Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
commit 7e8213c1f3acc064aef37813a39f13cbfe7c3ce7 upstream.
code32_start should point at the start of the protected mode code, and
*not* at the beginning of the bzImage. This is much easier to do in
assembly so document that callers of make_boot_params() need to fill out
code32_start.
The fallout from this bug is that we would end up relocating the image
but copying the image at some offset, resulting in what appeared to be
memory corruption.
Reported-by: Thomas Bächler <thomas@archlinux.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
commit b3b42ac2cbae1f3cecbb6229964a4d48af31d382 upstream.
The IRET instruction, when returning to a 16-bit segment, only
restores the bottom 16 bits of the user space stack pointer. We have
a software workaround for that ("espfix") for the 32-bit kernel, but
it relies on a nonzero stack segment base which is not available in
32-bit mode.
Since 16-bit support is somewhat crippled anyway on a 64-bit kernel
(no V86 mode), and most (if not quite all) 64-bit processors support
virtualization for the users who really need it, simply reject
attempts at creating a 16-bit segment when running on top of a 64-bit
kernel.
Link: http://lkml.kernel.org/n/tip-kicdm89kzw9lldryb1br9od0@git.kernel.org
commit 12729f14d8357fb845d75155228b21e76360272d upstream.
If a failure occurs while modifying ftrace function, it bails out and will
remove the tracepoints to be back to what the code originally was.
There is missing the final sync run across the CPUs after the fix up is done
and before the ftrace int3 handler flag is reset.
Here's the description of the problem:
CPU0 CPU1
remove_breakpoint();
modifying_ftrace_code = 0;
[still sees breakpoint]
<takes trap>
[sees modifying_ftrace_code as zero]
[no breakpoint handler]
[goto failed case]
[trap exception - kernel breakpoint, no
handler]
BUG()
Link: http://lkml.kernel.org/r/1393258342-29978-2-git-send-email-pmladek@suse.cz
Fixes: 8a4d0a687a5 "ftrace: Use breakpoint method to update ftrace caller"
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
Signed-off-by: Petr Mladek <pmladek@suse.cz>
A number of situations currently require the heavyweight smp_mb(),
even though there is no need to order prior stores against later
loads. Many architectures have much cheaper ways to handle these
situations, but the Linux kernel currently has no portable way
to make use of them.
This commit therefore supplies smp_load_acquire() and
smp_store_release() to remedy this situation. The new
smp_load_acquire() primitive orders the specified load against
any subsequent reads or writes, while the new smp_store_release()
primitive orders the specifed store against any prior reads or
writes. These primitives allow array-based circular FIFOs to be
implemented without an smp_mb(), and also allow a theoretical
hole in rcu_assign_pointer() to be closed at no additional
expense on most architectures.
In addition, the RCU experience transitioning from explicit
smp_read_barrier_depends() and smp_wmb() to rcu_dereference()
and rcu_assign_pointer(), respectively resulted in substantial
improvements in readability. It therefore seems likely that
replacing other explicit barriers with smp_load_acquire() and
smp_store_release() will provide similar benefits. It appears
that roughly half of the explicit barriers in core kernel code
might be so replaced.
[Changelog by PaulMck]
(cherry picked from commit 47933ad41a86a4a9b50bed7c9b9bd2ba242aac63)
Reviewed-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Michael Ellerman <michael@ellerman.id.au>
Cc: Michael Neuling <mikey@neuling.org>
Cc: Victor Kaplansky <VICTORK@il.ibm.com>
Link: http://lkml.kernel.org/r/20131213150640.908486364@infradead.org
We've switched over every architecture that supports SMP to it, so
remove the new useless config variable.
arch/arm/Kconfig
block/blk-mq.c
Change-Id: Ic19c3ac07a38a1636d6aa2fed5e55a58833f9b2c
Cc: Jan Kara <jack@suse.cz>
(cherry picked from commit 0a06ff068f1255bcd7965ab07bc0f4adc3eb639a)
Use more appropriate NUMA_NO_NODE instead of -1 in all archs' module_alloc()
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Acked-by: David Rientjes <rientjes@google.com>
(cherry picked from commit 40c3baa7c66f1352521378ee83509fb8f4c465de)
arch/x86/ia32/ia32_signal.c
Change-Id: I701cb58fffb756a2d29e7c828728d149c35e6c6a
(cherry picked from commit ce3959604878c1c693979ec552069dc8bdb5ccde)
All arches do essentially the same thing now for
early_init_dt_setup_initrd_arch, so it can now be removed.
arch/arm/mm/init.c
arch/c6x/kernel/devicetree.c
arch/powerpc/kernel/prom.c
(cherry picked from commit 29eb45a9ab4839a1e9cef2bcf369b918c9c4fcad)
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: x86@kernel.org
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Acked-by: Grant Likely <grant.likely@linaro.org>
Change-Id: I84b59cec16fa7e96fa8ff3de04aa959f7039a7a9
In order to prepare to per-arch implementations of preempt_count move
the required bits into an asm-generic header and use this for all
archs.
(cherry picked from commit a787870924dbd6f321661e06d4ec1c7a408c9ccf)
arch/c6x/include/asm/Kbuild
arch/cris/include/asm/Kbuild
arch/h8300/include/asm/Kbuild
arch/ia64/include/asm/Kbuild
arch/mips/include/asm/Kbuild
arch/openrisc/include/asm/Kbuild
arch/powerpc/include/asm/Kbuild
arch/score/include/asm/Kbuild
include/linux/preempt.h
Change-Id: I544914d3c23cc50da658296a34f9f2796854e259
Link: http://lkml.kernel.org/n/tip-h5j0c1r3e3fk015m30h8f1zx@git.kernel.org
On some PAE architectures, the entire range of physical memory could reside
outside the 32-bit limit. These systems need the ability to specify the
initrd location using 64-bit numbers.
This patch globally modifies the early_init_dt_setup_initrd_arch() function to
use 64-bit numbers instead of the current unsigned long.
There has been quite a bit of debate about whether to use u64 or phys_addr_t.
It was concluded to stick to u64 to be consistent with rest of the device
tree code. As summarized by Geert, "The address to load the initrd is decided
by the bootloader/user and set at that point later in time. The dtb should not
be tied to the kernel you are booting"
More details on the discussion can be found here:
https://lkml.org/lkml/2013/6/20/690
https://lkml.org/lkml/2012/9/13/544
(cherry picked from commit 374d5c9964c10373ba39bbe934f4262eb87d7114)
Change-Id: Iab36378e1de4e6c2cb07a3b88aeb5ff4afbe535b
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Signed-off-by: Grant Likely <grant.likely@linaro.org>
commit 6f8a1b335fde143b7407036e2368d3cd6eb55674 upstream.
Commit 03bbcb2e7e2 (iommu/vt-d: add quirk for broken interrupt
remapping on 55XX chipsets) properly disables irq remapping on the
5500/5520 chipsets that don't correctly perform that feature.
However, when I wrote it, I followed the errata sheet linked in that
commit too closely, and explicitly tied the activation of the quirk to
revision 0x13 of the chip, under the assumption that earlier revisions
were not in the field. Recently a system was reported to be suffering
from this remap bug and the quirk hadn't triggered, because the
revision id register read at a lower value that 0x13, so the quirk
test failed improperly. Given this, it seems only prudent to adjust
this quirk so that any revision less than 0x13 has the quirk asserted.
[ tglx: Removed the 0x12 comparison of pci id 3405 as this is covered
by the <= 0x13 check already ]
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Cc: x86@kernel.org
Link: http://lkml.kernel.org/r/1394649873-14913-1-git-send-email-nhorman@tuxdriver.com
commit 8ceee72808d1ae3fb191284afc2257a2be964725 upstream.
The GHASH setkey() function uses SSE registers but fails to call
kernel_fpu_begin()/kernel_fpu_end(). Instead of adding these calls, and
then having to deal with the restriction that they cannot be called from
interrupt context, move the setkey() implementation to the C domain.
Note that setkey() does not use any particular SSE features and is not
expected to become a performance bottleneck.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Fixes: 0e1227d356e9b (crypto: ghash - Add PCLMULQDQ accelerated implementation)
commit 825600c0f20e595daaa7a6dd8970f84fa2a2ee57 upstream.
On x86 uniprocessor systems topology_physical_package_id() returns -1
which causes rapl_cpu_prepare() to leave rapl_pmu variable uninitialized
which leads to GPF in rapl_pmu_init().
See arch/x86/kernel/cpu/perf_event_intel_rapl.c.
It turns out that physical_package_id and core_id can actually be
retreived for uniprocessor systems too. Enabling them also fixes
rapl_pmu code.
Signed-off-by: Artem Fetishev <artem_fetishev@epam.com>
Cc: Stephane Eranian <eranian@google.com>
commit 26a865f4aa8e66a6d94958de7656f7f1b03c6c56 upstream.
After free_loaded_vmcs executes, the "loaded_vmcs" structure
is kfreed, and now vmx->loaded_vmcs points to a kfreed area.
Subsequent free_loaded_vmcs then attempts to manipulate
vmx->loaded_vmcs.
Switch the order to avoid the problem.
https://bugzilla.redhat.com/show_bug.cgi?id=1047892
Reviewed-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
commit 37f6a4e237303549c8676dfe1fd1991ceab512eb upstream.
Rom Freiman <rom@stratoscale.com> notes other code paths vulnerable to
bug fixed by 989c6b34f6a9480e397b.
commit 989c6b34f6a9480e397b170cc62237e89bf4fdb9 upstream.
It is possible for __direct_map to be called on invalid root_hpa
(-1), two examples:
1) try_async_pf -> can_do_async_pf
-> vmx_interrupt_allowed -> nested_vmx_vmexit
2) vmx_handle_exit -> vmx_interrupt_allowed -> nested_vmx_vmexit
Then to load_vmcs12_host_state and kvm_mmu_reset_context.
Check for this possibility, let fault exception be regenerated.
BZ: https://bugzilla.redhat.com/show_bug.cgi?id=924916
commit fdfaf64e75397567257e1051931f9a3377360665 upstream.
Commit a998d4342337 claimed to introduce negative offset support to x86 jit,
but it couldn't be working, since at the time of the execution
of LD+ABS or LD+IND instructions via call into
bpf_internal_load_pointer_neg_helper() the %edx (3rd argument of this func)
had junk value instead of access size in bytes (1 or 2 or 4).
Store size into %edx instead of %ecx (what original commit intended to do)
Fixes: a998d4342337 ("bpf jit: Let the x86 jit handle negative offsets")
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Cc: Jan Seiffert <kaffeemonster@googlemail.com>
Cc: Eric Dumazet <edumazet@google.com>
commit 731bd6a93a6e9172094a2322bd0ee964bb1f4d63 upstream.
For non-eager fpu mode, thread's fpu state is allocated during the first
fpu usage (in the context of device not available exception). This
(math_state_restore()) can be a blocking call and hence we enable
interrupts (which were originally disabled when the exception happened),
allocate memory and disable interrupts etc.
But the eager-fpu mode, call's the same math_state_restore() from
kernel_fpu_end(). The assumption being that tsk_used_math() is always
set for the eager-fpu mode and thus avoid the code path of enabling
interrupts, allocating fpu state using blocking call and disable
interrupts etc.
But the below issue was noticed by Maarten Baert, Nate Eldredge and
few others:
If a user process dumps core on an ecrypt fs while aesni-intel is loaded,
we get a BUG() in __find_get_block() complaining that it was called with
interrupts disabled; then all further accesses to our ecrypt fs hang
and we have to reboot.
The aesni-intel code (encrypting the core file that we are writing) needs
the FPU and quite properly wraps its code in kernel_fpu_{begin,end}(),
the latter of which calls math_state_restore(). So after kernel_fpu_end(),
interrupts may be disabled, which nobody seems to expect, and they stay
that way until we eventually get to __find_get_block() which barfs.
For eager fpu, most the time, tsk_used_math() is true. At few instances
during thread exit, signal return handling etc, tsk_used_math() might
be false.
In kernel_fpu_end(), for eager-fpu, call math_state_restore()
only if tsk_used_math() is set. Otherwise, don't bother. Kernel code
path which cleared tsk_used_math() knows what needs to be done
with the fpu state.
Reported-by: Maarten Baert <maarten-baert@hotmail.com>
Reported-by: Nate Eldredge <nate@thatsmathematics.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Suresh Siddha <sbsiddha@gmail.com>
Link: http://lkml.kernel.org/r/1391410583.3801.6.camel@europa
Cc: George Spelvin <linux@horizon.com>
commit 596f3142d2b7be307a1652d59e7b93adab918437 upstream.
We always disable cr8 intercept in its handler, but only re-enable it
if handling KVM_REQ_EVENT, so there can be a window where we do not
intercept cr8 writes, which allows an interrupt to disrupt a higher
priority task.
Fix this by disabling intercepts in the same function that re-enables
them when needed. This fixes BSOD in Windows 2008.
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 847d7970defb45540735b3fb4e88471c27cacd85 upstream.
For systems with multiple servers and routed fabric, all
northbridges get assigned to the first server. Fix this by also
using the node reported from the PCI bus. For single-fabric
systems, the northbriges are on PCI bus 0 by definition, which
are on NUMA node 0 by definition, so this is invarient on most
systems.
Tested on fam10h and fam15h single and multi-fabric systems and
candidate for stable.
Signed-off-by: Daniel J Blueman <daniel@numascale.com>
Acked-by: Steffen Persvold <sp@numascale.com>
Acked-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/1394710981-3596-1-git-send-email-daniel@numascale.com
commit b01d4e68933ec23e43b1046fa35d593cefcf37d1 upstream.
It's an enum, not a #define, you can't use it in asm files.
Introduced in commit 5fa10196bdb5 ("x86: Ignore NMIs that come in during
early boot"), and sadly I didn't compile-test things like I should have
before pushing out.
My weak excuse is that the x86 tree generally doesn't introduce stupid
things like this (and the ARM pull afterwards doesn't cause me to do a
compile-test either, since I don't cross-compile).
Cc: Don Zickus <dzickus@redhat.com>
Cc: H. Peter Anvin <hpa@linux.intel.com>
commit 5fa10196bdb5f190f595ebd048490ee52dddea0f upstream.
Don Zickus reports:
A customer generated an external NMI using their iLO to test kdump
worked. Unfortunately, the machine hung. Disabling the nmi_watchdog
made things work.
I speculated the external NMI fired, caused the machine to panic (as
expected) and the perf NMI from the watchdog came in and was latched.
My guess was this somehow caused the hang.
It appears that the latched NMI stays latched until the early page
table generation on 64 bits, which causes exceptions to happen which
end in IRET, which re-enable NMI. Therefore, ignore NMIs that come in
during early execution, until we have proper exception handling.
Reported-and-tested-by: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/r/1394221143-29713-1-git-send-email-dzickus@redhat.com
Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
commit 26e61e8939b1fe8729572dabe9a9e97d930dd4f6 upstream.
Vince "Super Tester" Weaver reported a new round of syscall fuzzing (Trinity) failures,
with perf WARN_ON()s triggering. He also provided traces of the failures.
This is I think the relevant bit:
> pec_1076_warn-2804 [000] d... 147.926153: x86_pmu_disable: x86_pmu_disable
> pec_1076_warn-2804 [000] d... 147.926153: x86_pmu_state: Events: {
> pec_1076_warn-2804 [000] d... 147.926156: x86_pmu_state: 0: state: .R config: ffffffffffffffff ( (null))
> pec_1076_warn-2804 [000] d... 147.926158: x86_pmu_state: 33: state: AR config: 0 (ffff88011ac99800)
> pec_1076_warn-2804 [000] d... 147.926159: x86_pmu_state: }
> pec_1076_warn-2804 [000] d... 147.926160: x86_pmu_state: n_events: 1, n_added: 0, n_txn: 1
> pec_1076_warn-2804 [000] d... 147.926161: x86_pmu_state: Assignment: {
> pec_1076_warn-2804 [000] d... 147.926162: x86_pmu_state: 0->33 tag: 1 config: 0 (ffff88011ac99800)
> pec_1076_warn-2804 [000] d... 147.926163: x86_pmu_state: }
> pec_1076_warn-2804 [000] d... 147.926166: collect_events: Adding event: 1 (ffff880119ec8800)
So we add the insn:p event (fd[23]).
At this point we should have:
n_events = 2, n_added = 1, n_txn = 1
> pec_1076_warn-2804 [000] d... 147.926170: collect_events: Adding event: 0 (ffff8800c9e01800)
> pec_1076_warn-2804 [000] d... 147.926172: collect_events: Adding event: 4 (ffff8800cbab2c00)
We try and add the {BP,cycles,br_insn} group (fd[3], fd[4], fd[15]).
These events are 0:cycles and 4:br_insn, the BP event isn't x86_pmu so
that's not visible.
group_sched_in()
pmu->start_txn() /* nop - BP pmu */
event_sched_in()
event->pmu->add()
So here we should end up with:
0: n_events = 3, n_added = 2, n_txn = 2
4: n_events = 4, n_added = 3, n_txn = 3
But seeing the below state on x86_pmu_enable(), the must have failed,
because the 0 and 4 events aren't there anymore.
Looking at group_sched_in(), since the BP is the leader, its
event_sched_in() must have succeeded, for otherwise we would not have
seen the sibling adds.
But since neither 0 or 4 are in the below state; their event_sched_in()
must have failed; but I don't see why, the complete state: 0,0,1:p,4
fits perfectly fine on a core2.
However, since we try and schedule 4 it means the 0 event must have
succeeded! Therefore the 4 event must have failed, its failure will
have put group_sched_in() into the fail path, which will call:
event_sched_out()
event->pmu->del()
on 0 and the BP event.
Now x86_pmu_del() will reduce n_events; but it will not reduce n_added;
giving what we see below:
n_event = 2, n_added = 2, n_txn = 2
> pec_1076_warn-2804 [000] d... 147.926177: x86_pmu_enable: x86_pmu_enable
> pec_1076_warn-2804 [000] d... 147.926177: x86_pmu_state: Events: {
> pec_1076_warn-2804 [000] d... 147.926179: x86_pmu_state: 0: state: .R config: ffffffffffffffff ( (null))
> pec_1076_warn-2804 [000] d... 147.926181: x86_pmu_state: 33: state: AR config: 0 (ffff88011ac99800)
> pec_1076_warn-2804 [000] d... 147.926182: x86_pmu_state: }
> pec_1076_warn-2804 [000] d... 147.926184: x86_pmu_state: n_events: 2, n_added: 2, n_txn: 2
> pec_1076_warn-2804 [000] d... 147.926184: x86_pmu_state: Assignment: {
> pec_1076_warn-2804 [000] d... 147.926186: x86_pmu_state: 0->33 tag: 1 config: 0 (ffff88011ac99800)
> pec_1076_warn-2804 [000] d... 147.926188: x86_pmu_state: 1->0 tag: 1 config: 1 (ffff880119ec8800)
> pec_1076_warn-2804 [000] d... 147.926188: x86_pmu_state: }
> pec_1076_warn-2804 [000] d... 147.926190: x86_pmu_enable: S0: hwc->idx: 33, hwc->last_cpu: 0, hwc->last_tag: 1 hwc->state: 0
So the problem is that x86_pmu_del(), when called from a
group_sched_in() that fails (for whatever reason), and without x86_pmu
TXN support (because the leader is !x86_pmu), will corrupt the n_added
state.
Reported-and-Tested-by: Vince Weaver <vincent.weaver@maine.edu>
Cc: Dave Jones <davej@redhat.com>
Link: http://lkml.kernel.org/r/20140221150312.GF3104@twins.programming.kicks-ass.net
commit c091c71ad2218fc50a07b3d1dab85783f3b77efd upstream.
GFP_ATOMIC is not a single gfp flag, but a macro which expands to the other
flags, where meaningful is the LACK of __GFP_WAIT flag. To check if caller
wants to perform an atomic allocation, the code must test for a lack of the
__GFP_WAIT flag. This patch fixes the issue introduced in v3.5-rc1.
commit a08d3b3b99efd509133946056531cdf8f3a0c09b upstream.
The problem occurs when the guest performs a pusha with the stack
address pointing to an mmio address (or an invalid guest physical
address) to start with, but then extending into an ordinary guest
physical address. When doing repeated emulated pushes
emulator_read_write sets mmio_needed to 1 on the first one. On a
later push when the stack points to regular memory,
mmio_nr_fragments is set to 0, but mmio_is_needed is not set to 0.
As a result, KVM exits to userspace, and then returns to
complete_emulated_mmio. In complete_emulated_mmio
vcpu->mmio_cur_fragment is incremented. The termination condition of
vcpu->mmio_cur_fragment == vcpu->mmio_nr_fragments is never achieved.
The code bounces back and fourth to userspace incrementing
mmio_cur_fragment past it's buffer. If the guest does nothing else it
eventually leads to a a crash on a memcpy from invalid memory address.
However if a guest code can cause the vm to be destroyed in another
vcpu with excellent timing, then kvm_clear_async_pf_completion_queue
can be used by the guest to control the data that's pointed to by the
call to cancel_work_item, which can be used to gain execution.
Fixes: f78146b0f9230765c6315b2e14f56112513389ad
Signed-off-by: Andrew Honig <ahonig@google.com>
commit 87fbb2ac6073a7039303517546a76074feb14c84 upstream.
When the conversion was made to remove stop machine and use the breakpoint
logic instead, the modification of the function graph caller is still
done directly as though it was being done under stop machine.
As it is not converted via stop machine anymore, there is a possibility
that the code could be layed across cache lines and if another CPU is
accessing that function graph call when it is being updated, it could
cause a General Protection Fault.
Convert the update of the function graph caller to use the breakpoint
method as well.
Fixes: 08d636b6d4fb "ftrace/x86: Have arch x86_64 use breakpoints instead of stop machine"
commit 4640c7ee9b8953237d05a61ea3ea93981d1bc961 upstream.
If CONFIG_X86_SMAP is disabled, smap_violation() tests for conditions
which are incorrect (as the AC flag doesn't matter), causing spurious
faults.
The dynamic disabling of SMAP (nosmap on the command line) is fine
because it disables X86_FEATURE_SMAP, therefore causing the
static_cpu_has() to return false.
Found by Fengguang Wu's test system.
[ v3: move all predicates into smap_violation() ]
[ v2: use IS_ENABLED() instead of #ifdef ]
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Link: http://lkml.kernel.org/r/20140213124550.GA30497@localhost
commit 03bbd596ac04fef47ce93a730b8f086d797c3021 upstream.
If SMAP support is not compiled into the kernel, don't enable SMAP in
CR4 -- in fact, we should clear it, because the kernel doesn't contain
the proper STAC/CLAC instructions for SMAP support.
commit 7cde9b27e7b3a2e09d647bb4f6d94e842698d2d5 upstream.
Due to the way kernel is initialized under Xen is possible that the
ring1 selector used by the kernel for the boot cpu end up to be copied
to userspace leading to segmentation fault in the userspace.
Xen code in the kernel initialize no-boot cpus with correct selectors (ds
and es set to __USER_DS) but the boot one keep the ring1 (passed by Xen).
On task context switch (switch_to) we assume that ds, es and cs already
point to __USER_DS and __KERNEL_CSso these selector are not changed.
If processor is an Intel that support sysenter instruction sysenter/sysexit
is used so ds and es are not restored switching back from kernel to
userspace. In the case the selectors point to a ring1 instead of __USER_DS
the userspace code will crash on first memory access attempt (to be
precise Xen on the emulated iret used to do sysexit will detect and set ds
and es to zero which lead to GPF anyway).
Now if an userspace process call kernel using sysenter and get rescheduled
(for me it happen on a specific init calling wait4) could happen that the
ring1 selector is set to ds and es.
This is quite hard to detect cause after a while these selectors are fixed
(__USER_DS seems sticky).
Bisecting the code commit 7076aada1040de4ed79a5977dbabdb5e5ea5e249 appears
to be the first one that have this issue.
Signed-off-by: Frediano Ziglio <frediano.ziglio@citrix.com>
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Reviewed-by: Andrew Cooper <andrew.cooper3@citrix.com>
commit 0160676bba69523e8b0ac83f306cce7d342ed7c8 upstream.
On hosts with more than 168 GB of memory, a 32-bit guest may attempt
to grant map an MFN that is error cannot lookup in its mapping of the
m2p table. There is an m2p lookup as part of m2p_add_override() and
m2p_remove_override(). The lookup falls off the end of the mapped
portion of the m2p and (because the mapping is at the highest virtual
address) wraps around and the lookup causes a fault on what appears to
be a user space address.
do_page_fault() (thinking it's a fault to a userspace address), tries
to lock mm->mmap_sem. If the gntdev device is used for the grant map,
m2p_add_override() is called from from gnttab_mmap() with mm->mmap_sem
already locked. do_page_fault() then deadlocks.
The deadlock would most commonly occur when a 64-bit guest is started
and xenconsoled attempts to grant map its console ring.
Introduce mfn_to_pfn_no_overrides() which checks the MFN is within the
mapped portion of the m2p table before accessing the table and use
this in m2p_add_override(), m2p_remove_override(), and mfn_to_pfn()
(which already had the correct range check).
All faults caused by accessing the non-existant parts of the m2p are
thus within the kernel address space and exception_fixup() is called
without trying to lock mm->mmap_sem.
This means that for MFNs that are outside the mapped range of the m2p
then mfn_to_pfn() will always look in the m2p overrides. This is
correct because it must be a foreign MFN (and the PFN in the m2p in
this case is only relevant for the other domain).
v3: check for auto_translated_physmap in mfn_to_pfn_no_overrides()
v2: in mfn_to_pfn() look in m2p_overrides if the MFN is out of
range as it's probably foreign.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Cc: Stefano Stabellini <stefano.stabellini@citrix.com>
Cc: Jan Beulich <JBeulich@suse.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
commit f98b7a772ab51b52ca4d2a14362fc0e0c8a2e0f3 upstream.
There was a large performance regression that was bisected to
commit 611ae8e3 ("x86/tlb: enable tlb flush range support for
x86"). This patch simply changes the default balance point
between a local and global flush for IvyBridge.
In the interest of allowing the tests to be reproduced, this
patch was tested using mmtests 0.15 with the following
configurations
configs/config-global-dhp__tlbflush-performance
configs/config-global-dhp__scheduler-performance
configs/config-global-dhp__network-performance
Results are from two machines
Ivybridge 4 threads: Intel(R) Core(TM) i3-3240 CPU @ 3.40GHz
Ivybridge 8 threads: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
Page fault microbenchmark showed nothing interesting.
Ebizzy was configured to run multiple iterations and threads.
Thread counts ranged from 1 to NR_CPUS*2. For each thread count,
it ran 100 iterations and each iteration lasted 10 seconds.
Ivybridge 4 threads
3.13.0-rc7 3.13.0-rc7
vanilla altshift-v3
Mean 1 6395.44 ( 0.00%) 6789.09 ( 6.16%)
Mean 2 7012.85 ( 0.00%) 8052.16 ( 14.82%)
Mean 3 6403.04 ( 0.00%) 6973.74 ( 8.91%)
Mean 4 6135.32 ( 0.00%) 6582.33 ( 7.29%)
Mean 5 6095.69 ( 0.00%) 6526.68 ( 7.07%)
Mean 6 6114.33 ( 0.00%) 6416.64 ( 4.94%)
Mean 7 6085.10 ( 0.00%) 6448.51 ( 5.97%)
Mean 8 6120.62 ( 0.00%) 6462.97 ( 5.59%)
Ivybridge 8 threads
vanilla altshift-v3
Mean 1 7336.65 ( 0.00%) 7787.02 ( 6.14%)
Mean 2 8218.41 ( 0.00%) 9484.13 ( 15.40%)
Mean 3 7973.62 ( 0.00%) 8922.01 ( 11.89%)
Mean 4 7798.33 ( 0.00%) 8567.03 ( 9.86%)
Mean 5 7158.72 ( 0.00%) 8214.23 ( 14.74%)
Mean 6 6852.27 ( 0.00%) 7952.45 ( 16.06%)
Mean 7 6774.65 ( 0.00%) 7536.35 ( 11.24%)
Mean 8 6510.50 ( 0.00%) 6894.05 ( 5.89%)
Mean 12 6182.90 ( 0.00%) 6661.29 ( 7.74%)
Mean 16 6100.09 ( 0.00%) 6608.69 ( 8.34%)
Ebizzy hits the worst case scenario for TLB range flushing every
time and it shows for these Ivybridge CPUs at least that the
default choice is a poor on. The patch addresses the problem.
Next was a tlbflush microbenchmark written by Alex Shi at
http://marc.info/?l=linux-kernel&m=133727348217113 . It
measures access costs while the TLB is being flushed. The
expectation is that if there are always full TLB flushes that
the benchmark would suffer and it benefits from range flushing
There are 320 iterations of the test per thread count. The
number of entries is randomly selected with a min of 1 and max
of 512. To ensure a reasonably even spread of entries, the full
range is broken up into 8 sections and a random number selected
within that section.
iteration 1, random number between 0-64
iteration 2, random number between 64-128 etc
This is still a very weak methodology. When you do not know
what are typical ranges, random is a reasonable choice but it
can be easily argued that the opimisation was for smaller ranges
and an even spread is not representative of any workload that
matters. To improve this, we'd need to know the probability
distribution of TLB flush range sizes for a set of workloads
that are considered "common", build a synthetic trace and feed
that into this benchmark. Even that is not perfect because it
would not account for the time between flushes but there are
limits of what can be reasonably done and still be doing
something useful. If a representative synthetic trace is
provided then this benchmark could be revisited and the shift values retuned.
Ivybridge 4 threads
vanilla altshift-v3
Mean 1 10.50 ( 0.00%) 10.50 ( 0.03%)
Mean 2 17.59 ( 0.00%) 17.18 ( 2.34%)
Mean 3 22.98 ( 0.00%) 21.74 ( 5.41%)
Mean 5 47.13 ( 0.00%) 46.23 ( 1.92%)
Mean 8 43.30 ( 0.00%) 42.56 ( 1.72%)
Ivybridge 8 threads
vanilla altshift-v3
Mean 1 9.45 ( 0.00%) 9.36 ( 0.93%)
Mean 2 9.37 ( 0.00%) 9.70 ( -3.54%)
Mean 3 9.36 ( 0.00%) 9.29 ( 0.70%)
Mean 5 14.49 ( 0.00%) 15.04 ( -3.75%)
Mean 8 41.08 ( 0.00%) 38.73 ( 5.71%)
Mean 13 32.04 ( 0.00%) 31.24 ( 2.49%)
Mean 16 40.05 ( 0.00%) 39.04 ( 2.51%)
For both CPUs, average access time is reduced which is good as
this is the benchmark that was used to tune the shift values in
the first place albeit it is now known *how* the benchmark was
used.
The scheduler benchmarks were somewhat inconclusive. They
showed gains and losses and makes me reconsider how stable those
benchmarks really are or if something else might be interfering
with the test results recently.
Network benchmarks were inconclusive. Almost all results were
flat except for netperf-udp tests on the 4 thread machine.
These results were unstable and showed large variations between
reboots. It is unknown if this is a recent problems but I've
noticed before that netperf-udp results tend to vary.
Based on these results, changing the default for Ivybridge seems
like a logical choice.
Tested-by: Davidlohr Bueso <davidlohr@hp.com>
Reviewed-by: Alex Shi <alex.shi@linaro.org>
Link: http://lkml.kernel.org/n/tip-cqnadffh1tiqrshthRj3Esge@git.kernel.org
commit 3b56496865f9f7d9bcb2f93b44c63f274f08e3b6 upstream.
This adds the workaround for erratum 793 as a precaution in case not
every BIOS implements it. This addresses CVE-2013-6885.
Erratum text:
[Revision Guide for AMD Family 16h Models 00h-0Fh Processors,
document 51810 Rev. 3.04 November 2013]
793 Specific Combination of Writes to Write Combined Memory Types and
Locked Instructions May Cause Core Hang
Description
Under a highly specific and detailed set of internal timing
conditions, a locked instruction may trigger a timing sequence whereby
the write to a write combined memory type is not flushed, causing the
locked instruction to stall indefinitely.
Potential Effect on System
Processor core hang.
Suggested Workaround
BIOS should set MSR
C001_1020[15] = 1b.
Fix Planned
No fix planned
[ hpa: updated description, fixed typo in MSR name ]
Link: http://lkml.kernel.org/r/20140114230711.GS29865@pd.tnic
Tested-by: Aravind Gopalakrishnan <aravind.gopalakrishnan@amd.com>
[ Upstream commit aee636c4809fa54848ff07a899b326eb1f9987a2 ]
At first Jakub Zawadzki noticed that some divisions by reciprocal_divide
were not correct. (off by one in some cases)
http://www.wireshark.org/~darkjames/reciprocal-buggy.c
He could also show this with BPF:
http://www.wireshark.org/~darkjames/set-and-dump-filter-k-bug.c
The reciprocal divide in linux kernel is not generic enough,
lets remove its use in BPF, as it is not worth the pain with
current cpus.
Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl>
Cc: Mircea Gherzan <mgherzan@gmail.com>
Cc: Daniel Borkmann <dxchgb@gmail.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Matt Evans <matt@ozlabs.org>
commit 9ed96e87c5748de4c2807ef17e81287c7304186c upstream.
Limit PIT timer frequency similarly to the limit applied by
LAPIC timer.
commit a7f84f03f660d93574ac88835d056c0d6468aebe upstream.
Current code check boot service region with kernel text region by:
start+size >= __pa_symbol(_text)
The end of the above region should be start + size - 1 instead.
I see this problem in ovmf + Fedora 19 grub boot:
text start: 1000000 md start: 800000 md size: 800000
Signed-off-by: Dave Young <dyoung@redhat.com>
Acked-by: Toshi Kani <toshi.kani@hp.com>
Tested-by: Toshi Kani <toshi.kani@hp.com>
commit 0dce7cd67fd9055c4a2ff278f8af1431e646d346 upstream.
Commit e66d2ae7c67bd moved the assignment
vcpu->arch.apic_base = value above a condition with
(vcpu->arch.apic_base ^ value), causing that check
to always fail. Use old_value, vcpu->arch.apic_base's
old value, in the condition instead.
Signed-off-by: Andrew Jones <drjones@redhat.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
commit 1739f09e33d8f66bf48ddbc3eca615574da6c4f6 upstream.
Function tracing callbacks expect to have the ftrace_ops that registered it
passed to them, not the address of the variable that holds the ftrace_ops
that registered it.
Use a mov instead of a lea to store the ftrace_ops into the parameter
of the function tracing callback.
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/20131113152004.459787f9@gandalf.local.home
commit bee09ed91cacdbffdbcd3b05de8409c77ec9fcd6 upstream.
On AMD family 10h we see following error messages while waking up from
S3 for all non-boot CPUs leading to a failed IBS initialization:
Enabling non-boot CPUs ...
smpboot: Booting Node 0 Processor 1 APIC 0x1
[Firmware Bug]: cpu 1, try to use APIC500 (LVT offset 0) for vector 0x400, but the register is already in use for vector 0xf9 on another cpu
perf: IBS APIC setup failed on cpu #1
process: Switch to broadcast mode on CPU1
CPU1 is up
ACPI: Waking up from system sleep state S3
Reason for this is that during suspend the LVT offset for the IBS
vector gets lost and needs to be reinialized while resuming.
The offset is read from the IBSCTL msr. On family 10h the offset needs
to be 1 as offset 0 is used for the MCE threshold interrupt, but
firmware assings it for IBS to 0 too. The kernel needs to reprogram
the vector. The msr is a readonly node msr, but a new value can be
written via pci config space access. The reinitialization is
implemented for family 10h in setup_ibs_ctl() which is forced during
IBS setup.
This patch fixes IBS setup after waking up from S3 by adding
resume/supend hooks for the boot cpu which does the offset
reinitialization.
Marking it as stable to let distros pick up this fix.
Signed-off-by: Robert Richter <rric@kernel.org>
Link: http://lkml.kernel.org/r/1389797849-5565-1-git-send-email-rric.net@gmail.com
commit 26bef1318adc1b3a530ecc807ef99346db2aa8b0 upstream.
Before we do an EMMS in the AMD FXSAVE information leak workaround we
need to clear any pending exceptions, otherwise we trap with a
floating-point exception inside this code.
Reported-by: halfdog <me@halfdog.net>
Tested-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/CA%2B55aFxQnY_PCG_n4=0w-VG=YLXL-yr7oMxyy0WU2gCBAf3ydg@mail.gmail.com
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit 20841405940e7be0617612d521e206e4b6b325db upstream.
There are a few subtle races, between change_protection_range (used by
mprotect and change_prot_numa) on one side, and NUMA page migration and
compaction on the other side.
The basic race is that there is a time window between when the PTE gets
made non-present (PROT_NONE or NUMA), and the TLB is flushed.
During that time, a CPU may continue writing to the page.
This is fine most of the time, however compaction or the NUMA migration
code may come in, and migrate the page away.
When that happens, the CPU may continue writing, through the cached
translation, to what is no longer the current memory location of the
process.
This only affects x86, which has a somewhat optimistic pte_accessible.
All other architectures appear to be safe, and will either always flush,
or flush whenever there is a valid mapping, even with no permissions
(SPARC).
The basic race looks like this:
CPU A CPU B CPU C
load TLB entry
make entry PTE/PMD_NUMA
fault on entry
read/write old page
start migrating page
change PTE/PMD to new page
read/write old page [*]
flush TLB
reload TLB from new entry
read/write new page
lose data
[*] the old page may belong to a new user at this point!
The obvious fix is to flush remote TLB entries, by making sure that
pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may
still be accessible if there is a TLB flush pending for the mm.
This should fix both NUMA migration and compaction.
[mgorman@suse.de: fix build]
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Alex Thorlton <athorlton@sgi.com>
commit e0acd0a68ec7dbf6b7a81a87a867ebd7ac9b76c4 upstream.
This is only theoretical, but after try_to_wake_up(p) was changed
to check p->state under p->pi_lock the code like
__set_current_state(TASK_INTERRUPTIBLE);
schedule();
can miss a signal. This is the special case of wait-for-condition,
it relies on try_to_wake_up/schedule interaction and thus it does
not need mb() between __set_current_state() and if(signal_pending).
However, this __set_current_state() can move into the critical
section protected by rq->lock, now that try_to_wake_up() takes
another lock we need to ensure that it can't be reordered with
"if (signal_pending(current))" check inside that section.
The patch is actually one-liner, it simply adds smp_wmb() before
spin_lock_irq(rq->lock). This is what try_to_wake_up() already
does by the same reason.
We turn this wmb() into the new helper, smp_mb__before_spinlock(),
for better documentation and to allow the architectures to change
the default implementation.
While at it, kill smp_mb__after_lock(), it has no callers.
Perhaps we can also add smp_mb__before/after_spinunlock() for
prepare_to_wait().
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit e66d2ae7c67bd9ac982a3d1890564de7f7eabf4b upstream.
Update arch.apic_base before triggering recalculate_apic_map. Otherwise
the recalculation will work against the previous state of the APIC and
will fail to build the correct map when an APIC is hardware-enabled
again.
This fixes a regression of 1e08ec4a13.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
commit 40e2d7f9b5dae048789c64672bf3027fbb663ffa upstream.
Linux 3.10 changed the timing of how thread_info->flags is touched:
x86: Use generic idle loop
(7d1a941731fabf27e5fb6edbebb79fe856edb4e5)
This caused Intel NHM-EX and WSM-EX servers to experience a large number
of immediate MONITOR/MWAIT break wakeups, which caused cpuidle to demote
from deep C-states to shallow C-states, which caused these platforms
to experience a significant increase in idle power.
Note that this issue was already present before the commit above,
however, it wasn't seen often enough to be noticed in power measurements.
Here we extend an errata workaround from the Core2 EX "Dunnington"
to extend to NHM-EX and WSM-EX, to prevent these immediate
returns from MWAIT, reducing idle power on these platforms.
While only acpi_idle ran on Dunnington, intel_idle
may also run on these two newer systems.
As of today, there are no other models that are known
to need this tweak.
Link: http://lkml.kernel.org/r/CAJvTdK=%2BaNN66mYpCGgbHGCHhYQAKx-vB0kJSWjVpsNb_hOAtQ@mail.gmail.com
Signed-off-by: Len Brown <len.brown@intel.com>
Link: http://lkml.kernel.org/r/baff264285f6e585df757d58b17788feabc68918.1387403066.git.len.brown@intel.com
commit 8b3b005d675726e38bc504d2e35a991e55819155 upstream.
In checkin
5551a34e5aea x86-64, build: Always pass in -mno-sse
we unconditionally added -mno-sse to the main build, to keep newer
compilers from generating SSE instructions from autovectorization.
However, this did not extend to the special environments
(arch/x86/boot, arch/x86/boot/compressed, and arch/x86/realmode/rm).
Add -mno-sse to the compiler command line for these environments, and
add -mno-mmx to all the environments as well, as we don't want a
compiler to generate MMX code either.
This patch also removes a $(cc-option) call for -m32, since we have
long since stopped supporting compilers too old for the -m32 option,
and in fact hardcode it in other places in the Makefiles.
Reported-by: Kevin B. Smith <kevin.b.smith@intel.com>
Cc: Sunil K. Pandey <sunil.k.pandey@intel.com>
Cc: H. J. Lu <hjl.tools@gmail.com>
Link: http://lkml.kernel.org/n/tip-j21wzqv790q834n7yc6g80j1@git.kernel.org
commit 04bf9ba720fcc4fa313fa122b799ae0989b6cd50 upstream.
UEFI time services are often broken once we're in virtual mode. We were
already refusing to use them on 64-bit systems, but it turns out that
they're also broken on some 32-bit firmware, including the Dell Venue.
Disable them for now, we can revisit once we have the 1:1 mappings code
incorporated.
Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com>
Link: http://lkml.kernel.org/r/1385754283-2464-1-git-send-email-matthew.garrett@nebula.com
Cc: Matt Fleming <matt.fleming@intel.com>
commit 17d68b763f09a9ce824ae23eb62c9efc57b69271 upstream.
A guest can cause a BUG_ON() leading to a host kernel crash.
When the guest writes to the ICR to request an IPI, while in x2apic
mode the following things happen, the destination is read from
ICR2, which is a register that the guest can control.
kvm_irq_delivery_to_apic_fast uses the high 16 bits of ICR2 as the
cluster id. A BUG_ON is triggered, which is a protection against
accessing map->logical_map with an out-of-bounds access and manages
to avoid that anything really unsafe occurs.
The logic in the code is correct from real HW point of view. The problem
is that KVM supports only one cluster with ID 0 in clustered mode, but
the code that has the bug does not take this into account.
Reported-by: Lars Bull <larsbull@google.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
commit fda4e2e85589191b123d31cdc21fd33ee70f50fd upstream.
In kvm_lapic_sync_from_vapic and kvm_lapic_sync_to_vapic there is the
potential to corrupt kernel memory if userspace provides an address that
is at the end of a page. This patches concerts those functions to use
kvm_write_guest_cached and kvm_read_guest_cached. It also checks the
vapic_address specified by userspace during ioctl processing and returns
an error to userspace if the address is not a valid GPA.
This is generally not guest triggerable, because the required write is
done by firmware that runs before the guest. Also, it only affects AMD
processors and oldish Intel that do not have the FlexPriority feature
(unless you disable FlexPriority, of course; then newer processors are
also affected).
Fixes: b93463aa59d6 ('KVM: Accelerated apic support')
Reported-by: Andrew Honig <ahonig@google.com>
commit b963a22e6d1a266a67e9eecc88134713fd54775c upstream.
Under guest controllable circumstances apic_get_tmcct will execute a
divide by zero and cause a crash. If the guest cpuid support
tsc deadline timers and performs the following sequence of requests
the host will crash.
- Set the mode to periodic
- Set the TMICT to 0
- Set the mode bits to 11 (neither periodic, nor one shot, nor tsc deadline)
- Set the TMICT to non-zero.
Then the lapic_timer.period will be 0, but the TMICT will not be. If the
guest then reads from the TMCCT then the host will perform a divide by 0.
This patch ensures that if the lapic_timer.period is 0, then the division
does not occur.
