commit ccbcdf7cf1b5f6c6db30d84095b9c6c53043af55 upstream.
The order-based approach is not only less efficient (requiring a shift
and a compare, typical generated code looking like this
mov eax, [machine_to_phys_order]
mov ecx, eax
shr ebx, cl
test ebx, ebx
jnz ...
whereas a direct check requires just a compare, like in
cmp ebx, [machine_to_phys_nr]
jae ...
), but also slightly dangerous in the 32-on-64 case - the element
address calculation can wrap if the next power of two boundary is
sufficiently far away from the actual upper limit of the table, and
hence can result in user space addresses being accessed (with it being
unknown what may actually be mapped there).
Additionally, the elimination of the mistaken use of fls() here (should
have been __fls()) fixes a latent issue on x86-64 that would trigger
if the code was run on a system with memory extending beyond the 44-bit
boundary.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
[v1: Based on Jeremy's feedback]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Simple enough - we use an extern defined symbol which is not
defined when CONFIG_SMP is not defined. This fixes the linker
dying.
CC: stable@kernel.org
The MAXSMP config option requires CPUMASK_OFFSTACK, which in turn
requires we init the memory for the maps while we bring up the cpus.
MAXSMP also increases NR_CPUS to 4096. This increase in size exposed an
issue in the argument construction for multicalls from
xen_flush_tlb_others. The args should only need space for the actual
number of cpus.
Also in 2.6.39 it exposes a bootup problem.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff8157a1d3>] set_cpu_sibling_map+0x123/0x30d
Call Trace:
[<ffffffff81039a3f>] ? xen_restore_fl_direct_reloc+0x4/0x4
[<ffffffff819dc4db>] xen_smp_prepare_cpus+0x36/0x135
Signed-off-by: Andrew Jones <drjones@redhat.com>
[v2: Updated to compile on 3.0]
[v3: Updated to compile when CONFIG_SMP is not defined]
We only need to set max_pfn_mapped to the last pfn mapped on x86_64 to
make sure that cleanup_highmap doesn't remove important mappings at
_end.
We don't need to do this on x86_32 because cleanup_highmap is not called
on x86_32. Besides lowering max_pfn_mapped on x86_32 has the unwanted
side effect of limiting the amount of memory available for the 1:1
kernel pagetable allocation.
This patch reverts the x86_32 part of the original patch.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
* 'upstream/tidy-xen-mmu-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
xen: fix compile without CONFIG_XEN_DEBUG_FS
Use arbitrary_virt_to_machine() to deal with ioremapped pud updates.
Use arbitrary_virt_to_machine() to deal with ioremapped pmd updates.
xen/mmu: remove all ad-hoc stats stuff
xen: use normal virt_to_machine for ptes
xen: make a pile of mmu pvop functions static
vmalloc: remove vmalloc_sync_all() from alloc_vm_area()
xen: condense everything onto xen_set_pte
xen: use mmu_update for xen_set_pte_at()
xen: drop all the special iomap pte paths.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
To make way for tracing.
We no longer support HIGHPTE allocations, so ptes should always be
within the kernel's direct map, and don't need pagetable walks
to convert to machine addresses.
xen_set_pte_at and xen_clear_pte are essentially identical to
xen_set_pte, so just make them all common.
When batched set_pte and pte_clear are the same, but the unbatch operation
must be different: they need to update the two halves of the pte in
different order.
In principle update_va_mapping is a good match for set_pte_at, since
it gets the address being mapped, which allows Xen to use its linear
pagetable mapping.
However that assumes that the pmd for the address is attached to the
current pagetable, which may not be true for a given user address space
because the kernel pmd is not shared (at least on 32-bit guests).
Normally the kernel will automatically sync a missing part of the
pagetable with the init_mm pagetable transparently via faults, but that
fails when a missing address is passed to Xen.
And while the linear pagetable mapping is very useful for 32-bit Xen
(as it avoids an explicit domain mapping), 32-bit Xen is deprecated.
64-bit Xen has all memory mapped all the time, so it makes no real
difference.
The upshot is that we should use mmu_update, since it can operate on
non-current pagetables or detached pagetables.
Xen can work out when we're doing IO mappings for itself, so we don't
need to do anything special, and the extra tests just clog things up.
and 'stable/mmu.bugfixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/irq' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: do not clear and mask evtchns in __xen_evtchn_do_upcall
* 'stable/p2m.bugfixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/p2m: Create entries in the P2M_MFN trees's to track 1-1 mappings
* 'stable/e820.bugfixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/setup: Fix for incorrect xen_extra_mem_start initialization under 32-bit
xen/setup: Ignore E820_UNUSABLE when setting 1-1 mappings.
* 'stable/mmu.bugfixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen mmu: fix a race window causing leave_mm BUG()
Cleanup code/data sections definitions
accordingly to include/linux/init.h.
Signed-off-by: Daniel Kiper <dkiper@net-space.pl>
[v1: Rebased on top of latest linus's to include fixes in mmu.c]
There's a race window in xen_drop_mm_ref, where remote cpu may exit
dirty bitmap between the check on this cpu and the point where remote
cpu handles drop request. So in drop_other_mm_ref we need check
whether TLB state is still lazy before calling into leave_mm. This
bug is rarely observed in earlier kernel, but exaggerated by the
commit 831d52bc153971b70e64eccfbed2b232394f22f8
("x86, mm: avoid possible bogus tlb entries by clearing prev mm_cpumask after switching mm")
which clears bitmap after changing the TLB state. the call trace is as below:
kernel BUG at arch/x86/mm/tlb.c:61!
invalid opcode: 0000 [#1] SMP
last sysfs file: /sys/devices/system/xen_memory/xen_memory0/info/current_kb
CPU 1
Modules linked in: 8021q garp xen_netback xen_blkback blktap blkback_pagemap nbd bridge stp llc autofs4 ipmi_devintf ipmi_si ipmi_msghandler lockd sunrpc bonding ipv6 xenfs dm_multipath video output sbs sbshc parport_pc lp parport ses enclosure snd_seq_dummy snd_seq_oss snd_seq_midi_event snd_seq snd_seq_device serio_raw bnx2 snd_pcm_oss snd_mixer_oss snd_pcm snd_timer iTCO_wdt snd soundcore snd_page_alloc i2c_i801 iTCO_vendor_support i2c_core pcs pkr pata_acpi ata_generic ata_piix shpchp mptsas mptscsih mptbase [last unloaded: freq_table]
Pid: 25581, comm: khelper Not tainted 2.6.32.36fixxen #1 Tecal RH2285
RIP: e030:[<ffffffff8103a3cb>] [<ffffffff8103a3cb>] leave_mm+0x15/0x46
RSP: e02b:ffff88002805be48 EFLAGS: 00010046
RAX: 0000000000000000 RBX: 0000000000000001 RCX: ffff88015f8e2da0
RDX: ffff88002805be78 RSI: 0000000000000000 RDI: 0000000000000001
RBP: ffff88002805be48 R08: ffff88009d662000 R09: dead000000200200
R10: dead000000100100 R11: ffffffff814472b2 R12: ffff88009bfc1880
R13: ffff880028063020 R14: 00000000000004f6 R15: 0000000000000000
FS: 00007f62362d66e0(0000) GS:ffff880028058000(0000) knlGS:0000000000000000
CS: e033 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000003aabc11909 CR3: 000000009b8ca000 CR4: 0000000000002660
DR0: 0000000000000000 DR1: 0000000000000000 DR2: 00000000000000 00
Process khelper (pid: 25581, threadinfo ffff88007691e000, task ffff88009b92db40)
Stack:
ffff88002805be68 ffffffff8100e4ae 0000000000000001 ffff88009d733b88
<0> ffff88002805be98 ffffffff81087224 ffff88002805be78 ffff88002805be78
<0> ffff88015f808360 00000000000004f6 ffff88002805bea8 ffffffff81010108
Call Trace:
<IRQ>
[<ffffffff8100e4ae>] drop_other_mm_ref+0x2a/0x53
[<ffffffff81087224>] generic_smp_call_function_single_interrupt+0xd8/0xfc
[<ffffffff81010108>] xen_call_function_single_interrupt+0x13/0x28
[<ffffffff810a936a>] handle_IRQ_event+0x66/0x120
[<ffffffff810aac5b>] handle_percpu_irq+0x41/0x6e
[<ffffffff8128c1c0>] __xen_evtchn_do_upcall+0x1ab/0x27d
[<ffffffff8128dd11>] xen_evtchn_do_upcall+0x33/0x46
[<ffffffff81013efe>] xen_do_hyper visor_callback+0x1e/0x30
<EOI>
[<ffffffff814472b2>] ? _spin_unlock_irqrestore+0x15/0x17
[<ffffffff8100f8cf>] ? xen_restore_fl_direct_end+0x0/0x1
[<ffffffff81113f71>] ? flush_old_exec+0x3ac/0x500
[<ffffffff81150dc5>] ? load_elf_binary+0x0/0x17ef
[<ffffffff8115115d>] ? load_elf_binary+0x398/0x17ef
[<ffffffff81042fcf>] ? need_resched+0x23/0x2d
[<ffffffff811f4648>] ? process_measurement+0xc0/0xd7
[<ffffffff81113094>] ? search_binary_handler+0xc8/0x255
[<ffffffff81114362>] ? do_execve+0x1c3/0x29e
[<ffffffff8101155d>] ? sys_execve+0x43/0x5d
[<ffffffff8106fc45>] ? __call_usermodehelper+0x0/0x6f
[<ffffffff81013e28>] ? kernel_execve+0x68/0xd0
[<ffffffff 8106fc45>] ? __call_usermodehelper+0x0/0x6f
[<ffffffff8106fb64>] ? ____call_usermodehelper+0x113/0x11e
[<ffffffff81013daa>] ? child_rip+0xa/0x20
[<ffffffff81012f91>] ? int_ret_from_sys_call+0x7/0x1b
[<ffffffff8101371d>] ? retint_restore_args+0x5/0x6
[<ffffffff81013da0>] ? child_rip+0x0/0x20
Code: 41 5e 41 5f c9 c3 55 48 89 e5 0f 1f 44 00 00 e8 17 ff ff ff c9 c3 55 48 89 e5 0f 1f 44 00 00 65 8b 04 25 c8 55 01 00 ff c8 75 04 <0f> 0b eb fe 65 48 8b 34 25 c0 55 01 00 48 81 c6 b8 02 00 00 e8
RIP [<ffffffff8103a3cb>] leave_mm+0x15/0x46
RSP <ffff88002805be48>
---[ end trace ce9cee6832a9c503 ]---
Tested-by: Maoxiaoyun<tinnycloud@hotmail.com>
Signed-off-by: Kevin Tian <kevin.tian@intel.com>
[v1: Fleshed out the git description a bit]
Introduce a new x86_init hook called pagetable_reserve that at the end
of init_memory_mapping is used to reserve a range of memory addresses for
the kernel pagetable pages we used and free the other ones.
On native it just calls memblock_x86_reserve_range while on xen it also
takes care of setting the spare memory previously allocated
for kernel pagetable pages from RO to RW, so that it can be used for
other purposes.
A detailed explanation of the reason why this hook is needed follows.
As a consequence of the commit:
commit 4b239f458c229de044d6905c2b0f9fe16ed9e01e
Author: Yinghai Lu <yinghai@kernel.org>
Date: Fri Dec 17 16:58:28 2010 -0800
x86-64, mm: Put early page table high
at some point init_memory_mapping is going to reach the pagetable pages
area and map those pages too (mapping them as normal memory that falls
in the range of addresses passed to init_memory_mapping as argument).
Some of those pages are already pagetable pages (they are in the range
pgt_buf_start-pgt_buf_end) therefore they are going to be mapped RO and
everything is fine.
Some of these pages are not pagetable pages yet (they fall in the range
pgt_buf_end-pgt_buf_top; for example the page at pgt_buf_end) so they
are going to be mapped RW. When these pages become pagetable pages and
are hooked into the pagetable, xen will find that the guest has already
a RW mapping of them somewhere and fail the operation.
The reason Xen requires pagetables to be RO is that the hypervisor needs
to verify that the pagetables are valid before using them. The validation
operations are called "pinning" (more details in arch/x86/xen/mmu.c).
In order to fix the issue we mark all the pages in the entire range
pgt_buf_start-pgt_buf_top as RO, however when the pagetable allocation
is completed only the range pgt_buf_start-pgt_buf_end is reserved by
init_memory_mapping. Hence the kernel is going to crash as soon as one
of the pages in the range pgt_buf_end-pgt_buf_top is reused (b/c those
ranges are RO).
For this reason we need a hook to reserve the kernel pagetable pages we
used and free the other ones so that they can be reused for other
purposes.
On native it just means calling memblock_x86_reserve_range, on Xen it
also means marking RW the pagetable pages that we allocated before but
that haven't been used before.
Another way to fix this is without using the hook is by adding a 'if
(xen_pv_domain)' in the 'init_memory_mapping' code and calling the Xen
counterpart, but that is just nasty.
Acked-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: H. Peter Anvin <hpa@zytor.com>
This reverts commit a38647837a411f7df79623128421eef2118b5884.
It does not work with certain AMD machines.
last_pfn = 0x100000 max_arch_pfn = 0x400000000
initial memory mapped : 0 - 02c3a000
Base memory trampoline at [ffff88000009b000] 9b000 size 20480
init_memory_mapping: 0000000000000000-0000000100000000
0000000000 - 0100000000 page 4k
kernel direct mapping tables up to 100000000 @ ff7fb000-100000000
init_memory_mapping: 0000000100000000-00000001e0800000
0100000000 - 01e0800000 page 4k
kernel direct mapping tables up to 1e0800000 @ 1df0f3000-1e0000000
xen: setting RW the range fffdc000 - 100000000
RAMDISK: 0203b000 - 02c3a000
No NUMA configuration found
Faking a node at 0000000000000000-00000001e0800000
NUMA: Using 63 for the hash shift.
Initmem setup node 0 0000000000000000-00000001e0800000
NODE_DATA [00000001dfffb000 - 00000001dfffffff]
IP: [<ffffffff81cf6a75>] setup_node_bootmem+0x18a/0x1ea
PGD 0
Oops: 0003 [#1] SMP
last sysfs file:
CPU 0
Modules linked in:
Pid: 0, comm: swapper Not tainted 2.6.39-0-virtual #6~smb1
RIP: e030:[<ffffffff81cf6a75>] [<ffffffff81cf6a75>] setup_node_bootmem+0x18a/0x1ea
RSP: e02b:ffffffff81c01e38 EFLAGS: 00010046
RAX: 0000000000000000 RBX: 00000001e0800000 RCX: 0000000000001040
RDX: 0000000000004100 RSI: 0000000000000000 RDI: ffff8801dfffb000
RBP: ffffffff81c01e58 R08: 0000000000000020 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000bfe400
FS: 0000000000000000(0000) GS:ffffffff81cca000(0000) knlGS:0000000000000000
CS: e033 DS: 0000 ES: 0000 CR0: 0000000080050033
CR2: 0000000000000000 CR3: 0000000001c03000 CR4: 0000000000000660
Process swapper (pid: 0, threadinfo ffffffff81c00000, task ffffffff81c0b020)
Stack:
0000000000000040 0000000000000001 0000000000000000 ffffffffffffffff
ffffffff81c01e88 ffffffff81cf6c25 0000000000000000 0000000000000000
ffffffff81cf687f 0000000000000000 ffffffff81c01ea8 ffffffff81cf6e45
Call Trace:
[<ffffffff81cf6c25>] numa_register_memblks.constprop.3+0x150/0x181
[<ffffffff81cf687f>] ? numa_add_memblk+0x7c/0x7c
[<ffffffff81cf6e45>] numa_init.part.2+0x1c/0x7c
[<ffffffff81cf6f67>] numa_init+0x6c/0x70
[<ffffffff81cf7057>] initmem_init+0x39/0x3b
[<ffffffff81ce5865>] setup_arch+0x64e/0x769
[<ffffffff815e43c1>] ? printk+0x51/0x53
[<ffffffff81cdf92b>] start_kernel+0xd4/0x3f3
[<ffffffff81cdf388>] x86_64_start_reservations+0x132/0x136
[<ffffffff81ce2ed4>] xen_start_kernel+0x588/0x58f
Code: 41 00 00 48 8b 3c c5 a0 24 cc 81 31 c0 40 f6 c7 01 74 05 aa 66 ba ff 40 40 f6 c7 02 74 05 66 ab 83 ea 02 89 d1 c1 e9 02 f6 c2 02 <f3> ab 74 02 66 ab 80 e2 01 74 01 aa 49 63 c4 48 c1 eb 0c 44 89
RIP [<ffffffff81cf6a75>] setup_node_bootmem+0x18a/0x1ea
RSP <ffffffff81c01e38>
---[ end trace a7919e7f17c0a725 ]---
Kernel panic - not syncing: Attempted to kill the idle task!
Pid: 0, comm: swapper Tainted: G D 2.6.39-0-virtual #6~smb1
Reported-by: Stefan Bader <stefan.bader@canonical.com>
mask_rw_pte is currently checking if a pfn is a pagetable page if it
falls in the range pgt_buf_start - pgt_buf_end but that is incorrect
because pgt_buf_end is a moving target: pgt_buf_top is the real
boundary.
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
it causes the Linux kernel to crash under Xen:
mapping kernel into physical memory
Xen: setup ISA identity maps
about to get started...
(XEN) mm.c:2466:d0 Bad type (saw 7400000000000001 != exp 1000000000000000) for mfn b1d89 (pfn bacf7)
(XEN) mm.c:3027:d0 Error while pinning mfn b1d89
(XEN) traps.c:481:d0 Unhandled invalid opcode fault/trap [#6] on VCPU 0 [ec=0000]
(XEN) domain_crash_sync called from entry.S
(XEN) Domain 0 (vcpu#0) crashed on cpu#0:
The reason is that at some point init_memory_mapping is going to reach
the pagetable pages area and map those pages too (mapping them as normal
memory that falls in the range of addresses passed to init_memory_mapping
as argument). Some of those pages are already pagetable pages (they are
in the range pgt_buf_start-pgt_buf_end) therefore they are going to be
mapped RO and everything is fine.
ranges are RO).
For this reason, this function is introduced which is called _after_
the init_memory_mapping has completed (in a perfect world we would
call this function from init_memory_mapping, but lets ignore that).
Because we are called _after_ init_memory_mapping the pgt_buf_[start,
end,top] have all changed to new values (b/c another init_memory_mapping
is called). Hence, the first time we enter this function, we save
away the pgt_buf_start value and update the pgt_buf_[end,top].
When we detect that the "old" pgt_buf_start through pgt_buf_end
PFNs have been reserved (so memblock_x86_reserve_range has been called),
we immediately set out to RW the "old" pgt_buf_end through pgt_buf_top.
And then we update those "old" pgt_buf_[end|top] with the new ones
so that we can redo this on the next pagetable.
Reviewed-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
[v1: Updated with Jeremy's comments]
[v2: Added the crash output]
The two "is_early_ioremap_ptep" checks in mask_rw_pte are only used on
x86_64, in fact early_ioremap is not used at all to setup the initial
pagetable on x86_32.
Moreover on x86_32 the two checks are wrong because the range
pgt_buf_start..pgt_buf_end initially should be mapped RW because
the pages in the range are not pagetable pages yet and haven't been
cleared yet. Afterwards considering the pgt_buf_start..pgt_buf_end is
part of the initial mapping, xen_alloc_pte is capable of turning
the ptes RO when they become pagetable pages.
Fix the issue and improve the readability of the code providing two
different implementation of mask_rw_pte for x86_32 and x86_64.
There are valid situations in which this error is not
a warning. Mainly when QEMU maps a guest memory and uses
the VM_IO flag to set the MFNs. For right now make the
WARN be WARN_ONCE. In the future we will:
1). Remove the VM_IO code handling..
2). .. which will also remove this debug facility.
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
xen: update mask_rw_pte after kernel page tables init changes
xen: set max_pfn_mapped to the last pfn mapped
x86: Cleanup highmap after brk is concluded
Fix up trivial onflict (added header file includes) in
arch/x86/mm/init_64.c
After "x86-64, mm: Put early page table high" already existing kernel
page table pages can be mapped using early_ioremap too so we need to
update mask_rw_pte to make sure these pages are still mapped RO.
The reason why we have to do that is explain by the commit message of
fef5ba797991f9335bcfc295942b684f9bf613a1:
"Xen requires that all pages containing pagetable entries to be mapped
read-only. If pages used for the initial pagetable are already mapped
then we can change the mapping to RO. However, if they are initially
unmapped, we need to make sure that when they are later mapped, they
are also mapped RO.
..SNIP..
the pagetable setup code early_ioremaps the pages to write their
entries, so we must make sure that mappings created in the early_ioremap
fixmap area are mapped RW. (Those mappings are removed before the pages
are presented to Xen as pagetable pages.)"
We accomplish all this in mask_rw_pte by mapping RO all the pages mapped
using early_ioremap apart from the last one that has been allocated
because it is not a page table page yet (it has not been hooked into the
page tables yet).
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
LKML-Reference: <alpine.DEB.2.00.1103171739050.3382@kaball-desktop>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Do not set max_pfn_mapped to the end of the initial memory mappings,
that also contain pages that don't belong in pfn space (like the mfn
list).
Set max_pfn_mapped to the last real pfn mapped in the initial memory
mappings that is the pfn backing _end.
x86: Flush TLB if PGD entry is changed in i386 PAE mode
x86, dumpstack: Correct stack dump info when frame pointer is available
x86: Clean up csum-copy_64.S a bit
x86: Fix common misspellings
x86: Fix misspelling and align params
x86: Use PentiumPro-optimized partial_csum() on VIA C7
They were generated by 'codespell' and then manually reviewed.
Cc: trivial@kernel.org
LKML-Reference: <1300389856-1099-3-git-send-email-lucas.demarchi@profusion.mobi>
'stable/balloon' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/hvc-console' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/hvc: Disable probe_irq_on/off from poking the hvc-console IRQ line.
* 'stable/gntalloc.v6' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: gntdev: fix build warning
xen/p2m/m2p/gnttab: do not add failed grant maps to m2p override
xen-gntdev: Add cast to pointer
xen-gntdev: Fix incorrect use of zero handle
xen: change xen/[gntdev/gntalloc] to default m
xen-gntdev: prevent using UNMAP_NOTIFY_CLEAR_BYTE on read-only mappings
xen-gntdev: Avoid double-mapping memory
xen-gntdev: Avoid unmapping ranges twice
xen-gntdev: Use map->vma for checking map validity
xen-gntdev: Fix unmap notify on PV domains
xen-gntdev: Fix memory leak when mmap fails
xen/gntalloc,gntdev: Add unmap notify ioctl
xen-gntalloc: Userspace grant allocation driver
xen-gntdev: Support mapping in HVM domains
xen-gntdev: Add reference counting to maps
xen-gntdev: Use find_vma rather than iterating our vma list manually
xen-gntdev: Change page limit to be global instead of per-open
* 'stable/balloon' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (24 commits)
xen-gntdev: Use ballooned pages for grant mappings
xen-balloon: Add interface to retrieve ballooned pages
xen-balloon: Move core balloon functionality out of module
xen/balloon: Remove pr_info's and don't alter retry_count
xen/balloon: Protect against CPU exhaust by event/x process
xen/balloon: Migration from mod_timer() to schedule_delayed_work()
xen/balloon: Removal of driver_pages
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (93 commits)
x86, tlb, UV: Do small micro-optimization for native_flush_tlb_others()
x86-64, NUMA: Don't call numa_set_distanc() for all possible node combinations during emulation
x86-64, NUMA: Don't assume phys node 0 is always online in numa_emulation()
x86-64, NUMA: Clean up initmem_init()
x86-64, NUMA: Fix numa_emulation code with node0 without RAM
x86-64, NUMA: Revert NUMA affine page table allocation
x86: Work around old gas bug
x86-64, NUMA: Better explain numa_distance handling
x86-64, NUMA: Fix distance table handling
mm: Move early_node_map[] reverse scan helpers under HAVE_MEMBLOCK
x86-64, NUMA: Fix size of numa_distance array
x86: Rename e820_table_* to pgt_buf_*
bootmem: Move __alloc_memory_core_early() to nobootmem.c
bootmem: Move contig_page_data definition to bootmem.c/nobootmem.c
bootmem: Separate out CONFIG_NO_BOOTMEM code into nobootmem.c
x86-64, NUMA: Seperate out numa_alloc_distance() from numa_set_distance()
x86-64, NUMA: Add proper function comments to global functions
x86-64, NUMA: Move NUMA emulation into numa_emulation.c
x86-64, NUMA: Prepare numa_emulation() for moving NUMA emulation into a separate file
x86-64, NUMA: Do not scan two times for setup_node_bootmem()
Fix up conflicts in arch/x86/kernel/smpboot.c
* 'stable/p2m-identity.v4.9.1' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/m2p: Check whether the MFN has IDENTITY_FRAME bit set..
xen/m2p: No need to catch exceptions when we know that there is no RAM
xen/debug: WARN_ON when identity PFN has no _PAGE_IOMAP flag set.
xen/debugfs: Add 'p2m' file for printing out the P2M layout.
xen/setup: Set identity mapping for non-RAM E820 and E820 gaps.
xen/mmu: WARN_ON when racing to swap middle leaf.
xen/mmu: Set _PAGE_IOMAP if PFN is an identity PFN.
xen/mmu: Add the notion of identity (1-1) mapping.
xen: Mark all initial reserved pages for the balloon as INVALID_P2M_ENTRY.
* 'stable/e820' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/e820: Don't mark balloon memory as E820_UNUSABLE when running as guest and fix overflow.
xen/setup: Inhibit resource API from using System RAM E820 gaps as PCI mem gaps.
arch/x86/mm/numa_64.c
Merge reason: Resolve the conflict, update the branch to .38.
Removal of driver_pages (I do not have seen any references to it).
Only enabled if XEN_DEBUG is enabled. We print a warning
when:
pfn_to_mfn(pfn) == pfn, but no VM_IO (_PAGE_IOMAP) flag set
(and pfn is an identity mapped pfn)
pfn_to_mfn(pfn) != pfn, and VM_IO flag is set.
(ditto, pfn is an identity mapped pfn)
[v2: Make it dependent on CONFIG_XEN_DEBUG instead of ..DEBUG_FS]
[v3: Fix compiler warning]
Reviewed-by: Ian Campbell <ian.campbell@citrix.com>
We walk over the whole P2M tree and construct a simplified view of
which PFN regions belong to what level and what type they are.
Only enabled if CONFIG_XEN_DEBUG_FS is set.
[v2: UNKN->UNKNOWN, use uninitialized_var]
[v3: Rebased on top of mmu->p2m code split]
[v4: Fixed the else if]
Reviewed-by: Ian Campbell <Ian.Campbell@eu.citrix.com>
If we find that the PFN is within the P2M as an identity
PFN make sure to tack on the _PAGE_IOMAP flag.
It's forbidden to take the page_table_lock with the irq disabled
or if there's contention the IPIs (for tlb flushes) sent with
the page_table_lock held will never run leading to a deadlock.
Nobody takes the pgd_lock from irq context so the _irqsave can be
removed.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: <stable@kernel.org>
LKML-Reference: <201102162345.p1GNjMjm021738@imap1.linux-foundation.org>
With this patch, we diligently set regions that will be used by the
balloon driver to be INVALID_P2M_ENTRY and under the ownership
of the balloon driver. We are OK using the __set_phys_to_machine
as we do not expect to be allocating any P2M middle or entries pages.
The set_phys_to_machine has the side-effect of potentially allocating
new pages and we do not want that at this stage.
We can do this because xen_build_mfn_list_list will have already
allocated all such pages up to xen_max_p2m_pfn.
We also move the check for auto translated physmap down the
stack so it is present in __set_phys_to_machine.
[v2: Rebased with mmu->p2m code split]
e820_table_{start|end|top}, which are used to buffer page table
allocation during early boot, are now derived from memblock and don't
have much to do with e820. Change the names so that they reflect what
they're used for.
This patch doesn't introduce any behavior change.
-v2: Ingo found that earlier patch "x86: Use early pre-allocated page
table buffer top-down" caused crash on 32bit and needed to be
dropped. This patch was updated to reflect the change.
-tj: Updated commit description.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Fixes this build error:
ERROR: "arbitrary_virt_to_machine" [drivers/xen/xen-gntdev.ko] undefined!
On stock 2.6.37-rc4, running:
# mount lilith:/export /mnt/lilith
# find /mnt/lilith/ -type f -print0 | xargs -0 file
crashes the machine fairly quickly under Xen. Often it results in oops
messages, but the couple of times I tried just now, it just hung quietly
and made Xen print some rude messages:
(XEN) mm.c:2389:d80 Bad type (saw 7400000000000001 != exp
3000000000000000) for mfn 1d7058 (pfn 18fa7)
(XEN) mm.c:964:d80 Attempt to create linear p.t. with write perms
(XEN) mm.c:2389:d80 Bad type (saw 7400000000000010 != exp
1000000000000000) for mfn 1d2e04 (pfn 1d1fb)
(XEN) mm.c:2965:d80 Error while pinning mfn 1d2e04
Which means the domain tried to map a pagetable page RW, which would
allow it to map arbitrary memory, so Xen stopped it. This is because
vm_unmap_ram() left some pages mapped in the vmalloc area after NFS had
finished with them, and those pages got recycled as pagetable pages
while still having these RW aliases.
Removing those mappings immediately removes the Xen-visible aliases, and
so it has no problem with those pages being reused as pagetable pages.
Deferring the TLB flush doesn't upset Xen because it can flush the TLB
itself as needed to maintain its invariants.
When unmapping a region in the vmalloc space, clear the ptes
immediately. There's no point in deferring this because there's no
amortization benefit.
The TLBs are left dirty, and they are flushed lazily to amortize the
cost of the IPIs.
This specific motivation for this patch is an oops-causing regression
since 2.6.36 when using NFS under Xen, triggered by the NFS client's use
of vm_map_ram() introduced in 56e4ebf877b60 ("NFS: readdir with vmapped
pages") . XFS also uses vm_map_ram() and could cause similar problems.
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Bryan Schumaker <bjschuma@netapp.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Alex Elder <aelder@sgi.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: remove duplicated #include
xen: x86/32: perform initial startup on initial_page_table
Only make swapper_pg_dir readonly and pinned when generic x86 architecture code
(which also starts on initial_page_table) switches to it. This helps ensure
that the generic setup paths work on Xen unmodified. In particular
clone_pgd_range writes directly to the destination pgd entries and is used to
initialise swapper_pg_dir so we need to ensure that it remains writeable until
the last possible moment during bring up.
This is complicated slightly by the need to avoid sharing kernel PMD entries
when running under Xen, therefore the Xen implementation must make a copy of
the kernel PMD (which is otherwise referred to by both intial_page_table and
swapper_pg_dir) before switching to swapper_pg_dir.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: H. Peter Anvin <hpa@linux.intel.com>
upstream/for-linus
* upstream/core:
xen/events: Use PIRQ instead of GSI value when unmapping MSI/MSI-X irqs.
xen: set IO permission early (before early_cpu_init())
xen: re-enable boot-time ballooning
xen/balloon: make sure we only include remaining extra ram
xen/balloon: the balloon_lock is useless
xen: add extra pages to balloon
xen/events: use locked set|clear_bit() for cpu_evtchn_mask
xen/evtchn: clear secondary CPUs' cpu_evtchn_mask[] after restore
xen: implement XENMEM_machphys_mapping
* upstream/xenfs:
Revert "xen/privcmd: create address space to allow writable mmaps"
xen/xenfs: update xenfs_mount for new prototype
xen: fix header export to userspace
xen: set vma flag VM_PFNMAP in the privcmd mmap file_op
xen: xenfs: privcmd: check put_user() return code
* upstream/evtchn:
xen: make evtchn's name less generic
xen/evtchn: the evtchn device is non-seekable
xen/evtchn: add missing static
xen/evtchn: Fix name of Xen event-channel device
xen/evtchn: don't do unbind_from_irqhandler under spinlock
xen/evtchn: remove spurious barrier
xen/evtchn: ports start enabled
xen/evtchn: dynamically allocate port_user array
xen/evtchn: track enabled state for each port
* commit 'v2.6.37-rc2': (10093 commits)
Linux 2.6.37-rc2
capabilities/syslog: open code cap_syslog logic to fix build failure
i2c: Sanity checks on adapter registration
i2c: Mark i2c_adapter.id as deprecated
i2c: Drivers shouldn't include <linux/i2c-id.h>
i2c: Delete unused adapter IDs
i2c: Remove obsolete cleanup for clientdata
include/linux/kernel.h: Move logging bits to include/linux/printk.h
Fix gcc 4.5.1 miscompiling drivers/char/i8k.c (again)
hwmon: (w83795) Check for BEEP pin availability
hwmon: (w83795) Clear intrusion alarm immediately
hwmon: (w83795) Read the intrusion state properly
hwmon: (w83795) Print the actual temperature channels as sources
hwmon: (w83795) List all usable temperature sources
hwmon: (w83795) Expose fan control method
hwmon: (w83795) Fix fan control mode attributes
hwmon: (lm95241) Check validity of input values
hwmon: Change mail address of Hans J. Koch
PCI: sysfs: fix printk warnings
GFS2: Fix inode deallocation race
This hypercall allows Xen to specify a non-default location for the
machine to physical mapping. This capability is used when running a 32
bit domain 0 on a 64 bit hypervisor to shrink the hypervisor hole to
exactly the size required.
[ Impact: add Xen hypercall definitions ]
Set VM_PFNMAP in the privcmd mmap file_op, rather than later in
xen_remap_domain_mfn_range when it is too late because
vma_wants_writenotify has already been called and vm_page_prot has
already been modified.
sizeof(pmd_t *) is 4 bytes on 32-bit PAE leading to an allocation of
only 2048 bytes. The correct size is sizeof(pmd_t) giving us a full
page allocation.
and branch 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm
* 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm:
xen: register xen pci notifier
xen: initialize cpu masks for pv guests in xen_smp_init
xen: add a missing #include to arch/x86/pci/xen.c
xen: mask the MTRR feature from the cpuid
xen: make hvc_xen console work for dom0.
xen: add the direct mapping area for ISA bus access
xen: Initialize xenbus for dom0.
xen: use vcpu_ops to setup cpu masks
xen: map a dummy page for local apic and ioapic in xen_set_fixmap
xen: remap MSIs into pirqs when running as initial domain
xen: remap GSIs as pirqs when running as initial domain
xen: introduce XEN_DOM0 as a silent option
xen: map MSIs into pirqs
xen: support GSI -> pirq remapping in PV on HVM guests
xen: add xen hvm acpi_register_gsi variant
acpi: use indirect call to register gsi in different modes
xen: implement xen_hvm_register_pirq
xen: get the maximum number of pirqs from xen
xen: support pirq != irq
* 'stable/xen-pcifront-0.8.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (27 commits)
X86/PCI: Remove the dependency on isapnp_disable.
xen: Update Makefile with CONFIG_BLOCK dependency for biomerge.c
MAINTAINERS: Add myself to the Xen Hypervisor Interface and remove Chris Wright.
x86: xen: Sanitse irq handling (part two)
swiotlb-xen: On x86-32 builts, select SWIOTLB instead of depending on it.
MAINTAINERS: Add myself for Xen PCI and Xen SWIOTLB maintainer.
xen/pci: Request ACS when Xen-SWIOTLB is activated.
xen-pcifront: Xen PCI frontend driver.
xenbus: prevent warnings on unhandled enumeration values
xenbus: Xen paravirtualised PCI hotplug support.
xen/x86/PCI: Add support for the Xen PCI subsystem
x86: Introduce x86_msi_ops
msi: Introduce default_[teardown|setup]_msi_irqs with fallback.
x86/PCI: Export pci_walk_bus function.
x86/PCI: make sure _PAGE_IOMAP it set on pci mappings
x86/PCI: Clean up pci_cache_line_size
xen: fix shared irq device passthrough
xen: Provide a variant of xen_poll_irq with timeout.
xen: Find an unbound irq number in reverse order (high to low).
xen: statically initialize cpu_evtchn_mask_p
Fix up trivial conflicts in drivers/pci/Makefile
