sizeof(pmd_t *) is 4 bytes on 32-bit PAE leading to an allocation of
only 2048 bytes. The correct size is sizeof(pmd_t) giving us a full
page allocation.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
and branch 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm
* 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm:
xen: register xen pci notifier
xen: initialize cpu masks for pv guests in xen_smp_init
xen: add a missing #include to arch/x86/pci/xen.c
xen: mask the MTRR feature from the cpuid
xen: make hvc_xen console work for dom0.
xen: add the direct mapping area for ISA bus access
xen: Initialize xenbus for dom0.
xen: use vcpu_ops to setup cpu masks
xen: map a dummy page for local apic and ioapic in xen_set_fixmap
xen: remap MSIs into pirqs when running as initial domain
xen: remap GSIs as pirqs when running as initial domain
xen: introduce XEN_DOM0 as a silent option
xen: map MSIs into pirqs
xen: support GSI -> pirq remapping in PV on HVM guests
xen: add xen hvm acpi_register_gsi variant
acpi: use indirect call to register gsi in different modes
xen: implement xen_hvm_register_pirq
xen: get the maximum number of pirqs from xen
xen: support pirq != irq
* 'stable/xen-pcifront-0.8.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (27 commits)
X86/PCI: Remove the dependency on isapnp_disable.
xen: Update Makefile with CONFIG_BLOCK dependency for biomerge.c
MAINTAINERS: Add myself to the Xen Hypervisor Interface and remove Chris Wright.
x86: xen: Sanitse irq handling (part two)
swiotlb-xen: On x86-32 builts, select SWIOTLB instead of depending on it.
MAINTAINERS: Add myself for Xen PCI and Xen SWIOTLB maintainer.
xen/pci: Request ACS when Xen-SWIOTLB is activated.
xen-pcifront: Xen PCI frontend driver.
xenbus: prevent warnings on unhandled enumeration values
xenbus: Xen paravirtualised PCI hotplug support.
xen/x86/PCI: Add support for the Xen PCI subsystem
x86: Introduce x86_msi_ops
msi: Introduce default_[teardown|setup]_msi_irqs with fallback.
x86/PCI: Export pci_walk_bus function.
x86/PCI: make sure _PAGE_IOMAP it set on pci mappings
x86/PCI: Clean up pci_cache_line_size
xen: fix shared irq device passthrough
xen: Provide a variant of xen_poll_irq with timeout.
xen: Find an unbound irq number in reverse order (high to low).
xen: statically initialize cpu_evtchn_mask_p
Fix up trivial conflicts in drivers/pci/Makefile
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
* 'upstream/xenfs' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
xen/privcmd: make privcmd visible in domU
xen/privcmd: move remap_domain_mfn_range() to core xen code and export.
privcmd: MMAPBATCH: Fix error handling/reporting
xenbus: export xen_store_interface for xenfs
xen/privcmd: make sure vma is ours before doing anything to it
xen/privcmd: print SIGBUS faults
xen/xenfs: set_page_dirty is supposed to return true if it dirties
xen/privcmd: create address space to allow writable mmaps
xen: add privcmd driver
xen: add variable hypercall caller
xen: add xen_set_domain_pte()
xen: add /proc/xen/xsd_{kva,port} to xenfs
* 'upstream/core' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: (29 commits)
xen: include xen/xen.h for definition of xen_initial_domain()
xen: use host E820 map for dom0
xen: correctly rebuild mfn list list after migration.
xen: improvements to VIRQ_DEBUG output
xen: set up IRQ before binding virq to evtchn
xen: ensure that all event channels start off bound to VCPU 0
xen/hvc: only notify if we actually sent something
xen: don't add extra_pages for RAM after mem_end
xen: add support for PAT
xen: make sure xen_max_p2m_pfn is up to date
xen: limit extra memory to a certain ratio of base
xen: add extra pages for E820 RAM regions, even if beyond mem_end
xen: make sure xen_extra_mem_start is beyond all non-RAM e820
xen: implement "extra" memory to reserve space for pages not present at boot
xen: Use host-provided E820 map
xen: don't map missing memory
xen: defer building p2m mfn structures until kernel is mapped
xen: add return value to set_phys_to_machine()
xen: convert p2m to a 3 level tree
xen: make install_p2mtop_page() static
Fix up trivial conflict in arch/x86/xen/mmu.c, and fix the use of
'reserve_early()' - in the new memblock world order it is now
'memblock_x86_reserve_range()' instead. Pointed out by Jeremy.
add the direct mapping area for ISA bus access when running as initial
domain
Signed-off-by: Juan Quintela <quintela@redhat.com>
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Otherwise the second migration attempt fails because the mfn_list_list
still refers to all the old mfns.
We need to update the entires in both p2m_top_mfn and the mid_mfn
pages which p2m_top_mfn refers to.
In order to do this we need to keep track of the virtual addresses
mapping the p2m_mid_mfn pages since we cannot rely on
mfn_to_virt(p2m_top_mfn[idx]) since p2m_top_mfn[idx] will still
contain the old MFN after a migration, which may now belong to another
domain and hence have a different mapping in the m2p.
Therefore add and maintain a third top level page, p2m_top_mfn_p[],
which tracks the virtual addresses of the mfns contained in
p2m_top_mfn[].
We also need to update the content of the p2m_mid_missing_mfn page on
resume to refer to the page's new mfn.
p2m_missing does not need updating since the migration process takes
care of the leaf p2m pages for us.
Convert Linux PAT entries into Xen ones when constructing ptes. Linux
doesn't use _PAGE_PAT for ptes, so the only difference in the first 4
entries is that Linux uses _PAGE_PWT for WC, whereas Xen (and default)
use it for WT.
xen_pte_val does the inverse conversion.
We hard-code assumptions about Linux's current PAT layout, but a
warning on the wrmsr to MSR_IA32_CR_PAT should point out any problems.
If necessary we could go to a more general table-based conversion between
Linux and Xen PAT entries.
hugetlbfs poses a problem at the moment, the x86 architecture uses the
same flag for _PAGE_PAT and _PAGE_PSE, which changes meaning depending
on which pagetable level we're using. At the moment this should be OK
so long as nobody tries to do a pte_val on a hugetlbfs pte.
Keep xen_max_p2m_pfn up to date with the end of the extra memory
we're adding. It is possible that it will be too high since memory
may be truncated by a "mem=" option on the kernel command line, but
that won't matter.
When setting up a pte for a missing pfn (no matching mfn), just create
an empty pte rather than a junk mapping.
When building mfn parts of p2m structure, we rely on being able to
use mfn_to_virt, which in turn requires kernel to be mapped into
the linear area (which is distinct from the kernel image mapping
on 64-bit). Defer calling xen_build_mfn_list_list() until after
xen_setup_kernel_pagetable();
set_phys_to_machine() can return false on failure, which means a memory
allocation failure for the p2m structure. It can only fail if setting
the mfn for a pfn in previously unused address space. It is guaranteed
to succeed if you're setting a mapping to INVALID_P2M_ENTRY or updating
the mfn for an existing pfn.
Make the p2m structure a 3 level tree which covers the full possible
physical space.
The p2m structure contains mappings from the domain's pfns to system-wide
mfns. The structure has 3 levels and two roots. The first root is for
the domain's own use, and is linked with virtual addresses. The second
is all mfn references, and is used by Xen on save/restore to allow it to
update the p2m mapping for the domain.
At boot, the domain builder provides a simple flat p2m array for all the
initially present pages. We construct the two levels above that using
the early_brk allocator. After early boot time, set_phys_to_machine()
will allocate any missing levels using the normal kernel allocator
(at GFP_KERNEL, so it must be called in a normal blocking context).
Because the early_brk() API requires us to pre-reserve the maximum amount
of memory we could allocate, there is still a CONFIG_XEN_MAX_DOMAIN_MEMORY
config option, but its only negative side-effect is to increase the
kernel's apparent bss size. However, since all unused brk memory is
returned to the heap, there's no real downside to making it large.
Allocate p2m tables based on the actual runtime maximum pfn rather than
the static config-time limit.
Use early brk mechanism to allocate p2m tables, to save memory when
booting non-Xen.
* 'core-memblock-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (74 commits)
x86-64: Only set max_pfn_mapped to 512 MiB if we enter via head_64.S
xen: Cope with unmapped pages when initializing kernel pagetable
memblock, bootmem: Round pfn properly for memory and reserved regions
memblock: Annotate memblock functions with __init_memblock
memblock: Allow memblock_init to be called early
memblock/arm: Fix memblock_region_is_memory() typo
x86, memblock: Remove __memblock_x86_find_in_range_size()
memblock: Fix wraparound in find_region()
x86-32, memblock: Make add_highpages honor early reserved ranges
x86, memblock: Fix crashkernel allocation
arm, memblock: Fix the sparsemem build
memblock: Fix section mismatch warnings
powerpc, memblock: Fix memblock API change fallout
memblock, microblaze: Fix memblock API change fallout
x86: Remove old bootmem code
x86, memblock: Use memblock_memory_size()/memblock_free_memory_size() to get correct dma_reserve
x86: Remove not used early_res code
x86, memblock: Replace e820_/_early string with memblock_
x86: Use memblock to replace early_res
x86, memblock: Use memblock_debug to control debug message print out
Fix up trivial conflicts in arch/x86/kernel/setup.c and kernel/Makefile
This allows xenfs to be built as a module, previously it required flush_tlb_all
and arbitrary_virt_to_machine to be exported.
Add xen_set_domain_pte() to allow setting a pte mapping a page from
another domain. The common case is to map from DOMID_IO, the pseudo
domain which owns all IO pages, but will also be used in the privcmd
interface to map other domain pages.
[ Impact: new Xen-internal API for cross-domain mappings ]
Xen requires that all pages containing pagetable entries to be mapped
read-only. If pages used for the initial pagetable are already mapped
then we can change the mapping to RO. However, if they are initially
unmapped, we need to make sure that when they are later mapped, they
are also mapped RO.
We do this by knowing that the kernel pagetable memory is pre-allocated
in the range e820_table_start - e820_table_end, so any pfn within this
range should be mapped read-only. However, the pagetable setup code
early_ioremaps the pages to write their entries, so we must make sure
that mappings created in the early_ioremap fixmap area are mapped RW.
(Those mappings are removed before the pages are presented to Xen
as pagetable pages.)
LKML-Reference: <4CB63A80.8060702@goop.org>
Cc: Yinghai Lu <yinghai@kernel.org>
arch/x86/kernel/trampoline.c
mm/memblock.c
Merge reason: Resolve the conflicts, update to latest upstream.
1.include linux/memblock.h directly. so later could reduce e820.h reference.
2 this patch is done by sed scripts mainly
-v2: use MEMBLOCK_ERROR instead of -1ULL or -1UL
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
VMI was the only user of the alloc_pmd_clone hook, given that VMI
is now removed we can also remove this hook.
Signed-off-by: Alok N Kataria <akataria@vmware.com>
LKML-Reference: <1282608357.19396.36.camel@ank32.eng.vmware.com>
Cc: Jeremy Fitzhardinge <jeremy@xensource.com>
* 'stable/xen-swiotlb-0.8.6' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
x86: Detect whether we should use Xen SWIOTLB.
pci-swiotlb-xen: Add glue code to setup dma_ops utilizing xen_swiotlb_* functions.
swiotlb-xen: SWIOTLB library for Xen PV guest with PCI passthrough.
xen/mmu: inhibit vmap aliases rather than trying to clear them out
vmap: add flag to allow lazy unmap to be disabled at runtime
xen: Add xen_create_contiguous_region
xen: Rename the balloon lock
xen: Allow unprivileged Xen domains to create iomap pages
xen: use _PAGE_IOMAP in ioremap to do machine mappings
Fix up trivial conflicts (adding both xen swiotlb and xen pci platform
driver setup close to each other) in drivers/xen/{Kconfig,Makefile} and
include/xen/xen-ops.h
This patch introduce a CONFIG_XEN_PVHVM compile time option to
enable/disable Xen PV on HVM support.
Rather than trying to deal with aliases once they appear, just completely
inhibit them. Mostly the removal of aliases was managable, but it comes
unstuck in xen_create_contiguous_region() because it gets executed at
interrupt time (as a result of dma_alloc_coherent()), which causes all
sorts of confusion in the vmap code, as it was never intended to be run
in interrupt context.
This has the unfortunate side effect of removing all the unmap batching
the vmap code so carefully added, but that can't be helped.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
When a pagetable is about to be destroyed, we notify Xen so that the
hypervisor can clear the related shadow pagetable.
A memory region must be physically contiguous in order to be accessed
through DMA. This patch adds xen_create_contiguous_region, which
ensures a region of contiguous virtual memory is also physically
contiguous.
Based on Stephen Tweedie's port of the 2.6.18-xen version.
Remove contiguous_bitmap[] as it's no longer needed.
Ported from linux-2.6.18-xen.hg 707:e410857fd83c
[ Impact: add Xen-internal API to make pages phys-contig ]
Signed-off-by: Alex Nixon <alex.nixon@citrix.com>
* xen_create_contiguous_region needs access to the balloon lock to
ensure memory doesn't change under its feet, so expose the balloon
lock
* Change the name of the lock to xen_reservation_lock, to imply it's
now less-specific usage.
[ Impact: cleanup ]
PV DomU domains are allowed to map hardware MFNs for PCI passthrough,
but are not generally allowed to map raw machine pages. In particular,
various pieces of code try to map DMI and ACPI tables in the ISA ROM
range. We disallow _PAGE_IOMAP for those mappings, so that they are
redirected to a set of local zeroed pages we reserve for that purpose.
[ Impact: prevent passthrough of ISA space, as we only allow PCI ]
In a Xen domain, ioremap operates on machine addresses, not
pseudo-physical addresses. We use _PAGE_IOMAP to determine whether a
mapping is intended for machine addresses.
[ Impact: allow Xen domain to map real hardware ]
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Now that both Xen and VMI disable allocations of PTE pages from high
memory this paravirt op serves no further purpose.
This effectively reverts ce6234b5 "add kmap_atomic_pte for mapping
highpte pages".
LKML-Reference: <1267204562-11844-3-git-send-email-ian.campbell@citrix.com>
Acked-by: Alok Kataria <akataria@vmware.com>
There's a path in the pagefault code where the kernel deliberately
breaks its own locking rules by kmapping a high pte page without
holding the pagetable lock (in at least page_check_address). This
breaks Xen's ability to track the pinned/unpinned state of the
page. There does not appear to be a viable workaround for this
behaviour so simply disable HIGHPTE for all Xen guests.
LKML-Reference: <1267204562-11844-1-git-send-email-ian.campbell@citrix.com>
Cc: Pasi Kärkkäinen <pasik@iki.fi>
Cc: <stable@kernel.org> # .32.x: 14315592: Allow highmem user page tables to be disabled at boot time
Cc: <xen-devel@lists.xensource.com>
pvops kernels >= 2.6.30 can currently only be saved and restored once. The
second attempt to save results in:
ERROR Internal error: Frame# in pfn-to-mfn frame list is not in pseudophys
ERROR Internal error: entry 0: p2m_frame_list[0] is 0xf2c2c2c2, max 0x120000
ERROR Internal error: Failed to map/save the p2m frame list
I finally narrowed it down to:
commit cdaead6b4e657f960d6d6f9f380e7dfeedc6a09b
Author: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Date: Fri Feb 27 15:34:59 2009 -0800
xen: split construction of p2m mfn tables from registration
Build the p2m_mfn_list_list early with the rest of the p2m table, but
register it later when the real shared_info structure is in place.
The unforeseen side-effect of this change was to cause the mfn list list to not
be rebuilt on resume. Prior to this change it would have been rebuilt via
xen_post_suspend() -> xen_setup_shared_info() -> xen_setup_mfn_list_list().
Fix by explicitly calling xen_build_mfn_list_list() from xen_post_suspend().
Cc: Stable Kernel <stable@kernel.org>
Makes code futureproof against the impending change to mm->cpu_vm_mask (to be a pointer).
It's also a chance to use the new cpumask_ ops which take a pointer
(the older ones are deprecated, but there's no hurry for arch code).
We really do not need two paravirt/x86_init_ops functions which are
called in two consecutive source lines. Move the only user of
post_allocator_init into the already existing pagetable_setup_done
function.
Replace more paravirt hackery by proper x86_init_ops.
* 'x86-xen-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (42 commits)
xen: cache cr0 value to avoid trap'n'emulate for read_cr0
xen/x86-64: clean up warnings about IST-using traps
xen/x86-64: fix breakpoints and hardware watchpoints
xen: reserve Xen start_info rather than e820 reserving
xen: add FIX_TEXT_POKE to fixmap
lguest: update lazy mmu changes to match lguest's use of kvm hypercalls
xen: honour VCPU availability on boot
xen: add "capabilities" file
xen: drop kexec bits from /sys/hypervisor since kexec isn't implemented yet
xen/sys/hypervisor: change writable_pt to features
xen: add /sys/hypervisor support
xen/xenbus: export xenbus_dev_changed
xen: use device model for suspending xenbus devices
xen: remove suspend_cancel hook
xen/dev-evtchn: clean up locking in evtchn
xen: export ioctl headers to userspace
xen: add /dev/xen/evtchn driver
xen: add irq_from_evtchn
xen: clean up gate trap/interrupt constants
xen: set _PAGE_NX in __supported_pte_mask before pagetable construction
mmu.c needs to #include module.h to prevent these warnings:
arch/x86/xen/mmu.c:239: warning: data definition has no type or storage class
arch/x86/xen/mmu.c:239: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL_GPL'
arch/x86/xen/mmu.c:239: warning: parameter names (without types) in function declaration
[ Impact: cleanup ]
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
LKML-Reference: <new-submission>
arch/frv/include/asm/pgtable.h
arch/x86/include/asm/required-features.h
arch/x86/xen/mmu.c
Merge reason: x86/xen was on a .29 base still, move it to a fresher
branch and pick up Xen fixes as well, plus resolve
conflicts
The Xen pagetables are no longer implicitly reserved as part of the other
i386_start_kernel reservations, so make sure we explicitly reserve them.
This prevents them from being released into the general kernel free page
pool and reused.
[ Impact: fix Xen guest crash ]
Also-Bisected-by: Bryan Donlan <bdonlan@gmail.com>
Cc: Xen-devel <xen-devel@lists.xensource.com>
LKML-Reference: <4A032EEC.30509@goop.org>
* 'for-rc1/xen/core' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
xen: resume interrupts before system devices.
xen/mmu: weaken flush_tlb_other test
xen/mmu: some early pagetable cleanups
Xen: Add virt_to_pfn helper function
x86-64: remove PGE from must-have feature list
xen: mask XSAVE from cpuid
NULL noise: arch/x86/xen/smp.c
xen: remove xen_load_gdt debug
xen: make xen_load_gdt simpler
xen: clean up xen_load_gdt
xen: separate p2m allocation from setting
xen: disable preempt for leave_lazy_mmu
Use phys_addr_t for receiving a physical address argument instead of
unsigned long. This allows fixmap to handle pages higher than 4GB on
x86-32.
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
FIX_TEXT_POKE[01] are used to map kernel addresses, so they're mapping
pfns, not mfns.
pfns, not mfns.
Impact: fixes crashing bug
There's no particular problem with getting an empty cpu mask,
so just shortcut-return if we get one.
Avoids crash reported by Christophe Saout <christophe@saout.de>
