path: root/arch/x86
2008-05-13Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: user_regset_view table fix for ia32 on 64-bit x86: arch/x86/mm/pat.c - fix warning x86: fix csum_partial() export x86: early_init_centaur(): use set_cpu_cap() x86: fix app crashes after SMP resume x86: wakeup.lds.S - section ordering fix x86: [VOYAGER] fix duplicate phys_cpu_present_map symbol x86/pci: fix broken ISA DMA
2008-05-13x86: user_regset_view table fix for ia32 on 64-bitRoland McGrath
The user_regset_view table for the 32-bit regsets on the 64-bit build had the wrong sizes for the FP regsets. This bug had no user-visible effect (just on kernel modules using the user_regset interfaces and the like). But the fix is trivial and risk-free. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-13x86: arch/x86/mm/pat.c - fix warningPranith Kumar
fix this warning: arch/x86/mm/pat.c: In function `phys_mem_access_prot_allowed': arch/x86/mm/pat.c:558: warning: long long unsigned int format, long unsigned int arg (arg 6) arch/x86/mm/pat.c: In function `map_devmem': arch/x86/mm/pat.c:580: warning: long long unsigned int format, long unsigned int arg (arg 6) Signed-off-by: D Pranith Kumar <bobby.prani@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-13x86: fix csum_partial() exportIngo Molnar
Fix this symbol export problem: Building modules, stage 2. MODPOST 193 modules ERROR: "csum_partial" [fs/reiserfs/reiserfs.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 This is due to a known weakness of symbol exports: if a symbol's only in-core user is an EXPORT_SYMBOL from a lib-y section, the symbol is not linked in. The solution is to move the export to x8664_ksyms_64.c - but the real solution would be to fix kbuild. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-13x86: early_init_centaur(): use set_cpu_cap()Andrew Morton
arch/x86/kernel/setup_64.c:954: warning: passing argument 2 of 'set_bit' from incompatible pointer type Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-13x86: fix app crashes after SMP resumeHugh Dickins
After resume on a 2cpu laptop, kernel builds collapse with a sed hang, sh or make segfault (often on 20295564), real-time signal to cc1 etc. Several hurdles to jump, but a manually-assisted bisect led to -rc1's d2bcbad5f3ad38a1c09861bca7e252dde7bb8259 x86: do not zap_low_mappings in __smp_prepare_cpus. Though the low mappings were removed at bootup, they were left behind (with Global flags helping to keep them in TLB) after resume or cpu online, causing the crashes seen. Reinstate zap_low_mappings (with local __flush_tlb_all) for each cpu_up on x86_32. This used to be serialized by smp_commenced_mask: that's now gone, but a low_mappings flag will do. No need for native_smp_cpus_done to repeat the zap: let mem_init zap BSP's low mappings just like on UP. (In passing, fix error code from native_cpu_up: do_boot_cpu returns a variety of diagnostic values, Dprintk what it says but convert to -EIO. And save_pg_dir separately before zap_low_mappings: doesn't matter now, but zapping twice in succession wiped out resume's swsusp_pg_dir.) That worked well on the duo and one quad, but wouldn't boot 3rd or 4th cpu on P4 Xeon, oopsing just after unlock_ipi_call_lock. The TLB flush IPI now being sent reveals a long-standing bug: the booting cpu has its APIC readied in smp_callin at the top of start_secondary, but isn't put into the cpu_online_map until just before that unlock_ipi_call_lock. So native_smp_call_function_mask to online cpus would send_IPI_allbutself, including the cpu just coming up, though it has been excluded from the count to wait for: by the time it handles the IPI, the call data on native_smp_call_function_mask's stack may well have been overwritten. So fall back to send_IPI_mask while cpu_online_map does not match cpu_callout_map: perhaps there's a better APICological fix to be made at the start_secondary end, but I wouldn't know that. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-13x86/PCI: X86_PAT & mprotectVenki Pallipadi
Some versions of X used the mprotect workaround to change caching type from UC to WB, so that it can then use mtrr to program WC for that region [1]. Change the mmap of pci space through /sys or /proc interfaces from UC to UC_MINUS. With this change, X will not need to use mprotect workaround to get WC type since the MTRR mapping type will be honored. The bug in mprotect that clobbers PAT bits is fixed in a follow on patch. So, this X workaround will stop working as well. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-05-13x86/PCI: fix broken ISA DMATakashi Iwai
Rene Herman reported: > commit 8779f2fc3b84ebb6c5181fb13d702e9944c16069 > > "x86: don't try to allocate from DMA zone at first" > > breaks all of ISA DMA. Or all of ALSA ISA DMA at least. All > ISA soundcards are silent following that commit -- no error > messages, everything appears fine, just silence. That patch is buggy. We had an implicit assumption that dev = NULL for ISA devices that require 24bit DMA. The recent work on x86 dma_alloc_coherent() breaks the ISA DMA buffer allocation, which is represented by "dev = NULL" and requires 24bit DMA implicitly. Bisected-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-05-12x86: wakeup.lds.S - section ordering fixCyrill Gorcunov
To allow linker to catch sections overlapping we have to declare them in appropriate order. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-12x86: [VOYAGER] fix duplicate phys_cpu_present_map symbolJames Bottomley
The phys_cpu_present_map is an expected symbol in the SMP harness. Unfortunately, x86 recently moved this and a few others to kernel/setup.c where it doesn't quite work because voyager has to define its own. Use CONFIG_X86_LOCAL_APIC to isolate these definitions and fix up another area in setup.c where CONFIG_X86_SMP should be used instead of CONFIG_SMP. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: toralf.foerster@gmx.de Cc: Mike Travis <travis@sgi.com> Cc: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-12x86/pci: fix broken ISA DMATakashi Iwai
Rene Herman reported: > commit 8779f2fc3b84ebb6c5181fb13d702e9944c16069 > > "x86: don't try to allocate from DMA zone at first" > > breaks all of ISA DMA. Or all of ALSA ISA DMA at least. All > ISA soundcards are silent following that commit -- no error > messages, everything appears fine, just silence. That patch is buggy. We had an implicit assumption that dev = NULL for ISA devices that require 24bit DMA. The recent work on x86 dma_alloc_coherent() breaks the ISA DMA buffer allocation, which is represented by "dev = NULL" and requires 24bit DMA implicitly. Bisected-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Tested-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: x86: rdc: leds build/config fix x86: sysfs cpu?/topology is empty in 2.6.25 (32-bit Intel system) x86: revert commit 709f744 ("x86: bitops asm constraint fixes") x86: restrict keyboard io ports reservation to make ipmi driver work x86: fix fpu restore from sig return x86: remove spew print out about bus to node mapping x86: revert printk format warning change which is for linux-next x86: cleanup PAT cpu validation x86: geode: define geode_has_vsa2() even if CONFIG_MGEODE_LX is not set x86: GEODE: cache results from geode_has_vsa2() and uninline x86: revert geode config dependency
2008-05-10x86: rdc: leds build/config fixIngo Molnar
select NEW_LEDS for now until the Kconfig dependencies have been fixed. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-10x86: restrict keyboard io ports reservation to make ipmi driver workHelge Wagner
On some of our (single board computer) boards (x86) we are using an IPMI controller that uses I/O ports 0x62 and 0x66 for a KCS (keyboard controller style) IPMI system interface. Trying to load the openipmi driver fails, because the ports (0x62/0x66) are reserved for keyboard. keyboard reserves the full range 0x60-0x6F while it doesn't need to. Reserve only ports 0x60 and 0x64 for the legacy PS/2 i8042 keyboad controller instead of 0x60-0x6F to allow the openipmi driver to work. [ tglx: added 64bit fixup ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-10x86: fix fpu restore from sig returnSuresh Siddha
If the task never used fpu, initialize the fpu before restoring the FP state from the signal handler context. This will allocate the fpu state, if the task never needed it before. Reported-and-bisected-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Tested-by: Eric Sesterhenn <snakebyte@gmx.de> Cc: Frederik Deweerdt <deweerdt@free.fr> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-10x86: remove spew print out about bus to node mappingYinghai Lu
Jeff Garzik pointed out that this printout is not needed. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-10x86: revert printk format warning change which is for linux-nextThomas Gleixner
commit 62179849b40aded9e727cca5006627a1c4d6446e x86: fix setup printk format warning is for linux-next and not for .26 Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-08Revert "PCI: remove default PCI expansion ROM memory allocation"Linus Torvalds
This reverts commit 9f8daccaa05c14e5643bdd4faf5aed9cc8e6f11e, which was reported to break X startup (xf86-video-ati-6.8.0). See http://bugs.freedesktop.org/show_bug.cgi?id=15523 for details. Reported-by: Laurence Withers <l@lwithers.me.uk> Cc: Gary Hade <garyhade@us.ibm.com> Cc: Greg KH <greg@kroah.com> Cc: Jan Beulich <jbeulich@novell.com> Cc: "Jun'ichi Nomura" <j-nomura@ce.jp.nec.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: [ALSA] soc at91 minor bug fixes [ALSA] soc - at91-pcm - Fix line wrapping pcspkr: fix dependancies
2008-05-08x86: cleanup PAT cpu validationThomas Gleixner
Move the scattered checks for PAT support to a single function. Its moved to addon_cpuid_features.c as this file is shared between 32 and 64 bit. Remove the manipulation of the PAT feature bit and just disable PAT in the PAT layer, based on the PAT bit provided by the CPU and the current CPU version/model white list. Change the boot CPU check so it works on Voyager somewhere in the future as well :) Also panic, when a secondary has PAT disabled but the primary one has alrady switched to PAT. We have no way to undo that. The white list is kept for now to ensure that we can rely on known to work CPU types and concentrate on the software induced problems instead of fighthing CPU erratas and subtle wreckage caused by not yet verified CPUs. Once the PAT code has stabilized enough, we can remove the white list and open the can of worms. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-08x86: GEODE: cache results from geode_has_vsa2() and uninlineAndres Salomon
This moves geode_has_vsa2 into a .c file, caches the result we get from the VSA virtual registers, and causes the function to no longer be inline. [akpm@linux-foundation.org: cleanup] Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-08x86: revert geode config dependencyThomas Gleixner
commit e26a28d190304d910ee49b81cbfe6d9241f56e86 x86: olpc build fix was a fix to a patch that was withdrawn/delayed and then erroneously commited to x86.git. Revert it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-07pcspkr: fix dependanciesStas Sergeev
fix pcspkr dependancies: make the pcspkr platform drivers to depend on a platform device, and not the other way around. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Dmitry Torokhov <dtor@mail.ru> CC: Vojtech Pavlik <vojtech@suse.cz> CC: Michael Opdenacker <michael-lists@free-electrons.com> [fixed for 2.6.26-rc1 by tiwai] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-06x86: fix PAE pmd_bad bootup warningHugh Dickins
Fix warning from pmd_bad() at bootup on a HIGHMEM64G HIGHPTE x86_32. That came from 9fc34113f6880b215cbea4e7017fc818700384c2 x86: debug pmd_bad(); but we understand now that the typecasting was wrong for PAE in the previous version: pagetable pages above 4GB looked bad and stopped Arjan from booting. And revert that cded932b75ab0a5f9181ee3da34a0a488d1a14fd x86: fix pmd_bad and pud_bad to support huge pages. It was the wrong way round: we shouldn't weaken every pmd_bad and pud_bad check to let huge pages slip through - in part they check that we _don't_ have a huge page where it's not expected. Put the x86 pmd_bad() and pud_bad() definitions back to what they have long been: they can be improved (x86_32 should use PTE_MASK, to stop PAE thinking junk in the upper word is good; and x86_64 should follow x86_32's stricter comparison, to stop thinking any subset of required bits is good); but that should be a later patch. Fix Hans' good observation that follow_page() will never find pmd_huge() because that would have already failed the pmd_bad test: test pmd_huge in between the pmd_none and pmd_bad tests. Tighten x86's pmd_huge() check? No, once it's a hugepage entry, it can get quite far from a good pmd: for example, PROT_NONE leaves it with only ACCESSED of the KERN_PGTABLE bits. However... though follow_page() contains this and another test for huge pages, so it's nice to keep it working on them, where does it actually get called on a huge page? get_user_pages() checks is_vm_hugetlb_page(vma) to to call alternative hugetlb processing, as does unmap_vmas() and others. Signed-off-by: Hugh Dickins <hugh@veritas.com> Earlier-version-tested-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jeff Chua <jeff.chua.linux@gmail.com> Cc: Hans Rosenfeld <hans.rosenfeld@amd.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched-fixes * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched-fixes: sched: default to n for GROUP_SCHED and FAIR_GROUP_SCHED sched: add optional support for CONFIG_HAVE_UNSTABLE_SCHED_CLOCK sched, x86: add HAVE_UNSTABLE_SCHED_CLOCK sched: fix cpu clock sched: fair-group: fix a Div0 error of the fair group scheduler sched: fix missing locking in sched_domains code sched: make clock sync tunable by architecture code sched: fix debugging sched: fix sched_info_switch not being called according to documentation sched: fix hrtick_start_fair and CPU-Hotplug sched: fix SCHED_FAIR wake-idle logic error sched: fix RT task-wakeup logic sched: add statics, don't return void expressions sched: add debug checks to idle functions sched: remove old sched doc sched: make rt_sched_class, idle_sched_class static sched: optimize calc_delta_mine() sched: fix normalized sleeper
2008-05-05sched, x86: add HAVE_UNSTABLE_SCHED_CLOCKIngo Molnar
add the HAVE_UNSTABLE_SCHED_CLOCK, for architectures to select. the next change utilizes it. Signed-off-by: Ingo Molnar <mingo@elte.hu>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: x86 PCI: call dmi_check_pciprobe() x86/pci: add pci=skip_isa_align command lines. x86/pci: remove flag in pci_cfg_space_size_ext x86: fix section mismatch in pci_scan_bus
2008-05-05x86 PCI: call dmi_check_pciprobe()Yinghai Lu
this change: | commit 08f1c192c3c32797068bfe97738babb3295bbf42 | Author: Muli Ben-Yehuda <muli@il.ibm.com> | Date: Sun Jul 22 00:23:39 2007 +0300 | | x86-64: introduce struct pci_sysdata to facilitate sharing of ->sysdata | | This patch introduces struct pci_sysdata to x86 and x86-64, and | converts the existing two users (NUMA, Calgary) to use it. | | This lays the groundwork for having other users of sysdata, such as | the PCI domains work. | | The Calgary bits are tested, the NUMA bits just look ok. replaces pcibios_scan_root with pci_scan_bus_parented... but in pcibios_scan_root we have a DMI check: dmi_check_system(pciprobe_dmi_table); when when have several peer root buses this could be called multiple times (which is bad), so move that call to pci_access_init(). Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-05-05x86/pci: add pci=skip_isa_align command lines.Yinghai Lu
so we don't align the io port start address for pci cards. also move out dmi check out acpi.c, because it has nothing to do with acpi. it could spare some calling when we have several peer root buses. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-05-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-fixes * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-fixes: x86: fix setup printk format warning x86: olpc build fix x86: video/fbdev.c: add MODULE_LICENSE x86: fix up bootparam.h for userspace inclusion x86: relocs ELF handling - use SELFMAG instead of numeric constant x86: vdso ELF handling - use SELFMAG instead of numeric constant x86: remove dell reboot dmi quirk board name match x86: es7000 build fix x86: make additional_cpus static x86: make start_secondary() static kbuild, suspend, x86: fix rebuild of wakeup.bin uml: fix gcc problem x86: undo visws/numaq build changes
2008-05-04x86: fix setup printk format warningRandy Dunlap
Fix x86 setup printk format warming: next-20080430/arch/x86/kernel/setup.c:172: warning: format '%lu' expects type 'long unsigned int', but argument 2 has type 'ssize_t' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: mingo@elte.hu Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-04x86: olpc build fixThomas Gleixner
CONFIG_OLPC needs to depend on MGEODE_LX Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-04x86: video/fbdev.c: add MODULE_LICENSEAdrian Bunk
Add the missing MODULE_LICENSE("GPL"). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-04x86: relocs ELF handling - use SELFMAG instead of numeric constantCyrill Gorcunov
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: akpm@linux-foundation.org Cc: hpa@zytor.com Cc: mingo@elte.hu Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-04x86: vdso ELF handling - use SELFMAG instead of numeric constantCyrill Gorcunov
2008-05-04x86: remove dell reboot dmi quirk board name matchBen
http://bugzilla.kernel.org/show_bug.cgi?id=10547 Newer Dell OptiPlex 745s hang before rebooting after 'sudo reboot'. A patch for some versions of the OptiPlex was proposed here -- http://lkml.org/lkml/2007/6/5/59 -- and is included in 2.6.23 and later kernels, according to http://lxr.linux.no/linux+v2.6.23/arch/i386/kernel/reboot.c . However, the DMI_BOARD_NAME ("0WF810") is too restrictive. Newer OptiPlex machines have a DMI_BOARD_NAME of "0RF703". I therefore suggest adding another clause to reboot.c, similar to the one in the original patch, but matching a DMI_BOARD_NAME of "0RF703". On further inspection, it seems that there are other DMI_BOARD_NAMEs for this same machine. They seem to change from time to time, which means that the current code is fragile. Moreover, using bios reboot should not break non-SFF OptiPlex 745s, and so a reasonable fix is to simply drop the match on DMI_BOARD_NAME. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-04x86: es7000 build fixIngo Molnar
2008-05-04x86: make additional_cpus staticAdrian Bunk
This patch makes the needlessly global additional_cpus static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-04x86: make start_secondary() staticAdrian Bunk
start_secondary() needlessly became global. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-04kbuild, suspend, x86: fix rebuild of wakeup.binSam Ravnborg
In kernel/acpi/realmode/Makefile use the 'always' variable to say that wakeup.bin should always be made. In acpi/Makefile we then do not need to specify the requested target and we avoid the message from make: `arch/x86/kernel/acpi/realmode/wakeup.bin' is up to date. Add wakeup.lds to list af targets to avoid rebuilding wakeup.bin - from Roland McGrath. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@suse.cz> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-04x86: undo visws/numaq build changesThomas Gleixner
arch/x86/pci/Makefile_32 has a nasty detail. VISWS and NUMAQ build override the generic pci-y rules. This needs a proper cleanup, but that needs more thoughts. Undo commit 895d30935ebe05f192e844792668bf8d19deaae7 x86: numaq fix do not override the existing pci-y rule when adding visws or numaq rules. There is also a stupid init function ordering problem vs. acpi.o Add comments to the Makefile to avoid tripping over this again. Remove the srat stub code in discontig_32.c to allow a proper NUMAQ build. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-04x86: KVM geust: make setup_secondary_clock definition dependent on local apicGlauber Costa
Since the pv_apic_ops are only present if CONFIG_X86_LOCAL_APIC is compiled in, kvmclock failed to build without this option. This patch fixes this. Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: MMU: Allow more than PAGES_PER_HPAGE write protections per large pageAvi Kivity
nonpae guests can call rmap_write_protect twice per page (for page tables) or four times per page (for page directories), triggering a bogus warning. Remove the warning. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: avoid fx_init() schedule in atomicAndrea Arcangeli
This make sure not to schedule in atomic during fx_init. I also changed the name of fpu_init to fx_finit to avoid duplicating the name with fpu_init that is already used in the kernel, this makes grep simpler if nothing else. Signed-off-by: Andrea Arcangeli <andrea@qumranet.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: Avoid spurious execeptions after setting registersJan Kiszka
Clear pending exceptions when setting new register values. This avoids spurious exceptions after restoring a vcpu state or after reset-on-triple-fault. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: PIT: support mode 4Marcelo Tosatti
The in-kernel PIT emulation ignores pending timers if operating under mode 4, which for example DragonFlyBSD uses (and Plan9 too, apparently). Mode 4 seems to be similar to one-shot mode, other than the fact that it starts counting after the next CLK pulse once programmed, while mode 1 starts counting immediately, so add a FIXME to enhance precision. Fixes sourceforge bug 1952988. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Acked-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: x86 emulator: disable writeback on lmswAvi Kivity
The recent changes allowing memory operands with lmsw and smsw left lmsw with writeback enabled. Since lmsw has no oridinary destination operand, the dst pointer was not initialized, resulting in an oops. Close the hole by disabling writeback for lmsw. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: x86: task switch: fix wrong bit setting for the busy flagIzik Eidus
The busy bit is bit 1 of the type field, not bit 8. Signed-off-by: Izik Eidus <izike@qumranet.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: VMX: Enable EPT feature for KVMSheng Yang
Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: VMX: Prepare an identity page table for EPT in real modeSheng Yang
[aliguory: plug leak] Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Anthony Liguori <aliguori@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
