commit 72813bfbf0276a97c82af038efb5f02dcdd9e310 upstream.
This involves initializing the boot params EFI related fields and the
efi global variable.
Without this fix a PVH dom0 doesn't detect when booted from EFI, and
thus doesn't support accessing any of the EFI related data.
Reported-by: PGNet Dev <pgnet.dev@gmail.com>
Signed-off-by: Roger Pau Monné <roger.pau@citrix.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: stable@vger.kernel.org # 4.19+
commit c9f804d64bb93c8dbf957df1d7e9de11380e522d upstream.
Or else xen_domain() returns false despite xen_pvh being set.
We need to refactor PVH entry code so that support for other hypervisors
like Qemu/KVM can be added more easily.
The original design for PVH entry in Xen guests relies on being able to
obtain the memory map from the hypervisor using a hypercall. When we
extend the PVH entry ABI to support other hypervisors like Qemu/KVM,
a new mechanism will be added that allows the guest to get the memory
map without needing to use hypercalls.
For Xen guests, the hypercall approach will still be supported. In
preparation for adding support for other hypervisors, we can move the
code that uses hypercalls into the Xen specific file. This will allow us
to compile kernels in the future without CONFIG_XEN that are still capable
of being booted as a Qemu/KVM guest via the PVH entry point.
Signed-off-by: Maran Wilson <maran.wilson@oracle.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
This patch moves the small block of code used for initializing Xen PVH
virtual machines into the Xen specific file. This initialization is not
going to be needed for Qemu/KVM guests. Moving it out of the common file
is going to allow us to compile kernels in the future without CONFIG_XEN
that are still capable of being booted as a Qemu/KVM guest via the PVH
entry point.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
The first step in that direction is to create a new file that will
eventually hold the Xen specific routines.
Once hypervisors other than Xen start using the PVH entry point for
starting VMs, we would like the option of being able to compile PVH entry
capable kernels without enabling CONFIG_XEN and all the code that comes
along with that. To allow that, we are moving the PVH code out of Xen and
into files sitting at a higher level in the tree.
This patch is not introducing any code or functional changes, just moving
files from one location to another.
Pull x86 grub2 updates from Ingo Molnar:
"This extends the x86 boot protocol to include an address for the RSDP
table - utilized by Xen currently.
Matching Grub2 patches are pending as well. (Juergen Gross)"
* 'x86-grub2-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/acpi, x86/boot: Take RSDP address for boot params if available
x86/boot: Add ACPI RSDP address to setup_header
x86/xen: Fix boot loader version reported for PVH guests
The boot loader version reported via sysfs is wrong in case of the
kernel being booted via the Xen PVH boot entry. it should be 2.12
(0x020c), but it is reported to be 2.18 (0x0212).
As the current way to set the version is error prone use the more
readable variant (2 << 8) | 12.
Signed-off-by: Juergen Gross <jgross@suse.com>
Cc: <stable@vger.kernel.org> # 4.12
Cc: boris.ostrovsky@oracle.com
Cc: bp@alien8.de
Cc: corbet@lwn.net
Cc: linux-doc@vger.kernel.org
Cc: xen-devel@lists.xenproject.org
Link: http://lkml.kernel.org/r/20181010061456.22238-2-jgross@suse.com
Nothing Xen specific in these headers, which get included from a lot
of code in the kernel. So prune the includes and move them to the
Xen-specific files that actually use them instead.
Use a global variable to store the start flags for both PV and PVH.
This allows the xen_initial_domain macro to work properly on PVH.
Note that ARM is also switched to use the new variable.
Add pvh_get_root_pointer() for Xen PVH guests to communicate the
address of the RSDP table given to the kernel via Xen start info.
This makes the kernel boot again in PVH mode after on recent Xen the
RSDP was moved to higher addresses. So up to that change it was pure
luck that the legacy method to locate the RSDP was working when
running as PVH mode.
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: lenb@kernel.org
Cc: linux-acpi@vger.kernel.org
Link: http://lkml.kernel.org/r/20180219100906.14265-4-jgross@suse.com
In case we are booted via the default boot entry by a generic loader
like grub or OVMF it is necessary to distinguish between a HVM guest
with a device model supporting legacy devices and a PVH guest without
device model.
PVH guests will always have x86_platform.legacy.no_vga set and
x86_platform.legacy.rtc cleared, while both won't be true for HVM
guests.
Test for both conditions in the guest_late_init hook and set xen_pvh
to true if they are met.
Move some of the early PVH initializations to the new hook in order
to avoid duplicated code.
Link: http://lkml.kernel.org/r/20171109132739.23465-6-jgross@suse.com
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
e820 map is updated with information from the zeropage (i.e. pvh_bootparams)
by default_machine_specific_memory_setup(). With the way things are done
now, we end up with a duplicated e820 map.
Create enlighten_pvh.c by splitting off PVH related code from enlighten.c,
put it under CONFIG_XEN_PVH.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
