path: root/arch/x86/xen/xen-asm.S
2008-04-24xen: fold xen_sysexit into xen_iretJeremy Fitzhardinge
xen_sysexit and xen_iret were doing essentially the same thing. Rather than having a separate implementation for xen_sysexit, we can just strip the stack back to an iret frame and jump into xen_iret. This removes a lot of code and complexity - specifically, another critical region. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24xen: jump to iret fixupJeremy Fitzhardinge
Use jmp rather than call for the iret fixup, so its consistent with the sysexit fixup, and it simplifies the stack (which is already complex). Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24xen: support sysenter/sysexit if hypervisor doesJeremy Fitzhardinge
64-bit Xen supports sysenter for 32-bit guests, so support its use. (sysenter is faster than int $0x80 in 32-on-64.) sysexit is still not supported, so we fake it up using iret. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24xen: make sure iret faults are trappedJeremy Fitzhardinge
2008-04-17xen: use iret instruction all the timeJeremy Fitzhardinge
Change iret implementation to not be dependent on direct-access vcpu structure. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-27xen: fix RMW when unmasking eventsJeremy Fitzhardinge
xen_irq_enable_direct and xen_sysexit were using "andw $0x00ff, XEN_vcpu_info_pending(vcpu)" to unmask events and test for pending ones in one instuction. Unfortunately, the pending flag must be modified with a locked operation since it can be set by another CPU, and the unlocked form of this operation was causing the pending flag to get lost, allowing the processor to return to usermode with pending events and ultimately deadlock. The simple fix would be to make it a locked operation, but that's rather costly and unnecessary. The fix here is to split the mask-clearing and pending-testing into two instructions; the interrupt window between them is of no concern because either way pending or new events will be processed. This should fix lingering bugs in using direct vcpu structure access too. [ Stable: needed in 2.6.24.x ] Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Stable <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-11i386: move xenThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
