git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen features and fixes from David Vrabel:
- use a single source list of hypercalls, generating other tables etc.
at build time.
- add a "Xen PV" APIC driver to support >255 VCPUs in PV guests.
- significant performance improve to guest save/restore/migration.
- scsiback/front save/restore support.
- infrastructure for multi-page xenbus rings.
- misc fixes.
* tag 'stable/for-linus-4.1-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/pci: Try harder to get PXM information for Xen
xenbus_client: Extend interface to support multi-page ring
xen-pciback: also support disabling of bus-mastering and memory-write-invalidate
xen: support suspend/resume in pvscsi frontend
xen: scsiback: add LUN of restored domain
xen-scsiback: define a pr_fmt macro with xen-pvscsi
xen/mce: fix up xen_late_init_mcelog() error handling
xen/privcmd: improve performance of MMAPBATCH_V2
xen: unify foreign GFN map/unmap for auto-xlated physmap guests
x86/xen/apic: WARN with details.
x86/xen: Provide a "Xen PV" APIC driver to support >255 VCPUs
xen/pciback: Don't print scary messages when unsupported by hypervisor.
xen: use generated hypercall symbols in arch/x86/xen/xen-head.S
xen: use generated hypervisor symbols in arch/x86/xen/trace.c
xen: synchronize include/xen/interface/xen.h with xen
xen: build infrastructure for generating hypercall depending symbols
xen: balloon: Use static attribute groups for sysfs entries
xen: pcpu: Use static attribute groups for sysfs entry
We would want to use number of page table level to define mm_struct.
Let's expose it as CONFIG_PGTABLE_LEVELS.
Tested-by: Guenter Roeck <linux@roeck-us.net>
Make the IOCTL_PRIVCMD_MMAPBATCH_V2 (and older V1 version) map
multiple frames at a time rather than one at a time, despite the pages
being non-consecutive GFNs.
xen_remap_foreign_mfn_array() is added which maps an array of GFNs
(instead of a consecutive range of GFNs).
Since per-frame errors are returned in an array, privcmd must set the
MMAPBATCH_V1 error bits as part of the "report errors" phase, after
all the frames are mapped.
Migrate times are significantly improved (when using a PV toolstack
domain). For example, for an idle 12 GiB PV guest:
Before After
real 0m38.179s 0m26.868s
user 0m15.096s 0m13.652s
sys 0m28.988s 0m18.732s
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Auto-translated physmap guests (arm, arm64 and x86 PVHVM/PVH) map and
unmap foreign GFNs using the same method (updating the physmap).
Unify the two arm and x86 implementations into one commont one.
Note that on arm and arm64, the correct error code will be returned
(instead of always -EFAULT) and map/unmap failure warnings are no
longer printed. These changes are required if the foreign domain is
paging (-ENOENT failures are expected and must be propagated up to the
caller).
Remove a nested ifdef.
Signed-off-by: Juergen Gross <jgross@suse.com>
The file arch/x86/xen/mmu.c has some functions that can be annotated
with "__init".
Pull additional xen update from David Vrabel:
"Xen: additional features for 3.19-rc0
- Linear p2m for x86 PV guests which simplifies the p2m code,
improves performance and will allow for > 512 GB PV guests in the
future.
A last-minute, configuration specific issue was discovered with this
change which is why it was not included in my previous pull request.
This is now been fixed and tested"
* tag 'stable/for-linus-3.19-rc0b-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen: switch to post-init routines in xen mmu.c earlier
Revert "swiotlb-xen: pass dev_addr to swiotlb_tbl_unmap_single"
xen: annotate xen_set_identity_and_remap_chunk() with __init
xen: introduce helper functions to do safe read and write accesses
xen: Speed up set_phys_to_machine() by using read-only mappings
xen: switch to linear virtual mapped sparse p2m list
xen: Hide get_phys_to_machine() to be able to tune common path
x86: Introduce function to get pmd entry pointer
xen: Delay invalidating extra memory
xen: Delay m2p_override initialization
xen: Delay remapping memory of pv-domain
xen: use common page allocation function in p2m.c
xen: Make functions static
xen: fix some style issues in p2m.c
With the virtual mapped linear p2m list the post-init mmu operations
must be used for setting up the p2m mappings, as in case of
CONFIG_FLATMEM the init routines may trigger BUGs.
paging_init() sets up all infrastructure needed to switch to the
post-init mmu ops done by xen_post_allocator_init(). With the virtual
mapped linear p2m list we need some mmu ops during setup of this list,
so we have to switch to the correct mmu ops as soon as possible.
The p2m list is usable from the beginning, just expansion requires to
have established the new linear mapping. So the call of
xen_remap_memory() had to be introduced, but this is not due to the
mmu ops requiring this.
Summing it up: calling xen_post_allocator_init() not directly after
paging_init() was conceptually wrong in the beginning, it just didn't
matter up to now as no functions used between the two calls needed
some critical mmu ops (e.g. alloc_pte). This has changed now, so I
corrected it.
Reported-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Pull x86 vdso updates from Ingo Molnar:
"Various vDSO updates from Andy Lutomirski, mostly cleanups and
reorganization to improve maintainability, but also some
micro-optimizations and robustization changes"
* 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86_64/vsyscall: Restore orig_ax after vsyscall seccomp
x86_64: Add a comment explaining the TASK_SIZE_MAX guard page
x86_64,vsyscall: Make vsyscall emulation configurable
x86_64, vsyscall: Rewrite comment and clean up headers in vsyscall code
x86_64, vsyscall: Turn vsyscalls all the way off when vsyscall==none
x86,vdso: Use LSL unconditionally for vgetcpu
x86: vdso: Fix build with older gcc
x86_64/vdso: Clean up vgetcpu init and merge the vdso initcalls
x86_64/vdso: Remove jiffies from the vvar page
x86/vdso: Make the PER_CPU segment 32 bits
x86/vdso: Make the PER_CPU segment start out accessed
x86/vdso: Change the PER_CPU segment to use struct desc_struct
x86_64/vdso: Move getcpu code from vsyscall_64.c to vdso/vma.c
x86_64/vsyscall: Move all of the gate_area code to vsyscall_64.c
At start of the day the Xen hypervisor presents a contiguous mfn list
to a pv-domain. In order to support sparse memory this mfn list is
accessed via a three level p2m tree built early in the boot process.
Whenever the system needs the mfn associated with a pfn this tree is
used to find the mfn.
Instead of using a software walked tree for accessing a specific mfn
list entry this patch is creating a virtual address area for the
entire possible mfn list including memory holes. The holes are
covered by mapping a pre-defined page consisting only of "invalid
mfn" entries. Access to a mfn entry is possible by just using the
virtual base address of the mfn list and the pfn as index into that
list. This speeds up the (hot) path of determining the mfn of a
pfn.
Kernel build on a Dell Latitude E6440 (2 cores, HT) in 64 bit Dom0
showed following improvements:
Elapsed time: 32:50 -> 32:35
System: 18:07 -> 17:47
User: 104:00 -> 103:30
Tested with following configurations:
- 64 bit dom0, 8GB RAM
- 64 bit dom0, 128 GB RAM, PCI-area above 4 GB
- 32 bit domU, 512 MB, 8 GB, 43 GB (more wouldn't work even without
the patch)
- 32 bit domU, ballooning up and down
- 32 bit domU, save and restore
- 32 bit domU with PCI passthrough
- 64 bit domU, 8 GB, 2049 MB, 5000 MB
- 64 bit domU, ballooning up and down
- 64 bit domU, save and restore
- 64 bit domU with PCI passthrough
Today get_phys_to_machine() is always called when the mfn for a pfn
is to be obtained. Add a wrapper __pfn_to_mfn() as inline function
to be able to avoid calling get_phys_to_machine() when possible as
soon as the switch to a linear mapped p2m list has been done.
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Early in the boot process the memory layout of a pv-domain is changed
to match the E820 map (either the host one for Dom0 or the Xen one)
regarding placement of RAM and PCI holes. This requires removing memory
pages initially located at positions not suitable for RAM and adding
them later at higher addresses where no restrictions apply.
To be able to operate on the hypervisor supported p2m list until a
virtual mapped linear p2m list can be constructed, remapping must
be delayed until virtual memory management is initialized, as the
initial p2m list can't be extended unlimited at physical memory
initialization time due to it's fixed structure.
A further advantage is the reduction in complexity and code volume as
we don't have to be careful regarding memory restrictions during p2m
updates.
In arch/x86/xen/p2m.c three different allocation functions for
obtaining a memory page are used: extend_brk(), alloc_bootmem_align()
or __get_free_page(). Which of those functions is used depends on the
progress of the boot process of the system.
Introduce a common allocation routine selecting the to be called
allocation routine dynamically based on the boot progress. This allows
moving initialization steps without having to care about changing
allocation calls.
With the dynamical mapping between cache modes and pgprot values it is
now possible to use all cache modes via the Xen hypervisor PAT settings
in a pv domain.
All to be done is to read the PAT configuration MSR and set up the
translation tables accordingly.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: stefan.bader@canonical.com
Cc: xen-devel@lists.xensource.com
Cc: ville.syrjala@linux.intel.com
Cc: jbeulich@suse.com
Cc: toshi.kani@hp.com
Cc: plagnioj@jcrosoft.com
Cc: tomi.valkeinen@ti.com
Cc: bhelgaas@google.com
Link: http://lkml.kernel.org/r/1415019724-4317-19-git-send-email-jgross@suse.com
This adds CONFIG_X86_VSYSCALL_EMULATION, guarded by CONFIG_EXPERT.
Turning it off completely disables vsyscall emulation, saving ~3.5k
for vsyscall_64.c, 4k for vsyscall_emu_64.S (the fake vsyscall
page), some tiny amount of core mm code that supports a gate area,
and possibly 4k for a wasted pagetable. The latter is because the
vsyscall addresses are misaligned and fit poorly in the fixmap.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/406db88b8dd5f0cbbf38216d11be34bbb43c7eae.1414618407.git.luto@amacapital.net
The 3 level p2m tree for the Xen tools is constructed very early at
boot by calling xen_build_mfn_list_list(). Memory needed for this tree
is allocated via extend_brk().
As this tree (other than the kernel internal p2m tree) is only needed
for domain save/restore, live migration and crash dump analysis it
doesn't matter whether it is constructed very early or just some
milliseconds later when memory allocation is possible by other means.
This patch moves the call of xen_build_mfn_list_list() just after
calling xen_pagetable_p2m_copy() simplifying this function, too, as it
doesn't have to bother with two parallel trees now. The same applies
for some other internal functions.
While simplifying code, make early_can_reuse_p2m_middle() static and
drop the unused second parameter. p2m_mid_identity_mfn can be removed
as well, it isn't used either.
Since mfn_to_pfn() returns the correct PFN for identity mappings (as
used for MMIO regions), the use of _PAGE_IOMAP is not required in
pte_mfn_to_pfn().
Do not set the _PAGE_IOMAP flag in pte_pfn_to_mfn() and do not use it
in pte_mfn_to_pfn().
This will allow _PAGE_IOMAP to be removed, making it available for
future use.
When RANDOMIZE_BASE (KASLR) is enabled; or the sum of all loaded
modules exceeds 512 MiB, then loading modules fails with a warning
(and hence a vmalloc allocation failure) because the PTEs for the
newly-allocated vmalloc address space are not zero.
WARNING: CPU: 0 PID: 494 at linux/mm/vmalloc.c:128
vmap_page_range_noflush+0x2a1/0x360()
This is caused by xen_setup_kernel_pagetables() copying
level2_kernel_pgt into level2_fixmap_pgt, overwriting many non-present
entries.
Without KASLR, the normal kernel image size only covers the first half
of level2_kernel_pgt and module space starts after that.
L4[511]->level3_kernel_pgt[510]->level2_kernel_pgt[ 0..255]->kernel
[256..511]->module
[511]->level2_fixmap_pgt[ 0..505]->module
This allows 512 MiB of of module vmalloc space to be used before
having to use the corrupted level2_fixmap_pgt entries.
With KASLR enabled, the kernel image uses the full PUD range of 1G and
module space starts in the level2_fixmap_pgt. So basically:
L4[511]->level3_kernel_pgt[510]->level2_kernel_pgt[0..511]->kernel
[511]->level2_fixmap_pgt[0..505]->module
And now no module vmalloc space can be used without using the corrupt
Fix this by properly converting the level2_fixmap_pgt entries to MFNs,
and setting level1_fixmap_pgt as read-only.
A number of comments were also using the the wrong L3 offset for
level2_kernel_pgt. These have been corrected.
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull x86 cdso updates from Peter Anvin:
"Vdso cleanups and improvements largely from Andy Lutomirski. This
makes the vdso a lot less ''special''"
* 'x86/vdso' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/vdso, build: Make LE access macros clearer, host-safe
x86/vdso, build: Fix cross-compilation from big-endian architectures
x86/vdso, build: When vdso2c fails, unlink the output
x86, vdso: Fix an OOPS accessing the HPET mapping w/o an HPET
x86, mm: Replace arch_vma_name with vm_ops->name for vsyscalls
x86, mm: Improve _install_special_mapping and fix x86 vdso naming
mm, fs: Add vm_ops->name as an alternative to arch_vma_name
x86, vdso: Remove vestiges of VDSO_PRELINK and some outdated comments
x86, vdso: Move the vvar and hpet mappings next to the 64-bit vDSO
x86, vdso: Move the 32-bit vdso special pages after the text
x86, vdso: Reimplement vdso.so preparation in build-time C
x86, vdso: Move syscall and sysenter setup into kernel/cpu/common.c
x86, vdso: Clean up 32-bit vs 64-bit vdso params
x86, mm: Ensure correct alignment of the fixmap
When running as a dom0 in PVH mode, foreign pfns that are accessed
must be added to our p2m which is managed by xen. This is done via
XENMEM_add_to_physmap_range hypercall. This is needed for toolstack
building guests and mapping guest memory, xentrace mapping xen pages,
etc.
Signed-off-by: Mukesh Rathor <mukesh.rathor@oracle.com>
_PAGE_IOMAP is used in xen_remap_domain_mfn_range() to prevent the
pfn_pte() call in remap_area_mfn_pte_fn() from using the p2m to translate
the MFN. If mfn_pte() is used instead, the p2m look up is avoided and
the use of _PAGE_IOMAP is no longer needed.
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
This makes the 64-bit and x32 vdsos use the same mechanism as the
32-bit vdso. Most of the churn is deleting all the old fixmap code.
Link: http://lkml.kernel.org/r/8af87023f57f6bb96ec8d17fce3f88018195b49b.1399317206.git.luto@amacapital.net
Pull x86 vdso changes from Peter Anvin:
"This is the revamp of the 32-bit vdso and the associated cleanups.
This adds timekeeping support to the 32-bit vdso that we already have
in the 64-bit vdso. Although 32-bit x86 is legacy, it is likely to
remain in the embedded space for a very long time to come.
This removes the traditional COMPAT_VDSO support; the configuration
variable is reused for simply removing the 32-bit vdso, which will
produce correct results but obviously suffer a performance penalty.
Only one beta version of glibc was affected, but that version was
unfortunately included in one OpenSUSE release.
This is not the end of the vdso cleanups. Stefani and Andy have
agreed to continue work for the next kernel cycle; in fact Andy has
already produced another set of cleanups that came too late for this
cycle.
An incidental, but arguably important, change is that this ensures
that unused space in the VVAR page is properly zeroed. It wasn't
before, and would contain whatever garbage was left in memory by BIOS
or the bootloader. Since the VVAR page is accessible to user space
this had the potential of information leaks"
* 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
x86, vdso: Fix the symbol versions on the 32-bit vDSO
x86, vdso, build: Don't rebuild 32-bit vdsos on every make
x86, vdso: Actually discard the .discard sections
x86, vdso: Fix size of get_unmapped_area()
x86, vdso: Finish removing VDSO32_PRELINK
x86, vdso: Move more vdso definitions into vdso.h
x86: Load the 32-bit vdso in place, just like the 64-bit vdsos
x86, vdso32: handle 32 bit vDSO larger one page
x86, vdso32: Disable stack protector, adjust optimizations
x86, vdso: Zero-pad the VVAR page
x86, vdso: Add 32 bit VDSO time support for 64 bit kernel
x86, vdso: Add 32 bit VDSO time support for 32 bit kernel
x86, vdso: Patch alternatives in the 32-bit VDSO
x86, vdso: Introduce VVAR marco for vdso32
x86, vdso: Cleanup __vdso_gettimeofday()
x86, vdso: Replace VVAR(vsyscall_gtod_data) by gtod macro
x86, vdso: __vdso_clock_gettime() cleanup
x86, vdso: Revamp vclock_gettime.c
mm: Add new func _install_special_mapping() to mmap.c
x86, vdso: Make vsyscall_gtod_data handling x86 generic
This reverts commit a9c8e4beeeb64c22b84c803747487857fe424b68.
PTEs in Xen PV guests must contain machine addresses if _PAGE_PRESENT
is set and pseudo-physical addresses is _PAGE_PRESENT is clear.
This is because during a domain save/restore (migration) the page
table entries are "canonicalised" and uncanonicalised". i.e., MFNs are
converted to PFNs during domain save so that on a restore the page
table entries may be rewritten with the new MFNs on the destination.
This canonicalisation is only done for PTEs that are present.
This change resulted in writing PTEs with MFNs if _PAGE_PROTNONE (or
_PAGE_NUMA) was set but _PAGE_PRESENT was clear. These PTEs would be
migrated as-is which would result in unexpected behaviour in the
destination domain. Either a) the MFN would be translated to the
wrong PFN/page; b) setting the _PAGE_PRESENT bit would clear the PTE
because the MFN is no longer owned by the domain; or c) the present
bit would not get set.
Symptoms include "Bad page" reports when munmapping after migrating a
domain.
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: <stable@vger.kernel.org> [3.12+]
Checkin
b0b49f2673f0 x86, vdso: Remove compat vdso support
... removed the VDSO from the fixmap, and thus FIX_VDSO; remove a
stray reference in Xen.
Found by Fengguang Wu's test robot.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Link: http://lkml.kernel.org/r/4bb4690899106eb11430b1186d5cc66ca9d1660c.1394751608.git.luto@amacapital.net
Steven Noonan forwarded a users report where they had a problem starting
vsftpd on a Xen paravirtualized guest, with this in dmesg:
BUG: Bad page map in process vsftpd pte:8000000493b88165 pmd:e9cc01067
page:ffffea00124ee200 count:0 mapcount:-1 mapping: (null) index:0x0
page flags: 0x2ffc0000000014(referenced|dirty)
addr:00007f97eea74000 vm_flags:00100071 anon_vma:ffff880e98f80380 mapping: (null) index:7f97eea74
CPU: 4 PID: 587 Comm: vsftpd Not tainted 3.12.7-1-ec2 #1
Call Trace:
dump_stack+0x45/0x56
print_bad_pte+0x22e/0x250
unmap_single_vma+0x583/0x890
unmap_vmas+0x65/0x90
exit_mmap+0xc5/0x170
mmput+0x65/0x100
do_exit+0x393/0x9e0
do_group_exit+0xcc/0x140
SyS_exit_group+0x14/0x20
system_call_fastpath+0x1a/0x1f
Disabling lock debugging due to kernel taint
BUG: Bad rss-counter state mm:ffff880e9ca60580 idx:0 val:-1
BUG: Bad rss-counter state mm:ffff880e9ca60580 idx:1 val:1
The issue could not be reproduced under an HVM instance with the same
kernel, so it appears to be exclusive to paravirtual Xen guests. He
bisected the problem to commit 1667918b6483 ("mm: numa: clear numa
hinting information on mprotect") that was also included in 3.12-stable.
The problem was related to how xen translates ptes because it was not
accounting for the _PAGE_NUMA bit. This patch splits pte_present to add
a pteval_present helper for use by xen so both bare metal and xen use
the same code when checking if a PTE is present.
[mgorman@suse.de: wrote changelog, proposed minor modifications]
[akpm@linux-foundation.org: fix typo in comment]
Reported-by: Steven Noonan <steven@uplinklabs.net>
Tested-by: Steven Noonan <steven@uplinklabs.net>
Signed-off-by: Elena Ufimtseva <ufimtseva@gmail.com>
Pull x86 asmlinkage (LTO) changes from Peter Anvin:
"This patchset adds more infrastructure for link time optimization
(LTO).
This patchset was pulled into my tree late because of a
miscommunication (part of the patchset was picked up by other
maintainers). However, the patchset is strictly build-related and
seems to be okay in testing"
* 'x86-asmlinkage-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, asmlinkage, xen: Fix type of NMI
x86, asmlinkage, xen, kvm: Make {xen,kvm}_lock_spinning global and visible
x86: Use inline assembler instead of global register variable to get sp
x86, asmlinkage, paravirt: Make paravirt thunks global
x86, asmlinkage, paravirt: Don't rely on local assembler labels
x86, asmlinkage, lguest: Fix C functions used by inline assembler
The paravirt thunks use a hack of using a static reference to a static
function to reference that function from the top level statement.
This assumes that gcc always generates static function names in a specific
format, which is not necessarily true.
Simply make these functions global and asmlinkage or __visible. This way the
static __used variables are not needed and everything works.
Functions with arguments are __visible to keep the register calling
convention on 32bit.
Changed in paravirt and in all users (Xen and vsmp)
v2: Use __visible for functions with arguments
Cc: Ido Yariv <ido@wizery.com>
Link: http://lkml.kernel.org/r/1382458079-24450-5-git-send-email-andi@firstfloor.org
We also optimize one - the TLB flush. The native operation would
needlessly IPI offline VCPUs causing extra wakeups. Using the
Xen one avoids that and lets the hypervisor determine which
VCPU needs the TLB flush.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
.. which are surprisingly small compared to the amount for PV code.
PVH uses mostly native mmu ops, we leave the generic (native_*) for
the majority and just overwrite the baremetal with the ones we need.
At startup, we are running with pre-allocated page-tables
courtesy of the tool-stack. But we still need to graft them
in the Linux initial pagetables. However there is no need to
unpin/pin and change them to R/O or R/W.
Note that the xen_pagetable_init due to 7836fec9d0994cc9c9150c5a33f0eb0eb08a335a
"xen/mmu/p2m: Refactor the xen_pagetable_init code." does not
need any changes - we just need to make sure that xen_post_allocator_init
does not alter the pvops from the default native one.
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Stefano noticed that the code runs only under 64-bit so
the comments about 32-bit are pointless.
Also we change the condition for xen_revector_p2m_tree
returning the same value (because it could not allocate
a swath of space to put the new P2M in) or it had been
called once already. In such we return early from the
function.
The revectoring and copying of the P2M only happens when
!auto-xlat and on 64-bit builds. It is not obvious from
the code, so lets have seperate 32 and 64-bit functions.
We also invert the check for auto-xlat to make the code
flow simpler.
Suggested-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Pull Xen updates from Konrad Rzeszutek Wilk:
"This has tons of fixes and two major features which are concentrated
around the Xen SWIOTLB library.
The short <blurb> is that the tracing facility (just one function) has
been added to SWIOTLB to make it easier to track I/O progress.
Additionally under Xen and ARM (32 & 64) the Xen-SWIOTLB driver
"is used to translate physical to machine and machine to physical
addresses of foreign[guest] pages for DMA operations" (Stefano) when
booting under hardware without proper IOMMU.
There are also bug-fixes, cleanups, compile warning fixes, etc.
The commit times for some of the commits is a bit fresh - that is b/c
we wanted to make sure we have the Ack's from the ARM folks - which
with the string of back-to-back conferences took a bit of time. Rest
assured - the code has been stewing in #linux-next for some time.
Features:
- SWIOTLB has tracing added when doing bounce buffer.
- Xen ARM/ARM64 can use Xen-SWIOTLB. This work allows Linux to
safely program real devices for DMA operations when running as a
guest on Xen on ARM, without IOMMU support. [*1]
- xen_raw_printk works with PVHVM guests if needed.
Bug-fixes:
- Make memory ballooning work under HVM with large MMIO region.
- Inform hypervisor of MCFG regions found in ACPI DSDT.
- Remove deprecated IRQF_DISABLED.
- Remove deprecated __cpuinit.
[*1]:
"On arm and arm64 all Xen guests, including dom0, run with second
stage translation enabled. As a consequence when dom0 programs a
device for a DMA operation is going to use (pseudo) physical
addresses instead machine addresses. This work introduces two trees
to track physical to machine and machine to physical mappings of
foreign pages. Local pages are assumed mapped 1:1 (physical address
== machine address). It enables the SWIOTLB-Xen driver on ARM and
ARM64, so that Linux can translate physical addresses to machine
addresses for dma operations when necessary. " (Stefano)"
* tag 'stable/for-linus-3.13-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (32 commits)
xen/arm: pfn_to_mfn and mfn_to_pfn return the argument if nothing is in the p2m
arm,arm64/include/asm/io.h: define struct bio_vec
swiotlb-xen: missing include dma-direction.h
pci-swiotlb-xen: call pci_request_acs only ifdef CONFIG_PCI
arm: make SWIOTLB available
xen: delete new instances of added __cpuinit
xen/balloon: Set balloon's initial state to number of existing RAM pages
xen/mcfg: Call PHYSDEVOP_pci_mmcfg_reserved for MCFG areas.
xen: remove deprecated IRQF_DISABLED
x86/xen: remove deprecated IRQF_DISABLED
swiotlb-xen: fix error code returned by xen_swiotlb_map_sg_attrs
swiotlb-xen: static inline xen_phys_to_bus, xen_bus_to_phys, xen_virt_to_bus and range_straddles_page_boundary
grant-table: call set_phys_to_machine after mapping grant refs
arm,arm64: do not always merge biovec if we are running on Xen
swiotlb: print a warning when the swiotlb is full
swiotlb-xen: use xen_dma_map/unmap_page, xen_dma_sync_single_for_cpu/device
xen: introduce xen_dma_map/unmap_page and xen_dma_sync_single_for_cpu/device
tracing/events: Fix swiotlb tracepoint creation
swiotlb-xen: use xen_alloc/free_coherent_pages
xen: introduce xen_alloc/free_coherent_pages
If split page table lock is in use, we embed the lock into struct page
of table's page. We have to disable split lock, if spinlock_t is too
big be to be embedded, like when DEBUG_SPINLOCK or DEBUG_LOCK_ALLOC
enabled.
This patch add support for dynamic allocation of split page table lock
if we can't embed it to struct page.
page->ptl is unsigned long now and we use it as spinlock_t if
sizeof(spinlock_t) <= sizeof(long), otherwise it's pointer to spinlock_t.
The spinlock_t allocated in pgtable_page_ctor() for PTE table and in
pgtable_pmd_page_ctor() for PMD table. All other helpers converted to
support dynamically allocated page->ptl.
Reviewed-by: Peter Zijlstra <peterz@infradead.org>
We're going to introduce split page table lock for PMD level. Let's
rename existing split ptlock for PTE level to avoid confusion.
Tested-by: Alex Thorlton <athorlton@sgi.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Eric W . Biederman" <ebiederm@xmission.com>
Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Robin Holt <robinmholt@gmail.com>
Cc: Sedat Dilek <sedat.dilek@gmail.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
* stefano/swiotlb-xen-9.1:
arm64/xen: get_dma_ops: return xen_dma_ops if we are running as xen_initial_domain
arm/xen: get_dma_ops: return xen_dma_ops if we are running as xen_initial_domain
swiotlb-xen: introduce xen_swiotlb_set_dma_mask
xen/arm,arm64: enable SWIOTLB_XEN
xen: make xen_create_contiguous_region return the dma address
xen/x86: allow __set_phys_to_machine for autotranslate guests
arm/xen,arm64/xen: introduce p2m
arm64: define DMA_ERROR_CODE
arch/arm/include/asm/dma-mapping.h
drivers/xen/swiotlb-xen.c
[Conflicts arose b/c "arm: make SWIOTLB available" v8 was in Stefano's
branch, while I had v9 + Ack from Russel. I also fixed up white-space
issues]
Use xen_alloc_coherent_pages and xen_free_coherent_pages to allocate or
free coherent pages.
We need to be careful handling the pointer returned by
xen_alloc_coherent_pages, because on ARM the pointer is not equal to
phys_to_virt(*dma_handle). In fact virt_to_phys only works for kernel
direct mapped RAM memory.
In ARM case the pointer could be an ioremap address, therefore passing
it to virt_to_phys would give you another physical address that doesn't
correspond to it.
Make xen_create_contiguous_region take a phys_addr_t as start parameter to
avoid the virt_to_phys calls which would be incorrect.
Changes in v6:
- remove extra spaces.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Modify xen_create_contiguous_region to return the dma address of the
newly contiguous buffer.
Changes in v4:
- use virt_to_machine instead of virt_to_bus.
Jan Beulich spotted that the PAT MSR settings in the Xen public
document that "the first (PAT6) column was wrong across the
board, and the column for PAT7 was missing altogether."
This updates it to be in sync.
CC: Jan Beulich <jbeulich@suse.com>
Acked-by: Jan Beulich <jbeulich@suse.com>
Pull perparatory x86 kasrl changes from Ingo Molnar:
"This contains changes from the ongoing KASLR work, by Kees Cook.
The main changes are the use of a read-only IDT on x86 (which
decouples the userspace visible virtual IDT address from the physical
address), and a rework of ELF relocation support, in preparation of
random, boot-time kernel image relocation."
* 'x86-kaslr-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, relocs: Refactor the relocs tool to merge 32- and 64-bit ELF
x86, relocs: Build separate 32/64-bit tools
x86, relocs: Add 64-bit ELF support to relocs tool
x86, relocs: Consolidate processing logic
x86, relocs: Generalize ELF structure names
x86: Use a read-only IDT alias on all CPUs
Pull x86 fixes from Ingo Molnar:
"Misc fixes"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mm: Flush lazy MMU when DEBUG_PAGEALLOC is set
x86/mm/cpa/selftest: Fix false positive in CPA self test
x86/mm/cpa: Convert noop to functional fix
x86, mm: Patch out arch_flush_lazy_mmu_mode() when running on bare metal
x86, mm, paravirt: Fix vmalloc_fault oops during lazy MMU updates
Make a copy of the IDT (as seen via the "sidt" instruction) read-only.
This primarily removes the IDT from being a target for arbitrary memory
write attacks, and has the added benefit of also not leaking the kernel
base offset, if it has been relocated.
We already did this on vendor == Intel and family == 5 because of the
F0 0F bug -- regardless of if a particular CPU had the F0 0F bug or
not. Since the workaround was so cheap, there simply was no reason to
be very specific. This patch extends the readonly alias to all CPUs,
but does not activate the #PF to #UD conversion code needed to deliver
the proper exception in the F0 0F case except on Intel family 5
processors.
Link: http://lkml.kernel.org/r/20130410192422.GA17344@www.outflux.net
Cc: Eric Northup <digitaleric@google.com>
Invoking arch_flush_lazy_mmu_mode() results in calls to
preempt_enable()/disable() which may have performance impact.
Since lazy MMU is not used on bare metal we can patch away
arch_flush_lazy_mmu_mode() so that it is never called in such
environment.
[ hpa: the previous patch "Fix vmalloc_fault oops during lazy MMU
updates" may cause a minor performance regression on
bare metal. This patch resolves that performance regression. It is
somewhat unclear to me if this is a good -stable candidate. ]
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Link: http://lkml.kernel.org/r/1364045796-10720-2-git-send-email-konrad.wilk@oracle.com
Tested-by: Josh Boyer <jwboyer@redhat.com>
Acked-by: Borislav Petkov <bp@suse.de>
Cc: <stable@vger.kernel.org> SEE NOTE ABOVE
provided pagetables.
Occassionaly on a DL380 G4 the guest would crash quite early with this:
(XEN) d244:v0: unhandled page fault (ec=0003)
(XEN) Pagetable walk from ffffffff84dc7000:
(XEN) L4[0x1ff] = 00000000c3f18067 0000000000001789
(XEN) L3[0x1fe] = 00000000c3f14067 000000000000178d
(XEN) L2[0x026] = 00000000dc8b2067 0000000000004def
(XEN) L1[0x1c7] = 00100000dc8da067 0000000000004dc7
(XEN) domain_crash_sync called from entry.S
(XEN) Domain 244 (vcpu#0) crashed on cpu#3:
(XEN) ----[ Xen-4.1.3OVM x86_64 debug=n Not tainted ]----
(XEN) CPU: 3
(XEN) RIP: e033:[<ffffffff81263f22>]
(XEN) RFLAGS: 0000000000000216 EM: 1 CONTEXT: pv guest
(XEN) rax: 0000000000000000 rbx: ffffffff81785f88 rcx: 000000000000003f
(XEN) rdx: 0000000000000000 rsi: 00000000dc8da063 rdi: ffffffff84dc7000
The offending code shows it to be a loop writting the value zero
(%rax) in the %rdi (the L4 provided by Xen) register:
0: 44 00 00 add %r8b,(%rax)
3: 31 c0 xor %eax,%eax
5: b9 40 00 00 00 mov $0x40,%ecx
a: 66 0f 1f 84 00 00 00 nopw 0x0(%rax,%rax,1)
11: 00 00
13: ff c9 dec %ecx
15:* 48 89 07 mov %rax,(%rdi) <-- trapping instruction
18: 48 89 47 08 mov %rax,0x8(%rdi)
1c: 48 89 47 10 mov %rax,0x10(%rdi)
which fails. xen_setup_kernel_pagetable recycles some of the Xen's
page-table entries when it has switched over to its Linux page-tables.
Right before try to clear the page, we make a hypercall to change
it from _RO to _RW and that works (otherwise we would hit an BUG()).
And the _RW flag is set for that page:
(XEN) L1[0x1c7] = 001000004885f067 0000000000004dc7
The error code is 3, so PFEC_page_present and PFEC_write_access, so page is
present (correct), and we tried to write to the page, but a violation
occurred. The one theory is that the the page entries in hardware
(which are cached) are not up to date with what we just set. Especially
as we have just done an CR3 write and flushed the multicalls.
This patch does solve the problem by flusing out the TLB page
entry after changing it from _RO to _RW and we don't hit this
issue anymore.
Fixed-Oracle-Bug: 16243091 [ON OCCASIONS VM START GOES INTO
'CRASH' STATE: CLEAR_PAGE+0X12 ON HP DL380 G4]
Reported-and-Tested-by: Saar Maoz <Saar.Maoz@oracle.com>
We move the setting of write_cr3 from the early bootup variant
(see git commit 0cc9129d75ef8993702d97ab0e49542c15ac6ab9
"x86-64, xen, mmu: Provide an early version of write_cr3.")
to a more appropiate location.
This new location sets all of the other non-early variants
of pvops calls - and most importantly is before the
alternative_asm mechanism kicks in.
With commit 8170e6bed465 ("x86, 64bit: Use a #PF handler to materialize
early mappings on demand") we started hitting an early bootup crash
where the Xen hypervisor would inform us that:
(XEN) d7:v0: unhandled page fault (ec=0000)
(XEN) Pagetable walk from ffffea000005b2d0:
(XEN) L4[0x1d4] = 0000000000000000 ffffffffffffffff
(XEN) Domain 7 (vcpu#0) crashed on cpu#3:
(XEN) ----[ Xen-4.2.0 x86_64 debug=n Not tainted ]----
.. that Xen was unable to context switch back to dom0.
Looking at the calling stack we find:
[<ffffffff8103feba>] xen_get_user_pgd+0x5a <--
[<ffffffff81042d27>] xen_write_cr3+0x77
[<ffffffff81ad2d21>] init_mem_mapping+0x1f9
[<ffffffff81ac293f>] setup_arch+0x742
[<ffffffff81666d71>] printk+0x48
We are trying to figure out whether we need to up-date the user PGD as
well. Please keep in mind that under 64-bit PV guests we have a limited
amount of rings: 0 for the Hypervisor, and 1 for both the Linux kernel
and user-space. As such the Linux pvops'fied version of write_cr3
checks if it has to update the user-space cr3 as well.
That clearly is not needed during early bootup. The recent changes (see
above git commit) streamline the x86 page table allocation to be much
simpler (And also incidentally the #PF handler ends up in spirit being
similar to how the Xen toolstack sets up the initial page-tables).
The fix is to have an early-bootup version of cr3 that just loads the
kernel %cr3. The later version - which also handles user-page
modifications will be used after the initial page tables have been
setup.
[ hpa: removed a redundant #ifdef and made the new function __init.
Also note that x86-32 already has such an early xen_write_cr3. ]
Tested-by: "H. Peter Anvin" <hpa@zytor.com>
Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/1361579812-23709-1-git-send-email-konrad.wilk@oracle.com
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Coming patches to x86/mm2 require the changes and advanced baseline in
x86/boot.
Resolved Conflicts:
arch/x86/kernel/setup.c
mm/nobootmem.c
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
- Add necessary infrastructure to make balloon driver work under ARM.
- Add /dev/xen/privcmd interfaces to work with ARM and PVH.
- Improve Xen PCIBack wild-card parsing.
- Add Xen ACPI PAD (Processor Aggregator) support - so can offline/
online sockets depending on the power consumption.
- PVHVM + kexec = use an E820_RESV region for the shared region so we
don't overwrite said region during kexec reboot.
- Cleanups, compile fixes.
Fix up some trivial conflicts due to the balloon driver now working on
ARM, and there were changes next to the previous work-arounds that are
now gone.
* tag 'stable/for-linus-3.8-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/PVonHVM: fix compile warning in init_hvm_pv_info
xen: arm: implement remap interfaces needed for privcmd mappings.
xen: correctly use xen_pfn_t in remap_domain_mfn_range.
xen: arm: enable balloon driver
xen: balloon: allow PVMMU interfaces to be compiled out
xen: privcmd: support autotranslated physmap guests.
xen: add pages parameter to xen_remap_domain_mfn_range
xen/acpi: Move the xen_running_on_version_or_later function.
xen/xenbus: Remove duplicate inclusion of asm/xen/hypervisor.h
xen/acpi: Fix compile error by missing decleration for xen_domain.
xen/acpi: revert pad config check in xen_check_mwait
xen/acpi: ACPI PAD driver
xen-pciback: reject out of range inputs
xen-pciback: simplify and tighten parsing of device IDs
xen PVonHVM: use E820_Reserved area for shared_info
For Xen on ARM a PFN is 64 bits so we need to use the appropriate
type here.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
[v2: include the necessary header,
Reported-by: Fengguang Wu <fengguang.wu@intel.com> ]
Also introduce xen_unmap_domain_mfn_range. These are the parts of
Mukesh's "xen/pvh: Implement MMU changes for PVH" which are also
needed as a baseline for ARM privcmd support.
The original patch was:
This derivative is also:
