commit f104765b4f81fd74d69e0eb161e89096deade2db upstream.
If hardware doesn't support DecodeAssist - a feature that provides
more information about the intercept in the VMCB, KVM decodes the
instruction and then updates the next_rip vmcb control field.
However, NRIP support itself depends on cpuid Fn8000_000A_EDX[NRIPS].
Since skip_emulated_instruction() doesn't verify nrip support
before accepting control.next_rip as valid, avoid writing this
field if support isn't present.
Signed-off-by: Bandan Das <bsd@redhat.com>
commit f84598bd7c851f8b0bf8cd0d7c3be0d73c432ff4 upstream.
mc_saved_tmp is a static array allocated on the stack, we need to make
sure mc_saved_count stays within its bounds, otherwise we're overflowing
the stack in _save_mc(). A specially crafted microcode header could lead
to a kernel crash or potentially kernel execution.
Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Link: http://lkml.kernel.org/r/1422964824-22056-1-git-send-email-quentin.casasnovas@oracle.com
Signed-off-by: Sheng Yong <shengyong1@huawei.com>
commit a6dfa128ce5c414ab46b1d690f7a1b8decb8526d upstream.
A huge amount of NIC drivers use the DMA API, however if
compiled under 32-bit an very important part of the DMA API can
be ommitted leading to the drivers not working at all
(especially if used with 'swiotlb=force iommu=soft').
As Prashant Sreedharan explains it: "the driver [tg3] uses
DEFINE_DMA_UNMAP_ADDR(), dma_unmap_addr_set() to keep a copy of
the dma "mapping" and dma_unmap_addr() to get the "mapping"
value. On most of the platforms this is a no-op, but ... with
"iommu=soft and swiotlb=force" this house keeping is required,
... otherwise we pass 0 while calling pci_unmap_/pci_dma_sync_
instead of the DMA address."
As such enable this even when using 32-bit kernels.
Reported-by: Ian Jackson <Ian.Jackson@eu.citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Prashant Sreedharan <prashant@broadcom.com>
Cc: Michael Chan <mchan@broadcom.com>
Cc: boris.ostrovsky@oracle.com
Cc: cascardo@linux.vnet.ibm.com
Cc: david.vrabel@citrix.com
Cc: sanjeevb@broadcom.com
Cc: siva.kallam@broadcom.com
Cc: vyasevich@gmail.com
Cc: xen-devel@lists.xensource.com
Link: http://lkml.kernel.org/r/20150417190448.GA9462@l.oracle.com
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 898761158be7682082955e3efa4ad24725305fc7 upstream.
smep_andnot_wp is initialized in kvm_init_shadow_mmu and shadow pages
should not be reused for different values of it. Thus, it has to be
added to the mask in kvm_mmu_pte_write.
Reviewed-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
commit 7f8998c7aef3ac9c5f3f2943e083dfa6302e90d0 upstream.
The different architectures used their own (and different) declarations:
extern __visible const void __nosave_begin, __nosave_end;
extern const void __nosave_begin, __nosave_end;
extern long __nosave_begin, __nosave_end;
Consolidate them using the first variant in <asm/sections.h>.
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
commit 7fb08eca45270d0ae86e1ad9d39c40b7a55d0190 upstream.
This replaces four copies in various stages of mm_fault_error() handling
with just a single one. It will also allow for more natural placement
of the unlocking after some further cleanup.
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
[shengyong: Backport to 3.10
- adjust context
- ignore modification for arch nios2, because 3.10 does not support it
- ignore modification for driver lustre, because 3.10 does not support it
- ignore VM_FAULT_FALLBACK in VM_FAULT_ERROR, becase 3.10 does not support
this flag
- add SIGSEGV handling to powerpc/cell spu_fault.c, because 3.10 does not
separate it to copro_fault.c
- add SIGSEGV handling in mm/memory.c, because 3.10 does not separate it
to gup.c
commit f3747379accba8e95d70cec0eae0582c8c182050 upstream.
SYSENTER emulation is broken in several ways:
1. It misses the case of 16-bit code segments completely (CVE-2015-0239).
2. MSR_IA32_SYSENTER_CS is checked in 64-bit mode incorrectly (bits 0 and 1 can
still be set without causing #GP).
3. MSR_IA32_SYSENTER_EIP and MSR_IA32_SYSENTER_ESP are not masked in
legacy-mode.
4. There is some unneeded code.
Fix it.
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
[zhangzhiqiang: backport to 3.10:
- adjust context
- in 3.10 context "ctxt->eflags &= ~(EFLG_VM | EFLG_IF | EFLG_RF)" is replaced by
"ctxt->eflags &= ~(EFLG_VM | EFLG_IF)" in upstream, which was changed by another commit.
- After the above adjustments, becomes same to the original patch:
https://github.com/torvalds/linux/commit/f3747379accba8e95d70cec0eae0582c8c182050
Signed-off-by: Zhiqiang Zhang <zhangzhiqiang.zhang@huawei.com>
commit e893286918d2cde3a94850d8f7101cd1039e0c62 upstream.
On gcc5 the kernel does not link:
ld: .eh_frame_hdr table[4] FDE at 0000000000000648 overlaps table[5] FDE at 0000000000000670.
Because prior GCC versions always emitted NOPs on ALIGN directives, but
gcc5 started omitting them.
.LSTARTFDEDLSI1 says:
/* HACK: The dwarf2 unwind routines will subtract 1 from the
return address to get an address in the middle of the
presumed call instruction. Since we didn't get here via
a call, we need to include the nop before the real start
to make up for it. */
.long .LSTART_sigreturn-1-. /* PC-relative start address */
But commit 69d0627a7f6e ("x86 vDSO: reorder vdso32 code") from 2.6.25
replaced .org __kernel_vsyscall+32,0x90 by ALIGN right before
__kernel_sigreturn.
Of course, ALIGN need not generate any NOP in there. Esp. gcc5 collapses
vclock_gettime.o and int80.o together with no generated NOPs as "ALIGN".
So fix this by adding to that point at least a single NOP and make the
function ALIGN possibly with more NOPs then.
Kudos for reporting and diagnosing should go to Richard.
Reported-by: Richard Biener <rguenther@suse.de>
Acked-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/1425543211-12542-1-git-send-email-jslaby@suse.cz
commit f4c3686386393c120710dd34df2a74183ab805fd upstream.
drop_fpu() does clear_used_math() and usually this is correct
because tsk == current.
However switch_fpu_finish()->restore_fpu_checking() is called before
__switch_to() updates the "current_task" variable. If it fails,
we will wrongly clear the PF_USED_MATH flag of the previous task.
So use clear_stopped_child_used_math() instead.
Cc: Pekka Riikonen <priikone@iki.fi>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Cc: Suresh Siddha <sbsiddha@gmail.com>
Link: http://lkml.kernel.org/r/20150309171041.GB11388@redhat.com
__restore_xstate_sig()
commit a7c80ebcac3068b1c3cb27d538d29558c30010c8 upstream.
math_state_restore() assumes it is called with irqs disabled,
but this is not true if the caller is __restore_xstate_sig().
This means that if ia32_fxstate == T and __copy_from_user()
fails, __restore_xstate_sig() returns with irqs disabled too.
This triggers:
BUG: sleeping function called from invalid context at kernel/locking/rwsem.c:41
dump_stack
___might_sleep
? _raw_spin_unlock_irqrestore
__might_sleep
down_read
print_vma_addr
signal_fault
sys32_rt_sigreturn
Change __restore_xstate_sig() to call set_used_math()
unconditionally. This avoids enabling and disabling interrupts
in math_state_restore(). If copy_from_user() fails, we can
simply do fpu_finit() by hand.
[ Note: this is only the first step. math_state_restore() should
not check used_math(), it should set this flag. While
init_fpu() should simply die. ]
Link: http://lkml.kernel.org/r/20150307153844.GB25954@redhat.com
commit ccfe8c3f7e52ae83155cb038753f4c75b774ca8a upstream.
The kernel crypto API logic requires the caller to provide the
length of (ciphertext || authentication tag) as cryptlen for the
AEAD decryption operation. Thus, the cipher implementation must
calculate the size of the plaintext output itself and cannot simply use
cryptlen.
The RFC4106 GCM decryption operation tries to overwrite cryptlen memory
in req->dst. As the destination buffer for decryption only needs to hold
the plaintext memory but cryptlen references the input buffer holding
(ciphertext || authentication tag), the assumption of the destination
buffer length in RFC4106 GCM operation leads to a too large size. This
patch simply uses the already calculated plaintext size.
In addition, this patch fixes the offset calculation of the AAD buffer
pointer: as mentioned before, cryptlen already includes the size of the
tag. Thus, the tag does not need to be added. With the addition, the AAD
will be written beyond the already allocated buffer.
Note, this fixes a kernel crash that can be triggered from user space
via AF_ALG(aead) -- simply use the libkcapi test application
from [1] and update it to use rfc4106-gcm-aes.
Using [1], the changes were tested using CAVS vectors to demonstrate
that the crypto operation still delivers the right results.
[1] http://www.chronox.de/libkcapi.html
CC: Tadeusz Struk <tadeusz.struk@intel.com>
Signed-off-by: Stephan Mueller <smueller@chronox.de>
commit 4ff6f8e61eb7f96d3ca535c6d240f863ccd6fb7d upstream.
This has been broken for a long time: it broke first in 2.6.35, then was
almost fixed in 2.6.36 but this one-liner slipped through the cracks.
The bug shows up as an infinite loop in Windows 7 (and newer) boot on
32-bit hosts without EPT.
Windows uses CMPXCHG8B to write to page tables, which causes a
page fault if running without EPT; the emulator is then called from
kvm_mmu_page_fault. The loop then happens if the higher 4 bytes are
not 0; the common case for this is that the NX bit (bit 63) is 1.
Fixes: 6550e1f165f384f3a46b60a1be9aba4bc3c2adad
Fixes: 16518d5ada690643453eb0aef3cc7841d3623c2d
Reported-by: Erik Rull <erik.rull@rdsoftware.de>
Tested-by: Erik Rull <erik.rull@rdsoftware.de>
commit 956421fbb74c3a6261903f3836c0740187cf038b upstream.
'ret_from_fork' checks TIF_IA32 to determine whether 'pt_regs' and
the related state make sense for 'ret_from_sys_call'. This is
entirely the wrong check. TS_COMPAT would make a little more
sense, but there's really no point in keeping this optimization
at all.
This fixes a return to the wrong user CS if we came from int
0x80 in a 64-bit task.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/4710be56d76ef994ddf59087aad98c000fbab9a4.1424989793.git.luto@amacapital.net
[ Backported from tip:x86/asm. ]
commit 4e7c22d447bb6d7e37bfe39ff658486ae78e8d77 upstream.
The issue is that the stack for processes is not properly randomized on
64 bit architectures due to an integer overflow.
The affected function is randomize_stack_top() in file
"fs/binfmt_elf.c":
static unsigned long randomize_stack_top(unsigned long stack_top)
unsigned int random_variable = 0;
if ((current->flags & PF_RANDOMIZE) &&
!(current->personality & ADDR_NO_RANDOMIZE)) {
random_variable = get_random_int() & STACK_RND_MASK;
random_variable <<= PAGE_SHIFT;
return PAGE_ALIGN(stack_top) + random_variable;
return PAGE_ALIGN(stack_top) - random_variable;
Note that, it declares the "random_variable" variable as "unsigned int".
Since the result of the shifting operation between STACK_RND_MASK (which
is 0x3fffff on x86_64, 22 bits) and PAGE_SHIFT (which is 12 on x86_64):
then the two leftmost bits are dropped when storing the result in the
"random_variable". This variable shall be at least 34 bits long to hold
the (22+12) result.
These two dropped bits have an impact on the entropy of process stack.
Concretely, the total stack entropy is reduced by four: from 2^28 to
2^30 (One fourth of expected entropy).
This patch restores back the entropy by correcting the types involved
in the operations in the functions randomize_stack_top() and
stack_maxrandom_size().
The successful fix can be tested with:
$ for i in `seq 1 10`; do cat /proc/self/maps | grep stack; done
7ffeda566000-7ffeda587000 rw-p 00000000 00:00 0 [stack]
7fff5a332000-7fff5a353000 rw-p 00000000 00:00 0 [stack]
7ffcdb7a1000-7ffcdb7c2000 rw-p 00000000 00:00 0 [stack]
7ffd5e2c4000-7ffd5e2e5000 rw-p 00000000 00:00 0 [stack]
Once corrected, the leading bytes should be between 7ffc and 7fff,
rather than always being 7fff.
Signed-off-by: Hector Marco-Gisbert <hecmargi@upv.es>
Signed-off-by: Ismael Ripoll <iripoll@upv.es>
[ Rebased, fixed 80 char bugs, cleaned up commit message, added test example and CVE ]
Fixes: CVE-2015-1593
Link: http://lkml.kernel.org/r/20150214173350.GA18393@www.outflux.net
commit 7f187922ddf6b67f2999a76dcb71663097b75497 upstream.
When the guest writes to the TSC, the masterclock TSC copy must be
updated as well along with the TSC_OFFSET update, otherwise a negative
tsc_timestamp is calculated at kvm_guest_time_update.
Once "if (!vcpus_matched && ka->use_master_clock)" is simplified to
"if (ka->use_master_clock)", the corresponding "if (!ka->use_master_clock)"
becomes redundant, so remove the do_request boolean and collapse
everything into a single condition.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit d974baa398f34393db76be45f7d4d04fbdbb4a0a upstream.
CR4 isn't constant; at least the TSD and PCE bits can vary.
TBH, treating CR0 and CR3 as constant scares me a bit, too, but it looks
like it's correct.
This adds a branch and a read from cr4 to each vm entry. Because it is
extremely likely that consecutive entries into the same vcpu will have
the same host cr4 value, this fixes up the vmcs instead of restoring cr4
after the fact. A subsequent patch will add a kernel-wide cr4 shadow,
reducing the overhead in the common case to just two memory reads and a
branch.
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: Petr Matousek <pmatouse@redhat.com>
Cc: Gleb Natapov <gleb@kernel.org>
[wangkai: Backport to 3.10: adjust context]
Signed-off-by: Wang Kai <morgan.wang@huawei.com>
commit a642fc305053cc1c6e47e4f4df327895747ab485 upstream.
On systems with invvpid instruction support (corresponding bit in
IA32_VMX_EPT_VPID_CAP MSR is set) guest invocation of invvpid
causes vm exit, which is currently not handled and results in
propagation of unknown exit to userspace.
Fix this by installing an invvpid vm exit handler.
This is CVE-2014-3646.
Cc: stable@vger.kernel.org
Signed-off-by: Petr Matousek <pmatouse@redhat.com>
commit 51ac3d2f0c505ca36ffc9715ffd518d756589ef8 upstream.
NEC OEMs the same platforms as Stratus does, which have multiple devices on
some PCIe buses under downstream ports.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=51331
Fixes: 1278998f8ff6 ("PCI: Work around Stratus ftServer broken PCIe hierarchy (fix DMI check)")
Signed-off-by: Charlotte Richardson <charlotte.richardson@stratus.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: Myron Stowe <myron.stowe@redhat.com>
commit 4943ba16bbc2db05115707b3ff7b4874e9e3c560 upstream.
This adds the module loading prefix "crypto-" to the template lookup
as well.
For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly
includes the "crypto-" prefix at every level, correctly rejecting "vfat":
net-pf-38
algif-hash
crypto-vfat(blowfish)
crypto-vfat(blowfish)-all
crypto-vfat
Reported-by: Mathias Krause <minipli@googlemail.com>
Acked-by: Mathias Krause <minipli@googlemail.com>
commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
commit 7ddc6a2199f1da405a2fb68c40db8899b1a8cd87 upstream.
These functions can be executed on the int3 stack, so kprobes
are dangerous. Tracing is probably a bad idea, too.
Fixes: b645af2d5905 ("x86_64, traps: Rework bad_iret")
Link: http://lkml.kernel.org/r/50e33d26adca60816f3ba968875801652507d0c4.1416870125.git.luto@amacapital.net
[bwh: Backported to 3.10:
- Use __kprobes instead of NOKPROBE_SYMBOL()
- Adjust context]
commit 3669ef9fa7d35f573ec9c0e0341b29251c2734a7 upstream.
The Witcher 2 did something like this to allocate a TLS segment index:
struct user_desc u_info;
bzero(&u_info, sizeof(u_info));
u_info.entry_number = (uint32_t)-1;
syscall(SYS_set_thread_area, &u_info);
Strictly speaking, this code was never correct. It should have set
read_exec_only and seg_not_present to 1 to indicate that it wanted
to find a free slot without putting anything there, or it should
have put something sensible in the TLS slot if it wanted to allocate
a TLS entry for real. The actual effect of this code was to
allocate a bogus segment that could be used to exploit espfix.
The set_thread_area hardening patches changed the behavior, causing
set_thread_area to return -EINVAL and crashing the game.
This changes set_thread_area to interpret this as a request to find
a free slot and to leave it empty, which isn't *quite* what the game
expects but should be close enough to keep it working. In
particular, using the code above to allocate two segments will
allocate the same segment both times.
According to FrostbittenKing on Github, this fixes The Witcher 2.
If this somehow still causes problems, we could instead allocate
a limit==0 32-bit data segment, but that seems rather ugly to me.
Fixes: 41bdc78544b8 x86/tls: Validate TLS entries to protect espfix
Cc: torvalds@linux-foundation.org
Link: http://lkml.kernel.org/r/0cb251abe1ff0958b8e468a9a9a905b80ae3a746.1421954363.git.luto@amacapital.net
commit e30ab185c490e9a9381385529e0fd32f0a399495 upstream.
32-bit programs don't have an lm bit in their ABI, so they can't
reliably cause LDT_empty to return true without resorting to memset.
They shouldn't need to do this.
This should fix a longstanding, if minor, issue in all 64-bit kernels
as well as a potential regression in the TLS hardening code.
Link: http://lkml.kernel.org/r/72a059de55e86ad5e2935c80aa91880ddf19d07c.1421954363.git.luto@amacapital.net
commit 520452172e6b318f3a8bd9d4fe1e25066393de25 upstream.
Many users see this message when booting without knowning that it is
of no importance and that TSC calibration may have succeeded by
another way.
As explained by Paul Bolle in
http://lkml.kernel.org/r/1348488259.1436.22.camel@x61.thuisdomein
"Fast TSC calibration failed" should not be considered as an error
since other calibration methods are being tried afterward. At most,
those send a warning if they fail (not an error). So let's change
the message from error to warning.
[ tglx: Make if pr_info. It's really not important at all ]
Fixes: c767a54ba065 x86/debug: Add KERN_<LEVEL> to bare printks, convert printks to pr_<level>
Signed-off-by: Alexandre Demers <alexandre.f.demers@gmail.com>
Link: http://lkml.kernel.org/r/1418106470-6906-1-git-send-email-alexandre.f.demers@gmail.com
commit 32c6590d126836a062b3140ed52d898507987017 upstream.
The Hyper-V clocksource is continuous; mark it accordingly.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Acked-by: jasowang@redhat.com
Cc: gregkh@linuxfoundation.org
Cc: devel@linuxdriverproject.org
Cc: olaf@aepfle.de
Cc: apw@canonical.com
Link: http://lkml.kernel.org/r/1421108762-3331-1-git-send-email-kys@microsoft.com
commit b485342bd79af363c77ef1a421c4a0aef2de9812 upstream.
Commit a074335a370e ("x86, um: Mark system call tables readonly") was
supposed to mark the sys_call_table in UML as RO by adding the const,
but it doesn't have the desired effect as it's nevertheless being placed
into the data section since __cacheline_aligned enforces sys_call_table
being placed into .data..cacheline_aligned instead. We need to use
the ____cacheline_aligned version instead to fix this issue.
Before:
$ nm -v arch/x86/um/sys_call_table_64.o | grep -1 "sys_call_table"
U sys_writev
0000000000000000 D sys_call_table
0000000000000000 D syscall_table_size
After:
U sys_writev
0000000000000000 R sys_call_table
Fixes: a074335a370e ("x86, um: Mark system call tables readonly")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit 237d28db036e411f22c03cfd5b0f6dc2aa9bf3bc upstream.
If the function graph tracer traces a jprobe callback, the system will
crash. This can easily be demonstrated by compiling the jprobe
sample module that is in the kernel tree, loading it and running the
function graph tracer.
# modprobe jprobe_example.ko
# echo function_graph > /sys/kernel/debug/tracing/current_tracer
# ls
The first two commands end up in a nice crash after the first fork.
(do_fork has a jprobe attached to it, so "ls" just triggers that fork)
The problem is caused by the jprobe_return() that all jprobe callbacks
must end with. The way jprobes works is that the function a jprobe
is attached to has a breakpoint placed at the start of it (or it uses
ftrace if fentry is supported). The breakpoint handler (or ftrace callback)
will copy the stack frame and change the ip address to return to the
jprobe handler instead of the function. The jprobe handler must end
with jprobe_return() which swaps the stack and does an int3 (breakpoint).
This breakpoint handler will then put back the saved stack frame,
simulate the instruction at the beginning of the function it added
a breakpoint to, and then continue on.
For function tracing to work, it hijakes the return address from the
stack frame, and replaces it with a hook function that will trace
the end of the call. This hook function will restore the return
address of the function call.
If the function tracer traces the jprobe handler, the hook function
for that handler will not be called, and its saved return address
will be used for the next function. This will result in a kernel crash.
To solve this, pause function tracing before the jprobe handler is called
and unpause it before it returns back to the function it probed.
Some other updates:
Used a variable "saved_sp" to hold kcb->jprobe_saved_sp. This makes the
code look a bit cleaner and easier to understand (various tries to fix
this bug required this change).
Note, if fentry is being used, jprobes will change the ip address before
the function graph tracer runs and it will not be able to trace the
function that the jprobe is probing.
Link: http://lkml.kernel.org/r/20150114154329.552437962@goodmis.org
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
commit af91568e762d04931dcbdd6bef4655433d8b9418 upstream.
The uncore_collect_events functions assumes that event group
might contain only uncore events which is wrong, because it
might contain any type of events.
This bug leads to uncore framework touching 'not' uncore events,
which could end up all sorts of bugs.
One was triggered by Vince's perf fuzzer, when the uncore code
touched breakpoint event private event space as if it was uncore
event and caused BUG:
BUG: unable to handle kernel paging request at ffffffff82822068
IP: [<ffffffff81020338>] uncore_assign_events+0x188/0x250
The code in uncore_assign_events() function was looking for
event->hw.idx data while the event was initialized as a
breakpoint with different members in event->hw union.
This patch forces uncore_collect_events() to collect only uncore
events.
Reported-by: Vince Weaver <vince@deater.net>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Yan, Zheng <zheng.z.yan@intel.com>
Link: http://lkml.kernel.org/r/1418243031-20367-2-git-send-email-jolsa@kernel.org
commit 1ddf0b1b11aa8a90cef6706e935fc31c75c406ba upstream.
In Linux 3.18 and below, GCC hoists the lsl instructions in the
pvclock code all the way to the beginning of __vdso_clock_gettime,
slowing the non-paravirt case significantly. For unknown reasons,
presumably related to the removal of a branch, the performance issue
is gone as of
e76b027e6408 x86,vdso: Use LSL unconditionally for vgetcpu
but I don't trust GCC enough to expect the problem to stay fixed.
There should be no correctness issue, because the __getcpu calls in
__vdso_vlock_gettime were never necessary in the first place.
Note to stable maintainers: In 3.18 and below, depending on
configuration, gcc 4.9.2 generates code like this:
9c3: 44 0f 03 e8 lsl %ax,%r13d
9c7: 45 89 eb mov %r13d,%r11d
9ca: 0f 03 d8 lsl %ax,%ebx
This patch won't apply as is to any released kernel, but I'll send a
trivial backported version if needed.
Backported by Andy Lutomirski. Should apply to all affected
versions. This fixes a functionality bug as well as a performance
bug: buggy kernels can infinite loop in __vdso_clock_gettime on
affected compilers. See, for exammple:
https://bugzilla.redhat.com/show_bug.cgi?id=1178975
Fixes: 51c19b4f5927 x86: vdso: pvclock gettime support
Cc: Marcelo Tosatti <mtosatti@redhat.com>
commit 394f56fe480140877304d342dec46d50dc823d46 upstream.
The theory behind vdso randomization is that it's mapped at a random
offset above the top of the stack. To avoid wasting a page of
memory for an extra page table, the vdso isn't supposed to extend
past the lowest PMD into which it can fit. Other than that, the
address should be a uniformly distributed address that meets all of
the alignment requirements.
The current algorithm is buggy: the vdso has about a 50% probability
of being at the very end of a PMD. The current algorithm also has a
decent chance of failing outright due to incorrect handling of the
case where the top of the stack is near the top of its PMD.
This fixes the implementation. The paxtest estimate of vdso
"randomisation" improves from 11 bits to 18 bits. (Disclaimer: I
don't know what the paxtest code is actually calculating.)
It's worth noting that this algorithm is inherently biased: the vdso
is more likely to end up near the end of its PMD than near the
beginning. Ideally we would either nix the PMD sharing requirement
or jointly randomize the vdso and the stack to reduce the bias.
In the mean time, this is a considerable improvement with basically
no risk of compatibility issues, since the allowed outputs of the
algorithm are unchanged.
As an easy test, doing this:
for i in `seq 10000`
do grep -P vdso /proc/self/maps |cut -d- -f1
done |sort |uniq -d
used to produce lots of output (1445 lines on my most recent run).
A tiny subset looks like this:
7fffdfffe000
7fffe01fe000
7fffe05fe000
7fffe07fe000
7fffe09fe000
7fffe0bfe000
7fffe0dfe000
Note the suspicious fe000 endings. With the fix, I get a much more
palatable 76 repeated addresses.
commit 3fb2f4237bb452eb4e98f6a5dbd5a445b4fed9d0 upstream.
It turns out that there's a lurking ABI issue. GCC, when
compiling this in a 32-bit program:
struct user_desc desc = {
.entry_number = idx,
.base_addr = base,
.limit = 0xfffff,
.seg_32bit = 1,
.contents = 0, /* Data, grow-up */
.read_exec_only = 0,
.limit_in_pages = 1,
.seg_not_present = 0,
.useable = 0,
will leave .lm uninitialized. This means that anything in the
kernel that reads user_desc.lm for 32-bit tasks is unreliable.
Revert the .lm check in set_thread_area(). The value never did
anything in the first place.
Fixes: 0e58af4e1d21 ("x86/tls: Disallow unusual TLS segments")
Link: http://lkml.kernel.org/r/d7875b60e28c512f6a6fc0baf5714d58e7eaadbb.1418856405.git.luto@amacapital.net
commit 29fa6825463c97e5157284db80107d1bfac5d77b upstream.
paravirt_enabled has the following effects:
- Disables the F00F bug workaround warning. There is no F00F bug
workaround any more because Linux's standard IDT handling already
works around the F00F bug, but the warning still exists. This
is only cosmetic, and, in any event, there is no such thing as
KVM on a CPU with the F00F bug.
- Disables 32-bit APM BIOS detection. On a KVM paravirt system,
there should be no APM BIOS anyway.
- Disables tboot. I think that the tboot code should check the
CPUID hypervisor bit directly if it matters.
- paravirt_enabled disables espfix32. espfix32 should *not* be
disabled under KVM paravirt.
The last point is the purpose of this patch. It fixes a leak of the
high 16 bits of the kernel stack address on 32-bit KVM paravirt
guests. Fixes CVE-2014-8134.
Suggested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit f647d7c155f069c1a068030255c300663516420e upstream.
Otherwise, if buggy user code points DS or ES into the TLS
array, they would be corrupted after a context switch.
This also significantly improves the comments and documents some
gotchas in the code.
Before this patch, the both tests below failed. With this
patch, the es test passes, although the gsbase test still fails.
----- begin es test -----
* Copyright (c) 2014 Andy Lutomirski
* GPL v2
static unsigned short GDT3(int idx)
return (idx << 3) | 3;
static int create_tls(int idx, unsigned int base)
.base_addr = base,
.limit = 0xfffff,
.seg_32bit = 1,
.useable = 0,
if (syscall(SYS_set_thread_area, &desc) != 0)
err(1, "set_thread_area");
return desc.entry_number;
int main()
int idx = create_tls(-1, 0);
printf("Allocated GDT index %d\n", idx);
unsigned short orig_es;
asm volatile ("mov %%es,%0" : "=rm" (orig_es));
int errors = 0;
int total = 1000;
for (int i = 0; i < total; i++) {
asm volatile ("mov %0,%%es" : : "rm" (GDT3(idx)));
usleep(100);
unsigned short es;
asm volatile ("mov %%es,%0" : "=rm" (es));
asm volatile ("mov %0,%%es" : : "rm" (orig_es));
if (es != GDT3(idx)) {
if (errors == 0)
printf("[FAIL]\tES changed from 0x%hx to 0x%hx\n",
GDT3(idx), es);
errors++;
if (errors) {
printf("[FAIL]\tES was corrupted %d/%d times\n", errors, total);
return 1;
} else {
printf("[OK]\tES was preserved\n");
return 0;
----- end es test -----
----- begin gsbase test -----
* gsbase.c, a gsbase test
* GPL v2
static unsigned char *testptr, *testptr2;
static unsigned char read_gs_testvals(void)
unsigned char ret;
asm volatile ("movb %%gs:%1, %0" : "=r" (ret) : "m" (*testptr));
return ret;
int main()
int errors = 0;
testptr = mmap((void *)0x200000000UL, 1, PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_FIXED | MAP_ANONYMOUS, -1, 0);
if (testptr == MAP_FAILED)
err(1, "mmap");
testptr2 = mmap((void *)0x300000000UL, 1, PROT_READ | PROT_WRITE,
if (testptr2 == MAP_FAILED)
err(1, "mmap");
*testptr = 0;
*testptr2 = 1;
if (syscall(SYS_arch_prctl, ARCH_SET_GS,
(unsigned long)testptr2 - (unsigned long)testptr) != 0)
err(1, "ARCH_SET_GS");
usleep(100);
if (read_gs_testvals() == 1) {
printf("[OK]\tARCH_SET_GS worked\n");
} else {
printf("[FAIL]\tARCH_SET_GS failed\n");
errors++;
asm volatile ("mov %0,%%gs" : : "r" (0));
if (read_gs_testvals() == 0) {
printf("[OK]\tWriting 0 to gs worked\n");
} else {
printf("[FAIL]\tWriting 0 to gs failed\n");
errors++;
usleep(100);
printf("[OK]\tgsbase is still zero\n");
} else {
printf("[FAIL]\tgsbase was corrupted\n");
errors++;
return errors == 0 ? 0 : 1;
----- end gsbase test -----
Link: http://lkml.kernel.org/r/509d27c9fec78217691c3dad91cec87e1006b34a.1418075657.git.luto@amacapital.net
commit 0e58af4e1d2166e9e33375a0f121e4867010d4f8 upstream.
Users have no business installing custom code segments into the
GDT, and segments that are not present but are otherwise valid
are a historical source of interesting attacks.
For completeness, block attempts to set the L bit. (Prior to
this patch, the L bit would have been silently dropped.)
This is an ABI break. I've checked glibc, musl, and Wine, and
none of them look like they'll have any trouble.
Note to stable maintainers: this is a hardening patch that fixes
no known bugs. Given the possibility of ABI issues, this
probably shouldn't be backported quickly.
Acked-by: H. Peter Anvin <hpa@zytor.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Willy Tarreau <w@1wt.eu>
commit 41bdc78544b8a93a9c6814b8bbbfef966272abbe upstream.
Installing a 16-bit RW data segment into the GDT defeats espfix.
AFAICT this will not affect glibc, Wine, or dosemu at all.
commit bfd0a56b90005f8c8a004baf407ad90045c2b11e upstream.
If we let L1 use EPT, we should probably also support the INVEPT instruction.
In our current nested EPT implementation, when L1 changes its EPT table
for L2 (i.e., EPT12), L0 modifies the shadow EPT table (EPT02), and in
the course of this modification already calls INVEPT. But if last level
of shadow page is unsync not all L1's changes to EPT12 are intercepted,
which means roots need to be synced when L1 calls INVEPT. Global INVEPT
should not be different since roots are synced by kvm_mmu_load() each
time EPTP02 changes.
Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Signed-off-by: Nadav Har'El <nyh@il.ibm.com>
Signed-off-by: Jun Nakajima <jun.nakajima@intel.com>
Signed-off-by: Xinhao Xu <xinhao.xu@intel.com>
Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
[bwh: Backported to 3.2:
- Adjust context, filename
- Simplify handle_invept() as recommended by Paolo - nEPT is not
supported so we always raise #UD]
Cc: Vinson Lee <vlee@twopensource.com>
commit 82975bc6a6df743b9a01810fb32cb65d0ec5d60b upstream.
x86 call do_notify_resume on paranoid returns if TIF_UPROBE is set but
not on non-paranoid returns. I suspect that this is a mistake and that
the code only works because int3 is paranoid.
Setting _TIF_NOTIFY_RESUME in the uprobe code was probably a workaround
for the x86 bug. With that bug fixed, we can remove _TIF_NOTIFY_RESUME
from the uprobes code.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Acked-by: Borislav Petkov <bp@suse.de>
commit 45e2a9d4701d8c624d4a4bcdd1084eae31e92f58 upstream.
When setting up permissions on kernel memory at boot, the end of the
PMD that was split from bss remained executable. It should be NX like
the rest. This performs a PMD alignment instead of a PAGE alignment to
get the correct span of memory.
Before:
---[ High Kernel Mapping ]---
0xffffffff8202d000-0xffffffff82200000 1868K RW GLB NX pte
0xffffffff82200000-0xffffffff82c00000 10M RW PSE GLB NX pmd
0xffffffff82c00000-0xffffffff82df5000 2004K RW GLB NX pte
0xffffffff82df5000-0xffffffff82e00000 44K RW GLB x pte
0xffffffff82e00000-0xffffffffc0000000 978M pmd
After:
0xffffffff82200000-0xffffffff82e00000 12M RW PSE GLB NX pmd
[ tglx: Changed it to roundup(_brk_end, PMD_SIZE) and added a comment.
We really should unmap the reminder along with the holes
caused by init,initdata etc. but thats a different issue ]
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Wang Nan <wangnan0@huawei.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Link: http://lkml.kernel.org/r/20141114194737.GA3091@www.outflux.net
commit 2cd3949f702692cf4c5d05b463f19cd706a92dd3 upstream.
We have some very similarly named command-line options:
arch/x86/kernel/cpu/common.c:__setup("noxsave", x86_xsave_setup);
arch/x86/kernel/cpu/common.c:__setup("noxsaveopt", x86_xsaveopt_setup);
arch/x86/kernel/cpu/common.c:__setup("noxsaves", x86_xsaves_setup);
__setup() is designed to match options that take arguments, like
"foo=bar" where you would have:
__setup("foo", x86_foo_func...);
The problem is that "noxsave" actually _matches_ "noxsaves" in
the same way that "foo" matches "foo=bar". If you boot an old
kernel that does not know about "noxsaves" with "noxsaves" on the
command line, it will interpret the argument as "noxsave", which
is not what you want at all.
This makes the "noxsave" handler only return success when it finds
an *exact* match.
[ tglx: We really need to make __setup() more robust. ]
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Dave Hansen <dave@sr71.net>
Cc: x86@kernel.org
Link: http://lkml.kernel.org/r/20141111220133.FE053984@viggo.jf.intel.com
commit b645af2d5905c4e32399005b867987919cbfc3ae upstream.
It's possible for iretq to userspace to fail. This can happen because
of a bad CS, SS, or RIP.
Historically, we've handled it by fixing up an exception from iretq to
land at bad_iret, which pretends that the failed iret frame was really
the hardware part of #GP(0) from userspace. To make this work, there's
an extra fixup to fudge the gs base into a usable state.
This is suboptimal because it loses the original exception. It's also
buggy because there's no guarantee that we were on the kernel stack to
begin with. For example, if the failing iret happened on return from an
NMI, then we'll end up executing general_protection on the NMI stack.
This is bad for several reasons, the most immediate of which is that
general_protection, as a non-paranoid idtentry, will try to deliver
signals and/or schedule from the wrong stack.
This patch throws out bad_iret entirely. As a replacement, it augments
the existing swapgs fudge into a full-blown iret fixup, mostly written
in C. It's should be clearer and more correct.
commit 6f442be2fb22be02cafa606f1769fa1e6f894441 upstream.
On a 32-bit kernel, this has no effect, since there are no IST stacks.
On a 64-bit kernel, #SS can only happen in user code, on a failed iret
to user space, a canonical violation on access via RSP or RBP, or a
genuine stack segment violation in 32-bit kernel code. The first two
cases don't need IST, and the latter two cases are unlikely fatal bugs,
and promoting them to double faults would be fine.
This fixes a bug in which the espfix64 code mishandles a stack segment
violation.
This saves 4k of memory per CPU and a tiny bit of code.
commit af726f21ed8af2cdaa4e93098dc211521218ae65 upstream.
There's nothing special enough about the espfix64 double fault fixup to
justify writing it in assembly. Move it to C.
This also fixes a bug: if the double fault came from an IST stack, the
old asm code would return to a partially uninitialized stack frame.
Fixes: 3891a04aafd668686239349ea58f3314ea2af86b
commit 3a13c4d761b4b979ba8767f42345fed3274991b0 upstream.
The x86 fault handler bails in the middle of error handling when the
task has a fatal signal pending. For a subsequent patch this is a
problem in OOM situations because it relies on pagefault_out_of_memory()
being called even when the task has been killed, to perform proper
per-task OOM state unwinding.
Shortcutting the fault like this is a rather minor optimization that
saves a few instructions in rare cases. Just remove it for
user-triggered faults.
Use the opportunity to split the fault retry handling from actual fault
errors and add locking documentation that reads suprisingly similar to
ARM's.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: azurIt <azurit@pobox.sk>
commit 759496ba6407c6994d6a5ce3a5e74937d7816208 upstream.
Unlike global OOM handling, memory cgroup code will invoke the OOM killer
in any OOM situation because it has no way of telling faults occuring in
kernel context - which could be handled more gracefully - from
Pass a flag that identifies faults originating in user space from the
architecture-specific fault handlers to generic code so that memcg OOM
handling can be improved.
commit a2b9e6c1a35afcc0973acb72e591c714e78885ff upstream.
Commit fc3a9157d314 ("KVM: X86: Don't report L2 emulation failures to
user-space") disabled the reporting of L2 (nested guest) emulation failures to
userspace due to race-condition between a vmexit and the instruction emulator.
The same rational applies also to userspace applications that are permitted by
the guest OS to access MMIO area or perform PIO.
This patch extends the current behavior - of injecting a #UD instead of
reporting it to userspace - also for guest userspace code.
commit 1996388e9f4e3444db8273bc08d25164d2967c21 upstream.
This was discussed back in February:
https://lkml.org/lkml/2014/2/18/956
But I never saw a patch come out of it.
On IvyBridge we share the SandyBridge cache event tables, but the
dTLB-load-miss event is not compatible. Patch it up after
the fact to the proper DTLB_LOAD_MISSES.DEMAND_LD_MISS_CAUSES_A_WALK
Signed-off-by: Vince Weaver <vincent.weaver@maine.edu>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1407141528200.17214@vincent-weaver-1.umelst.maine.edu
Cc: Hou Pengyang <houpengyang@huawei.com>
commit 81f49a8fd7088cfcb588d182eeede862c0e3303e upstream.
is_compat_task() is the wrong check for audit arch; the check should
be is_ia32_task(): x32 syscalls should be AUDIT_ARCH_X86_64, not
AUDIT_ARCH_I386.
CONFIG_AUDITSYSCALL is currently incompatible with x32, so this has
no visible effect.
Link: http://lkml.kernel.org/r/a0138ed8c709882aec06e4acc30bfa9b623b8717.1409954077.git.luto@amacapital.net
commit b47dcbdc5161d3d5756f430191e2840d9b855492 upstream.
If the TSC is unusable or disabled, then this patch fixes:
- Confusion while trying to clear old APIC interrupts.
- Division by zero and incorrect programming of the TSC deadline
timer.
This fixes boot if the CPU has a TSC deadline timer but a missing or
broken TSC. The failure to boot can be observed with qemu using
-cpu qemu64,-tsc,+tsc-deadline
This also happens to me in nested KVM for unknown reasons.
With this patch, I can boot cleanly (although without a TSC).
Cc: Bandan Das <bsd@redhat.com>
Link: http://lkml.kernel.org/r/e2fa274e498c33988efac0ba8b7e3120f7f92d78.1413393027.git.luto@amacapital.net
commit 234f3ce485d54017f15cf5e0699cff4100121601 upstream.
Before changing rip (during jmp, call, ret, etc.) the target should be asserted
to be canonical one, as real CPUs do. During sysret, both target rsp and rip
should be canonical. If any of these values is noncanonical, a #GP exception
should occur. The exception to this rule are syscall and sysenter instructions
in which the assigned rip is checked during the assignment to the relevant
MSRs.
This patch fixes the emulator to behave as real CPUs do for near branches.
Far branches are handled by the next patch.
This fixes CVE-2014-3647.
