another pfn range, which is needed
for support of huge RAM, this memblock_reserve() must be split up to
cover all affected reserved pages explicitly.
The affected pages are:
- start_info page
- xenstore ring (might be missing, mfn is 0 in this case)
- console ring (not for initial domain)
The update_va_mapping hypercall can fail if the VA isn't present
in the guest's page tables. Under certain loads, this can
result in an OOPS when the target address is in unpopulated vmap
space.
While we're at it, add comments to help explain what's going on.
This isn't a great long-term fix. This code should probably be
changed to use something like set_memory_ro.
Cc: David Vrabel <dvrabel@cantab.net>
Cc: Jan Beulich <jbeulich@suse.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: security@kernel.org <security@kernel.org>
Cc: xen-devel <xen-devel@lists.xen.org>
Link: http://lkml.kernel.org/r/0b0e55b995cda11e7829f140b833ef932fcabe3a.1438291540.git.luto@kernel.org
We've had ->read_tsc() and ->read_tscp() paravirt hooks since
the very beginning of paravirt, i.e.,
d3561b7fa0fb ("[PATCH] paravirt: header and stubs for paravirtualisation").
AFAICT, the only paravirt guest implementation that ever
replaced these calls was vmware, and it's gone. Arguably even
vmware shouldn't have hooked RDTSC -- we fully support systems
that don't have a TSC at all, so there's no point for a paravirt
implementation to pretend that we have a TSC but to replace it.
I also doubt that these hooks actually worked. Calls to rdtscl()
and rdtscll(), which respected the hooks, were used seemingly
interchangeably with native_read_tsc(), which did not.
Just remove them. If anyone ever needs them again, they can try
to make a case for why they need them.
Before, on a paravirt config:
12618257 1816384 1093632 15528273 ecf151 vmlinux
After:
12617207 1816384 1093632 15527223 eced37 vmlinux
Cc: Huang Rui <ray.huang@amd.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Len Brown <lenb@kernel.org>
Cc: kvm ML <kvm@vger.kernel.org>
Link: http://lkml.kernel.org/r/d08a2600fb298af163681e5efd8e599d889a5b97.1434501121.git.luto@kernel.org
Pull x86 core updates from Ingo Molnar:
"There were so many changes in the x86/asm, x86/apic and x86/mm topics
in this cycle that the topical separation of -tip broke down somewhat -
so the result is a more traditional architecture pull request,
collected into the 'x86/core' topic.
The topics were still maintained separately as far as possible, so
bisectability and conceptual separation should still be pretty good -
but there were a handful of merge points to avoid excessive
dependencies (and conflicts) that would have been poorly tested in the
end.
The next cycle will hopefully be much more quiet (or at least will
have fewer dependencies).
The main changes in this cycle were:
* x86/apic changes, with related IRQ core changes: (Jiang Liu, Thomas
Gleixner)
- This is the second and most intrusive part of changes to the x86
interrupt handling - full conversion to hierarchical interrupt
domains:
[IOAPIC domain] -----
[MSI domain] --------[Remapping domain] ----- [ Vector domain ]
| (optional) |
[HPET MSI domain] ----- |
[DMAR domain] -----------------------------
[Legacy domain] -----------------------------
This now reflects the actual hardware and allowed us to distangle
the domain specific code from the underlying parent domain, which
can be optional in the case of interrupt remapping. It's a clear
separation of functionality and removes quite some duct tape
constructs which plugged the remap code between ioapic/msi/hpet
and the vector management.
- Intel IOMMU IRQ remapping enhancements, to allow direct interrupt
injection into guests (Feng Wu)
* x86/asm changes:
- Tons of cleanups and small speedups, micro-optimizations. This
is in preparation to move a good chunk of the low level entry
code from assembly to C code (Denys Vlasenko, Andy Lutomirski,
Brian Gerst)
- Moved all system entry related code to a new home under
arch/x86/entry/ (Ingo Molnar)
- Removal of the fragile and ugly CFI dwarf debuginfo annotations.
Conversion to C will reintroduce many of them - but meanwhile
they are only getting in the way, and the upstream kernel does
not rely on them (Ingo Molnar)
- NOP handling refinements. (Borislav Petkov)
* x86/mm changes:
- Big PAT and MTRR rework: making the code more robust and
preparing to phase out exposing direct MTRR interfaces to drivers -
in favor of using PAT driven interfaces (Toshi Kani, Luis R
Rodriguez, Borislav Petkov)
- New ioremap_wt()/set_memory_wt() interfaces to support
Write-Through cached memory mappings. This is especially
important for good performance on NVDIMM hardware (Toshi Kani)
* x86/ras changes:
- Add support for deferred errors on AMD (Aravind Gopalakrishnan)
This is an important RAS feature which adds hardware support for
poisoned data. That means roughly that the hardware marks data
which it has detected as corrupted but wasn't able to correct, as
poisoned data and raises an APIC interrupt to signal that in the
form of a deferred error. It is the OS's responsibility then to
take proper recovery action and thus prolonge system lifetime as
far as possible.
- Add support for Intel "Local MCE"s: upcoming CPUs will support
CPU-local MCE interrupts, as opposed to the traditional system-
wide broadcasted MCE interrupts (Ashok Raj)
- Misc cleanups (Borislav Petkov)
* x86/platform changes:
- Intel Atom SoC updates
... and lots of other cleanups, fixlets and other changes - see the
shortlog and the Git log for details"
* 'x86-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (222 commits)
x86/hpet: Use proper hpet device number for MSI allocation
x86/hpet: Check for irq==0 when allocating hpet MSI interrupts
x86/mm/pat, drivers/infiniband/ipath: Use arch_phys_wc_add() and require PAT disabled
x86/mm/pat, drivers/media/ivtv: Use arch_phys_wc_add() and require PAT disabled
x86/platform/intel/baytrail: Add comments about why we disabled HPET on Baytrail
genirq: Prevent crash in irq_move_irq()
genirq: Enhance irq_data_to_desc() to support hierarchy irqdomain
iommu, x86: Properly handle posted interrupts for IOMMU hotplug
iommu, x86: Provide irq_remapping_cap() interface
iommu, x86: Setup Posted-Interrupts capability for Intel iommu
iommu, x86: Add cap_pi_support() to detect VT-d PI capability
iommu, x86: Avoid migrating VT-d posted interrupts
iommu, x86: Save the mode (posted or remapped) of an IRTE
iommu, x86: Implement irq_set_vcpu_affinity for intel_ir_chip
iommu: dmar: Provide helper to copy shared irte fields
iommu: dmar: Extend struct irte for VT-d Posted-Interrupts
iommu: Add new member capability to struct irq_remap_ops
x86/asm/entry/64: Disentangle error_entry/exit gsbase/ebx/usermode code
x86/asm/entry/32: Shorten __audit_syscall_entry() args preparation
x86/asm/entry/32: Explain reloading of registers after __audit_syscall_entry()
x86/core, to merge last updates
In the case when PAT is disabled on the command line with
"nopat" or when virtualization doesn't support PAT (correctly) -
see
9d34cfdf4796 ("x86: Don't rely on VMWare emulating PAT MSR correctly").
we emulate it using the PWT and PCD cache attribute bits. Get
rid of boot_pat_state while at it.
Based on a conglomerate patch from Toshi Kani.
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
Cc: Elliott@hp.com
Cc: arnd@arndb.de
Cc: hch@lst.de
Cc: hmh@hmh.eng.br
Cc: linux-mm <linux-mm@kvack.org>
Cc: linux-nvdimm@lists.01.org
Cc: stefan.bader@canonical.com
Cc: yigal@plexistor.com
Link: http://lkml.kernel.org/r/1433436928-31903-3-git-send-email-bp@alien8.de
After the latest round of cleanups, fpu__cpu_init() has become
a simple call to fpu__init_cpu().
Rename fpu__init_cpu() to fpu__cpu_init() and remove the
extra layer.
Reviewed-by: Borislav Petkov <bp@alien8.de>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
fpu_init() is a bit of a misnomer in that it (falsely) creates the
impression that it's related to the (old) fpu_finit() function,
which initializes FPU ctx state.
Rename it to fpu__cpu_init() to make its boot time initialization
clear, and to move it to the fpu__*() namespace.
Also fix and extend its comment block to point out that it's
called not only on the boot CPU, but on secondary CPUs as well.
Commit 61f01dd941ba ("x86_64, asm: Work around AMD SYSRET SS descriptor
attribute issue") makes AMD processors set SS to __KERNEL_DS in
__switch_to() to deal with cases when SS is NULL.
This breaks Xen PV guests who do not want to load SS with__KERNEL_DS.
Since the problem that the commit is trying to address would have to be
fixed in the hypervisor (if it in fact exists under Xen) there is no
reason to set X86_BUG_SYSRET_SS_ATTRS flag for PV VPCUs here.
This can be easily achieved by adding x86_hyper_xen_hvm.set_cpu_features
op which will clear this flag. (And since this structure is no longer
HVM-specific we should do some renaming).
Reported-by: Sander Eikelenboom <linux@eikelenboom.it>
We don't use irq_enable_sysexit on 64-bit kernels any more.
Remove all the paravirt and Xen machinery to support it on
64-bit kernels.
Tested-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Denys Vlasenko <vda.linux@googlemail.com>
Link: http://lkml.kernel.org/r/8a03355698fe5b94194e9e7360f19f91c1b2cf1f.1428100853.git.luto@kernel.org
Pull xen features and fixes from David Vrabel:
- use a single source list of hypercalls, generating other tables etc.
at build time.
- add a "Xen PV" APIC driver to support >255 VCPUs in PV guests.
- significant performance improve to guest save/restore/migration.
- scsiback/front save/restore support.
- infrastructure for multi-page xenbus rings.
- misc fixes.
* tag 'stable/for-linus-4.1-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/pci: Try harder to get PXM information for Xen
xenbus_client: Extend interface to support multi-page ring
xen-pciback: also support disabling of bus-mastering and memory-write-invalidate
xen: support suspend/resume in pvscsi frontend
xen: scsiback: add LUN of restored domain
xen-scsiback: define a pr_fmt macro with xen-pvscsi
xen/mce: fix up xen_late_init_mcelog() error handling
xen/privcmd: improve performance of MMAPBATCH_V2
xen: unify foreign GFN map/unmap for auto-xlated physmap guests
x86/xen/apic: WARN with details.
x86/xen: Provide a "Xen PV" APIC driver to support >255 VCPUs
xen/pciback: Don't print scary messages when unsupported by hypervisor.
xen: use generated hypercall symbols in arch/x86/xen/xen-head.S
xen: use generated hypervisor symbols in arch/x86/xen/trace.c
xen: synchronize include/xen/interface/xen.h with xen
xen: build infrastructure for generating hypercall depending symbols
xen: balloon: Use static attribute groups for sysfs entries
xen: pcpu: Use static attribute groups for sysfs entry
Instead of mangling the default APIC driver, provide a Xen PV guest
specific one that explicitly provides appropriate methods.
This allows use to report that all APIC IDs are valid, allowing dom0
to boot with more than 255 VCPUs.
Since the probe order of APIC drivers is link dependent, we add in an
late probe function to change to the Xen PV if it hadn't been done
during bootup.
Suggested-by: David Vrabel <david.vrabel@citrix.com>
Reported-by: Cathy Avery <cathy.avery@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
We currently store references to the top of the kernel stack in
multiple places: kernel_stack (with an offset) and
init_tss.x86_tss.sp0 (no offset). The latter is defined by
hardware and is a clean canonical way to find the top of the
stack. Add an accessor so we can start using it.
This needs minor paravirt tweaks. On native, sp0 defines the
top of the kernel stack and is therefore always correct. On Xen
and lguest, the hypervisor tracks the top of the stack, but we
want to start reading sp0 in the kernel. Fixing this is simple:
just update our local copy of sp0 as well as the hypervisor's
copy on task switches.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/8d675581859712bee09a055ed8f785d80dac1eca.1425611534.git.luto@amacapital.net
Commit 1e02ce4cccdc ("x86: Store a per-cpu shadow copy of CR4")
introduced CR4 shadows.
These shadows are initialized in early boot code. The commit missed
initialization for 64-bit PV(H) guests that this patch adds.
Commit d524165cb8db ("x86/apic: Check x2apic early") tests X2APIC_ENABLE
bit of MSR_IA32_APICBASE when CONFIG_X86_X2APIC is off and panics
the kernel when this bit is set.
Xen's PV guests will pass this MSR read to the hypervisor which will
return its version of the MSR, where this bit might be set. Make sure
we clear it before returning MSR value to the caller.
CR4 manipulation was split, seemingly at random, between direct
(write_cr4) and using a helper (set/clear_in_cr4). Unfortunately,
the set_in_cr4 and clear_in_cr4 helpers also poke at the boot code,
which only a small subset of users actually wanted.
This patch replaces all cr4 access in functions that don't leave cr4
exactly the way they found it with new helpers cr4_set_bits,
cr4_clear_bits, and cr4_set_bits_and_update_boot.
Cc: Vince Weaver <vince@deater.net>
Cc: "hillf.zj" <hillf.zj@alibaba-inc.com>
Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/495a10bdc9e67016b8fd3945700d46cfd5c12c2f.1414190806.git.luto@amacapital.net
Pull xen bug fixes from David Vrabel:
"Several critical linear p2m fixes that prevented some hosts from
booting"
* tag 'stable/for-linus-3.19-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
x86/xen: properly retrieve NMI reason
xen: check for zero sized area when invalidating memory
xen: use correct type for physical addresses
xen: correct race in alloc_p2m_pmd()
xen: correct error for building p2m list on 32 bits
x86/xen: avoid freeing static 'name' when kasprintf() fails
x86/xen: add extra memory for remapped frames during setup
x86/xen: don't count how many PFNs are identity mapped
x86/xen: Free bootmem in free_p2m_page() during early boot
x86/xen: Remove unnecessary BUG_ON(preemptible()) in xen_setup_timer()
Using the native code here can't work properly, as the hypervisor would
normally have cleared the two reason bits by the time Dom0 gets to see
the NMI (if passed to it at all). There's a shared info field for this,
and there's an existing hook to use - just fit the two together. This
is particularly relevant so that NMIs intended to be handled by APEI /
GHES actually make it to the respective handler.
Note that the hook can (and should) be used irrespective of whether
being in Dom0, as accessing port 0x61 in a DomU would be even worse,
while the shared info field would just hold zero all the time. Note
further that hardware NMI handling for PVH doesn't currently work
anyway due to missing code in the hypervisor (but it is expected to
work the native rather than the PV way).
With the dynamical mapping between cache modes and pgprot values it is
now possible to use all cache modes via the Xen hypervisor PAT settings
in a pv domain.
All to be done is to read the PAT configuration MSR and set up the
translation tables accordingly.
Cc: xen-devel@lists.xensource.com
Cc: ville.syrjala@linux.intel.com
Cc: jbeulich@suse.com
Cc: toshi.kani@hp.com
Cc: plagnioj@jcrosoft.com
Cc: tomi.valkeinen@ti.com
Cc: bhelgaas@google.com
Link: http://lkml.kernel.org/r/1415019724-4317-19-git-send-email-jgross@suse.com
The 3 level p2m tree for the Xen tools is constructed very early at
boot by calling xen_build_mfn_list_list(). Memory needed for this tree
is allocated via extend_brk().
As this tree (other than the kernel internal p2m tree) is only needed
for domain save/restore, live migration and crash dump analysis it
doesn't matter whether it is constructed very early or just some
milliseconds later when memory allocation is possible by other means.
This patch moves the call of xen_build_mfn_list_list() just after
calling xen_pagetable_p2m_copy() simplifying this function, too, as it
doesn't have to bother with two parallel trees now. The same applies
for some other internal functions.
While simplifying code, make early_can_reuse_p2m_middle() static and
drop the unused second parameter. p2m_mid_identity_mfn can be removed
as well, it isn't used either.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu consistent-ops changes from Tejun Heo:
"Way back, before the current percpu allocator was implemented, static
and dynamic percpu memory areas were allocated and handled separately
and had their own accessors. The distinction has been gone for many
years now; however, the now duplicate two sets of accessors remained
with the pointer based ones - this_cpu_*() - evolving various other
operations over time. During the process, we also accumulated other
inconsistent operations.
This pull request contains Christoph's patches to clean up the
duplicate accessor situation. __get_cpu_var() uses are replaced with
with this_cpu_ptr() and __this_cpu_ptr() with raw_cpu_ptr().
Unfortunately, the former sometimes is tricky thanks to C being a bit
messy with the distinction between lvalues and pointers, which led to
a rather ugly solution for cpumask_var_t involving the introduction of
this_cpu_cpumask_var_ptr().
This converts most of the uses but not all. Christoph will follow up
with the remaining conversions in this merge window and hopefully
remove the obsolete accessors"
* 'for-3.18-consistent-ops' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (38 commits)
irqchip: Properly fetch the per cpu offset
percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t -fix
ia64: sn_nodepda cannot be assigned to after this_cpu conversion. Use __this_cpu_write.
Revert "powerpc: Replace __get_cpu_var uses"
percpu: Remove __this_cpu_ptr
clocksource: Replace __this_cpu_ptr with raw_cpu_ptr
sparc: Replace __get_cpu_var uses
avr32: Replace __get_cpu_var with __this_cpu_write
blackfin: Replace __get_cpu_var uses
tile: Use this_cpu_ptr() for hardware counters
tile: Replace __get_cpu_var uses
alpha: Replace __get_cpu_var
ia64: Replace __get_cpu_var uses
s390: cio driver &__get_cpu_var replacements
s390: Replace __get_cpu_var uses
mips: Replace __get_cpu_var uses
MIPS: Replace __get_cpu_var uses in FPU emulator.
arm: Replace __this_cpu_ptr with raw_cpu_ptr
This fixes two bugs in PVH guests:
- Not setting EFER.NX means the NX bit in page table entries is
ignored on Intel processors and causes reserved bit page faults on
AMD processors.
- After the Xen commit 7645640d6ff1 ("x86/PVH: don't set EFER_SCE for
pvh guest") PVH guests are required to set EFER.SCE to enable the
SYSCALL instruction.
Secondary VCPUs are started with pagetables with the NX bit set so
EFER.NX must be set before using any stack or data segment.
xen_pvh_cpu_early_init() is the new secondary VCPU entry point that
sets EFER before jumping to cpu_bringup_and_idle().
Signed-off-by: Mukesh Rathor <mukesh.rathor@oracle.com>
Size restrictions native kernels wouldn't have resulted from the initrd
getting mapped into the initial mapping. The kernel doesn't really need
the initrd to be mapped, so use infrastructure available in Xen to avoid
the mapping and hence the restriction.
The _PAGE_IO_MAP PTE flag was only used by Xen PV guests to mark PTEs
that were used to map I/O regions that are 1:1 in the p2m. This
allowed Xen to obtain the correct PFN when converting the MFNs read
from a PTE back to their PFN.
Xen guests no longer use _PAGE_IOMAP for this. Instead mfn_to_pfn()
returns the correct PFN by using a combination of the m2p and p2m to
determine if an MFN corresponds to a 1:1 mapping in the the p2m.
Remove _PAGE_IOMAP, replacing it with _PAGE_UNUSED2 to allow for
future uses of the PTE flag.
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
__get_cpu_var() is used for multiple purposes in the kernel source. One of
them is address calculation via the form &__get_cpu_var(x). This calculates
the address for the instance of the percpu variable of the current processor
based on an offset.
Other use cases are for storing and retrieving data from the current
processors percpu area. __get_cpu_var() can be used as an lvalue when
writing data or on the right side of an assignment.
__get_cpu_var() is defined as :
#define __get_cpu_var(var) (*this_cpu_ptr(&(var)))
__get_cpu_var() always only does an address determination. However, store
and retrieve operations could use a segment prefix (or global register on
other platforms) to avoid the address calculation.
this_cpu_write() and this_cpu_read() can directly take an offset into a
percpu area and use optimized assembly code to read and write per cpu
variables.
This patch converts __get_cpu_var into either an explicit address
calculation using this_cpu_ptr() or into a use of this_cpu operations that
use the offset. Thereby address calculations are avoided and less registers
are used when code is generated.
Transformations done to __get_cpu_var()
1. Determine the address of the percpu instance of the current processor.
DEFINE_PER_CPU(int, y);
int *x = &__get_cpu_var(y);
Converts to
int *x = this_cpu_ptr(&y);
2. Same as #1 but this time an array structure is involved.
DEFINE_PER_CPU(int, y[20]);
int *x = __get_cpu_var(y);
Converts to
int *x = this_cpu_ptr(y);
3. Retrieve the content of the current processors instance of a per cpu
variable.
int x = __get_cpu_var(y)
Converts to
int x = __this_cpu_read(y);
4. Retrieve the content of a percpu struct
DEFINE_PER_CPU(struct mystruct, y);
struct mystruct x = __get_cpu_var(y);
Converts to
memcpy(&x, this_cpu_ptr(&y), sizeof(x));
5. Assignment to a per cpu variable
__get_cpu_var(y) = x;
Converts to
__this_cpu_write(y, x);
6. Increment/Decrement etc of a per cpu variable
__get_cpu_var(y)++
Converts to
__this_cpu_inc(y)
Cc: x86@kernel.org
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Christoph Lameter <cl@linux.com>
Pull Xen updates from David Vrabel:
- remove unused V2 grant table support
- note that Konrad is xen-blkkback/front maintainer
- add 'xen_nopv' option to disable PV extentions for x86 HVM guests
- misc minor cleanups
* tag 'stable/for-linus-3.17-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen-pciback: Document the 'quirks' sysfs file
xen/pciback: Fix error return code in xen_pcibk_attach()
xen/events: drop negativity check of unsigned parameter
xen/setup: Remove Identity Map Debug Message
xen/events/fifo: remove a unecessary use of BM()
xen/events/fifo: ensure all bitops are properly aligned even on x86
xen/events/fifo: reset control block and local HEADs on resume
xen/arm: use BUG_ON
xen/grant-table: remove support for V2 tables
x86/xen: safely map and unmap grant frames when in atomic context
MAINTAINERS: Make me the Xen block subsystem (front and back) maintainer
xen: Introduce 'xen_nopv' to disable PV extensions for HVM guests.
Pull EFI changes from Ingo Molnar:
"Main changes in this cycle are:
- arm64 efi stub fixes, preservation of FP/SIMD registers across
firmware calls, and conversion of the EFI stub code into a static
library - Ard Biesheuvel
- Xen EFI support - Daniel Kiper
- Support for autoloading the efivars driver - Lee, Chun-Yi
- Use the PE/COFF headers in the x86 EFI boot stub to request that
the stub be loaded with CONFIG_PHYSICAL_ALIGN alignment - Michael
Brown
- Consolidate all the x86 EFI quirks into one file - Saurabh Tangri
- Additional error logging in x86 EFI boot stub - Ulf Winkelvos
- Support loading initrd above 4G in EFI boot stub - Yinghai Lu
- EFI reboot patches for ACPI hardware reduced platforms"
* 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits)
efi/arm64: Handle missing virtual mapping for UEFI System Table
arch/x86/xen: Silence compiler warnings
x86/efi: Request desired alignment via the PE/COFF headers
x86/efi: Add better error logging to EFI boot stub
efi: Autoload efivars
efi: Update stale locking comment for struct efivars
arch/x86: Remove efi_set_rtc_mmss()
arch/x86: Replace plain strings with constants
xen: Put EFI machinery in place
xen: Define EFI related stuff
arch/x86: Remove redundant set_bit(EFI_MEMMAP) call
arch/x86: Remove redundant set_bit(EFI_SYSTEM_TABLES) call
efi: Introduce EFI_PARAVIRT flag
arch/x86: Do not access EFI memory map if it is not available
efi: Use early_mem*() instead of early_io*()
arch/ia64: Define early_memunmap()
x86/reboot: Add EFI reboot quirk for ACPI Hardware Reduced flag
efi/reboot: Allow powering off machines using EFI
efi/reboot: Add generic wrapper around EfiResetSystem()
Compiler complains in the following way when x86 32-bit kernel
with Xen support is build:
CC arch/x86/xen/enlighten.o
arch/x86/xen/enlighten.c: In function ‘xen_start_kernel’:
arch/x86/xen/enlighten.c:1726:3: warning: right shift count >= width of type [enabled by default]
Such line contains following EFI initialization code:
boot_params.efi_info.efi_systab_hi = (__u32)(__pa(efi_systab_xen) >> 32);
There is no issue if x86 64-bit kernel is build. However, 32-bit case
generate warning (even if that code will not be executed because Xen
does not work on 32-bit EFI platforms) due to __pa() returning unsigned long
type which has 32-bits width. So move whole EFI initialization stuff
to separate function and build it conditionally to avoid above mentioned
warning on x86 32-bit architecture.
Signed-off-by: Daniel Kiper <daniel.kiper@oracle.com>
Reviewed-by: Konrad Rzeszutek Wilk <Konrad.wilk@oracle.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
This patch enables EFI usage under Xen dom0. Standard EFI Linux
Kernel infrastructure cannot be used because it requires direct
access to EFI data and code. However, in dom0 case it is not possible
because above mentioned EFI stuff is fully owned and controlled
by Xen hypervisor. In this case all calls from dom0 to EFI must
be requested via special hypercall which in turn executes relevant
EFI code in behalf of dom0.
When dom0 kernel boots it checks for EFI availability on a machine.
If it is detected then artificial EFI system table is filled.
Native EFI callas are replaced by functions which mimics them
by calling relevant hypercall. Later pointer to EFI system table
is passed to standard EFI machinery and it continues EFI subsystem
initialization taking into account that there is no direct access
to EFI boot services, runtime, tables, structures, etc. After that
system runs as usual.
This patch is based on Jan Beulich and Tang Liang work.
Signed-off-by: Tang Liang <liang.tang@oracle.com>
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com
By default when CONFIG_XEN and CONFIG_XEN_PVHVM kernels are
run, they will enable the PV extensions (drivers, interrupts, timers,
etc) - which is the best option for the majority of use cases.
However, in some cases (kexec not fully working, benchmarking)
we want to disable Xen PV extensions. As such introduce the
'xen_nopv' parameter that will do it.
This parameter is intended only for HVM guests as the Xen PV
guests MUST boot with PV extensions. However, even if you use
'xen_nopv' on Xen PV guests it will be ignored.
[v2: s/off/xen_nopv/ per Boris Ostrovsky recommendation.]
[v3: Add Reviewed-by]
[v4: Clarify that this is only for HVM guests]
Pull Xen fixes from David Vrabel:
"Xen regression and PVH fixes for 3.16-rc1
- fix dom0 PVH memory setup on latest unstable Xen releases
- fix 64-bit x86 PV guest boot failure on Xen 3.1 and earlier
- fix resume regression on non-PV (auto-translated physmap) guests"
* tag 'stable/for-linus-3.16-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/grant-table: fix suspend for non-PV guests
x86/xen: no need to explicitly register an NMI callback
Revert "xen/pvh: Update E820 to work with PVH (v2)"
x86/xen: fix memory setup for PVH dom0
