The genapic field and the accessor macro weren't used anywhere.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Andi Kleen <ak@suse.de>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
I noticed that some lowlevel send_IPI_mask helpers had a hotplug/preempt
race whereupon the cpu_online_map was read before disabling preemption;
cpumask_t mask = cpu_online_map;
int cpu = get_cpu();
cpu_clear(cpu, mask);
But then i realised that there is no need for these lowlevel functions to
be going through all this trouble when all the callers are already made
hotplug/preempt safe.
Signed-off-by: Zwane Mwaikambo <zwane@arm.linux.org.uk>
No x86-64 chipset has this bug
Generated code doesn't change because it was always disabled.
Need to ensure we dont get prempted when we clear ourself from mask when using
clustered mode genapic code.
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
Acked-by: Andi Kleen <ak@muc.de>
infrastructure for it.
Let it rip!
