Add a NODE level to the generic cache events which is used to measure
local vs remote memory accesses. Like all other cache events, an
ACCESS is HIT+MISS, if there is no way to distinguish between reads
and writes do reads only etc..
The below needs filling out for !x86 (which I filled out with
unsupported events).
I'm fairly sure ARM can leave it like that since it doesn't strike me as
an architecture that even has NUMA support. SH might have something since
it does appear to have some NUMA bits.
Sparc64, PowerPC and MIPS certainly want a good look there since they
clearly are NUMA capable.
Cc: David Daney <ddaney@caviumnetworks.com>
Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1303508226.4865.8.camel@laptop
Since the OFFCORE registers are fully symmetric, try the other one
when the specified one is already in use.
Link: http://lkml.kernel.org/r/1306141897.18455.8.camel@twins
This patch adds Intel Sandy Bridge offcore_response support by
providing the low-level constraint table for those events.
On Sandy Bridge, there are two offcore_response events. Each uses
its own dedictated extra register. But those registers are NOT shared
between sibling CPUs when HT is on unlike Nehalem/Westmere. They are
always private to each CPU. But they still need to be controlled within
an event group. All events within an event group must use the same
value for the extra MSR. That's not controlled by the second patch in
this series.
Furthermore on Sandy Bridge, the offcore_response events have NO
counter constraints contrary to what the official documentation
indicates, so drop the events from the contraint table.
Signed-off-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/20110606145712.GA7304@quad
The validate_group() function needs to validate events with
extra shared regs. Within an event group, only events with
the same value for the extra reg can co-exist. This was not
checked by validate_group() because it was missing the
shared_regs logic.
This patch changes the allocation of the fake cpuc used for
validation to also point to a fake shared_regs structure such
that group events be properly testing.
It modifies __intel_shared_reg_get_constraints() to use
spin_lock_irqsave() to avoid lockdep issues.
Link: http://lkml.kernel.org/r/20110606145708.GA7279@quad
This patch improves the code managing the extra shared registers
used for offcore_response events on Intel Nehalem/Westmere. The
idea is to use static allocation instead of dynamic allocation.
This simplifies greatly the get and put constraint routines for
those events.
The patch also renames per_core to shared_regs because the same
data structure gets used whether or not HT is on. When HT is
off, those events still need to coordination because they use
a extra MSR that has to be shared within an event group.
Link: http://lkml.kernel.org/r/20110606145703.GA7258@quad
Since only samples call perf_output_sample() its much saner (and more
correct) to put the sample logic in there than in the
perf_output_begin()/perf_output_end() pair.
Saves a useless argument, reduces conditionals and shrinks
struct perf_output_handle, win!
Link: http://lkml.kernel.org/n/tip-2crpvsx3cqu67q3zqjbnlpsc@git.kernel.org
The nmi parameter indicated if we could do wakeups from the current
context, if not, we would set some state and self-IPI and let the
resulting interrupt do the wakeup.
For the various event classes:
- hardware: nmi=0; PMI is in fact an NMI or we run irq_work_run from
the PMI-tail (ARM etc.)
- tracepoint: nmi=0; since tracepoint could be from NMI context.
- software: nmi=[0,1]; some, like the schedule thing cannot
perform wakeups, and hence need 0.
As one can see, there is very little nmi=1 usage, and the down-side of
not using it is that on some platforms some software events can have a
jiffy delay in wakeup (when arch_irq_work_raise isn't implemented).
The up-side however is that we can remove the nmi parameter and save a
bunch of conditionals in fast paths.
Cc: Michael Cree <mcree@orcon.net.nz>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/n/tip-agjev8eu666tvknpb3iaj0fg@git.kernel.org
Due to restriction and specifics of Netburst PMU we need a separated
event for NMI watchdog. In particular every Netburst event
consumes not just a counter and a config register, but also an
additional ESCR register.
Since ESCR registers are grouped upon counters (i.e. if ESCR is occupied
for some event there is no room for another event to enter until its
released) we need to pick up the "least" used ESCR (or the most available
one) for nmi-watchdog purposes -- so MSR_P4_CRU_ESCR2/3 was chosen.
With this patch nmi-watchdog and perf top should be able to run simultaneously.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
CC: Lin Ming <ming.m.lin@intel.com>
CC: Arnaldo Carvalho de Melo <acme@redhat.com>
CC: Frederic Weisbecker <fweisbec@gmail.com>
Tested-and-reviewed-by: Don Zickus <dzickus@redhat.com>
Tested-and-reviewed-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/20110623124918.GC13050@sun
commit 21a3c96 uses node_start/end_pfn(nid) for detection start/end
of nodes. But, it's not defined in linux/mmzone.h but defined in
/arch/???/include/mmzone.h which is included only under
CONFIG_NEED_MULTIPLE_NODES=y.
Then, we see
mm/page_cgroup.c: In function 'page_cgroup_init':
mm/page_cgroup.c:308: error: implicit declaration of function 'node_start_pfn'
mm/page_cgroup.c:309: error: implicit declaration of function 'node_end_pfn'
So, fixiing page_cgroup.c is an idea...
But node_start_pfn()/node_end_pfn() is a very generic macro and
should be implemented in the same manner for all archs.
(m32r has different implementation...)
This patch removes definitions of node_start/end_pfn() in each archs
and defines a unified one in linux/mmzone.h. It's not under
CONFIG_NEED_MULTIPLE_NODES, now.
A result of macro expansion is here (mm/page_cgroup.c)
for !NUMA
start_pfn = ((&contig_page_data)->node_start_pfn);
end_pfn = ({ pg_data_t *__pgdat = (&contig_page_data); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;});
for NUMA (x86-64)
start_pfn = ((node_data[nid])->node_start_pfn);
end_pfn = ({ pg_data_t *__pgdat = (node_data[nid]); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;});
Changelog:
- fixed to avoid using "nid" twice in node_end_pfn() macro.
Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com>
Reported-and-tested-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
x86/PCI/ACPI: fix type mismatch
PCI: fix new kernel-doc warning
PCI: Fix warning in drivers/pci/probe.c on sparc64
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/bug.fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/setup: Fix for incorrect xen_extra_mem_start.
xen: When calling power_off, don't call the halt function.
xen: Fix compile warning when CONFIG_SMP is not defined.
xen: support CONFIG_MAXSMP
xen: partially revert "xen: set max_pfn_mapped to the last pfn mapped"
* 'kvm-updates/3.0' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: Fix register corruption in pvclock_scale_delta
KVM: MMU: fix opposite condition in mapping_level_dirty_bitmap
KVM: VMX: do not overwrite uptodate vcpu->arch.cr3 on KVM_SET_SREGS
KVM: MMU: Fix build warnings in walk_addr_generic()
The 128-bit multiply in pvclock.h was missing an output constraint for
EDX which caused a register corruption to appear. Thanks to Ulrich for
diagnosing the EDX corruption and Avi for providing this fix.
Signed-off-by: Zachary Amsden <zamsden@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
The condition is opposite, it always maps huge page for the dirty tracked page
Reported-by: Steve <stefan.bosak@gmail.com>
Signed-off-by: Steve <stefan.bosak@gmail.com>
Only decache guest CR3 value if vcpu->arch.cr3 is stale.
Fixes loadvm with live guest.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Tested-by: Markus Schade <markus.schade@gmail.com>
On 3.0-rc1 I get
In file included from arch/x86/kvm/mmu.c:2856:
arch/x86/kvm/paging_tmpl.h: In function ‘paging32_walk_addr_generic’:
arch/x86/kvm/paging_tmpl.h:124: warning: ‘ptep_user’ may be used uninitialized in this function
In file included from arch/x86/kvm/mmu.c:2852:
arch/x86/kvm/paging_tmpl.h: In function ‘paging64_walk_addr_generic’:
caused by 6e2ca7d1802bf8ed9908435e34daa116662e7790. According to Takuya
Yoshikawa, ptep_user won't be used uninitialized so shut up gcc.
Cc: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp>
Link: http://lkml.kernel.org/r/20110530094604.GC21833@liondog.tnic
Signed-off-by: Borislav Petkov <bp@alien8.de>
Commit 916f676f8dc started reserving boot service code since some systems
require you to keep that code around until SetVirtualAddressMap is called.
However, in some cases those areas will overlap with reserved regions.
The proper medium-term fix is to fix the bootloader to prevent the
conflicts from occurring by moving the kernel to a better position,
but the kernel should check for this possibility, and only reserve regions
which can be reserved.
Signed-off-by: Maarten Lankhorst <m.b.lankhorst@gmail.com>
Link: http://lkml.kernel.org/r/4DF7A005.1050407@gmail.com
Acked-by: Matthew Garrett <mjg@redhat.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
The earlier attempts (24bdb0b62cc82120924762ae6bc85afc8c3f2b26)
at fixing this problem caused other problems to surface (PV guests
with no PCI passthrough would have SWIOTLB turned on - which meant
64MB of precious contingous DMA32 memory being eaten up per guest).
The problem was: "on xen we add an extra memory region at the end of
the e820, and on this particular machine this extra memory region
would start below 4g and cross over the 4g boundary:
[0xfee01000-0x192655000)
Unfortunately e820_end_of_low_ram_pfn does not expect an
e820 layout like that so it returns 4g, therefore initial_memory_mapping
will map [0 - 0x100000000), that is a memory range that includes some
reserved memory regions."
The memory range was the IOAPIC regions, and with the 1-1 mapping
turned on, it would map them as RAM, not as MMIO regions. This caused
the hypervisor to complain. Fortunately this is experienced only under
the initial domain so we guard for it.
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
.. As it won't actually power off the machine.
Reported-by: Sven Köhler <sven.koehler@gmail.com>
Tested-by: Sven Köhler <sven.koehler@gmail.com>
Signed-off-by: Tom Goetz <tom.goetz@virtualcomputer.com>
The MAXSMP config option requires CPUMASK_OFFSTACK, which in turn
requires we init the memory for the maps while we bring up the cpus.
MAXSMP also increases NR_CPUS to 4096. This increase in size exposed an
issue in the argument construction for multicalls from
xen_flush_tlb_others. The args should only need space for the actual
number of cpus.
Also in 2.6.39 it exposes a bootup problem.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff8157a1d3>] set_cpu_sibling_map+0x123/0x30d
Call Trace:
[<ffffffff81039a3f>] ? xen_restore_fl_direct_reloc+0x4/0x4
[<ffffffff819dc4db>] xen_smp_prepare_cpus+0x36/0x135
CC: stable@kernel.org
Signed-off-by: Andrew Jones <drjones@redhat.com>
[v2: Updated to compile on 3.0]
[v3: Updated to compile when CONFIG_SMP is not defined]
[ Also from Ben Hutchings <ben@decadent.org.uk> and Vitaliy Ivanov
<vitalivanov@gmail.com> ]
Commit 06ae40ce073d ("x86 idle: EXPORT_SYMBOL(default_idle, pm_idle)
only when APM demands it") removed the export for pm_idle/default_idle
unless the apm module was modularised and CONFIG_APM_CPU_IDLE was set.
But the apm module uses pm_idle/default_idle unconditionally,
CONFIG_APM_CPU_IDLE only affects the bios idle threshold. Adjust the
export accordingly.
[ Used #ifdef instead of #if defined() as it's shorter, and what both
Ben and Vitaliy used.. Andy, you're out-voted ;) - Linus ]
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: Len Brown <len.brown@intel.com>
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm: Compare only lower 32 bits of framebuffer map offsets
drm/i915: Don't leak in i915_gem_shmem_pread_slow()
drm/radeon/kms: do bounds checking for 3D_LOAD_VBPNTR and bump array limit
drm/radeon/kms: fix mac g5 quirk
x86/uv/x2apic: update for change in pci bridge handling.
alpha, drm: Remove obsolete Alpha support in MGA DRM code
alpha/drm: Cleanup Alpha support in DRM generic code
savage: remove unnecessary if statement
drm/radeon: fix GUI idle IH debug statements
drm/radeon/kms: check modes against max pixel clock
drm: fix fbs in DRM_IOCTL_MODE_GETRESOURCES ioctl
When I added 3448a19da479b6bd1e28e2a2be9fa16c6a6feb39
I forgot about the special uv handling code for this, so this
patch fixes it up.
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
ftrace: Revert 8ab2b7efd ftrace: Remove unnecessary disabling of irqs
kprobes/trace: Fix kprobe selftest for gcc 4.6
ftrace: Fix possible undefined return code
oprofile, dcookies: Fix possible circular locking dependency
oprofile: Fix locking dependency in sync_start()
oprofile: Free potentially owned tasks in case of errors
oprofile, x86: Add comments to IBS LVT offset initialization
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: devicetree: Add missing early_init_dt_setup_initrd_arch stub
x86: cpu-hotplug: Prevent softirq wakeup on wrong CPU
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq: Prevent potential NULL dereference in irq_set_irq_wake()
Unconditionally changing the address limit to USER_DS and not restoring
it to its old value in the error path is wrong because it prevents us
using kernel memory on repeated calls to this function. This, in fact,
breaks the fallback of hard coded paths to the init program from being
ever successful if the first candidate fails to load.
With this patch applied switching to USER_DS is delayed until the point
of no return is reached which makes it possible to have a multi-arch
rootfs with one arch specific init binary for each of the (hard coded)
probed paths.
Since the address limit is already set to USER_DS when start_thread()
will be invoked, this redundancy can be safely removed.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: stable@kernel.org
This patch fixes the following build failure:
drivers/built-in.o: In function `early_init_dt_check_for_initrd':
/home/florian/dev/kernel/x86/linux-2.6-x86/drivers/of/fdt.c:571:
undefined reference to `early_init_dt_setup_initrd_arch'
make: *** [.tmp_vmlinux1] Error 1
which happens as soon as we enable initrd support on a x86 devicetree
platform such as Intel CE4100.
Signed-off-by: Florian Fainelli <ffainelli@freebox.fr>
Cc: Maxime Bizon <mbizon@freebox.fr>
Acked-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Cc: stable@kernel.org # 2.6.39
Link: http://lkml.kernel.org/r/201106061015.50039.ffainelli@freebox.fr
We only need to set max_pfn_mapped to the last pfn mapped on x86_64 to
make sure that cleanup_highmap doesn't remove important mappings at
_end.
We don't need to do this on x86_32 because cleanup_highmap is not called
on x86_32. Besides lowering max_pfn_mapped on x86_32 has the unwanted
side effect of limiting the amount of memory available for the 1:1
kernel pagetable allocation.
This patch reverts the x86_32 part of the original patch.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
xen: off by one errors in multicalls.c
xen: use the trigger info we already have to choose the irq handler
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/urgent
After a newly plugged CPU sets the cpu_online bit it enables
interrupts and goes idle. The cpu which brought up the new cpu waits
for the cpu_online bit and when it observes it, it sets the cpu_active
bit for this cpu. The cpu_active bit is the relevant one for the
scheduler to consider the cpu as a viable target.
With forced threaded interrupt handlers which imply forced threaded
softirqs we observed the following race:
cpu 0 cpu 1
bringup(cpu1);
set_cpu_online(smp_processor_id(), true);
local_irq_enable();
while (!cpu_online(cpu1));
timer_interrupt()
-> wake_up(softirq_thread_cpu1);
-> enqueue_on(softirq_thread_cpu1, cpu0);
cpu_notify(CPU_ONLINE, cpu1);
-> sched_cpu_active(cpu1)
-> set_cpu_active((cpu1, true);
When an interrupt happens before the cpu_active bit is set by the cpu
which brought up the newly onlined cpu, then the scheduler refuses to
enqueue the woken thread which is bound to that newly onlined cpu on
that newly onlined cpu due to the not yet set cpu_active bit and
selects a fallback runqueue. Not really an expected and desirable
behaviour.
So far this has only been observed with forced hard/softirq threading,
but in theory this could happen without forced threaded hard/softirqs
as well. It's probably unobservable as it would take a massive
interrupt storm on the newly onlined cpu which causes the softirq loop
to wake up the softirq thread and an even longer delay of the cpu
which waits for the cpu_online bit.
Reviewed-by: Peter Zijlstra <peterz@infradead.org>
x86/amd-iommu: Fix boot crash with hidden PCI devices
x86/amd-iommu: Use only per-device dma_ops
x86/amd-iommu: Fix 3 possible endless loops
KVM: Initialize kvm before registering the mmu notifier
KVM: x86: use proper port value when checking io instruction permission
KVM: add missing void __user * cast to access_ok() call
Some PCIe cards ship with a PCI-PCIe bridge which is not
visible as a PCI device in Linux. But the device-id of the
bridge is present in the IOMMU tables which causes a boot
crash in the IOMMU driver.
This patch fixes by removing these cards from the IOMMU
handling. This is a pure -stable fix, a real fix to handle
this situation appriatly will follow for the next merge
window.
Cc: stable@kernel.org # > 2.6.32
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Unfortunatly there are systems where the AMD IOMMU does not
cover all devices. This breaks with the current driver as it
initializes the global dma_ops variable. This patch limits
the AMD IOMMU to the devices listed in the IVRS table fixing
DMA for devices not covered by the IOMMU.
The driver contains several loops counting on an u16 value
where the exit-condition is checked against variables that
can have values up to 0xffff. In this case the loops will
never exit. This patch fixed 3 such loops.
Commit f6511935f42 moved the permission check for io instructions
to the ->check_perm callback. It failed to copy the port value from RDX
register for string and "in,out ax,dx" instructions.
Fix it by reading RDX register at decode stage when appropriate.
Fixes FC8.32 installation.
b->args[] has MC_ARGS elements, so the comparison here should be
">=" instead of ">". Otherwise we read past the end of the array
one space.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
The flags field of struct resource from linux/ioport.h is "unsigned
long". Change the "type" parameter of coalesce_windows() function to
match that field. This fixes the following warning messages when
compiling with "make C=1 W=1 bzImage modules":
arch/x86/pci/acpi.c: In function ‘coalesce_windows’:
arch/x86/pci/acpi.c:198: warning: conversion to ‘long unsigned int’ from ‘int’ may change the sign of the result
arch/x86/pci/acpi.c:203: warning: conversion to ‘long unsigned int’ from ‘int’ may change the sign of the result
Signed-off-by: Márton Németh <nm127@freemail.hu>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
virtio_net: delay TX callbacks
virtio: add api for delayed callbacks
virtio_test: support event index
vhost: support event index
virtio_ring: support event idx feature
virtio ring: inline function to check for events
virtio: event index interface
virtio: add full three-clause BSD text to headers.
virtio balloon: kill tell-host-first logic
virtio console: don't manually set or finalize VIRTIO_CONSOLE_F_MULTIPORT.
drivers, block: virtio_blk: Replace cryptic number with the macro
virtio_blk: allow re-reading config space at runtime
lguest: remove support for VIRTIO_F_NOTIFY_ON_EMPTY.
lguest: fix up compilation after move
lguest: fix timer interrupt setup
x86: Fix mwait_play_dead() faulting on mwait-incapable cpus
x86 idle: Fix mwait deprecation warning message
Evil merge to remove extra quote noticed by Joe Perches
x86: Put back -pg to tsc.o and add no GCOV to vread_tsc_64.o
Adding a comment in the code as IBS LVT setup is not obvious at all ...
Signed-off-by: Robert Richter <robert.richter@amd.com>
A logic error in mwait_play_dead() causes the kernel to use
mwait even on cpus which don't support it, such as KVM virtual
cpus.
Introduced by:
349c004e3d31: x86: A fast way to check capabilities of the current cpu
Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=36222
Reported-by: Török Edwin <edwintorok@gmail.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Tejun Heo <tj@kernel.org>
Link: http://lkml.kernel.org/r/1306758237-9327-1-git-send-email-avi@redhat.com
Fix:
arch/x86/kernel/process.c:645:1: warning: unknown escape sequence '\i'
due to missing escape backslash, introduced by this commit:
5d4c47e0195b: x86 idle: deprecate mwait_idle() and "idle=mwait" cmdline param
Cc: Len Brown <len.brown@intel.com>
Link: http://lkml.kernel.org/r/1306748286-24701-1-git-send-email-bp@alien8.de
Without an IRQ chip set, we now get a WARN_ON and no timer interrupt. This
prevents booting.
Fortunately, the fix is a one-liner: set up the timer IRQ like everything
else.
Cc: stable@kernel.org # .39.x
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6
* 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6:
x86 idle: deprecate "no-hlt" cmdline param
x86 idle APM: deprecate CONFIG_APM_CPU_IDLE
x86 idle floppy: deprecate disable_hlt()
x86 idle: EXPORT_SYMBOL(default_idle, pm_idle) only when APM demands it
x86 idle: clarify AMD erratum 400 workaround
idle governor: Avoid lock acquisition to read pm_qos before entering idle
cpuidle: menu: fixed wrapping timers at 4.294 seconds
mwait_idle() is a C1-only idle loop intended to be more efficient
than HLT on SMP hardware that supports it.
But mwait_idle() has been replaced by the more general
mwait_idle_with_hints(), which handles both C1 and deeper C-states.
ACPI uses only mwait_idle_with_hints(), and never uses mwait_idle().
Deprecate mwait_idle() and the "idle=mwait" cmdline param
to simplify the x86 idle code.
After this change, kernels configured with
(!CONFIG_ACPI=n && !CONFIG_INTEL_IDLE=n) when run on hardware
that support MWAIT will simply use HLT. If MWAIT is desired
on those systems, cpuidle and the cpuidle drivers above
can be used.
cc: x86@kernel.org
cc: stable@kernel.org # .39.x
Signed-off-by: Len Brown <len.brown@intel.com>
We'd rather that modern machines not check if HLT works on
every entry into idle, for the benefit of machines that had
marginal electricals 15-years ago. If those machines are still running
the upstream kernel, they can use "idle=poll". The only difference
will be that they'll now invoke HLT in machine_hlt().
cc: x86@kernel.org # .39.x
We don't want to export the pm_idle function pointer to modules.
Currently CONFIG_APM_CPU_IDLE w/ CONFIG_APM_MODULE forces us to.
CONFIG_APM_CPU_IDLE is of dubious value, it runs only on 32-bit
uniprocessor laptops that are over 10 years old. It calls into
the BIOS during idle, and is known to cause a number of machines
to fail.
Removing CONFIG_APM_CPU_IDLE and will allow us to stop exporting
pm_idle. Any systems that were calling into the APM BIOS
at run-time will simply use HLT instead.
cc: x86@kernel.org
cc: Jiri Kosina <jkosina@suse.cz>
