commit 3df8d9208569ef0b2313e516566222d745f3b94b upstream.
A typo (or mis-merge?) resulted in leaf 6 only being probed if
cpuid_level >= 7.
Fixes: 2ccd71f1b278 ("x86/cpufeature: Move some of the scattered feature bits to x86_capability")
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Acked-by: Borislav Petkov <bp@alien8.de>
Cc: Brian Gerst <brgerst@gmail.com>
Link: http://lkml.kernel.org/r/6ea30c0e9daec21e488b54761881a6dfcf3e04d0.1481825597.git.luto@kernel.org
commit a01aa6c9f40fe03c82032e7f8b3bcf1e6c93ac0e upstream.
As userspace knows nothing about kernel config, thus #ifdefs
around ABI prctl constants makes them invisible to userspace.
Let it be clean'n'simple: remove #ifdefs.
If kernel has CONFIG_CHECKPOINT_RESTORE disabled, sys_prctl()
will return -EINVAL for those prctls.
Reported-by: Paul Bolle <pebolle@tiscali.nl>
Signed-off-by: Dmitry Safonov <dsafonov@virtuozzo.com>
Acked-by: Andy Lutomirski <luto@kernel.org>
Cc: 0x7f454c46@gmail.com
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: linux-mm@kvack.org
Cc: oleg@redhat.com
Fixes: 2eefd8789698 ("x86/arch_prctl/vdso: Add ARCH_MAP_VDSO_*")
Link: http://lkml.kernel.org/r/20161027141516.28447-2-dsafonov@virtuozzo.com
commit 6ef4e07ecd2db21025c446327ecf34414366498b upstream.
Otherwise, mismatch between the smm bit in hflags and the MMU role
can cause a NULL pointer dereference.
Signed-off-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
commit 9d85eb9119f4eeeb48e87adfcd71f752655700e9 upstream.
The logical package management has several issues:
- The APIC ids provided by ACPI are not required to be the same as the
initial APIC id which can be retrieved by CPUID. The APIC ids provided
by ACPI are those which are written by the BIOS into the APIC. The
initial id is set by hardware and can not be changed. The hardware
provided ids contain the real hardware package information.
Especially AMD sets the effective APIC id different from the hardware id
as they need to reserve space for the IOAPIC ids starting at id 0.
As a consequence those machines trigger the currently active firmware
bug printouts in dmesg, These are obviously wrong.
- Virtual machines have their own interesting of enumerating APICs and
packages which are not reliably covered by the current implementation.
The sizing of the mapping array has been tweaked to be generously large to
handle systems which provide a wrong core count when HT is disabled so the
whole magic which checks for space in the physical hotplug case is not
needed anymore.
Simplify the whole machinery and do the mapping when the CPU starts and the
CPUID derived physical package information is available. This solves the
observed problems on AMD machines and works for the virtualization issues
as well.
Remove the extra call from XEN cpu bringup code as it is not longer
required.
Fixes: d49597fd3bc7 ("x86/cpu: Deal with broken firmware (VMWare/XEN)")
Reported-and-tested-by: Borislav Petkov <bp@suse.de>
Tested-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: M. Vefa Bicakci <m.v.b@runbox.com>
Cc: xen-devel <xen-devel@lists.xen.org>
Cc: Charles (Chas) Williams <ciwillia@brocade.com>
Cc: Alok Kataria <akataria@vmware.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1612121102260.3429@nanos
to it
commit 847fa1a6d3d00f3bdf68ef5fa4a786f644a0dd67 upstream.
With new binutils, gcc may get smart with its optimization and change a jmp
from a 5 byte jump to a 2 byte one even though it was jumping to a global
function. But that global function existed within a 2 byte radius, and gcc
was able to optimize it. Unfortunately, that jump was also being modified
when function graph tracing begins. Since ftrace expected that jump to be 5
bytes, but it was only two, it overwrote code after the jump, causing a
crash.
This was fixed for x86_64 with commit 8329e818f149, with the same subject as
this commit, but nothing was done for x86_32.
Fixes: d61f82d06672 ("ftrace: use dynamic patching for updating mcount calls")
Reported-by: Colin Ian King <colin.king@canonical.com>
Tested-by: Colin Ian King <colin.king@canonical.com>
commit ef85b67385436ddc1998f45f1d6a210f935b3388 upstream.
When L2 exits to L0 due to "exception or NMI", software exceptions
(#BP and #OF) for which L1 has requested an intercept should be
handled by L1 rather than L0. Previously, only hardware exceptions
were forwarded to L1.
Signed-off-by: Jim Mattson <jmattson@google.com>
commit 834fcd298003c10ce450e66960c78893cb1cc4b5 upstream.
If the pmu registration fails the registered hotplug callbacks are not
removed. Wrong in any case, but fatal in case of a modular driver.
Replace the nonsensical state names with proper ones while at it.
Fixes: 77c34ef1c319 ("perf/x86/intel/cstate: Convert Intel CSTATE to hotplug state machine")
Cc: Sebastian Siewior <bigeasy@linutronix.de>
commit b0c1ef52959582144bbea9a2b37db7f4c9e399f7 upstream.
An earlier patch allowed enabling PT and LBR at the same
time on Goldmont. However it also allowed enabling BTS and LBR
at the same time, which is still not supported. Fix this by
bypassing the check only for PT.
Cc: alexander.shishkin@intel.com
Cc: kan.liang@intel.com
Fixes: ccbebba4c6bf ("perf/x86/intel/pt: Bypass PT vs. LBR exclusivity if the core supports it")
Link: http://lkml.kernel.org/r/20161209001417.4713-1-andi@firstfloor.org
commit 334bb773876403eae3457d81be0b8ea70f8e4ccc upstream.
Commit 4efca4ed ("kbuild: modversions for EXPORT_SYMBOL() for asm") adds
modversion support for symbols exported from asm files. Architectures
must include C-style declarations for those symbols in asm/asm-prototypes.h
in order for them to be versioned.
Add these declarations for x86, and an architecture-independent file that
can be used for common symbols.
With f27c2f6 reverting 8ab2ae6 ("default exported asm symbols to zero") we
produce a scary warning on x86, this commit fixes that.
Signed-off-by: Adam Borowski <kilobyte@angband.pl>
Tested-by: Kalle Valo <kvalo@codeaurora.org>
Acked-by: Nicholas Piggin <npiggin@gmail.com>
Tested-by: Peter Wu <peter@lekensteyn.nl>
Tested-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Michal Marek <mmarek@suse.com>
Pull x86 fixes from Ingo Molnar:
"Misc fixes: a core dumping crash fix, a guess-unwinder regression fix,
plus three build warning fixes"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/unwind: Fix guess-unwinder regression
x86/build: Annotate die() with noreturn to fix build warning on clang
x86/platform/olpc: Fix resume handler build warning
x86/apic/uv: Silence a shift wrapping warning
x86/coredump: Always use user_regs_struct for compat_elf_gregset_t
Lukasz reported that perf stat counters overflow handling is broken on KNL/SLM.
Both these parts have full_width_write set, and that does indeed have
a problem. In order to deal with counter wrap, we must sample the
counter at at least half the counter period (see also the sampling
theorem) such that we can unambiguously reconstruct the count.
However commit:
069e0c3c4058 ("perf/x86/intel: Support full width counting")
sets the sampling interval to the full period, not half.
Fixing that exposes another issue, in that we must not sign extend the
delta value when we shift it right; the counter cannot have
decremented after all.
With both these issues fixed, counter overflow functions correctly
again.
Reported-by: Lukasz Odzioba <lukasz.odzioba@intel.com>
Tested-by: Liang, Kan <kan.liang@intel.com>
Tested-by: Odzioba, Lukasz <lukasz.odzioba@intel.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: stable@vger.kernel.org
Fixes: 069e0c3c4058 ("perf/x86/intel: Support full width counting")
The Knights Mill is enough close to Knights Landing so the path reuses
C-state residency support of the latter.
Signed-off-by: Piotr Luc <piotr.luc@intel.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/20161201000853.18260-1-piotr.luc@intel.com
My attempt at fixing some KASAN false positive warnings was rather brain
dead, and it broke the guess unwinder. With frame pointers disabled,
/proc/<pid>/stack is broken:
# cat /proc/1/stack
[<ffffffffffffffff>] 0xffffffffffffffff
Restore the code flow to more closely resemble its previous state, while
still using READ_ONCE_NOCHECK() macros to silence KASAN false positives.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Fixes: c2d75e03d630 ("x86/unwind: Prevent KASAN false positive warnings in guess unwinder")
Link: http://lkml.kernel.org/r/b824f92c2c22eca5ec95ac56bd2a7c84cf0b9df9.1480309971.git.jpoimboe@redhat.com
Fixes below warning with clang:
In file included from ../arch/x86/tools/relocs_64.c:17:
../arch/x86/tools/relocs.c:977:6: warning: variable 'do_reloc' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
Signed-off-by: Peter Foley <pefoley2@pefoley.com>
Link: http://lkml.kernel.org/r/20161126222229.673-1-pefoley2@pefoley.com
Fix:
arch/x86/platform/olpc/olpc-xo15-sci.c:199:12: warning: ‘xo15_sci_resume’
defined but not used [-Wunused-function]
static int xo15_sci_resume(struct device *dev)
which I see in randconfig builds here.
Link: http://lkml.kernel.org/r/20161126142706.13602-1-bp@alien8.de
Pull KVM fixes from Radim Krčmář:
"Four fixes for bugs found by syzkaller on x86, all for stable"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: x86: check for pic and ioapic presence before use
KVM: x86: fix out-of-bounds accesses of rtc_eoi map
KVM: x86: drop error recovery in em_jmp_far and em_ret_far
KVM: x86: fix out-of-bounds access in lapic
Split irqchip allows pic and ioapic routes to be used without them being
created, which results in NULL access. Check for NULL and avoid it.
(The setup is too racy for a nicer solutions.)
Found by syzkaller:
general protection fault: 0000 [#1] SMP DEBUG_PAGEALLOC KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 3 PID: 11923 Comm: kworker/3:2 Not tainted 4.9.0-rc5+ #27
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Workqueue: events irqfd_inject
task: ffff88006a06c7c0 task.stack: ffff880068638000
RIP: 0010:[...] [...] __lock_acquire+0xb35/0x3380 kernel/locking/lockdep.c:3221
RSP: 0000:ffff88006863ea20 EFLAGS: 00010006
RAX: dffffc0000000000 RBX: dffffc0000000000 RCX: 0000000000000000
RDX: 0000000000000039 RSI: 0000000000000000 RDI: 1ffff1000d0c7d9e
RBP: ffff88006863ef58 R08: 0000000000000001 R09: 0000000000000000
R10: 00000000000001c8 R11: 0000000000000000 R12: ffff88006a06c7c0
R13: 0000000000000001 R14: ffffffff8baab1a0 R15: 0000000000000001
FS: 0000000000000000(0000) GS:ffff88006d100000(0000) knlGS:0000000000000000
CR2: 00000000004abdd0 CR3: 000000003e2f2000 CR4: 00000000000026e0
Stack:
ffffffff894d0098 1ffff1000d0c7d56 ffff88006863ecd0 dffffc0000000000
ffff88006a06c7c0 0000000000000000 ffff88006863ecf8 0000000000000082
0000000000000000 ffffffff815dd7c1 ffffffff00000000 ffffffff00000000
Call Trace:
[...] lock_acquire+0x2a2/0x790 kernel/locking/lockdep.c:3746
[...] __raw_spin_lock include/linux/spinlock_api_smp.h:144
[...] _raw_spin_lock+0x38/0x50 kernel/locking/spinlock.c:151
[...] spin_lock include/linux/spinlock.h:302
[...] kvm_ioapic_set_irq+0x4c/0x100 arch/x86/kvm/ioapic.c:379
[...] kvm_set_ioapic_irq+0x8f/0xc0 arch/x86/kvm/irq_comm.c:52
[...] kvm_set_irq+0x239/0x640 arch/x86/kvm/../../../virt/kvm/irqchip.c:101
[...] irqfd_inject+0xb4/0x150 arch/x86/kvm/../../../virt/kvm/eventfd.c:60
[...] process_one_work+0xb40/0x1ba0 kernel/workqueue.c:2096
[...] worker_thread+0x214/0x18a0 kernel/workqueue.c:2230
[...] kthread+0x328/0x3e0 kernel/kthread.c:209
[...] ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:433
Fixes: 49df6397edfc ("KVM: x86: Split the APIC from the rest of IRQCHIP.")
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
KVM was using arrays of size KVM_MAX_VCPUS with vcpu_id, but ID can be
bigger that the maximal number of VCPUs, resulting in out-of-bounds
access.
Found by syzkaller:
BUG: KASAN: slab-out-of-bounds in __apic_accept_irq+0xb33/0xb50 at addr [...]
Write of size 1 by task a.out/27101
CPU: 1 PID: 27101 Comm: a.out Not tainted 4.9.0-rc5+ #49
Call Trace:
[...] __apic_accept_irq+0xb33/0xb50 arch/x86/kvm/lapic.c:905
[...] kvm_apic_set_irq+0x10e/0x180 arch/x86/kvm/lapic.c:495
[...] kvm_irq_delivery_to_apic+0x732/0xc10 arch/x86/kvm/irq_comm.c:86
[...] ioapic_service+0x41d/0x760 arch/x86/kvm/ioapic.c:360
[...] ioapic_set_irq+0x275/0x6c0 arch/x86/kvm/ioapic.c:222
[...] kvm_ioapic_inject_all arch/x86/kvm/ioapic.c:235
[...] kvm_set_ioapic+0x223/0x310 arch/x86/kvm/ioapic.c:670
[...] kvm_vm_ioctl_set_irqchip arch/x86/kvm/x86.c:3668
[...] kvm_arch_vm_ioctl+0x1a08/0x23c0 arch/x86/kvm/x86.c:3999
[...] kvm_vm_ioctl+0x1fa/0x1a70 arch/x86/kvm/../../../virt/kvm/kvm_main.c:3099
Fixes: af1bae5497b9 ("KVM: x86: bump KVM_MAX_VCPU_ID to 1023")
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
em_jmp_far and em_ret_far assumed that setting IP can only fail in 64
bit mode, but syzkaller proved otherwise (and SDM agrees).
Code segment was restored upon failure, but it was left uninitialized
outside of long mode, which could lead to a leak of host kernel stack.
We could have fixed that by always saving and restoring the CS, but we
take a simpler approach and just break any guest that manages to fail
as the error recovery is error-prone and modern CPUs don't need emulator
for this.
Found by syzkaller:
WARNING: CPU: 2 PID: 3668 at arch/x86/kvm/emulate.c:2217 em_ret_far+0x428/0x480
Kernel panic - not syncing: panic_on_warn set ...
CPU: 2 PID: 3668 Comm: syz-executor Not tainted 4.9.0-rc4+ #49
Call Trace:
[...] __dump_stack lib/dump_stack.c:15
[...] dump_stack+0xb3/0x118 lib/dump_stack.c:51
[...] panic+0x1b7/0x3a3 kernel/panic.c:179
[...] __warn+0x1c4/0x1e0 kernel/panic.c:542
[...] warn_slowpath_null+0x2c/0x40 kernel/panic.c:585
[...] em_ret_far+0x428/0x480 arch/x86/kvm/emulate.c:2217
[...] em_ret_far_imm+0x17/0x70 arch/x86/kvm/emulate.c:2227
[...] x86_emulate_insn+0x87a/0x3730 arch/x86/kvm/emulate.c:5294
[...] x86_emulate_instruction+0x520/0x1ba0 arch/x86/kvm/x86.c:5545
[...] emulate_instruction arch/x86/include/asm/kvm_host.h:1116
[...] complete_emulated_io arch/x86/kvm/x86.c:6870
[...] complete_emulated_mmio+0x4e9/0x710 arch/x86/kvm/x86.c:6934
[...] kvm_arch_vcpu_ioctl_run+0x3b7a/0x5a90 arch/x86/kvm/x86.c:6978
[...] kvm_vcpu_ioctl+0x61e/0xdd0 arch/x86/kvm/../../../virt/kvm/kvm_main.c:2557
[...] vfs_ioctl fs/ioctl.c:43
[...] do_vfs_ioctl+0x18c/0x1040 fs/ioctl.c:679
[...] SYSC_ioctl fs/ioctl.c:694
[...] SyS_ioctl+0x8f/0xc0 fs/ioctl.c:685
[...] entry_SYSCALL_64_fastpath+0x1f/0xc2
Fixes: d1442d85cc30 ("KVM: x86: Handle errors when RIP is set during far jumps")
Cluster xAPIC delivery incorrectly assumed that dest_id <= 0xff.
With enabled KVM_X2APIC_API_USE_32BIT_IDS in KVM_CAP_X2APIC_API, a
userspace can send an interrupt with dest_id that results in
out-of-bounds access.
Found by syzkaller:
BUG: KASAN: slab-out-of-bounds in kvm_irq_delivery_to_apic_fast+0x11fa/0x1210 at addr ffff88003d9ca750
Read of size 8 by task syz-executor/22923
CPU: 0 PID: 22923 Comm: syz-executor Not tainted 4.9.0-rc4+ #49
Call Trace:
[...] kasan_object_err+0x1c/0x70 mm/kasan/report.c:156
[...] print_address_description mm/kasan/report.c:194
[...] kasan_report_error mm/kasan/report.c:283
[...] kasan_report+0x231/0x500 mm/kasan/report.c:303
[...] __asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:329
[...] kvm_irq_delivery_to_apic_fast+0x11fa/0x1210 arch/x86/kvm/lapic.c:824
[...] kvm_irq_delivery_to_apic+0x132/0x9a0 arch/x86/kvm/irq_comm.c:72
[...] kvm_set_msi+0x111/0x160 arch/x86/kvm/irq_comm.c:157
[...] kvm_send_userspace_msi+0x201/0x280 arch/x86/kvm/../../../virt/kvm/irqchip.c:74
[...] kvm_vm_ioctl+0xba5/0x1670 arch/x86/kvm/../../../virt/kvm/kvm_main.c:3015
Fixes: e45115b62f9a ("KVM: x86: use physical LAPIC array for logical x2APIC")
'm_io' is stored in 6 bits so it's a number in the 0-63 range. Static
analysis tools complain that 1 << 63 will wrap so I have changed it to
1ULL << m_io.
This code is over three years old so presumably the bug doesn't happen
very frequently in real life or someone would have complained by now.
Cc: Alex Thorlton <athorlton@sgi.com>
Cc: Dimitri Sivanich <sivanich@sgi.com>
Cc: Mike Travis <travis@sgi.com>
Cc: Nathan Zimmer <nzimmer@sgi.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: kernel-janitors@vger.kernel.org
Fixes: b15cc4a12bed ("x86, uv, uv3: Update x2apic Support for SGI UV3")
Link: http://lkml.kernel.org/r/20161123221908.GA23997@mwanda
Commit:
90954e7b9407 ("x86/coredump: Use pr_reg size, rather that TIF_IA32 flag")
changed the coredumping code to construct the elf coredump file according
to register set size - and that's good: if binary crashes with 32-bit code
selector, generate 32-bit ELF core, otherwise - 64-bit core.
That was made for restoring 32-bit applications on x86_64: we want
32-bit application after restore to generate 32-bit ELF dump on crash.
All was quite good and recently I started reworking 32-bit applications
dumping part of CRIU: now it has two parasites (32 and 64) for seizing
compat/native tasks, after rework it'll have one parasite, working in
64-bit mode, to which 32-bit prologue long-jumps during infection.
And while it has worked for my work machine, in VM with
!CONFIG_X86_X32_ABI during reworking I faced that segfault in 32-bit
binary, that has long-jumped to 64-bit mode results in dereference
of garbage:
32-victim[19266]: segfault at f775ef65 ip 00000000f775ef65 sp 00000000f776aa50 error 14
BUG: unable to handle kernel paging request at ffffffffffffffff
IP: [<ffffffff81332ce0>] strlen+0x0/0x20
Call Trace:
[] elf_core_dump+0x11a9/0x1480
[] do_coredump+0xa6b/0xe60
[] get_signal+0x1a8/0x5c0
[] do_signal+0x23/0x660
[] exit_to_usermode_loop+0x34/0x65
[] prepare_exit_to_usermode+0x2f/0x40
[] retint_user+0x8/0x10
That's because we have 64-bit registers set (with according total size)
and we're writing it to elf_thread_core_info which has smaller size
on !CONFIG_X86_X32_ABI. That lead to overwriting ELF notes part.
Tested on 32-, 64-bit ELF crashes and on 32-bit binaries that have
jumped with 64-bit code selector - all is readable with gdb.
Fixes: 90954e7b9407 ("x86/coredump: Use pr_reg size, rather that TIF_IA32 flag")
Pull perf fixes from Ingo Molnar:
"Six fixes for bugs that were found via fuzzing, and a trivial
hw-enablement patch for AMD Family-17h CPU PMUs"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/intel/uncore: Allow only a single PMU/box within an events group
perf/x86/intel: Cure bogus unwind from PEBS entries
perf/x86: Restore TASK_SIZE check on frame pointer
perf/core: Fix address filter parser
perf/x86: Add perf support for AMD family-17h processors
perf/x86/uncore: Fix crash by removing bogus event_list[] handling for SNB client uncore IMC
perf/core: Do not set cpuctx->cgrp for unscheduled cgroups
"Misc fixes:
- two fixes to make (very) old Intel CPUs boot reliably
- fix the intel-mid driver and rename it
- two KASAN false positive fixes
- an FPU fix
- two sysfb fixes
- two build fixes related to new toolchain versions"
x86/platform/intel-mid: Rename platform_wdt to platform_mrfld_wdt
x86/build: Build compressed x86 kernels as PIE when !CONFIG_RELOCATABLE as well
x86/platform/intel-mid: Register watchdog device after SCU
x86/fpu: Fix invalid FPU ptrace state after execve()
x86/boot: Fail the boot if !M486 and CPUID is missing
x86/traps: Ignore high word of regs->cs in early_fixup_exception()
x86/dumpstack: Prevent KASAN false positive warnings
x86/boot: Avoid warning for zero-filling .bss
x86/sysfb: Fix lfb_size calculation
x86/sysfb: Add support for 64bit EFI lfb_base
Group validation expects all events to be of the same PMU; however
is_uncore_pmu() is too wide, it matches _all_ uncore events, even
across PMUs.
This triggers failure when we group different events from different
uncore PMUs, like:
perf stat -vv -e '{uncore_cbox_0/config=0x0334/,uncore_qpi_0/event=1/}' -a sleep 1
Fix is_uncore_pmu() by only matching events to the box at hand.
Note that generic code; ran after this step; will disallow this
mixture of PMU events.
Reported-by: Jiri Olsa <jolsa@redhat.com>
Tested-by: Jiri Olsa <jolsa@redhat.com>
Cc: Kan Liang <kan.liang@intel.com>
Cc: Vince Weaver <vince@deater.net>
Link: http://lkml.kernel.org/r/20161118125354.GQ3117@twins.programming.kicks-ass.net
Vince Weaver reported that perf_fuzzer + KASAN detects that PEBS event
unwinds sometimes do 'weird' things. In particular, we seemed to be
ending up unwinding from random places on the NMI stack.
While it was somewhat expected that the event record BP,SP would not
match the interrupt BP,SP in that the interrupt is strictly later than
the record event, it was overlooked that it could be on an already
overwritten stack.
Therefore, don't copy the recorded BP,SP over the interrupted BP,SP
when we need stack unwinds.
Note that its still possible the unwind doesn't full match the actual
event, as its entirely possible to have done an (I)RET between record
and interrupt, but on average it should still point in the general
direction of where the event came from. Also, it's the best we can do,
considering.
The particular scenario that triggered the bogus NMI stack unwind was
a PEBS event with very short period, upon enabling the event at the
tail of the PMI handler (FREEZE_ON_PMI is not used), it instantly
triggers a record (while still on the NMI stack) which in turn
triggers the next PMI. This then causes back-to-back NMIs and we'll
try and unwind the stack-frame from the last NMI, which obviously is
now overwritten by our own.
Analyzed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Cc: Stephane Eranian <eranian@gmail.com>
Cc: davej@codemonkey.org.uk <davej@codemonkey.org.uk>
Cc: dvyukov@google.com <dvyukov@google.com>
Fixes: ca037701a025 ("perf, x86: Add PEBS infrastructure")
Link: http://lkml.kernel.org/r/20161117171731.GV3157@twins.programming.kicks-ass.net
The following commit:
75925e1ad7f5 ("perf/x86: Optimize stack walk user accesses")
... switched from copy_from_user_nmi() to __copy_from_user_nmi() with a manual
access_ok() check.
Unfortunately, copy_from_user_nmi() does an explicit check against TASK_SIZE,
whereas the access_ok() uses whatever the current address limit of the task is.
We are getting NMIs when __probe_kernel_read() has switched to KERNEL_DS, and
then see vmalloc faults when we access what looks like pointers into vmalloc
space:
[] WARNING: CPU: 3 PID: 3685731 at arch/x86/mm/fault.c:435 vmalloc_fault+0x289/0x290
[] CPU: 3 PID: 3685731 Comm: sh Tainted: G W 4.6.0-5_fbk1_223_gdbf0f40 #1
[] Call Trace:
[] <NMI> [<ffffffff814717d1>] dump_stack+0x4d/0x6c
[] [<ffffffff81076e43>] __warn+0xd3/0xf0
[] [<ffffffff81076f2d>] warn_slowpath_null+0x1d/0x20
[] [<ffffffff8104a899>] vmalloc_fault+0x289/0x290
[] [<ffffffff8104b5a0>] __do_page_fault+0x330/0x490
[] [<ffffffff8104b70c>] do_page_fault+0xc/0x10
[] [<ffffffff81794e82>] page_fault+0x22/0x30
[] [<ffffffff81006280>] ? perf_callchain_user+0x100/0x2a0
[] [<ffffffff8115124f>] get_perf_callchain+0x17f/0x190
[] [<ffffffff811512c7>] perf_callchain+0x67/0x80
[] [<ffffffff8114e750>] perf_prepare_sample+0x2a0/0x370
[] [<ffffffff8114e840>] perf_event_output+0x20/0x60
[] [<ffffffff8114aee7>] ? perf_event_update_userpage+0xc7/0x130
[] [<ffffffff8114ea01>] __perf_event_overflow+0x181/0x1d0
[] [<ffffffff8114f484>] perf_event_overflow+0x14/0x20
[] [<ffffffff8100a6e3>] intel_pmu_handle_irq+0x1d3/0x490
[] [<ffffffff8147daf7>] ? copy_user_enhanced_fast_string+0x7/0x10
[] [<ffffffff81197191>] ? vunmap_page_range+0x1a1/0x2f0
[] [<ffffffff811972f1>] ? unmap_kernel_range_noflush+0x11/0x20
[] [<ffffffff814f2056>] ? ghes_copy_tofrom_phys+0x116/0x1f0
[] [<ffffffff81040d1d>] ? x2apic_send_IPI_self+0x1d/0x20
[] [<ffffffff8100411d>] perf_event_nmi_handler+0x2d/0x50
[] [<ffffffff8101ea31>] nmi_handle+0x61/0x110
[] [<ffffffff8101ef94>] default_do_nmi+0x44/0x110
[] [<ffffffff8101f13b>] do_nmi+0xdb/0x150
[] [<ffffffff81795187>] end_repeat_nmi+0x1a/0x1e
[] <<EOE>> <IRQ> [<ffffffff8115d05e>] ? __probe_kernel_read+0x3e/0xa0
Fix this by moving the valid_user_frame() check to before the uaccess
that loads the return address and the pointer to the next frame.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Fixes: 75925e1ad7f5 ("perf/x86: Optimize stack walk user accesses")
Rename the watchdog platform library file to explicitly show that is used only
on Intel Merrifield platforms.
Link: http://lkml.kernel.org/r/20161118172723.179761-1-andriy.shevchenko@linux.intel.com
Since the bootloader may load the compressed x86 kernel at any address,
it should always be built as PIE, not just when CONFIG_RELOCATABLE=y.
Otherwise, linker in binutils 2.27 will optimize GOT load into the
absolute address when building the compressed x86 kernel as a non-PIE
executable.
Signed-off-by: H.J. Lu <hjl.tools@gmail.com>
[ Small wording changes. ]
Watchdog device in Intel Tangier relies on SCU to be present. It uses the SCU
IPC channel to send commands and receive responses. If watchdog driver is
initialized quite before SCU and a command has been sent the result is always
an error like the following:
intel_mid_wdt: Error stopping watchdog: 0xffffffed
Register watchdog device whne SCU is ready to avoid described issue.
Link: http://lkml.kernel.org/r/20161118165224.175514-1-andriy.shevchenko@linux.intel.com
[ Small cleanups. ]
Robert O'Callahan reported that after an execve PTRACE_GETREGSET
NT_X86_XSTATE continues to return the pre-exec register values
until the exec'ed task modifies FPU state.
The test code is at:
https://bugzilla.redhat.com/attachment.cgi?id=1164286.
What is happening is fpu__clear() does not properly clear fpstate.
Fix it by doing just that.
Reported-by: Robert O'Callahan <robert@ocallahan.org>
Signed-off-by: Yu-cheng Yu <yu-cheng.yu@intel.com>
Cc: <stable@vger.kernel.org>
Cc: Borislav Petkov <bp@suse.de>
Cc: David Hansen <dave.hansen@linux.intel.com>
Cc: Ravi V. Shankar <ravi.v.shankar@intel.com>
Link: http://lkml.kernel.org/r/1479402695-6553-1-git-send-email-yu-cheng.yu@intel.com
Linux will have all kinds of sporadic problems on systems that don't
have the CPUID instruction unless CONFIG_M486=y. In particular,
sync_core() will explode.
I believe that these kernels had a better chance of working before
commit 05fb3c199bb0 ("x86/boot: Initialize FPU and X86_FEATURE_ALWAYS
even if we don't have CPUID"). That commit inadvertently fixed a
serious bug: we used to fail to detect the FPU if CPUID wasn't
present. Because we also used to forget to set X86_FEATURE_ALWAYS, we
end up with no cpu feature bits set at all. This meant that
alternative patching didn't do anything and, if paravirt was disabled,
we could plausibly finish the entire boot process without calling
sync_core().
Rather than trying to work around these issues, just have the kernel
fail loudly if it's running on a CPUID-less 486, doesn't have CPUID,
and doesn't have CONFIG_M486 set.
Reported-by: Matthew Whitehead <tedheadster@gmail.com>
Link: http://lkml.kernel.org/r/70eac6639f23df8be5fe03fa1984aedd5d40077a.1479598603.git.luto@kernel.org
On the 80486 DX, it seems that some exceptions may leave garbage in
the high bits of CS. This causes sporadic failures in which
early_fixup_exception() refuses to fix up an exception.
As far as I can tell, this has been buggy for a long time, but the
problem seems to have been exacerbated by commits:
1e02ce4cccdc ("x86: Store a per-cpu shadow copy of CR4")
e1bfc11c5a6f ("x86/init: Fix cr4_init_shadow() on CR4-less machines")
This appears to have broken for as long as we've had early
exception handling.
[ Note to stable maintainers: This patch is needed all the way back to 3.4,
but it will only apply to 4.6 and up, as it depends on commit:
0e861fbb5bda ("x86/head: Move early exception panic code into early_fixup_exception()")
If you want to backport to kernels before 4.6, please don't backport the
prerequisites (there was a big chain of them that rewrote a lot of the
early exception machinery); instead, ask me and I can send you a one-liner
that will apply. ]
Fixes: 4c5023a3fa2e ("x86-32: Handle exception table entries during early boot")
Link: http://lkml.kernel.org/r/cb32c69920e58a1a58e7b5cad975038a69c0ce7d.1479609510.git.luto@kernel.org
"ARM:
- Fix handling of the 32bit cycle counter
- Fix cycle counter filtering
x86:
- Fix a race leading to double unregistering of user notifiers
- Amend oversight in kvm_arch_set_irq that turned Hyper-V code dead
- Use SRCU around kvm_lapic_set_vapic_addr
- Avoid recursive flushing of asynchronous page faults
- Do not rely on deferred update in KVM_GET_CLOCK, which fixes #GP
- Let userspace know that KVM_GET_CLOCK is useful with master clock;
4.9 changed the return value to better match the guest clock, but
didn't provide means to let guests take advantage of it"
kvm: x86: merge kvm_arch_set_irq and kvm_arch_set_irq_inatomic
KVM: x86: fix missed SRCU usage in kvm_lapic_set_vapic_addr
KVM: async_pf: avoid recursive flushing of work items
kvm: kvmclock: let KVM_GET_CLOCK return whether the master clock is in use
KVM: Disable irq while unregistering user notifier
KVM: x86: do not go through vcpu in __get_kvmclock_ns
KVM: arm64: Fix the issues when guest PMCCFILTR is configured
arm64: KVM: pmu: Fix AArch32 cycle counter access
kvm_arch_set_irq is unused since commit b97e6de9c96. Merge
its functionality with kvm_arch_set_irq_inatomic.
Reported-by: Jiang Biao <jiang.biao2@zte.com.cn>
Reported by syzkaller:
[ INFO: suspicious RCU usage. ]
4.9.0-rc4+ #47 Not tainted
./include/linux/kvm_host.h:536 suspicious rcu_dereference_check() usage!
stack backtrace:
CPU: 1 PID: 6679 Comm: syz-executor Not tainted 4.9.0-rc4+ #47
ffff880039e2f6d0 ffffffff81c2e46b ffff88003e3a5b40 0000000000000000
0000000000000001 ffffffff83215600 ffff880039e2f700 ffffffff81334ea9
ffffc9000730b000 0000000000000004 ffff88003c4f8420 ffff88003d3f8000
Call Trace:
[< inline >] __dump_stack lib/dump_stack.c:15
[<ffffffff81c2e46b>] dump_stack+0xb3/0x118 lib/dump_stack.c:51
[<ffffffff81334ea9>] lockdep_rcu_suspicious+0x139/0x180 kernel/locking/lockdep.c:4445
[< inline >] __kvm_memslots include/linux/kvm_host.h:534
[< inline >] kvm_memslots include/linux/kvm_host.h:541
[<ffffffff8105d6ae>] kvm_gfn_to_hva_cache_init+0xa1e/0xce0 virt/kvm/kvm_main.c:1941
[<ffffffff8112685d>] kvm_lapic_set_vapic_addr+0xed/0x140 arch/x86/kvm/lapic.c:2217
Fixes: fda4e2e85589191b123d31cdc21fd33ee70f50fd
Cc: Andrew Honig <ahonig@google.com>
Userspace can read the exact value of kvmclock by reading the TSC
and fetching the timekeeping parameters out of guest memory. This
however is brittle and not necessary anymore with KVM 4.11. Provide
a mechanism that lets userspace know if the new KVM_GET_CLOCK
semantics are in effect, and---since we are at it---if the clock
is stable across all VCPUs.
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Function user_notifier_unregister should be called only once for each
registered user notifier.
Function kvm_arch_hardware_disable can be executed from an IPI context
which could cause a race condition with a VCPU returning to user mode
and attempting to unregister the notifier.
Signed-off-by: Ignacio Alvarado <ikalvarado@google.com>
Fixes: 18863bdd60f8 ("KVM: x86 shared msr infrastructure")
Going through the first VCPU is wrong if you follow a KVM_SET_CLOCK with
a KVM_GET_CLOCK immediately after, without letting the VCPU run and
call kvm_guest_time_update.
To fix this, compute the kvmclock value ourselves, using the master
clock (tsc, nsec) pair as the base and the host CPU frequency as
the scale.
Reported-by: Marcelo Tosatti <mtosatti@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild fixes from Michal Marek:
"Here are some regression fixes for kbuild:
- modversion support for exported asm symbols (Nick Piggin). The
affected architectures need separate patches adding
asm-prototypes.h.
- fix rebuilds of lib-ksyms.o (Nick Piggin)
- -fno-PIE builds (Sebastian Siewior and Borislav Petkov). This is
not a kernel regression, but one of the Debian gcc package.
Nevertheless, it's quite annoying, so I think it should go into
mainline and stable now"
* 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: Steal gcc's pie from the very beginning
kbuild: be more careful about matching preprocessed asm ___EXPORT_SYMBOL
x86/kexec: add -fno-PIE
scripts/has-stack-protector: add -fno-PIE
kbuild: add -fno-PIE
kbuild: prevent lib-ksyms.o rebuilds
This patch enables perf core PMU support for the new AMD family-17h processors.
In family-17h, there is no PMC-event constraint. All events, irrespective of
the type, can be measured using any of the six generic performance counters.
Signed-off-by: Janakarajan Natarajan <Janakarajan.Natarajan@amd.com>
Acked-by: Borislav Petkov <bp@suse.de>
Cc: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Link: http://lkml.kernel.org/r/1479399306-13375-1-git-send-email-Janakarajan.Natarajan@amd.com
The oops stack dump code scans the entire stack, which can cause KASAN
"stack-out-of-bounds" false positive warnings. Tell KASAN to ignore it.
Link: http://lkml.kernel.org/r/5f6e80c4b0c7f7f0b6211900847a247cdaad753c.1479398226.git.jpoimboe@redhat.com
The guess unwinder scans the entire stack, which can cause KASAN
Reported-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/61939c0b2b2d63ce97ba59cba3b00fd47c2962cf.1479398226.git.jpoimboe@redhat.com
The latest binutils are warning about a .fill directive with an explicit
value in a .bss section:
arch/x86/kernel/head_32.S: Assembler messages:
arch/x86/kernel/head_32.S:677: Warning: ignoring fill value in section `.bss..page_aligned'
arch/x86/kernel/head_32.S:679: Warning: ignoring fill value in section `.bss..page_aligned'
This comes from the 'ENTRY()' macro padding the space between the symbols
with 'nop' via:
.align 4,0x90
Open-coding the .globl directive without the padding avoids that warning,
as all the symbols are already page aligned.
Link: http://lkml.kernel.org/r/20161116141726.2013389-1-arnd@arndb.de
client uncore IMC
Vince Weaver reported the following bug when KASAN is enabled:
[ 205.748005] BUG: KASAN: slab-out-of-bounds in snb_uncore_imc_event_del+0x6c/0xa0 at addr ffff8800caa43768
[ 205.758324] Read of size 8 by task perf_fuzzer/6618
It's caused by accessing box->event_list.
For client IMC, there are no generic counters. It defines its own fixed
free running counters. So event_list and n_events are unused.
They can be removed safely, which fixes the bug.
( There's still the separate question of how uninitialized state snuck into
this data structure - but that's a separate fix. )
Tested-by: Vince Weaver <vincent.weaver@maine.edu>
Signed-off-by: Kan Liang <kan.liang@intel.com>
Cc: acme@kernel.org
Cc: eranian@gmail.com
Link: http://lkml.kernel.org/r/1479235210-29090-1-git-send-email-kan.liang@intel.com
The screen_info.lfb_size field is shifted by 16 bits *only* in case of
VBE. This has historical reasons since VBE advertised it similarly.
However, in case of EFI framebuffers, the size is no longer shifted. Fix
the x86 simple-framebuffer setup code to use the correct size in the
non-VBE case.
While at it, avoid variable abbreviations and rename 'len' to 'length',
and use the correct types matching the screen_info definition.
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Cc: Matt Fleming <matt.fleming@intel.com>
Cc: Tom Gundersen <teg@jklm.no>
Link: http://lkml.kernel.org/r/20161115120158.15388-3-dh.herrmann@gmail.com
The screen_info object was extended to support 64-bit lfb_base addresses
in:
ae2ee627dc87 ("efifb: Add support for 64-bit frame buffer addresses")
However, the x86 simple-framebuffer setup code never made use of it. Fix
it to properly assemble and verify the lfb_base before advertising
simple-framebuffer devices.
In particular, this means if VIDEO_CAPABILITY_64BIT_BASE is set, the
screen_info->ext_lfb_base field will contain the upper 32bit of the
actual lfb_base. Make sure the address is not 0 (i.e., unset), as well as
does not overflow the physical address type.
Link: http://lkml.kernel.org/r/20161115120158.15388-2-dh.herrmann@gmail.com
"Misc fixes:
- fix an Intel/MID boot crash/hang bug
- fix a cache topology mis-parsing bug on certain AMD CPUs
- fix a virtualization firmware bug by adding a check+quirk
workaround on the kernel side"
x86/cpu/AMD: Fix cpu_llc_id for AMD Fam17h systems
x86/platform/intel-mid: Retrofit pci_platform_pm_ops ->get_state hook
"An uncore PMU driver hardware enablement change for Intel SkyLake
uncore PMUs (Skylake Y, U, H and S platforms), plus a number of
tooling fixes for the histogram handling/displaying code"
perf/x86/intel/uncore: Add more Intel uncore IMC PCI IDs for SkyLake
perf hists: Fix column length on --hierarchy
perf hists browser: Fix column indentation on --hierarchy
perf hists browser: Show folded sign properly on --hierarchy
perf hists browser: Fix indentation of folded sign on --hierarchy
perf hist browser: Fix hierarchy column counts
Booting an EFI mixed mode kernel has been crashing since commit:
e37e43a497d5 ("x86/mm/64: Enable vmapped stacks (CONFIG_HAVE_ARCH_VMAP_STACK=y)")
The user-visible effect in my test setup was the kernel being unable
to find the root file system ramdisk. This was likely caused by silent
memory or page table corruption.
Enabling CONFIG_DEBUG_VIRTUAL=y immediately flagged the thunking code as
abusing virt_to_phys() because it was passing addresses that were not
part of the kernel direct mapping.
Use the slow version instead, which correctly handles all memory
regions by performing a page table walk.
Suggested-by: Andy Lutomirski <luto@amacapital.net>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: linux-efi@vger.kernel.org
Link: http://lkml.kernel.org/r/20161112210424.5157-3-matt@codeblueprint.co.uk
