commit f611f2da99420abc973c32cdbddbf5c365d0a20c upstream.
The patches missed an indirect use of IRQF_NO_SUSPEND pulled in via
IRQF_TIMER. The following patch fixes the issue.
With this fixlet PV guest migration works just fine. I also booted the
entire series as a dom0 kernel and it appeared fine.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit e7a3481c0246c8e45e79c629efd63b168e91fcda upstream.
If the guest domain has been suspend/resumed or migrated, then the
system clock backing the pvclock clocksource may revert to a smaller
value (ie, can be non-monotonic across the migration/save-restore).
Make sure we zero last_value in that case so that the domain
continues to see clock updates.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
commit 8a22b9996b001c88f2bfb54c6de6a05fc39e177a upstream.
xen_sched_clock only counts unstolen time. In principle this should
be useful to the Linux scheduler so that it knows how much time a process
actually consumed. But in practice this doesn't work very well as the
scheduler expects the sched_clock time to be synchronized between
cpus. It also uses sched_clock to measure the time a task spends
sleeping, in which case "unstolen time" isn't meaningful.
So just use plain xen_clocksource_read to return wallclock nanoseconds
for sched_clock.
commit f350c7922faad3397c98c81a9e5658f5a1ef0214 upstream.
Otherwise the timer is disabled by dpm_suspend_noirq() which in turn prevents
correct operation of stop_machine on multi-processor systems and breaks
suspend.
commit be012920ecba161ad20303a3f6d9e96c58cf97c7 upstream.
This is necessary to ensure the runstate area is available to
xen_sched_clock before any calls to printk which will require it in
order to provide a timestamp.
I chose to pull the xen_setup_runstate_info out of xen_time_init into
the caller in order to maintain parity with calling
xen_setup_runstate_info separately from calling xen_time_resume.
Pass clocksource pointer to the read() callback for clocksources. This
allows us to share the callback between multiple instances.
[hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods]
[akpm@linux-foundation.org: cleanup]
Signed-off-by: Magnus Damm <damm@igel.co.jp>
Acked-by: John Stultz <johnstul@us.ibm.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
* 'cputime' of git://git390.osdl.marist.edu/pub/scm/linux-2.6:
[PATCH] fast vdso implementation for CLOCK_THREAD_CPUTIME_ID
[PATCH] improve idle cputime accounting
[PATCH] improve precision of idle time detection.
[PATCH] improve precision of process accounting.
[PATCH] idle cputime accounting
[PATCH] fix scaled & unscaled cputime accounting
The cpu time spent by the idle process actually doing something is
currently accounted as idle time. This is plain wrong, the architectures
that support VIRT_CPU_ACCOUNTING=y can do better: distinguish between the
time spent doing nothing and the time spent by idle doing work. The first
is accounted with account_idle_time and the second with account_system_time.
The architectures that use the account_xxx_time interface directly and not
the account_xxx_ticks interface now need to do the check for the idle
process in their arch code. In particular to improve the system vs true
idle time accounting the arch code needs to measure the true idle time
instead of just testing for the idle process.
To improve the tick based accounting as well we would need an architecture
primitive that can tell us if the pt_regs of the interrupted context
points to the magic instruction that halts the cpu.
In addition idle time is no more added to the stime of the idle process.
This field now contains the system time of the idle process as it should
be. On systems without VIRT_CPU_ACCOUNTING this will always be zero as
every tick that occurs while idle is running will be accounted as idle
time.
This patch contains the necessary common code changes to be able to
distinguish idle system time and true idle time. The architectures with
support for VIRT_CPU_ACCOUNTING need some changes to exploit this.
Impact: change calling convention of existing clock_event APIs
struct clock_event_timer's cpumask field gets changed to take pointer,
as does the ->broadcast function.
Another single-patch change. For safety, we BUG_ON() in
clockevents_register_device() if it's not set.
KVM intends to use paravirt code to calibrate khz. Xen
current code will do just fine. So as a first step, factor out
code to pvclock.c.
Signed-off-by: Glauber Costa <gcosta@redhat.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
Note the changes from 2.6.18-xen CPU hotplugging:
A vcpu_down request from the remote admin via Xenbus both hotunplugs the
CPU, and disables it by removing it from the cpu_present map, and removing
its entry in /sys.
A vcpu_up request from the remote admin only re-enables the CPU, and does
not immediately bring the CPU up. A udev event is emitted, which can be
caught by the user if he wishes to automatically re-up CPUs when available,
or implement a more complex policy.
Signed-off-by: Alex Nixon <alex.nixon@citrix.com>
Acked-by: Jeremy Fitzhardinge <jeremy@goop.org>
Ingo Molnar wrote:
> -tip testing found this build failure:
> arch/x86/xen/spinlock.c: In function ‘spin_time_start’:
> arch/x86/xen/spinlock.c:60: error: implicit declaration of function ‘xen_clocksource_read’
> i've excluded these new commits for now from tip/master - could you
> please send a delta fix against tip/x86/xen?
Make xen_clocksource_read non-static.
Rename the paravirtualized calculate_cpu_khz to calibrate_tsc.
In all cases, we actually calibrate_tsc and use that as the cpu_khz value.
Signed-off-by: Alok N Kataria <akataria@vmware.com>
Signed-off-by: Dan Hecht <dhecht@vmware.com>
Cc: Dan Hecht <dhecht@vmware.com>
arch/x86/xen/enlighten.c
arch/x86/xen/mmu.c
This patch updates the xen guest to use the pvclock structs
and helper functions.
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
We have a few instances of the open-coded iterative div/mod loop, used
when we don't expcet the dividend to be much bigger than the divisor.
Unfortunately modern gcc's have the tendency to strength "reduce" this
into a full mod operation, which isn't necessarily any faster, and
even if it were, doesn't exist if gcc implements it in libgcc.
The workaround is to put a dummy asm statement in the loop to prevent
gcc from performing the transformation.
This patch creates a single implementation of this loop, and uses it
to replace the open-coded versions I know about.
Cc: john stultz <johnstul@us.ibm.com>
Cc: Segher Boessenkool <segher@kernel.crashing.org>
Cc: Christian Kujau <lists@nerdbynature.de>
Cc: Robert Hancock <hancockr@shaw.ca>
On resume, the vcpu timer modes will not be restored. The timer
infrastructure doesn't do this for us, since it assumes the cpus
are offline. We can just poke the other vcpus into the right mode
directly though.
Hook into the device model to make sure that timekeeping's resume handler
is called. This deals with our clocksource's non-monotonicity over the
save/restore. Explicitly call clock_has_changed() to make sure that
all the timers get retriggered properly.
This patch implements Xen save/restore and migration.
Saving is triggered via xenbus, which is polled in
drivers/xen/manage.c. When a suspend request comes in, the kernel
prepares itself for saving by:
1 - Freeze all processes. This is primarily to prevent any
partially-completed pagetable updates from confusing the suspend
process. If CONFIG_PREEMPT isn't defined, then this isn't necessary.
2 - Suspend xenbus and other devices
3 - Stop_machine, to make sure all the other vcpus are quiescent. The
Xen tools require the domain to run its save off vcpu0.
4 - Within the stop_machine state, it pins any unpinned pgds (under
construction or destruction), performs canonicalizes various other
pieces of state (mostly converting mfns to pfns), and finally
5 - Suspend the domain
Restore reverses the steps used to save the domain, ending when all
the frozen processes are thawed.
Use xen_khz to denote xen_specific clock speed. Avoid shadowing
cpu_khz.
arch/x86/xen/time.c:220:6: warning: symbol 'cpu_khz' shadows an earlier one
include/asm/tsc.h:17:21: originally declared here
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Fix from: Ian Campbell <ijc@hellion.org.uk>
Signed-off-by: Andi Kleen <ak@suse.de>
When sending a call-function IPI to a vcpu, yield if the vcpu isn't
running.
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
