path: root/arch/x86
2016-11-11crypto: aesni: shut up -Wmaybe-uninitialized warningArnd Bergmann
The rfc4106 encrypy/decrypt helper functions cause an annoying false-positive warning in allmodconfig if we turn on -Wmaybe-uninitialized warnings again: arch/x86/crypto/aesni-intel_glue.c: In function ‘helper_rfc4106_decrypt’: include/linux/scatterlist.h:67:31: warning: ‘dst_sg_walk.sg’ may be used uninitialized in this function [-Wmaybe-uninitialized] The problem seems to be that the compiler doesn't track the state of the 'one_entry_in_sg' variable across the kernel_fpu_begin/kernel_fpu_end section. This takes the easy way out by adding a bogus initialization, which should be harmless enough to get the patch into v4.9 so we can turn on this warning again by default without producing useless output. A follow-up patch for v4.10 rearranges the code to make the warning go away. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-11x86: apm: avoid uninitialized dataArnd Bergmann
apm_bios_call() can fail, and return a status in its argument structure. If that status however is zero during a call from apm_get_power_status(), we end up using data that may have never been set, as reported by "gcc -Wmaybe-uninitialized": arch/x86/kernel/apm_32.c: In function ‘apm’: arch/x86/kernel/apm_32.c:1729:17: error: ‘bx’ may be used uninitialized in this function [-Werror=maybe-uninitialized] arch/x86/kernel/apm_32.c:1835:5: error: ‘cx’ may be used uninitialized in this function [-Werror=maybe-uninitialized] arch/x86/kernel/apm_32.c:1730:17: note: ‘cx’ was declared here arch/x86/kernel/apm_32.c:1842:27: error: ‘dx’ may be used uninitialized in this function [-Werror=maybe-uninitialized] arch/x86/kernel/apm_32.c:1731:17: note: ‘dx’ was declared here This changes the function to return "APM_NO_ERROR" here, which makes the code more robust to broken BIOS versions, and avoids the warning. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Jiri Kosina <jkosina@suse.cz> Reviewed-by: Luis R. Rodriguez <mcgrof@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-04Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Paolo Bonzini: "One NULL pointer dereference, and two fixes for regressions introduced during the merge window. The rest are fixes for MIPS, s390 and nested VMX" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: kvm: x86: Check memopp before dereference (CVE-2016-8630) kvm: nVMX: VMCLEAR an active shadow VMCS after last use KVM: x86: drop TSC offsetting kvm_x86_ops to fix KVM_GET/SET_CLOCK KVM: x86: fix wbinvd_dirty_mask use-after-free kvm/x86: Show WRMSR data is in hex kvm: nVMX: Fix kernel panics induced by illegal INVEPT/INVVPID types KVM: document lock orders KVM: fix OOPS on flush_work KVM: s390: Fix STHYI buffer alignment for diag224 KVM: MIPS: Precalculate MMIO load resume PC KVM: MIPS: Make ERET handle ERL before EXL KVM: MIPS: Fix lazy user ASID regenerate for SMP
2016-11-02kvm: x86: Check memopp before dereference (CVE-2016-8630)Owen Hofmann
Commit 41061cdb98 ("KVM: emulate: do not initialize memopp") removes a check for non-NULL under incorrect assumptions. An undefined instruction with a ModR/M byte with Mod=0 and R/M-5 (e.g. 0xc7 0x15) will attempt to dereference a null pointer here. Fixes: 41061cdb98a0bec464278b4db8e894a3121671f5 Message-Id: <1477592752-126650-2-git-send-email-osh@google.com> Signed-off-by: Owen Hofmann <osh@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-11-02kvm: nVMX: VMCLEAR an active shadow VMCS after last useJim Mattson
After a successful VM-entry with the "VMCS shadowing" VM-execution control set, the shadow VMCS referenced by the VMCS link pointer field in the current VMCS becomes active on the logical processor. A VMCS that is made active on more than one logical processor may become corrupted. Therefore, before an active VMCS can be migrated to another logical processor, the first logical processor must execute a VMCLEAR for the active VMCS. VMCLEAR both ensures that all VMCS data are written to memory and makes the VMCS inactive. Signed-off-by: Jim Mattson <jmattson@google.com> Reviewed-By: David Matlack <dmatlack@google.com> Message-Id: <1477668579-22555-1-git-send-email-jmattson@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-11-02KVM: x86: drop TSC offsetting kvm_x86_ops to fix KVM_GET/SET_CLOCKPaolo Bonzini
Since commit a545ab6a0085 ("kvm: x86: add tsc_offset field to struct kvm_vcpu_arch", 2016-09-07) the offset between host and L1 TSC is cached and need not be fished out of the VMCS or VMCB. This means that we can implement adjust_tsc_offset_guest and read_l1_tsc entirely in generic code. The simplification is particularly significant for VMX code, where vmx->nested.vmcs01_tsc_offset was duplicating what is now in vcpu->arch.tsc_offset. Therefore the vmcs01_tsc_offset can be dropped completely. More importantly, this fixes KVM_GET_CLOCK/KVM_SET_CLOCK which, after commit 108b249c453d ("KVM: x86: introduce get_kvmclock_ns", 2016-09-01) called read_l1_tsc while the VMCS was not loaded. It thus returned bogus values on Intel CPUs. Fixes: 108b249c453dd7132599ab6dc7e435a7036c193f Reported-by: Roman Kagan <rkagan@virtuozzo.com> Reviewed-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-10-29x86/smpboot: Init apic mapping before usageThomas Gleixner
The recent changes, which forced the registration of the boot cpu on UP systems, which do not have ACPI tables, have been fixed for systems w/o local APIC, but left a wreckage for systems which have neither ACPI nor mptables, but the CPU has an APIC, e.g. virtualbox. The boot process crashes in prefill_possible_map() as it wants to register the boot cpu, which needs to access the local apic, but the local APIC is not yet mapped. There is no reason why init_apic_mapping() can't be invoked before prefill_possible_map(). So instead of playing another silly early mapping game, as the ACPI/mptables code does, we just move init_apic_mapping() before the call to prefill_possible_map(). In hindsight, I should have noticed that combination earlier. Sorry for the churn (also in stable)! Fixes: ff8560512b8d ("x86/boot/smp: Don't try to poke disabled/non-existent APIC") Reported-and-debugged-by: Michal Necasek <michal.necasek@oracle.com> Reported-and-tested-by: Wolfgang Bauer <wbauer@tmo.at> Cc: prarit@redhat.com Cc: ville.syrjala@linux.intel.com Cc: michael.thayer@oracle.com Cc: knut.osmundsen@oracle.com Cc: frank.mehnert@oracle.com Cc: Borislav Petkov <bp@alien8.de> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1610282114380.5053@nanos Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-10-28Merge tag 'acpi-4.9-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI fixes from Rafael Wysocki: "These fix recent ACPICA regressions, an older PCI IRQ management regression, and an incorrect return value of a function in the APEI code. Specifics: - Fix three ACPICA issues related to the interpreter locking and introduced by recent changes in that area (Lv Zheng). - Fix a PCI IRQ management regression introduced during the 4.7 cycle and related to the configuration of shared IRQs on systems with an ISA bus (Sinan Kaya). - Fix up a return value of one function in the APEI code (Punit Agrawal)" * tag 'acpi-4.9-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPICA: Dispatcher: Fix interpreter locking around acpi_ev_initialize_region() ACPICA: Dispatcher: Fix an unbalanced lock exit path in acpi_ds_auto_serialize_method() ACPICA: Dispatcher: Fix order issue of method termination ACPI / APEI: Fix incorrect return value of ghes_proc() ACPI/PCI: pci_link: Include PIRQ_PENALTY_PCI_USING for ISA IRQs ACPI/PCI: pci_link: penalize SCI correctly ACPI/PCI/IRQ: assign ISA IRQ directly during early boot stages
2016-10-28Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc kernel fixes: a virtualization environment related fix, an uncore PMU driver removal handling fix, a PowerPC fix and new events for Knights Landing" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/intel: Honour the CPUID for number of fixed counters in hypervisors perf/powerpc: Don't call perf_event_disable() from atomic context perf/core: Protect PMU device removal with a 'pmu_bus_running' check, to fix CONFIG_DEBUG_TEST_DRIVER_REMOVE=y kernel panic perf/x86/intel/cstate: Add C-state residency events for Knights Landing
2016-10-28Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Misc fixes: three build fixes, an unwinder fix and a microcode loader fix" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/microcode/AMD: Fix more fallout from CONFIG_RANDOMIZE_MEMORY=y x86: Fix export for mcount and __fentry__ x86/quirks: Hide maybe-uninitialized warning x86/build: Fix build with older GCC versions x86/unwind: Fix empty stack dereference in guess unwinder
2016-10-28Merge tag 'drm-x86-pat-regression-fix' of ↵Linus Torvalds
git://people.freedesktop.org/~airlied/linux Pull drm x86/pat regression fixes from Dave Airlie: "This is a standalone pull request for the fix for a regression introduced in -rc1 by a change to vm_insert_mixed to start using the PAT range tracking to validate page protections. With this fix in place, all the VRAM mappings for GPU drivers ended up at UC instead of WC. There are probably better ways to fix this long term, but nothing I'd considered for -fixes that wouldn't need more settling in time. So I've just created a new arch API that the drivers can reserve all their VRAM aperture ranges as WC" * tag 'drm-x86-pat-regression-fix' of git://people.freedesktop.org/~airlied/linux: drm/drivers: add support for using the arch wc mapping API. x86/io: add interface to reserve io memtype for a resource range. (v1.1)
2016-10-28KVM: x86: fix wbinvd_dirty_mask use-after-freeIdo Yariv
vcpu->arch.wbinvd_dirty_mask may still be used after freeing it, corrupting memory. For example, the following call trace may set a bit in an already freed cpu mask: kvm_arch_vcpu_load vcpu_load vmx_free_vcpu_nested vmx_free_vcpu kvm_arch_vcpu_free Fix this by deferring freeing of wbinvd_dirty_mask. Cc: stable@vger.kernel.org Signed-off-by: Ido Yariv <ido@wizery.com> Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
2016-10-28perf/x86/intel: Honour the CPUID for number of fixed counters in hypervisorsImre Palik
perf doesn't seem to honour the number of fixed counters specified by CPUID leaf 0xa. It always assumes that Intel CPUs have at least 3 fixed counters. So if some of the fixed counters are masked out by the hypervisor, it still tries to check/set them. This patch makes perf behave nicer when the kernel is running under a hypervisor that doesn't expose all the counters. This patch contains some ideas from Matt Wilson. Signed-off-by: Imre Palik <imrep@amazon.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Andi Kleen <ak@linux.intel.com> Cc: Alexander Kozyrev <alexander.kozyrev@intel.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Artyom Kuanbekov <artyom.kuanbekov@intel.com> Cc: David Carrillo-Cisneros <davidcc@google.com> Cc: David Woodhouse <dwmw@amazon.co.uk> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Kan Liang <kan.liang@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matt Wilson <msw@amazon.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1477037939-15605-1-git-send-email-imrep.amz@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-28x86/microcode/AMD: Fix more fallout from CONFIG_RANDOMIZE_MEMORY=yBorislav Petkov
We needed the physical address of the container in order to compute the offset within the relocated ramdisk. And we did this by doing __pa() on the virtual address. However, __pa() does checks whether the physical address is within PAGE_OFFSET and __START_KERNEL_map - see __phys_addr() - which fail if we have CONFIG_RANDOMIZE_MEMORY enabled: we feed a virtual address which *doesn't* have the randomization offset into a function which uses PAGE_OFFSET which *does* have that offset. This makes this check fire: VIRTUAL_BUG_ON((x > y) || !phys_addr_valid(x)); ^^^^^^ due to the randomization offset. The fix is as simple as using __pa_nodebug() because we do that randomization offset accounting later in that function ourselves. Reported-by: Bob Peterson <rpeterso@redhat.com> Tested-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andreas Gruenbacher <agruenba@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mm <linux-mm@kvack.org> Cc: stable@vger.kernel.org # 4.9 Link: http://lkml.kernel.org/r/20161027123623.j2jri5bandimboff@pd.tnic Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-27kconfig.h: remove config_enabled() macroMasahiro Yamada
The use of config_enabled() is ambiguous. For config options, IS_ENABLED(), IS_REACHABLE(), etc. will make intention clearer. Sometimes config_enabled() has been used for non-config options because it is useful to check whether the given symbol is defined or not. I have been tackling on deprecating config_enabled(), and now is the time to finish this work. Some new users have appeared for v4.9-rc1, but it is trivial to replace them: - arch/x86/mm/kaslr.c replace config_enabled() with IS_ENABLED() because CONFIG_X86_ESPFIX64 and CONFIG_EFI are boolean. - include/asm-generic/export.h replace config_enabled() with __is_defined(). Then, config_enabled() can be removed now. Going forward, please use IS_ENABLED(), IS_REACHABLE(), etc. for config options, and __is_defined() for non-config symbols. Link: http://lkml.kernel.org/r/1476616078-32252-1-git-send-email-yamada.masahiro@socionext.com Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Cc: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Kees Cook <keescook@chromium.org> Cc: Michal Marek <mmarek@suse.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Thomas Garnier <thgarnie@google.com> Cc: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-27kvm/x86: Show WRMSR data is in hexBorislav Petkov
Add the "0x" prefix to the error messages format to make it unambiguous about what kind of value we're talking about. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: "Radim Krčmář" <rkrcmar@redhat.com> Message-Id: <20161027181445.25319-1-bp@alien8.de> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-10-27kvm: nVMX: Fix kernel panics induced by illegal INVEPT/INVVPID typesJim Mattson
Bitwise shifts by amounts greater than or equal to the width of the left operand are undefined. A malicious guest can exploit this to crash a 32-bit host, due to the BUG_ON(1)'s in handle_{invept,invvpid}. Signed-off-by: Jim Mattson <jmattson@google.com> Message-Id: <1477496318-17681-1-git-send-email-jmattson@google.com> [Change 1UL to 1, to match the range check on the shift count. - Paolo] Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-10-26x86: Fix export for mcount and __fentry__Steven Rostedt
Commit 784d5699eddc5 ("x86: move exports to actual definitions") removed the EXPORT_SYMBOL(__fentry__) and EXPORT_SYMBOL(mcount) from x8664_ksyms_64.c, and added EXPORT_SYMBOL(function_hook) in mcount_64.S instead. The problem is that function_hook isn't a function at all, but a macro that is defined as either mcount or __fentry__ depending on the support from gcc. Originally, I thought this was a macro issue, like what __stringify() is used for. But the problem is a bit deeper. The Makefile.build has some magic that does post processing of files to create the CRC bindings. It does some searches for EXPORT_SYMBOL() and because it finds a macro name and not the actual functions, this causes function_hook not to be converted into mcount or __fentry__ and they are missed. Instead of adding more magic to Makefile.build, just add EXPORT_SYMBOL() for mcount and __fentry__ where the ifdef is used. Since this is assembly and not C, it doesn't require being set after the function is defined. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Tested-by: Borislav Petkov <bp@alien8.de> Cc: Gabriel C <nix.or.die@gmail.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Link: http://lkml.kernel.org/r/20161024150148.4f9d90e4@gandalf.local.home Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-10-26x86/io: add interface to reserve io memtype for a resource range. (v1.1)Dave Airlie
A recent change to the mm code in: 87744ab3832b mm: fix cache mode tracking in vm_insert_mixed() started enforcing checking the memory type against the registered list for amixed pfn insertion mappings. It happens that the drm drivers for a number of gpus relied on this being broken. Currently the driver only inserted VRAM mappings into the tracking table when they came from the kernel, and userspace mappings never landed in the table. This led to a regression where all the mapping end up as UC instead of WC now. I've considered a number of solutions but since this needs to be fixed in fixes and not next, and some of the solutions were going to introduce overhead that hadn't been there before I didn't consider them viable at this stage. These mainly concerned hooking into the TTM io reserve APIs, but these API have a bunch of fast paths I didn't want to unwind to add this to. The solution I've decided on is to add a new API like the arch_phys_wc APIs (these would have worked but wc_del didn't take a range), and use them from the drivers to add a WC compatible mapping to the table for all VRAM on those GPUs. This means we can then create userspace mapping that won't get degraded to UC. v1.1: use CONFIG_X86_PAT + add some comments in io.h Cc: Toshi Kani <toshi.kani@hp.com> Cc: Borislav Petkov <bp@alien8.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Brian Gerst <brgerst@gmail.com> Cc: x86@kernel.org Cc: mcgrof@suse.com Cc: Dan Williams <dan.j.williams@intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2016-10-25x86/quirks: Hide maybe-uninitialized warningArnd Bergmann
gcc -Wmaybe-uninitialized detects that quirk_intel_brickland_xeon_ras_cap uses uninitialized data when CONFIG_PCI is not set: arch/x86/kernel/quirks.c: In function ‘quirk_intel_brickland_xeon_ras_cap’: arch/x86/kernel/quirks.c:641:13: error: ‘capid0’ is used uninitialized in this function [-Werror=uninitialized] However, the function is also not called in this configuration, so we can avoid the warning by moving the existing #ifdef to cover it as well. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: linux-pci@vger.kernel.org Link: http://lkml.kernel.org/r/20161024153325.2752428-1-arnd@arndb.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-25x86/build: Fix build with older GCC versionsJan Beulich
Older GCC (observed with 4.1.x) doesn't support -Wno-override-init and also doesn't ignore unknown -Wno-* options. Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu> Cc: Valdis.Kletnieks@vt.edu Fixes: 5e44258d16 "x86/build: Reduce the W=1 warnings noise when compiling x86 syscall tables" Link: http://lkml.kernel.org/r/580E3E1C02000078001191C4@prv-mh.provo.novell.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-25x86/unwind: Fix empty stack dereference in guess unwinderJosh Poimboeuf
Vince Waver reported the following bug: WARNING: CPU: 0 PID: 21338 at arch/x86/mm/fault.c:435 vmalloc_fault+0x58/0x1f0 CPU: 0 PID: 21338 Comm: perf_fuzzer Not tainted 4.8.0+ #37 Hardware name: Hewlett-Packard HP Compaq Pro 6305 SFF/1850, BIOS K06 v02.57 08/16/2013 Call Trace: <NMI> ? dump_stack+0x46/0x59 ? __warn+0xd5/0xee ? vmalloc_fault+0x58/0x1f0 ? __do_page_fault+0x6d/0x48e ? perf_log_throttle+0xa4/0xf4 ? trace_page_fault+0x22/0x30 ? __unwind_start+0x28/0x42 ? perf_callchain_kernel+0x75/0xac ? get_perf_callchain+0x13a/0x1f0 ? perf_callchain+0x6a/0x6c ? perf_prepare_sample+0x71/0x2eb ? perf_event_output_forward+0x1a/0x54 ? __default_send_IPI_shortcut+0x10/0x2d ? __perf_event_overflow+0xfb/0x167 ? x86_pmu_handle_irq+0x113/0x150 ? native_read_msr+0x6/0x34 ? perf_event_nmi_handler+0x22/0x39 ? perf_ibs_nmi_handler+0x4a/0x51 ? perf_event_nmi_handler+0x22/0x39 ? nmi_handle+0x4d/0xf0 ? perf_ibs_handle_irq+0x3d1/0x3d1 ? default_do_nmi+0x3c/0xd5 ? do_nmi+0x92/0x102 ? end_repeat_nmi+0x1a/0x1e ? entry_SYSCALL_64_after_swapgs+0x12/0x4a ? entry_SYSCALL_64_after_swapgs+0x12/0x4a ? entry_SYSCALL_64_after_swapgs+0x12/0x4a <EOE> ^A4---[ end trace 632723104d47d31a ]--- BUG: stack guard page was hit at ffffc90008500000 (stack is ffffc900084fc000..ffffc900084fffff) kernel stack overflow (page fault): 0000 [#1] SMP ... The NMI hit in the entry code right after setting up the stack pointer from 'cpu_current_top_of_stack', so the kernel stack was empty. The 'guess' version of __unwind_start() attempted to dereference the "top of stack" pointer, which is not actually *on* the stack. Add a check in the guess unwinder to deal with an empty stack. (The frame pointer unwinder already has such a check.) Reported-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 7c7900f89770 ("x86/unwind: Add new unwind interface and implementations") Link: http://lkml.kernel.org/r/20161024133127.e5evgeebdbohnmpb@treble Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-24Merge tag 'for-linus-4.9-rc2-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen fixes from David Vrabel: - advertise control feature flags in xenstore - fix x86 build when XEN_PVHVM is disabled * tag 'for-linus-4.9-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xenbus: check return value of xenbus_scanf() xenbus: prefer list_for_each() x86: xen: move cpu_up functions out of ifdef xenbus: advertise control feature flags
2016-10-24x86: xen: move cpu_up functions out of ifdefArnd Bergmann
Three newly introduced functions are not defined when CONFIG_XEN_PVHVM is disabled, but are still being used: arch/x86/xen/enlighten.c:141:12: warning: ‘xen_cpu_up_prepare’ used but never defined arch/x86/xen/enlighten.c:142:12: warning: ‘xen_cpu_up_online’ used but never defined arch/x86/xen/enlighten.c:143:12: warning: ‘xen_cpu_dead’ used but never defined Fixes: 4d737042d6c4 ("xen/x86: Convert to hotplug state machine") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2016-10-24ACPI/PCI: pci_link: penalize SCI correctlySinan Kaya
Ondrej reported that IRQs stopped working in v4.7 on several platforms. A typical scenario, from Ondrej's VT82C694X/694X, is: ACPI: Using PIC for interrupt routing ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 *11 12 14 15) ACPI: No IRQ available for PCI Interrupt Link [LNKA] 8139too 0000:00:0f.0: PCI INT A: no GSI We're using PIC routing, so acpi_irq_balance == 0, and LNKA is already active at IRQ 11. In that case, acpi_pci_link_allocate() only tries to use the active IRQ (IRQ 11) which also happens to be the SCI. We should penalize the SCI by PIRQ_PENALTY_PCI_USING, but irq_get_trigger_type(11) returns something other than IRQ_TYPE_LEVEL_LOW, so we penalize it by PIRQ_PENALTY_ISA_ALWAYS instead, which makes acpi_pci_link_allocate() assume the IRQ isn't available and give up. Add acpi_penalize_sci_irq() so platforms can tell us the SCI IRQ, trigger, and polarity directly and we don't have to depend on irq_get_trigger_type(). Fixes: 103544d86976 (ACPI,PCI,IRQ: reduce resource requirements) Link: http://lkml.kernel.org/r/201609251512.05657.linux@rainbow-software.org Reported-by: Ondrej Zary <linux@rainbow-software.org> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Sinan Kaya <okaya@codeaurora.org> Tested-by: Jonathan Liu <net147@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-10-22Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Three fixes, a hw-enablement and a cross-arch fix/enablement change: - SGI/UV fix for older platforms - x32 signal handling fix - older x86 platform bootup APIC fix - AVX512-4VNNIW (Neural Network Instructions) and AVX512-4FMAPS (Multiply Accumulation Single precision instructions) enablement. - move thread_info back into x86 specific code, to make life easier for other architectures trying to make use of CONFIG_THREAD_INFO_IN_TASK_STRUCT=y" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/boot/smp: Don't try to poke disabled/non-existent APIC sched/core, x86: Make struct thread_info arch specific again x86/signal: Remove bogus user_64bit_mode() check from sigaction_compat_abi() x86/platform/UV: Fix support for EFI_OLD_MEMMAP after BIOS callback updates x86/cpufeature: Add AVX512_4VNNIW and AVX512_4FMAPS features x86/vmware: Skip timer_irq_works() check on VMware
2016-10-22x86/boot/smp: Don't try to poke disabled/non-existent APICVille Syrjälä
Apparently trying to poke a disabled or non-existent APIC leads to a box that doesn't even boot. Let's not do that. No real clue if this is the right fix, but at least my P3 machine boots again. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bp@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Len Brown <len.brown@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yinghai Lu <yinghai@kernel.org> Cc: dyoung@redhat.com Cc: kexec@lists.infradead.org Cc: stable@vger.kernel.org Fixes: 2a51fe083eba ("arch/x86: Handle non enumerated CPU after physical hotplug") Link: http://lkml.kernel.org/r/1477102684-5092-1-git-send-email-ville.syrjala@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-21Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fixes from Radim Krčmář: "ARM: - avoid livelock when walking guest page tables - fix HYP mode static keys without CC_HAVE_ASM_GOTO MIPS: - fix a build error without TRACEPOINTS_ENABLED s390: - reject a malformed userspace configuration x86: - suppress a warning without CONFIG_CPU_FREQ - initialize whole irq_eoi array" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: arm/arm64: KVM: Map the BSS at HYP arm64: KVM: Take S1 walks into account when determining S2 write faults KVM: s390: reject invalid modes for runtime instrumentation kvm: x86: memset whole irq_eoi kvm/x86: Fix unused variable warning in kvm_timer_init() KVM: MIPS: Add missing uaccess.h include
2016-10-20kvm: x86: memset whole irq_eoiJiri Slaby
gcc 7 warns: arch/x86/kvm/ioapic.c: In function 'kvm_ioapic_reset': arch/x86/kvm/ioapic.c:597:2: warning: 'memset' used with length equal to number of elements without multiplication by element size [-Wmemset-elt-size] And it is right. Memset whole array using sizeof operator. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: x86@kernel.org Cc: kvm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: stable@vger.kernel.org Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> [Added x86 subject tag] Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
2016-10-20kvm/x86: Fix unused variable warning in kvm_timer_init()Borislav Petkov
When CONFIG_CPU_FREQ is not set, int cpu is unused and gcc rightfully warns about it: arch/x86/kvm/x86.c: In function ‘kvm_timer_init’: arch/x86/kvm/x86.c:5697:6: warning: unused variable ‘cpu’ [-Wunused-variable] int cpu; ^~~ But since it is used only in the CONFIG_CPU_FREQ block, simply move it there, thus squashing the warning too. Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
2016-10-20sched/core, x86: Make struct thread_info arch specific againHeiko Carstens
The following commit: c65eacbe290b ("sched/core: Allow putting thread_info into task_struct") ... made 'struct thread_info' a generic struct with only a single ::flags member, if CONFIG_THREAD_INFO_IN_TASK_STRUCT=y is selected. This change however seems to be quite x86 centric, since at least the generic preemption code (asm-generic/preempt.h) assumes that struct thread_info also has a preempt_count member, which apparently was not true for x86. We could add a bit more #ifdefs to solve this problem too, but it seems to be much simpler to make struct thread_info arch specific again. This also makes the conversion to THREAD_INFO_IN_TASK_STRUCT a bit easier for architectures that have a couple of arch specific stuff in their thread_info definition. The arch specific stuff _could_ be moved to thread_struct. However keeping them in thread_info makes it easier: accessing thread_info members is simple, since it is at the beginning of the task_struct, while the thread_struct is at the end. At least on s390 the offsets needed to access members of the thread_struct (with task_struct as base) are too large for various asm instructions. This is not a problem when keeping these members within thread_info. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: keescook@chromium.org Cc: linux-arch@vger.kernel.org Link: http://lkml.kernel.org/r/1476901693-8492-2-git-send-email-mark.rutland@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-20x86/signal: Remove bogus user_64bit_mode() check from sigaction_compat_abi()Dmitry Safonov
The recent introduction of SA_X32/IA32 sa_flags added a check for user_64bit_mode() into sigaction_compat_abi(). user_64bit_mode() is true for native 64-bit processes and x32 processes. Due to that the function returns w/o setting the SA_X32_ABI flag for X32 processes. In consequence the kernel attempts to deliver the signal to the X32 process in native 64-bit mode causing the process to segfault. Remove the check, so the actual check for X32 mode which sets the ABI flag can be reached. There is no side effect for native 64-bit mode. [ tglx: Rewrote changelog ] Fixes: 6846351052e6 ("x86/signal: Add SA_{X32,IA32}_ABI sa_flags") Reported-by: Mikulas Patocka <mpatocka@redhat.com> Tested-by: Adam Borowski <kilobyte@angband.pl> Signed-off-by: Dmitry Safonov <0x7f454c46@gmail.com> Cc: Dmitry Safonov <dsafonov@virtuozzo.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: linux-mm@kvack.org Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Pavel Emelyanov <xemul@virtuozzo.com> Link: http://lkml.kernel.org/r/CAJwJo6Z8ZWPqNfT6t-i8GW1MKxQrKDUagQqnZ%2B0%2B697%3DMyVeGg@mail.gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-20x86/platform/UV: Fix support for EFI_OLD_MEMMAP after BIOS callback updatesAlex Thorlton
Some time ago, we brought our UV BIOS callback code up to speed with the new EFI memory mapping scheme, in commit: d1be84a232e3 ("x86/uv: Update uv_bios_call() to use efi_call_virt_pointer()") By leveraging some changes that I made to a few of the EFI runtime callback mechanisms, in commit: 80e75596079f ("efi: Convert efi_call_virt() to efi_call_virt_pointer()") This got everything running smoothly on UV, with the new EFI mapping code. However, this left one, small loose end, in that EFI_OLD_MEMMAP (a.k.a. efi=old_map) will no longer work on UV, on kernels that include the aforementioned changes. At the time this was not a major issue (in fact, it still really isn't), but there's no reason that EFI_OLD_MEMMAP *shouldn't* work on our systems. This commit adds a check into uv_bios_call(), to see if we have the EFI_OLD_MEMMAP bit set in efi.flags. If it is set, we fall back to using our old callback method, which uses efi_call() directly on the __va() of our function pointer. Signed-off-by: Alex Thorlton <athorlton@sgi.com> Acked-by: Matt Fleming <matt@codeblueprint.co.uk> Cc: <stable@vger.kernel.org> # v4.7 and later Cc: Andy Lutomirski <luto@kernel.org> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Dimitri Sivanich <sivanich@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Mike Travis <travis@sgi.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russ Anderson <rja@sgi.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-efi@vger.kernel.org Link: http://lkml.kernel.org/r/1476928131-170101-1-git-send-email-athorlton@sgi.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-19Merge branch 'gup_flag-cleanups'Linus Torvalds
Merge the gup_flags cleanups from Lorenzo Stoakes: "This patch series adjusts functions in the get_user_pages* family such that desired FOLL_* flags are passed as an argument rather than implied by flags. The purpose of this change is to make the use of FOLL_FORCE explicit so it is easier to grep for and clearer to callers that this flag is being used. The use of FOLL_FORCE is an issue as it overrides missing VM_READ/VM_WRITE flags for the VMA whose pages we are reading from/writing to, which can result in surprising behaviour. The patch series came out of the discussion around commit 38e088546522 ("mm: check VMA flags to avoid invalid PROT_NONE NUMA balancing"), which addressed a BUG_ON() being triggered when a page was faulted in with PROT_NONE set but having been overridden by FOLL_FORCE. do_numa_page() was run on the assumption the page _must_ be one marked for NUMA node migration as an actual PROT_NONE page would have been dealt with prior to this code path, however FOLL_FORCE introduced a situation where this assumption did not hold. See https://marc.info/?l=linux-mm&m=147585445805166 for the patch proposal" Additionally, there's a fix for an ancient bug related to FOLL_FORCE and FOLL_WRITE by me. [ This branch was rebased recently to add a few more acked-by's and reviewed-by's ] * gup_flag-cleanups: mm: replace access_process_vm() write parameter with gup_flags mm: replace access_remote_vm() write parameter with gup_flags mm: replace __access_remote_vm() write parameter with gup_flags mm: replace get_user_pages_remote() write/force parameters with gup_flags mm: replace get_user_pages() write/force parameters with gup_flags mm: replace get_vaddr_frames() write/force parameters with gup_flags mm: replace get_user_pages_locked() write/force parameters with gup_flags mm: replace get_user_pages_unlocked() write/force parameters with gup_flags mm: remove write/force parameters from __get_user_pages_unlocked() mm: remove write/force parameters from __get_user_pages_locked() mm: remove gup_flags FOLL_WRITE games from __get_user_pages()
2016-10-19x86/cpufeature: Add AVX512_4VNNIW and AVX512_4FMAPS featuresPiotr Luc
AVX512_4VNNIW - Vector instructions for deep learning enhanced word variable precision. AVX512_4FMAPS - Vector instructions for deep learning floating-point single precision. These new instructions are to be used in future Intel Xeon & Xeon Phi processors. The bits 2&3 of CPUID[level:0x07, EDX] inform that new instructions are supported by a processor. The spec can be found in the Intel Software Developer Manual (SDM) or in the Instruction Set Extensions Programming Reference (ISE). Define new feature flags to enumerate the new instructions in /proc/cpuinfo accordingly to CPUID bits and add the required xsave extensions which are required for proper operation. Signed-off-by: Piotr Luc <piotr.luc@intel.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20161018150111.29926-1-piotr.luc@intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-10-19x86/vmware: Skip timer_irq_works() check on VMwareRenat Valiullin
The timer_irq_works() boot check may sometimes fail in a VM, when the Host is overcommitted or when the Guest is running nested. Since the intended check is unnecessary on VMware's virtual hardware, by-pass it. Signed-off-by: Renat Valiullin <rvaliullin@vmware.com> Acked-by: Alok N Kataria <akataria@vmware.com> Cc: virtualization@lists.linux-foundation.org Link: http://lkml.kernel.org/r/20161013184539.GA11497@rvaliullin-vm Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-10-19mm: replace access_process_vm() write parameter with gup_flagsLorenzo Stoakes
This removes the 'write' argument from access_process_vm() and replaces it with 'gup_flags' as use of this function previously silently implied FOLL_FORCE, whereas after this patch callers explicitly pass this flag. We make this explicit as use of FOLL_FORCE can result in surprising behaviour (and hence bugs) within the mm subsystem. Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-19mm: replace get_user_pages() write/force parameters with gup_flagsLorenzo Stoakes
This removes the 'write' and 'force' from get_user_pages() and replaces them with 'gup_flags' to make the use of FOLL_FORCE explicit in callers as use of this flag can result in surprising behaviour (and hence bugs) within the mm subsystem. Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Christian König <christian.koenig@amd.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-19perf/x86/intel/cstate: Add C-state residency events for Knights LandingLukasz Odzioba
Although KNL does support C1,C6,PC2,PC3,PC6 states, the patch only supports C6,PC2,PC3,PC6, because there is no counter for C1. C6 residency counter MSR on KNL has a different address than other platforms which is handled as a new quirk flag. Signed-off-by: Lukasz Odzioba <lukasz.odzioba@intel.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: bp@suse.de Cc: dave.hansen@linux.intel.com Cc: kan.liang@intel.com Link: http://lkml.kernel.org/r/1475598386-19597-1-git-send-email-lukasz.odzioba@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-18mm: replace get_user_pages_unlocked() write/force parameters with gup_flagsLorenzo Stoakes
This removes the 'write' and 'force' use from get_user_pages_unlocked() and replaces them with 'gup_flags' to make the use of FOLL_FORCE explicit in callers as use of this flag can result in surprising behaviour (and hence bugs) within the mm subsystem. Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com> Reviewed-by: Jan Kara <jack@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-18Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Misc fixes, plus hw-enablement changes: - fix persistent RAM handling - remove pkeys warning - remove duplicate macro - fix debug warning in irq handler - add new 'Knights Mill' CPU related constants and enable the perf bits" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/intel/uncore: Add Knights Mill CPUID perf/x86/intel/rapl: Add Knights Mill CPUID perf/x86/intel: Add Knights Mill CPUID x86/cpu/intel: Add Knights Mill to Intel family x86/e820: Don't merge consecutive E820_PRAM ranges pkeys: Remove easily triggered WARN x86: Remove duplicate rtit status MSR macro x86/smp: Add irq_enter/exit() in smp_reschedule_interrupt()
2016-10-18Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Four tooling fixes, two kprobes KASAN related fixes and an x86 PMU driver fix/cleanup" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf jit: Fix build issue on Ubuntu perf jevents: Handle events including .c and .o perf/x86/intel: Remove an inconsistent NULL check kprobes: Unpoison stack in jprobe_return() for KASAN kprobes: Avoid false KASAN reports during stack copy perf header: Set nr_numa_nodes only when we parsed all the data perf top: Fix refreshing hierarchy entries on TUI
2016-10-18Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking fixes from Ingo Molnar: "Two fixes: - a file locks fix (missing critical section, bug introduced in this merge window) - an x86 down_write() stack frame annotation" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking, fs/locks: Add missing file_sem locks locking/rwsem/x86: Add stack frame dependency for ____down_write()
2016-10-18locking/rwsem/x86: Add stack frame dependency for ____down_write()Josh Poimboeuf
Arnd reported the following objtool warning: kernel/locking/rwsem.o: warning: objtool: down_write_killable()+0x16: call without frame pointer save/setup The warning means gcc placed the ____down_write() inline asm (and its call instruction) before the frame pointer setup in down_write_killable(), which breaks frame pointer convention and can result in incorrect stack traces. Force the stack frame to be created before the call instruction by listing the stack pointer as an output operand in the inline asm statement. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1188b7015f04baf361e59de499ee2d7272c59dce.1476393828.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-17x86, pkeys: remove cruft from never-merged syscallsDave Hansen
pkey_set() and pkey_get() were syscalls present in older versions of the protection keys patches. The syscall number definitions were inadvertently left in place. This patch removes them. I did a git grep and verified that these are the last places in the tree that these appear, save for the protection_keys.c tests and Documentation. Those spots talk about functions called pkey_get/set() which are wrappers for the direct PKRU instructions, not the syscalls. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: mgorman@techsingularity.net Cc: arnd@arndb.de Cc: linux-api@vger.kernel.org Cc: linux-mm@kvack.org Cc: luto@kernel.org Cc: akpm@linux-foundation.org Fixes: f9afc6197e9bb ("x86: Wire up protection keys system calls") Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-17perf/x86/intel/uncore: Add Knights Mill CPUIDPiotr Luc
Add Knights Mill (KNM) to the list of CPUIDs supported by PMU. Signed-off-by: Piotr Luc <piotr.luc@intel.com> Reviewed-by: Dave Hansen <dave.hansen@intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20161012182758.2925-1-piotr.luc@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-17perf/x86/intel/rapl: Add Knights Mill CPUIDPiotr Luc
Add Knights Mill (KNM) to the list of CPUIDs supported by rapl. Signed-off-by: Piotr Luc <piotr.luc@intel.com> Reviewed-by: Dave Hansen <dave.hansen@intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20161012182725.2701-1-piotr.luc@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-17perf/x86/intel: Add Knights Mill CPUIDPiotr Luc
Add Knights Mill (KNM) to the list of CPUIDs supported by PMU. Signed-off-by: Piotr Luc <piotr.luc@intel.com> Reviewed-by: Dave Hansen <dave.hansen@intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20161012182634.2462-1-piotr.luc@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-17x86/cpu/intel: Add Knights Mill to Intel familyPiotr Luc
Add CPUID of Knights Mill (KNM) processor to Intel family list. Signed-off-by: Piotr Luc <piotr.luc@intel.com> Reviewed-by: Dave Hansen <dave.hansen@intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20161012180520.30976-1-piotr.luc@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-16perf/x86/intel: Remove an inconsistent NULL checkDan Carpenter
Smatch complains that we don't check "event->ctx" consistently. It's never NULL so we can just remove the check. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: David Carrillo-Cisneros <davidcc@google.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Kan Liang <kan.liang@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: kernel-janitors@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
